IPC example run Fails on the pandaboard Es OMAP4460
Hello, everyone:
i am using CCSV5.4.0, I tried to run IPC notify example on Pandaboard Es which contain an OMAP4460,.it can run into main both M3 core and A9's, except DSP(Tesla). when i load the dsp.out.  it's can't run into mian, i don't know how to fix it . I also try program without bios, it can load correctly.
I am new user on OMAP4, i can't really find the suitable example on the Pandboard Es.Not large application,just a simple demo. if you know some webs, could you tell me please?
Thank you!
        Johnny
  • Johnny,Can you tell where the DSP ran to when it failed?
    If you Connect to the DSP with CCS, where is it stopped? Is there any output in the console window? Is there any output in a SYS/BIOS Log or System module in use (SysStd or SysMin most likely). The Log and System output is available in the ROV tool: CCS Tools->ROV menu selection.
    What version of SYS/BIOS and IPC are you using?Regards,- Rob
