Is it possible to use the two ethernet ports on the DM648 as independant physical interfaces with a separate NDK IP stack running on each port i.e. each port having it's own (DHCP assigned) IP address?
Grant
Grant
From what I understand, this is not a supported use-case. I believe it has been done, but as a custom change by a specific user. I'll check to see if any more detailed information can be made available.
The engineer placed code and info at the following site:
http://tiexpressdsp.com/index.php/Using_two_DM648_EMACs_separately
