Other Parts Discussed in Thread: AM1808
Hi every one.
I’m writing you because I need a recommendation about memory DDR and memory Flash NAND. Let me explain me, I’m working with a DSP C6748 on a customized PCB. Our customized PCB is based on the PCB LCDK C6748, it means that we’re using the same DDR2 memory and the same NAND Flash. When the DSP is working in Deep Sleep those memories consume a lot of power (even if the memories are in low consumption mode). So I’m wondering if you can recommend other memories for our customized PCB?
Our minimum requirements for the DDR or mDDR: at least 256 Mbytes. And for the NAND Flash 128 Mbytes.
Thank you in advance.
