Other Parts Discussed in Thread: CCSTUDIO
I am hoping that this is a right forum - I have a problem with properly configuring a project.
I am running CCS 3.38.2, CGT v.6.0.8, BIOS 5.31.08 for 6437.
We are converting from xdm 0.9 to xdm 1.x and this required few modifications in the project setup.
I have had the project running correctly, but after few changes things went out of synch resuling in configuration errors.
To simplify the problems of switching I have setup a bat file to configure all environmental variables. I ahave also configured the xdcpaths_evmDM6437.dat to reflect changes.
My demo project (standard dm6437_demo.pjt (that comes with eval board) used to work. After changes something went off (probably a typo or miss-configuration). Here is a problem printout which I attribute to Configuro unable finding a file of interest.
[dm6437_demo.cfg] "C:\Program Files\Texas Instruments\xdctools_3_16_02_32\xs.exe" xdc.tools.configuro.ccs --xdcpathsfile="xdcpaths.dat" -tti.targets.C64P -pti.platforms.evmDM6437 -rdebug --tcf -Dconfig.importPath=".;../;../examples/common/evmDM6437" -c "C:/CCStudio_v3.3/C6000/cgtools" --xp "C:/CCStudio_v3.3/bios_5_31_08//packages" -o "xdcconfig" dm6437_demo.cfg
js: "C:/dvsdk_1_11_00_00/xdc_2_95_02/packages/xdc/xdc.tci", line 540: TypeError: Cannot read property "current" from undefined
Any recommendation where can I search for the offending line/variable etc ?
Ja
here are addional info about environmental variables and revs of major modules::
ECHO **********************************
set ENV_VARIABLE=BIOS_INSTALL_DIR
set ENV_VAR_VALUE="C:\CCStudio_v3.3\bios_5_31_08"
setx %ENV_VARIABLE% %ENV_VAR_VALUE% -m
echo %ENV_VARIABLE% = %ENV_VAR_VALUE%
set ENV_VARIABLE=BIOSUTILS_INSTALL_DIR
set ENV_VAR_VALUE="D:\dvsdk_1_11_00_00_refer\biosutils_1_00_02"
set ENV_VARIABLE=BSL_EVMDM6437_INSTALLDIR
set ENV_VAR_VALUE="C:\CCStudio_v3.3\boards\evmdm6437_v2"
set ENV_VARIABLE=CE_INSTALL_DIR
set ENV_VAR_VALUE="D:\dvdsdk_1_11_00_00_refer\codec_engine_1_20_02"
set ENV_VARIABLE=PSP_INCLUDE_SOC_PATH
set ENV_VAR_VALUE=DM6437
set ENV_VARIABLE=PSP_INSTALL_DIR
set ENV_VAR_VALUE="D:\dvsdk_1_11_00_00_refer\pspdrivers_1_10_00\packages"
set ENV_VARIABLE=XDCROOT
set ENV_VAR_VALUE="%BIOSDVSDK_INSTALL_DIR%\xdc_2_95_02"
set ENV_VARIABLE=XDCPATH
set ENV_VAR_VALUE="%BIOSDVSDK_INSTALL_DIR%\xdc_2_95_02;%BIOSDVSDK_INSTALL_DIR%\xdc_2_95_02\packages"
