Hi:
There is something error when I use DM8168 DVRRDK4.0 to decode and display a 1080p video!
I used the VDEC + VDIS - SD/HD Decode ONLY demo! And my demo_ini file is
[file00]
path=/data/rain.h264
width=1920
height=1080
enable=1
codec=h264
numbuf=0
displaydelay=0
The error info is:
[m3video] 63444:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] ALGPROCESS FAILED:STATUS
root@dm816x:/opt/dvr_rdk/ti816x#
root@dm816x:/opt/dvr_rdk/ti816x# ./init.sh
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
*** Kernel Base address validated ***
Kernel bootargs validated
numid=101,iface=MIXER,name='Left DAC Mux'
; type=ENUMERATED,access=rw------,values=1,items=3
; Item #0 'DAC_L1'
; Item #1 'DAC_L3'
; Item #2 'DAC_L2'
: values=2
numid=99,iface=MIXER,name='Right DAC Mux'
; Item #0 'DAC_R1'
; Item #1 'DAC_R3'
; Item #2 'DAC_R2'
: values=2
[c6xdsp ] Remote Debug Shared Memory @ 0xbfd00000
[m3video] Remote Debug Shared Memory @ 0xbfd10820
[m3vpss ] Remote Debug Shared Memory @ 0xbfd21040
SysLink version : 2.20.02.20
SysLink module created on Date:Sep 26 2014 Time:10:54:58
Trace enabled
Trace SetFailureReason enabled
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
*** TVP5158 probe : START ***
TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
TI DVR : TVP5158 device address : 0x5c, 0x5d, 0x5e, 0x5f
Device found : I2C (0xXX): 0x08 = 0x51
I2C (0xXX): 0x09 = 0x58
Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x58): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5c): 0x08 = 0x51
I2C (0x5c): 0x09 = 0x58
I2C (0x5d): 0x08 = 0x51
I2C (0x5d): 0x09 = 0x58
I2C (0x5e): 0x08 = 0x51
I2C (0x5e): 0x09 = 0x58
I2C (0x5f): 0x08 = 0x51
I2C (0x5f): 0x09 = 0x58
*** TVP5158 probe : END ***
/opt/dvr_rdk/ti816x
root@dm816x:/opt/dvr_rdk/ti816x# ./load.sh
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_2048M_512M.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
[m3vpss ] ***** VPSS Firmware build time 16:15:01 Jan 24 2015 EDG gcc 3.0 mode
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 274909088
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 549818 Khz ***
[m3vpss ]
[m3vpss ] 34: SYSTEM : System Common Init in progress !!!
[m3vpss ] 35: SYSTEM: IPC init in progress !!!
[m3vpss ] 35: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 37: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
After Ipc_startcallback status [0x00000000]
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video_2048M_512M.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ***** VIDEO Firmware build time 16:15:43 Jan 24 2015 EDG gcc 3.0 mode
[m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 274909088
[m3video]
[m3video] *** UTILS: CPU KHz = 549818 Khz ***
[m3video]
[m3video] 442: SYSTEM : System Common Init in progress !!!
[m3video] 442: SYSTEM: IPC init in progress !!!
[m3video] 442: SYSTEM: Attaching to [HOST] ...
[m3video] 445: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_2048M_512M.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** VIDEO Firmware build time 16:13:11 Jan 24 2015 EDG gcc 3.0 mode
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 1000000000
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 1000000 Khz ***
[c6xdsp ]
[c6xdsp ] 5: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 5: SYSTEM: IPC init in progress !!!
[c6xdsp ] 5: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 8: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 10: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 708: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 709: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[c6xdsp ] 12: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !DMA: Module install successful, device major num = 251
[m3video] DRV: Module install successful
710: SYSTEM: AttDRV: Module built on Sep 26 2014 10:55:58
aching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 710: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[c6xdsp ] 12: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
[m3video] 710: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
[m3vpss ] 710: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
[c6xdsp ] 12: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[m3video] 711: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 711: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[c6xdsp ] 12: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[m3video] 711: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 711: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[c6xdsp ] 12: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3video] 712: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3vpss ] 712: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[c6xdsp ] 12: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[m3video] 712: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[m3vpss ] 712: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[c6xdsp ] 12: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3video] 713: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3vpss ] 713: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[c6xdsp ] 12: SYSTEM: IPC init DONE !!!
[m3video] 713: SYSTEM: IPC init DONE !!!
[m3vpss ] 713: SYSTEM: IPC init DONE !!!
[c6xdsp ] 14: MEM: Shared Region 2: Base = 0xa0700000, Length = 0x1d900000 (473 MB)
[c6xdsp ] 14: MEM: ERROR: SharedRegion_setEntry (2, 0x9952bb5c) FAILED !!! (status=-1)
[m3video] 718: MEM: Shared Region 2: Base = 0xa0700000, Length = 0x1d900000 (473 MB)
[m3vpss ] 718: MEM: Shared Region 2: Base = 0xa0700000, Length = 0x1d900000 (473 MB)
[m3video] 719: MEM: Shared Region 1: Base = 0x80000000, Length = 0x11600000 (278 MB)
[m3vpss ] 719: MEM: Shared Region 1: Base = 0x80000000, Length = 0x11600000 (278 MB)
[m3video] 720: SYSTEM : System Common Init Done !!!
[m3vpss ] 720: SYSTEM : System Common Init Done !!!
[m3video] 721: SYSTEM : System Video Init in progress !!!
[m3vpss ] 720: SYSTEM : System VPSS Init in progress !!!
[m3video] 721: SYSTEM : System Video Init Done !!!
[m3video] 721: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 721: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 721: SYSTEM: ListElem Shared Addr = 0xbe1b3e00
[m3vpss ] === HDVPSS Clocks are enabled ===
[m3video] 724: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 724: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 724: SYSTEM: ListElem Shared Addr = 0xbe1b7300
[m3vpss ] === HDVPSS is fully functional ===
[m3video] 730: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
[m3vpss ] === HDVPSS module is not in standby ===
[m3video] 730: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
[m3vpss ] === I2C1 Clk is active ===
[m3video] 730: SYSTEM: ListElem Shared Addr = 0xbe1bdd00
[m3vpss ] 729: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3video] 732: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
[m3vpss ] 730: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 733: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
[m3vpss ] 730: SYSTEM: ListElem Shared Addr = 0xbe1bad80
[m3video] 733: SYSTEM: ListElem Shared Addr = 0xbe1e6a00
[m3vpss ] 732: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 735: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
[m3vpss ] 732: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 735: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
[m3vpss ] 732: SYSTEM: ListElem Shared Addr = 0xbe1e3780
[m3video] 736: SYSTEM: ListElem Shared Addr = 0xbe20c200
[m3vpss ] 746: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
[m3video] 749: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 746: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
[m3video] 749: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 747: SYSTEM: ListElem Shared Addr = 0xbe231a00
[m3video] 749: SYSTEM: ListElem Shared Addr = 0xbe257500
[m3vpss ] 749: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
[m3video] 751: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 749: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
[m3video] 752: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 749: SYSTEM: ListElem Shared Addr = 0xbe274d00
[m3video] 752: SYSTEM: ListElem Shared Addr = 0xbe29a780
[m3vpss ] 752: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
[m3video] 753: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 752: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
[m3video] 754: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 752: SYSTEM: ListElem Shared Addr = 0xbe2b8000
[m3video] 754: HDVICP: Doing PRCM for IVAHD[1] ...
[m3vpss ] 754: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3video] 754: HDVICP: PRCM for IVAHD[1] ... DONE.
[m3vpss ] 754: SYSTEM : FVID2 Init in progress !!!
[m3video] 754: HDVICP: Doing PRCM for IVAHD[2] ...
[m3video] 754: HDVICP: PRCM for IVAHD[2] ... DONE.
[m3video] 754: SYSTEM : Initializing Links !!!
[m3vpss ] Received character 's'
[m3video] 755: SYSTEM : FREE SPACE : System Heap = 6279304 B, Mbx = 10240 msgs)
[m3vpss ] TILER_STATS: CNT :8BIT
[m3video] Received character 's'
[m3video] 755: SYSTEM : FREE SPACE : SR0 Heap = 21114368 B (20 MB)
[m3vpss ] TILER_STATS: CNT RESOLUTION: 16384 x 8192
[m3video] 755: SYSTEM : FREE SPACE : Frame Buffer = 495976320 B (472 MB)
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 8188
[m3video] 755: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] TILER_STATS: NUM FREE BUCKETS: 1
[m3video] 755: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] TILER_STATS: NUM USED BUCKETS: 0
[m3video] 757: SYSTEM : FREE SPACE : Tiler 8-bit = 134152192 B (127 MB) - TILER ON
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 134152192 (99 %)
[m3video] 757: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] TILER_STATS: TOTAL USED AREA: 0 (0 %)
[m3video] 791: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] TILER_STATS: CNT :16BIT
[m3vpss ] TILER_STATS: CNT RESOLUTION: 32768 x 4096
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 4096
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 134217728 (100 %)
[m3vpss ] 824: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 824: SYSTEM : Device Init in progress !!!
[m3vpss ] 827: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 867: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 868: UTILS: DMA: HWI Create for INT63 !!!
[m3vpss ] 868: SYSTEM : Initializing Links !!!
[m3vpss ] 868: SYSTEM : FREE SPACE : System Heap = 74056 B, Mbx = 10240 msgs)
[m3vpss ] 868: SYSTEM : FREE SPACE : SR0 Heap = 21114368 B (20 MB)
[m3vpss ] 868: SYSTEM : FREE SPACE : Frame Buffer = 491666304 B (468 MB)
[m3vpss ] 869: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] 870: SYSTEM : FREE SPACE : Tiler 8-bit = 134152192 B (127 MB) - TILER ON
[m3vpss ] 870: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 984: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 984: SYSTEM : Set Static L3 pressure for HDVPSS as High
[c6xdsp ] 1021: MEM: Shared Region 1: Base = 0x80000000, Length = 0x11600000 (278 MB)
[c6xdsp ] 1022: SYSTEM : System Common Init Done !!!
[c6xdsp ] 1009: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 1009: SYSTEM : RpeServer_init() done... Ret Val 0!!!
[c6xdsp ] 1024: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
[c6xdsp ] 1024: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
[c6xdsp ] 1024: SYSTEM: ListElem Shared Addr = 0xbe2dd800
[c6xdsp ] 1025: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
[c6xdsp ] 1025: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
[c6xdsp ] 1025: SYSTEM: ListElem Shared Addr = 0xbe303000
[c6xdsp ] 1025: SYSTEM: Creating Li[module] vpss probe done.
stMP [DSP_IPC_OUT_21] in region 0 ...
[c6xdsp ] 1026: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
[c6xdsp ] 1026: SYSTEM: ListElem Shared Addr = 0xbe328800
[c6xdsp ] 1026: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 1026: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 1026: SYSTEM: [module] ti81xxfb probe done.
ListElem Shared Addr = 0xbe34e000
[c6xdsp ] 1027: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 1027: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 1027: SYSTEM: ListElem Shared Addr = 0xbe36bb00
[c6xdsp ] !!WARNING.Resource already regHDMI W1 rev 2.0
istered:2
[c6xHDMI CEC Spec version 1.2
dsp ] 1014: SYSTEM : Initializing Links !!!
[c6xdsp ] Received character 's'
/opt/dvr_rdk/ti816x
[c6xdsp ] 1027: SYSTEM : FREE SPACE : System Heap = 10391168 B, Mbx = 10240 msgs)
[c6xdsp ] 1026: SYSTEM : Initializing Links ... DONE !!!
[c6xdsp ] ETH_OFFLOAD: Init !!!
[c6xdsp ] 1026: SYSTEM : System DSP Init Done !!!
ORG 0x46c00524: 0
NEW 0x46c00524: 2
root@dm816x:/opt/dvr_rdk/ti816x# ./run.sh
Main Menu
1: VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
2: VCAP + VENC + VDIS - SD Encode ONLY
3: VCAP + VENC + VDEC + VDIS - Progressive HD Encode + Decode
4: VDEC + VDIS - SD/HD Decode ONLY
a: 960H DVR usecase
e: Exit
Enter Choice: 4
Sample ini files available in ./demo_ini folder.
Enter the .ini filename with full path : ./demo_ini/1920x1080_01CH.ini
*** a new param codec is needed for ini, if you not sure about this
*** please reference demo_ini/704x576_02_32CH.ini
*** H264: codec = h264
*** MPEG4: codec = mpeg4
*** MJPEG: codec = mjpeg
*** Four new params numbuf ,displaydelay,tilerEnable,fieldPicture has been added for ini, if not defaults are set
*** Generate header files ***
This will take very long time if the file is large.
- For first time you MUST select YES.
- If you already have the header file on disk, you can select NO.
Do you want to generate header ? (YES - y, NO - n) : y
0: Opening file [/data/rain.h264] of 1920 x 1080 Codec: h264...
0: WARNING: Either the displaydelay was not set or Default value was set as 0
0: WARNING: Either the Num of output buffers not set or Default value was set as zero
Input file [/data/rain.h264] opened successfully !!!
Output file [/data/rain.h264.hdr] opened successfully !!!
gVdecVdis_config.numChannels : 1 gVdecVdis_config.chBufSize[0] : 2073600
File open ... DONE !!!
--------------- CHANNEL DETAILS-------------
Dec Channels => 1
Disp Channels => 1
0: SYSTEM: System Common Init in progress !!!
0: SYSTEM: IPC init in progress !!!
14: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
14: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
14: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
14: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
14: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
16: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
18: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
19: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
20: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
20: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
21: SYSTEM: Notify register to [DSP] line 0, event 15 ...
22: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
22: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
23: SYSTEM: IPC init DONE !!!
24: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
26: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
27: SYSTEM: ListElem Shared Addr = 0x40ee0880
28: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
30: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
31: SYSTEM: ListElem Shared Addr = 0x40f15a80
33: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
35: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
36: SYSTEM: ListElem Shared Addr = 0x40f4ac80
37: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
39: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
41: SYSTEM: ListElem Shared Addr = 0x40f8df80
42: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
44: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
45: SYSTEM: ListElem Shared Addr = 0x40fd1280
62: SYSTEM: System Common Init Done !!!
ch[0], h264
[host] HDMI Ctrl :Initializing
[host] HDMI Ctrl :Initialized
[host] HDMI Ctrl :Sink Connected
[FBDEV]
[FBDEV] FB: Starting !!!
[FBDEV] FB: Opened device [/dev/fb0] (fd=23) !!!
[FBDEV]
[FBDEV] Fix Screen Info
[FBDEV] ---------------
[FBDEV] Line Length - 2560
[FBDEV] Physical Address = dea00000
[FBDEV] Buffer Length = 8294400
[FBDEV]
[FBDEV]
[FBDEV] Var Screen Info
[FBDEV] Xres - 1280
[FBDEV] Yres - 720
[FBDEV] Xres Virtual - 1280
[FBDEV] Yres Virtual - 720
[FBDEV] Bits Per Pixel - 16
[FBDEV] Pixel Clk - 6734
[FBDEV] Rotation - 0
[FBDEV]
[FBDEV]
[FBDEV] Reg Params Info
[FBDEV] region 0, postion 0 x 0, prioirty 1
[FBDEV] first 1, last 1
[FBDEV] sc en 0, sten en 0
[FBDEV] tran en 0, type 0, key 0
[FBDEV] blend 0, alpha 0
[FBDEV] bb en 0, alpha 0
[FBDEV]
[FBDEV]
[FBDEV] ### BUF SIZE = 1843200 Bytes !!!
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] Xres - 1280
[FBDEV] Yres - 720
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] grpx_fb_draw ...
[FBDEV] grpx_fb_draw ... Done !!!
[FBDEV] FB: Start DONE !!!
[FBDEV]
205: MCFW : CPU Revision [ES2.0] !!!
[host] 207: IPC_BITS_OUT : Create in progress !!!
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:0,Size:0x9E3400
[host]
******* RingBuf 0 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x48661080 To Phy:0x80000080
[host]
###Bit buff of size from the SR # 1 : 10368000 / bufsize 2073600, maxQueueDepth 50
[host] ###Bit buff BasePtr: 48661080 / PhyAddr 80000080
[host] 208: IPC_BITS_OUT : Create Done !!!
[m3video] 58021: IPC_BITS_IN : Create in progress !!!
[m3vpss ] WARNING!!.Tiler Memory cannot be accessed by M3 in 2G build.Will not disable
[m3video] 58021: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
[m3video] 58021: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
[m3video] 58022: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[m3video] 58023: IPC_BITS_IN : Create Done !!!
[m3video] 58024: DECODE: Create in progress ... !!!
[m3video] DECLINK_H264:HEAPID:0 USED:4264
[m3video] DECLINK_H264:HEAPID:3 USED:8937472
[m3video] 58150: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3vpss ] 58156: IPC_IN_M3 : Create in progress !!!
[m3video] 58152: DECODE: All CH Create ... DONE !!!
[m3vpss ] 58156: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[m3vpss ] 58156: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[m3vpss ] 58157: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[m3video] DECLINK:HEAPID:0 USED:4384
[m3vpss ] 58158: IPC_IN_M3 : Create Done !!!
[m3video] DECLINK:HEAPID:3 USED:27000832
[m3vpss ] 58159: MP_SCLR: Create in progress !!!
[m3video] 58154: DECODE: Create ... DONE !!!
[m3video] 58155: IPC_OUT_M3 : Create in progress !!!
[m3video] 58155: IPC_OUT_M3 : Create Done !!!
[m3vpss ] 58160: MP_SCLR: Configured to use scalar instance 4 !!!
[m3vpss ] 58161: MP_SCLR: Create Done !!!
[m3vpss ] 58166: DUP : Create Done !!!
[m3vpss ] 58166: SWMS: Create in progress !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58)
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 58 (0x49004740)
[m3vpss ] SWMS: instance 0, sc id 7, start win 0 end win 15
[m3vpss ] SWMS: instance 1, sc id 4, start win 16 end win 33
[m3vpss ] 58307: SWMS : VipScReq is FALSE!!!
[m3vpss ] 58310: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 58310: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 58310: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] 58314: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 58314: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 58314: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] 58314: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 58315: SWMS0 : Loading Vertical Co-effs (7/16)x ...
[m3vpss ] 58315: SWMS0 : Loading Horizontal Co-effs (6/16)x ...
[m3vpss ] 58315: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 30
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame |
[m3vpss ] ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 | 0, 0 | 1920 x 1080 | 2048 / 2048 | NON-TILED | 0, 0 | 736 x 500 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 1 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 736, 0 | 736 x 500 | 3840 / 0 | NON-TILED | OFF | 1 | 422I | OFF |
[m3vpss ] 2 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 500 | 736 x 500 | 3840 / 0 | NON-TILED | OFF | 1 | 422I | OFF |
[m3vpss ] 3 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 736, 500 | 736 x 500 | 3840 / 0 | NON-TILED | OFF | 1 | 422I | OFF |
[m3vpss ] 4 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 1472, 0 | 368 x 250 | 3840 / 0 | NON-TILED | ON | 1 | 422I | OFF |
[m3vpss ] 5 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 1472, 250 | 368 x 250 | 3840 / 0 | NON-TILED | ON | 1 | 422I | OFF |
[m3vpss ] 6 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 1472, 500 | 368 x 250 | 3840 / 0 | NON-TILED | ON | 1 | 422I | OFF |
[m3vpss ] 7 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 1472, 750 | 368 x 250 | 3840 / 0 | NON-TILED | ON | 1 | 422I | OFF |
[m3vpss ]
[m3vpss ] SWMS:HEAPID:0 USED:288
[m3vpss ] SWMS:HEAPID:1 USED:60832
[m3vpss ] SWMS:HEAPID:4 USED:29030400
[m3vpss ] 58318: SWMS: Create Done !!!
[m3vpss ] 58319: SWMS: Create in progress !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 59 (59)
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
[m3vpss ] SWMS: instance 0, sc id 6, start win 0 end win 15
[m3vpss ] SWMS: instance 1, sc id 3, start win 16 end win 33
[m3vpss ] 58459: SWMS : VipScReq is FALSE!!!
[m3vpss ] 58462: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 58463: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 58463: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] 58466: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 58466: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 58467: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] 58467: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 58467: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 58467: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 58468: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 0 | 0, 0 | 1920 x 1080 | 2048 / 2048 | NON-TILED | 0, 0 | 1920 x 1080 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ]
[m3vpss ] SWMS:HEAPID:1 USED:66656
[m3vpss ] 58469: SWMS: Create Done !!!
[m3vpss ] 58469: DISPLAY: Create in progress !!!
[m3vpss ] 58470: DISPLAY: Create Done !!!
[m3vpss ] 58471: DISPLAY: Create in progress !!!
[m3vpss ] 58471: DISPLAY: Create Done !!!
[m3vpss ] 58473: SWMS : ******* Configuring clock 30 secs...
[m3vpss ] 58473: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 58473: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 58473: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] 58475: DISPLAY: Start in progress !!!
[m3vpss ] 58518: DISPLAY: Start Done !!!
[m3vpss ] 58518: DISPLAY: HDDAC(BP0) : 46 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7811 / 0 ) !!!
[m3vpss ] 58518: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
[m3vpss ] 58518: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 1, SDDAC(SEC1) 0
[m3vpss ] 58518: SYSTEM : FREE SPACE : System Heap = 67320 B, Mbx = 10238 msgs)
[m3vpss ] 58519: SYSTEM : FREE SPACE : SR0 Heap = 16840192 B (16 MB)
[m3vpss ] 58519: SYSTEM : FREE SPACE : Frame Buffer = 406604672 B (387 MB)
[m3vpss ] 58519: SYSTEM : FREE SPACE : Bitstream Buffer = 281136000 B (268 MB)
[m3vpss ] 58519: DISPLAY: Start in progress !!!
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
5: Audio Capture <TVP5158> & Encode <AAC-LC, G711> demo
6: Change Playback Channel <valid only if capture/playback is active>
7: Audio encode demo <File In/Out>
8: Audio decode demo <File In/Out>
i: Print detailed system information
s: Core Status: Active/In-active
f: Switch IVA Channel Map
e: Stop Demo
Enter Choice:
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
e: Stop Demo
Enter Choice: [m3vpss ] TILER_STATS: CNT RESOLUTION: 16384 x 8192
[m3vpss ] 58521: SYSTEM : FREE SPACE : Tiler 8-bit = 134152192 B (127 MB) - TILER ON
[m3vpss ] 58521: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 58560: DISPLAY: Start Done !!!
[m3vpss ] 58560: DISPLAY: DVO2(BP1) : 48 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 7811 / 0 ) !!!
[m3vpss ] 58560: SWMS: Start in Progress !!!
[m3vpss ] 58560: SWMS: Start Done !!!
[m3vpss ] 58560: DISPLAY DRV: DVO2(BP1) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
[m3vpss ] 58561: SWMS: Start Done !!!
[m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[0],FirstPTS[0]
[m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[0],FirstPTS[0]
[m3vpss ] AVSYNC:Media Time Base:0,FirstVidPTS:0,FirstAudPTS:-1
DEMO: HDMI TV/Monitor connected !!!
DEMO: TV Detected - HDMI interface !!!
DEMO: INFO : Resolution set to 1080P60 !!!
[DECODER ERROR] 5631: DECODE CH <0> ERROR: IH264VDEC_ERR_NOSLICE : 0,
[DECODER ERROR] 5631: DECODE CH <0> ERROR: XDM_INSUFFICIENTDATA : 10,
[m3video] outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x401
[m3video] Sequence called number 138
[m3video] 66244:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] Sequence called number 224
[m3video] 68310:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] Sequence called number 287
[m3video] 71677:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] Sequence called number 387
[m3video] 73344:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] Sequence called number 439
[m3video] 86277:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] Sequence called number 828
[m3video] 92353:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] Sequence called number 1011
[m3video] 97477:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] Sequence called number 1166
[m3video] 100677:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] Sequence called number 1264
[m3video] 106444:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
[m3video] Sequence called number 1437
For more information see Annex
