Hi
We are trying to build the EtherCat example (not the full feature application). We did all the steps according to user guide, but now the following errors appear during build:
**** Clean-only build of configuration Debug for project ethercat ****
"c:\\ti\\ccsv6\\utils\\bin\\gmake" -k clean
cleaning ../src/sysbios ...
DEL /F "ethercat.out" "configPkg\linker.cmd" "configPkg\compiler.opt" "ethercat.hex"
Das System kann die angegebene Datei nicht finden.
gmake: [clean] Error 1 (ignored)
RMDIR /S/Q "configPkg\"
gmake: [clean] Error 2 (ignored)
DEL /F "tiescappl.pp" "tiescutils.pp"
C:\ti\am335x_sysbios_ind_sdk_1.1.0.6\sdk\examples\ethercat_slave\Debug\tiescappl.pp konnte nicht gefunden werden
DEL /F "tiescappl.obj" "tiescutils.obj"
C:\ti\am335x_sysbios_ind_sdk_1.1.0.6\sdk\examples\ethercat_slave\Debug\tiescappl.obj konnte nicht gefunden werden
'Finished clean'
**** Build Finished ****
**** Build of configuration Debug for project ethercat ****
"c:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
making ../src/sysbios/sysbios.aea8fnv ...
gmake[1]: Entering directory `C:/ti/am335x_sysbios_ind_sdk_1.1.0.6/sdk/examples/ethercat_slave/src/sysbios'
clea8fnv C:/ti/bios_6_41_00_26/packages/ti/sysbios/BIOS.c ...
asmea8fnv C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/IntrinsicsSupport_asm.asm ...
asmea8fnv C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/TaskSupport_asm.asm ...
asmea8fnv C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/a8/intcps/Hwi_asm.s470 ...
asmea8fnv C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/a8/intcps/Hwi_asm_switch.s470 ...
asmea8fnv C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/exc/Exception_asm.asm ...
"C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/exc/Exception_asm.asm", ERROR! at line 154:
[E0200]
Operation cannot be performed on given operands
.if (__TI_ARM_V7__ = 1)
"C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/exc/Exception_asm.asm", ERROR! at line 158:
[E0001]
Undefined symbol
ldr sp, excStackAddr
[E0001]
Address must be defined in the current section
[E0004]
Illegal operand
"C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/exc/Exception_asm.asm", ERROR! at line 172:
[E0200]
"C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/exc/Exception_asm.asm", ERROR! at line 176:
[E0001]
Undefined symbol
[E0001]
[E0004]
10 Assembly Errors, No Assembly Warnings
Illegal operand
"C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/exc/Exception_asm.asm", ERROR! at line 192:
[E0200]
.if (__TI_ARM_V7__ != 1)
"C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/exc/Exception_asm.asm", ERROR! at EOF:
[E0300]
The following symbols are undefined:
__TI_ARM_V7__
excStackAddr
Errors in Source - Assembler Aborted
gmake[1]: *** [exc_Exception_asm.obj] Error 1
>> Compilation failure
asmea8fnv C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/a8/Cache_asm.asm ...
asmea8fnv C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/a8/Mmu_asm.asm ...
asmea8fnv C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/a8/TimestampProvider_asm.asm ...
asmea8fnv C:/ti/bios_6_41_00_26/packages/ti/sysbios/timers/dmtimer/Timer_asm.s470 ...
gmake[1]: Target `all' not remade because of errors.
gmake[1]: Leaving directory `C:/ti/am335x_sysbios_ind_sdk_1.1.0.6/sdk/examples/ethercat_slave/src/sysbios'
gmake: *** [../src/sysbios/sysbios.aea8fnv] Error 2
'Building file: ../ethercat.cfg'
'Invoking: XDCtools'
"C:/ti/xdctools_3_30_05_60_core/xs" --xdcpath="c:/ti/ccsv6/ccs_base;C:/ti/bios_6_41_00_26/packages;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.A8Fnv -p ti.platforms.evmAM3359 -r release -b "C:/ti/am335x_sysbios_ind_sdk_1.1.0.6/sdk/examples/ethercat_slave/.config/xconfig_ethercat/config.bld" -c "c:/ti/ccsv6/tools/compiler/arm_4.9.5" --compileOptions "-g --optimize_with_debug" "../ethercat.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring ethercat.xea8fnv from package/cfg/ethercat_pea8fnv.cfg ...
Warning: xdc.cfg.INCOMPATIBLE_TARGET_VERSION: the compiler version [4.9.5] used by the current target 'ti.targets.arm.elf.A8Fnv' is not compatible with compiler version of targets used to build the following packages; package ti.targets.arm.rtsarm [in C:/ti/bios_6_41_00_26/packages/ti/targets/arm/rtsarm/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.family.arm [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.knl [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/knl/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.family.arm.exc [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/exc/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.family.arm.a8.intcps [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/a8/intcps/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.family.arm.a8 [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/a8/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.heaps [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/heaps/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.gates [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/gates/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.hal [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/hal/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.xdcruntime [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/xdcruntime/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.family.arm.a8.ti81xx [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/family/arm/a8/ti81xx/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.timers.dmtimer [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/timers/dmtimer/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
; package ti.sysbios.utils [in C:/ti/bios_6_41_00_26/packages/ti/sysbios/utils/] was built using the target 'ti.targets.arm.elf.A8Fnv' with compiler version [5.1.5].
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
making C:/ti/am335x_sysbios_ind_sdk_1.1.0.6/sdk/examples/ethercat_slave/src/sysbios/sysbios.aea8fnv ...
[E0200]
[E0001]
Undefined symbol
[E0001]
[E0004]
Illegal operand
[E0200]
[E0001]
Undefined symbol
[E0001]
>> Compilation failure
[E0004]
Illegal operand
[E0200]
[E0300]
__TI_ARM_V7__
excStackAddr
gmake: *** [C:/ti/am335x_sysbios_ind_sdk_1.1.0.6/sdk/examples/ethercat_slave/src/sysbios/sysbios.aea8fnv] Error 2
Build of libraries failed.
error: xdc.cfg.SourceDir: "C:/ti/xdctools_3_30_05_60_core/packages/xdc/cfg/SourceDir.xs", line 184: xdc.cfg.SourceDir : Build of generated source libraries failed: exit status = 2:
js: "C:/ti/xdctools_3_30_05_60_core/packages/xdc/cfg/Main.xs", line 160: Error: Configuration failed!
gmake.exe: *** [package/cfg/ethercat_pea8fnv.xdl] Error 1
gmake.exe: *** Deleting file `package/cfg/ethercat_pea8fnv.xdl'
gmake.exe: *** [package/cfg/ethercat_pea8fnv.xdl] Deleting file `package/cfg/ethercat_pea8fnv.h'
gmake.exe: *** [package/cfg/ethercat_pea8fnv.xdl] Deleting file `package/cfg/ethercat_pea8fnv.c'
js: "C:/ti/xdctools_3_30_05_60_core/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake: *** [configPkg/linker.cmd] Error 1
gmake: Target `all' not remade because of errors.
Do you have any idea what is going wrong?
Daniel
