I'm trying to interface Murata WiFi / BT module LBEE5ZSTNC-523, with a customized and connected in MMC3 board.
But this not working. I followed all the tutorial:
a)processors.wiki.ti.com/.../WL18xx_Platform_Integration_Guide
b) processors.wiki.ti.com/.../SD_Driver's_Guide
My settings are:
For Device Tree:
48 wlan_en_reg: fixedregulator@2 {
49 compatible = "regulator-fixed";
50 regulator-name = "wlan-en-regulator";
51 regulator-min-microvolt = <1800000>;
52 regulator-max-microvolt = <1800000>;
53
54 /* WLAN_EN GPIO for this board - Bank1, pin29 */
55 gpio = <&gpio1 29 0>;
56
57 /* WLAN card specific delay */
58 startup-delay-us = <70000>;
59 enable-active-high;
60 vin-supply = <&vbat>;
61 };
171 wlcore_sdio {
172 compatible = "wlcore";
173 gpio = <&gpio0>; /* Bank0, pin31 */
174 irq = <31>;
175
176 /*
177 * TODO: use edge irqs for suspend/resume.
178 * in newer kerenls, we seem to miss interrupts when
179 * working with edge irqs, so revert back to level irqs.
180 /
181 /* platform-quirks = <1>; /
182
183 /* if a 12xx card is there, configure the clock to
184 WL12XX_REFCLOCK_38_XTAL /
185 /*board-ref-clock = <4>;*/
186 board-tcxo-clock = <5>;
187 };
171 wlcore_sdio {
174 irq = <31>;
175
176 /*
180 /
182
187 };
442 /* wl12xx/wl18xx card enable/irq GPIOs. */
443 wlan_pins_default: pinmux_wlan_pins_default {
444 pinctrl-single,pins = <
445 0x7C 0x07 /*(PIN_OUTPUT_PULLUP | MUX_MODE7) /* gpmc_csn0.gpio1_29 */
446 0x74 0x27 /* (PIN_INPUT_PULLUP | MUX_MODE7) /* gpmc_wpn.gpio0_31 */
447 0x1AC 0x17 /* mcasp0_ahclkx.gpio3_21, OUTPUT_PULLUP | MODE7 */
448 >;
449 };
706 &mmc3 {
707 /* these are on the crossbar and are outlined in the
708 xbar-event-map element */
709 dmas = <&edma 12
710 &edma 13>;
711 dma-names = "tx", "rx";
712 status = "okay";
713 vmmc-supply = <&wlan_en_reg>;
714 bus-width = <4>;
715 pinctrl-names = "default";
716 pinctrl-0 = <&mmc3_pins_default &wlan_pins_default>;
717 ti,non-removable;
718 ti,needs-special-hs-handling;
719 cap-power-off-card;
720 keep-power-in-suspend;
721
722 #address-cells = <1>;
723 #size-cells = <0>;
724 };
725
726 &edma {
727 ti,edma-xbar-event-map = /bits/ 16 <1 12
728 2 13>;
729 };
When I check the mmc status with dmesg I get this:
# dmesg | grep mmc
[ 1.518765] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/mmc@47810000[0]'
[ 1.518788] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/mmc@47810000[0]'
[ 1.519026] omap_hsmmc 47810000.mmc: context is restored: restore count 1
[ 1.519043] omap_hsmmc 47810000.mmc: enabled
[ 1.520086] mmc0: clock 0Hz busmode 2 powermode 1 cs 0 Vdd 7 width 0 timing 0
[ 1.612189] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 0 timing 0
[ 1.632535] mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 1.639507] mmc0: starting CMD52 arg 00000c00 flags 00000195
[ 1.639905] mmc0: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 1.640011] mmc0: clock 0Hz busmode 2 powermode 2 cs 0 Vdd 7 width 0 timing 0
[ 1.640026] mmc0: gated MCI clock
[ 1.640842] mmc0: starting CMD52 arg 80000c08 flags 00000195
[ 1.640866] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 0 timing 0
[ 1.640889] mmc0: ungated MCI clock
[ 1.641267] mmc0: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 1.641438] mmc0: clock 0Hz busmode 2 powermode 2 cs 0 Vdd 7 width 0 timing 0
[ 1.641452] mmc0: gated MCI clock
[ 1.641544] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 0 timing 0
[ 1.641563] mmc0: ungated MCI clock
[ 1.641576] mmc0: clock 400000Hz busmode 2 powermode 2 cs 1 Vdd 7 width 0 timing 0
[ 1.641629] mmc0: clock 0Hz busmode 2 powermode 2 cs 1 Vdd 7 width 0 timing 0
[ 1.641640] mmc0: gated MCI clock
[ 1.642736] mmc0: starting CMD0 arg 00000000 flags 000000c0
[ 1.642752] mmc0: clock 400000Hz busmode 2 powermode 2 cs 1 Vdd 7 width 0 timing 0
[ 1.642768] mmc0: ungated MCI clock
[ 1.642939] mmc0: req done (CMD0): 0: 00000000 00000000 00000000 00000000
[ 1.643220] mmc0: clock 0Hz busmode 2 powermode 2 cs 1 Vdd 7 width 0 timing 0
[ 1.643234] mmc0: gated MCI clock
[ 1.644319] mmc0: clock 400000Hz busmode 2 powermode 2 cs 1 Vdd 7 width 0 timing 0
[ 1.644338] mmc0: ungated MCI clock
[ 1.644351] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 0 timing 0
[ 1.644405] mmc0: clock 0Hz busmode 2 powermode 2 cs 0 Vdd 7 width 0 timing 0
[ 1.644416] mmc0: gated MCI clock
[ 1.645433] mmc0: starting CMD8 arg 000000aa flags 000002f5
[ 1.645448] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 0 timing 0
[ 1.645462] mmc0: ungated MCI clock
[ 1.645840] mmc0: req done (CMD8): -110: 00000000 00000000 00000000 00000000
[ 1.646074] mmc0: starting CMD5 arg 00000000 flags 000002e1
[ 1.646505] mmc0: req failed (CMD5): -110, retrying...
[ 1.646904] mmc0: req failed (CMD5): -110, retrying...
[ 1.653398] mmc0: req failed (CMD5): -110, retrying...
[ 1.653777] mmc0: req done (CMD5): -110: 00000000 00000000 00000000 00000000
[ 1.653839] mmc0: starting CMD55 arg 00000000 flags 000000f5
[ 1.660135] mmc0: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.660223] mmc0: starting CMD55 arg 00000000 flags 000000f5
[ 1.660610] mmc0: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.660678] mmc0: starting CMD55 arg 00000000 flags 000000f5
[ 1.661060] mmc0: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.661134] mmc0: starting CMD55 arg 00000000 flags 000000f5
[ 1.661520] mmc0: req done (CMD55): -110: 00000000 00000000 00000000 00000000
[ 1.661741] mmc0: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 7 width 0 timing 0
[ 1.661774] mmc0: starting CMD1 arg 00000000 flags 000000e1
[ 1.662156] mmc0: req done (CMD1): -110: 00000000 00000000 00000000 00000000
[ 1.668835] mmc0: clock 0Hz busmode 1 powermode 0 cs 0 Vdd 0 width 0 timing 0
[ 1.669904] mmc0: frequency set to 0 in disable function, this means the clock is already disabled.
[ 1.765004] omap_hsmmc 47810000.mmc: disabled
[ 1.906936] vmmc: 1800 <--> 3300 mV at 3300 mV
[ 1.911804] vmmc: supplied by vbat
When inserting the modules:
# modprobe wlcore_sdio
# modprobe wl12xx
[ 904.237000] cfg80211: Calling CRDA to update world regulatory domain
# lsmod
Module Size Used by Not tainted
wl12xx 48468 0
wlcore 148365 1 wl12xx
mac80211 242111 2 wl12xx,wlcore
cfg80211 155930 2 wlcore,mac80211
wlcore_sdio 3404 0
musb_dsps 6460 0
musb_hdrc 50243 1 musb_dsps
snd_soc_evm 5066 0
snd_soc_davinci_mcasp 11865 0
snd_soc_omap 2040 1 snd_soc_davinci_mcasp
snd_pcm_dmaengine 2718 1 snd_soc_omap
musb_am335x 988 0 [permanent]
snd_soc_tlv320aic3x 30759 0
snd_soc_core 101438 4 snd_soc_evm,snd_soc_davinci_mcasp,snd_soc_omap,snd_soc_tlv320aic3x
snd_compress 6764 1 snd_soc_core
regmap_spi 1329 1 snd_soc_core
snd_pcm 66770 5 snd_soc_evm,snd_soc_davinci_mcasp,snd_soc_omap,snd_pcm_dmaengine,snd_soc_core
snd_timer 15794 1 snd_pcm
snd 42728 4 snd_soc_core,snd_compress,snd_pcm,snd_timer
soundcore 4225 1 snd
tilcdc 23963 0
drm_kms_helper 27968 2 tilcdc
drm 190204 3 tilcdc,drm_kms_helper
But nothing interface wlan0:
# ifup wlan0 up
ip: SIOCGIFFLAGS: No such device
Could someone give me a hint? The problem in this MMC3 or some other configuration?
Fabio MN
