Beagleboard with USB OTG
Guru 20755 points
Other Parts Discussed in Thread: OMAP3530, DAC7512, TCA6416, LM8323, PCF8574, LM63, LM70, LM73, LM77, LM80, LM83, LM87, LM90, LM92, LM93, LM95241, ADS7828, ADS7871, AMC6821, TMP102, TMP401, TMP421, TPS65010, TWL6030, BQ24022, LP3971, LP3972, TPS65023, TLV320AIC23B, TVP5150, TVP7002, THS7303, DA8XX, LP3944, LP5521, LP5523, DAC124S085
Texas Instruments X-Loader 1.5.0 (Jun 14 2011 - 22:04:07)
Beagle Rev C5
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.06-rc2 (Jan 15 2015 - 11:12:37)
, CPU-OPP2 L3-165MHz
OMAP3 Beagle board + LPDDR/NAND
DRAM:  256 MB
NAND:  512 MiB
In:    serial
Out:   serial
Err:   serial
Board revision Ax/Bx
Die ID #74aa000700000000015a676401014023
Hit any key to stop autoboot:  0
mmc1 is available
reading uImage
3064968 bytes read
## Booting kernel from Legacy Image at 80300000 ...
   Image Name:   Linux-2.6.37
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3064904 Bytes =  2.9 MB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Linux version 2.6.37 (ubuntu@ubuntu-laptop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #5 Thu Jan 15 13:40:05 IST 2015
[    0.000000] CPU: ARMv7 Processor [411fc087] revision 7 (ARMv7), cr=10c53c7f
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: OMAP3 Beagle Board
[    0.000000] Reserving 4194304 bytes SDRAM for VRAM
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] OMAP3430/3530 ES3.1.2 (l2cache iva sgx neon isp 720mhz )
[    0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 64000
[    0.000000] Kernel command line: console=ttyO2,115200n8 root=/dev/mmcblk0p2 rw rootwait
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 252MB = 252MB total
[    0.000000] Memory: 242452k/242452k available, 19692k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
[    0.000000]     vmalloc : 0xd0800000 - 0xf8000000   ( 632 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .init : 0xc0008000 - 0xc003a000   ( 200 kB)
[    0.000000]       .text : 0xc003a000 - 0xc05abf00   (5576 kB)
[    0.000000]       .data : 0xc05ac000 - 0xc07681a0   (1777 kB)
[    0.000000] NR_IRQS:409
[    0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
[    0.000000] omap_hwmod: i2c1: softreset failed (waited 10000 usec)
[    0.000000] omap_hwmod: i2c2: softreset failed (waited 10000 usec)
[    0.000000] omap_hwmod: i2c3: softreset failed (waited 10000 usec)
[    0.000000] Reprogramming SDRC clock to 332000000 Hz
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[    0.000000] Total of 96 interrupts on 1 active controller
[    0.000000] GPMC revision 5.0
[    0.000000] Trying to install interrupt handler for IRQ402
[    0.000000] Trying to install interrupt handler for IRQ403
[    0.000000] Trying to install interrupt handler for IRQ404
[    0.000000] Trying to install interrupt handler for IRQ405
[    0.000000] Trying to install interrupt handler for IRQ406
[    0.000000] Trying to install interrupt handler for IRQ407
[    0.000000] Trying to install interrupt handler for IRQ408
[    0.000000] Trying to install type control for IRQ409
[    0.000000] Trying to set irq flags for IRQ409
[    0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[    0.000000] Console: colour dummy device 80x30
[    0.000000] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[    0.000000] ... MAX_LOCKDEP_SUBCLASSES:  8
[    0.000000] ... MAX_LOCK_DEPTH:          48
[    0.000000] ... MAX_LOCKDEP_KEYS:        8191
[    0.000000] ... CLASSHASH_SIZE:          4096
[    0.000000] ... MAX_LOCKDEP_ENTRIES:     16384
[    0.000000] ... MAX_LOCKDEP_CHAINS:      32768
[    0.000000] ... CHAINHASH_SIZE:          16384
[    0.000000]  memory used by lock dependency info: 3951 kB
[    0.000000]  per task-struct memory footprint: 2304 bytes
[    0.000000] Calibrating delay loop... 458.96 BogoMIPS (lpj=1789952)
[    0.000000] pid_max: default: 32768 minimum: 301
[    0.000000] Security Framework initialized
[    0.000000] Mount-cache hash table entries: 512
[    0.000000] CPU: Testing write buffer coherency: ok
[    0.000000] devtmpfs: initialized
[    0.000000] regulator: core version 0.5
[    0.000000] regulator: dummy:
[    0.000000] NET: Registered protocol family 16
[    0.000000] OMAP GPIO hardware version 2.5
[    0.000000] omap_mux_init: Add partition: #1: core, flags: 0
[    0.000000] OMAP3 Beagle Rev: C4
[    0.000000] Found NAND on CS0
[    0.000000] Registering NAND on CS0
[    0.000000] Unable to get DVI reset GPIO
[    0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.000000] OMAP DMA hardware revision 4.0
[    0.144134] bio: create slab <bio-0> at 0
[    0.150665] Tanya: twl_init
[    0.155609] SCSI subsystem initialized
[    0.156433] Tanya:SPI fck=-1067740260, ick=-1067737408 num_chipselect=4
[    0.158935] Tanya:SPI fck=-1067740352, ick=-1067737500 num_chipselect=2
[    0.160736] Tanya:SPI fck=-1067740444, ick=-1067737592 num_chipselect=2
[    0.162475] Tanya:SPI fck=-1067740536, ick=-1067737684 num_chipselect=1
[    0.169647] usbcore: registered new interface driver usbfs
[    0.170776] usbcore: registered new interface driver hub
[    0.172241] usbcore: registered new device driver usb
[    0.178924] omap_device: omap_i2c.1: new worst case activate latency 0: 30517
[    0.189697] omap_i2c omap_i2c.1: bus 1 rev3.12 at 2600 kHz
[    0.193878] Tanya: twl_probe
[    0.200103] Tanya: twl4030_init_sih_modules
[    0.200439] Tanya: twl4030_init_sih_modules
[    0.200714] Tanya: twl4030_init_sih_modules
[    0.200988] Tanya: twl4030_init_sih_modules
[    0.201141] Tanya: twl4030_init_sih_modules
[    0.201171] Tanya: twl4030_init_sih_modules
[    0.204681] twl4030: PIH (irq 7) chaining IRQs 368..375
[    0.204925] twl4030: power (irq 373) chaining IRQs 376..383
[    0.206787] Tanya: Starting twl4030_irq_thread
[    0.206817] Tanya: Starting irq handling
[    0.208068] twl4030: gpio (irq 368) chaining IRQs 384..401
[    0.224761] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
[    0.228637] regulator: VDAC: 1800 mV normal standby
[    0.232269] regulator: VDVI: 1800 mV normal standby
[    0.236480] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
[    0.240112] regulator: VAUX3: 1800 mV normal standby
[    0.243743] regulator: VAUX4: 1800 mV normal standby
[    0.244323] omap_device: omap_i2c.1: new worst case deactivate latency 0: 30517
[    0.254241] omap_i2c omap_i2c.2: bus 2 rev3.12 at 400 kHz
[    0.268615] omap_i2c omap_i2c.3: bus 3 rev3.12 at 100 kHz
[    0.278900] Advanced Linux Sound Architecture Driver Version 1.0.23.
[    0.284179] Switching to clocksource 32k_counter
[    0.473022] musb-hdrc: version 6.0, otg (peripheral+host), debug=0
[    0.473602] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[    0.473632] HS USB OTG: no transceiver configured
[    0.473632] musb-hdrc musb-hdrc.0: musb_init_controller failed with status -19
[    0.475524] NET: Registered protocol family 2
[    0.476470] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.478820] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.479461] TCP bind hash table entries: 8192 (order: 6, 360448 bytes)
[    0.485076] TCP: Hash tables configured (established 8192 bind 8192)
[    0.485198] TCP reno registered
[    0.485229] UDP hash table entries: 128 (order: 1, 12288 bytes)
[    0.485656] UDP-Lite hash table entries: 128 (order: 1, 12288 bytes)
[    0.487091] NET: Registered protocol family 1
[    0.489105] RPC: Registered udp transport module.
[    0.489135] RPC: Registered tcp transport module.
[    0.489135] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.490478] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.493621] platform iva.0: Enabled OPP corresponding to 720MHz
[    0.497802] omap-iommu omap-iommu.0: isp registered
[    0.498931] OMAP35x  Linux PSP version 04.02.00.07 (OMAP3BEAGLE)
[    0.695159] VFS: Disk quotas dquot_6.5.2
[    0.695312] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.698791] JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.700256] msgmni has been set to 473
[    0.706054] io scheduler noop registered
[    0.706085] io scheduler deadline registered
[    0.706420] io scheduler cfq registered (default)
[    0.769042] OMAP DSS rev 2.0
[    0.769683] OMAP DISPC rev 3.0
[    0.769958] OMAP VENC rev 2
[    0.771728] OMAP DSI rev 1.0
[    1.101165] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.113647] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[    1.116485] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[    1.118469] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[    1.924835] console [ttyO2] enabled
[    1.993774] brd: module loaded
[    2.028259] loop: module loaded
[    2.040191] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.047180] omap2-nand driver initializing
[    2.052246] ONFI flash detected
[    2.055816] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron )
[    2.062957] Creating 5 MTD partitions on "omap2-nand.0":
[    2.068634] 0x000000000000-0x000000080000 : "X-Loader"
[    2.086791] 0x000000080000-0x000000260000 : "U-Boot"
[    2.102020] 0x000000260000-0x000000280000 : "U-Boot Env"
[    2.116455] 0x000000280000-0x000000680000 : "Kernel"
[    2.132568] 0x000000680000-0x000020000000 : "File System"
[    2.403686] OneNAND driver initializing
[    2.415679] usbcore: registered new interface driver asix
[    2.422424] usbcore: registered new interface driver cdc_ether
[    2.429565] usbcore: registered new interface driver net1080
[    2.436553] usbcore: registered new interface driver cdc_subset
[    2.443756] usbcore: registered new interface driver zaurus
[    2.449768] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.457153] ehci-omap.0 supply hsusb0 not found, using dummy regulator
[    2.464294] ehci-omap.0 supply hsusb1 not found, using dummy regulator
[    4.487548] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[    4.496459] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[    4.505462] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[    4.526641] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[    4.534545] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.541717] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.549377] usb usb1: Product: OMAP-EHCI Host Controller
[    4.555023] usb usb1: Manufacturer: Linux Elbit version 1.6 2.6.37 ehci_hcd
[    4.562377] usb usb1: SerialNumber: ehci-omap.0
[    4.576568] hub 1-0:1.0: USB hub found
[    4.580841] hub 1-0:1.0: 3 ports detected
[    4.613861] Initializing USB Mass Storage driver...
[    4.620300] usbcore: registered new interface driver usb-storage
[    4.626586] USB Mass Storage support registered.
[    4.632598] usbcore: registered new interface driver usbtest
[    4.644042] mice: PS/2 mouse device common for all mice
[    4.653747] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.672210] omap_device: omap_i2c.1: new worst case activate latency 0: 91552
[    4.681396] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[    4.694732] Tanya: twl4030_sih_do_edge status [0x20003]
[    4.694763]
[    4.708190] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[    4.715454] twl_rtc twl_rtc: Power up reset detected.
[    4.722808] twl_rtc twl_rtc: Enabling TWL-RTC.
[    4.729125] Tanya: twl4030_sih_do_edge status [0x20001]
[    4.729125]
[    4.736968] i2c /dev entries driver
[    4.750061] Linux media interface: v0.10
[    4.755340] Linux video capture interface: v2.00
[    4.762878] omap3isp supply VDD_CSIPHY1 not found, using dummy regulator
[    4.770111] omap3isp supply VDD_CSIPHY2 not found, using dummy regulator
[    4.777862] omap3isp omap3isp: Revision 2.0 found
[    4.783172] omap-iommu omap-iommu.0: isp: version 1.1
[    4.899047] omap_i2c omap_i2c.2: Arbitration lost
[    4.904266] mt9v113 2-003c: chip id mismatch read 0x0, expecting 0x2280
[    4.921447] isp_register_subdev_group: Unable to register subdev mt9v113
[    4.930786] usbcore: registered new interface driver uvcvideo
[    4.936889] USB Video Class driver (v1.0.0)
[    4.941864] omap_device: omap_wdt.-1: new worst case activate latency 0: 30517
[    4.952301] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[    4.960601] twl4030_wdt twl4030_wdt: Failed to register misc device
[    4.967346] twl4030_wdt: probe of twl4030_wdt failed with error -16
[    4.986267] Tanya: twl4030_sih_do_edge status [0x20003]
[    4.986267]
[    5.004425] usbcore: registered new interface driver usbhid
[    5.010528] usbhid: USB HID core driver
[    5.020812] usbcore: registered new interface driver snd-usb-audio
[    5.030792] ALSA device list:
[    5.033935]   No soundcards found.
[    5.037597] oprofile: hardware counters not available
[    5.042968] oprofile: using timer interrupt.
[    5.048095] TCP cubic registered
[    5.051574] Initializing XFRM netlink socket
[    5.056274] NET: Registered protocol family 17
[    5.061218] NET: Registered protocol family 15
[    5.066711] Registering the dns_resolver key type
[    5.072448] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[    5.082580] ThumbEE CPU extension supported.
[    5.109924] Power Management for TI OMAP3.
[    5.115203] sr_init: No PMIC hook to init smartreflex
[    5.121185] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[    5.130584] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[    5.140991] SmartReflex Class3 initialized
[    5.208282] clock: disabling unused clocks to save power
[    5.217102] platform iva.0: omap_voltage_scale: Already at the requestedrate 360000000
[    5.225555] platform mpu.0: omap_voltage_scale: Already at the requestedrate 500000000
[    5.233947] platform l3_main.0: omap_voltage_scale: Already at the requestedrate 166000000
[    5.275573] regulator_init_complete: incomplete constraints, leaving VDAC on
[    5.285034] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[    5.294403] omap_vout omap_vout: Buffer Size = 3686400
[    5.303558] omap_vout omap_vout: : registered and initialized video device 15
[    5.311187] omap_vout omap_vout: Buffer Size = 3686400
[    5.319824] omap_vout omap_vout: : registered and initialized video device 16
[    5.334259] Waiting for root device /dev/mmcblk0p2...
[    5.456420] mmc0: new high speed SDHC card at address aaaa
[    5.466003] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[    5.490356]  mmcblk0: p1 p2
[    5.572448] EXT3-fs: barriers not enabled
[    5.625091] kjournald starting.  Commit interval 5 seconds
[    5.631439] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
[    5.643585] EXT3-fs (mmcblk0p2): using internal journal
[    5.649169] EXT3-fs (mmcblk0p2): recovery complete
[    5.657531] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[    5.665557] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    5.672149] Freeing init memory: 200K
Failed to open /dev/kmsg for logging: No such file or directory
Failed to mount /sys/fs/cgroup: No such file or directory
Failed to mount /sys/fs/cgroup/systemd: No such file or directory
[    5.993072] <27>systemd[1]: Failed to enumerate cgroup controllers: No such file or directory
[    6.002319] <30>systemd[1]: systemd 37 running in system mode. (+PAM +LIBWRAP -AUDIT -SELINUX +SYSVINIT -LIBCRYPTSETUP; angstrom)
Welcome to The ֵngstrצm Distribution!
[    6.102142] <28>systemd[1]: /sbin/modprobe failed with error code 1.
[    6.113250] <30>systemd[1]: Set hostname to <beagleboard>.
[    6.134460] <28>systemd[1]: CONFIG_CGROUPS was not set when your kernel was compiled. Systems without control groups are not supported. We will now sleep for 10s, and then continue boot-up. Expect breakage and please do not file bugs. Instead fix your kernel and enable CONFIG_CGROUPS.
[   16.187103] <28>systemd[1]: No control group support available, not creating root group.
[   16.599395] <27>systemd[1]: Failed to open /dev/autofs: No such file or directory
[   16.607482] <27>systemd[1]: Failed to initialize automounter: No such file or directory
[   16.616149] <29>systemd[1]: Unit proc-sys-fs-binfmt_misc.automount entered failed state.
Starting Runtime Directory...
Starting Remount API VFS...
Starting Lock Directory...
Starting Media Directory...
Started Apply Kernel Variables                                          [  OK  ]
Started Huge Pages File System                                          [  OK  ]
Starting POSIX Message Queue File System...
Starting File System Check on Root Device...
Started Load Kernel Modules                                             [  OK  ]
Started Configuration File System                                       [  OK  ]
Started FUSE Control File System                                        [  OK  ]
[   16.939086] <30>systemd-fsck[625]: Root directory is writable, skipping check.
Started Set Up Additional Binary Formats                                [  OK  ]
Starting Debug File System...
Started Security File System                                            [  OK  ]
Starting Syslog Kernel Log Buffer Bridge...
Started Syslog Kernel Log Buffer Bridge                                 [  OK  ]
Starting udev Coldplug all Devices...
Starting udev Kernel Device Manager...
Started Runtime Directory                                               [  OK  ]
Started Remount API VFS                                                 [  OK  ]
Started Lock Directory                                                  [  OK  ]
Started Media Directory                                                 [  OK  ]
[   17.218414] <30>udevd[629]: starting version 175
Started udev Kernel Device Manager                                      [  OK  ]
Started POSIX Message Queue File System                                 [  OK  ]
Started File System Check on Root Device                                [  OK  ]
Started Debug File System                                               [  OK  ]
Starting Remount Root FS...
Starting STDOUT Syslog Bridge...
Started STDOUT Syslog Bridge                                            [  OK  ]
Started Remount Root FS                                                 [  OK  ]
Started Opkg first boot configure                                       [  OK  ]
Starting /tmp...
Started Machine ID first boot configure                                 [  OK  ]
Started /tmp                                                            [  OK  ]
Starting Load Random Seed...
Starting Recreate Volatile Files and Directories...
Started Load Random Seed                                                [  OK  ]
Started Recreate Volatile Files and Directories                         [  OK  ]
Starting Console System Startup Logging...
Starting xinetd.service...
Started Angstrom LED config                                             [  OK  ]
Starting Timestamping service...
Started Timestamping service                                            [  OK  ]
Starting Network Manager...
Started SSH Key Generation                                              [  OK  ]
Starting System Logging Service...
Starting Permit User Sessions...
Starting Login Service...
Starting Avahi mDNS/DNS-SD Stack...
Starting Periodic Command Scheduler...
Started Periodic Command Scheduler                                      [  OK  ]
Starting D-Bus System Message Bus...
Starting Disk Manager...
[   19.131164] <30>systemctl[730]: Failed to get D-Bus connection: No connection to service manager.
Started Console System Startup Logging                                  [  OK  ]
[   19.220214] <29>systemd[1]: rsyslog.service: control process exited, code=exited status=1
Failed to start [   19.379089] <29>System Logging Ssystemdervice          [1]:                 Unit rsyslog.service entered failed state.        [
FAILED]
See 'systemctl status rsyslog.service' for details.
[   19.426696] <75>/usr/sbin/crond[734]: (CRON) INFO (Syslog will be used instead of sendmail.): No such file or directory
Started Permit User Sessions                                            [  OK  ]
Failed to start Login Service                                           [FAILED]
[   19.601104] <27>systemd-logind[732]: Failed to open /sys/class/tty/tty0/active: No such file or directory
See 'systemctl status systemd-logind.service' for details.
Starting internet superserver: xinetd[   19.855804] <27>systemd-logind[732]: Failed to fully start up daemon: No such file or directory
[   19.901824] <29>systemd[1]: systemd-logind.service: main process exited, code=exited, status=1
[   20.020385] <29>systemd[1]: Unit systemd-logind.service entered failed state.
[   20.269042] <30>avahi-daemon[733]: Found user 'avahi' (UID 998) and group 'avahi' (GID 996).
[   20.537048] <30>avahi-daemon[733]: Successfully dropped root privileges.
Started D-Bus System Message Bus                                        [  OK  ]
[   20.770416] <30>avahi-daemon[733]: avahi-daemon 0.6.30 starting up.
[   21.478668] <30>udisks-daemon[736]: (process:736): GLib-WARNING **: goption.c:2168: ignoring no-arg, optional-arg or filename flags (16) on option of type 1
[   21.773986] <26>xinetd[877]: 877 {init_services} no services. Exiting...
[   21.818237] <30>NetworkManager[729]: NetworkManager[729]: <info> NetworkManager (version 0.9.2.0) is starting...
[   22.058532] <14>NetworkManager[729]: <info> NetworkManager (version 0.9.2.0) is starting...
[   22.105010] <30>NetworkManager[729]: NetworkManager[729]: <info> Read config file (null)
[   22.285491] <14>NetworkManager[729]: <info> Read config file (null)
[   23.054901] <30>load-timestamp.sh[728]: Update systemtime from /etc/timestamp
[   23.717346] <30>load-timestamp.sh[728]: Thu Jan 12 12:19:00 UTC 2012
[   23.881378] <30>udisks-daemon[736]: (udisks-daemon:736): udisks-daemon-DEBUG: Starting daemon version 1.0.4
Started xinetd.service                                                  [  OK  ]
Started Disk Manager                                                    [  OK  ]
[   24.210540] <30>avahi-daemon[733]: Successfully called chroot().
Started Avahi mDNS/DNS-SD Stack                                         [  OK  ]
[   24.474090] <30>avahi-daemon[733]: Successfully dropped remaining capabilities.
Starting Serial Getty on ttyO2...
Started Serial Getty on ttyO2                   [   24.752014] <30>                avahi-daemon        [[733]:   OK  ]
Loading service file /services/sftp-ssh.service.
[   24.858886] <30>avahi-daemon[733]: Loading service file /services/ssh.service.
[   25.108764] <30>avahi-daemon[733]: Loading service file /services/udisks.service.
[   25.154052] <30>avahi-daemon[733]: Network interface enumeration completed.
[   25.301086] <30>avahi-daemon[733]: Registering HINFO record with values 'ARMV7L'/'LINUX ELBIT VERSION 1.6'.
[   25.354919] <30>avahi-daemon[733]: Server startup complete. Host name is beagleboard.local. Local service cookie is 3063129.
[   25.519256] <30>avahi-daemon[733]: Service "beagleboard" (/services/udisks.service) successfully established.
[   25.625762] <30>avahi-daemon[733]: Service "beagleboard" (/services/ssh.service) successfully established.
[   25.649688] <30>avahi-daemon[733]: Service "beagleboard" (/services/sftp-ssh.service) successfully established.
Started udev Coldplug all Devices                                       [  OK  ]
[   25.939788] <30>dbus-daemon[820]: dbus[820]: [system] Activating service name='org.freedesktop.PolicyKit1' (using servicehelper)
[   26.035156] <29>dbus[820]: [system] Activating service name='org.freedesktop.PolicyKit1' (using servicehelper)
Starting Getty on tty1...
                         Started Getty on tty1                                                   [  OK  ]
.---O---.
|       |                  .-.           o o
|       |     | __  |  ---'| '--.|  .-'|     |     |
The Angstrom Distribution beagleboard ttyO2
Angstrom v2012.01-core - Kernel 2.6.37
beagleboard login: Starting Gnome Display Manager...
                                                    Started Gnome Display Manager                                           [  OK  ]
                                                    [   28.878479] <30>polkitd[1130]: started daemon version 0.103 using authority implementation `local' version `0.103'
[   28.897308] <30>dbus-daemon[820]: dbus[820]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
[   28.982269] <29>dbus[820]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
[   29.023040] <30>NetworkManager[729]: NetworkManager[729]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
[   29.042388] <12>NetworkManager[729]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
[   29.091064] <30>NetworkManager[729]: NetworkManager[729]: <info> Loaded plugin keyfile: (c) 2007 - 2010 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
[   29.166015] <14>NetworkManager[729]: <info> Loaded plugin keyfile: (c) 2007 - 2010 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
[   29.241699] <30>NetworkManager[729]: NetworkManager[729]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
[   29.306396] <30>udisks-daemon[736]: (udisks-daemon:736): udisks-daemon-WARNING **: No /proc/mdstat file: No such file or directory
[   29.355560] <12>NetworkManager[729]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
[   29.386962] <30>NetworkManager[729]: NetworkManager[729]:    keyfile: parsing Dominion ...
[   29.436584] <13>NetworkManager[729]: keyfile: parsing Dominion ...
Started Network Manager                         [   29.479125] <30>                udisks-daemon        [[736]:   OK  ]
                                       **** ADDING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
[   29.527465] <30>NetworkManager[729]: NetworkManager[729]:    keyfile:     read connection 'Dominion'
[   29.563140] <13>NetworkManager[729]: keyfile:     read connection 'Dominion'
[   29.573028] <30>NetworkManager[729]: NetworkManager[729]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
[   29.634735] <12>NetworkManager[729]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
[   29.655426] <30>udisks-daemon[736]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
[   29.710144] <30>NetworkManager[729]: NetworkManager[729]: <info> trying to start the modem manager...
[   29.737701] <14>NetworkManager[729]: <info> trying to start the modem manager...
r[   29.772430] <30>NetworkManager[729]: NetworkManager[729]: <info> monitoring kernel firmware directory '/lib/firmware'.
[   29.788452] <14>NetworkManager[729]: <info> monitoring kernel firmware directory '/lib/firmware'.
[   29.811981] <30>udisks-daemon[736]: **** ADDED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
[   29.839630] <30>udisks-daemon[736]: **** ADDING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
[   29.891632] <30>udisks-daemon[736]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
[   29.917846] <14>NetworkManager[729]: <info> WiFi enabled by radio killswitch; enabled by state file
o[   29.962005] <30>udisks-daemon[736]: **** ADDED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
[   30.019592] <14>NetworkManager[729]: <info> WWAN enabled by radio killswitch; enabled by state file
[   30.058410] <30>udisks-daemon[736]: **** ADDING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
o[   30.113403] <14>NetworkManager[729]: <info> WiMAX enabled by radio killswitch; enabled by state file
[   30.167083] <30>udisks-daemon[736]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
[   30.226104] <14>NetworkManager[729]: <info> Networking is enabled by state file
t[   30.266937] <30>udisks-daemon[736]: **** ADDED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
[   30.342956] <30>systemd[1]: Startup finished in 16s 471ms 244us (kernel) + 13s 597ms 725us (userspace) = 30s 68ms 969us.
[   30.370941] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/loop0
[   30.409118] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/block/loop0
[   30.426208] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/loop0
[   30.472900] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/loop1
[   30.499298] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/block/loop1
[   30.538208] <30>NetworkManager[729]: NetworkManager[729]: <info> WiFi enabled by radio killswitch; enabled by state file
[   30.569702] <30>NetworkManager[729]: NetworkManager[729]: <info> WWAN enabled by radio killswitch; enabled by state file
[   30.622497] <30>NetworkManager[729]: NetworkManager[729]: <info> WiMAX enabled by radio killswitch; enabled by state file
[   30.644378] <30>NetworkManager[729]: NetworkManager[729]: <info> Networking is enabled by state file
[   30.673034] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/loop1
[   30.693145] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/loop2
[   30.710968] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/block/loop2
[   30.725067] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/loop2
[   30.739807] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/loop3
[   30.762237] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/block/loop3
[   30.777191] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/loop3
[   30.799499] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/loop4
[   30.816253] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/block/loop4
[   30.837432] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/loop4
[   30.855316] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/loop5
[   30.868743] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/block/loop5
[   30.895782] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/loop5
[   30.914184] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/loop6
[   30.943023] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/block/loop6
[   30.968383] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/loop6
[   30.988128] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/loop7
[   30.999908] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/block/loop7
[   31.019409] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/loop7
[   31.050537] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram0
[   31.080352] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram0
[   31.096588] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram1
[   31.108154] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram1
[   31.118041] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram10
Last login: Thu Jan 12 12:19:06 GMT 2012 on ttyO2
[   31.143280] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram10
[   31.154479] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram11
[   31.163055] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram11
[   31.173797] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram12
[   31.199859] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram12
[   31.235198] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram13
[   31.255859] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram13
[   31.270904] <83>login[1120]: pam_env(login:session): Unable to open env file: /etc/default/locale: No such file or directory
[   31.300628] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram14
[   31.331848] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram14
[   31.355682] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram15
[   31.387023] <12>NetworkManager[729]: <warn> bluez error getting default adapter: The name org.bluez was not provided by any .service files
[   31.406463] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram15
[   31.417510] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram2
[   31.449523] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram2
[   31.450775] <86>login[1120]: pam_unix(login:session): session opened for user root by LOGIN(uid=0)
[   31.451202] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram3
[   31.452758] <85>login[1250]: ROOT LOGIN  on '/dev/ttyO2'
[   31.456359] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram3
[   31.456878] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram4
[   31.457244] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram4
[   31.457611] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram5
[   31.457946] <30>NetworkManager[729]: NetworkManager[729]: <warn> bluez error getting default adapter: The name org.bluez was not provided by any .service files
[   31.458282] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram5
[   31.458618] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram6
[   31.468597] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram6
[   31.469085] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram7
[   31.469482] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram7
[   31.469604] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram8
[   31.469726] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram8
[   31.469818] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/block/ram9
[   31.469940] <30>udisks-daemon[736]: **** IGNORING ADD /sys/devices/virtual/block/ram9
[   31.470062] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/mtd/mtd0/mtdblock0
[   31.470153] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/mtd/mtd0/mtdblock0
[   31.470275] <30>udisks-daemon[736]: **** ADDED /sys/devices/virtual/mtd/mtd0/mtdblock0
[   31.470367] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/mtd/mtd1/mtdblock1
[   31.470489] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/mtd/mtd1/mtdblock1
[   31.470611] <30>udisks-daemon[736]: **** ADDED /sys/devices/virtual/mtd/mtd1/mtdblock1
[   31.470703] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/mtd/mtd2/mtdblock2
[   31.683654] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/mtd/mtd2/mtdblock2
root@beagleboard[   31.697052] <30>:~#
udisks-daemon[736]: **** ADDED /sys/devices/virtual/mtd/mtd2/mtdblock2
root@beagleboard[   31.708190] <30>:~#
udisks-daemon[736]: **** ADDING /sys/devices/virtual/mtd/mtd3/mtdblock3
root@beagleboard[   31.719573] <30>:~#
udisks-daemon[736]: **** UPDATING /sys/devices/virtual/mtd/mtd3/mtdblock3
root@beagleboard[   31.730987] <30>:~# udisks-daemon[736]: **** ADDED /sys/devices/virtual/mtd/mtd3/mtdblock3
[   31.740997] <30>udisks-daemon[736]: **** ADDING /sys/devices/virtual/mtd/mtd4/mtdblock4
[   31.749847] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/mtd/mtd4/mtdblock4
[   31.758911] <30>udisks-daemon[736]: **** ADDED /sys/devices/virtual/mtd/mtd4/mtdblock4
[   31.767700] <30>udisks-daemon[736]: **** CHANGING /sys/devices/virtual/mtd/mtd0/mtdblock0
[   31.776824] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/mtd/mtd0/mtdblock0
[   31.785827] <30>udisks-daemon[736]: **** CHANGED /sys/devices/virtual/mtd/mtd0/mtdblock0
[   31.795227] <30>udisks-daemon[736]: **** CHANGING /sys/devices/virtual/mtd/mtd1/mtdblock1
[   31.804260] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/mtd/mtd1/mtdblock1
[   31.813293] <30>udisks-daemon[736]: **** CHANGED /sys/devices/virtual/mtd/mtd1/mtdblock1
[   31.822265] <30>udisks-daemon[736]: **** CHANGING /sys/devices/virtual/mtd/mtd2/mtdblock2
[   31.831390] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/mtd/mtd2/mtdblock2
[   31.840393] <30>udisks-daemon[736]: **** CHANGED /sys/devices/virtual/mtd/mtd2/mtdblock2
[   31.849334] <30>udisks-daemon[736]: **** CHANGING /sys/devices/virtual/mtd/mtd3/mtdblock3
[   31.858337] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/mtd/mtd3/mtdblock3
[   31.867370] <30>udisks-daemon[736]: **** CHANGED /sys/devices/virtual/mtd/mtd3/mtdblock3
[   31.876556] <30>udisks-daemon[736]: **** CHANGING /sys/devices/virtual/mtd/mtd4/mtdblock4
[   31.885406] <30>udisks-daemon[736]: **** UPDATING /sys/devices/virtual/mtd/mtd4/mtdblock4
[   31.894256] <30>udisks-daemon[736]: **** CHANGED /sys/devices/virtual/mtd/mtd4/mtdblock4
[   31.902954] <30>udisks-daemon[736]: **** CHANGING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
[   31.914916] <30>udisks-daemon[736]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
[   31.926971] <30>udisks-daemon[736]: **** CHANGED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
[   31.948760] <30>udisks-daemon[736]: **** CHANGING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
[   31.970153] <30>udisks-daemon[736]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
[   31.987335] <30>udisks-daemon[736]: **** CHANGED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
[   32.000976] <30>udisks-daemon[736]: **** CHANGING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
[   32.015350] <30>udisks-daemon[736]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
[   32.028594] <30>udisks-daemon[736]: **** CHANGED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~# cd [   33.821350] <30>dbus-daemon[820]: dbus[820]: [system] Activating via systemd: service name='org.freedesktop.ConsoleKit' unit='console-kit-daemon.service'
[   33.838836] <29>dbus[820]: [system] Activating via systemd: service name='org.freedesktop.ConsoleKit' unit='console-kit-daemon.service'
[   34.087005] <30>dbus-daemon[820]: dbus[820]: [system] Successfully activated service 'org.freedesktop.ConsoleKit'
[   34.119628] <29>dbus[820]: [system] Successfully activated service 'org.freedesktop.ConsoleKit'
[   35.132629] <28>gnome-session[1331]: WARNING: Failed to run gconf-sanity-check-2: Failed to execute child process "/usr/libexec/gconf-sanity-check-2" (No such file or directory)
[   35.696105] <30>NetworkManager[729]: (NetworkManager:729): GLib-GIO-WARNING **: Missing callback called fullpath = /var/run/ConsoleKit/database
[   35.822174] <28>gnome-session[1331]: WARNING: Could not launch application 'at-spi-registryd-wrapper.desktop': Unable to start application: Failed to execute child process "/usr/libexec/at-spi-registryd" (No such file or directory)
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~#
root@beagleboard:~# modprobe [   39.334136] <85>polkitd(authority=local)[1130]: Registered Authentication Agent for unix-session:/org/freedesktop/ConsoleKit/Session1 (system bus name :1.16 [/usr/libexec/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale C)
g_[   39.773468] <30>dbus-daemon[820]: dbus[820]: [system] Activating service name='org.freedesktop.UPower' (using servicehelper)
[   39.808105] <29>dbus[820]: [system] Activating service name='org.freedesktop.UPower' (using servicehelper)
et[   40.046661] <30>dbus-daemon[820]: dbus[820]: [system] Successfully activated service 'org.freedesktop.UPower'
h[   40.097900] <29>dbus[820]: [system] Successfully activated service 'org.freedesktop.UPower'
er[   40.305389] <30>dbus-daemon[820]: (upowerd:1348): UPower-WARNING **: failed to get directory: Error opening directory '/sys/class/leds': No such file or directory
[   40.367340] <30>dbus-daemon[820]: (upowerd:1348): UPower-Linux-WARNING **: failed to run script: Failed to execute child process "/usr/bin/pm-is-supported" (No such file or directory)
[   40.436218] <30>dbus-daemon[820]: (upowerd:1348): UPower-Linux-WARNING **: failed to run script: Failed to execute child process "/usr/bin/pm-is-supported" (No such file or directory)
FATAL: Error inserting g_ether (/lib/modules/2.6.37/kernel/drivers/usb/gadget/g_ether.ko): No such device
root@beagleboard:~# [   40.945129] <30>dbus-daemon[820]: (upowerd:1348): UPower-WARNING **: failed to run script: Failed to execute child process "/usr/sbin/pm-powersave" (No such file or directory)
[   42.455780] <28>gdm-simple-greeter[1342]: Gtk-WARNING: gtkwidget.c:5683: widget not within a GtkWindow
[   42.686828] omap_device: omap_uart.2: new worst case deactivate latency 0: 30517
[   42.687408] omap_device: omap_uart.0: new worst case activate latency 0: 30517
[   43.289306] omap_device: omap_uart.2: new worst case deactivate latency 0: 61035
[   43.408721] <28>gdm-simple-greeter[1342]: WARNING: Unable to load CK history: no seat-id found
de[   43.986663] <85>gdm-session-worker[1346]: pam_warn(gdm-autologin:auth): function=[pam_sm_authenticate] service=[gdm-autologin] terminal=[:0] user=[root] ruser=[<unknown>] rhost=[<unknown>]
[   44.039367] <85>gdm-session-worker[1346]: pam_warn(gdm-autologin:account): function=[pam_sm_acct_mgmt] service=[gdm-autologin] terminal=[:0] user=[root] ruser=[<unknown>] rhost=[<unknown>]
pmod -a
root@beagleboard:~# modprobe g_ether
root@beagleboard:~# [   53.666320] <85>gdm-session-worker[1346]: pam_warn(gdm-autologin:setcred): function=[pam_sm_setcred] service=[gdm-autologin] terminal=[:0] user=[root] ruser=[<unknown>] rhost=[<unknown>]
[   53.748779] <85>gdm-session-worker[1346]: pam_warn(gdm-autologin:session): function=[pam_sm_open_session] service=[gdm-autologin] terminal=[:0] user=[root] ruser=[<unknown>] rhost=[<unknown>]
[   53.814239] <86>gdm-session-worker[1346]: pam_unix(gdm-autologin:session): session opened for user root by (uid=0)
[   54.448944] <85>polkitd(authority=local)[1130]: Unregistered Authentication Agent for unix-session:/org/freedesktop/ConsoleKit/Session1 (system bus name :1.16, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale C) (disconnected from bus)
[   55.571838] <28>gnome-session[1378]: WARNING: Failed to run gconf-sanity-check-2: Failed to execute child process "/usr/libexec/gconf-sanity-check-2" (No such file or directory)
[   57.249664] <37>gnome-keyring-daemon[1400]: GLib-GIO: Using the 'memory' GSettings backend.  Your settings will not be saved or shared with other applications.
[   73.304504] <30>dbus-daemon[820]: dbus[820]: [system] Activating service name='org.gnome.SettingsDaemon.DateTimeMechanism' (using servicehelper)
[   73.381011] <29>dbus[820]: [system] Activating service name='org.gnome.SettingsDaemon.DateTimeMechanism' (using servicehelper)
[   73.788452] <30>dbus-daemon[820]: dbus[820]: [system] Successfully activated service 'org.gnome.SettingsDaemon.DateTimeMechanism'
[   73.874420] <29>dbus[820]: [system] Successfully activated service 'org.gnome.SettingsDaemon.DateTimeMechanism'
[   74.066345] <30>dbus-daemon[820]: ** (process:1441): DEBUG: Setting killtimer to 30 seconds...
[  104.718475] <30>dbus-daemon[820]: ** (process:1441): DEBUG: Exiting due to inactivity
root@beagleboard:/lib/modules# cd 2.6.37/kernel/drivers/usb/gadget/
root@beagleboard:/lib/modules/2.6.37/kernel/drivers/usb/gadget# insmod g_ether.ko
insmod: error inserting 'g_ether.ko': -1 No such device
I have trouble using ethernet usb gadget driver on the beagleboard (omap3530).
I am using SDK 4.2.0.7 for the kernel, I've compiled it with beaglebpoard config, so everything is expected to work as required on this EVM.
I have compiled both kernel and modules with ethernet gadget module enabled, but on trying to insmod the driver, I get the following;
Did anyone encounter such failure ?
Attached boot log.
Ran
  • Hi Ran,
    After compiling a modules you have to copy them to the file systems and next to insert. If they are available and you have again this problem could you try to compile these modules into the kernel to see if the problem is not in the same drivers.
    BR
    Ivan
  • Hi Ivan,
    yes I know, I did that several times, and did it from clean, but I still get same error.
    I also tried to compile the usb otg inside kernel, but I still don't get the additional usb0 with ifconfig.
    I have attached both .config and the boot log (something does not work when attaching text files, so I had to copy-paste it here).
    Do you have a beagleboard (revD) which works with PSP 04.02.00.007 with usb otg ?
    I really struglle with it, though it is actually EVM, so I don't understand what is wrong (I have some binaried in which it all works well, but I don;t have the sources for it)
    Thanks for any idea,
    Ran
    # Automatically generated make config: don't edit
    # Linux/arm 2.6.37 Kernel Configuration
    # Fri Jan 16 00:03:14 2015
    CONFIG_ARM=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_GENERIC_GPIO=y
    # CONFIG_ARCH_USES_GETTIMEOFFSET is not set
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_HAVE_PROC_CPU=y
    CONFIG_GENERIC_HARDIRQS=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_HAVE_LATENCYTOP_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_RWSEM_GENERIC_SPINLOCK=y
    CONFIG_ARCH_HAS_CPUFREQ=y
    CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_NEED_DMA_MAP_STATE=y
    CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y
    CONFIG_ARM_L1_CACHE_SHIFT_6=y
    CONFIG_VECTORS_BASE=0xffff0000
    CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
    CONFIG_CONSTRUCTORS=y
    CONFIG_HAVE_IRQ_WORK=y
    CONFIG_IRQ_WORK=y
    # General setup
    CONFIG_EXPERIMENTAL=y
    CONFIG_BROKEN_ON_SMP=y
    CONFIG_LOCK_KERNEL=y
    CONFIG_INIT_ENV_ARG_LIMIT=32
    CONFIG_CROSS_COMPILE=""
    CONFIG_LOCALVERSION=""
    # CONFIG_LOCALVERSION_AUTO is not set
    CONFIG_HAVE_KERNEL_GZIP=y
    CONFIG_HAVE_KERNEL_LZMA=y
    CONFIG_HAVE_KERNEL_LZO=y
    CONFIG_KERNEL_GZIP=y
    # CONFIG_KERNEL_LZMA is not set
    # CONFIG_KERNEL_LZO is not set
    CONFIG_SWAP=y
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    # CONFIG_POSIX_MQUEUE is not set
    CONFIG_BSD_PROCESS_ACCT=y
    # CONFIG_BSD_PROCESS_ACCT_V3 is not set
    CONFIG_TASKSTATS=y
    CONFIG_TASK_DELAY_ACCT=y
    CONFIG_TASK_XACCT=y
    CONFIG_TASK_IO_ACCOUNTING=y
    # CONFIG_AUDIT is not set
    # CONFIG_HAVE_GENERIC_HARDIRQS is not set
    # CONFIG_SPARSE_IRQ is not set
    # RCU Subsystem
    CONFIG_TREE_PREEMPT_RCU=y
    # CONFIG_TINY_RCU is not set
    # CONFIG_TINY_PREEMPT_RCU is not set
    CONFIG_PREEMPT_RCU=y
    # CONFIG_RCU_TRACE is not set
    CONFIG_RCU_FANOUT=32
    # CONFIG_RCU_FANOUT_EXACT is not set
    # CONFIG_TREE_RCU_TRACE is not set
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    CONFIG_LOG_BUF_SHIFT=16
    # CONFIG_CGROUPS is not set
    # CONFIG_NAMESPACES is not set
    # CONFIG_SYSFS_DEPRECATED is not set
    # CONFIG_RELAY is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
    # CONFIG_RD_BZIP2 is not set
    # CONFIG_RD_LZMA is not set
    # CONFIG_RD_LZO is not set
    CONFIG_CC_OPTIMIZE_FOR_SIZE=y
    CONFIG_SYSCTL=y
    CONFIG_ANON_INODES=y
    CONFIG_EMBEDDED=y
    CONFIG_UID16=y
    # CONFIG_SYSCTL_SYSCALL is not set
    CONFIG_KALLSYMS=y
    # CONFIG_KALLSYMS_ALL is not set
    # CONFIG_KALLSYMS_EXTRA_PASS is not set
    CONFIG_HOTPLUG=y
    CONFIG_PRINTK=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    CONFIG_HAVE_PERF_EVENTS=y
    CONFIG_PERF_USE_VMALLOC=y
    # Kernel Performance Events And Counters
    CONFIG_PERF_EVENTS=y
    # CONFIG_PERF_COUNTERS is not set
    # CONFIG_DEBUG_PERF_USE_VMALLOC is not set
    CONFIG_VM_EVENT_COUNTERS=y
    # CONFIG_COMPAT_BRK is not set
    CONFIG_SLAB=y
    # CONFIG_SLUB is not set
    # CONFIG_SLOB is not set
    CONFIG_PROFILING=y
    CONFIG_OPROFILE=y
    CONFIG_HAVE_OPROFILE=y
    # CONFIG_KPROBES is not set
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
    CONFIG_HAVE_CLK=y
    CONFIG_HAVE_HW_BREAKPOINT=y
    # GCOV-based kernel profiling
    # CONFIG_GCOV_KERNEL is not set
    CONFIG_HAVE_GENERIC_DMA_COHERENT=y
    CONFIG_SLABINFO=y
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
    CONFIG_MODULE_FORCE_LOAD=y
    CONFIG_MODULE_UNLOAD=y
    CONFIG_MODULE_FORCE_UNLOAD=y
    CONFIG_MODVERSIONS=y
    CONFIG_MODULE_SRCVERSION_ALL=y
    CONFIG_BLOCK=y
    CONFIG_LBDAF=y
    CONFIG_BLK_DEV_BSG=y
    # CONFIG_BLK_DEV_INTEGRITY is not set
    # IO Schedulers
    CONFIG_IOSCHED_NOOP=y
    CONFIG_IOSCHED_DEADLINE=y
    CONFIG_IOSCHED_CFQ=y
    # CONFIG_DEFAULT_DEADLINE is not set
    CONFIG_DEFAULT_CFQ=y
    # CONFIG_DEFAULT_NOOP is not set
    CONFIG_DEFAULT_IOSCHED="cfq"
    # CONFIG_INLINE_SPIN_TRYLOCK is not set
    # CONFIG_INLINE_SPIN_TRYLOCK_BH is not set
    # CONFIG_INLINE_SPIN_LOCK is not set
    # CONFIG_INLINE_SPIN_LOCK_BH is not set
    # CONFIG_INLINE_SPIN_LOCK_IRQ is not set
    # CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set
    # CONFIG_INLINE_SPIN_UNLOCK is not set
    # CONFIG_INLINE_SPIN_UNLOCK_BH is not set
    # CONFIG_INLINE_SPIN_UNLOCK_IRQ is not set
    # CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set
    # CONFIG_INLINE_READ_TRYLOCK is not set
    # CONFIG_INLINE_READ_LOCK is not set
    # CONFIG_INLINE_READ_LOCK_BH is not set
    # CONFIG_INLINE_READ_LOCK_IRQ is not set
    # CONFIG_INLINE_READ_LOCK_IRQSAVE is not set
    # CONFIG_INLINE_READ_UNLOCK is not set
    # CONFIG_INLINE_READ_UNLOCK_BH is not set
    # CONFIG_INLINE_READ_UNLOCK_IRQ is not set
    # CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set
    # CONFIG_INLINE_WRITE_TRYLOCK is not set
    # CONFIG_INLINE_WRITE_LOCK is not set
    # CONFIG_INLINE_WRITE_LOCK_BH is not set
    # CONFIG_INLINE_WRITE_LOCK_IRQ is not set
    # CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set
    # CONFIG_INLINE_WRITE_UNLOCK is not set
    # CONFIG_INLINE_WRITE_UNLOCK_BH is not set
    # CONFIG_INLINE_WRITE_UNLOCK_IRQ is not set
    # CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set
    # CONFIG_MUTEX_SPIN_ON_OWNER is not set
    CONFIG_FREEZER=y
    # System Type
    CONFIG_MMU=y
    # CONFIG_ARCH_AAEC2000 is not set
    # CONFIG_ARCH_INTEGRATOR is not set
    # CONFIG_ARCH_REALVIEW is not set
    # CONFIG_ARCH_VERSATILE is not set
    # CONFIG_ARCH_VEXPRESS is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_ARCH_BCMRING is not set
    # CONFIG_ARCH_CLPS711X is not set
    # CONFIG_ARCH_CNS3XXX is not set
    # CONFIG_ARCH_GEMINI is not set
    # CONFIG_ARCH_EBSA110 is not set
    # CONFIG_ARCH_EP93XX is not set
    # CONFIG_ARCH_FOOTBRIDGE is not set
    # CONFIG_ARCH_MXC is not set
    # CONFIG_ARCH_STMP3XXX is not set
    # CONFIG_ARCH_NETX is not set
    # CONFIG_ARCH_H720X is not set
    # CONFIG_ARCH_IOP13XX is not set
    # CONFIG_ARCH_IOP32X is not set
    # CONFIG_ARCH_IOP33X is not set
    # CONFIG_ARCH_IXP23XX is not set
    # CONFIG_ARCH_IXP2000 is not set
    # CONFIG_ARCH_IXP4XX is not set
    # CONFIG_ARCH_DOVE is not set
    # CONFIG_ARCH_KIRKWOOD is not set
    # CONFIG_ARCH_LOKI is not set
    # CONFIG_ARCH_LPC32XX is not set
    # CONFIG_ARCH_MV78XX0 is not set
    # CONFIG_ARCH_ORION5X is not set
    # CONFIG_ARCH_MMP is not set
    # CONFIG_ARCH_KS8695 is not set
    # CONFIG_ARCH_NS9XXX is not set
    # CONFIG_ARCH_W90X900 is not set
    # CONFIG_ARCH_NUC93X is not set
    # CONFIG_ARCH_TEGRA is not set
    # CONFIG_ARCH_PNX4008 is not set
    # CONFIG_ARCH_PXA is not set
    # CONFIG_ARCH_MSM is not set
    # CONFIG_ARCH_SHMOBILE is not set
    # CONFIG_ARCH_RPC is not set
    # CONFIG_ARCH_SA1100 is not set
    # CONFIG_ARCH_S3C2410 is not set
    # CONFIG_ARCH_S3C64XX is not set
    # CONFIG_ARCH_S5P64X0 is not set
    # CONFIG_ARCH_S5P6442 is not set
    # CONFIG_ARCH_S5PC100 is not set
    # CONFIG_ARCH_S5PV210 is not set
    # CONFIG_ARCH_S5PV310 is not set
    # CONFIG_ARCH_SHARK is not set
    # CONFIG_ARCH_TCC_926 is not set
    # CONFIG_ARCH_LH7A40X is not set
    # CONFIG_ARCH_U300 is not set
    # CONFIG_ARCH_U8500 is not set
    # CONFIG_ARCH_NOMADIK is not set
    # CONFIG_ARCH_DAVINCI is not set
    CONFIG_ARCH_OMAP=y
    # CONFIG_PLAT_SPEAR is not set
    # TI OMAP Common Features
    CONFIG_ARCH_OMAP_OTG=y
    # CONFIG_ARCH_OMAP1 is not set
    CONFIG_ARCH_OMAP2PLUS=y
    # OMAP Feature Selections
    CONFIG_OMAP_SMARTREFLEX=y
    # CONFIG_OMAP_SMARTREFLEX_CLASS3 is not set
    CONFIG_OMAP_RESET_CLOCKS=y
    # CONFIG_OMAP_MUX is not set
    CONFIG_OMAP_MCBSP=y
    CONFIG_OMAP_MBOX_FWK=m
    CONFIG_OMAP_MBOX_KFIFO_SIZE=256
    CONFIG_OMAP_IOMMU=y
    # CONFIG_OMAP_IOMMU_DEBUG is not set
    CONFIG_OMAP_MPU_TIMER=y
    # CONFIG_OMAP_32K_TIMER is not set
    # CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set
    CONFIG_OMAP_DM_TIMER=y
    # CONFIG_OMAP_PM_NONE is not set
    CONFIG_OMAP_PM_NOOP=y
    # TI OMAP2/3/4 Specific Features
    CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
    # CONFIG_ARCH_OMAP2 is not set
    CONFIG_ARCH_OMAP3=y
    # CONFIG_ARCH_OMAP4 is not set
    # CONFIG_ARCH_TI81XX is not set
    CONFIG_ARCH_OMAP3430=y
    CONFIG_OMAP_PACKAGE_CBB=y
    # OMAP Board Type
    CONFIG_MACH_OMAP3_BEAGLE=y
    # CONFIG_MACH_DEVKIT8000 is not set
    # CONFIG_MACH_OMAP_LDP is not set
    CONFIG_MACH_OMAP3530_LV_SOM=y
    CONFIG_MACH_OMAP3_TORPEDO=y
    # CONFIG_MACH_OVERO is not set
    # CONFIG_MACH_OMAP3EVM is not set
    # CONFIG_MACH_OMAP3517EVM is not set
    # CONFIG_MACH_CRANEBOARD is not set
    # CONFIG_MACH_OMAP3_PANDORA is not set
    # CONFIG_MACH_OMAP3_TOUCHBOOK is not set
    # CONFIG_MACH_OMAP_3430SDP is not set
    # CONFIG_MACH_NOKIA_RM680 is not set
    # CONFIG_MACH_NOKIA_RX51 is not set
    # CONFIG_MACH_OMAP_ZOOM2 is not set
    # CONFIG_MACH_OMAP_ZOOM3 is not set
    # CONFIG_MACH_CM_T35 is not set
    # CONFIG_MACH_CM_T3517 is not set
    # CONFIG_MACH_IGEP0020 is not set
    # CONFIG_MACH_IGEP0030 is not set
    # CONFIG_MACH_SBC3530 is not set
    # CONFIG_MACH_OMAP_3630SDP is not set
    # CONFIG_OMAP3_EMU is not set
    # CONFIG_OMAP3_SDRC_AC_TIMING is not set
    # Processor Type
    CONFIG_CPU_32v6K=y
    CONFIG_CPU_V7=y
    CONFIG_CPU_32v7=y
    CONFIG_CPU_ABRT_EV7=y
    CONFIG_CPU_PABRT_V7=y
    CONFIG_CPU_CACHE_V7=y
    CONFIG_CPU_CACHE_VIPT=y
    CONFIG_CPU_COPY_V6=y
    CONFIG_CPU_TLB_V7=y
    CONFIG_CPU_HAS_ASID=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    # Processor Features
    CONFIG_ARM_THUMB=y
    CONFIG_ARM_THUMBEE=y
    # CONFIG_CPU_ICACHE_DISABLE is not set
    # CONFIG_CPU_DCACHE_DISABLE is not set
    # CONFIG_CPU_BPREDICT_DISABLE is not set
    CONFIG_ARM_L1_CACHE_SHIFT=6
    CONFIG_ARM_DMA_MEM_BUFFERABLE=y
    CONFIG_ARM_ERRATA_430973=y
    # CONFIG_ARM_ERRATA_458693 is not set
    # CONFIG_ARM_ERRATA_460075 is not set
    # CONFIG_ARM_ERRATA_743622 is not set
    CONFIG_COMMON_CLKDEV=y
    # Bus support
    # CONFIG_PCI_SYSCALL is not set
    # CONFIG_ARCH_SUPPORTS_MSI is not set
    # CONFIG_PCCARD is not set
    # Kernel Features
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ=y
    CONFIG_HIGH_RES_TIMERS=y
    CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
    CONFIG_VMSPLIT_3G=y
    # CONFIG_VMSPLIT_2G is not set
    # CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0xC0000000
    # CONFIG_PREEMPT_NONE is not set
    # CONFIG_PREEMPT_VOLUNTARY is not set
    CONFIG_PREEMPT=y
    CONFIG_HZ=100
    # CONFIG_THUMB2_KERNEL is not set
    CONFIG_AEABI=y
    # CONFIG_OABI_COMPAT is not set
    CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
    # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
    # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
    # CONFIG_HIGHMEM is not set
    CONFIG_SELECT_MEMORY_MODEL=y
    CONFIG_FLATMEM_MANUAL=y
    CONFIG_FLATMEM=y
    CONFIG_FLAT_NODE_MEM_MAP=y
    CONFIG_HAVE_MEMBLOCK=y
    CONFIG_PAGEFLAGS_EXTENDED=y
    CONFIG_SPLIT_PTLOCK_CPUS=4
    # CONFIG_PHYS_ADDR_T_64BIT is not set
    CONFIG_ZONE_DMA_FLAG=0
    CONFIG_VIRT_TO_BUS=y
    # CONFIG_KSM is not set
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_NEED_PER_CPU_KM=y
    CONFIG_FORCE_MAX_ZONEORDER=11
    CONFIG_LEDS=y
    CONFIG_ALIGNMENT_TRAP=y
    # CONFIG_UACCESS_WITH_MEMCPY is not set
    # CONFIG_SECCOMP is not set
    # CONFIG_CC_STACKPROTECTOR is not set
    # CONFIG_DEPRECATED_PARAM_STRUCT is not set
    # Boot options
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_CMDLINE=" debug "
    # CONFIG_CMDLINE_FORCE is not set
    # CONFIG_XIP_KERNEL is not set
    CONFIG_KEXEC=y
    CONFIG_ATAGS_PROC=y
    # CONFIG_AUTO_ZRELADDR is not set
    # CPU Power Management
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_TABLE=y
    CONFIG_CPU_FREQ_DEBUG=y
    CONFIG_CPU_FREQ_STAT=y
    CONFIG_CPU_FREQ_STAT_DETAILS=y
    CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
    CONFIG_CPU_FREQ_GOV_POWERSAVE=y
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
    CONFIG_CPU_FREQ_GOV_ONDEMAND=y
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
    CONFIG_CPU_IDLE=y
    CONFIG_CPU_IDLE_GOV_LADDER=y
    CONFIG_CPU_IDLE_GOV_MENU=y
    # Floating point emulation
    # At least one emulation must be selected
    CONFIG_VFP=y
    CONFIG_VFPv3=y
    CONFIG_NEON=y
    # Userspace binary formats
    CONFIG_BINFMT_ELF=y
    # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
    CONFIG_HAVE_AOUT=y
    CONFIG_BINFMT_AOUT=m
    CONFIG_BINFMT_MISC=y
    # Power management options
    CONFIG_PM=y
    CONFIG_PM_DEBUG=y
    # CONFIG_PM_ADVANCED_DEBUG is not set
    # CONFIG_PM_VERBOSE is not set
    CONFIG_CAN_PM_TRACE=y
    CONFIG_PM_SLEEP=y
    CONFIG_SUSPEND_NVS=y
    CONFIG_SUSPEND=y
    CONFIG_SUSPEND_FREEZER=y
    # CONFIG_APM_EMULATION is not set
    CONFIG_PM_RUNTIME=y
    CONFIG_PM_OPS=y
    CONFIG_ARCH_HAS_OPP=y
    CONFIG_PM_OPP=y
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_NET=y
    # Networking options
    CONFIG_PACKET=y
    CONFIG_UNIX=y
    CONFIG_XFRM=y
    # CONFIG_XFRM_USER is not set
    # CONFIG_XFRM_SUB_POLICY is not set
    # CONFIG_XFRM_MIGRATE is not set
    # CONFIG_XFRM_STATISTICS is not set
    CONFIG_XFRM_IPCOMP=m
    CONFIG_NET_KEY=y
    # CONFIG_NET_KEY_MIGRATE is not set
    CONFIG_INET=y
    # CONFIG_IP_MULTICAST is not set
    # CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_FIB_HASH=y
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    CONFIG_IP_PNP_BOOTP=y
    CONFIG_IP_PNP_RARP=y
    CONFIG_NET_IPIP=m
    # CONFIG_NET_IPGRE_DEMUX is not set
    # CONFIG_ARPD is not set
    # CONFIG_SYN_COOKIES is not set
    CONFIG_INET_AH=m
    CONFIG_INET_ESP=m
    CONFIG_INET_IPCOMP=m
    CONFIG_INET_XFRM_TUNNEL=m
    CONFIG_INET_TUNNEL=m
    CONFIG_INET_XFRM_MODE_TRANSPORT=y
    CONFIG_INET_XFRM_MODE_TUNNEL=y
    CONFIG_INET_XFRM_MODE_BEET=y
    CONFIG_INET_LRO=y
    CONFIG_INET_DIAG=m
    CONFIG_INET_TCP_DIAG=m
    CONFIG_TCP_CONG_ADVANCED=y
    CONFIG_TCP_CONG_BIC=m
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_TCP_CONG_WESTWOOD=m
    CONFIG_TCP_CONG_HTCP=m
    CONFIG_TCP_CONG_HSTCP=m
    CONFIG_TCP_CONG_HYBLA=m
    CONFIG_TCP_CONG_VEGAS=m
    CONFIG_TCP_CONG_SCALABLE=m
    CONFIG_TCP_CONG_LP=m
    CONFIG_TCP_CONG_VENO=m
    CONFIG_TCP_CONG_YEAH=m
    CONFIG_TCP_CONG_ILLINOIS=m
    CONFIG_DEFAULT_CUBIC=y
    # CONFIG_DEFAULT_RENO is not set
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    CONFIG_IPV6=m
    # CONFIG_IPV6_PRIVACY is not set
    # CONFIG_IPV6_ROUTER_PREF is not set
    # CONFIG_IPV6_OPTIMISTIC_DAD is not set
    CONFIG_INET6_AH=m
    CONFIG_INET6_ESP=m
    CONFIG_INET6_IPCOMP=m
    CONFIG_IPV6_MIP6=m
    CONFIG_INET6_XFRM_TUNNEL=m
    CONFIG_INET6_TUNNEL=m
    CONFIG_INET6_XFRM_MODE_TRANSPORT=m
    CONFIG_INET6_XFRM_MODE_TUNNEL=m
    CONFIG_INET6_XFRM_MODE_BEET=m
    CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION=m
    CONFIG_IPV6_SIT=m
    # CONFIG_IPV6_SIT_6RD is not set
    CONFIG_IPV6_NDISC_NODETYPE=y
    CONFIG_IPV6_TUNNEL=m
    CONFIG_IPV6_MULTIPLE_TABLES=y
    CONFIG_IPV6_SUBTREES=y
    CONFIG_IPV6_MROUTE=y
    # CONFIG_IPV6_MROUTE_MULTIPLE_TABLES is not set
    # CONFIG_IPV6_PIMSM_V2 is not set
    # CONFIG_NETWORK_SECMARK is not set
    # CONFIG_NETWORK_PHY_TIMESTAMPING is not set
    CONFIG_NETFILTER=y
    # CONFIG_NETFILTER_DEBUG is not set
    CONFIG_NETFILTER_ADVANCED=y
    CONFIG_BRIDGE_NETFILTER=y
    # Core Netfilter Configuration
    CONFIG_NETFILTER_NETLINK=m
    CONFIG_NETFILTER_NETLINK_QUEUE=m
    CONFIG_NETFILTER_NETLINK_LOG=m
    CONFIG_NF_CONNTRACK=m
    CONFIG_NF_CONNTRACK_MARK=y
    CONFIG_NF_CONNTRACK_EVENTS=y
    CONFIG_NF_CT_PROTO_DCCP=m
    CONFIG_NF_CT_PROTO_GRE=m
    CONFIG_NF_CT_PROTO_SCTP=m
    CONFIG_NF_CT_PROTO_UDPLITE=m
    CONFIG_NF_CONNTRACK_AMANDA=m
    CONFIG_NF_CONNTRACK_FTP=m
    CONFIG_NF_CONNTRACK_H323=m
    CONFIG_NF_CONNTRACK_IRC=m
    CONFIG_NF_CONNTRACK_NETBIOS_NS=m
    CONFIG_NF_CONNTRACK_PPTP=m
    CONFIG_NF_CONNTRACK_SANE=m
    CONFIG_NF_CONNTRACK_SIP=m
    CONFIG_NF_CONNTRACK_TFTP=m
    CONFIG_NF_CT_NETLINK=m
    # CONFIG_NETFILTER_TPROXY is not set
    CONFIG_NETFILTER_XTABLES=m
    # Xtables combined modules
    CONFIG_NETFILTER_XT_MARK=m
    CONFIG_NETFILTER_XT_CONNMARK=m
    # Xtables targets
    # CONFIG_NETFILTER_XT_TARGET_CHECKSUM is not set
    CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
    CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
    # CONFIG_NETFILTER_XT_TARGET_CT is not set
    # CONFIG_NETFILTER_XT_TARGET_DSCP is not set
    CONFIG_NETFILTER_XT_TARGET_HL=m
    # CONFIG_NETFILTER_XT_TARGET_IDLETIMER is not set
    # CONFIG_NETFILTER_XT_TARGET_LED is not set
    CONFIG_NETFILTER_XT_TARGET_MARK=m
    CONFIG_NETFILTER_XT_TARGET_NFLOG=m
    CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
    # CONFIG_NETFILTER_XT_TARGET_NOTRACK is not set
    CONFIG_NETFILTER_XT_TARGET_RATEEST=m
    # CONFIG_NETFILTER_XT_TARGET_TEE is not set
    # CONFIG_NETFILTER_XT_TARGET_TRACE is not set
    CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
    # CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set
    # Xtables matches
    # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
    CONFIG_NETFILTER_XT_MATCH_COMMENT=m
    CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
    CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
    CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
    CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
    # CONFIG_NETFILTER_XT_MATCH_CPU is not set
    CONFIG_NETFILTER_XT_MATCH_DCCP=m
    CONFIG_NETFILTER_XT_MATCH_DSCP=m
    CONFIG_NETFILTER_XT_MATCH_ESP=m
    CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
    CONFIG_NETFILTER_XT_MATCH_HELPER=m
    CONFIG_NETFILTER_XT_MATCH_HL=m
    CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
    # CONFIG_NETFILTER_XT_MATCH_IPVS is not set
    CONFIG_NETFILTER_XT_MATCH_LENGTH=m
    CONFIG_NETFILTER_XT_MATCH_LIMIT=m
    CONFIG_NETFILTER_XT_MATCH_MAC=m
    CONFIG_NETFILTER_XT_MATCH_MARK=m
    CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
    # CONFIG_NETFILTER_XT_MATCH_OSF is not set
    CONFIG_NETFILTER_XT_MATCH_OWNER=m
    CONFIG_NETFILTER_XT_MATCH_POLICY=m
    # CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set
    CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
    CONFIG_NETFILTER_XT_MATCH_QUOTA=m
    CONFIG_NETFILTER_XT_MATCH_RATEEST=m
    CONFIG_NETFILTER_XT_MATCH_REALM=m
    CONFIG_NETFILTER_XT_MATCH_RECENT=m
    CONFIG_NETFILTER_XT_MATCH_SCTP=m
    CONFIG_NETFILTER_XT_MATCH_STATE=m
    CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
    CONFIG_NETFILTER_XT_MATCH_STRING=m
    CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
    CONFIG_NETFILTER_XT_MATCH_TIME=m
    CONFIG_NETFILTER_XT_MATCH_U32=m
    CONFIG_IP_VS=m
    CONFIG_IP_VS_IPV6=y
    CONFIG_IP_VS_DEBUG=y
    CONFIG_IP_VS_TAB_BITS=12
    # IPVS transport protocol load balancing support
    CONFIG_IP_VS_PROTO_TCP=y
    CONFIG_IP_VS_PROTO_UDP=y
    CONFIG_IP_VS_PROTO_AH_ESP=y
    CONFIG_IP_VS_PROTO_ESP=y
    CONFIG_IP_VS_PROTO_AH=y
    # CONFIG_IP_VS_PROTO_SCTP is not set
    # IPVS scheduler
    CONFIG_IP_VS_RR=m
    CONFIG_IP_VS_WRR=m
    CONFIG_IP_VS_LC=m
    CONFIG_IP_VS_WLC=m
    CONFIG_IP_VS_LBLC=m
    CONFIG_IP_VS_LBLCR=m
    CONFIG_IP_VS_DH=m
    CONFIG_IP_VS_SH=m
    CONFIG_IP_VS_SED=m
    CONFIG_IP_VS_NQ=m
    # IPVS application helper
    CONFIG_IP_VS_FTP=m
    CONFIG_IP_VS_NFCT=y
    # CONFIG_IP_VS_PE_SIP is not set
    # IP: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV4=m
    CONFIG_NF_CONNTRACK_IPV4=m
    CONFIG_NF_CONNTRACK_PROC_COMPAT=y
    CONFIG_IP_NF_QUEUE=m
    CONFIG_IP_NF_IPTABLES=m
    CONFIG_IP_NF_MATCH_ADDRTYPE=m
    CONFIG_IP_NF_MATCH_AH=m
    CONFIG_IP_NF_MATCH_ECN=m
    CONFIG_IP_NF_MATCH_TTL=m
    CONFIG_IP_NF_FILTER=m
    CONFIG_IP_NF_TARGET_REJECT=m
    CONFIG_IP_NF_TARGET_LOG=m
    CONFIG_IP_NF_TARGET_ULOG=m
    CONFIG_NF_NAT=m
    CONFIG_NF_NAT_NEEDED=y
    CONFIG_IP_NF_TARGET_MASQUERADE=m
    CONFIG_IP_NF_TARGET_NETMAP=m
    CONFIG_IP_NF_TARGET_REDIRECT=m
    CONFIG_NF_NAT_SNMP_BASIC=m
    CONFIG_NF_NAT_PROTO_DCCP=m
    CONFIG_NF_NAT_PROTO_GRE=m
    CONFIG_NF_NAT_PROTO_UDPLITE=m
    CONFIG_NF_NAT_PROTO_SCTP=m
    CONFIG_NF_NAT_FTP=m
    CONFIG_NF_NAT_IRC=m
    CONFIG_NF_NAT_TFTP=m
    CONFIG_NF_NAT_AMANDA=m
    CONFIG_NF_NAT_PPTP=m
    CONFIG_NF_NAT_H323=m
    CONFIG_NF_NAT_SIP=m
    CONFIG_IP_NF_MANGLE=m
    CONFIG_IP_NF_TARGET_CLUSTERIP=m
    CONFIG_IP_NF_TARGET_ECN=m
    CONFIG_IP_NF_TARGET_TTL=m
    CONFIG_IP_NF_RAW=m
    CONFIG_IP_NF_ARPTABLES=m
    CONFIG_IP_NF_ARPFILTER=m
    CONFIG_IP_NF_ARP_MANGLE=m
    # IPv6: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV6=m
    CONFIG_NF_CONNTRACK_IPV6=m
    CONFIG_IP6_NF_QUEUE=m
    CONFIG_IP6_NF_IPTABLES=m
    CONFIG_IP6_NF_MATCH_AH=m
    CONFIG_IP6_NF_MATCH_EUI64=m
    CONFIG_IP6_NF_MATCH_FRAG=m
    CONFIG_IP6_NF_MATCH_OPTS=m
    CONFIG_IP6_NF_MATCH_HL=m
    CONFIG_IP6_NF_MATCH_IPV6HEADER=m
    CONFIG_IP6_NF_MATCH_MH=m
    CONFIG_IP6_NF_MATCH_RT=m
    CONFIG_IP6_NF_TARGET_HL=m
    CONFIG_IP6_NF_TARGET_LOG=m
    CONFIG_IP6_NF_FILTER=m
    CONFIG_IP6_NF_TARGET_REJECT=m
    CONFIG_IP6_NF_MANGLE=m
    CONFIG_IP6_NF_RAW=m
    # CONFIG_BRIDGE_NF_EBTABLES is not set
    CONFIG_IP_DCCP=m
    CONFIG_INET_DCCP_DIAG=m
    # DCCP CCIDs Configuration (EXPERIMENTAL)
    # CONFIG_IP_DCCP_CCID2_DEBUG is not set
    CONFIG_IP_DCCP_CCID3=y
    # CONFIG_IP_DCCP_CCID3_DEBUG is not set
    CONFIG_IP_DCCP_TFRC_LIB=y
    # DCCP Kernel Hacking
    # CONFIG_IP_DCCP_DEBUG is not set
    CONFIG_IP_SCTP=m
    # CONFIG_SCTP_DBG_MSG is not set
    # CONFIG_SCTP_DBG_OBJCNT is not set
    # CONFIG_SCTP_HMAC_NONE is not set
    # CONFIG_SCTP_HMAC_SHA1 is not set
    CONFIG_SCTP_HMAC_MD5=y
    # CONFIG_RDS is not set
    CONFIG_TIPC=m
    # CONFIG_TIPC_ADVANCED is not set
    # CONFIG_TIPC_DEBUG is not set
    CONFIG_ATM=m
    CONFIG_ATM_CLIP=m
    # CONFIG_ATM_CLIP_NO_ICMP is not set
    CONFIG_ATM_LANE=m
    CONFIG_ATM_MPOA=m
    CONFIG_ATM_BR2684=m
    # CONFIG_ATM_BR2684_IPFILTER is not set
    # CONFIG_L2TP is not set
    CONFIG_STP=m
    CONFIG_GARP=m
    CONFIG_BRIDGE=m
    CONFIG_BRIDGE_IGMP_SNOOPING=y
    # CONFIG_NET_DSA is not set
    CONFIG_VLAN_8021Q=m
    CONFIG_VLAN_8021Q_GVRP=y
    # CONFIG_DECNET is not set
    CONFIG_LLC=m
    # CONFIG_LLC2 is not set
    # CONFIG_IPX is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    # CONFIG_ECONET is not set
    CONFIG_WAN_ROUTER=m
    # CONFIG_PHONET is not set
    # CONFIG_IEEE802154 is not set
    CONFIG_NET_SCHED=y
    # Queueing/Scheduling
    CONFIG_NET_SCH_CBQ=m
    CONFIG_NET_SCH_HTB=m
    CONFIG_NET_SCH_HFSC=m
    CONFIG_NET_SCH_ATM=m
    CONFIG_NET_SCH_PRIO=m
    CONFIG_NET_SCH_MULTIQ=m
    CONFIG_NET_SCH_RED=m
    CONFIG_NET_SCH_SFQ=m
    CONFIG_NET_SCH_TEQL=m
    CONFIG_NET_SCH_TBF=m
    CONFIG_NET_SCH_GRED=m
    CONFIG_NET_SCH_DSMARK=m
    CONFIG_NET_SCH_NETEM=m
    CONFIG_NET_SCH_DRR=m
    # Classification
    CONFIG_NET_CLS=y
    CONFIG_NET_CLS_BASIC=m
    CONFIG_NET_CLS_TCINDEX=m
    CONFIG_NET_CLS_ROUTE4=m
    CONFIG_NET_CLS_ROUTE=y
    CONFIG_NET_CLS_FW=m
    CONFIG_NET_CLS_U32=m
    CONFIG_CLS_U32_PERF=y
    CONFIG_CLS_U32_MARK=y
    CONFIG_NET_CLS_RSVP=m
    CONFIG_NET_CLS_RSVP6=m
    CONFIG_NET_CLS_FLOW=m
    # CONFIG_NET_EMATCH is not set
    # CONFIG_NET_CLS_ACT is not set
    CONFIG_NET_CLS_IND=y
    CONFIG_NET_SCH_FIFO=y
    # CONFIG_DCB is not set
    CONFIG_DNS_RESOLVER=y
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # CONFIG_HAMRADIO is not set
    CONFIG_CAN=m
    CONFIG_CAN_RAW=m
    CONFIG_CAN_BCM=m
    # CAN Device Drivers
    CONFIG_CAN_VCAN=m
    # CONFIG_CAN_DEV is not set
    # CONFIG_CAN_DEBUG_DEVICES is not set
    CONFIG_IRDA=m
    # IrDA protocols
    CONFIG_IRLAN=m
    CONFIG_IRNET=m
    CONFIG_IRCOMM=m
    CONFIG_IRDA_ULTRA=y
    # IrDA options
    CONFIG_IRDA_CACHE_LAST_LSAP=y
    CONFIG_IRDA_FAST_RR=y
    CONFIG_IRDA_DEBUG=y
    # Infrared-port device drivers
    # SIR device drivers
    CONFIG_IRTTY_SIR=m
    # Dongle support
    CONFIG_DONGLE=y
    CONFIG_ESI_DONGLE=m
    CONFIG_ACTISYS_DONGLE=m
    CONFIG_TEKRAM_DONGLE=m
    CONFIG_TOIM3232_DONGLE=m
    CONFIG_LITELINK_DONGLE=m
    CONFIG_MA600_DONGLE=m
    CONFIG_GIRBIL_DONGLE=m
    CONFIG_MCP2120_DONGLE=m
    CONFIG_OLD_BELKIN_DONGLE=m
    # CONFIG_ACT200L_DONGLE is not set
    CONFIG_KINGSUN_DONGLE=m
    CONFIG_KSDAZZLE_DONGLE=m
    CONFIG_KS959_DONGLE=m
    # FIR device drivers
    CONFIG_USB_IRDA=m
    CONFIG_SIGMATEL_FIR=m
    CONFIG_MCS_FIR=m
    CONFIG_BT=m
    CONFIG_BT_L2CAP=m
    CONFIG_BT_SCO=m
    CONFIG_BT_RFCOMM=m
    CONFIG_BT_RFCOMM_TTY=y
    CONFIG_BT_BNEP=m
    CONFIG_BT_BNEP_MC_FILTER=y
    CONFIG_BT_BNEP_PROTO_FILTER=y
    CONFIG_BT_HIDP=m
    # Bluetooth device drivers
    CONFIG_BT_HCIBTUSB=m
    CONFIG_BT_HCIBTSDIO=m
    CONFIG_BT_HCIUART=m
    CONFIG_BT_HCIUART_H4=y
    CONFIG_BT_HCIUART_BCSP=y
    # CONFIG_BT_HCIUART_ATH3K is not set
    CONFIG_BT_HCIUART_LL=y
    CONFIG_BT_HCIBCM203X=m
    CONFIG_BT_HCIBPA10X=m
    CONFIG_BT_HCIBFUSB=m
    # CONFIG_BT_HCIVHCI is not set
    # CONFIG_BT_MRVL is not set
    # CONFIG_BT_ATH3K is not set
    CONFIG_AF_RXRPC=m
    # CONFIG_AF_RXRPC_DEBUG is not set
    # CONFIG_RXKAD is not set
    CONFIG_FIB_RULES=y
    CONFIG_WIRELESS=y
    CONFIG_WIRELESS_EXT=y
    CONFIG_WEXT_CORE=y
    CONFIG_WEXT_PROC=y
    CONFIG_WEXT_SPY=y
    CONFIG_WEXT_PRIV=y
    CONFIG_CFG80211=m
    # CONFIG_NL80211_TESTMODE is not set
    # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
    # CONFIG_CFG80211_REG_DEBUG is not set
    CONFIG_CFG80211_DEFAULT_PS=y
    # CONFIG_CFG80211_DEBUGFS is not set
    # CONFIG_CFG80211_INTERNAL_REGDB is not set
    CONFIG_CFG80211_WEXT=y
    CONFIG_WIRELESS_EXT_SYSFS=y
    CONFIG_LIB80211=y
    CONFIG_LIB80211_CRYPT_WEP=m
    CONFIG_LIB80211_CRYPT_CCMP=m
    CONFIG_LIB80211_CRYPT_TKIP=m
    # CONFIG_LIB80211_DEBUG is not set
    CONFIG_MAC80211=m
    CONFIG_MAC80211_HAS_RC=y
    CONFIG_MAC80211_RC_PID=y
    # CONFIG_MAC80211_RC_MINSTREL is not set
    CONFIG_MAC80211_RC_DEFAULT_PID=y
    CONFIG_MAC80211_RC_DEFAULT="pid"
    # CONFIG_MAC80211_MESH is not set
    CONFIG_MAC80211_LEDS=y
    # CONFIG_MAC80211_DEBUGFS is not set
    # CONFIG_MAC80211_DEBUG_MENU is not set
    CONFIG_WIMAX=m
    CONFIG_WIMAX_DEBUG_LEVEL=8
    CONFIG_RFKILL=m
    CONFIG_RFKILL_LEDS=y
    CONFIG_RFKILL_INPUT=y
    CONFIG_NET_9P=m
    # CONFIG_NET_9P_DEBUG is not set
    # CONFIG_CAIF is not set
    # CONFIG_CEPH_LIB is not set
    # Device Drivers
    # Generic Driver Options
    CONFIG_UEVENT_HELPER_PATH=""
    CONFIG_DEVTMPFS=y
    CONFIG_DEVTMPFS_MOUNT=y
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    CONFIG_FW_LOADER=y
    CONFIG_FIRMWARE_IN_KERNEL=y
    CONFIG_EXTRA_FIRMWARE=""
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_SYS_HYPERVISOR is not set
    # CONFIG_CONNECTOR is not set
    CONFIG_MTD=y
    # CONFIG_MTD_DEBUG is not set
    # CONFIG_MTD_TESTS is not set
    CONFIG_MTD_CONCAT=y
    CONFIG_MTD_PARTITIONS=y
    # CONFIG_MTD_REDBOOT_PARTS is not set
    # CONFIG_MTD_CMDLINE_PARTS is not set
    # CONFIG_MTD_AFS_PARTS is not set
    # CONFIG_MTD_AR7_PARTS is not set
    # User Modules And Translation Layers
    CONFIG_MTD_CHAR=y
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
    # CONFIG_FTL is not set
    # CONFIG_NFTL is not set
    # CONFIG_INFTL is not set
    # CONFIG_RFD_FTL is not set
    # CONFIG_SSFDC is not set
    # CONFIG_SM_FTL is not set
    # CONFIG_MTD_OOPS is not set
    # RAM/ROM/Flash chip drivers
    # CONFIG_MTD_CFI is not set
    # CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
    # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
    # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
    # CONFIG_MTD_CFI_I4 is not set
    # CONFIG_MTD_CFI_I8 is not set
    # CONFIG_MTD_RAM is not set
    # CONFIG_MTD_ROM is not set
    # CONFIG_MTD_ABSENT is not set
    # Mapping drivers for chip access
    # CONFIG_MTD_COMPLEX_MAPPINGS is not set
    # CONFIG_MTD_PLATRAM is not set
    # Self-contained MTD device drivers
    # CONFIG_MTD_DATAFLASH is not set
    # CONFIG_MTD_M25P80 is not set
    # CONFIG_MTD_SST25L is not set
    # CONFIG_MTD_SLRAM is not set
    # CONFIG_MTD_PHRAM is not set
    # CONFIG_MTD_MTDRAM is not set
    # CONFIG_MTD_BLOCK2MTD is not set
    # Disk-On-Chip Device Drivers
    # CONFIG_MTD_DOC2000 is not set
    # CONFIG_MTD_DOC2001 is not set
    # CONFIG_MTD_DOC2001PLUS is not set
    CONFIG_MTD_NAND_ECC=y
    # CONFIG_MTD_NAND_ECC_SMC is not set
    CONFIG_MTD_NAND=y
    # CONFIG_MTD_NAND_VERIFY_WRITE is not set
    # CONFIG_MTD_SM_COMMON is not set
    # CONFIG_MTD_NAND_MUSEUM_IDS is not set
    # CONFIG_MTD_NAND_GPIO is not set
    CONFIG_MTD_NAND_OMAP2=y
    CONFIG_MTD_NAND_IDS=y
    # CONFIG_MTD_NAND_DISKONCHIP is not set
    # CONFIG_MTD_NAND_NANDSIM is not set
    CONFIG_MTD_NAND_PLATFORM=y
    # CONFIG_MTD_ALAUDA is not set
    # CONFIG_MTD_ONENAND is not set
    # LPDDR flash memory drivers
    # CONFIG_MTD_LPDDR is not set
    CONFIG_MTD_UBI=y
    CONFIG_MTD_UBI_WL_THRESHOLD=4096
    CONFIG_MTD_UBI_BEB_RESERVE=1
    # CONFIG_MTD_UBI_GLUEBI is not set
    # UBI debugging options
    # CONFIG_MTD_UBI_DEBUG is not set
    # CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_COW_COMMON is not set
    CONFIG_BLK_DEV_LOOP=y
    CONFIG_BLK_DEV_CRYPTOLOOP=m
    # DRBD disabled because PROC_FS, INET or CONNECTOR not selected
    # CONFIG_BLK_DEV_NBD is not set
    # CONFIG_BLK_DEV_UB is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=16
    CONFIG_BLK_DEV_RAM_SIZE=16384
    # CONFIG_BLK_DEV_XIP is not set
    CONFIG_CDROM_PKTCDVD=m
    CONFIG_CDROM_PKTCDVD_BUFFERS=8
    # CONFIG_CDROM_PKTCDVD_WCACHE is not set
    # CONFIG_ATA_OVER_ETH is not set
    # CONFIG_MG_DISK is not set
    # CONFIG_BLK_DEV_RBD is not set
    CONFIG_MISC_DEVICES=y
    # CONFIG_AD525X_DPOT is not set
    # CONFIG_ICS932S401 is not set
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_APDS9802ALS is not set
    # CONFIG_ISL29003 is not set
    # CONFIG_ISL29020 is not set
    # CONFIG_SENSORS_TSL2550 is not set
    # CONFIG_SENSORS_BH1780 is not set
    # CONFIG_SENSORS_BH1770 is not set
    # CONFIG_SENSORS_APDS990X is not set
    # CONFIG_HMC6352 is not set
    # CONFIG_DS1682 is not set
    # CONFIG_TI_DAC7512 is not set
    # CONFIG_BMP085 is not set
    # CONFIG_C2PORT is not set
    # EEPROM support
    CONFIG_EEPROM_AT24=m
    # CONFIG_EEPROM_AT25 is not set
    # CONFIG_EEPROM_LEGACY is not set
    # CONFIG_EEPROM_MAX6875 is not set
    CONFIG_EEPROM_93CX6=y
    CONFIG_IWMC3200TOP=m
    # CONFIG_IWMC3200TOP_DEBUG is not set
    # CONFIG_IWMC3200TOP_DEBUGFS is not set
    # Texas Instruments shared transport line discipline
    # CONFIG_TI_ST is not set
    CONFIG_HAVE_IDE=y
    # CONFIG_IDE is not set
    # SCSI device support
    CONFIG_SCSI_MOD=y
    CONFIG_RAID_ATTRS=m
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    # CONFIG_SCSI_TGT is not set
    # CONFIG_SCSI_NETLINK is not set
    CONFIG_SCSI_PROC_FS=y
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    # CONFIG_CHR_DEV_OSST is not set
    CONFIG_BLK_DEV_SR=y
    CONFIG_BLK_DEV_SR_VENDOR=y
    CONFIG_CHR_DEV_SG=y
    CONFIG_CHR_DEV_SCH=m
    CONFIG_SCSI_MULTI_LUN=y
    # CONFIG_SCSI_CONSTANTS is not set
    # CONFIG_SCSI_LOGGING is not set
    # CONFIG_SCSI_SCAN_ASYNC is not set
    CONFIG_SCSI_WAIT_SCAN=m
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    CONFIG_SCSI_ISCSI_ATTRS=m
    # CONFIG_SCSI_SAS_ATTRS is not set
    # CONFIG_SCSI_SAS_LIBSAS is not set
    # CONFIG_SCSI_SRP_ATTRS is not set
    CONFIG_SCSI_LOWLEVEL=y
    CONFIG_ISCSI_TCP=m
    # CONFIG_ISCSI_BOOT_SYSFS is not set
    # CONFIG_LIBFC is not set
    # CONFIG_LIBFCOE is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_DH is not set
    # CONFIG_SCSI_OSD_INITIATOR is not set
    # CONFIG_ATA is not set
    CONFIG_MD=y
    CONFIG_BLK_DEV_MD=m
    CONFIG_MD_LINEAR=m
    CONFIG_MD_RAID0=m
    CONFIG_MD_RAID1=m
    CONFIG_MD_RAID10=m
    CONFIG_MD_RAID456=m
    CONFIG_MD_MULTIPATH=m
    CONFIG_MD_FAULTY=m
    CONFIG_BLK_DEV_DM=m
    # CONFIG_DM_DEBUG is not set
    CONFIG_DM_CRYPT=m
    CONFIG_DM_SNAPSHOT=m
    CONFIG_DM_MIRROR=m
    # CONFIG_DM_LOG_USERSPACE is not set
    CONFIG_DM_ZERO=m
    CONFIG_DM_MULTIPATH=m
    # CONFIG_DM_MULTIPATH_QL is not set
    # CONFIG_DM_MULTIPATH_ST is not set
    CONFIG_DM_DELAY=m
    # CONFIG_DM_UEVENT is not set
    CONFIG_NETDEVICES=y
    CONFIG_DUMMY=m
    CONFIG_BONDING=m
    CONFIG_MACVLAN=m
    # CONFIG_MACVTAP is not set
    CONFIG_EQUALIZER=m
    CONFIG_TUN=m
    CONFIG_VETH=m
    CONFIG_MII=y
    CONFIG_PHYLIB=y
    # MII PHY device drivers
    # CONFIG_MARVELL_PHY is not set
    # CONFIG_DAVICOM_PHY is not set
    # CONFIG_QSEMI_PHY is not set
    # CONFIG_LXT_PHY is not set
    # CONFIG_CICADA_PHY is not set
    # CONFIG_VITESSE_PHY is not set
    # CONFIG_SMSC_PHY is not set
    # CONFIG_BROADCOM_PHY is not set
    # CONFIG_BCM63XX_PHY is not set
    # CONFIG_ICPLUS_PHY is not set
    # CONFIG_REALTEK_PHY is not set
    # CONFIG_NATIONAL_PHY is not set
    # CONFIG_STE10XP is not set
    # CONFIG_LSI_ET1011C_PHY is not set
    # CONFIG_MICREL_PHY is not set
    # CONFIG_FIXED_PHY is not set
    # CONFIG_MDIO_BITBANG is not set
    CONFIG_NET_ETHERNET=y
    # CONFIG_AX88796 is not set
    # CONFIG_SMC91X is not set
    # CONFIG_DM9000 is not set
    CONFIG_ENC28J60=y
    # CONFIG_ENC28J60_WRITEVERIFY is not set
    # CONFIG_ETHOC is not set
    CONFIG_SMC911X=y
    CONFIG_SMSC911X=y
    # CONFIG_SMSC911X_ARCH_HOOKS is not set
    # CONFIG_DNET is not set
    # CONFIG_IBM_NEW_EMAC_ZMII is not set
    # CONFIG_IBM_NEW_EMAC_RGMII is not set
    # CONFIG_IBM_NEW_EMAC_TAH is not set
    # CONFIG_IBM_NEW_EMAC_EMAC4 is not set
    # CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
    # CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
    # CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
    # CONFIG_B44 is not set
    CONFIG_KS8851=y
    # CONFIG_KS8851_MLL is not set
    # CONFIG_NETDEV_1000 is not set
    # CONFIG_NETDEV_10000 is not set
    CONFIG_WLAN=y
    # CONFIG_LIBERTAS_THINFIRM is not set
    CONFIG_AT76C50X_USB=m
    CONFIG_USB_ZD1201=m
    CONFIG_USB_NET_RNDIS_WLAN=m
    CONFIG_RTL8187=m
    CONFIG_RTL8187_LEDS=y
    # CONFIG_MAC80211_HWSIM is not set
    # CONFIG_ATH_COMMON is not set
    CONFIG_B43=m
    # CONFIG_B43_SDIO is not set
    CONFIG_B43_PIO=y
    CONFIG_B43_PHY_LP=y
    CONFIG_B43_LEDS=y
    CONFIG_B43_HWRNG=y
    # CONFIG_B43_DEBUG is not set
    # CONFIG_B43LEGACY is not set
    CONFIG_HOSTAP=m
    CONFIG_HOSTAP_FIRMWARE=y
    CONFIG_HOSTAP_FIRMWARE_NVRAM=y
    # CONFIG_IWM is not set
    CONFIG_LIBERTAS=m
    CONFIG_LIBERTAS_USB=m
    # CONFIG_LIBERTAS_SDIO is not set
    # CONFIG_LIBERTAS_SPI is not set
    # CONFIG_LIBERTAS_DEBUG is not set
    # CONFIG_LIBERTAS_MESH is not set
    CONFIG_P54_COMMON=m
    CONFIG_P54_USB=m
    # CONFIG_P54_SPI is not set
    CONFIG_P54_LEDS=y
    CONFIG_RT2X00=m
    CONFIG_RT2500USB=m
    CONFIG_RT73USB=m
    # CONFIG_RT2800USB is not set
    CONFIG_RT2X00_LIB_USB=m
    CONFIG_RT2X00_LIB=m
    CONFIG_RT2X00_LIB_FIRMWARE=y
    CONFIG_RT2X00_LIB_CRYPTO=y
    CONFIG_RT2X00_LIB_LEDS=y
    # CONFIG_RT2X00_DEBUG is not set
    CONFIG_WL1251=m
    CONFIG_WL1251_SPI=m
    CONFIG_WL1251_SDIO=m
    # CONFIG_WL12XX is not set
    CONFIG_ZD1211RW=m
    # CONFIG_ZD1211RW_DEBUG is not set
    # WiMAX Wireless Broadband devices
    CONFIG_WIMAX_I2400M=m
    CONFIG_WIMAX_I2400M_USB=m
    CONFIG_WIMAX_I2400M_SDIO=m
    CONFIG_WIMAX_IWMC3200_SDIO=y
    CONFIG_WIMAX_I2400M_DEBUG_LEVEL=8
    # USB Network Adapters
    CONFIG_USB_CATC=y
    CONFIG_USB_KAWETH=y
    CONFIG_USB_PEGASUS=y
    CONFIG_USB_RTL8150=y
    CONFIG_USB_USBNET=y
    CONFIG_USB_NET_AX8817X=y
    CONFIG_USB_NET_CDCETHER=y
    # CONFIG_USB_NET_CDC_EEM is not set
    CONFIG_USB_NET_DM9601=y
    # CONFIG_USB_NET_SMSC75XX is not set
    CONFIG_USB_NET_SMSC95XX=y
    CONFIG_USB_NET_GL620A=y
    CONFIG_USB_NET_NET1080=y
    CONFIG_USB_NET_PLUSB=y
    CONFIG_USB_NET_MCS7830=y
    CONFIG_USB_NET_RNDIS_HOST=y
    CONFIG_USB_NET_CDC_SUBSET=y
    CONFIG_USB_ALI_M5632=y
    CONFIG_USB_AN2720=y
    CONFIG_USB_BELKIN=y
    CONFIG_USB_ARMLINUX=y
    CONFIG_USB_EPSON2888=y
    CONFIG_USB_KC2190=y
    CONFIG_USB_NET_ZAURUS=y
    # CONFIG_USB_NET_CX82310_ETH is not set
    CONFIG_USB_HSO=m
    CONFIG_USB_NET_INT51X1=m
    # CONFIG_USB_IPHETH is not set
    # CONFIG_USB_SIERRA_NET is not set
    # CONFIG_WAN is not set
    CONFIG_ATM_DRIVERS=y
    # CONFIG_ATM_DUMMY is not set
    # CONFIG_ATM_TCP is not set
    # CAIF transport drivers
    CONFIG_PPP=m
    CONFIG_PPP_MULTILINK=y
    CONFIG_PPP_FILTER=y
    CONFIG_PPP_ASYNC=m
    CONFIG_PPP_SYNC_TTY=m
    CONFIG_PPP_DEFLATE=m
    CONFIG_PPP_BSDCOMP=m
    CONFIG_PPP_MPPE=m
    CONFIG_PPPOE=m
    # CONFIG_PPPOATM is not set
    # CONFIG_SLIP is not set
    CONFIG_SLHC=m
    CONFIG_NETCONSOLE=m
    CONFIG_NETCONSOLE_DYNAMIC=y
    CONFIG_NETPOLL=y
    CONFIG_NETPOLL_TRAP=y
    CONFIG_NET_POLL_CONTROLLER=y
    # CONFIG_ISDN is not set
    # CONFIG_PHONE is not set
    # Input device support
    CONFIG_INPUT=y
    CONFIG_INPUT_FF_MEMLESS=y
    CONFIG_INPUT_POLLDEV=y
    # CONFIG_INPUT_SPARSEKMAP is not set
    # Userland interfaces
    CONFIG_INPUT_MOUSEDEV=y
    CONFIG_INPUT_MOUSEDEV_PSAUX=y
    CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
    CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
    # CONFIG_INPUT_JOYDEV is not set
    CONFIG_INPUT_EVDEV=y
    # CONFIG_INPUT_EVBUG is not set
    # Input Device Drivers
    CONFIG_INPUT_KEYBOARD=y
    # CONFIG_KEYBOARD_ADP5588 is not set
    # CONFIG_KEYBOARD_ATKBD is not set
    # CONFIG_KEYBOARD_QT2160 is not set
    # CONFIG_KEYBOARD_LKKBD is not set
    CONFIG_KEYBOARD_GPIO=y
    # CONFIG_KEYBOARD_GPIO_POLLED is not set
    # CONFIG_KEYBOARD_TCA6416 is not set
    # CONFIG_KEYBOARD_MATRIX is not set
    # CONFIG_KEYBOARD_LM8323 is not set
    # CONFIG_KEYBOARD_MAX7359 is not set
    # CONFIG_KEYBOARD_MCS is not set
    # CONFIG_KEYBOARD_NEWTON is not set
    # CONFIG_KEYBOARD_OPENCORES is not set
    # CONFIG_KEYBOARD_STOWAWAY is not set
    # CONFIG_KEYBOARD_SUNKBD is not set
    # CONFIG_KEYBOARD_TWL4030 is not set
    # CONFIG_KEYBOARD_XTKBD is not set
    CONFIG_INPUT_MOUSE=y
    CONFIG_MOUSE_PS2=y
    CONFIG_MOUSE_PS2_ALPS=y
    CONFIG_MOUSE_PS2_LOGIPS2PP=y
    CONFIG_MOUSE_PS2_SYNAPTICS=y
    CONFIG_MOUSE_PS2_TRACKPOINT=y
    # CONFIG_MOUSE_PS2_ELANTECH is not set
    # CONFIG_MOUSE_PS2_SENTELIC is not set
    # CONFIG_MOUSE_PS2_TOUCHKIT is not set
    # CONFIG_MOUSE_SERIAL is not set
    # CONFIG_MOUSE_APPLETOUCH is not set
    # CONFIG_MOUSE_BCM5974 is not set
    # CONFIG_MOUSE_VSXXXAA is not set
    # CONFIG_MOUSE_GPIO is not set
    # CONFIG_MOUSE_SYNAPTICS_I2C is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    # CONFIG_INPUT_TOUCHSCREEN is not set
    CONFIG_INPUT_MISC=y
    # CONFIG_INPUT_AD714X is not set
    # CONFIG_INPUT_ATI_REMOTE is not set
    # CONFIG_INPUT_ATI_REMOTE2 is not set
    # CONFIG_INPUT_KEYSPAN_REMOTE is not set
    # CONFIG_INPUT_POWERMATE is not set
    # CONFIG_INPUT_YEALINK is not set
    # CONFIG_INPUT_CM109 is not set
    CONFIG_INPUT_TWL4030_PWRBUTTON=y
    # CONFIG_INPUT_TWL4030_VIBRA is not set
    CONFIG_INPUT_UINPUT=y
    # CONFIG_INPUT_PCF8574 is not set
    # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
    # CONFIG_INPUT_ADXL34X is not set
    # Hardware I/O ports
    CONFIG_SERIO=y
    CONFIG_SERIO_SERPORT=y
    CONFIG_SERIO_LIBPS2=y
    # CONFIG_SERIO_RAW is not set
    # CONFIG_SERIO_ALTERA_PS2 is not set
    # CONFIG_SERIO_PS2MULT is not set
    # CONFIG_GAMEPORT is not set
    # Character devices
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_HW_CONSOLE=y
    CONFIG_VT_HW_CONSOLE_BINDING=y
    CONFIG_DEVKMEM=y
    # CONFIG_SERIAL_NONSTANDARD is not set
    # CONFIG_N_GSM is not set
    # Serial drivers
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_CONSOLE=y
    CONFIG_SERIAL_8250_NR_UARTS=32
    CONFIG_SERIAL_8250_RUNTIME_UARTS=4
    CONFIG_SERIAL_8250_EXTENDED=y
    CONFIG_SERIAL_8250_MANY_PORTS=y
    CONFIG_SERIAL_8250_SHARE_IRQ=y
    CONFIG_SERIAL_8250_DETECT_IRQ=y
    CONFIG_SERIAL_8250_RSA=y
    # Non-8250 serial port support
    # CONFIG_SERIAL_MAX3100 is not set
    # CONFIG_SERIAL_MAX3107 is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    CONFIG_SERIAL_OMAP=y
    CONFIG_SERIAL_OMAP_CONSOLE=y
    # CONFIG_SERIAL_TIMBERDALE is not set
    # CONFIG_SERIAL_ALTERA_JTAGUART is not set
    # CONFIG_SERIAL_ALTERA_UART is not set
    CONFIG_UNIX98_PTYS=y
    # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
    # CONFIG_LEGACY_PTYS is not set
    # CONFIG_TTY_PRINTK is not set
    # CONFIG_IPMI_HANDLER is not set
    CONFIG_HW_RANDOM=y
    # CONFIG_HW_RANDOM_TIMERIOMEM is not set
    # CONFIG_R3964 is not set
    # CONFIG_RAW_DRIVER is not set
    # CONFIG_TCG_TPM is not set
    # CONFIG_TI81XX_HDMI is not set
    # CONFIG_RAMOOPS is not set
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    # CONFIG_I2C_MUX is not set
    CONFIG_I2C_HELPER_AUTO=y
    # I2C Hardware Bus support
    # I2C system bus drivers (mostly embedded / system-on-chip)
    # CONFIG_I2C_DESIGNWARE is not set
    # CONFIG_I2C_GPIO is not set
    # CONFIG_I2C_OCORES is not set
    CONFIG_I2C_OMAP=y
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_SIMTEC is not set
    # CONFIG_I2C_XILINX is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_PARPORT_LIGHT is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_STUB is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_BITBANG is not set
    # CONFIG_SPI_GPIO is not set
    CONFIG_SPI_OMAP24XX=y
    # CONFIG_SPI_XILINX is not set
    # CONFIG_SPI_DESIGNWARE is not set
    # SPI Protocol Masters
    CONFIG_SPI_SPIDEV=y
    # CONFIG_SPI_TLE62X0 is not set
    # PPS support
    # CONFIG_PPS is not set
    CONFIG_ARCH_REQUIRE_GPIOLIB=y
    CONFIG_GPIOLIB=y
    # CONFIG_DEBUG_GPIO is not set
    CONFIG_GPIO_SYSFS=y
    # Memory mapped GPIO expanders:
    # CONFIG_GPIO_BASIC_MMIO is not set
    # CONFIG_GPIO_IT8761E is not set
    # CONFIG_GPIO_VX855 is not set
    # I2C GPIO expanders:
    # CONFIG_GPIO_MAX7300 is not set
    # CONFIG_GPIO_MAX732X is not set
    # CONFIG_GPIO_PCA953X is not set
    # CONFIG_GPIO_PCF857X is not set
    # CONFIG_GPIO_SX150X is not set
    CONFIG_GPIO_TWL4030=y
    # CONFIG_GPIO_ADP5588 is not set
    # PCI GPIO expanders:
    # SPI GPIO expanders:
    # CONFIG_GPIO_MAX7301 is not set
    # CONFIG_GPIO_MCP23S08 is not set
    # CONFIG_GPIO_MC33880 is not set
    # CONFIG_GPIO_74X164 is not set
    # AC97 GPIO expanders:
    # MODULbus GPIO expanders:
    # CONFIG_W1 is not set
    CONFIG_POWER_SUPPLY=m
    # CONFIG_POWER_SUPPLY_DEBUG is not set
    # CONFIG_PDA_POWER is not set
    # CONFIG_TEST_POWER is not set
    # CONFIG_BATTERY_DS2782 is not set
    # CONFIG_BATTERY_BQ20Z75 is not set
    # CONFIG_BATTERY_BQ27x00 is not set
    # CONFIG_BATTERY_MAX17040 is not set
    # CONFIG_CHARGER_ISP1704 is not set
    # CONFIG_CHARGER_TWL4030 is not set
    CONFIG_HWMON=y
    # CONFIG_HWMON_VID is not set
    # CONFIG_HWMON_DEBUG_CHIP is not set
    # Native drivers
    # CONFIG_SENSORS_AD7414 is not set
    # CONFIG_SENSORS_AD7418 is not set
    # CONFIG_SENSORS_ADCXX is not set
    # CONFIG_SENSORS_ADM1021 is not set
    # CONFIG_SENSORS_ADM1025 is not set
    # CONFIG_SENSORS_ADM1026 is not set
    # CONFIG_SENSORS_ADM1029 is not set
    # CONFIG_SENSORS_ADM1031 is not set
    # CONFIG_SENSORS_ADM9240 is not set
    # CONFIG_SENSORS_ADT7411 is not set
    # CONFIG_SENSORS_ADT7462 is not set
    # CONFIG_SENSORS_ADT7470 is not set
    # CONFIG_SENSORS_ADT7475 is not set
    # CONFIG_SENSORS_ASC7621 is not set
    # CONFIG_SENSORS_ATXP1 is not set
    # CONFIG_SENSORS_DS1621 is not set
    # CONFIG_SENSORS_F71805F is not set
    # CONFIG_SENSORS_F71882FG is not set
    # CONFIG_SENSORS_F75375S is not set
    # CONFIG_SENSORS_G760A is not set
    # CONFIG_SENSORS_GL518SM is not set
    # CONFIG_SENSORS_GL520SM is not set
    # CONFIG_SENSORS_GPIO_FAN is not set
    # CONFIG_SENSORS_IT87 is not set
    # CONFIG_SENSORS_JC42 is not set
    # CONFIG_SENSORS_LM63 is not set
    # CONFIG_SENSORS_LM70 is not set
    # CONFIG_SENSORS_LM73 is not set
    # CONFIG_SENSORS_LM75 is not set
    # CONFIG_SENSORS_LM77 is not set
    # CONFIG_SENSORS_LM78 is not set
    # CONFIG_SENSORS_LM80 is not set
    # CONFIG_SENSORS_LM83 is not set
    # CONFIG_SENSORS_LM85 is not set
    # CONFIG_SENSORS_LM87 is not set
    # CONFIG_SENSORS_LM90 is not set
    # CONFIG_SENSORS_LM92 is not set
    # CONFIG_SENSORS_LM93 is not set
    # CONFIG_SENSORS_LTC4215 is not set
    # CONFIG_SENSORS_LTC4245 is not set
    # CONFIG_SENSORS_LTC4261 is not set
    # CONFIG_SENSORS_LM95241 is not set
    # CONFIG_SENSORS_MAX1111 is not set
    # CONFIG_SENSORS_MAX1619 is not set
    # CONFIG_SENSORS_MAX6650 is not set
    # CONFIG_SENSORS_PC87360 is not set
    # CONFIG_SENSORS_PC87427 is not set
    # CONFIG_SENSORS_PCF8591 is not set
    # CONFIG_SENSORS_SHT15 is not set
    # CONFIG_SENSORS_SMM665 is not set
    # CONFIG_SENSORS_DME1737 is not set
    # CONFIG_SENSORS_EMC1403 is not set
    # CONFIG_SENSORS_EMC2103 is not set
    # CONFIG_SENSORS_SMSC47M1 is not set
    # CONFIG_SENSORS_SMSC47M192 is not set
    # CONFIG_SENSORS_SMSC47B397 is not set
    # CONFIG_SENSORS_ADS7828 is not set
    # CONFIG_SENSORS_ADS7871 is not set
    # CONFIG_SENSORS_AMC6821 is not set
    # CONFIG_SENSORS_THMC50 is not set
    # CONFIG_SENSORS_TMP102 is not set
    # CONFIG_SENSORS_TMP401 is not set
    # CONFIG_SENSORS_TMP421 is not set
    # CONFIG_SENSORS_VT1211 is not set
    # CONFIG_SENSORS_W83781D is not set
    # CONFIG_SENSORS_W83791D is not set
    # CONFIG_SENSORS_W83792D is not set
    # CONFIG_SENSORS_W83793 is not set
    # CONFIG_SENSORS_W83795 is not set
    # CONFIG_SENSORS_W83L785TS is not set
    # CONFIG_SENSORS_W83L786NG is not set
    # CONFIG_SENSORS_W83627HF is not set
    # CONFIG_SENSORS_W83627EHF is not set
    # CONFIG_SENSORS_LIS3_SPI is not set
    # CONFIG_SENSORS_LIS3_I2C is not set
    CONFIG_THERMAL=y
    CONFIG_THERMAL_HWMON=y
    CONFIG_WATCHDOG=y
    CONFIG_WATCHDOG_NOWAYOUT=y
    # Watchdog Device Drivers
    # CONFIG_SOFT_WATCHDOG is not set
    CONFIG_OMAP_WATCHDOG=y
    # CONFIG_TWL4030_WATCHDOG is not set
    # CONFIG_MAX63XX_WATCHDOG is not set
    # USB-based Watchdog Cards
    # CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    # Sonics Silicon Backplane
    CONFIG_SSB=y
    CONFIG_SSB_BLOCKIO=y
    CONFIG_SSB_SDIOHOST_POSSIBLE=y
    # CONFIG_SSB_SDIOHOST is not set
    # CONFIG_SSB_SILENT is not set
    # CONFIG_SSB_DEBUG is not set
    CONFIG_MFD_SUPPORT=y
    CONFIG_MFD_CORE=y
    # CONFIG_MFD_88PM860X is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_MFD_ASIC3 is not set
    # CONFIG_HTC_EGPIO is not set
    # CONFIG_HTC_PASIC3 is not set
    # CONFIG_HTC_I2CPLD is not set
    # CONFIG_TPS65010 is not set
    # CONFIG_TPS6507X is not set
    CONFIG_TWL4030_CORE=y
    CONFIG_TWL4030_POWER=y
    CONFIG_TWL4030_CODEC=y
    # CONFIG_TWL6030_PWM is not set
    # CONFIG_MFD_STMPE is not set
    # CONFIG_MFD_TC35892 is not set
    # CONFIG_MFD_TMIO is not set
    # CONFIG_MFD_T7L66XB is not set
    # CONFIG_MFD_TC6387XB is not set
    # CONFIG_MFD_TC6393XB is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_PMIC_ADP5520 is not set
    # CONFIG_MFD_MAX8925 is not set
    # CONFIG_MFD_MAX8998 is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM831X_I2C is not set
    # CONFIG_MFD_WM831X_SPI is not set
    # CONFIG_MFD_WM8350_I2C is not set
    # CONFIG_MFD_WM8994 is not set
    # CONFIG_MFD_PCF50633 is not set
    # CONFIG_MFD_MC13XXX is not set
    # CONFIG_ABX500_CORE is not set
    # CONFIG_EZX_PCAP is not set
    # CONFIG_MFD_TPS6586X is not set
    CONFIG_REGULATOR=y
    # CONFIG_REGULATOR_DEBUG is not set
    # CONFIG_REGULATOR_DUMMY is not set
    # CONFIG_REGULATOR_FIXED_VOLTAGE is not set
    # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
    # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
    # CONFIG_REGULATOR_BQ24022 is not set
    # CONFIG_REGULATOR_MAX1586 is not set
    # CONFIG_REGULATOR_MAX8649 is not set
    # CONFIG_REGULATOR_MAX8660 is not set
    # CONFIG_REGULATOR_MAX8952 is not set
    CONFIG_REGULATOR_TWL4030=y
    # CONFIG_REGULATOR_LP3971 is not set
    # CONFIG_REGULATOR_LP3972 is not set
    # CONFIG_REGULATOR_TPS65023 is not set
    # CONFIG_REGULATOR_TPS6507X is not set
    # CONFIG_REGULATOR_ISL6271A is not set
    # CONFIG_REGULATOR_AD5398 is not set
    CONFIG_MEDIA_SUPPORT=y
    # Multimedia core support
    # CONFIG_MEDIA_CONTROLLER is not set
    CONFIG_VIDEO_DEV=y
    CONFIG_VIDEO_V4L2_COMMON=y
    CONFIG_VIDEO_ALLOW_V4L1=y
    CONFIG_VIDEO_V4L1_COMPAT=y
    CONFIG_DVB_CORE=m
    CONFIG_VIDEO_MEDIA=m
    # Multimedia drivers
    CONFIG_IR_CORE=y
    CONFIG_VIDEO_IR=y
    CONFIG_LIRC=y
    CONFIG_RC_MAP=y
    CONFIG_IR_NEC_DECODER=y
    CONFIG_IR_RC5_DECODER=y
    CONFIG_IR_RC6_DECODER=y
    CONFIG_IR_JVC_DECODER=y
    CONFIG_IR_SONY_DECODER=y
    CONFIG_IR_RC5_SZ_DECODER=y
    CONFIG_IR_LIRC_CODEC=y
    # CONFIG_IR_IMON is not set
    # CONFIG_IR_MCEUSB is not set
    # CONFIG_IR_STREAMZAP is not set
    CONFIG_MEDIA_ATTACH=y
    CONFIG_MEDIA_TUNER=m
    CONFIG_MEDIA_TUNER_CUSTOMISE=y
    # Customize TV tuners
    CONFIG_MEDIA_TUNER_SIMPLE=m
    CONFIG_MEDIA_TUNER_TDA8290=m
    CONFIG_MEDIA_TUNER_TDA827X=m
    CONFIG_MEDIA_TUNER_TDA18271=m
    CONFIG_MEDIA_TUNER_TDA9887=m
    CONFIG_MEDIA_TUNER_TEA5761=m
    CONFIG_MEDIA_TUNER_TEA5767=m
    CONFIG_MEDIA_TUNER_MT20XX=m
    CONFIG_MEDIA_TUNER_MT2060=m
    CONFIG_MEDIA_TUNER_MT2266=m
    CONFIG_MEDIA_TUNER_MT2131=m
    CONFIG_MEDIA_TUNER_QT1010=m
    CONFIG_MEDIA_TUNER_XC2028=m
    CONFIG_MEDIA_TUNER_XC5000=m
    CONFIG_MEDIA_TUNER_MXL5005S=m
    CONFIG_MEDIA_TUNER_MXL5007T=m
    CONFIG_MEDIA_TUNER_MC44S803=m
    CONFIG_MEDIA_TUNER_MAX2165=m
    CONFIG_MEDIA_TUNER_TDA18218=m
    CONFIG_VIDEO_V4L2=y
    CONFIG_VIDEO_V4L1=y
    CONFIG_VIDEOBUF_GEN=y
    CONFIG_VIDEOBUF_VMALLOC=m
    CONFIG_VIDEOBUF_DMA_CONTIG=y
    CONFIG_VIDEOBUF_DVB=m
    CONFIG_VIDEO_TVEEPROM=m
    CONFIG_VIDEO_TUNER=m
    CONFIG_VIDEO_CAPTURE_DRIVERS=y
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    # CONFIG_VIDEO_HELPER_CHIPS_AUTO is not set
    CONFIG_VIDEO_IR_I2C=m
    # Encoders/decoders and other helper chips
    # Audio decoders
    # CONFIG_VIDEO_TVAUDIO is not set
    # CONFIG_VIDEO_TDA7432 is not set
    # CONFIG_VIDEO_TDA9840 is not set
    # CONFIG_VIDEO_TDA9875 is not set
    # CONFIG_VIDEO_TEA6415C is not set
    # CONFIG_VIDEO_TEA6420 is not set
    CONFIG_VIDEO_MSP3400=m
    # CONFIG_VIDEO_CS5345 is not set
    CONFIG_VIDEO_CS53L32A=m
    # CONFIG_VIDEO_M52790 is not set
    # CONFIG_VIDEO_TLV320AIC23B is not set
    CONFIG_VIDEO_WM8775=m
    # CONFIG_VIDEO_WM8739 is not set
    # CONFIG_VIDEO_VP27SMPX is not set
    # RDS decoders
    # CONFIG_VIDEO_SAA6588 is not set
    # Video decoders
    # CONFIG_VIDEO_ADV7180 is not set
    # CONFIG_VIDEO_BT819 is not set
    # CONFIG_VIDEO_BT856 is not set
    # CONFIG_VIDEO_BT866 is not set
    # CONFIG_VIDEO_KS0127 is not set
    # CONFIG_VIDEO_OV7670 is not set
    # CONFIG_VIDEO_MT9T001 is not set
    CONFIG_VIDEO_MT9V011=m
    # CONFIG_VIDEO_MT9V113 is not set
    # CONFIG_VIDEO_MT9T111 is not set
    # CONFIG_VIDEO_TCM825X is not set
    # CONFIG_VIDEO_SAA7110 is not set
    CONFIG_VIDEO_SAA711X=m
    # CONFIG_VIDEO_SAA717X is not set
    # CONFIG_VIDEO_SAA7191 is not set
    # CONFIG_VIDEO_TVP514X is not set
    # CONFIG_VIDEO_TVP5150 is not set
    # CONFIG_VIDEO_TVP7002 is not set
    # CONFIG_VIDEO_VPX3220 is not set
    # Video and audio decoders
    CONFIG_VIDEO_CX25840=m
    # MPEG video encoders
    CONFIG_VIDEO_CX2341X=m
    # Video encoders
    # CONFIG_VIDEO_SAA7127 is not set
    # CONFIG_VIDEO_SAA7185 is not set
    # CONFIG_VIDEO_ADV7170 is not set
    # CONFIG_VIDEO_ADV7175 is not set
    # CONFIG_VIDEO_THS7303 is not set
    # CONFIG_VIDEO_ADV7343 is not set
    # CONFIG_VIDEO_AK881X is not set
    # Video improvement chips
    # CONFIG_VIDEO_UPD64031A is not set
    # CONFIG_VIDEO_UPD64083 is not set
    CONFIG_VIDEO_VIVI=m
    # CONFIG_VIDEO_VPSS_SYSTEM is not set
    CONFIG_VIDEO_VPFE_CAPTURE=y
    # CONFIG_VIDEO_DM6446_CCDC is not set
    CONFIG_VIDEO_OMAP2_VOUT=y
    # CONFIG_VIDEO_CPIA2 is not set
    # CONFIG_VIDEO_AU0828 is not set
    # CONFIG_VIDEO_SR030PC30 is not set
    # CONFIG_SOC_CAMERA is not set
    CONFIG_V4L_USB_DRIVERS=y
    CONFIG_USB_VIDEO_CLASS=m
    CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
    CONFIG_USB_GSPCA=m
    CONFIG_USB_M5602=m
    CONFIG_USB_STV06XX=m
    # CONFIG_USB_GL860 is not set
    # CONFIG_USB_GSPCA_BENQ is not set
    CONFIG_USB_GSPCA_CONEX=m
    # CONFIG_USB_GSPCA_CPIA1 is not set
    CONFIG_USB_GSPCA_ETOMS=m
    CONFIG_USB_GSPCA_FINEPIX=m
    # CONFIG_USB_GSPCA_JEILINJ is not set
    # CONFIG_USB_GSPCA_KONICA is not set
    CONFIG_USB_GSPCA_MARS=m
    # CONFIG_USB_GSPCA_MR97310A is not set
    CONFIG_USB_GSPCA_OV519=m
    CONFIG_USB_GSPCA_OV534=m
    # CONFIG_USB_GSPCA_OV534_9 is not set
    CONFIG_USB_GSPCA_PAC207=m
    # CONFIG_USB_GSPCA_PAC7302 is not set
    CONFIG_USB_GSPCA_PAC7311=m
    # CONFIG_USB_GSPCA_SN9C2028 is not set
    # CONFIG_USB_GSPCA_SN9C20X is not set
    CONFIG_USB_GSPCA_SONIXB=m
    CONFIG_USB_GSPCA_SONIXJ=m
    CONFIG_USB_GSPCA_SPCA500=m
    CONFIG_USB_GSPCA_SPCA501=m
    CONFIG_USB_GSPCA_SPCA505=m
    CONFIG_USB_GSPCA_SPCA506=m
    CONFIG_USB_GSPCA_SPCA508=m
    CONFIG_USB_GSPCA_SPCA561=m
    # CONFIG_USB_GSPCA_SPCA1528 is not set
    # CONFIG_USB_GSPCA_SQ905 is not set
    # CONFIG_USB_GSPCA_SQ905C is not set
    # CONFIG_USB_GSPCA_SQ930X is not set
    CONFIG_USB_GSPCA_STK014=m
    # CONFIG_USB_GSPCA_STV0680 is not set
    CONFIG_USB_GSPCA_SUNPLUS=m
    CONFIG_USB_GSPCA_T613=m
    CONFIG_USB_GSPCA_TV8532=m
    CONFIG_USB_GSPCA_VC032X=m
    # CONFIG_USB_GSPCA_XIRLINK_CIT is not set
    CONFIG_USB_GSPCA_ZC3XX=m
    CONFIG_VIDEO_PVRUSB2=m
    CONFIG_VIDEO_PVRUSB2_SYSFS=y
    CONFIG_VIDEO_PVRUSB2_DVB=y
    # CONFIG_VIDEO_PVRUSB2_DEBUGIFC is not set
    CONFIG_VIDEO_HDPVR=m
    CONFIG_VIDEO_EM28XX=m
    CONFIG_VIDEO_EM28XX_ALSA=m
    CONFIG_VIDEO_EM28XX_DVB=m
    # CONFIG_VIDEO_TLG2300 is not set
    CONFIG_VIDEO_CX231XX=m
    # CONFIG_VIDEO_CX231XX_ALSA is not set
    CONFIG_VIDEO_CX231XX_DVB=m
    CONFIG_VIDEO_USBVISION=m
    # CONFIG_USB_VICAM is not set
    # CONFIG_USB_IBMCAM is not set
    # CONFIG_USB_KONICAWC is not set
    CONFIG_USB_ET61X251=m
    # CONFIG_USB_SE401 is not set
    CONFIG_USB_SN9C102=m
    CONFIG_USB_PWC=m
    # CONFIG_USB_PWC_DEBUG is not set
    CONFIG_USB_PWC_INPUT_EVDEV=y
    CONFIG_USB_ZR364XX=m
    CONFIG_USB_STKWEBCAM=m
    CONFIG_USB_S2255=m
    # CONFIG_V4L_MEM2MEM_DRIVERS is not set
    CONFIG_RADIO_ADAPTERS=y
    # CONFIG_I2C_SI4713 is not set
    # CONFIG_RADIO_SI4713 is not set
    # CONFIG_USB_DSBR is not set
    # CONFIG_RADIO_SI470X is not set
    # CONFIG_USB_MR800 is not set
    # CONFIG_RADIO_TEA5764 is not set
    # CONFIG_RADIO_SAA7706H is not set
    # CONFIG_RADIO_TEF6862 is not set
    CONFIG_DVB_MAX_ADAPTERS=8
    CONFIG_DVB_DYNAMIC_MINORS=y
    CONFIG_DVB_CAPTURE_DRIVERS=y
    # CONFIG_TTPCI_EEPROM is not set
    # Supported USB Adapters
    CONFIG_DVB_USB=m
    # CONFIG_DVB_USB_DEBUG is not set
    CONFIG_DVB_USB_A800=m
    CONFIG_DVB_USB_DIBUSB_MB=m
    # CONFIG_DVB_USB_DIBUSB_MB_FAULTY is not set
    CONFIG_DVB_USB_DIBUSB_MC=m
    CONFIG_DVB_USB_DIB0700=m
    CONFIG_DVB_USB_UMT_010=m
    CONFIG_DVB_USB_CXUSB=m
    CONFIG_DVB_USB_M920X=m
    CONFIG_DVB_USB_GL861=m
    CONFIG_DVB_USB_AU6610=m
    CONFIG_DVB_USB_DIGITV=m
    CONFIG_DVB_USB_VP7045=m
    CONFIG_DVB_USB_VP702X=m
    CONFIG_DVB_USB_GP8PSK=m
    CONFIG_DVB_USB_NOVA_T_USB2=m
    CONFIG_DVB_USB_TTUSB2=m
    CONFIG_DVB_USB_DTT200U=m
    CONFIG_DVB_USB_OPERA1=m
    CONFIG_DVB_USB_AF9005=m
    CONFIG_DVB_USB_AF9005_REMOTE=m
    CONFIG_DVB_USB_DW2102=m
    CONFIG_DVB_USB_CINERGY_T2=m
    CONFIG_DVB_USB_ANYSEE=m
    CONFIG_DVB_USB_DTV5100=m
    CONFIG_DVB_USB_AF9015=m
    # CONFIG_DVB_USB_CE6230 is not set
    # CONFIG_DVB_USB_FRIIO is not set
    # CONFIG_DVB_USB_EC168 is not set
    # CONFIG_DVB_USB_AZ6027 is not set
    # CONFIG_DVB_USB_LME2510 is not set
    # CONFIG_SMS_SIANO_MDTV is not set
    # Supported FlexCopII (B2C2) Adapters
    CONFIG_DVB_B2C2_FLEXCOP=m
    CONFIG_DVB_B2C2_FLEXCOP_USB=m
    # CONFIG_DVB_B2C2_FLEXCOP_DEBUG is not set
    # Supported DVB Frontends
    # CONFIG_DVB_FE_CUSTOMISE is not set
    # Multistandard (satellite) frontends
    CONFIG_DVB_STB6100=m
    # DVB-S (satellite) frontends
    CONFIG_DVB_CX24123=m
    CONFIG_DVB_MT312=m
    CONFIG_DVB_ZL10039=m
    CONFIG_DVB_S5H1420=m
    CONFIG_DVB_STV0288=m
    CONFIG_DVB_STB6000=m
    CONFIG_DVB_STV0299=m
    CONFIG_DVB_STV6110=m
    CONFIG_DVB_STV0900=m
    CONFIG_DVB_TDA10086=m
    CONFIG_DVB_TUNER_ITD1000=m
    CONFIG_DVB_TUNER_CX24113=m
    CONFIG_DVB_TDA826X=m
    CONFIG_DVB_CX24116=m
    CONFIG_DVB_SI21XX=m
    CONFIG_DVB_DS3000=m
    # DVB-T (terrestrial) frontends
    CONFIG_DVB_CX22702=m
    CONFIG_DVB_TDA1004X=m
    CONFIG_DVB_NXT6000=m
    CONFIG_DVB_MT352=m
    CONFIG_DVB_ZL10353=m
    CONFIG_DVB_DIB3000MB=m
    CONFIG_DVB_DIB3000MC=m
    CONFIG_DVB_DIB7000M=m
    CONFIG_DVB_DIB7000P=m
    CONFIG_DVB_TDA10048=m
    CONFIG_DVB_AF9013=m
    # DVB-C (cable) frontends
    CONFIG_DVB_TDA10023=m
    CONFIG_DVB_STV0297=m
    # ATSC (North American/Korean Terrestrial/Cable DTV) frontends
    CONFIG_DVB_NXT200X=m
    CONFIG_DVB_BCM3510=m
    CONFIG_DVB_LGDT330X=m
    CONFIG_DVB_LGDT3305=m
    CONFIG_DVB_S5H1409=m
    CONFIG_DVB_S5H1411=m
    # ISDB-T (terrestrial) frontends
    CONFIG_DVB_DIB8000=m
    # Digital terrestrial only tuners/PLL
    CONFIG_DVB_PLL=m
    CONFIG_DVB_TUNER_DIB0070=m
    CONFIG_DVB_TUNER_DIB0090=m
    # SEC control devices for DVB-S
    CONFIG_DVB_LNBP21=m
    CONFIG_DVB_ISL6421=m
    CONFIG_DVB_LGS8GXX=m
    CONFIG_DVB_ATBM8830=m
    # Tools to develop new frontends
    # CONFIG_DVB_DUMMY_FE is not set
    # CONFIG_DAB is not set
    # Graphics support
    # CONFIG_DRM is not set
    # CONFIG_VGASTATE is not set
    # CONFIG_VIDEO_OUTPUT_CONTROL is not set
    CONFIG_FB=y
    # CONFIG_FIRMWARE_EDID is not set
    # CONFIG_FB_DDC is not set
    # CONFIG_FB_BOOT_VESA_SUPPORT is not set
    CONFIG_FB_CFB_FILLRECT=y
    CONFIG_FB_CFB_COPYAREA=y
    CONFIG_FB_CFB_IMAGEBLIT=y
    # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
    # CONFIG_FB_SYS_FILLRECT is not set
    # CONFIG_FB_SYS_COPYAREA is not set
    # CONFIG_FB_SYS_IMAGEBLIT is not set
    # CONFIG_FB_FOREIGN_ENDIAN is not set
    # CONFIG_FB_SYS_FOPS is not set
    # CONFIG_FB_SVGALIB is not set
    # CONFIG_FB_MACMODES is not set
    # CONFIG_FB_BACKLIGHT is not set
    CONFIG_FB_MODE_HELPERS=y
    # CONFIG_FB_TILEBLITTING is not set
    # Frame buffer hardware drivers
    # CONFIG_FB_S1D13XXX is not set
    # CONFIG_FB_TMIO is not set
    # CONFIG_FB_VIRTUAL is not set
    # CONFIG_FB_METRONOME is not set
    # CONFIG_FB_MB862XX is not set
    # CONFIG_FB_BROADSHEET is not set
    # CONFIG_FB_OMAP_BOOTLOADER_INIT is not set
    CONFIG_OMAP2_VRAM=y
    CONFIG_OMAP2_VRFB=y
    CONFIG_OMAP2_DSS=y
    CONFIG_OMAP2_VRAM_SIZE=14
    CONFIG_OMAP2_DSS_DEBUG_SUPPORT=y
    # CONFIG_OMAP2_DSS_COLLECT_IRQ_STATS is not set
    CONFIG_OMAP2_DSS_DPI=y
    # CONFIG_OMAP2_DSS_RFBI is not set
    CONFIG_OMAP2_DSS_VENC=y
    CONFIG_OMAP2_VENC_OUT_TYPE_SVIDEO=y
    # CONFIG_OMAP2_VENC_OUT_TYPE_COMPOSITE is not set
    # CONFIG_OMAP2_DSS_SDI is not set
    CONFIG_OMAP2_DSS_DSI=y
    CONFIG_OMAP2_DSS_USE_DSI_PLL=y
    # CONFIG_OMAP2_DSS_FAKE_VSYNC is not set
    CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0
    CONFIG_FB_OMAP2=y
    CONFIG_FB_OMAP2_DEBUG_SUPPORT=y
    CONFIG_FB_OMAP2_NUM_FBS=3
    # OMAP2/3 Display Device Drivers
    # CONFIG_PANEL_GENERIC is not set
    CONFIG_PANEL_SHARP_LS037V7DW01=y
    # CONFIG_PANEL_SHARP_LQ043T1DG01 is not set
    # CONFIG_PANEL_TAAL is not set
    # CONFIG_PANEL_TOPPOLY_TDO35S is not set
    # CONFIG_PANEL_TPO_TD043MTEA1 is not set
    # CONFIG_BACKLIGHT_LCD_SUPPORT is not set
    CONFIG_BACKLIGHT_CLASS_DEVICE=y
    # Display device support
    CONFIG_DISPLAY_SUPPORT=y
    # Display hardware drivers
    # Console display driver support
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE=y
    # CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY is not set
    CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
    # CONFIG_FONTS is not set
    CONFIG_FONT_8x8=y
    CONFIG_FONT_8x16=y
    CONFIG_LOGO=y
    # CONFIG_LOGO_LINUX_MONO is not set
    # CONFIG_LOGO_LINUX_VGA16 is not set
    CONFIG_LOGO_LINUX_CLUT224=y
    CONFIG_SOUND=y
    CONFIG_SOUND_OSS_CORE=y
    CONFIG_SOUND_OSS_CORE_PRECLAIM=y
    CONFIG_SND=y
    CONFIG_SND_TIMER=y
    CONFIG_SND_PCM=y
    CONFIG_SND_HWDEP=y
    CONFIG_SND_RAWMIDI=y
    CONFIG_SND_JACK=y
    CONFIG_SND_SEQUENCER=m
    # CONFIG_SND_SEQ_DUMMY is not set
    CONFIG_SND_OSSEMUL=y
    CONFIG_SND_MIXER_OSS=y
    CONFIG_SND_PCM_OSS=y
    CONFIG_SND_PCM_OSS_PLUGINS=y
    CONFIG_SND_SEQUENCER_OSS=y
    CONFIG_SND_HRTIMER=m
    CONFIG_SND_SEQ_HRTIMER_DEFAULT=y
    # CONFIG_SND_DYNAMIC_MINORS is not set
    CONFIG_SND_SUPPORT_OLD_API=y
    CONFIG_SND_VERBOSE_PROCFS=y
    # CONFIG_SND_VERBOSE_PRINTK is not set
    # CONFIG_SND_DEBUG is not set
    CONFIG_SND_RAWMIDI_SEQ=m
    # CONFIG_SND_OPL3_LIB_SEQ is not set
    # CONFIG_SND_OPL4_LIB_SEQ is not set
    # CONFIG_SND_SBAWE_SEQ is not set
    # CONFIG_SND_EMU10K1_SEQ is not set
    CONFIG_SND_DRIVERS=y
    # CONFIG_SND_DUMMY is not set
    # CONFIG_SND_ALOOP is not set
    # CONFIG_SND_VIRMIDI is not set
    # CONFIG_SND_MTPAV is not set
    # CONFIG_SND_SERIAL_U16550 is not set
    # CONFIG_SND_MPU401 is not set
    # CONFIG_SND_ARM is not set
    CONFIG_SND_SPI=y
    CONFIG_SND_USB=y
    CONFIG_SND_USB_AUDIO=y
    # CONFIG_SND_USB_UA101 is not set
    CONFIG_SND_USB_CAIAQ=m
    CONFIG_SND_USB_CAIAQ_INPUT=y
    CONFIG_SND_SOC=y
    CONFIG_SND_OMAP_SOC=y
    CONFIG_SND_OMAP_SOC_MCBSP=y
    CONFIG_SND_OMAP_SOC_OMAP3_BEAGLE=y
    CONFIG_SND_SOC_I2C_AND_SPI=y
    # CONFIG_SND_SOC_ALL_CODECS is not set
    CONFIG_SND_SOC_TWL4030=y
    # CONFIG_SOUND_PRIME is not set
    CONFIG_HID_SUPPORT=y
    CONFIG_HID=y
    # CONFIG_HIDRAW is not set
    # USB Input Devices
    CONFIG_USB_HID=y
    # CONFIG_HID_PID is not set
    # CONFIG_USB_HIDDEV is not set
    # Special HID drivers
    # CONFIG_HID_3M_PCT is not set
    CONFIG_HID_A4TECH=y
    # CONFIG_HID_ACRUX_FF is not set
    CONFIG_HID_APPLE=y
    CONFIG_HID_BELKIN=y
    # CONFIG_HID_CANDO is not set
    CONFIG_HID_CHERRY=y
    CONFIG_HID_CHICONY=y
    # CONFIG_HID_PRODIKEYS is not set
    CONFIG_HID_CYPRESS=y
    # CONFIG_HID_DRAGONRISE is not set
    # CONFIG_HID_EGALAX is not set
    # CONFIG_HID_ELECOM is not set
    CONFIG_HID_EZKEY=y
    # CONFIG_HID_KYE is not set
    # CONFIG_HID_UCLOGIC is not set
    # CONFIG_HID_WALTOP is not set
    CONFIG_HID_GYRATION=y
    # CONFIG_HID_TWINHAN is not set
    # CONFIG_HID_KENSINGTON is not set
    CONFIG_HID_LOGITECH=y
    # CONFIG_LOGITECH_FF is not set
    # CONFIG_LOGIRUMBLEPAD2_FF is not set
    # CONFIG_LOGIG940_FF is not set
    # CONFIG_LOGIWII_FF is not set
    # CONFIG_HID_MAGICMOUSE is not set
    CONFIG_HID_MICROSOFT=y
    # CONFIG_HID_MOSART is not set
    CONFIG_HID_MONTEREY=y
    CONFIG_HID_NTRIG=y
    # CONFIG_HID_ORTEK is not set
    CONFIG_HID_PANTHERLORD=y
    # CONFIG_PANTHERLORD_FF is not set
    CONFIG_HID_PETALYNX=y
    # CONFIG_HID_PICOLCD is not set
    # CONFIG_HID_QUANTA is not set
    # CONFIG_HID_ROCCAT is not set
    # CONFIG_HID_ROCCAT_KONE is not set
    # CONFIG_HID_ROCCAT_PYRA is not set
    CONFIG_HID_SAMSUNG=y
    CONFIG_HID_SONY=y
    # CONFIG_HID_STANTUM is not set
    CONFIG_HID_SUNPLUS=y
    # CONFIG_HID_GREENASIA is not set
    # CONFIG_HID_SMARTJOYPLUS is not set
    CONFIG_HID_TOPSEED=y
    # CONFIG_HID_THRUSTMASTER is not set
    # CONFIG_HID_WACOM is not set
    # CONFIG_HID_ZEROPLUS is not set
    # CONFIG_HID_ZYDACRON is not set
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB_ARCH_HAS_OHCI=y
    CONFIG_USB_ARCH_HAS_EHCI=y
    CONFIG_USB=y
    # CONFIG_USB_DEBUG is not set
    CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
    # Miscellaneous USB options
    CONFIG_USB_DEVICEFS=y
    CONFIG_USB_DEVICE_CLASS=y
    # CONFIG_USB_DYNAMIC_MINORS is not set
    CONFIG_USB_SUSPEND=y
    CONFIG_USB_OTG=y
    # CONFIG_USB_OTG_WHITELIST is not set
    # CONFIG_USB_OTG_BLACKLIST_HUB is not set
    CONFIG_USB_MON=y
    # CONFIG_USB_WUSB is not set
    # CONFIG_USB_WUSB_CBAF is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    CONFIG_USB_EHCI_HCD=y
    # CONFIG_USB_EHCI_ROOT_HUB_TT is not set
    CONFIG_USB_EHCI_TT_NEWSCHED=y
    # CONFIG_USB_OXU210HP_HCD is not set
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_ISP1760_HCD is not set
    # CONFIG_USB_ISP1362_HCD is not set
    # CONFIG_USB_OHCI_HCD is not set
    # CONFIG_USB_U132_HCD is not set
    # CONFIG_USB_SL811_HCD is not set
    # CONFIG_USB_R8A66597_HCD is not set
    # CONFIG_USB_HWA_HCD is not set
    CONFIG_USB_MUSB_HDRC=y
    # Platform Glue Layer
    # CONFIG_USB_MUSB_TUSB6010_GLUE is not set
    # CONFIG_USB_MUSB_OMAP2PLUS_GLUE is not set
    # CONFIG_USB_MUSB_AM35X_GLUE is not set
    # CONFIG_USB_MUSB_DAVINCI is not set
    # CONFIG_USB_MUSB_DA8XX is not set
    # CONFIG_USB_MUSB_TUSB6010 is not set
    # CONFIG_USB_MUSB_OMAP2PLUS is not set
    # CONFIG_USB_MUSB_AM35X is not set
    # CONFIG_USB_MUSB_TI81XX is not set
    # CONFIG_USB_MUSB_BLACKFIN is not set
    # CONFIG_USB_MUSB_UX500 is not set
    # CONFIG_USB_MUSB_HOST is not set
    # CONFIG_USB_MUSB_PERIPHERAL is not set
    CONFIG_USB_MUSB_OTG=y
    CONFIG_USB_GADGET_MUSB_HDRC=y
    CONFIG_USB_MUSB_HDRC_HCD=y
    # CONFIG_MUSB_PIO_ONLY is not set
    # CONFIG_USB_INVENTRA_DMA_HW is not set
    # CONFIG_USB_TI_CPPI_DMA_HW is not set
    # CONFIG_USB_TI_CPPI41_DMA_HW is not set
    # CONFIG_USB_INVENTRA_DMA is not set
    # CONFIG_USB_TI_CPPI_DMA is not set
    # CONFIG_USB_TI_CPPI41_DMA is not set
    # CONFIG_USB_TUSB_OMAP_DMA is not set
    # CONFIG_USB_MUSB_DEBUG is not set
    # USB Device Class drivers
    CONFIG_USB_ACM=m
    CONFIG_USB_PRINTER=m
    CONFIG_USB_WDM=m
    CONFIG_USB_TMC=m
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
    # also be needed; see USB_STORAGE Help for more info
    CONFIG_USB_STORAGE=y
    # CONFIG_USB_STORAGE_DEBUG is not set
    # CONFIG_USB_STORAGE_DATAFAB is not set
    # CONFIG_USB_STORAGE_FREECOM is not set
    # CONFIG_USB_STORAGE_ISD200 is not set
    # CONFIG_USB_STORAGE_USBAT is not set
    # CONFIG_USB_STORAGE_SDDR09 is not set
    # CONFIG_USB_STORAGE_SDDR55 is not set
    # CONFIG_USB_STORAGE_JUMPSHOT is not set
    # CONFIG_USB_STORAGE_ALAUDA is not set
    # CONFIG_USB_STORAGE_ONETOUCH is not set
    # CONFIG_USB_STORAGE_KARMA is not set
    # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
    # CONFIG_USB_UAS is not set
    # CONFIG_USB_LIBUSUAL is not set
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    # USB port drivers
    CONFIG_USB_SERIAL=m
    CONFIG_USB_EZUSB=y
    CONFIG_USB_SERIAL_GENERIC=y
    CONFIG_USB_SERIAL_AIRCABLE=m
    CONFIG_USB_SERIAL_ARK3116=m
    CONFIG_USB_SERIAL_BELKIN=m
    CONFIG_USB_SERIAL_CH341=m
    CONFIG_USB_SERIAL_WHITEHEAT=m
    CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
    # CONFIG_USB_SERIAL_CP210X is not set
    CONFIG_USB_SERIAL_CYPRESS_M8=m
    CONFIG_USB_SERIAL_EMPEG=m
    CONFIG_USB_SERIAL_FTDI_SIO=m
    CONFIG_USB_SERIAL_FUNSOFT=m
    CONFIG_USB_SERIAL_VISOR=m
    CONFIG_USB_SERIAL_IPAQ=m
    CONFIG_USB_SERIAL_IR=m
    CONFIG_USB_SERIAL_EDGEPORT=m
    CONFIG_USB_SERIAL_EDGEPORT_TI=m
    CONFIG_USB_SERIAL_GARMIN=m
    CONFIG_USB_SERIAL_IPW=m
    CONFIG_USB_SERIAL_IUU=m
    CONFIG_USB_SERIAL_KEYSPAN_PDA=m
    CONFIG_USB_SERIAL_KEYSPAN=m
    CONFIG_USB_SERIAL_KEYSPAN_MPR=y
    CONFIG_USB_SERIAL_KEYSPAN_USA28=y
    CONFIG_USB_SERIAL_KEYSPAN_USA28X=y
    CONFIG_USB_SERIAL_KEYSPAN_USA28XA=y
    CONFIG_USB_SERIAL_KEYSPAN_USA28XB=y
    CONFIG_USB_SERIAL_KEYSPAN_USA19=y
    CONFIG_USB_SERIAL_KEYSPAN_USA18X=y
    CONFIG_USB_SERIAL_KEYSPAN_USA19W=y
    CONFIG_USB_SERIAL_KEYSPAN_USA19QW=y
    CONFIG_USB_SERIAL_KEYSPAN_USA19QI=y
    CONFIG_USB_SERIAL_KEYSPAN_USA49W=y
    CONFIG_USB_SERIAL_KEYSPAN_USA49WLC=y
    CONFIG_USB_SERIAL_KLSI=m
    CONFIG_USB_SERIAL_KOBIL_SCT=m
    CONFIG_USB_SERIAL_MCT_U232=m
    CONFIG_USB_SERIAL_MOS7720=m
    CONFIG_USB_SERIAL_MOS7840=m
    CONFIG_USB_SERIAL_MOTOROLA=m
    CONFIG_USB_SERIAL_NAVMAN=m
    CONFIG_USB_SERIAL_PL2303=m
    CONFIG_USB_SERIAL_OTI6858=m
    # CONFIG_USB_SERIAL_QCAUX is not set
    # CONFIG_USB_SERIAL_QUALCOMM is not set
    CONFIG_USB_SERIAL_SPCP8X5=m
    CONFIG_USB_SERIAL_HP4X=m
    CONFIG_USB_SERIAL_SAFE=m
    # CONFIG_USB_SERIAL_SAFE_PADDED is not set
    # CONFIG_USB_SERIAL_SAMBA is not set
    CONFIG_USB_SERIAL_SIEMENS_MPI=m
    CONFIG_USB_SERIAL_SIERRAWIRELESS=m
    # CONFIG_USB_SERIAL_SYMBOL is not set
    CONFIG_USB_SERIAL_TI=m
    CONFIG_USB_SERIAL_CYBERJACK=m
    CONFIG_USB_SERIAL_XIRCOM=m
    CONFIG_USB_SERIAL_WWAN=m
    CONFIG_USB_SERIAL_OPTION=m
    CONFIG_USB_SERIAL_OMNINET=m
    CONFIG_USB_SERIAL_OPTICON=m
    # CONFIG_USB_SERIAL_VIVOPAY_SERIAL is not set
    # CONFIG_USB_SERIAL_ZIO is not set
    # CONFIG_USB_SERIAL_SSU100 is not set
    CONFIG_USB_SERIAL_DEBUG=m
    # USB Miscellaneous drivers
    CONFIG_USB_EMI62=m
    CONFIG_USB_EMI26=m
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_RIO500 is not set
    CONFIG_USB_LEGOTOWER=m
    CONFIG_USB_LCD=m
    CONFIG_USB_LED=m
    CONFIG_USB_CYPRESS_CY7C63=m
    CONFIG_USB_CYTHERM=m
    CONFIG_USB_IDMOUSE=m
    CONFIG_USB_FTDI_ELAN=m
    # CONFIG_USB_APPLEDISPLAY is not set
    CONFIG_USB_SISUSBVGA=m
    CONFIG_USB_SISUSBVGA_CON=y
    CONFIG_USB_LD=m
    CONFIG_USB_TRANCEVIBRATOR=m
    # CONFIG_USB_IOWARRIOR is not set
    CONFIG_USB_TEST=m
    # CONFIG_USB_ISIGHTFW is not set
    # CONFIG_USB_YUREX is not set
    CONFIG_USB_ATM=m
    CONFIG_USB_SPEEDTOUCH=m
    CONFIG_USB_CXACRU=m
    CONFIG_USB_UEAGLEATM=m
    CONFIG_USB_XUSBATM=m
    CONFIG_USB_GADGET=y
    # CONFIG_USB_GADGET_DEBUG is not set
    # CONFIG_USB_GADGET_DEBUG_FILES is not set
    CONFIG_USB_GADGET_DEBUG_FS=y
    CONFIG_USB_GADGET_VBUS_DRAW=480
    CONFIG_USB_GADGET_SELECTED=y
    # CONFIG_USB_GADGET_OMAP is not set
    # CONFIG_USB_GADGET_R8A66597 is not set
    # CONFIG_USB_GADGET_M66592 is not set
    # CONFIG_USB_GADGET_DUMMY_HCD is not set
    CONFIG_USB_GADGET_DUALSPEED=y
    # CONFIG_USB_ZERO is not set
    # CONFIG_USB_AUDIO is not set
    CONFIG_USB_ETH=y
    CONFIG_USB_ETH_RNDIS=y
    # CONFIG_USB_ETH_EEM is not set
    # CONFIG_USB_GADGETFS is not set
    # CONFIG_USB_FUNCTIONFS is not set
    # CONFIG_USB_FILE_STORAGE is not set
    # CONFIG_USB_MASS_STORAGE is not set
    # CONFIG_USB_G_SERIAL is not set
    # CONFIG_USB_MIDI_GADGET is not set
    # CONFIG_USB_G_PRINTER is not set
    # CONFIG_USB_CDC_COMPOSITE is not set
    # CONFIG_USB_G_MULTI is not set
    # CONFIG_USB_G_HID is not set
    # CONFIG_USB_G_DBGP is not set
    # CONFIG_USB_G_WEBCAM is not set
    # OTG and related infrastructure
    CONFIG_USB_OTG_UTILS=y
    CONFIG_USB_GPIO_VBUS=y
    # CONFIG_ISP1301_OMAP is not set
    # CONFIG_USB_ULPI is not set
    CONFIG_TWL4030_USB=y
    CONFIG_NOP_USB_XCEIV=y
    CONFIG_MMC=y
    # CONFIG_MMC_DEBUG is not set
    CONFIG_MMC_UNSAFE_RESUME=y
    # MMC/SD/SDIO Card Drivers
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_MINORS=8
    CONFIG_MMC_BLOCK_BOUNCE=y
    # CONFIG_SDIO_UART is not set
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_SDHCI is not set
    # CONFIG_MMC_OMAP is not set
    CONFIG_MMC_OMAP_HS=y
    CONFIG_MMC_SPI=m
    # CONFIG_MMC_USHC is not set
    # CONFIG_MEMSTICK is not set
    CONFIG_NEW_LEDS=y
    CONFIG_LEDS_CLASS=y
    # LED drivers
    # CONFIG_LEDS_PCA9532 is not set
    CONFIG_LEDS_GPIO=y
    CONFIG_LEDS_GPIO_PLATFORM=y
    # CONFIG_LEDS_LP3944 is not set
    # CONFIG_LEDS_LP5521 is not set
    # CONFIG_LEDS_LP5523 is not set
    # CONFIG_LEDS_PCA955X is not set
    # CONFIG_LEDS_DAC124S085 is not set
    # CONFIG_LEDS_REGULATOR is not set
    # CONFIG_LEDS_BD2802 is not set
    # CONFIG_LEDS_LT3593 is not set
    CONFIG_LEDS_TRIGGERS=y
    # LED Triggers
    CONFIG_LEDS_TRIGGER_TIMER=m
    CONFIG_LEDS_TRIGGER_HEARTBEAT=y
    CONFIG_LEDS_TRIGGER_BACKLIGHT=m
    # CONFIG_LEDS_TRIGGER_GPIO is not set
    CONFIG_LEDS_TRIGGER_DEFAULT_ON=m
    # iptables trigger is under Netfilter config (LED target)
    # CONFIG_ACCESSIBILITY is not set
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=m
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    CONFIG_RTC_DRV_DS1307=m
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    # CONFIG_RTC_DRV_DS3232 is not set
    # CONFIG_RTC_DRV_MAX6900 is not set
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_ISL12022 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    # CONFIG_RTC_DRV_PCF8563 is not set
    # CONFIG_RTC_DRV_PCF8583 is not set
    # CONFIG_RTC_DRV_M41T80 is not set
    # CONFIG_RTC_DRV_BQ32K is not set
    CONFIG_RTC_DRV_TWL4030=m
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8581 is not set
    # CONFIG_RTC_DRV_RX8025 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_DS3234 is not set
    # CONFIG_RTC_DRV_PCF2123 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_CMOS is not set
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_MSM6242 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_RP5C01 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # on-CPU RTC drivers
    # CONFIG_DMADEVICES is not set
    # CONFIG_AUXDISPLAY is not set
    CONFIG_UIO=m
    CONFIG_UIO_PDRV=m
    CONFIG_UIO_PDRV_GENIRQ=m
    # CONFIG_STAGING is not set
    # File systems
    CONFIG_EXT2_FS=y
    # CONFIG_EXT2_FS_XATTR is not set
    # CONFIG_EXT2_FS_XIP is not set
    CONFIG_EXT3_FS=y
    # CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set
    # CONFIG_EXT3_FS_XATTR is not set
    CONFIG_EXT4_FS=y
    CONFIG_EXT4_FS_XATTR=y
    # CONFIG_EXT4_FS_POSIX_ACL is not set
    # CONFIG_EXT4_FS_SECURITY is not set
    # CONFIG_EXT4_DEBUG is not set
    CONFIG_JBD=y
    # CONFIG_JBD_DEBUG is not set
    CONFIG_JBD2=y
    # CONFIG_JBD2_DEBUG is not set
    CONFIG_FS_MBCACHE=y
    CONFIG_REISERFS_FS=m
    # CONFIG_REISERFS_CHECK is not set
    CONFIG_REISERFS_PROC_INFO=y
    CONFIG_REISERFS_FS_XATTR=y
    # CONFIG_REISERFS_FS_POSIX_ACL is not set
    # CONFIG_REISERFS_FS_SECURITY is not set
    CONFIG_JFS_FS=m
    # CONFIG_JFS_POSIX_ACL is not set
    # CONFIG_JFS_SECURITY is not set
    # CONFIG_JFS_DEBUG is not set
    # CONFIG_JFS_STATISTICS is not set
    CONFIG_FS_POSIX_ACL=y
    CONFIG_XFS_FS=m
    # CONFIG_XFS_QUOTA is not set
    # CONFIG_XFS_POSIX_ACL is not set
    # CONFIG_XFS_RT is not set
    # CONFIG_XFS_DEBUG is not set
    CONFIG_GFS2_FS=m
    # CONFIG_GFS2_FS_LOCKING_DLM is not set
    CONFIG_OCFS2_FS=m
    CONFIG_OCFS2_FS_O2CB=m
    CONFIG_OCFS2_FS_USERSPACE_CLUSTER=m
    CONFIG_OCFS2_FS_STATS=y
    CONFIG_OCFS2_DEBUG_MASKLOG=y
    # CONFIG_OCFS2_DEBUG_FS is not set
    CONFIG_BTRFS_FS=m
    # CONFIG_BTRFS_FS_POSIX_ACL is not set
    # CONFIG_NILFS2_FS is not set
    CONFIG_EXPORTFS=m
    CONFIG_FILE_LOCKING=y
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY_USER=y
    # CONFIG_FANOTIFY is not set
    CONFIG_QUOTA=y
    # CONFIG_QUOTA_NETLINK_INTERFACE is not set
    CONFIG_PRINT_QUOTA_WARNING=y
    # CONFIG_QUOTA_DEBUG is not set
    CONFIG_QUOTA_TREE=y
    # CONFIG_QFMT_V1 is not set
    CONFIG_QFMT_V2=y
    CONFIG_QUOTACTL=y
    CONFIG_AUTOFS4_FS=m
    CONFIG_FUSE_FS=m
    # CONFIG_CUSE is not set
    CONFIG_GENERIC_ACL=y
    # Caches
    # CONFIG_FSCACHE is not set
    # CD-ROM/DVD Filesystems
    CONFIG_ISO9660_FS=m
    CONFIG_JOLIET=y
    CONFIG_ZISOFS=y
    CONFIG_UDF_FS=m
    CONFIG_UDF_NLS=y
    # DOS/FAT/NT Filesystems
    CONFIG_FAT_FS=y
    CONFIG_MSDOS_FS=y
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    CONFIG_NTFS_FS=m
    # CONFIG_NTFS_DEBUG is not set
    CONFIG_NTFS_RW=y
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    CONFIG_TMPFS_POSIX_ACL=y
    # CONFIG_HUGETLB_PAGE is not set
    CONFIG_CONFIGFS_FS=m
    CONFIG_MISC_FILESYSTEMS=y
    CONFIG_ADFS_FS=m
    # CONFIG_ADFS_FS_RW is not set
    CONFIG_AFFS_FS=m
    # CONFIG_ECRYPT_FS is not set
    CONFIG_HFS_FS=m
    CONFIG_HFSPLUS_FS=m
    CONFIG_BEFS_FS=m
    # CONFIG_BEFS_DEBUG is not set
    CONFIG_BFS_FS=m
    CONFIG_EFS_FS=m
    CONFIG_JFFS2_FS=y
    CONFIG_JFFS2_FS_DEBUG=0
    CONFIG_JFFS2_FS_WRITEBUFFER=y
    # CONFIG_JFFS2_FS_WBUF_VERIFY is not set
    CONFIG_JFFS2_SUMMARY=y
    CONFIG_JFFS2_FS_XATTR=y
    CONFIG_JFFS2_FS_POSIX_ACL=y
    CONFIG_JFFS2_FS_SECURITY=y
    CONFIG_JFFS2_COMPRESSION_OPTIONS=y
    CONFIG_JFFS2_ZLIB=y
    CONFIG_JFFS2_LZO=y
    CONFIG_JFFS2_RTIME=y
    CONFIG_JFFS2_RUBIN=y
    # CONFIG_JFFS2_CMODE_NONE is not set
    # CONFIG_JFFS2_CMODE_PRIORITY is not set
    # CONFIG_JFFS2_CMODE_SIZE is not set
    CONFIG_JFFS2_CMODE_FAVOURLZO=y
    CONFIG_UBIFS_FS=y
    CONFIG_UBIFS_FS_XATTR=y
    CONFIG_UBIFS_FS_ADVANCED_COMPR=y
    CONFIG_UBIFS_FS_LZO=y
    CONFIG_UBIFS_FS_ZLIB=y
    # CONFIG_UBIFS_FS_DEBUG is not set
    # CONFIG_LOGFS is not set
    CONFIG_CRAMFS=m
    CONFIG_SQUASHFS=y
    # CONFIG_SQUASHFS_XATTR is not set
    # CONFIG_SQUASHFS_LZO is not set
    # CONFIG_SQUASHFS_EMBEDDED is not set
    CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
    CONFIG_VXFS_FS=m
    CONFIG_MINIX_FS=m
    CONFIG_OMFS_FS=m
    CONFIG_HPFS_FS=m
    CONFIG_QNX4FS_FS=m
    CONFIG_ROMFS_FS=m
    CONFIG_ROMFS_BACKED_BY_BLOCK=y
    # CONFIG_ROMFS_BACKED_BY_MTD is not set
    # CONFIG_ROMFS_BACKED_BY_BOTH is not set
    CONFIG_ROMFS_ON_BLOCK=y
    CONFIG_SYSV_FS=m
    CONFIG_UFS_FS=m
    # CONFIG_UFS_FS_WRITE is not set
    # CONFIG_UFS_DEBUG is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V3=y
    # CONFIG_NFS_V3_ACL is not set
    CONFIG_NFS_V4=y
    # CONFIG_NFS_V4_1 is not set
    CONFIG_ROOT_NFS=y
    # CONFIG_NFS_USE_LEGACY_DNS is not set
    CONFIG_NFS_USE_KERNEL_DNS=y
    # CONFIG_NFS_USE_NEW_IDMAPPER is not set
    CONFIG_NFSD=m
    CONFIG_NFSD_DEPRECATED=y
    CONFIG_NFSD_V2_ACL=y
    CONFIG_NFSD_V3=y
    CONFIG_NFSD_V3_ACL=y
    CONFIG_NFSD_V4=y
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_ACL_SUPPORT=m
    CONFIG_NFS_COMMON=y
    CONFIG_SUNRPC=y
    CONFIG_SUNRPC_GSS=y
    CONFIG_RPCSEC_GSS_KRB5=y
    # CONFIG_CEPH_FS is not set
    CONFIG_CIFS=m
    CONFIG_CIFS_STATS=y
    CONFIG_CIFS_STATS2=y
    # CONFIG_CIFS_WEAK_PW_HASH is not set
    # CONFIG_CIFS_UPCALL is not set
    # CONFIG_CIFS_XATTR is not set
    # CONFIG_CIFS_DEBUG2 is not set
    # CONFIG_CIFS_DFS_UPCALL is not set
    CONFIG_CIFS_EXPERIMENTAL=y
    CONFIG_NCP_FS=m
    # CONFIG_NCPFS_PACKET_SIGNING is not set
    # CONFIG_NCPFS_IOCTL_LOCKING is not set
    # CONFIG_NCPFS_STRONG is not set
    # CONFIG_NCPFS_NFS_NS is not set
    # CONFIG_NCPFS_OS2_NS is not set
    # CONFIG_NCPFS_SMALLDOS is not set
    # CONFIG_NCPFS_NLS is not set
    # CONFIG_NCPFS_EXTRAS is not set
    CONFIG_CODA_FS=m
    CONFIG_AFS_FS=m
    # CONFIG_AFS_DEBUG is not set
    CONFIG_9P_FS=m
    # CONFIG_9P_FS_POSIX_ACL is not set
    # Partition Types
    CONFIG_PARTITION_ADVANCED=y
    # CONFIG_ACORN_PARTITION is not set
    # CONFIG_OSF_PARTITION is not set
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_ATARI_PARTITION is not set
    CONFIG_MAC_PARTITION=y
    CONFIG_MSDOS_PARTITION=y
    CONFIG_BSD_DISKLABEL=y
    CONFIG_MINIX_SUBPARTITION=y
    CONFIG_SOLARIS_X86_PARTITION=y
    # CONFIG_UNIXWARE_DISKLABEL is not set
    CONFIG_LDM_PARTITION=y
    CONFIG_LDM_DEBUG=y
    # CONFIG_SGI_PARTITION is not set
    # CONFIG_ULTRIX_PARTITION is not set
    # CONFIG_SUN_PARTITION is not set
    # CONFIG_KARMA_PARTITION is not set
    CONFIG_EFI_PARTITION=y
    # CONFIG_SYSV68_PARTITION is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    CONFIG_NLS_CODEPAGE_737=m
    CONFIG_NLS_CODEPAGE_775=m
    CONFIG_NLS_CODEPAGE_850=m
    CONFIG_NLS_CODEPAGE_852=m
    CONFIG_NLS_CODEPAGE_855=m
    CONFIG_NLS_CODEPAGE_857=m
    CONFIG_NLS_CODEPAGE_860=m
    CONFIG_NLS_CODEPAGE_861=m
    CONFIG_NLS_CODEPAGE_862=m
    CONFIG_NLS_CODEPAGE_863=m
    CONFIG_NLS_CODEPAGE_864=m
    CONFIG_NLS_CODEPAGE_865=m
    CONFIG_NLS_CODEPAGE_866=m
    CONFIG_NLS_CODEPAGE_869=m
    CONFIG_NLS_CODEPAGE_936=m
    CONFIG_NLS_CODEPAGE_950=m
    CONFIG_NLS_CODEPAGE_932=m
    CONFIG_NLS_CODEPAGE_949=m
    CONFIG_NLS_CODEPAGE_874=m
    CONFIG_NLS_ISO8859_8=m
    CONFIG_NLS_CODEPAGE_1250=m
    CONFIG_NLS_CODEPAGE_1251=m
    CONFIG_NLS_ASCII=m
    CONFIG_NLS_ISO8859_1=y
    CONFIG_NLS_ISO8859_2=m
    CONFIG_NLS_ISO8859_3=m
    CONFIG_NLS_ISO8859_4=m
    CONFIG_NLS_ISO8859_5=m
    CONFIG_NLS_ISO8859_6=m
    CONFIG_NLS_ISO8859_7=m
    CONFIG_NLS_ISO8859_9=m
    CONFIG_NLS_ISO8859_13=m
    CONFIG_NLS_ISO8859_14=m
    CONFIG_NLS_ISO8859_15=m
    CONFIG_NLS_KOI8_R=m
    CONFIG_NLS_KOI8_U=m
    CONFIG_NLS_UTF8=y
    CONFIG_DLM=m
    # CONFIG_DLM_DEBUG is not set
    # Kernel hacking
    CONFIG_PRINTK_TIME=y
    CONFIG_ENABLE_WARN_DEPRECATED=y
    CONFIG_ENABLE_MUST_CHECK=y
    CONFIG_FRAME_WARN=1024
    CONFIG_MAGIC_SYSRQ=y
    # CONFIG_STRIP_ASM_SYMS is not set
    # CONFIG_UNUSED_SYMBOLS is not set
    CONFIG_DEBUG_FS=y
    # CONFIG_HEADERS_CHECK is not set
    CONFIG_DEBUG_KERNEL=y
    # CONFIG_DEBUG_SHIRQ is not set
    # CONFIG_LOCKUP_DETECTOR is not set
    # CONFIG_HARDLOCKUP_DETECTOR is not set
    CONFIG_DETECT_HUNG_TASK=y
    # CONFIG_BOOTPARAM_HUNG_TASK_PANIC is not set
    CONFIG_BOOTPARAM_HUNG_TASK_PANIC_VALUE=0
    CONFIG_SCHED_DEBUG=y
    CONFIG_SCHEDSTATS=y
    CONFIG_TIMER_STATS=y
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_DEBUG_SLAB is not set
    # CONFIG_DEBUG_KMEMLEAK is not set
    CONFIG_DEBUG_PREEMPT=y
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_RT_MUTEX_TESTER is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    CONFIG_DEBUG_MUTEXES=y
    CONFIG_BKL=y
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_SPARSE_RCU_POINTER is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_SPINLOCK_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    # CONFIG_DEBUG_KOBJECT is not set
    # CONFIG_DEBUG_BUGVERBOSE is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_VM is not set
    # CONFIG_DEBUG_WRITECOUNT is not set
    # CONFIG_DEBUG_MEMORY_INIT is not set
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_TEST_LIST_SORT is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    # CONFIG_DEBUG_CREDENTIALS is not set
    # CONFIG_BOOT_PRINTK_DELAY is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    # CONFIG_RCU_CPU_STALL_DETECTOR is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
    # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
    # CONFIG_LKDTM is not set
    # CONFIG_FAULT_INJECTION is not set
    # CONFIG_LATENCYTOP is not set
    # CONFIG_SYSCTL_SYSCALL_CHECK is not set
    # CONFIG_PAGE_POISONING is not set
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_HAVE_DYNAMIC_FTRACE=y
    CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
    CONFIG_RING_BUFFER=y
    CONFIG_RING_BUFFER_ALLOW_SWAP=y
    CONFIG_TRACING_SUPPORT=y
    CONFIG_FTRACE=y
    # CONFIG_FUNCTION_TRACER is not set
    # CONFIG_IRQSOFF_TRACER is not set
    # CONFIG_PREEMPT_TRACER is not set
    # CONFIG_SCHED_TRACER is not set
    # CONFIG_ENABLE_DEFAULT_TRACERS is not set
    CONFIG_BRANCH_PROFILE_NONE=y
    # CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
    # CONFIG_PROFILE_ALL_BRANCHES is not set
    # CONFIG_STACK_TRACER is not set
    # CONFIG_BLK_DEV_IO_TRACE is not set
    # CONFIG_RING_BUFFER_BENCHMARK is not set
    # CONFIG_DYNAMIC_DEBUG is not set
    # CONFIG_ATOMIC64_SELFTEST is not set
    # CONFIG_ASYNC_RAID6_TEST is not set
    # CONFIG_SAMPLES is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    # CONFIG_STRICT_DEVMEM is not set
    CONFIG_ARM_UNWIND=y
    # CONFIG_DEBUG_USER is not set
    # CONFIG_DEBUG_ERRORS is not set
    # CONFIG_DEBUG_STACK_USAGE is not set
    # CONFIG_DEBUG_LL is not set
    # CONFIG_OC_ETM is not set
    # Security options
    CONFIG_KEYS=y
    # CONFIG_KEYS_DEBUG_PROC_KEYS is not set
    # CONFIG_SECURITY_DMESG_RESTRICT is not set
    # CONFIG_SECURITY is not set
    # CONFIG_SECURITYFS is not set
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_DEFAULT_SECURITY=""
    CONFIG_XOR_BLOCKS=m
    CONFIG_ASYNC_CORE=m
    CONFIG_ASYNC_MEMCPY=m
    CONFIG_ASYNC_XOR=m
    CONFIG_ASYNC_PQ=m
    CONFIG_ASYNC_RAID6_RECOV=m
    CONFIG_CRYPTO=y
    # Crypto core or helper
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    CONFIG_CRYPTO_AEAD=m
    CONFIG_CRYPTO_AEAD2=y
    CONFIG_CRYPTO_BLKCIPHER=y
    CONFIG_CRYPTO_BLKCIPHER2=y
    CONFIG_CRYPTO_HASH=y
    CONFIG_CRYPTO_HASH2=y
    CONFIG_CRYPTO_RNG=m
    CONFIG_CRYPTO_RNG2=y
    CONFIG_CRYPTO_PCOMP2=y
    CONFIG_CRYPTO_MANAGER=y
    CONFIG_CRYPTO_MANAGER2=y
    CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
    CONFIG_CRYPTO_GF128MUL=m
    CONFIG_CRYPTO_NULL=m
    CONFIG_CRYPTO_WORKQUEUE=y
    CONFIG_CRYPTO_CRYPTD=m
    CONFIG_CRYPTO_AUTHENC=m
    CONFIG_CRYPTO_TEST=m
    # Authenticated Encryption with Associated Data
    CONFIG_CRYPTO_CCM=m
    CONFIG_CRYPTO_GCM=m
    CONFIG_CRYPTO_SEQIV=m
    # Block modes
    CONFIG_CRYPTO_CBC=y
    CONFIG_CRYPTO_CTR=m
    CONFIG_CRYPTO_CTS=m
    CONFIG_CRYPTO_ECB=y
    CONFIG_CRYPTO_LRW=m
    CONFIG_CRYPTO_PCBC=m
    CONFIG_CRYPTO_XTS=m
    # Hash modes
    CONFIG_CRYPTO_HMAC=m
    CONFIG_CRYPTO_XCBC=m
    # CONFIG_CRYPTO_VMAC is not set
    # Digest
    CONFIG_CRYPTO_CRC32C=y
    CONFIG_CRYPTO_GHASH=m
    CONFIG_CRYPTO_MD4=m
    CONFIG_CRYPTO_MD5=y
    CONFIG_CRYPTO_MICHAEL_MIC=y
    CONFIG_CRYPTO_RMD128=m
    CONFIG_CRYPTO_RMD160=m
    CONFIG_CRYPTO_RMD256=m
    CONFIG_CRYPTO_RMD320=m
    CONFIG_CRYPTO_SHA1=m
    CONFIG_CRYPTO_SHA256=m
    CONFIG_CRYPTO_SHA512=m
    CONFIG_CRYPTO_TGR192=m
    CONFIG_CRYPTO_WP512=m
    # Ciphers
    CONFIG_CRYPTO_AES=y
    CONFIG_CRYPTO_ANUBIS=m
    CONFIG_CRYPTO_ARC4=y
    CONFIG_CRYPTO_BLOWFISH=m
    CONFIG_CRYPTO_CAMELLIA=m
    CONFIG_CRYPTO_CAST5=m
    CONFIG_CRYPTO_CAST6=m
    CONFIG_CRYPTO_DES=y
    CONFIG_CRYPTO_FCRYPT=m
    CONFIG_CRYPTO_KHAZAD=m
    CONFIG_CRYPTO_SALSA20=m
    CONFIG_CRYPTO_SEED=m
    CONFIG_CRYPTO_SERPENT=m
    CONFIG_CRYPTO_TEA=m
    CONFIG_CRYPTO_TWOFISH=m
    CONFIG_CRYPTO_TWOFISH_COMMON=m
    # Compression
    CONFIG_CRYPTO_DEFLATE=y
    # CONFIG_CRYPTO_ZLIB is not set
    CONFIG_CRYPTO_LZO=y
    # Random Number Generation
    CONFIG_CRYPTO_ANSI_CPRNG=m
    CONFIG_CRYPTO_HW=y
    # CONFIG_CRYPTO_DEV_OMAP_SHAM is not set
    # CONFIG_CRYPTO_DEV_OMAP_AES is not set
    # CONFIG_BINARY_PRINTF is not set
    # Library routines
    CONFIG_RAID6_PQ=m
    CONFIG_BITREVERSE=y
    CONFIG_GENERIC_FIND_LAST_BIT=y
    CONFIG_CRC_CCITT=y
    CONFIG_CRC16=y
    CONFIG_CRC_T10DIF=y
    CONFIG_CRC_ITU_T=y
    CONFIG_CRC32=y
    CONFIG_CRC7=y
    CONFIG_LIBCRC32C=y
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_LZO_COMPRESS=y
    CONFIG_LZO_DECOMPRESS=y
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_TEXTSEARCH=y
    CONFIG_TEXTSEARCH_KMP=m
    CONFIG_TEXTSEARCH_BM=m
    CONFIG_TEXTSEARCH_FSM=m
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_IOPORT=y
    CONFIG_HAS_DMA=y
    CONFIG_NLATTR=y
    Texas Instruments X-Loader 1.5.0 (Jun 14 2011 - 22:04:07)
    Beagle Rev C5
    Reading boot sector
    Loading u-boot.bin from mmc
    U-Boot 2009.06-rc2 (Jan 15 2015 - 11:12:37)
    , CPU-OPP2 L3-165MHz
    OMAP3 Beagle board + LPDDR/NAND
    DRAM: 256 MB
    NAND: 512 MiB
    In: serial
    Out: serial
    Err: serial
    Board revision Ax/Bx
    Die ID #74aa000700000000015a676401014023
    Hit any key to stop autoboot: 0
    mmc1 is available
    reading uImage
    3132636 bytes read
    ## Booting kernel from Legacy Image at 80300000 ...
    Image Name: Linux-2.6.37
    Image Type: ARM Linux Kernel Image (uncompressed)
    Data Size: 3132572 Bytes = 3 MB
    Load Address: 80008000
    Entry Point: 80008000
    Verifying Checksum ... OK
    Loading Kernel Image ... OK
    OK
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    [ 0.000000] Linux version 2.6.37 (ubuntu@ubuntu-laptop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #12 PREEMPT Thu Jan 15 23:34:52 IST 2015
    [ 0.000000] CPU: ARMv7 Processor [411fc087] revision 7 (ARMv7), cr=10c53c7f
    [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
    [ 0.000000] Machine: OMAP3 Beagle Board
    [ 0.000000] Reserving 14680064 bytes SDRAM for VRAM
    [ 0.000000] Memory policy: ECC disabled, Data cache writeback
    [ 0.000000] OMAP3430/3530 ES3.1.2 (l2cache iva sgx neon isp 720mhz )
    [ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 61440
    [ 0.000000] Kernel command line: console=ttyO2,115200n8 root=/dev/mmcblk0p2 rw rootwait
    [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
    [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
    [ 0.000000] Memory: 242MB = 242MB total
    [ 0.000000] Memory: 239052k/239052k available, 23092k reserved, 0K highmem
    [ 0.000000] Virtual kernel memory layout:
    [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
    [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
    [ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
    [ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
    [ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
    [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
    [ 0.000000] .init : 0xc0008000 - 0xc0035000 ( 180 kB)
    [ 0.000000] .text : 0xc0035000 - 0xc05d1188 (5745 kB)
    [ 0.000000] .data : 0xc05d2000 - 0xc06180e0 ( 281 kB)
    [ 0.000000] Preemptable hierarchical RCU implementation.
    [ 0.000000] RCU-based detection of stalled CPUs is disabled.
    [ 0.000000] Verbose stalled-CPUs detection is disabled.
    [ 0.000000] NR_IRQS:409
    [ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
    [ 0.000000] omap_hwmod: i2c1: softreset failed (waited 10000 usec)
    [ 0.000000] omap_hwmod: i2c2: softreset failed (waited 10000 usec)
    [ 0.000000] omap_hwmod: i2c3: softreset failed (waited 10000 usec)
    [ 0.000000] Reprogramming SDRC clock to 332000000 Hz
    [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
    [ 0.000000] Total of 96 interrupts on 1 active controller
    [ 0.000000] GPMC revision 5.0
    [ 0.000000] Trying to install interrupt handler for IRQ402
    [ 0.000000] Trying to install interrupt handler for IRQ403
    [ 0.000000] Trying to install interrupt handler for IRQ404
    [ 0.000000] Trying to install interrupt handler for IRQ405
    [ 0.000000] Trying to install interrupt handler for IRQ406
    [ 0.000000] Trying to install interrupt handler for IRQ407
    [ 0.000000] Trying to install interrupt handler for IRQ408
    [ 0.000000] Trying to install type control for IRQ409
    [ 0.000000] Trying to set irq flags for IRQ409
    [ 0.000000] OMAP clockevent source: GPTIMER1 at 13000000 Hz
    [ 0.000000] Console: colour dummy device 80x30
    [ 0.000000] Calibrating delay loop... 498.07 BogoMIPS (lpj=2490368)
    [ 0.000000] pid_max: default: 32768 minimum: 301
    [ 0.000000] Mount-cache hash table entries: 512
    [ 0.000000] CPU: Testing write buffer coherency: ok
    [ 0.000000] devtmpfs: initialized
    [ 0.000000] regulator: core version 0.5
    [ 0.000000] regulator: dummy:
    [ 0.000000] NET: Registered protocol family 16
    [ 0.000000] OMAP GPIO hardware version 2.5
    [ 0.000000] omap_mux_init: Add partition: #1: core, flags: 0
    [ 0.000000] OMAP3 Beagle Rev: unknown 1
    [ 0.000000] Found NAND on CS0
    [ 0.000000] Registering NAND on CS0
    [ 0.000000] Unable to get DVI reset GPIO
    [ 0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
    [ 0.000000] OMAP DMA hardware revision 4.0
    [ 0.011291] bio: create slab <bio-0> at 0
    [ 0.012969] SCSI subsystem initialized
    [ 0.014984] usbcore: registered new interface driver usbfs
    [ 0.015228] usbcore: registered new interface driver hub
    [ 0.015502] usbcore: registered new device driver usb
    [ 0.015930] omap_device: omap_i2c.1: new worst case activate latency 0: 30517
    [ 0.034729] omap_i2c omap_i2c.1: bus 1 rev3.12 at 2600 kHz
    [ 0.047454] twl4030: PIH (irq 7) chaining IRQs 368..375
    [ 0.047485] twl4030: power (irq 373) chaining IRQs 376..383
    [ 0.048126] twl4030: gpio (irq 368) chaining IRQs 384..401
    [ 0.065368] regulator: VUSB1V5: 1500 mV normal standby
    [ 0.065979] regulator: VUSB1V8: 1800 mV normal standby
    [ 0.066558] regulator: VUSB3V1: 3100 mV normal standby
    [ 0.086791] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
    [ 0.105682] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
    [ 0.106231] regulator: VDAC: 1800 mV normal standby
    [ 0.106781] regulator: VDVI: 1800 mV normal standby
    [ 0.107421] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
    [ 0.108093] regulator: VAUX3: 1800 mV normal standby
    [ 0.108734] regulator: VAUX4: 1800 mV normal standby
    [ 0.108917] omap_device: omap_i2c.1: new worst case deactivate latency 0: 30517
    [ 0.109069] omap_i2c omap_i2c.2: bus 2 rev3.12 at 400 kHz
    [ 0.124725] omap_i2c omap_i2c.3: bus 3 rev3.12 at 100 kHz
    [ 0.125976] Advanced Linux Sound Architecture Driver Version 1.0.23.
    [ 0.126770] Switching to clocksource gp timer
    [ 0.146087] musb-hdrc: version 6.0, otg (peripheral+host), debug=0
    [ 0.146697] NET: Registered protocol family 2
    [ 0.147094] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.147766] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [ 0.148071] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.148254] TCP: Hash tables configured (established 8192 bind 8192)
    [ 0.148254] TCP reno registered
    [ 0.148284] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [ 0.148315] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [ 0.148651] NET: Registered protocol family 1
    [ 0.149353] RPC: Registered udp transport module.
    [ 0.149353] RPC: Registered tcp transport module.
    [ 0.149383] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.246856] platform iva.0: Enabled OPP corresponding to 720MHz
    [ 0.247558] omap-iommu omap-iommu.0: isp registered
    [ 0.247741] OMAP35x Linux PSP version 04.02.00.07 (OMAP3BEAGLE)
    [ 0.249816] VFS: Disk quotas dquot_6.5.2
    [ 0.249938] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [ 0.251464] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.252288] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
    [ 0.253295] msgmni has been set to 466
    [ 0.255615] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
    [ 0.255615] io scheduler noop registered
    [ 0.255645] io scheduler deadline registered
    [ 0.255828] io scheduler cfq registered (default)
    [ 0.306945] OMAP DSS rev 2.0
    [ 0.307067] OMAP DISPC rev 3.0
    [ 0.307098] OMAP VENC rev 2
    [ 0.307373] OMAP DSI rev 1.0
    [ 0.457763] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [ 0.607147] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
    [ 0.646911] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
    [ 0.686920] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
    [ 1.396850] console [ttyO2] enabled
    [ 1.438171] brd: module loaded
    [ 1.447143] loop: module loaded
    [ 1.452484] omap2-nand driver initializing
    [ 1.457183] ONFI flash detected
    [ 1.460754] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron )
    [ 1.468200] cmdlinepart partition parsing not available
    [ 1.473693] Creating 5 MTD partitions on "omap2-nand.0":
    [ 1.479339] 0x000000000000-0x000000080000 : "X-Loader"
    [ 1.486755] 0x000000080000-0x000000260000 : "U-Boot"
    [ 1.494598] 0x000000260000-0x000000280000 : "U-Boot Env"
    [ 1.501983] 0x000000280000-0x000000680000 : "Kernel"
    [ 1.510650] 0x000000680000-0x000020000000 : "File System"
    [ 1.731842] usbcore: registered new interface driver catc
    [ 1.737609] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
    [ 1.743896] usbcore: registered new interface driver kaweth
    [ 1.749816] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
    [ 1.757781] usbcore: registered new interface driver pegasus
    [ 1.763702] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
    [ 1.771026] usbcore: registered new interface driver rtl8150
    [ 1.777099] usbcore: registered new interface driver asix
    [ 1.782867] usbcore: registered new interface driver cdc_ether
    [ 1.789093] usbcore: registered new interface driver dm9601
    [ 1.795043] usbcore: registered new interface driver smsc95xx
    [ 1.801208] usbcore: registered new interface driver gl620a
    [ 1.807189] usbcore: registered new interface driver net1080
    [ 1.813201] usbcore: registered new interface driver plusb
    [ 1.819091] usbcore: registered new interface driver rndis_host
    [ 1.825378] usbcore: registered new interface driver cdc_subset
    [ 1.831726] usbcore: registered new interface driver zaurus
    [ 1.837707] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
    [ 1.846069] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 3.866760] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
    [ 3.873199] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
    [ 3.886962] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
    [ 3.906829] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
    [ 3.912963] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [ 3.920135] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 3.927734] usb usb1: Product: OMAP-EHCI Host Controller
    [ 3.933288] usb usb1: Manufacturer: Linux 2.6.37 ehci_hcd
    [ 3.938964] usb usb1: SerialNumber: ehci-omap.0
    [ 3.944671] hub 1-0:1.0: USB hub found
    [ 3.948699] hub 1-0:1.0: 3 ports detected
    [ 3.976898] Initializing USB Mass Storage driver...
    [ 3.982208] usbcore: registered new interface driver usb-storage
    [ 3.988525] USB Mass Storage support registered.
    [ 3.994018] mice: PS/2 mouse device common for all mice
    [ 4.000213] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [ 4.028411] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
    [ 4.040344] i2c /dev entries driver
    [ 4.045196] lirc_dev: IR Remote Control driver registered, major 251
    [ 4.052154] IR NEC protocol handler initialized
    [ 4.056945] IR RC5(x) protocol handler initialized
    [ 4.061981] IR RC6 protocol handler initialized
    [ 4.066711] IR JVC protocol handler initialized
    [ 4.071502] IR Sony protocol handler initialized
    [ 4.076324] IR RC5 (streamzap) protocol handler initialized
    [ 4.082183] IR LIRC bridge handler initialized
    [ 4.086883] Linux video capture interface: v2.00
    [ 4.091796] vpfe_init
    [ 4.095062] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
    [ 4.101837] cpuidle: using governor ladder
    [ 4.106109] cpuidle: using governor menu
    [ 4.117462] usbcore: registered new interface driver usbhid
    [ 4.123291] usbhid: USB HID core driver
    [ 4.128082] usbcore: registered new interface driver snd-usb-audio
    [ 4.135345] OMAP3 Beagle/Devkit8000 SoC init
    [ 4.224517] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
    [ 4.235595] ALSA device list:
    [ 4.239044] #0: omap3beagle
    [ 4.242126] oprofile: hardware counters not available
    [ 4.247467] oprofile: using timer interrupt.
    [ 4.252227] TCP cubic registered
    [ 4.255615] NET: Registered protocol family 17
    [ 4.260437] NET: Registered protocol family 15
    [ 4.265197] lib80211: common routines for IEEE802.11 drivers
    [ 4.272247] Registering the dns_resolver key type
    [ 4.279327] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
    [ 4.287597] ThumbEE CPU extension supported.
    [ 4.297241] Power Management for TI OMAP3.
    [ 4.302520] sr_init: No PMIC hook to init smartreflex
    [ 4.308105] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
    [ 4.316467] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
    [ 4.332611] clock: disabling unused clocks to save power
    [ 4.339691] platform l3_main.0: omap_voltage_scale: Already at the requestedrate 166000000
    [ 4.348449] platform iva.0: omap_voltage_scale: Already at the requestedrate 430000000
    [ 4.356811] platform mpu.0: omap_voltage_scale: Already at the requestedrate 600000000
    [ 4.365142] platform l3_main.0: omap_voltage_scale: Already at the requestedrate 166000000
    [ 4.374908] registered taskstats version 1
    [ 4.380767] omapfb omapfb: no driver for display
    [ 4.385681] omapfb omapfb: failed to setup omapfb
    [ 4.391265] regulator_init_complete: incomplete constraints, leaving VAUX3 on
    [ 4.399200] regulator_init_complete: incomplete constraints, leaving VDVI on
    [ 4.406799] regulator_init_complete: incomplete constraints, leaving VDAC on
    [ 4.414306] mmc0: new high speed SDHC card at address aaaa
    [ 4.420593] omap_vout omap_vout: probed for an unknown device
    [ 4.427246] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
    [ 4.436065] mmcblk0: p1 p2
    [ 4.444213] EXT3-fs: barriers not enabled
    [ 4.507019] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
    [ 4.516815] kjournald starting. Commit interval 5 seconds
    [ 4.523834] EXT3-fs (mmcblk0p2): using internal journal
    [ 4.529357] EXT3-fs (mmcblk0p2): recovery complete
    [ 4.536529] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
    [ 4.544036] VFS: Mounted root (ext3 filesystem) on device 179:2.
    [ 4.552795] devtmpfs: mounted
    [ 4.555969] Freeing init memory: 180K
    [ 4.787963] <27>systemd[1]: Failed to mount /sys/fs/cgroup: No such file or directory
    [ 4.796478] <27>systemd[1]: Failed to mount /sys/fs/cgroup/systemd: No such file or directory
    [ 4.814514] <27>systemd[1]: Failed to enumerate cgroup controllers: No such file or directory
    [ 4.823638] <30>systemd[1]: systemd 37 running in system mode. (+PAM +LIBWRAP -AUDIT -SELINUX +SYSVINIT -LIBCRYPTSETUP; angstrom)
    Welcome to The ֵngstrצm Distribution!
    [ 4.901885] <28>systemd[1]: /sbin/modprobe failed with error code 1.
    [ 4.911651] <30>systemd[1]: Set hostname to <beagleboard>.
    [ 4.926696] <28>systemd[1]: CONFIG_CGROUPS was not set when your kernel was compiled. Systems without control groups are not supported. We will now sleep for 10s, and then continue boot-up. Expect breakage and please do not file bugs. Instead fix your kernel and enable CONFIG_CGROUPS.
    [ 14.969299] <28>systemd[1]: No control group support available, not creating root group.
    [ 15.212493] <27>systemd[1]: Failed to open /dev/autofs: No such file or directory
    [ 15.220550] <27>systemd[1]: Failed to initialize automounter: No such file or directory
    [ 15.229095] <29>systemd[1]: Unit proc-sys-fs-binfmt_misc.automount entered failed state.
    Starting Runtime Directory...
    Starting Remount API VFS...
    Starting Lock Directory...
    Starting Media Directory...
    Started Apply Kernel Variables [ OK ]
    Started Huge Pages File System [ OK ]
    Started POSIX Message Queue File System [ OK ]
    Starting File System Check on Root Device...
    Started Load Kernel Modules [ OK ]
    [ 15.423828] <30>systemd-fsck[63]: Root directory is writable, skipping check.
    Started Configuration File System [ OK ]
    Started FUSE Control File System [ OK ]
    Started Set Up Additional Binary Formats [ OK ]
    Starting Debug File System...
    Started Security File System [ OK ]
    Starting Syslog Kernel Log Buffer Bridge...
    Started Syslog Kernel Log Buffer Bridge [ OK ]
    Starting udev Coldplug all Devices...
    Starting udev Kernel Device Manager...
    Started Runtime Directory [ OK ]
    Started Remount API VFS [ OK ]
    Started Lock Directory [ 15.672882] <30>udevd[67]: starting version 175
    [ OK ]
    Started udev Kernel Device Manager [ OK ]
    Started Media Directory [ OK ]
    Started File System Check on Root Device [ OK ]
    Started Debug File System [ OK ]
    Starting Remount Root FS...
    Starting STDOUT Syslog Bridge...
    Started STDOUT Syslog Bridge [ OK ]
    Started Remount Root FS [ OK ]
    Started Opkg first boot configure [ OK ]
    Starting /tmp...
    Started Machine ID first boot configure [ OK ]
    Started /tmp [ OK ]
    Starting Load Random Seed...
    Starting Recreate Volatile Files and Directories...
    Started Load Random Seed [ OK ]
    Started Recreate Volatile Files and Directories [ OK ]
    Starting Console System Startup Logging...
    Starting xinetd.service...
    Starting Angstrom LED config...
    Started Angstrom LED config [ OK ]
    Starting Timestamping service...
    Started Timestamping service [ OK ]
    Starting Network Manager...
    Started SSH Key Generation [ OK ]
    Starting System Logging Service...
    Starting Permit User Sessions...
    Starting Login Service...
    Starting Avahi mDNS/DNS-SD Stack...
    Starting Periodic Command Scheduler...
    Started Periodic Command Scheduler [ OK ]
    Starting D-Bus System Message Bus...
    Starting Disk Manager...
    Started udev Coldplug all Devices [ OK ]
    Started Console System Startup Logging [ OK ]
    [ 16.900695] <29>systemd[1]: rsyslog.service: control process exited, code=exited status=1
    Failed to start System Logging Service [ 17.076263] <29> [FAILED]
    See 'systemctl status rsyslog.service' for details.
    <30>systemctl[71]: Failed to get D-Bus connection: No connection to service manager.systemd[1]: Unit rsyslog.service entered failed state.
    Started Permit User Sessions [ OK ][ 17.224517]
    [ 17.226257] <75>
    Starting Serial Getty on ttyO2.../usr/sbin/crond[136]: (CRON) INFO (Syslog will be used instead of sendmail.): No such file or directory
    Started Serial Getty on ttyO2 [ OK ]
    [ 17.456878] <30>led-config[104]: Configuring leds:
    [ 17.547515] <27>Failed to start Login Service [FAILED]
    See 'systemctl status systemd-logind.service' for details.
    systemd-logind[131]: Failed to open /sys/class/tty/tty0/active: No such file or directoryStarting internet superserver: xinetd
    [ 17.714843] <27>systemd-logind[131]: Failed to fully start up daemon: No such file or directory
    [ 17.846923] <29>systemd[1]: systemd-logind.service: main process exited, code=exited, status=1Started D-Bus System Message Bus [ OK ]
    [ 18.028320] <29>systemd[1]: Unit systemd-logind.service entered failed state.
    [ 18.035858] <30>avahi-daemon[133]: Found user 'avahi' (UID 998) and group 'avahi' (GID 996).
    [ 18.225524] <30>avahi-daemon[133]: Successfully dropped root privileges.
    [ 18.692718] <30>
    avahi-daemon[133]: avahi-daemon 0.6.30 starting up.
    [ 18.852844] <30>led-config[104]: beagleboard::usr0: heartbeat
    [ 18.933868] <30>udisks-daemon.---O---.
    | | .-. o o
    | | | __ | ---'| '--.| .-'| | |
    The Angstrom Distribu[143]: tion beagleboard ttyO2
    Angstrom v2012.01-core - Kernel 2.6.37
    beagleboard login: (process:143): GLib-WARNING **: goption.c:2168: ignoring no-arg, optional-arg or filename flags (16) on option of type 1
    [ 19.248596] <26>xinetd[259]: 259 {init_services} no services. Exiting...
    [ 19.255676] <30>load-timestamp.sh[107]: Update systemtime from /etc/timestamp
    [ 19.372497] <30>led-config[104]: beagleboard::usr1: mmc0
    [ 19.466918] <30>NetworkManager[113]: NetworkManager[113]: <info> NetworkManager (version 0.9.2.0) is starting...Started xinetd.service [ OK ]
    Started Avahi mDNS/DNS-SD Stack [ OK ]
    Started Disk Manager [ OK ]
    [ 19.578643] <14>NetworkManager[113]: <info> NetworkManager (version 0.9.2.0) is starting...Starting Getty on tty1...
    Started Getty on tty1 [ OK ]
    [ 19.662536] <30>NetworkManager[113]: NetworkManager[113]: <info> Read config file (null)
    [ 19.740356] <14>NetworkManager[113]: <info> Read config file (null)
    [ 19.790466] <30>Starting Gnome Display Manager...
    Started Gnome Display Manager [oad-timestamp.sh2m OK ]
    [107]: Thu Jan 12 12:19:00 UTC 2012
    [ 19.854614] <30>udisks-daemon[143]: (udisks-daemon:143): udisks-daemon-DEBUG: Starting daemon version 1.0.4
    [ 19.885681] <30>avahi-daemon[133]: Successfully called chroot().
    [ 19.904937] <30>avahi-daemon[133]: Successfully dropped remaining capabilities.
    [ 19.920257] <30>avahi-daemon[133]: Loading service file /services/sftp-ssh.service.
    [ 19.961700] <30>avahi-daemon[133]: Loading service file /services/ssh.service.
    [ 19.984619] <30>avahi-daemon[133]: Loading service file /services/udisks.service.
    [ 20.022766] <30>avahi-daemon[133]: Network interface enumeration completed.Started D-Bus System Message Bus [ OK ]
    [ 20.080688] <30>avahi-daemon[133]: Registering HINFO record with values 'ARMV7L'/'LINUX'.
    [ 20.115814] <30>avahi-daemon[133]: Server startup complete. Host name is beagleboard.local. Local service cookie is 1373429146.
    [ 20.183471] <30>avahi-daemon[133]: Service "beagleboard" (/services/udisks.service) successfully established.
    [ 20.208404] <30>dbus-daemon[212]: dbus[212]: [system] Activating service name='org.freedesktop.PolicyKit1' (using servicehelper)
    [ 20.240814] <29>dbus[212]: [system] Activating service name='org.freedesktop.PolicyKit1' (using servicehelper)
    [ 20.258636] <30>avahi-daemon[133]: Service "beagleboard" (/services/ssh.service) successfully established.
    [ 20.279357] <30>avahi-daemon[133]: Service "beagleboard" (/services/sftp-ssh.service) successfully established.
    [ 20.381408] <30>polkitd[297]: started daemon version 0.103 using authority implementation `local' version `0.103'
    [ 20.445220] <30>dbus-daemon[212]: dbus[212]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
    [ 20.517059] <29>dbus[212]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
    [ 20.535949] <30>udisks-daemon[143]: (udisks-daemon:143): udisks-daemon-WARNING **: No /proc/mdstat file: No such file or directory
    [ 20.597442] <30>NetworkManager[113]: NetworkManager[113]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
    [ 20.637695] <12>NetworkManager[113]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
    [ 20.674224] <30>NetworkManager[113]: NetworkManager[113]: <info> Loaded plugin keyfile: (c) 2007 - 2010 Red Hat, Inc. To report bugs please use the NetworkManager mailing list.
    [ 20.716796] <14>NetworkManager[113]: <info> Loaded plugin keyfile: (c) 2007 - 2010 Red Hat, Inc. To report bugs please use the NetworkManager mailing list.
    [ 20.760131] <30>NetworkManager[113]: NetworkManager[113]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
    [ 20.809143] <12>NetworkManager[113]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
    [ 20.843475] <30>NetworkManager[113]: NetworkManager[113]: keyfile: parsing Dominion ...
    [ 20.854888] <13>NetworkManager[113]: keyfile: parsing Dominion ...
    [ 20.874084] <30>udisks-daemon[143]: **** ADDING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
    [ 20.913177] <30>udisks-daemon[143]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
    [ 20.929840] <30>NetworkManager[113]: NetworkManager[113]: keyfile: read connection 'Dominion'
    [ 20.930816] <13>NetworkManager[113]: keyfile: read connection 'Dominion'
    [ 20.932067] <30>udisks-daemon[143]: **** ADDED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
    [ 20.932342] <30>udisks-daemon[143]: **** ADDING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
    [ 20.932495] <30>udisks-daemon[143]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
    [ 20.932647] <12>NetworkManager[113]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
    [ 20.932800] <30>udisks-daemon[143]: **** ADDED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
    [ 20.933166] <14>NetworkManager[113]: <info> trying to start the modem manager...
    [ 20.937072] <30>udisks-daemon[143]: **** ADDING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
    [ 20.937316] <14>NetworkManager[113]: <info> monitoring kernel firmware directory '/lib/firmware'.
    [ 20.937896] <30>udisks-daemon[143]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
    [ 20.938079] <30>udisks-daemon[143]: **** ADDED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
    [ 20.938140] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/loop0
    [ 21.088714] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/block/loop0
    [ 21.088928] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/loop0
    [ 21.089080] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/loop1
    [ 21.089141] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/block/loop1
    [ 21.089324] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/loop1
    [ 21.089477] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/loop2
    [ 21.089538] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/block/loop2
    [ 21.089752] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/loop2
    [ 21.089874] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/loop3
    [ 21.089935] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/block/loop3
    [ 21.090148] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/loop3
    [ 21.090301] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/loop4
    [ 21.090332] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/block/loop4
    [ 21.090545] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/loop4
    [ 21.090698] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/loop5
    [ 21.090728] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/block/loop5
    [ 21.090942] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/loop5
    [ 21.091094] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/loop6
    [ 21.091552] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/block/loop6
    [ 21.091735] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/loop6
    [ 21.091796] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/loop7
    [ 21.092010] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/block/loop7
    [ 21.092163] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/loop7
    [ 21.092498] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram0
    [ 21.092651] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram0
    [ 21.092926] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram1
    [ 21.093109] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram1
    [ 21.095642] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram10
    [ 21.095886] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram10
    [ 21.096069] <14>NetworkManager[113]: <info> WiFi enabled by radio killswitch; enabled by state file
    [ 21.096221] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram11
    [ 21.096466] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram11
    [ 21.096862] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram12
    [ 21.097045] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram12
    [ 21.097198] <14>NetworkManager[113]: <info> WWAN enabled by radio killswitch; enabled by state file
    [ 21.097320] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram13
    [ 21.097473] <14>NetworkManager[113]: <info> WiMAX enabled by radio killswitch; enabled by state file
    [ 21.097625] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram13
    [ 21.097778] <14>NetworkManager[113]: <info> Networking is enabled by state file
    [ 21.099456] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram14
    [ 21.099731] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram14
    [ 21.099884] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram15
    [ 21.100128] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram15
    [ 21.100280] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram2
    [ 21.100433] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram2
    [ 21.100555] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram3
    [ 21.100708] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram3
    [ 21.100860] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram4
    [ 21.101013] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram4
    [ 21.101318] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram5
    [ 21.101470] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram5
    [ 21.101623] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram6
    [ 21.101776] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram6
    [ 21.101898] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram7
    [ 21.102050] <30>NetworkManager[113]: NetworkManager[113]: Error parsing file '/etc/NetworkManager/nm-system-settings.conf': No such file or directory
    [ 21.102203] <30>NetworkManager[113]: NetworkManager[113]: <info> trying to start the modem manager...
    [ 21.102355] <30>NetworkManager[113]: NetworkManager[113]: <info> monitoring kernel firmware directory '/lib/firmware'.
    [ 21.102478] <30>NetworkManager[113]: NetworkManager[113]: <info> WiFi enabled by radio killswitch; enabled by state file
    [ 21.106048] <30>NetworkManager[113]: NetworkManager[113]: <info> WWAN enabled by radio killswitch; enabled by state file
    [ 21.106292] <30>NetworkManager[113]: NetworkManager[113]: <info> WiMAX enabled by radio killswitch; enabled by state file
    [ 21.106628] <30>NetworkManager[113]: NetworkManager[113]: <info> Networking is enabled by state file
    [ 21.106781] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram7
    [ 21.106933] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram8
    [ 21.107086] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram8
    [ 21.107238] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/block/ram9
    [ 21.107360] <30>udisks-daemon[143]: **** IGNORING ADD /sys/devices/virtual/block/ram9
    [ 21.107513] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/mtd/mtd0/mtdblock0
    [ 21.107666] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/mtd/mtd0/mtdblock0
    [ 21.107788] <30>udisks-daemon[143]: **** ADDED /sys/devices/virtual/mtd/mtd0/mtdblock0
    [ 21.107940] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/mtd/mtd1/mtdblock1
    [ 21.108093] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/mtd/mtd1/mtdblock1
    [ 21.108215] <30>udisks-daemon[143]: **** ADDED /sys/devices/virtual/mtd/mtd1/mtdblock1
    [ 21.108367] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/mtd/mtd2/mtdblock2
    [ 21.108520] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/mtd/mtd2/mtdblock2
    [ 21.108642] <30>udisks-daemon[143]: **** ADDED /sys/devices/virtual/mtd/mtd2/mtdblock2
    [ 21.108795] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/mtd/mtd3/mtdblock3
    [ 21.108947] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/mtd/mtd3/mtdblock3
    [ 21.109069] <30>udisks-daemon[143]: **** ADDED /sys/devices/virtual/mtd/mtd3/mtdblock3
    [ 21.109222] <30>udisks-daemon[143]: **** ADDING /sys/devices/virtual/mtd/mtd4/mtdblock4
    [ 21.109375] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/mtd/mtd4/mtdblock4
    [ 21.109497] <30>udisks-daemon[143]: **** ADDED /sys/devices/virtual/mtd/mtd4/mtdblock4
    [ 21.109649] <30>udisks-daemon[143]: **** CHANGING /sys/devices/virtual/mtd/mtd0/mtdblock0
    [ 21.109802] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/mtd/mtd0/mtdblock0
    [ 21.109924] <30>udisks-daemon[143]: **** CHANGED /sys/devices/virtual/mtd/mtd0/mtdblock0
    [ 21.110076] <30>udisks-daemon[143]: **** CHANGING /sys/devices/virtual/mtd/mtd1/mtdblock1
    [ 21.110229] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/mtd/mtd1/mtdblock1
    [ 21.110443] <30>udisks-daemon[143]: **** CHANGED /sys/devices/virtual/mtd/mtd1/mtdblock1
    [ 21.110595] <30>udisks-daemon[143]: **** CHANGING /sys/devices/virtual/mtd/mtd2/mtdblock2
    [ 21.110748] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/mtd/mtd2/mtdblock2
    [ 21.110900] <30>udisks-daemon[143]: **** CHANGED /sys/devices/virtual/mtd/mtd2/mtdblock2
    [ 21.111022] <30>udisks-daemon[143]: **** CHANGING /sys/devices/virtual/mtd/mtd3/mtdblock3
    [ 21.111175] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/mtd/mtd3/mtdblock3
    [ 21.111328] <30>udisks-daemon[143]: **** CHANGED /sys/devices/virtual/mtd/mtd3/mtdblock3
    [ 21.111419] <30>udisks-daemon[143]: **** CHANGING /sys/devices/virtual/mtd/mtd4/mtdblock4
    [ 21.111480] <30>udisks-daemon[143]: **** UPDATING /sys/devices/virtual/mtd/mtd4/mtdblock4
    [ 21.111511] <30>udisks-daemon[143]: **** CHANGED /sys/devices/virtual/mtd/mtd4/mtdblock4
    [ 21.111572] <30>udisks-daemon[143]: **** CHANGING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
    [ 21.111633] <30>udisks-daemon[143]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
    [ 21.111694] <30>udisks-daemon[143]: **** CHANGED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0
    [ 21.111724] <30>udisks-daemon[143]: **** CHANGING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
    [ 21.111785] <30>udisks-daemon[143]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
    [ 21.111846] <30>udisks-daemon[143]: **** CHANGED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1
    [ 21.111907] <30>udisks-daemon[143]: **** CHANGING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
    [ 21.111938] <30>udisks-daemon[143]: **** UPDATING /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
    [ 21.111999] <30>udisks-daemon[143]: **** CHANGED /sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2
    Started Network Manager [ OK ]
    [ 22.110687] <30>gdm[295]: gdm-binary[295]: WARNING: GdmDisplay: display lasted 1.957935 seconds
    [ 22.146820] <28>gdm-binary[295]: WARNING: GdmDisplay: display lasted 1.957935 seconds
    [ 22.155090] <30>systemd[1]: Startup finished in 15s 266ms 935us (kernel) + 7s 184ms 328us (userspace) = 22s 451ms 263us.
    [ 22.381195] <30>NetworkManager[113]: NetworkManager[113]: <warn> bluez error getting default adapter: The name org.bluez was not provided by any .service files
    [ 22.406738] <12>NetworkManager[113]: <warn> bluez error getting default adapter: The name org.bluez was not provided by any .service files
    [ 22.456817] <30>gdm[295]: gdm-binary[295]: WARNING: GdmDisplay: display lasted 0.313439 seconds
    [ 22.466003] <28>gdm-binary[295]: WARNING: GdmDisplay: display lasted 0.313439 seconds
    [ 22.616180] <30>gdm[295]: gdm-binary[295]: WARNING: GdmDisplay: display lasted 0.176069 seconds
    [ 22.636779] <28>gdm-binary[295]: WARNING: GdmDisplay: display lasted 0.176069 seconds
    [ 22.795257] <30>gdm[295]: gdm-binary[295]: WARNING: GdmDisplay: display lasted 0.173888 seconds
    [ 22.816802] <28>gdm-binary[295]: WARNING: GdmDisplay: display lasted 0.173888 seconds
    [ 22.974395] <30>gdm[295]: gdm-binary[295]: WARNING: GdmDisplay: display lasted 0.173930 seconds
    [ 22.996795] <28>gdm-binary[295]: WARNING: GdmDisplay: display lasted 0.173930 seconds
    [ 23.153045] <30>gdm[295]: gdm-binary[295]: WARNING: GdmDisplay: display lasted 0.173069 seconds
    [ 23.163238] <28>gdm-binary[295]: WARNING: GdmDisplay: display lasted 0.173069 seconds
    [ 23.171722] <30>gdm[295]: gdm-binary[295]: WARNING: GdmLocalDisplayFactory: maximum number of X display failures reached: check X server log for errors
    [ 23.186065] <28>gdm-binary[295]: WARNING: GdmLocalDisplayFactory: maximum number of X display failures reached: check X server log for errors
    .---O---.
    | | .-. o o
    The Angstrom Distribution beagleboard ttyO2
    beagleboard login: root
    [ 294.464752] <83>login[173]: pam_env(login:session): Unable to open env file: /etc/default/locale: No such file or directory
    Last login: Thu Jan 12 12:20:28 GMT 2012 on ttyO[ 294.484008] <86>2
    login[173]: pam_unix(login:session): session opened for user root by LOGIN(uid=0)
    [ 294.510742] <85>login[328]: ROOT LOGIN on '/dev/ttyO2'
    root@beagleboard:~# ifconfig
    lo Link encap:Local Loopback
    inet addr:127.0.0.1 Mask:255.0.0.0
    UP LOOPBACK RUNNING MTU:16436 Metric:1
    RX packets:0 errors:0 dropped:0 overruns:0 frame:0
    TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:0
    RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
    root@beagleboard:~#
    I am not sure what causes the issue, but I see your .config does not have any glue layer defined. I have not used beagleboard for a very long time, don't remember which glue driver is for beagle, but I believe it is CONFIG_USB_MUSB_OMAP2PLUS_GLUE.
  • Check your kernel boot log, I don't see any MUSB related message. The driver is not loaded.
  • Hi Bin,
    Thank you very much !!!!!
    You are right, now it works !
  • Hello Bin Liu,
    It seems that it works, but only partly.
    It has some disconnections every several seconds, and after such disconnect I need to set the ip again, and only then can check ping with PC.
    Do you find any problem in the attched log below ?
    root@beagleboard:~#
    RX packets:6 errors:0 dropped:0 overruns:0 frame:0
    TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:672 (672.0 B) TX bytes:672 (672.0 B)
    usb0 Link encap:Ethernet HWaddr 36:19:CA:A6:B0:B2
    UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
    RX packets:258 errors:0 dropped:12 overruns:0 frame:0
    TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:21820 (21.3 KiB) TX bytes:2828 (2.7 KiB)
    root@beagleboard:~# [ 141.243835] <30>dhclient[340]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 6
    [ 141.252990] <30>NetworkManager[132]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 6
    ifconfig usb0 10.0.0.20
    [ 145.770416] <30>avahi-daemon[143]: root@beagleboardJoining mDNS multicast group on interface usb0.IPv4 with address 10.0.0.20.:~#
    [ 145.785308] <30>avahi-daemon[143]: New relevant interface usb0.IPv4 for mDNS.
    [ 145.792846] <30>avahi-daemon[143]: Registering new address record for 10.0.0.20 on usb0.IPv4.
    ifconfig usb0 10.0.0.20[ 147.258056] <30>dhclient[340]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 13
    [ 147.268096] <30>NetworkManager[132]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 13
    ping 10.0.0.17
    PING 10.0.0.17 (10.0.0.17): 56 data bytes
    64 bytes from 10.0.0.17: seq=0 ttl=128 time=4.558 ms
    64 bytes from 10.0.0.17: seq=1 ttl=128 time=0.681 ms
    64 bytes from 10.0.0.17: seq=2 ttl=128 time=0.545 ms
    64 bytes from 10.0.0.17: seq=3 ttl=128 time=0.626 ms
    64 bytes from 10.0.0.17: seq=4 ttl=128 time=0.682 ms
    64 bytes from 10.0.0.17: seq=5 ttl=128 time=0.484 ms
    64 bytes from 10.0.0.17: seq=6 ttl=128 time=0.682 ms
    64 bytes from 10.0.0.17: seq=7 ttl=128 time=0.699 ms
    64 bytes from 10.0.0.17: seq=8 ttl=128 time=0.569 ms
    64 bytes from 10.0.0.17: seq=9 ttl=128 time=0.602 ms
    64 bytes from 10.0.0.17: seq=10 ttl=128 time=0.664 ms
    [ 160.271301] <30>dhclient[340]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 9
    [ 160.280273] <30>NetworkManager[132]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 9
    64 bytes from 10.0.0.17: seq=11 ttl=128 time=0.716 ms
    64 bytes from 10.0.0.17: seq=12 ttl=128 time=0.654 ms
    64 bytes from 10.0.0.17: seq=13 ttl=128 time=0.585 ms
    64 bytes from 10.0.0.17: seq=14 ttl=128 time=0.658 ms
    64 bytes from 10.0.0.17: seq=15 ttl=128 time=0.657 ms
    64 bytes from 10.0.0.17: seq=16 ttl=128 time=0.507 ms
    64 bytes from 10.0.0.17: seq=17 ttl=128 time=0.650 ms
    64 bytes from 10.0.0.17: seq=18 ttl=128 time=0.657 ms
    64 bytes from 10.0.0.17: seq=19 ttl=128 time=0.664 ms
    [ 169.280670] <30>dhclient[340]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 13
    [ 169.289825] <30>NetworkManager[132]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 13
    64 bytes from 10.0.0.17: seq=20 ttl=128 time=0.750 ms
    64 bytes from 10.0.0.17: seq=21 ttl=128 time=0.645 ms
    64 bytes from 10.0.0.17: seq=22 ttl=128 time=0.509 ms
    64 bytes from 10.0.0.17: seq=23 ttl=128 time=0.652 ms
    64 bytes from 10.0.0.17: seq=24 ttl=128 time=0.661 ms
    64 bytes from 10.0.0.17: seq=25 ttl=128 time=0.614 ms
    64 bytes from 10.0.0.17: seq=26 ttl=128 time=0.605 ms
    [ 175.687316] <12>NetworkManager[132]: <warn> (usb0): DHCPv4 request timed out.
    [ 175.696746] <30>NetworkManager[132]: NetworkManager[132]: <warn> (usb0): DHCPv4 request timed out.
    [ 175.890899] <14>NetworkManager[132]: <info> (usb0): canceled DHCP transaction, DHCP client pid 340
    [ 175.900848] <14>NetworkManager[132]: <info> Activation (usb0) Stage 4 of 5 (IP4 Configure Timeout) scheduled...
    [ 175.911895] <14>NetworkManager[132]: <info> Activation (usb0) Stage 4 of 5 (IP4 Configure Timeout) started...
    [ 175.924743] <14>NetworkManager[132]: <info> Activation (usb0) Stage 5 of 5 (IP Configure Commit) scheduled...
    [ 175.935516] <14>NetworkManager[132]: <info> Activation (usb0) Stage 4 of 5 (IP4 Configure Timeout) complete.
    [ 175.946166] <30>NetworkManager[132]: NetworkManager[132]: <info> (usb0): canceled DHCP transaction, DHCP client pid 340
    [ 175.957763] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 4 of 5 (IP4 Configure Timeout) scheduled...
    [ 175.972564] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 4 of 5 (IP4 Configure Timeout) started...
    [ 175.985260] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 5 of 5 (IP Configure Commit) scheduled...
    [ 175.997924] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 4 of 5 (IP4 Configure Timeout) complete.
    [ 176.010406] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 5 of 5 (IP Configure Commit) started...
    [ 176.026794] <14>NetworkManager[132]: <info> Activation (usb0) Stage 5 of 5 (IP Configure Commit) started...
    [ 176.039611] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 5 of 5 (IP Configure Commit) failed (no IP configuration found)
    [ 176.054565] <14>NetworkManager[132]: <info> Activation (usb0) Stage 5 of 5 (IP Configure Commit) failed (no IP configuration found)
    [ 176.067382] <14>NetworkManager[132]: <info> (usb0): device state change: ip-config -> failed (reason 'ip-config-unavailable') [70 120 5]
    [ 176.081024] <30>NetworkManager[132]: NetworkManager[132]: <info> (usb0): device state change: ip-config -> failed (reason 'ip-config-unavailable') [70 120 5]
    [ 176.095947] <12>NetworkManager[132]: <warn> Activation (usb0) failed.
    [ 176.102752] <30>NetworkManager[132]: NetworkManager[132]: <warn> Activation (usb0) failed.
    [ 176.111511] <14>NetworkManager[132]: <info> Activation (usb0) Stage 5 of 5 (IP Configure Commit) complete.
    [ 176.121734] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 5 of 5 (IP Configure Commit) complete.
    [ 176.133880] <14>NetworkManager[132]: <info> (usb0): device state change: failed -> disconnected (reason 'none') [120 30 0]
    [ 176.145538] <30>NetworkManager[132]: NetworkManager[132]: <info> (usb0): device state change: failed -> disconnected (reason 'none') [120 30 0]
    [ 176.159118] <14>NetworkManager[132]: <info> (usb0): deactivating device (reason 'none') [0]
    [ 176.168151] <30>NetworkManager[132]: NetworkManager[132]: <info> (usb0): deactivating device (reason 'none') [0]
    [ 176.178894] <30>avahi-daemon[143]: Withdrawing address record for 10.0.0.20 on usb0.
    [ 176.187103] <30>avahi-daemon[143]: Leaving mDNS multicast group on interface usb0.IPv4 with address 10.0.0.20.
    [ 176.197692] <30>avahi-daemon[143]: Interface usb0.IPv4 no longer relevant for mDNS.
    ping: sendto: Network is unreachable
    root@beagleboard:~# [ 178.687561] <14>NetworkManager[132]: <info> Auto-activating connection 'Wired connection 1'.
    [ 178.702331] <14>NetworkManager[132]: <info> Activation (usb0) starting connection 'Wired connection 1'
    [ 178.712951] <14>NetworkManager[132]: <info> (usb0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
    [ 178.724975] <30>NetworkManager[132]: NetworkManager[132]: <info> Auto-activating connection 'Wired connection 1'.
    [ 178.736145] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) starting connection 'Wired connection 1'
    [ 178.750030] <30>NetworkManager[132]: NetworkManager[132]: <info> (usb0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
    [ 178.764343] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 1 of 5 (Device Prepare) scheduled...
    [ 178.776824] <14>NetworkManager[132]: <info> Activation (usb0) Stage 1 of 5 (Device Prepare) scheduled...
    [ 178.787170] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 1 of 5 (Device Prepare) started...
    [ 178.799346] <14>NetworkManager[132]: <info> Activation (usb0) Stage 1 of 5 (Device Prepare) started...
    [ 178.809600] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) scheduled...
    [ 178.823333] <14>NetworkManager[132]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) scheduled...
    [ 178.833953] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 1 of 5 (Device Prepare) complete.
    [ 178.845977] <14>NetworkManager[132]: <info> Activation (usb0) Stage 1 of 5 (Device Prepare) complete.
    [ 178.856079] <14>NetworkManager[132]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) starting...
    [ 178.868865] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) starting...
    [ 178.881317] <14>NetworkManager[132]: <info> (usb0): device state change: prepare -> config (reason 'none') [40 50 0]
    [ 178.895477] <30>NetworkManager[132]: NetworkManager[132]: <info> (usb0): device state change: prepare -> config (reason 'none') [40 50 0]
    [ 178.923431] <14>NetworkManager[132]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) successful.
    [ 178.943969] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) successful.
    [ 178.973449] <14>NetworkManager[132]: <info> Activation (usb0) Stage 3 of 5 (IP Configure Start) scheduled.
    [ 178.990295] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 3 of 5 (IP Configure Start) scheduled.
    [ 179.002838] <14>NetworkManager[132]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) complete.
    [ 179.013427] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) complete.
    [ 179.025634] <14>NetworkManager[132]: <info> Activation (usb0) Stage 3 of 5 (IP Configure Start) started...
    [ 179.036224] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 3 of 5 (IP Configure Start) started...
    [ 179.048706] <14>NetworkManager[132]: <info> (usb0): device state change: config -> ip-config (reason 'none') [50 70 0]
    [ 179.060333] <30>NetworkManager[132]: NetworkManager[132]: <info> (usb0): device state change: config -> ip-config (reason 'none') [50 70 0]
    [ 179.073944] <14>NetworkManager[132]: <info> Activation (usb0) Beginning DHCPv4 transaction (timeout in 45 seconds)
    [ 179.085174] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Beginning DHCPv4 transaction (timeout in 45 seconds)
    [ 179.100494] <14>NetworkManager[132]: <info> dhclient started with pid 348
    [ 179.108001] <30>NetworkManager[132]: NetworkManager[132]: <info> dhclient started with pid 348
    [ 179.118896] <14>NetworkManager[132]: <info> Activation (usb0) Stage 3 of 5 (IP Configure Start) complete.
    [ 179.140502] <30>NetworkManager[132]: NetworkManager[132]: <info> Activation (usb0) Stage 3 of 5 (IP Configure Start) complete.
    [ 179.189056] <30>dhclient[348]: Internet Systems Consortium DHCP Client 4.2.0
    [ 179.198425] <30>dhclient[348]: Copyright 2004-2010 Internet Systems Consortium.
    [ 179.207031] <30>NetworkManager[132]: Internet Systems Consortium DHCP Client 4.2.0
    [ 179.215759] <30>dhclient[348]: All rights reserved.
    [ 179.221405] <30>NetworkManager[132]: Copyright 2004-2010 Internet Systems Consortium.
    [ 179.231109] <30>dhclient[348]: For info, please visit https://www.isc.org/software/dhcp/
    [ 179.240264] <30>NetworkManager[132]: All rights reserved.
    [ 179.246887] <30>NetworkManager[132]: For info, please visit https://www.isc.org/software/dhcp/
    [ 179.256347] <27>dhclient[348]: can't create /var/lib/dhcp/dhclient-0c0c5428-c126-43cf-8afe-4c6c853eff49-usb0.lease: No such file or directory
    [ 179.269897] <30>NetworkManager[132]: can't create /var/lib/dhcp/dhclient-0c0c5428-c126-43cf-8afe-4c6c853eff49-usb0.lease: No such file or directory
    [ 179.283996] <30>NetworkManager[132]: NetworkManager[132]: <info> (usb0): DHCPv4 state changed nbi -> preinit
    [ 179.294647] <14>NetworkManager[132]: <info> (usb0): DHCPv4 state changed nbi -> preinit
    [ 179.303375] <30>dhclient[348]: Listening on LPF/usb0/36:19:ca:a6:b0:b2
    [ 179.310516] <30>dhclient[348]: Sending on LPF/usb0/36:19:ca:a6:b0:b2
    [ 179.317657] <30>NetworkManager[132]: Listening on LPF/usb0/36:19:ca:a6:b0:b2
    [ 179.325256] <30>dhclient[348]: Sending on Socket/fallback
    [ 179.331268] <30>NetworkManager[132]: Sending on LPF/usb0/36:19:ca:a6:b0:b2
    [ 179.339019] <30>dhclient[348]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 4
    [ 179.347930] <30>NetworkManager[132]: Sending on Socket/fallback
    [ 179.354583] <30>NetworkManager[132]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 4
    root@beagleboard:~#
    root@beagleboard:~# [ 183.251190] <30>dhclient[348]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 10
    [ 183.260375] <30>NetworkManager[132]: DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 10
    RX packets:377 errors:0 dropped:13 overruns:0 frame:0
    TX packets:58 errors:0 dropped:0 overruns:0 carrier:0
    RX bytes:30429 (29.7 KiB) TX bytes:13694 (13.3 KiB)
    Ran
  • All the testing are done on the beagleboard , with PSP 04.02.00.07. (except u-boot becuast u-boot from this PSP, though compiled for beagleboard get hangs on the beagleboard)
    Ran
