As per the DDR3 routing guidelines for 66AK2E02, the single ended trace impedance should be 50ohm.
But usually for other processors like DaVinci, the single ended impedance for DDR3 trace should be between 50-75ohms with +/-5 tolerance.
Similarly do we have a range between which the single ended trace impedance should be chosen for K2E processor?What is the tolerance allowed?
Can we use 55ohm with +/-5 ohm tolerance?
Thanks and Regards,
Madhura
