ipnc rdk3.8 video flick issue
I encounter an video flick issue, this issue happen at both hdmi display and encode bitstream, please check following video link, my usecase like this:
                  |---------swms---nsf--enc
cam--dup--|
                  |----------------hdmi
camera: 1080p@60fps,
swms: 60fps output
encode: 60fps
display: 60fps
If I reduce swms output fps to 30, the flick issue is gone. I am using ipnc rdk3.8 run at dm385 platform. Any suggestion will appreciate.
I test below case that is work fine:
    case 1: change encode format from h264 to mjpeg.
    case 2: encode h264 format, change usecase like this
                  |--------- enc
cam--dup--|
Following usecase still see flick(video sequence not right) issue:
    capture->swms->nsf->enc
                   |---------swms---nsf--enc (disable encode)
 cam--dup--|
Thank you very much,
david
video link:
https://drive.google.com/file/d/0B-paQ7KRgGzvLXVpOVRUX29IUFk/view?usp=sharing
