PCIe pciboot_interrupt example gives wrong results within cycle
Hello all,
I have modified project "pciboot_interrupt" from
mcsdk_2_01_02_06\tools\boot_loader\examples\pcie\
to run DMA-writing and DMA-reading whithin the cycle.
I was surprised because of after the command "sudo insmod pciedemo.ko"
program put out the messages "DMA test failed with 4 locations !"
in some of cycles (about half of all).
The wrong data was always the same:
rDaraVirt[576]=0x00
rDaraVirt[577]=0x00
rDaraVirt[578]=0x00
rDaraVirt[579]=0x00
Please answer the question:
what necessary to do in this example to avoid wrong results within the cycle?
I have made corrections in the original code of the pcidemo.c only:
- Row 1580.
Operator was appended with the "return 0" because of compilator's warning:
"ignoring return value of ‘pci_enable_device’, declared with attribute warn_unused_result [-Wunused-result]"
- Row 1604.
"ignoring return value of ‘request_irq’, declared with attribute warn_unused_result [-Wunused-result]"
- Row 1621.
Cycle "while" was appended with the Time out control, because of OS hung when cycle works too long time.
- Row 1742.
Functions mdelay(10000) and dspLocalReset() was commented.
(I made it because of programm often hung here)
Fuction dspLocalReset() was transfered into function cleanup_module()
- Row 1707.
Code was appended with the cycle "for"
(Rem. Q-ty of the cycles more than 22 brings the error from OS:
"BUG: soft lockup - CPU#1 stuck for 22s!"
As I think it is because of pcidemo process do not returns resources to the others too long time)
Modified pcidemo.c are attached.
I used:
Code Composer Studio 5.2.1.00018
mcsdk_2_01_02_06
MDSEVM6678L/MDXEVMPCI board
OS - Debian7, Ubuntu10.04
 * Copyright (c) 2011 Texas Instruments Incorporated - http://www.ti.com
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License as
 * published by the Free Software Foundation version 2.
 * This program is distributed "as is" WITHOUT ANY WARRANTY of any
 * kind, whether express or implied; without even the implied warranty
 * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * FILE NAME: pciedemo.c
 * DESCRIPTION: A sample code to load DSP boot image from a Linux machine into DSP.
 * Revision History:
 *    - 1.0:  Initial version (6678 little endian PCIE boot POST demo)
 *    - 1.1:  Add a new PCIE boot demo for HelloWorld
 *    - 1.2:  support 6670 boot
 *    - 1.3:  support big endian boot for 6670/6678; support 32-bit/64-bit Linux;
 *            support EDMA; support interrupt between host and DSP;
 *            added PCIE over EDMA throughput measurement
 *    - 1.4:  Add a DSP local reset demo; fix pushData() to handle cases when
 *            sections within different memory regions in a header file
 *    - 1.5:  Support 6657 boot
#include <linux/module.h>
#include <linux/types.h>
#include <linux/kernel.h>
#include <linux/pci.h>
#include <linux/delay.h>
#include <linux/fs.h>
#include <linux/init.h>
#include <linux/ioport.h>
#include <linux/interrupt.h>
#include <asm/uaccess.h>
#include <asm/dma-mapping.h>
#include <linux/time.h>
MODULE_LICENSE("GPL v2");
/* Must select the endianess */
#define BIG_ENDIAN          0
/* Must select which demo to run */
#define HELLO_WORLD_DEMO    0
#define POST_DEMO           0
#define EDMA_INTC_DEMO      1
#define LOCAL_RESET         1
/* Must select a platform */
#define EVMC6678L           1
#define EVMC6670L           0
#define EVMC6657L           0
#if BIG_ENDIAN
#define myIoread32  ioread32be
#define myIowrite32 iowrite32be
#else
#endif
#if EVMC6678L
#define MAGIC_ADDR          0x0087FFFC
#endif
#if EVMC6670L
#define MAGIC_ADDR          0x008FFFFC
#endif
#if EVMC6657L
#endif
/* Include header array */
#if HELLO_WORLD_DEMO
#if EVMC6678L
#include "pcieDdrInit_6678.h"     /* DDR init */
#include "pcieBootCode_6678.h"    /* "Hello world" boot example */
#endif
#if EVMC6670L
#include "pcieDdrInit_6670.h"     /* DDR init */
#include "pcieBootCode_6670.h"    /* "Hello world" boot example */
#endif
#if EVMC6657L
#include "pcieDdrInit_6657.h"     /* DDR init */
#include "pcieBootCode_6657.h"    /* "Hello world" boot example */
#endif
#endif
#if POST_DEMO
#if EVMC6678L
#include "post_6678.h"            /* POST boot example */
#endif
#if EVMC6670L
#include "post_6670.h"            /* POST boot example */
#endif
#if EVMC6657L
#include "post_6657.h"            /* POST boot example */
#endif
#endif
#if EDMA_INTC_DEMO
#if EVMC6678L
#include "pcieInterrupt_6678.h"   /* EDMA-Interrupt boot example */
#endif
#if EVMC6670L
#include "pcieInterrupt_6670.h"   /* EDMA-Interrupt boot example */
#endif
#endif
#if LOCAL_RESET
#if EVMC6678L
#include "pcieLocalReset_6678.h"
#endif
#if EVMC6670L
#include "pcieLocalReset_6670.h"
#endif
#endif
/* PCIE registers */
#define PCIE_BASE_ADDRESS            0x21800000
#define OB_SIZE                      0x30
#define PRIORITY                     0x3C
#define EP_IRQ_CLR                   0x68
#define EP_IRQ_STATUS                0x6C
#define LEGACY_A_IRQ_STATUS_RAW      0x180
#define LEGACY_A_IRQ_ENABLE_SET      0x188
#define LEGACY_A_IRQ_ENABLE_CLR      0x18C
#define OB_OFFSET_INDEX(n)           (0x200 + (8 * (n)))
#define OB_OFFSET_HI(n)              (0x204 + (8 * (n)))
#define IB_BAR(n)                    (0x300 + (0x10 * (n)))
#define IB_START_LO(n)               (0x304 + (0x10 * (n)))
#define IB_START_HI(n)               (0x308 + (0x10 * (n)))
#define IB_OFFSET(n)                 (0x30C + (0x10 * (n)))
#define PCIE_TI_VENDOR               0x104C
#define PCIE_TI_DEVICE               0xB005
/* PSC registers */
#define PSC_BASE_ADDRESS             0x02350000
#define PTCMD                        0x120
#define PTSTAT                       0x128
#define PDSTAT(n)                    (0x200 + (4 * (n)))
#define PDCTL(n)                     (0x300 + (4 * (n)))
#define MDSTAT(n)                    (0x800 + (4 * (n)))
#define MDCTL(n)                     (0xA00 + (4 * (n)))
/* EDMA registers */
#define EDMA_TPCC0_BASE_ADDRESS      0x02700000
#define DMAQNUM0                     0x0240
#define ESR                          0x1010
#define EESR                         0x1030
#define IESR                         0x1060
#define IPR                          0x1068
#define ICR                          0x1070
#define PARAM_0_OPT                  0x4000
#define PARAM_0_SRC                  0x4004
#define PARAM_0_A_B_CNT              0x4008
#define PARAM_0_DST                  0x400C
#define PARAM_0_SRC_DST_BIDX         0x4010
#define PARAM_0_LINK_BCNTRLD         0x4014
#define PARAM_0_SRC_DST_CIDX         0x4018
#define PARAM_0_CCNT                 0x401C
/* Chip level registers */
#define CHIP_LEVEL_BASE_ADDRESS      0x02620000
#define KICK0                        0x38
#define KICK1                        0x3C
#define KICK0_UNLOCK                 0x83E70B13
#define KICK1_UNLOCK                 0x95A4F1E0
#define KICK_LOCK                    0x0
#define DSP_BOOT_ADDR(n)             (0x040 + (4 * (n)))
#define IPCGR(n)                     (0x240 + (4 * (n)))
#define LL2_START                    0x00800000
#define MSMC_START                   0x0C000000  /* Shared L2 */
#define DDR_START                    0x80000000
#define PCIE_DATA                    0x60000000
/* Block size in bytes when r/w data between GPP and DSP via DSP CPU */
#define BLOCK_TRANSFER_SIZE          0x100
/* Data size in bytes when r/w data bewteen GPP and DSP via EDMA:
   GPP----PCIE link----PCIE data space----EDMA----DSP device memory (L2, DDR, ...) */
#define DMA_TRANSFER_SIZE            0x400000   /* 4MB */
/* Payload size in bytes over PCIE link. PCIe module supports
   outbound payload size of 128 bytes and inbound payload size of 256 bytes */
#define PCIE_TRANSFER_SIZE           0x80
/* For 1MB outbound translation window size */
#define PCIE_ADLEN_1MB               0x00100000
#define PCIE_1MB_BITMASK             0xFFF00000
#define PSC_SWRSTDISABLE             0x0
#define PSC_ENABLE                   0x3
#define LOC_RST_ASSERT               0x0
#define LOC_RST_DEASSERT             0x1
/* Power domains definitions */
#define PD0         0     // Power Domain-0
#define PD1         1     // Power Domain-1
#define PD2         2     // Power Domain-2
#define PD3         3     // Power Domain-3
#define PD4         4     // Power Domain-4
#define PD5         5     // Power Domain-5
#define PD6         6     // Power Domain-6
#define PD7         7     // Power Domain-7
#define PD8         8     // Power Domain-8
#define PD9         9     // Power Domain-9
#define PD10        10    // Power Domain-10
#define PD11        11    // Power Domain-11
#define PD12        12    // Power Domain-12
#define PD13        13    // Power Domain-13
#define PD14        14    // Power Domain-14
#define PD15        15    // Power Domain-15
#define PD16        16    // Power Domain-16
#define PD17        17    // Power Domain-17
#if EVMC6670L
/* Modules on power domain 0 */
#define LPSC_TCP3E     3
#define LPSC_VCP2A     4
/* Modules on power domain 1 */
#define LPSC_DEBUG     5
#define LPSC_TETB      6
/* Modules on power domain 2 */
#define LPSC_PA        7
#define LPSC_SGMII     8
#define LPSC_SA        9
/* Modules on power domain 3 */
#define LPSC_PCIE      10
/* Modules on power domain 4 */
#define LPSC_SRIO      11
/* Modules on power domain 5 */
#define LPSC_HYPER     12
/* Modules on power domain 6 */
#define LPSC_RESERV    13
/* Modules on power domain 7 */
#define LPSC_MSMCRAM   14
/* Modules on power domain 8 */
#define LPSC_RACA_RACB 15
#define LPSC_TAC       16
/* Modules on power domain 9 */
#define LPSC_FFTCA_FFTCB 17
/* Modules on power domain 10 */
#define LPSC_AIF2      18
/* Modules on power domain 11 */
#define LPSC_TCP3DA    19
/* Modules on power domain 12 */
#define LPSC_VCP2B     20
#define LPSC_VCP2C     21
#define LPSC_VCP2D     22
/* Modules on power domain 13 */
#define LPSC_C0_TIM0   23
/* Modules on power domain 14 */
#define LPSC_C1_TIM1   24
#define LPSC_C1_RSA    25
/* Modules on power domain 15 */
#define LPSC_C2_TIM2   26
#define LPSC_C2_RSA    27
/* Modules on power domain 16 */
#define LPSC_C3_TIM3   28
/* Modules on power domain 17 */
#define LPSC_TCP3dB    29
#endif
#if EVMC6678L
#define LPSC_EMIF16_SPI  3
#define LPSC_TSIP        4
#define LPSC_TETB_TRC    6
#define LPSC_PA          7
#define LPSC_SA          9
#define LPSC_C0_TIM0     15
#define LPSC_C1_TIM1     16
#define LPSC_C2_TIM2     17
#define LPSC_C3_TIM3     18
#define LPSC_C4_TIM4     19
#define LPSC_C5_TIM5     20
#define LPSC_C6_TIM6     21
#define LPSC_C7_TIM7     22
#endif
reg:  PCIE application registers
mem:  Local L2
msmc: Shared L2 memory
ddr:  DDR3
uint8_t *wDataVirt, *rDataVirt;          /* Virtue address for CPU */
dma_addr_t wData, rData;                 /* Physical PCIE bus address */
 * uncomment following line on very old kernels:
 * typedef unsigned long resource_size_t;
resource_size_t regBase = 0;
resource_size_t memBase = 0;
resource_size_t msmcBase = 0;
resource_size_t ddrBase = 0;
uint32_t *regVirt = NULL;
uint32_t *memVirt = NULL;
uint32_t *msmcVirt = NULL;
uint32_t *ddrVirt = NULL;
resource_size_t memLen = 0;
resource_size_t regLen = 0;
resource_size_t msmcLen = 0;
resource_size_t ddrLen = 0;
uint32_t *ptrReg = 0;
int32_t  irqNo;
uint32_t dummy;
struct pci_dev *PCIE_DEV = NULL;
struct timeval test_time1;
struct timeval test_time2;
struct timeval test_time3;
struct timeval test_time4;
 *  @func   PCI_FindPciDevices
 *  @desc   This function locates 6670/6678 PCIE cards on system.
 *  @modif  None.
void PCI_FindPciDevices(void)
	struct pci_dev *dev = NULL;
	while ((dev = pci_get_device(PCI_ANY_ID, PCI_ANY_ID, dev)) != NULL)
		if ((dev->vendor == PCIE_TI_VENDOR) && (dev->device == PCIE_TI_DEVICE)) {
			printk("Found TI device\n");
			irqNo = dev->irq;
			PCIE_DEV = dev;
			printk("TI device: vendor=0x%04x, dev=0x%04x, irq=0x%08x\n", dev->vendor, dev->device, dev->irq);
			break;
 *  @func   PCI_readBAR
 *  @desc   This function reads config.
 *  @modif  None.
void PCI_readBAR(void)
	resource_size_t  barStart[4];
	resource_size_t  barLen[4];
	resource_size_t  barFlags[4];
	barStart [0] = pci_resource_start (PCIE_DEV, 0);   /* BAR0 4K for PCIE application registers */
	barLen   [0] = pci_resource_len   (PCIE_DEV, 0);
	barFlags [0] = pci_resource_flags (PCIE_DEV, 0);
	barStart [1] = pci_resource_start (PCIE_DEV, 1);   /* BAR1 512K/1024K for 6678/6670 Local L2 */
	barLen   [1] = pci_resource_len   (PCIE_DEV, 1);
	barFlags [1] = pci_resource_flags (PCIE_DEV, 1);
	barStart [2] = pci_resource_start (PCIE_DEV, 2);   /* BAR2 4M/2M for 6678/6670 Shared L2 */
	barLen   [2] = pci_resource_len   (PCIE_DEV, 2);
	barFlags [2] = pci_resource_flags (PCIE_DEV, 2);
	barStart [3] = pci_resource_start (PCIE_DEV, 3);   /* BAR3 16M for DDR3 */
	barLen   [3] = pci_resource_len   (PCIE_DEV, 3);
	barFlags [3] = pci_resource_flags (PCIE_DEV, 3);
	 * Map the REG memory region
	if (barFlags[0] & IORESOURCE_MEM) {
		regBase = barStart[0];
		/* Map the memory region. */
		request_mem_region(regBase, barLen[0], "DSPLINK");
	else {
		request_region(regBase, barLen[0], "DSPLINK");
	if (regBase > 0) {
		regVirt = ioremap(barStart[0], barLen[0]);
	 * Map the LL2RAM memory region
	if (barFlags[1] & IORESOURCE_MEM) {
		memBase = barStart[1];
		request_mem_region(memBase, barLen[1], "DSPLINK");
	else {
		request_region(memBase, barLen[1], "DSPLINK");
	if (memBase > 0) {
		memVirt = ioremap(barStart[1], barLen[1]);
	 * Map the MSMC memory region
	if (barFlags[2] & IORESOURCE_MEM) {
		msmcBase = barStart[2];
		request_mem_region(msmcBase, barLen[2], "DSPLINK");
	else {
		request_region(msmcBase, barLen[2], "DSPLINK");
	if (msmcBase > 0) {
		msmcVirt = ioremap(barStart[2], barLen[2]);
	 * Map the DDR memory region
	if (barFlags[3] & IORESOURCE_MEM) {
		ddrBase = barStart[3];
		request_mem_region(ddrBase, barLen[3], "DSPLINK");
	else {
		request_region(ddrBase, barLen[3], "DSPLINK");
	if (ddrBase > 0) {
		ddrVirt = ioremap(barStart[3], barLen[3]);
	regLen  = barLen[0];
	memLen  = barLen[1];
	msmcLen = barLen[2];
	ddrLen  = barLen[3];
 *  @func   PCI_setMaster
 *  @desc   This function makes the given device to be master.
 *  @modif  None.
void PCI_setMaster(void)
	int32_t  retVal;
	uint16_t cmdVal;
	struct pci_dev *dev;
	dev = PCIE_DEV;
	/* set the DMA mask */
	if (pci_set_dma_mask(dev, 0xfffffff0ULL)) {
	/* set the desired PCI dev to be master, this internally sets the latency timer */
	pci_set_master(dev);
	pci_write_config_byte(dev, PCI_LATENCY_TIMER, 0x80);
	/* Add support memory write invalidate */
	retVal = pci_set_mwi(dev);
	pci_read_config_word(dev, PCI_COMMAND, (u16 *)&cmdVal);
	/* and set the master bit in command register. */
	cmdVal |= PCI_COMMAND_MEMORY
		| PCI_COMMAND_MASTER
		| PCI_COMMAND_SERR;
	/* and clear the interrupt disable bit in command register. */
	cmdVal &= ~PCI_COMMAND_INTX_DISABLE;
	pci_write_config_word(dev, PCI_COMMAND, cmdVal);
 *  @func   HAL_CheckPciInterrupt
 *  @desc   This function check whether interrupt is generated by C667x or not.
 *  @modif  None.
bool HAL_CheckPciInterrupt(void)
	uint32_t *pReg = (uint32_t *)regVirt;
	return ioread32(pReg + EP_IRQ_STATUS/4);
 *  @func   HAL_PciClearDspInterrupt
 *  @desc   Clear pending interrupt from DSP to Host.
 *  @modif  None.
void HAL_PciClearDspInterrupt(void)
	iowrite32(1, pReg+EP_IRQ_CLR/4);
 *  @func   HAL_PciEnableDspInterrupt
 *  @desc   Allow the DSP to generate interrupts to the Host.
 *  @modif  None.
void HAL_PciEnableDspInterrupt(void)
	iowrite32(1, pReg+LEGACY_A_IRQ_ENABLE_SET/4);
 *  @func   HAL_PciDisableDspInterrupt
 *  @desc   Disable the DSP to generate interrupts to the Host.
 *  @modif  None.
void HAL_PciDisableDspInterrupt(void)
	iowrite32(1, pReg+LEGACY_A_IRQ_ENABLE_CLR/4);
 *  @func   HAL_readDMA
 *  @desc   Move DMAs contents from DSP memory to GPP Memory. For DSP this is
 *          outbound write.
 *  flag:   0: Move data inside DSP; 1: Move data between GPP and DSP
 *  @modif  None.
void HAL_readDMA(uint32_t srcAddr, uint32_t dstAddr, uint32_t size, uint32_t flag)
	uint32_t *pReg, tmp, pageBase, i, tSize;
	pReg = (uint32_t *)regVirt;     /* Point to PCIE application registers */
	/* Move data between GPP and DSP, need to program PCIE OB registers */
	if (flag) {
		iowrite32(0x0, pReg + OB_SIZE/4); /* 1MB outbound translation size */
		if (size <= PCIE_ADLEN_1MB) {
			pageBase = dstAddr & PCIE_1MB_BITMASK;
			iowrite32(pageBase|0x1, pReg + OB_OFFSET_INDEX(0)/4);
			iowrite32(0x0, pReg + OB_OFFSET_HI(0)/4);
		else {
			for (tmp = size, i = 0; tmp > 0; tmp -= PCIE_ADLEN_1MB, i++) {
				pageBase = (dstAddr + (PCIE_ADLEN_1MB * i)) & PCIE_1MB_BITMASK;
				iowrite32(pageBase|0x1, pReg + OB_OFFSET_INDEX(i)/4);
				iowrite32(0x0, pReg + OB_OFFSET_HI(i)/4);
	/* Temporarily re-map IB region 3 from DDR memory to EDMA registers */
	iowrite32(EDMA_TPCC0_BASE_ADDRESS, pReg + IB_OFFSET(3)/4);
	pReg = (uint32_t*)ddrVirt;   /* Now it points to the start of EDMA_TPCC0_BASE_ADDRESS */
	while (true) {
		/* Use TC0 for DBS = 128 bytes */
		myIowrite32(0x0, pReg + DMAQNUM0/4);
		/* Set the interrupt enable for 1st Channel (IER). */
		myIowrite32(0x1, pReg + IESR/4);
		/* Clear any pending interrupt (IPR). */
		myIowrite32(0x1, pReg + ICR/4);
		/* Populate the Param entry. */
		myIowrite32(0x00100004, pReg + PARAM_0_OPT/4);    /* Enable SYNCDIM and TCINTEN, TCC = 0 */
		if (flag == 1) {
			/* Calculate the DSP PCI address for the PC address */
			tmp = PCIE_DATA + (dstAddr & ~PCIE_1MB_BITMASK);
			myIowrite32(tmp, pReg + PARAM_0_DST/4);
		} else {
			myIowrite32(dstAddr, pReg + PARAM_0_DST/4);
		/* Calculate the A & B count */
		if (size > PCIE_TRANSFER_SIZE)  {
			tmp = size/PCIE_TRANSFER_SIZE;
			tSize = tmp*PCIE_TRANSFER_SIZE;
			size -= (tmp*PCIE_TRANSFER_SIZE);
			tmp <<= 16;
			tmp |= PCIE_TRANSFER_SIZE;
		else {
			tmp = 0x10000|size;
			tSize = size;
			size = 0;
		myIowrite32(tmp, pReg + PARAM_0_A_B_CNT/4);
		myIowrite32(srcAddr, pReg + PARAM_0_SRC/4);
		myIowrite32(((PCIE_TRANSFER_SIZE<<16)|PCIE_TRANSFER_SIZE), pReg + PARAM_0_SRC_DST_BIDX/4);
		myIowrite32(0xFFFF, pReg + PARAM_0_LINK_BCNTRLD/4);
		myIowrite32(0x0, pReg + PARAM_0_SRC_DST_CIDX/4);
		/* C Count is set to 1 since mostly size will not be more than 1.75GB */
		myIowrite32(0x1, pReg + PARAM_0_CCNT/4);
		/* Set the Event Enable Set Register. */
		myIowrite32(0x1, pReg + EESR/4);
		/* Set the event set register. */
		myIowrite32(0x1, pReg + ESR/4);
		/* wait for current DMA to finish. */
		while (true) {
			/* check in steps of 10 usec. */
			udelay(10);
			tmp = myIoread32(pReg + IPR/4);
			if ((tmp & 0x1) == 1) {
				break;
		if (size != 0) {
			srcAddr += tSize;
			dstAddr += tSize;
		} else {
			break;
	/* Clear any pending interrupt. */
	myIowrite32(1, pReg + ICR/4);
	/* Restore pointer */
	iowrite32(DDR_START, pReg + IB_OFFSET(3)/4);
 *  @func   HAL_writeDMA
 *  @desc   Move DMAs contents from GPP memory to DSP Memory. For DSP this is
 *          outbound read.
 *  @modif  None.
void HAL_writeDMA(uint32_t srcAddr, uint32_t dstAddr, uint32_t size, uint32_t flag)
	if (flag) {
			pageBase = srcAddr & PCIE_1MB_BITMASK;
		else {
				pageBase = (srcAddr + (PCIE_ADLEN_1MB * i)) & PCIE_1MB_BITMASK;
	while (true) {
		if (flag == 1) {
			tmp = PCIE_DATA + (srcAddr & ~PCIE_1MB_BITMASK);
			myIowrite32(tmp, pReg + PARAM_0_SRC/4);
		} else {
			tmp <<= 16;
		else {
			tmp = 0x10000|size;
			tSize = size;
			size = 0;
		while (true) {
			udelay(10);
				break;
		if (size != 0) {
			srcAddr += tSize;
			dstAddr += tSize;
		} else {
			break;
	pReg = (uint32_t *)regVirt;     //Point to PCIE application registers
 *  @func   ISR_handler
 *  @desc   ISR.
 *  @modif  None.
static irqreturn_t ISR_handler(int irq, void *arg)
	uint32_t i, dma_failure_flag = 0, counter = 0;
	uint32_t status = HAL_CheckPciInterrupt();
	if (status == 1) {
		printk("Interrupt %d received from DSP\n", irq);
		printk("Read DMA from DSP ...\n");
		do_gettimeofday(&test_time3);
		HAL_readDMA(DDR_START, rData, DMA_TRANSFER_SIZE, 1);     /* Move from DSP to GPP */
		do_gettimeofday(&test_time4);
		for (i = 0; i < DMA_TRANSFER_SIZE; i++) {
			if ((~(rDataVirt[i])&0xFF) != wDataVirt[i]) {
				dma_failure_flag = 1;
				counter++;
printk("rDataVirt[%d]=0x%02x  \n", i,rDataVirt[i]);
		if (dma_failure_flag)
			printk("DMA test failed with %d locations !!!!!!!!!!!!!!!!!!!!\n", counter);
		else
			printk("DMA test passed!\n");
		HAL_PciClearDspInterrupt();
		return IRQ_HANDLED;
	return IRQ_NONE;
 *  @func   byteto32bits
 *  @desc   Convert 4 bytes to 32 bits long word
 *  @modif  None.
uint32_t byteTo32bits(uint8_t *pDspCode)
	uint32_t i, temp;
	temp = *pDspCode++;
	for(i = 0; i < 3;i++) {
		temp <<= 8;
		temp |= *pDspCode++;
	return(temp);
 *  @func   swap4bytes
 *  @desc   Endian swap: 0xA0B1C2D3 to 0xD3C2B1A0
 *  @modif  None.
void swap4bytes(uint32_t *pDspCode, uint32_t size)
	uint32_t i, temp;
	for(i = 0; i < size; i += 4, pDspCode++) {
		temp = *pDspCode;
		temp = (temp>>24) |
			((temp<<8) & 0x00FF0000) |
			((temp>>8) & 0x0000FF00) |
			(temp<<24);
		*pDspCode = temp;
 *  @func   writeDSPMemory
 *  @desc   Write a block of data into DSP memory from Linux host.
 *          Note the data buffer is in 32-bit format, unit of length is byte.
 *          coreNum: to write data: 0-7 for cores 0-7; 8 for MSMC; 9 for DDR.
 *  @modif  None.
uint32_t writeDSPMemory(uint32_t coreNum, uint32_t DSPMemAddr, uint32_t *buffer, uint32_t length)
	uint32_t i, offset, tempReg = 0;
	uint32_t *ptr;
	if (length == 0) {
		return 0;
	switch (coreNum) {
#if EVMC6678L
		case 0:
		case 1:
		case 2:
		case 3:
		case 4:
		case 5:
		case 6:
		case 7:
#endif
#if EVMC6670L
		case 0:
		case 1:
		case 2:
		case 3:
#endif
#if EVMC6657L
		case 0:
		case 1:
#endif
			DSPMemAddr &= 0x00FFFFFF;
			tempReg = ioread32(ptrReg + IB_OFFSET(1)/4);
			iowrite32(tempReg + coreNum*0x01000000, ptrReg + IB_OFFSET(1)/4); /* pointing to a different core */
			if (DSPMemAddr < LL2_START) {
				return 0;
			} else {
				offset = DSPMemAddr - LL2_START;
				ptr = (uint32_t *)memVirt + offset/4;
			break;
		case 8:  /* this is for MSMC */
			if (DSPMemAddr < MSMC_START) {
				return 0;
			} else {
				offset = DSPMemAddr - MSMC_START;
				ptr = (uint32_t *)msmcVirt + offset/4;
			break;
		case 9:  /* this is for DDR */
			if (DSPMemAddr < DDR_START) {
				return 0;
			} else {
				offset = DSPMemAddr - DDR_START;
				ptr = (uint32_t *)ddrVirt + offset/4;
			break;
		default:
			printk("Use coreNum 0-7 for core 0-7 of EVMC6678L, or coreNum 0-3 for core 0-3 of EVMC6670L; coreNum 8 for MSMC and coreNum 9 for DDR.\n");
			return 0;
			break;
	for (i = 0; i < length/4; i++) {
#if BIG_ENDIAN
		swap4bytes(&buffer[i], 4);
#endif
		*ptr = buffer[i];
		ptr++;
	if ((coreNum >= 0)&&(coreNum <= 7)) {
		iowrite32(tempReg, ptrReg + IB_OFFSET(1)/4);  /* Restore IB_OFFSET1 */
	return length;
 *  @func   readDSPMemory
 *  @desc   Read a block of DSP memory by Linux host.
 *          coreNum: to read data: 0-7 for cores 0-7; 8 for MSMC; 9 for DDR.
 *  @modif  None.
uint32_t readDSPMemory(uint32_t coreNum, uint32_t DSPMemAddr, uint32_t *buffer, uint32_t length)
	uint32_t *ptr;
	if (length == 0) {
		return 0;
	switch (coreNum) {
#if EVMC6678L
		case 0:
		case 1:
		case 2:
		case 3:
		case 4:
		case 5:
		case 6:
		case 7:
#endif
#if EVMC6670L
		case 0:
		case 1:
		case 2:
		case 3:
#endif
#if EVMC6657L
		case 0:
		case 1:
#endif
			iowrite32(tempReg + coreNum*0x1000000, ptrReg + IB_OFFSET(1)/4);        /* pointing to a different core */
				return 0;
			} else {
			break;
				return 0;
			} else {
			break;
				return 0;
			} else {
			break;
		default:
			return 0;
			break;
		buffer[i] = *ptr;
#if BIG_ENDIAN
#endif
		ptr++;
	return length;
 *  @func   pushData
 *  @desc   Parser function for DSP boot image array
 *  @modif  None.
void pushData(uint8_t *pDspCode, uint8_t coreNum, uint32_t *bootEntryAddr)
	uint32_t i, j, tempArray[BLOCK_TRANSFER_SIZE/4];
	uint32_t size, section = 0, totalSize = 0;
	uint32_t count, remainder, startAddr, temp;
	uint8_t newCoreNum;
	/* Get the boot entry address */
	*bootEntryAddr = byteTo32bits(pDspCode);
	printk("Boot entry address is 0x%8x\n", *bootEntryAddr);
	pDspCode +=4;
	while(1) {
		/* Get the size */
		size = byteTo32bits(pDspCode);
		if(size == 0) break;
		if ((size/4)*4 != size) {
			size = ((size/4)+1)*4;
		totalSize += size;
		section++;
		pDspCode += 4;
		startAddr = byteTo32bits(pDspCode);
		/* In case there are several sections within different memory regions */
		temp = (startAddr & 0xFF000000) >> 24;
		if (temp == 0x00 || ((temp >> 4) == 0x1)) {
			if (coreNum < 8) {
				/* Write address like 0x00800000 to core 1, 2, ... */
				newCoreNum = coreNum;
			} else {
				newCoreNum = 0;
		} else if (temp == 0x0C) {
			newCoreNum = 8;
		} else {
			newCoreNum = 9;
		pDspCode+= 4;
		count = size/BLOCK_TRANSFER_SIZE;
		remainder = size - count * BLOCK_TRANSFER_SIZE;
		for(i = 0; i < count; i++) {
			for (j = 0; j < BLOCK_TRANSFER_SIZE/4; j++) {
				tempArray[j] = byteTo32bits(pDspCode);
				pDspCode += 4;
			/* Transfer boot tables to DSP */
//                        printk("Start transfer DSP \n");
			writeDSPMemory(newCoreNum, startAddr, tempArray, BLOCK_TRANSFER_SIZE);
//                        printk("End trensfer DSP \n");
			startAddr += BLOCK_TRANSFER_SIZE;
		for (j = 0; j < remainder/4; j++) {
			pDspCode += 4;
//                 printk("Next transfer reminder \n");
		writeDSPMemory(newCoreNum, startAddr, tempArray, remainder);
//                 printk("End reminder \n");
		// printk("Section %d started at 0x%8x with size 0x%8x bytes written to core %d\n", section, startAddr, size, newCoreNum);
	printk("Total %d sections, 0x%x bytes of data were written\n", section, totalSize);
#if LOCAL_RESET
 *  @func   coreLocalReset
 *  @desc   Reset a particular CorePac, 6678 Data Manual, section 7.4.4
 *          initiated by LPSC MMRs
 *  @modif  None.
void coreLocalReset(uint32_t pid, uint32_t mid, uint32_t state)
	uint32_t *pReg, temp, counter = 0;
	/* Set MST_PRIV bit to access PSC via PCIE */
	iowrite32(((ioread32(pReg + PRIORITY/4))|0x00010000), pReg + PRIORITY/4);
	/* Temporarily re-map IB region 3 from DDR memory to PSC registers */
	iowrite32(PSC_BASE_ADDRESS, pReg + IB_OFFSET(3)/4);
	/* Now it points to the start of PSC_BASE_ADDRESS */
	temp = myIoread32(pReg + MDCTL(mid)/4);
	if (state == 0) {
		/* Reset assert */
		temp = ((temp & ~0x1F) | PSC_ENABLE) & (~0x100);
		printk("Start local reset assert for core (module id): %d ...\n", mid);
	} else 	{
		/* Reset de-assert */
		temp = (temp & ~0x1F) | PSC_ENABLE | (1 << 8);
		printk("Start local reset de-assert for core (module id): %d ...\n", mid);
	myIowrite32(temp, pReg + MDCTL(mid)/4);    /* Assert/De-assert local reset */
	/* No previous transition in progress */
	counter = 0;
	while (true) {
		temp = myIoread32(pReg + PTSTAT/4);
		if ((temp & (1 << pid)) == 0) break;
		mdelay(1);
		counter ++;
		if (counter > 10) {
			printk("Previous transition in progress pid %d mid %d state: %d\n", pid, mid, state);
			break;
	myIowrite32((1 << pid), pReg + PTCMD/4);
	/* Current transition finished */
	counter = 0;
	while (true) {
		mdelay(1);
		counter ++;
		if (counter > 10) {
			printk("Current transition in progress pid %d mid %d state: %d\n", pid, mid, state);
			break;
	/* Verifying state change */
	counter = 0;
	while (true) {
		temp = myIoread32(pReg + MDSTAT(mid)/4);
		if ((temp & 0x1F) == 3) break;
		mdelay(1);
		counter ++;
		if (counter > 10) {
			printk("MD stat for pid %d mid %d state: %d timeout\n", pid, mid, state);
			break;
 *  @func   setPscState
 *  @desc   Set a new power state for the specified domain id in a power controler
 *          domain. Wait for the power transition to complete.
 *      pid   -  power domain.
 *      mid   -  module id to use for module in the specified power domain
 *      state -  new state value to set (0 = RESET; 3 = ENABLE)
 *  @modif  None.
void setPscState(uint32_t pid, uint32_t mid, uint32_t state)
	uint32_t *pReg, mdctl, pdctl, temp, counter = 0;
	mdctl = myIoread32(pReg + MDCTL(mid)/4);
	pdctl = myIoread32(pReg + PDCTL(pid)/4);
	counter = 0;
	while (true) {
		mdelay(1);
		counter ++;
		if (counter > 10) {
			break;
	/* Set power domain control */
	myIowrite32(pdctl | 0x1, pReg + PDCTL(pid)/4);
	/* Set MDCTL NEXT to new state */
	mdctl = ((mdctl) & ~(0x1f)) | state;
	myIowrite32(mdctl, pReg + MDCTL(mid)/4);
	/* Start power transition by setting PTCMD GO to 1 */
	temp = myIoread32(pReg + PTCMD/4);
	myIowrite32(temp | (0x1<<pid), pReg + PTCMD/4);
	counter = 0;
	while (true) {
		mdelay(1);
		counter ++;
		if (counter > 10) {
			break;
	counter = 0;
	while (true) {
		if ((temp & 0x1F) == state) break;
		mdelay(1);
		counter ++;
		if (counter > 10) {
			break;
 *  @func   setBootAddrIpcgr
 *  @desc   Write boot entry point into DSP_BOOT_ADDR0 and the send an IPC
 *  @modif  None.
uint32_t setBootAddrIpcgr(uint32_t core, uint32_t addr)
	uint32_t *pReg;
	/* Temporarily re-map IB region 3 from DDR memory to chip level registers */
	iowrite32(CHIP_LEVEL_BASE_ADDRESS, pReg + IB_OFFSET(3)/4);
	/* Now it points to the start of CHIP_LEVEL_BASE_ADDRESS */
	/* Unlock KICK0, KICK1 */
	myIowrite32(KICK0_UNLOCK, pReg + KICK0/4);
	myIowrite32(KICK1_UNLOCK, pReg + KICK1/4);
	/* Check if the last 10 bits of addr is 0 */
	if ((addr & 0x3f) != 0) {
		printk("The address is not 1K aligned.\n");
		return 0;
	myIowrite32(addr, pReg + DSP_BOOT_ADDR(core)/4);
	myIowrite32(1, pReg + IPCGR(core)/4);
	mdelay(1);
	return 1;
 *  @func   dspLocalReset
 *  @desc   Perform DSP cores and periphrals reset
 *  @modif  None.
void dspLocalReset(void)
	uint32_t i, bootEntryAddr = 0;
#if EVMC6670L
	/* Local reset of all cores */
	coreLocalReset(PD13, LPSC_C0_TIM0, LOC_RST_ASSERT);
	coreLocalReset(PD14, LPSC_C1_TIM1, LOC_RST_ASSERT);
	coreLocalReset(PD15, LPSC_C2_TIM2, LOC_RST_ASSERT);
	coreLocalReset(PD16, LPSC_C3_TIM3, LOC_RST_ASSERT);
	/* Disable all other modules */
	setPscState(PD0, LPSC_TCP3E, PSC_SWRSTDISABLE);
	setPscState(PD0, LPSC_VCP2A, PSC_SWRSTDISABLE);
	setPscState(PD1, LPSC_DEBUG, PSC_SWRSTDISABLE);
	setPscState(PD1, LPSC_TETB, PSC_SWRSTDISABLE);
	setPscState(PD2, LPSC_SA, PSC_SWRSTDISABLE);
	setPscState(PD2, LPSC_SGMII, PSC_SWRSTDISABLE);
	setPscState(PD2, LPSC_PA, PSC_SWRSTDISABLE);
	//setPscState(PD3, LPSC_PCIE, PSC_SWRSTDISABLE);
	setPscState(PD4, LPSC_SRIO, PSC_SWRSTDISABLE);
	setPscState(PD5, LPSC_HYPER, PSC_SWRSTDISABLE);
	//setPscState(PD6, LPSC_RESERV, PSC_SWRSTDISABLE);
	setPscState(PD7, LPSC_MSMCRAM, PSC_SWRSTDISABLE);
	setPscState(PD8, LPSC_RACA_RACB, PSC_SWRSTDISABLE);
	setPscState(PD8, LPSC_TAC, PSC_SWRSTDISABLE);
	setPscState(PD9, LPSC_FFTCA_FFTCB, PSC_SWRSTDISABLE);
	setPscState(PD10, LPSC_AIF2, PSC_SWRSTDISABLE);
	setPscState(PD11, LPSC_TCP3DA, PSC_SWRSTDISABLE);
	setPscState(PD12, LPSC_VCP2B, PSC_SWRSTDISABLE);
	setPscState(PD12, LPSC_VCP2C, PSC_SWRSTDISABLE);
	setPscState(PD12, LPSC_VCP2D, PSC_SWRSTDISABLE);
	setPscState(PD17, LPSC_TCP3dB, PSC_SWRSTDISABLE);
	for (i = 0; i < 4; i++) {
		pushData(localResetCode, i, &bootEntryAddr);
		if (setBootAddrIpcgr(i, bootEntryAddr) == 0) {
			printk("Core %d is not ready !!! \n", i);
	/* Enable all other modules */
	setPscState(PD0, LPSC_TCP3E, PSC_ENABLE);
	setPscState(PD0, LPSC_VCP2A, PSC_ENABLE);
	setPscState(PD1, LPSC_DEBUG, PSC_ENABLE);
	setPscState(PD1, LPSC_TETB, PSC_ENABLE);
	setPscState(PD2, LPSC_PA, PSC_ENABLE);
	setPscState(PD2, LPSC_SGMII, PSC_ENABLE);
	setPscState(PD2, LPSC_SA, PSC_ENABLE);
	//setPscState(PD3, LPSC_PCIE, PSC_ENABLE);
	setPscState(PD4, LPSC_SRIO, PSC_ENABLE);
	setPscState(PD5, LPSC_HYPER, PSC_ENABLE);
	//setPscState(PD6, LPSC_RESERV, PSC_ENABLE);
	setPscState(PD7, LPSC_MSMCRAM, PSC_ENABLE);
	setPscState(PD8, LPSC_RACA_RACB, PSC_ENABLE);
	setPscState(PD8, LPSC_TAC, PSC_ENABLE);
	setPscState(PD9, LPSC_FFTCA_FFTCB, PSC_ENABLE);
	setPscState(PD10, LPSC_AIF2, PSC_ENABLE);
	setPscState(PD11, LPSC_TCP3DA, PSC_ENABLE);
	setPscState(PD12, LPSC_VCP2B, PSC_ENABLE);
	setPscState(PD12, LPSC_VCP2C, PSC_ENABLE);
	setPscState(PD12, LPSC_VCP2D, PSC_ENABLE);
	setPscState(PD17, LPSC_TCP3dB, PSC_ENABLE);
	/* Local out of reset of all cores */
	coreLocalReset(PD13, LPSC_C0_TIM0, LOC_RST_DEASSERT);
	coreLocalReset(PD14, LPSC_C1_TIM1, LOC_RST_DEASSERT);
	coreLocalReset(PD15, LPSC_C2_TIM2, LOC_RST_DEASSERT);
	coreLocalReset(PD16, LPSC_C3_TIM3, LOC_RST_DEASSERT);
#endif
#if EVMC6678L
	coreLocalReset(PD8,  LPSC_C0_TIM0, LOC_RST_ASSERT);
	coreLocalReset(PD9,  LPSC_C1_TIM1, LOC_RST_ASSERT);
	coreLocalReset(PD10, LPSC_C2_TIM2, LOC_RST_ASSERT);
	coreLocalReset(PD11, LPSC_C3_TIM3, LOC_RST_ASSERT);
	coreLocalReset(PD12, LPSC_C4_TIM4, LOC_RST_ASSERT);
	coreLocalReset(PD13, LPSC_C5_TIM5, LOC_RST_ASSERT);
	coreLocalReset(PD14, LPSC_C6_TIM6, LOC_RST_ASSERT);
	coreLocalReset(PD15, LPSC_C7_TIM7, LOC_RST_ASSERT);
	setPscState(PD0, LPSC_EMIF16_SPI, PSC_SWRSTDISABLE);
	setPscState(PD0, LPSC_TSIP, PSC_SWRSTDISABLE);
	setPscState(PD1, LPSC_TETB_TRC, PSC_SWRSTDISABLE);
	for (i = 0; i < 8; i++) {
	setPscState(PD0, LPSC_EMIF16_SPI, PSC_ENABLE);
	setPscState(PD0, LPSC_TSIP, PSC_ENABLE);
	setPscState(PD1, LPSC_TETB_TRC, PSC_ENABLE);
	coreLocalReset(PD8,  LPSC_C0_TIM0, LOC_RST_DEASSERT);
	coreLocalReset(PD9,  LPSC_C1_TIM1, LOC_RST_DEASSERT);
	coreLocalReset(PD10, LPSC_C2_TIM2, LOC_RST_DEASSERT);
	coreLocalReset(PD11, LPSC_C3_TIM3, LOC_RST_DEASSERT);
	coreLocalReset(PD12, LPSC_C4_TIM4, LOC_RST_DEASSERT);
	coreLocalReset(PD13, LPSC_C5_TIM5, LOC_RST_DEASSERT);
	coreLocalReset(PD14, LPSC_C6_TIM6, LOC_RST_DEASSERT);
	coreLocalReset(PD15, LPSC_C7_TIM7, LOC_RST_DEASSERT);
#endif
#endif
 *  @func   init_module
 *  @desc   Initialize a loadable module
 *  @modif  None.
int init_module(void)
	int j;
	uint32_t i;
	uint32_t bootEntryAddr = 0;              /* Store 32-bit boot entry address read from .h file */
#if HELLO_WORLD_DEMO | EDMA_INTC_DEMO
	uint32_t buffer[BLOCK_TRANSFER_SIZE/4];  /* Store 32-bit DSP memory readback data */
#endif
#if EDMA_INTC_DEMO
	uint32_t diff;
                   	int ii;
#endif
	printk ("Finding the device....\n") ;
	PCI_FindPciDevices();
	if (!PCIE_DEV) {
		printk ("No PCIE device found!!!\n") ;
	if (PCIE_DEV != NULL) {
		printk("Reading the BAR areas....\n");
		PCI_readBAR();
		printk("Enabling the device....\n");
		/* Linux Function: Initialize device before it's used by a driver */
		if(pci_enable_device(PCIE_DEV))return 0;
		/* Linux Function: Associates the given data with the given pci_driver structure */
		pci_set_drvdata(PCIE_DEV, memVirt);
		PCI_setMaster();
		printk("Access PCIE application register ....\n");
		/* Pointing to the beginning of the application registers */
		ptrReg = (uint32_t *)regVirt;
		/* Configure IB_BAR0 to BAR0 for PCIE registers; Configure IB_BAR1 to BAR1 for LL2 for core 0
		   Configure IB_BAR2 to BAR2 for MSMC; Configure IB_BAR3 to BAR3 for DDR */
			iowrite32(i, ptrReg + IB_BAR(i)/4);
			iowrite32(PCIE_DEV->resource[i].start, ptrReg + IB_START_LO(i)/4);
			iowrite32(0, ptrReg + IB_START_HI(i)/4);
		iowrite32(PCIE_BASE_ADDRESS, ptrReg + IB_OFFSET(0)/4);
		iowrite32(LL2_START + (1 << 28), ptrReg + IB_OFFSET(1)/4);
		iowrite32(MSMC_START, ptrReg + IB_OFFSET(2)/4);
		iowrite32(DDR_START, ptrReg + IB_OFFSET(3)/4);
		printk("Registering the irq %d ...\n", irqNo);
		if(request_irq(irqNo, ISR_handler, IRQF_SHARED, "TI 667x PCIE", &dummy))return 0;
		HAL_PciEnableDspInterrupt();
		/* Load DDR init code into DSP */
		pushData(ddrInitCode, 0, &bootEntryAddr);
		/* Write boot entry address into MAGIC_ADDR */
		writeDSPMemory(0, MAGIC_ADDR, &bootEntryAddr, 4);
		while (1) {
			readDSPMemory(0, MAGIC_ADDR, buffer, 4);
			if (buffer[0] == 0)  break;
			for (i = 0; i < 1000; i++) i++;
		 j=0;
		while (1)
					  if (buffer[0] == 0)
			                  printk("Waiting #1 of MAGIC_ADDR=0 is OK   \n");
				          printk("j = %04d  \n", j);
					  break;
					  j++;
					  if (j > 200000)
					  printk("Time out HELLO WORLD #1  !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!   \n");
					  return 0;
		/* Load "Hello World" demo into DSP */
		pushData(bootCode, 9, &bootEntryAddr);
	//	dspLocalReset();
#endif
#if POST_DEMO
		/* Load POST demo code into DSP */
		pushData(post, 0, &bootEntryAddr);
#endif
#if EDMA_INTC_DEMO
		printk("Allocating consistent memory  start...\n");
		wDataVirt = (uint8_t*)dma_alloc_coherent(&PCIE_DEV->dev, DMA_TRANSFER_SIZE, &wData, GFP_KERNEL);
		rDataVirt = (uint8_t*)dma_alloc_coherent(&PCIE_DEV->dev, DMA_TRANSFER_SIZE, &rData, GFP_KERNEL);
		printk("Allocating consistent memory end...\n");
			wDataVirt[i] = i;
			rDataVirt[i] = 0;
		printk("Finish DMA_TRANSFER_SIZE\n");
		/* Load Interrupt demo code into DSP */
		pushData(pcieInterrupt, 0, &bootEntryAddr);
		printk("Finish pushData \n");
		printk("Finish writeDSPMemory \n");
		while (1) {
		        j=0;
				while (1)
				  if (buffer[0] == 0)
				  break;
				  j++;
				  if (j > 200000)
				  printk("Time out EDMA  #1  !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!   \n");
					dma_free_coherent(&PCIE_DEV->dev, DMA_TRANSFER_SIZE, wDataVirt, wData);
					dma_free_coherent(&PCIE_DEV->dev, DMA_TRANSFER_SIZE, rDataVirt, rData);
					return 0;
		/* Wait 2 second for DDR init */
		mdelay(2000);
    for(ii=0; ii<10; ii++)
		printk ("Write DMA to DSP ...\n");
		do_gettimeofday(&test_time1);
		HAL_writeDMA (wData, DDR_START, DMA_TRANSFER_SIZE, 1);   /* Move from GPP to DSP */
		do_gettimeofday(&test_time2);
		/* Note: From PCIE specification, legacy interrupts cannot be generated from RC and be passed downstream.
		   The example below is just making use of the facility that RC can access EP side register to generate
		   a generic interrupt on local (EP) side using one of the event inputs of Interrupt Controller (INTC).
		   There is no real interrupt signal sent over the PCIe link */
		printk ("Generating interrupt to DSP ...\n");
		iowrite32(1, ptrReg + LEGACY_A_IRQ_STATUS_RAW/4);
		/* Waiting DSP ISR handler to process the interrupt from DSP and then generates an interrupt to host
		   Waiting for host ISR handler to process the interrupt from DSP before program exits */
		mdelay(1000);
		/* For demo how to move inside DSP purpose only, you can directly move between GPP and DSP using flag = 1 */
		//	HAL_writeDMA (0x80000000, 0x11800000, 0x10000, 0);
		//	HAL_writeDMA (0x11800000, 0x0C000000, 0x10000, 0);
		diff = (test_time2.tv_sec - test_time1.tv_sec)*1000000 + (test_time2.tv_usec - test_time1.tv_usec);
		printk("DMA write throughput is: %d.%02d MB/s\n", DMA_TRANSFER_SIZE/(1024*1024)*1000*1000/diff,
				((DMA_TRANSFER_SIZE/(1024*1024)*1000*1000)%diff)*100/diff);
		diff = (test_time4.tv_sec - test_time3.tv_sec)*1000000 + (test_time4.tv_usec - test_time3.tv_usec);
		printk("DMA read throughput is: %d.%02d MB/s\n", DMA_TRANSFER_SIZE/(1024*1024)*1000*1000/diff,
		printk("Freeing consistent memory ...\n");
#endif
#if LOCAL_RESET
//		mdelay(10000);
//		dspLocalReset();
#endif
	else {
		printk("No PCIE device found!!!\n");
	return 0 ;
 *  @func   cleanup_module
 *  @desc   Unregister a loadable module
 *  @modif  None.
void cleanup_module(void)
                printk("Start rmmod procedure !!!!!!!! \n");
		dspLocalReset();
		HAL_PciDisableDspInterrupt();
		 * Unmap baseRegs region & release the reg region.
		iounmap(regVirt);
		if (pci_resource_flags(PCIE_DEV, 0) & IORESOURCE_MEM) {
			release_mem_region(regBase, regLen);
		else {
			release_region(regBase, regLen);
		 * Unmap LL2 region & release the reg region.
		iounmap(memVirt);
		if (pci_resource_flags(PCIE_DEV, 1) & IORESOURCE_MEM) {
			release_mem_region(memBase, memLen);
		else {
			release_region(memBase,	memLen);
		 * Unmap MSMC region & release the reg region.
		iounmap(msmcVirt);
		if (pci_resource_flags(PCIE_DEV, 2) & IORESOURCE_MEM) {
			release_mem_region(msmcBase, msmcLen);
		else {
			release_region(msmcBase, msmcLen);
		 * Unmap DDR region & release the reg region.
		iounmap(ddrVirt);
		if (pci_resource_flags(PCIE_DEV, 3) & IORESOURCE_MEM) {
			release_mem_region(ddrBase, ddrLen);
		else {
			release_region(ddrBase, ddrLen);
		free_irq(irqNo, &dummy);
  • I have appended initialization of the wDataVirt[i] and DataVirt[i] into the cycle with the same result.                                                           Please look attachment.
     * Revision History:
    #define POST_DEMO           0
    #define EVMC6678L           1
    #define EVMC6670L           0
    #define EVMC6657L           0
    #if BIG_ENDIAN
    #else
    #endif
    #if EVMC6678L
    #endif
    #if EVMC6670L
    #endif
    #if EVMC6657L
    #endif
    #if EVMC6678L
    #endif
    #if EVMC6670L
    #endif
    #if EVMC6657L
    #endif
    #endif
    #if POST_DEMO
    #if EVMC6678L
    #endif
    #if EVMC6670L
    #endif
    #if EVMC6657L
    #endif
    #endif
    #if EDMA_INTC_DEMO
    #if EVMC6678L
    #endif
    #if EVMC6670L
    #endif
    #endif
    #if LOCAL_RESET
    #if EVMC6678L
    #endif
    #if EVMC6670L
    #endif
    #endif
    /* PSC registers */
    #define PTCMD                        0x120
    #define ESR                          0x1010
    #define EESR                         0x1030
    #define IESR                         0x1060
    #define IPR                          0x1068
    #define ICR                          0x1070
    #define KICK0                        0x38
    #define KICK1                        0x3C
    #if EVMC6670L
    #define LPSC_TETB      6
    #define LPSC_PA        7
    #define LPSC_SA        9
    #define LPSC_TAC       16
    #endif
    #if EVMC6678L
    #define LPSC_TSIP        4
    #define LPSC_PA          7
    #define LPSC_SA          9
    #endif
    mem:  Local L2
    ddr:  DDR3
    int32_t  irqNo;
    uint32_t dummy;
     *  @modif  None.
    			irqNo = dev->irq;
    			PCIE_DEV = dev;
    			break;
     *  @func   PCI_readBAR
     *  @modif  None.
    	else {
    	if (regBase > 0) {
    	else {
    	if (memBase > 0) {
    	else {
    	if (msmcBase > 0) {
    	else {
    	if (ddrBase > 0) {
    	regLen  = barLen[0];
    	memLen  = barLen[1];
    	ddrLen  = barLen[3];
     *  @modif  None.
    	int32_t  retVal;
    	uint16_t cmdVal;
    	dev = PCIE_DEV;
    		| PCI_COMMAND_MASTER
    		| PCI_COMMAND_SERR;
     *  @modif  None.
     *  @modif  None.
     *  @modif  None.
     *  @modif  None.
     *  @func   HAL_readDMA
     *          outbound write.
     *  @modif  None.
    	if (flag) {
    		else {
    	while (true) {
    		if (flag == 1) {
    		} else {
    			tmp <<= 16;
    		else {
    			tmp = 0x10000|size;
    			tSize = size;
    			size = 0;
    		while (true) {
    			udelay(10);
    				break;
    		if (size != 0) {
    			srcAddr += tSize;
    			dstAddr += tSize;
    		} else {
    			break;
     *          outbound read.
     *  @modif  None.
    	if (flag) {
    		else {
    	while (true) {
    		if (flag == 1) {
    		} else {
    			tmp <<= 16;
    		else {
    			tmp = 0x10000|size;
    			tSize = size;
    			size = 0;
    		while (true) {
    			udelay(10);
    				break;
    		if (size != 0) {
    			srcAddr += tSize;
    			dstAddr += tSize;
    		} else {
    			break;
     *  @func   ISR_handler
     *  @desc   ISR.
     *  @modif  None.
    	if (status == 1) {
    				counter++;
    		else
    		return IRQ_HANDLED;
    	return IRQ_NONE;
     *  @modif  None.
    	uint32_t i, temp;
    	temp = *pDspCode++;
    		temp <<= 8;
    	return(temp);
     *  @func   swap4bytes
     *  @modif  None.
    	uint32_t i, temp;
    		temp = *pDspCode;
    		temp = (temp>>24) |
    			(temp<<24);
    		*pDspCode = temp;
     *  @modif  None.
    	uint32_t *ptr;
    	if (length == 0) {
    		return 0;
    	switch (coreNum) {
    #if EVMC6678L
    		case 0:
    		case 1:
    		case 2:
    		case 3:
    		case 4:
    		case 5:
    		case 6:
    		case 7:
    #endif
    #if EVMC6670L
    		case 0:
    		case 1:
    		case 2:
    		case 3:
    #endif
    #if EVMC6657L
    		case 0:
    		case 1:
    #endif
    				return 0;
    			} else {
    			break;
    				return 0;
    			} else {
    			break;
    				return 0;
    			} else {
    			break;
    		default:
    			return 0;
    			break;
    #if BIG_ENDIAN
    #endif
    		*ptr = buffer[i];
    		ptr++;
    	return length;
     *  @modif  None.
    	uint32_t *ptr;
    	if (length == 0) {
    		return 0;
    	switch (coreNum) {
    #if EVMC6678L
    		case 0:
    		case 1:
    		case 2:
    		case 3:
    		case 4:
    		case 5:
    		case 6:
    		case 7:
    #endif
    #if EVMC6670L
    		case 0:
    		case 1:
    		case 2:
    		case 3:
    #endif
    #if EVMC6657L
    		case 0:
    		case 1:
    #endif
    				return 0;
    			} else {
    			break;
    				return 0;
    			} else {
    			break;
    				return 0;
    			} else {
    			break;
    		default:
    			return 0;
    			break;
    		buffer[i] = *ptr;
    #if BIG_ENDIAN
    #endif
    		ptr++;
    	return length;
     *  @func   pushData
     *  @modif  None.
    	uint8_t newCoreNum;
    	pDspCode +=4;
    	while(1) {
    		/* Get the size */
    		totalSize += size;
    		section++;
    		pDspCode += 4;
    			if (coreNum < 8) {
    			} else {
    				newCoreNum = 0;
    			newCoreNum = 8;
    		} else {
    			newCoreNum = 9;
    		pDspCode+= 4;
    				pDspCode += 4;
    			pDspCode += 4;
    #if LOCAL_RESET
     *  @modif  None.
    	if (state == 0) {
    		/* Reset assert */
    	} else 	{
    	counter = 0;
    	while (true) {
    		mdelay(1);
    		counter ++;
    		if (counter > 10) {
    			break;
    	counter = 0;
    	while (true) {
    		mdelay(1);
    		counter ++;
    		if (counter > 10) {
    			break;
    	counter = 0;
    	while (true) {
    		mdelay(1);
    		counter ++;
    		if (counter > 10) {
    			break;
     *  @func   setPscState
     *  @modif  None.
    	counter = 0;
    	while (true) {
    		mdelay(1);
    		counter ++;
    		if (counter > 10) {
    			break;
    	counter = 0;
    	while (true) {
    		mdelay(1);
    		counter ++;
    		if (counter > 10) {
    			break;
    	counter = 0;
    	while (true) {
    		mdelay(1);
    		counter ++;
    		if (counter > 10) {
    			break;
     *  @modif  None.
    	uint32_t *pReg;
    		return 0;
    	mdelay(1);
    	return 1;
     *  @modif  None.
    #if EVMC6670L
    #endif
    #if EVMC6678L
    #endif
    #endif
     *  @func   init_module
     *  @modif  None.
    	int j;
    	uint32_t i;
    #endif
    #if EDMA_INTC_DEMO
    	uint32_t diff;
                       	int ii;
    #endif
    	if (!PCIE_DEV) {
    		PCI_readBAR();
    		PCI_setMaster();
    		while (1) {
    		 j=0;
    		while (1)
    					  if (buffer[0] == 0)
    					  break;
    					  j++;
    					  if (j > 200000)
    					  return 0;
    	//	dspLocalReset();
    #endif
    #if POST_DEMO
    #endif
    #if EDMA_INTC_DEMO
    			wDataVirt[i] = i;
    			rDataVirt[i] = 0;
    		while (1) {
    		        j=0;
    				while (1)
    				  if (buffer[0] == 0)
    				  break;
    				  j++;
    				  if (j > 200000)
    					return 0;
    		mdelay(2000);
    			wDataVirt[i] = i;
    			rDataVirt[i] = 0;
    		mdelay(1000);
    #endif
    #if LOCAL_RESET
    //		mdelay(10000);
    //		dspLocalReset();
    #endif
    	else {
    	return 0 ;
     *  @modif  None.
    		dspLocalReset();
    		iounmap(regVirt);
    		else {
    		iounmap(memVirt);
    		else {
    		iounmap(msmcVirt);
    		else {
    		iounmap(ddrVirt);
    		else {
  • I noticed that result in 1-st cycle was always correct.  May be there are necessary to modify the pcieboot_interrupt.c too?
  • Hi Viktor,
    1. From my understanding, pciedemo.c(host app) is common across all the examples available under ..:\ti\mcsdk_2_xx_xx_xx\tools\boot_loader\examples\pcie so you can not have both the macros enabled ie LOCAL_RESET and EDMA_INTC_DEMO.
    2. Please let us know the board revision.
    www2.advantech.com/.../6678le_of.aspx
    Thank you.
    Thank you for your quick reply.
    1.     I always use LOCAL_RESET macros with the EDMA_INTC_DEMO macros (or with HELLO_WORD_DEMO)
    and it works because of it only invokes two functions:
    mdelay(10000);
    dspLocalReset();
     It is not my idea,  I looked earlier an approval from TI's team to use these two macroses together in one program. If it is necessary I'll try find this post again. I beleave it is unnecessary because of:        - these two functions are invoked after mentioned cycle and so can not be the case of described effect;
    - these fuctions are  commented in my program (I wrote about this correction earlier.
       The function dspLocalReset() will be invoked later, during procedure rmmod pciedemo.ko).
    Could you run my version of the program on your hardware ?  In reality one differs from original version with the additional cycle only.
    2. TMDSEVM6678L Rev.3B
    PCIe adaptor card, labeled with
    PCB REV: 17-00107-03; PCA REV: 18-00107-03
    I have tested the TI provide pciedemo example on EDMA_INTC_DEMO mode with enable LOCAL_RESET macro. It is working fine.
    The LOCAL_RESET code part is help for run the pciedemo example at multiple iteration.
  • Hi Ganapathi,
    OK. I had no serious problems with LocalReset (except for OS hung sometimes).
    My question was about EDMA_INTC_DEMO behaviour within the cycle.
    Could you run my version?
    Thank you,
    Viktor
    Yes, I have tested your code. It is working fine with multiple iteration.
    I think you increased the DMA transfer to DSP(10 times) and reset the DSP at the time of remove module. please find the attached test log.
    Linux@TestPC:~/Desktop/linux_host_loader$ sudo insmod pciedemo.ko
    Linux@TestPC:~/Desktop/linux_host_loader$ dmesg
    [  483.413795] Finding the device....
    [  483.413820] Found TI device
    [  483.413824] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  483.413827] Reading the BAR areas....
    [  483.418856] Enabling the device....
    [  483.418873] pci 0000:02:00.0: setting latency timer to 64
    [  483.418890] Access PCIE application register ....
    [  483.418896] Registering the irq 16 ...
    [  483.418907] Allocating consistent memory  start...
    [  483.422658] Allocating consistent memory end...
    [  483.563860] Finish DMA_TRANSFER_SIZE
    [  483.563866] Boot entry address is 0x  82e640
    [  483.566157] Total 5 sections, 0xf5e4 bytes of data were written
    [  483.566160] Finish pushData
    [  483.566164] Finish writeDSPMemory
    [  483.630008] Waiting #1 of MAGIC_ADDR=0 is OK
    [  483.630012] j = 29355
    [  485.754422] Write DMA to DSP ...
    [  485.766639] Generating interrupt to DSP ...
    [  485.891597] Interrupt 16 received from DSP
    [  485.891601] Read DMA from DSP ...
    [  485.895586] DMA test passed!
    [  486.758710] DMA write throughput is: 327.54 MB/s
    [  486.758713] DMA read throughput is: 341.70 MB/s
    [  486.898900] Write DMA to DSP ...
    [  486.911105] Generating interrupt to DSP ...
    [  487.036063] Interrupt 16 received from DSP
    [  487.036067] Read DMA from DSP ...
    [  487.040052] DMA test passed!
    [  487.903179] DMA write throughput is: 327.89 MB/s
    [  487.903182] DMA read throughput is: 341.73 MB/s
    [  488.043399] Write DMA to DSP ...
    [  488.055600] Generating interrupt to DSP ...
    [  488.180558] Interrupt 16 received from DSP
    [  488.180562] Read DMA from DSP ...
    [  488.184547] DMA test passed!
    [  489.047671] DMA write throughput is: 327.94 MB/s
    [  489.047675] DMA read throughput is: 341.73 MB/s
    [  489.187870] Write DMA to DSP ...
    [  489.200091] Generating interrupt to DSP ...
    [  489.325047] Interrupt 16 received from DSP
    [  489.325052] Read DMA from DSP ...
    [  489.329037] DMA test passed!
    [  490.192157] DMA write throughput is: 327.54 MB/s
    [  490.192161] DMA read throughput is: 341.73 MB/s
    [  490.332370] Write DMA to DSP ...
    [  490.344584] Generating interrupt to DSP ...
    [  490.469541] Interrupt 16 received from DSP
    [  490.469546] Read DMA from DSP ...
    [  490.473530] DMA test passed!
    [  491.336649] DMA write throughput is: 327.62 MB/s
    [  491.336652] DMA read throughput is: 341.73 MB/s
    [  491.476855] Write DMA to DSP ...
    [  491.489073] Generating interrupt to DSP ...
    [  491.614029] Interrupt 16 received from DSP
    [  491.614034] Read DMA from DSP ...
    [  491.618019] DMA test passed!
    [  492.481146] DMA write throughput is: 327.51 MB/s
    [  492.481150] DMA read throughput is: 341.70 MB/s
    [  492.621367] Write DMA to DSP ...
    [  492.633583] Generating interrupt to DSP ...
    [  492.758539] Interrupt 16 received from DSP
    [  492.758544] Read DMA from DSP ...
    [  492.762529] DMA test passed!
    [  493.625649] DMA write throughput is: 327.60 MB/s
    [  493.625652] DMA read throughput is: 341.73 MB/s
    [  493.766048] Write DMA to DSP ...
    [  493.778257] Generating interrupt to DSP ...
    [  493.903213] Interrupt 16 received from DSP
    [  493.903218] Read DMA from DSP ...
    [  493.907204] DMA test passed!
    [  494.770333] DMA write throughput is: 327.78 MB/s
    [  494.770337] DMA read throughput is: 341.70 MB/s
    [  494.910532] Write DMA to DSP ...
    [  494.922742] Generating interrupt to DSP ...
    [  495.047699] Interrupt 16 received from DSP
    [  495.047703] Read DMA from DSP ...
    [  495.051688] DMA test passed!
    [  495.914809] DMA write throughput is: 327.78 MB/s
    [  495.914812] DMA read throughput is: 341.73 MB/s
    [  496.055017] Write DMA to DSP ...
    [  496.067223] Generating interrupt to DSP ...
    [  496.192181] Interrupt 16 received from DSP
    [  496.192185] Read DMA from DSP ...
    [  496.196170] DMA test passed!
    [  497.059293] DMA write throughput is: 327.86 MB/s
    [  497.059297] DMA read throughput is: 341.73 MB/s
    [  497.059299] Freeing consistent memory ...
    Linux@TestPC:~/Desktop/linux_host_loader$ sudo rmmod pciedemo.ko
    [  510.620837] Start rmmod procedure !!!!!!!!
    [  510.620849] Start local reset assert for core (module id): 15 ...
    [  510.620858] Start local reset assert for core (module id): 16 ...
    [  510.620866] Start local reset assert for core (module id): 17 ...
    [  510.620875] Start local reset assert for core (module id): 18 ...
    [  510.620883] Start local reset assert for core (module id): 19 ...
    [  510.620891] Start local reset assert for core (module id): 20 ...
    [  510.620899] Start local reset assert for core (module id): 21 ...
    [  510.620907] Start local reset assert for core (module id): 22 ...
    [  510.637858] Previous transition in progress pid 4 mid 11 state: 0
    [  510.648789] Current transition in progress pid 4 mid 11 state: 0
    [  510.659717] MD stat for pid 4 mid 11 state: 0 timeout
    [  510.661724] Boot entry address is 0x  878000
    [  510.661798] Total 3 sections, 0x7a0 bytes of data were written
    [  510.662793] Boot entry address is 0x  878000
    [  510.662866] Total 3 sections, 0x7a0 bytes of data were written
    [  510.663861] Boot entry address is 0x  878000
    [  510.663933] Total 3 sections, 0x7a0 bytes of data were written
    [  510.664931] Boot entry address is 0x  878000
    [  510.665003] Total 3 sections, 0x7a0 bytes of data were written
    [  510.665999] Boot entry address is 0x  878000
    [  510.666071] Total 3 sections, 0x7a0 bytes of data were written
    [  510.667066] Boot entry address is 0x  878000
    [  510.667138] Total 3 sections, 0x7a0 bytes of data were written
    [  510.668136] Boot entry address is 0x  878000
    [  510.668209] Total 3 sections, 0x7a0 bytes of data were written
    [  510.669204] Boot entry address is 0x  878000
    [  510.669276] Total 3 sections, 0x7a0 bytes of data were written
    [  510.687212] MD stat for pid 2 mid 9 state: 3 timeout
    [  510.698148] Previous transition in progress pid 4 mid 11 state: 3
    [  510.709079] Current transition in progress pid 4 mid 11 state: 3
    [  510.720011] MD stat for pid 4 mid 11 state: 3 timeout
    [  510.721031] Start local reset de-assert for core (module id): 15 ...
    [  510.721041] Start local reset de-assert for core (module id): 16 ...
    [  510.721052] Start local reset de-assert for core (module id): 17 ...
    [  510.721061] Start local reset de-assert for core (module id): 18 ...
    [  510.721071] Start local reset de-assert for core (module id): 19 ...
    [  510.721082] Start local reset de-assert for core (module id): 20 ...
    [  510.721092] Start local reset de-assert for core (module id): 21 ...
    [  510.721103] Start local reset de-assert for core (module id): 22 ...
    [  517.986544] Finding the device....
    [  517.986569] Found TI device
    [  517.986574] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  517.986576] Reading the BAR areas....
    [  517.989441] Enabling the device....
    [  517.989455] pci 0000:02:00.0: setting latency timer to 64
    [  517.989469] Access PCIE application register ....
    [  517.989474] Registering the irq 16 ...
    [  517.989484] Allocating consistent memory  start...
    [  517.992942] Allocating consistent memory end...
    [  518.135296] Finish DMA_TRANSFER_SIZE
    [  518.135303] Boot entry address is 0x  82e640
    [  518.137553] Total 5 sections, 0xf5e4 bytes of data were written
    [  518.137556] Finish pushData
    [  518.137559] Finish writeDSPMemory
    [  518.201426] Waiting #1 of MAGIC_ADDR=0 is OK
    [  518.201430] j = 29358
    [  520.327330] Write DMA to DSP ...
    [  520.339531] Generating interrupt to DSP ...
    [  520.464482] Interrupt 16 received from DSP
    [  520.464485] Read DMA from DSP ...
    [  520.468001] DMA test passed!
    [  521.357652] DMA write throughput is: 327.97 MB/s
    [  521.357656] DMA read throughput is: 341.70 MB/s
    [  521.498329] Write DMA to DSP ...
    [  521.510516] Generating interrupt to DSP ...
    [  521.635465] Interrupt 16 received from DSP
    [  521.635468] Read DMA from DSP ...
    [  521.636001] DMA test passed!
    [  522.528631] DMA write throughput is: 328.38 MB/s
    [  522.528635] DMA read throughput is: 341.70 MB/s
    [  522.669309] Write DMA to DSP ...
    [  522.681504] Generating interrupt to DSP ...
    [  522.806451] Interrupt 16 received from DSP
    [  522.806454] Read DMA from DSP ...
    [  522.808001] DMA test passed!
    [  523.699607] DMA write throughput is: 328.16 MB/s
    [  523.699610] DMA read throughput is: 341.73 MB/s
    [  523.840315] Write DMA to DSP ...
    [  523.852501] Generating interrupt to DSP ...
    [  523.977449] Interrupt 16 received from DSP
    [  523.977452] Read DMA from DSP ...
    [  523.980001] DMA test passed!
    [  524.870585] DMA write throughput is: 328.40 MB/s
    [  524.870589] DMA read throughput is: 341.67 MB/s
    [  525.011358] Write DMA to DSP ...
    [  525.023545] Generating interrupt to DSP ...
    [  525.148495] Interrupt 16 received from DSP
    [  525.148498] Read DMA from DSP ...
    [  525.152001] DMA test passed!
    [  526.041694] DMA write throughput is: 328.38 MB/s
    [  526.041698] DMA read throughput is: 341.70 MB/s
    [  526.182518] Write DMA to DSP ...
    [  526.194705] Generating interrupt to DSP ...
    [  526.319654] Interrupt 16 received from DSP
    [  526.319657] Read DMA from DSP ...
    [  526.320002] DMA test passed!
    [  527.212802] DMA write throughput is: 328.38 MB/s
    [  527.212806] DMA read throughput is: 341.73 MB/s
    [  527.353581] Write DMA to DSP ...
    [  527.365773] Generating interrupt to DSP ...
    [  527.490722] Interrupt 16 received from DSP
    [  527.490725] Read DMA from DSP ...
    [  527.492001] DMA test passed!
    [  528.383952] DMA write throughput is: 328.21 MB/s
    [  528.383956] DMA read throughput is: 341.73 MB/s
    [  528.524845] Write DMA to DSP ...
    [  528.537031] Generating interrupt to DSP ...
    [  528.661980] Interrupt 16 received from DSP
    [  528.661983] Read DMA from DSP ...
    [  528.664001] DMA test passed!
    [  529.555230] DMA write throughput is: 328.40 MB/s
    [  529.555234] DMA read throughput is: 341.73 MB/s
    [  529.695911] Write DMA to DSP ...
    [  529.708109] Generating interrupt to DSP ...
    [  529.833058] Interrupt 16 received from DSP
    [  529.833061] Read DMA from DSP ...
    [  529.836002] DMA test passed!
    [  530.726296] DMA write throughput is: 328.11 MB/s
    [  530.726300] DMA read throughput is: 341.73 MB/s
    [  530.866974] Write DMA to DSP ...
    [  530.879165] Generating interrupt to DSP ...
    [  531.004116] Interrupt 16 received from DSP
    [  531.004119] Read DMA from DSP ...
    [  531.008001] DMA test passed!
    [  531.897275] DMA write throughput is: 328.27 MB/s
    [  531.897279] DMA read throughput is: 341.73 MB/s
    [  531.897281] Freeing consistent memory ...
  • Hi Ganapathi,
    Yes you are right. And this program works fine on your hardware but gives error on my harware.
    Please look my log file.
    Could you suggest me, how do resolve this problem?  What is the cause of similar behaviour of this program (or HW) ?
    Can you inform me what version of the board you are using now?
    Thank you very much for your assistance.
    Viktor.
    [  474.567037] Finding the device....
    [  474.567476] Found TI device
    [  474.567526] TI device: vendor=0x104c, dev=0xb005, irq=0x0000000c
    [  474.567597] Reading the BAR areas....
    [  474.570567] Enabling the device....
    [  474.570635] pci 0000:01:00.0: setting latency timer to 64
    [  474.570648] Access PCIE application register ....
    [  474.570705] Registering the irq 12 ...
    [  474.570771] Allocating consistent memory  start...
    [  474.575028] Allocating consistent memory end...
    [  474.587458] Finish DMA_TRANSFER_SIZE
    [  474.587516] Boot entry address is 0x  82e2c0
    [  474.588600] Total 5 sections, 0xf30c bytes of data were written
    [  474.588673] Finish pushData
    [  474.588710] Finish writeDSPMemory
    [  474.653279] Waiting #1 of MAGIC_ADDR=0 is OK
    [  474.653339] j = 46236
    [  476.649686] Write DMA to DSP ...
    [  476.661895] Generating interrupt to DSP ...
    [  476.790102] Interrupt 12 received from DSP
    [  476.793351] Read DMA from DSP ...
    [  476.794074] DMA test passed!
    [  477.657157] DMA write throughput is: 329.19 MB/s
    [  477.660470] DMA read throughput is: 342.58 MB/s
    [  477.676097] Write DMA to DSP ...
    [  477.691512] Generating interrupt to DSP ...
    [  477.819711] Interrupt 12 received from DSP
    [  477.820002] Read DMA from DSP ...
    [  477.820002] rDataVirt[576]=0x00
    [  477.820002] rDataVirt[577]=0x00
    [  477.820002] rDataVirt[578]=0x00
    [  477.820002] rDataVirt[579]=0x00
    [  477.820002] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  478.737961] DMA write throughput is: 329.02 MB/s
    [  478.741100] DMA read throughput is: 342.55 MB/s
    [  478.756533] Write DMA to DSP ...
    [  478.771723] Generating interrupt to DSP ...
    [  478.899659] Interrupt 12 received from DSP
    [  478.900014] Read DMA from DSP ...
    [  478.900014] DMA test passed!
    [  479.766693] DMA write throughput is: 329.05 MB/s
    [  479.769570] DMA read throughput is: 342.58 MB/s
    [  479.785013] Write DMA to DSP ...
    [  479.800090] Generating interrupt to DSP ...
    [  479.927969] Interrupt 12 received from DSP
    [  479.930913] Read DMA from DSP ...
    [  479.931943] DMA test passed!
    [  480.795011] DMA write throughput is: 328.89 MB/s
    [  480.797873] DMA read throughput is: 342.58 MB/s
    [  480.813020] Write DMA to DSP ...
    [  480.827943] Generating interrupt to DSP ...
    [  480.955596] Interrupt 12 received from DSP
    [  480.956002] Read DMA from DSP ...
    [  480.956002] DMA test passed!
    [  481.859781] DMA write throughput is: 329.16 MB/s
    [  481.862370] DMA read throughput is: 342.55 MB/s
    [  481.877175] Write DMA to DSP ...
    [  481.891780] Generating interrupt to DSP ...
    [  482.019152] Interrupt 12 received from DSP
    [  482.021562] Read DMA from DSP ...
    [  482.023125] DMA test passed!
    [  482.886185] DMA write throughput is: 328.97 MB/s
    [  482.888544] DMA read throughput is: 342.61 MB/s
    [  482.903227] Write DMA to DSP ...
    [  482.917680] Generating interrupt to DSP ...
    [  483.044861] Interrupt 12 received from DSP
    [  483.047078] Read DMA from DSP ...
    [  483.048002] rDataVirt[576]=0x00
    [  483.048002] rDataVirt[577]=0x00
    [  483.048002] rDataVirt[578]=0x00
    [  483.048002] rDataVirt[579]=0x00
    [  483.048002] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  483.956701] DMA write throughput is: 329.02 MB/s
    [  483.958034] DMA read throughput is: 342.46 MB/s
    [  483.966463] Write DMA to DSP ...
    [  483.979992] Generating interrupt to DSP ...
    [  484.106279] Interrupt 12 received from DSP
    [  484.107608] Read DMA from DSP ...
    [  484.110256] rDataVirt[576]=0x00
    [  484.110256] rDataVirt[577]=0x00
    [  484.110256] rDataVirt[578]=0x00
    [  484.110256] rDataVirt[579]=0x00
    [  484.110256] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  484.973265] DMA write throughput is: 329.00 MB/s
    [  484.974559] DMA read throughput is: 342.70 MB/s
    [  484.982801] Write DMA to DSP ...
    [  484.996299] Generating interrupt to DSP ...
    [  485.122558] Interrupt 12 received from DSP
    [  485.123857] Read DMA from DSP ...
    [  485.124001] rDataVirt[576]=0x00
    [  485.124001] rDataVirt[577]=0x00
    [  485.124001] rDataVirt[578]=0x00
    [  485.124001] rDataVirt[579]=0x00
    [  485.124001] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  486.019785] DMA write throughput is: 328.97 MB/s
    [  486.021105] DMA read throughput is: 342.72 MB/s
    [  486.029379] Write DMA to DSP ...
    [  486.042854] Generating interrupt to DSP ...
    [  486.169115] Interrupt 12 received from DSP
    [  486.170419] Read DMA from DSP ...
    [  486.173091] DMA test passed!
    [  487.036100] DMA write throughput is: 328.92 MB/s
    [  487.037416] DMA read throughput is: 342.67 MB/s
    [  487.038703] Freeing consistent memory ...
    [  495.100216] Start rmmod procedure !!!!!!!!
    [  495.102396] Start local reset assert for core (module id): 15 ...
    [  495.104611] Start local reset assert for core (module id): 16 ...
    [  495.106789] Start local reset assert for core (module id): 17 ...
    [  495.108976] Start local reset assert for core (module id): 18 ...
    [  495.111106] Start local reset assert for core (module id): 19 ...
    [  495.113219] Start local reset assert for core (module id): 20 ...
    [  495.115356] Start local reset assert for core (module id): 21 ...
    [  495.117468] Start local reset assert for core (module id): 22 ...
    [  495.126544] Boot entry address is 0x  878000
    [  495.128692] Total 3 sections, 0x748 bytes of data were written
    [  495.131812] Boot entry address is 0x  878000
    [  495.134017] Total 3 sections, 0x748 bytes of data were written
    [  495.137262] Boot entry address is 0x  878000
    [  495.139490] Total 3 sections, 0x748 bytes of data were written
    [  495.142738] Boot entry address is 0x  878000
    [  495.145012] Total 3 sections, 0x748 bytes of data were written
    [  495.148262] Boot entry address is 0x  878000
    [  495.150567] Total 3 sections, 0x748 bytes of data were written
    [  495.153857] Boot entry address is 0x  878000
    [  495.156206] Total 3 sections, 0x748 bytes of data were written
    [  495.159489] Boot entry address is 0x  878000
    [  495.161861] Total 3 sections, 0x748 bytes of data were written
    [  495.165173] Boot entry address is 0x  878000
    [  495.167516] Total 3 sections, 0x748 bytes of data were written
    [  495.187821] MD stat for pid 2 mid 9 state: 3 timeout
    [  495.193321] Start local reset de-assert for core (module id): 15 ...
    [  495.195745] Start local reset de-assert for core (module id): 16 ...
    [  495.198273] Start local reset de-assert for core (module id): 17 ...
    [  495.200759] Start local reset de-assert for core (module id): 18 ...
    [  495.203233] Start local reset de-assert for core (module id): 19 ...
    [  495.205691] Start local reset de-assert for core (module id): 20 ...
    [  495.208093] Start local reset de-assert for core (module id): 21 ...
    [  495.210320] Start local reset de-assert for core (module id): 22 ...
    [  497.241767] Finding the device....
    [  497.244459] Found TI device
    [  497.246702] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  497.249022] Reading the BAR areas....
    [  497.254028] Enabling the device....
    [  497.256402] pci 0000:01:00.0: setting latency timer to 64
    [  497.256416] Access PCIE application register ....
    [  497.258803] Registering the irq 16 ...
    [  497.261182] Allocating consistent memory  start...
    [  497.267526] Allocating consistent memory end...
    [  497.282274] Finish DMA_TRANSFER_SIZE
    [  497.284658] Boot entry address is 0x  82e2c0
    [  497.287955] Total 5 sections, 0xf30c bytes of data were written
    [  497.290347] Finish pushData
    [  497.292722] Finish writeDSPMemory
    [  497.356569] Waiting #1 of MAGIC_ADDR=0 is OK
    [  497.358963] j = 46230
    [  499.357678] Write DMA to DSP ...
    [  499.372334] Generating interrupt to DSP ...
    [  499.499707] Interrupt 16 received from DSP
    [  499.502121] Read DMA from DSP ...
    [  499.503698] DMA test passed!
    [  500.366760] DMA write throughput is: 329.08 MB/s
    [  500.369198] DMA read throughput is: 342.61 MB/s
    [  500.384089] Write DMA to DSP ...
    [  500.398660] Generating interrupt to DSP ...
    [  500.526062] Interrupt 16 received from DSP
    [  500.528470] Read DMA from DSP ...
    [  500.530053] DMA test passed!
    [  501.393096] DMA write throughput is: 328.89 MB/s
    [  501.395503] DMA read throughput is: 342.58 MB/s
    [  501.410182] Write DMA to DSP ...
    [  501.424691] Generating interrupt to DSP ...
    [  501.551983] Interrupt 16 received from DSP
    [  501.552002] Read DMA from DSP ...
    [  501.552002] rDataVirt[576]=0x00
    [  501.552002] rDataVirt[577]=0x00
    [  501.552002] rDataVirt[578]=0x00
    [  501.552002] rDataVirt[579]=0x00
    [  501.552002] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  502.465029] DMA write throughput is: 329.16 MB/s
    [  502.467432] DMA read throughput is: 342.58 MB/s
    [  502.482187] Write DMA to DSP ...
    [  502.496750] Generating interrupt to DSP ...
    [  502.624048] Interrupt 16 received from DSP
    [  502.626389] Read DMA from DSP ...
    [  502.628039] DMA test passed!
    [  503.491078] DMA write throughput is: 329.02 MB/s
    [  503.493390] DMA read throughput is: 342.58 MB/s
    [  503.507991] Write DMA to DSP ...
    [  503.522444] Generating interrupt to DSP ...
    [  503.649650] Interrupt 16 received from DSP
    [  503.651884] Read DMA from DSP ...
    [  503.653641] DMA test passed!
    [  504.516682] DMA write throughput is: 329.00 MB/s
    [  504.518882] DMA read throughput is: 342.58 MB/s
    [  504.533364] Write DMA to DSP ...
    [  504.547679] Generating interrupt to DSP ...
    [  504.674818] Interrupt 16 received from DSP
    [  504.676003] Read DMA from DSP ...
    [  504.676003] rDataVirt[576]=0x00
    [  504.676003] rDataVirt[577]=0x00
    [  504.676003] rDataVirt[578]=0x00
    [  504.676003] rDataVirt[579]=0x00
    [  504.676003] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  505.586596] DMA write throughput is: 329.16 MB/s
    [  505.588796] DMA read throughput is: 342.58 MB/s
    [  505.603399] Write DMA to DSP ...
    [  505.617744] Generating interrupt to DSP ...
    [  505.744836] Interrupt 16 received from DSP
    [  505.746994] Read DMA from DSP ...
    [  505.748827] DMA test passed!
    [  506.611822] DMA write throughput is: 329.13 MB/s
    [  506.613186] DMA read throughput is: 342.61 MB/s
    [  506.621520] Write DMA to DSP ...
    [  506.635035] Generating interrupt to DSP ...
    [  506.761336] Interrupt 16 received from DSP
    [  506.762671] Read DMA from DSP ...
    [  506.764001] rDataVirt[576]=0x00
    [  506.764001] rDataVirt[577]=0x00
    [  506.764001] rDataVirt[578]=0x00
    [  506.764001] rDataVirt[579]=0x00
    [  506.764001] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  507.658794] DMA write throughput is: 329.00 MB/s
    [  507.660114] DMA read throughput is: 342.61 MB/s
    [  507.668394] Write DMA to DSP ...
    [  507.681869] Generating interrupt to DSP ...
    [  507.808150] Interrupt 16 received from DSP
    [  507.809447] Read DMA from DSP ...
    [  507.812143] rDataVirt[576]=0x00
    [  507.812143] rDataVirt[577]=0x00
    [  507.812143] rDataVirt[578]=0x00
    [  507.812143] rDataVirt[579]=0x00
    [  507.812143] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  508.675116] DMA write throughput is: 329.13 MB/s
    [  508.676397] DMA read throughput is: 342.67 MB/s
    [  508.684635] Write DMA to DSP ...
    [  508.698046] Generating interrupt to DSP ...
    [  508.824249] Interrupt 16 received from DSP
    [  508.825498] Read DMA from DSP ...
    [  508.828002] rDataVirt[576]=0x00
    [  508.828002] rDataVirt[577]=0x00
    [  508.828002] rDataVirt[578]=0x00
    [  508.828002] rDataVirt[579]=0x00
    [  508.828002] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  509.721351] DMA write throughput is: 329.10 MB/s
    [  509.722612] DMA read throughput is: 342.64 MB/s
    [  509.723857] Freeing consistent memory ...
    [  512.062000] Start rmmod procedure !!!!!!!!
    [  512.064139] Start local reset assert for core (module id): 15 ...
    [  512.066336] Start local reset assert for core (module id): 16 ...
    [  512.068466] Start local reset assert for core (module id): 17 ...
    [  512.070558] Start local reset assert for core (module id): 18 ...
    [  512.072624] Start local reset assert for core (module id): 19 ...
    [  512.074654] Start local reset assert for core (module id): 20 ...
    [  512.076676] Start local reset assert for core (module id): 21 ...
    [  512.078657] Start local reset assert for core (module id): 22 ...
    [  512.089608] Boot entry address is 0x  878000
    [  512.091592] Total 3 sections, 0x748 bytes of data were written
    [  512.094590] Boot entry address is 0x  878000
    [  512.096629] Total 3 sections, 0x748 bytes of data were written
    [  512.099645] Boot entry address is 0x  878000
    [  512.101715] Total 3 sections, 0x748 bytes of data were written
    [  512.104762] Boot entry address is 0x  878000
    [  512.106853] Total 3 sections, 0x748 bytes of data were written
    [  512.109980] Boot entry address is 0x  878000
    [  512.112171] Total 3 sections, 0x748 bytes of data were written
    [  512.115370] Boot entry address is 0x  878000
    [  512.117605] Total 3 sections, 0x748 bytes of data were written
    [  512.120810] Boot entry address is 0x  878000
    [  512.123039] Total 3 sections, 0x748 bytes of data were written
    [  512.126277] Boot entry address is 0x  878000
    [  512.128555] Total 3 sections, 0x748 bytes of data were written
    [  512.148729] MD stat for pid 2 mid 9 state: 3 timeout
    [  512.154009] Start local reset de-assert for core (module id): 15 ...
    [  512.156358] Start local reset de-assert for core (module id): 16 ...
    [  512.158653] Start local reset de-assert for core (module id): 17 ...
    [  512.160928] Start local reset de-assert for core (module id): 18 ...
    [  512.163169] Start local reset de-assert for core (module id): 19 ...
    [  512.165386] Start local reset de-assert for core (module id): 20 ...
    [  512.167577] Start local reset de-assert for core (module id): 21 ...
    [  512.169756] Start local reset de-assert for core (module id): 22 ...
    [  513.769865] Finding the device....
    [  513.772470] Found TI device
    [  513.774833] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  513.777228] Reading the BAR areas....
    [  513.782838] Enabling the device....
    [  513.785302] pci 0000:01:00.0: setting latency timer to 64
    [  513.785316] Access PCIE application register ....
    [  513.787706] Registering the irq 16 ...
    [  513.790216] Allocating consistent memory  start...
    [  513.798814] Allocating consistent memory end...
    [  513.814372] Finish DMA_TRANSFER_SIZE
    [  513.816798] Boot entry address is 0x  82e2c0
    [  513.820319] Total 5 sections, 0xf30c bytes of data were written
    [  513.822943] Finish pushData
    [  513.825358] Finish writeDSPMemory
    [  513.889289] Waiting #1 of MAGIC_ADDR=0 is OK
    [  513.891650] j = 46238
    [  515.890066] Write DMA to DSP ...
    [  515.904605] Generating interrupt to DSP ...
    [  516.031879] Interrupt 16 received from DSP
    [  516.034232] Read DMA from DSP ...
    [  516.035870] DMA test passed!
    [  516.898837] DMA write throughput is: 329.10 MB/s
    [  516.901239] DMA read throughput is: 342.58 MB/s
    [  516.915980] Write DMA to DSP ...
    [  516.930630] Generating interrupt to DSP ...
    [  517.058010] Interrupt 16 received from DSP
    [  517.060002] Read DMA from DSP ...
    [  517.060002] DMA test passed!
    [  517.962745] DMA write throughput is: 328.89 MB/s
    [  517.964237] DMA read throughput is: 342.49 MB/s
    [  517.972670] Write DMA to DSP ...
    [  517.986273] Generating interrupt to DSP ...
    [  518.112653] Interrupt 16 received from DSP
    [  518.114130] Read DMA from DSP ...
    [  518.116645] DMA test passed!
    [  518.979519] DMA write throughput is: 329.10 MB/s
    [  518.981056] DMA read throughput is: 342.67 MB/s
    [  518.989559] Write DMA to DSP ...
    [  519.003339] Generating interrupt to DSP ...
    [  519.129807] Interrupt 16 received from DSP
    [  519.131338] Read DMA from DSP ...
    [  519.132001] DMA test passed!
    [  520.022577] DMA write throughput is: 329.02 MB/s
    [  520.024113] DMA read throughput is: 342.61 MB/s
    [  520.032552] Write DMA to DSP ...
    [  520.046197] Generating interrupt to DSP ...
    [  520.172590] Interrupt 16 received from DSP
    [  520.174056] Read DMA from DSP ...
    [  520.176582] DMA test passed!
    [  521.039455] DMA write throughput is: 329.05 MB/s
    [  521.040904] DMA read throughput is: 342.70 MB/s
    [  521.049299] Write DMA to DSP ...
    [  521.062879] Generating interrupt to DSP ...
    [  521.189214] Interrupt 16 received from DSP
    [  521.190613] Read DMA from DSP ...
    [  521.192001] rDataVirt[576]=0x00
    [  521.192001] rDataVirt[577]=0x00
    [  521.192001] rDataVirt[578]=0x00
    [  521.192001] rDataVirt[579]=0x00
    [  521.192001] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  522.087011] DMA write throughput is: 328.94 MB/s
    [  522.088435] DMA read throughput is: 342.75 MB/s
    [  522.096882] Write DMA to DSP ...
    [  522.110530] Generating interrupt to DSP ...
    [  522.236897] Interrupt 16 received from DSP
    [  522.238295] Read DMA from DSP ...
    [  522.240889] DMA test passed!
    [  523.103762] DMA write throughput is: 328.89 MB/s
    [  523.105195] DMA read throughput is: 342.70 MB/s
    [  523.113543] Write DMA to DSP ...
    [  523.127091] Generating interrupt to DSP ...
    [  523.253396] Interrupt 16 received from DSP
    [  523.254779] Read DMA from DSP ...
    [  523.256001] rDataVirt[576]=0x00
    [  523.256001] rDataVirt[577]=0x00
    [  523.256001] rDataVirt[578]=0x00
    [  523.256001] rDataVirt[579]=0x00
    [  523.256001] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  524.151061] DMA write throughput is: 329.13 MB/s
    [  524.152417] DMA read throughput is: 342.70 MB/s
    [  524.160741] Write DMA to DSP ...
    [  524.174239] Generating interrupt to DSP ...
    [  524.300499] Interrupt 16 received from DSP
    [  524.301838] Read DMA from DSP ...
    [  524.304491] DMA test passed!
    [  525.167366] DMA write throughput is: 329.10 MB/s
    [  525.168734] DMA read throughput is: 342.72 MB/s
    [  525.177069] Write DMA to DSP ...
    [  525.190566] Generating interrupt to DSP ...
    [  525.316831] Interrupt 16 received from DSP
    [  525.318164] Read DMA from DSP ...
    [  525.320001] DMA test passed!
    [  526.209049] DMA write throughput is: 329.10 MB/s
    [  526.210396] DMA read throughput is: 342.70 MB/s
    [  526.211724] Freeing consistent memory ...
    [  528.682753] Start rmmod procedure !!!!!!!!
    [  528.685013] Start local reset assert for core (module id): 15 ...
    [  528.687269] Start local reset assert for core (module id): 16 ...
    [  528.689513] Start local reset assert for core (module id): 17 ...
    [  528.691720] Start local reset assert for core (module id): 18 ...
    [  528.693908] Start local reset assert for core (module id): 19 ...
    [  528.696083] Start local reset assert for core (module id): 20 ...
    [  528.698208] Start local reset assert for core (module id): 21 ...
    [  528.700309] Start local reset assert for core (module id): 22 ...
    [  528.711371] Boot entry address is 0x  878000
    [  528.713501] Total 3 sections, 0x748 bytes of data were written
    [  528.716608] Boot entry address is 0x  878000
    [  528.718741] Total 3 sections, 0x748 bytes of data were written
    [  528.721881] Boot entry address is 0x  878000
    [  528.724061] Total 3 sections, 0x748 bytes of data were written
    [  528.727217] Boot entry address is 0x  878000
    [  528.729430] Total 3 sections, 0x748 bytes of data were written
    [  528.732643] Boot entry address is 0x  878000
    [  528.734877] Total 3 sections, 0x748 bytes of data were written
    [  528.738113] Boot entry address is 0x  878000
    [  528.740387] Total 3 sections, 0x748 bytes of data were written
    [  528.743646] Boot entry address is 0x  878000
    [  528.745971] Total 3 sections, 0x748 bytes of data were written
    [  528.749273] Boot entry address is 0x  878000
    [  528.751605] Total 3 sections, 0x748 bytes of data were written
    [  528.771876] MD stat for pid 2 mid 9 state: 3 timeout
    [  528.777284] Start local reset de-assert for core (module id): 15 ...
    [  528.779755] Start local reset de-assert for core (module id): 16 ...
    [  528.782189] Start local reset de-assert for core (module id): 17 ...
    [  528.784591] Start local reset de-assert for core (module id): 18 ...
    [  528.786945] Start local reset de-assert for core (module id): 19 ...
    [  528.789283] Start local reset de-assert for core (module id): 20 ...
    [  528.791587] Start local reset de-assert for core (module id): 21 ...
    [  528.793886] Start local reset de-assert for core (module id): 22 ...
    [  530.730044] Finding the device....
    [  530.732462] Found TI device
    [  530.734766] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  530.737116] Reading the BAR areas....
    [  530.742782] Enabling the device....
    [  530.745136] pci 0000:01:00.0: setting latency timer to 64
    [  530.745149] Access PCIE application register ....
    [  530.747492] Registering the irq 16 ...
    [  530.749862] Allocating consistent memory  start...
    [  530.756251] Allocating consistent memory end...
    [  530.771006] Finish DMA_TRANSFER_SIZE
    [  530.773484] Boot entry address is 0x  82e2c0
    [  530.776882] Total 5 sections, 0xf30c bytes of data were written
    [  530.779324] Finish pushData
    [  530.781740] Finish writeDSPMemory
    [  530.845655] Waiting #1 of MAGIC_ADDR=0 is OK
    [  530.848086] j = 46238
    [  532.846573] Write DMA to DSP ...
    [  532.861200] Generating interrupt to DSP ...
    [  532.988536] Interrupt 16 received from DSP
    [  532.990948] Read DMA from DSP ...
    [  532.992003] DMA test passed!
    [  533.892109] DMA write throughput is: 328.97 MB/s
    [  533.894516] DMA read throughput is: 342.49 MB/s
    [  533.909275] Write DMA to DSP ...
    [  533.923859] Generating interrupt to DSP ...
    [  534.051208] Interrupt 16 received from DSP
    [  534.052709] Read DMA from DSP ...
    [  534.055200] DMA test passed!
    [  534.919137] DMA write throughput is: 329.13 MB/s
    [  534.920636] DMA read throughput is: 342.70 MB/s
    [  534.929072] Write DMA to DSP ...
    [  534.942692] Generating interrupt to DSP ...
    [  535.069089] Interrupt 16 received from DSP
    [  535.070569] Read DMA from DSP ...
    [  535.072001] rDataVirt[576]=0x00
    [  535.072001] rDataVirt[577]=0x00
    [  535.072001] rDataVirt[578]=0x00
    [  535.072001] rDataVirt[579]=0x00
    [  535.072001] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  535.967724] DMA write throughput is: 328.89 MB/s
    [  535.969231] DMA read throughput is: 342.64 MB/s
    [  535.977689] Write DMA to DSP ...
    [  535.991345] Generating interrupt to DSP ...
    [  536.117735] Interrupt 16 received from DSP
    [  536.119191] Read DMA from DSP ...
    [  536.120001] DMA test passed!
    [  537.010278] DMA write throughput is: 329.05 MB/s
    [  537.011733] DMA read throughput is: 342.70 MB/s
    [  537.020114] Write DMA to DSP ...
    [  537.033684] Generating interrupt to DSP ...
    [  537.160002] Interrupt 16 received from DSP
    [  537.161391] Read DMA from DSP ...
    [  537.163994] DMA test passed!
    [  538.026869] DMA write throughput is: 329.08 MB/s
    [  538.028251] DMA read throughput is: 342.72 MB/s
    [  538.036590] Write DMA to DSP ...
    [  538.050121] Generating interrupt to DSP ...
    [  538.176388] Interrupt 16 received from DSP
    [  538.177757] Read DMA from DSP ...
    [  538.180001] rDataVirt[576]=0x00
    [  538.180001] rDataVirt[577]=0x00
    [  538.180001] rDataVirt[578]=0x00
    [  538.180001] rDataVirt[579]=0x00
    [  538.180001] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  539.074211] DMA write throughput is: 328.92 MB/s
    [  539.075571] DMA read throughput is: 342.70 MB/s
    [  539.084098] Write DMA to DSP ...
    [  539.097629] Generating interrupt to DSP ...
    [  539.223897] Interrupt 16 received from DSP
    [  539.225245] Read DMA from DSP ...
    [  539.227888] DMA test passed!
    [  540.090763] DMA write throughput is: 328.97 MB/s
    [  540.092149] DMA read throughput is: 342.72 MB/s
    [  540.100570] Write DMA to DSP ...
    [  540.114078] Generating interrupt to DSP ...
    [  540.240349] Interrupt 16 received from DSP
    [  540.241686] Read DMA from DSP ...
    [  540.244001] DMA test passed!
    [  541.132560] DMA write throughput is: 329.16 MB/s
    [  541.133901] DMA read throughput is: 342.70 MB/s
    [  541.142219] Write DMA to DSP ...
    [  541.155717] Generating interrupt to DSP ...
    [  541.281992] Interrupt 16 received from DSP
    [  541.283326] Read DMA from DSP ...
    [  541.285984] DMA test passed!
    [  542.148859] DMA write throughput is: 329.08 MB/s
    [  542.150203] DMA read throughput is: 342.67 MB/s
    [  542.158552] Write DMA to DSP ...
    [  542.172058] Generating interrupt to DSP ...
    [  542.298310] Interrupt 16 received from DSP
    [  542.299646] Read DMA from DSP ...
    [  542.300001] rDataVirt[576]=0x00
    [  542.300001] rDataVirt[577]=0x00
    [  542.300001] rDataVirt[578]=0x00
    [  542.300001] rDataVirt[579]=0x00
    [  542.300001] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  543.195651] DMA write throughput is: 328.97 MB/s
    [  543.196983] DMA read throughput is: 342.75 MB/s
    [  543.198303] Freeing consistent memory ...
    [  553.382889] Start rmmod procedure !!!!!!!!
    [  553.385155] Start local reset assert for core (module id): 15 ...
    [  553.387450] Start local reset assert for core (module id): 16 ...
    [  553.389725] Start local reset assert for core (module id): 17 ...
    [  553.391934] Start local reset assert for core (module id): 18 ...
    [  553.394121] Start local reset assert for core (module id): 19 ...
    [  553.396292] Start local reset assert for core (module id): 20 ...
    [  553.398417] Start local reset assert for core (module id): 21 ...
    [  553.400525] Start local reset assert for core (module id): 22 ...
    [  553.411589] Boot entry address is 0x  878000
    [  553.413721] Total 3 sections, 0x748 bytes of data were written
    [  553.416831] Boot entry address is 0x  878000
    [  553.418972] Total 3 sections, 0x748 bytes of data were written
    [  553.422106] Boot entry address is 0x  878000
    [  553.424288] Total 3 sections, 0x748 bytes of data were written
    [  553.427447] Boot entry address is 0x  878000
    [  553.429664] Total 3 sections, 0x748 bytes of data were written
    [  553.432865] Boot entry address is 0x  878000
    [  553.435102] Total 3 sections, 0x748 bytes of data were written
    [  553.438339] Boot entry address is 0x  878000
    [  553.440653] Total 3 sections, 0x748 bytes of data were written
    [  553.443913] Boot entry address is 0x  878000
    [  553.446227] Total 3 sections, 0x748 bytes of data were written
    [  553.449535] Boot entry address is 0x  878000
    [  553.451867] Total 3 sections, 0x748 bytes of data were written
    [  553.472142] MD stat for pid 2 mid 9 state: 3 timeout
    [  553.477535] Start local reset de-assert for core (module id): 15 ...
    [  553.480020] Start local reset de-assert for core (module id): 16 ...
    [  553.482444] Start local reset de-assert for core (module id): 17 ...
    [  553.484841] Start local reset de-assert for core (module id): 18 ...
    [  553.487201] Start local reset de-assert for core (module id): 19 ...
    [  553.489543] Start local reset de-assert for core (module id): 20 ...
    [  553.491853] Start local reset de-assert for core (module id): 21 ...
    [  553.494154] Start local reset de-assert for core (module id): 22 ...
    [  554.666346] Finding the device....
    [  554.668746] Found TI device
    [  554.671048] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  554.673394] Reading the BAR areas....
    [  554.679048] Enabling the device....
    [  554.681408] pci 0000:01:00.0: setting latency timer to 64
    [  554.681422] Access PCIE application register ....
    [  554.683767] Registering the irq 16 ...
    [  554.686146] Allocating consistent memory  start...
    [  554.692510] Allocating consistent memory end...
    [  554.707206] Finish DMA_TRANSFER_SIZE
    [  554.709593] Boot entry address is 0x  82e2c0
    [  554.712930] Total 5 sections, 0xf30c bytes of data were written
    [  554.715314] Finish pushData
    [  554.717673] Finish writeDSPMemory
    [  554.781550] Waiting #1 of MAGIC_ADDR=0 is OK
    [  554.783915] j = 46214
    [  556.782354] Write DMA to DSP ...
    [  556.796925] Generating interrupt to DSP ...
    [  556.924198] Interrupt 16 received from DSP
    [  556.926546] Read DMA from DSP ...
    [  556.928190] DMA test passed!
    [  557.791164] DMA write throughput is: 328.86 MB/s
    [  557.793575] DMA read throughput is: 342.61 MB/s
    [  557.808402] Write DMA to DSP ...
    [  557.823000] Generating interrupt to DSP ...
    [  557.950382] Interrupt 16 received from DSP
    [  557.952002] Read DMA from DSP ...
    [  557.952002] DMA test passed!
    [  558.853850] DMA write throughput is: 329.13 MB/s
    [  558.856247] DMA read throughput is: 342.55 MB/s
    [  558.870943] Write DMA to DSP ...
    [  558.885449] Generating interrupt to DSP ...
    [  559.012710] Interrupt 16 received from DSP
    [  559.014193] Read DMA from DSP ...
    [  559.016702] rDataVirt[576]=0x00
    [  559.016702] rDataVirt[577]=0x00
    [  559.016702] rDataVirt[578]=0x00
    [  559.016702] rDataVirt[579]=0x00
    [  559.016702] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  559.887196] DMA write throughput is: 329.00 MB/s
    [  559.888712] DMA read throughput is: 342.67 MB/s
    [  559.897195] Write DMA to DSP ...
    [  559.910830] Generating interrupt to DSP ...
    [  560.037218] Interrupt 16 received from DSP
    [  560.038668] Read DMA from DSP ...
    [  560.040001] rDataVirt[576]=0x00
    [  560.040001] rDataVirt[577]=0x00
    [  560.040001] rDataVirt[578]=0x00
    [  560.040001] rDataVirt[579]=0x00
    [  560.040001] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  560.935156] DMA write throughput is: 328.97 MB/s
    [  560.936515] DMA read throughput is: 342.64 MB/s
    [  560.944844] Write DMA to DSP ...
    [  560.958336] Generating interrupt to DSP ...
    [  561.084576] Interrupt 16 received from DSP
    [  561.085883] Read DMA from DSP ...
    [  561.088478] DMA test passed!
    [  561.951439] DMA write throughput is: 328.94 MB/s
    [  561.952782] DMA read throughput is: 342.70 MB/s
    [  561.961136] Write DMA to DSP ...
    [  561.974656] Generating interrupt to DSP ...
    [  562.100953] Interrupt 16 received from DSP
    [  562.102336] Read DMA from DSP ...
    [  562.104002] rDataVirt[576]=0x00
    [  562.104002] rDataVirt[577]=0x00
    [  562.104002] rDataVirt[578]=0x00
    [  562.104002] rDataVirt[579]=0x00
    [  562.104002] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  562.998540] DMA write throughput is: 328.97 MB/s
    [  562.999844] DMA read throughput is: 342.55 MB/s
    [  563.008260] Write DMA to DSP ...
    [  563.021726] Generating interrupt to DSP ...
    [  563.147948] Interrupt 16 received from DSP
    [  563.149261] Read DMA from DSP ...
    [  563.151939] DMA test passed!
    [  564.014816] DMA write throughput is: 328.97 MB/s
    [  564.016162] DMA read throughput is: 342.70 MB/s
    [  564.024446] Write DMA to DSP ...
    [  564.037928] Generating interrupt to DSP ...
    [  564.164147] Interrupt 16 received from DSP
    [  564.165443] Read DMA from DSP ...
    [  564.168001] rDataVirt[576]=0x00
    [  564.168001] rDataVirt[577]=0x00
    [  564.168001] rDataVirt[578]=0x00
    [  564.168001] rDataVirt[579]=0x00
    [  564.168001] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  565.061314] DMA write throughput is: 328.86 MB/s
    [  565.062579] DMA read throughput is: 342.70 MB/s
    [  565.070802] Write DMA to DSP ...
    [  565.084263] Generating interrupt to DSP ...
    [  565.210442] Interrupt 16 received from DSP
    [  565.211706] Read DMA from DSP ...
    [  565.214433] DMA test passed!
    [  566.077309] DMA write throughput is: 329.05 MB/s
    [  566.078578] DMA read throughput is: 342.72 MB/s
    [  566.086812] Write DMA to DSP ...
    [  566.100317] Generating interrupt to DSP ...
    [  566.226498] Interrupt 16 received from DSP
    [  566.227763] Read DMA from DSP ...
    [  566.228002] rDataVirt[576]=0x00
    [  566.228002] rDataVirt[577]=0x00
    [  566.228002] rDataVirt[578]=0x00
    [  566.228002] rDataVirt[579]=0x00
    [  566.228002] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  567.123546] DMA write throughput is: 329.02 MB/s
    [  567.124830] DMA read throughput is: 342.67 MB/s
    [  567.126089] Freeing consistent memory ...
    administrator@vict:~$
  • I am using initial version of C6678 EVM Rev 1.0. I think it is not a EVM hardware issue, better to try the same test on another Linux machine.
    Can you inform me what version of the PCIe adapter card you are using now? I am using latest version 17-00107-03.
    I have done four experiments:
    (1) Mother board: GA-G31M-ES2C
    OS: Debian7 Linux 3.2.0-4
    Result: Errors. Please look *log.txt in the previous post.
    (2) Mother board: GA-G31M-ES2C
    OS: Ubuntu14.04 Linux 3.13.0-32
    Result: similar to (1)
    (3) Mother board: ASUS P5Q-VM
    Result: Similar to (1) and new errors. Please look *log3.txt attached below.
    Also the strange throughput values, almost twice more than in the original example:
    DMA write throughput is: 658.00 MB/s
    DMA read throughput is: 658.54 MB/s
    (4) Mother board: ASUS P5Q-VM
    OS: Ubuntu10.04 Linux 2.6.38-10
    Result: Error during interrupt from DSP to Host
    (I corrected file grub:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash irqpoll"
    then 'update-grub', but though Host didn't get interrupt)
    Thank you,
    Viktor.
    [  108.293753] Finding the device....
    [  108.293770] Found TI device
    [  108.293771] TI device: vendor=0x104c, dev=0xb005, irq=0x0000000a
    [  108.293773] Reading the BAR areas....
    [  108.295443] Enabling the device....
    [  108.295456] pci 0000:01:00.0: setting latency timer to 64
    [  108.295463] Access PCIE application register ....
    [  108.295464] Registering the irq 10 ...
    [  108.295477] Allocating consistent memory  start...
    [  108.297473] Allocating consistent memory end...
    [  108.304762] Finish DMA_TRANSFER_SIZE
    [  108.304766] Boot entry address is 0x  82e2c0
    [  108.305364] Total 5 sections, 0xf30c bytes of data were written
    [  108.305366] Finish pushData
    [  108.305368] Finish writeDSPMemory
    [  108.370153] Waiting #1 of MAGIC_ADDR=0 is OK
    [  108.370155] j = 61078
    [  110.361606] Write DMA to DSP ...
    [  110.367686] Generating interrupt to DSP ...
    [  110.492652] Interrupt 10 received from DSP
    [  110.492654] Read DMA from DSP ...
    [  110.496622] rDataVirt[576]=0x00
    [  110.496622] rDataVirt[577]=0x00
    [  110.496622] rDataVirt[578]=0x00
    [  110.496622] rDataVirt[579]=0x00
    [  110.496622] rDataVirt[4192]=0x01
    [  110.496622] rDataVirt[4193]=0x00
    [  110.496622] rDataVirt[4194]=0x00
    [  110.496622] rDataVirt[4195]=0x00
    [  110.496622] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  111.359783] DMA write throughput is: 658.00 MB/s
    [  111.359786] DMA read throughput is: 658.54 MB/s
    [  111.367081] Write DMA to DSP ...
    [  111.373159] Generating interrupt to DSP ...
    [  111.498115] Interrupt 10 received from DSP
    [  111.498117] Read DMA from DSP ...
    [  111.500000] rDataVirt[576]=0x00
    [  111.500000] rDataVirt[577]=0x00
    [  111.500000] rDataVirt[578]=0x00
    [  111.500000] rDataVirt[579]=0x00
    [  111.500000] rDataVirt[4192]=0x01
    [  111.500000] rDataVirt[4193]=0x00
    [  111.500000] rDataVirt[4194]=0x00
    [  111.500000] rDataVirt[4195]=0x00
    [  111.500000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  112.381985] DMA write throughput is: 658.54 MB/s
    [  112.381988] DMA read throughput is: 659.19 MB/s
    [  112.389289] Write DMA to DSP ...
    [  112.395368] Generating interrupt to DSP ...
    [  112.520329] Interrupt 10 received from DSP
    [  112.520332] Read DMA from DSP ...
    [  112.524302] rDataVirt[576]=0x00
    [  112.524302] rDataVirt[577]=0x00
    [  112.524302] rDataVirt[578]=0x00
    [  112.524302] rDataVirt[579]=0x00
    [  112.524302] rDataVirt[4192]=0x01
    [  112.524302] rDataVirt[4193]=0x00
    [  112.524302] rDataVirt[4194]=0x00
    [  112.524302] rDataVirt[4195]=0x00
    [  112.524302] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  113.387464] DMA write throughput is: 658.11 MB/s
    [  113.387467] DMA read throughput is: 658.43 MB/s
    [  113.394929] Write DMA to DSP ...
    [  113.401008] Generating interrupt to DSP ...
    [  113.525959] Interrupt 10 received from DSP
    [  113.525961] Read DMA from DSP ...
    [  113.528000] rDataVirt[576]=0x00
    [  113.528000] rDataVirt[577]=0x00
    [  113.528000] rDataVirt[578]=0x00
    [  113.528000] rDataVirt[579]=0x00
    [  113.528000] rDataVirt[4192]=0x01
    [  113.528000] rDataVirt[4193]=0x00
    [  113.528000] rDataVirt[4194]=0x00
    [  113.528000] rDataVirt[4195]=0x00
    [  113.528000] rDataVirt[4208]=0x01
    [  113.528000] rDataVirt[4209]=0x00
    [  113.528000] rDataVirt[4210]=0x00
    [  113.528000] rDataVirt[4211]=0x00
    [  113.528000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  114.409830] DMA write throughput is: 658.76 MB/s
    [  114.409833] DMA read throughput is: 658.43 MB/s
    [  114.417131] Write DMA to DSP ...
    [  114.423209] Generating interrupt to DSP ...
    [  114.548170] Interrupt 10 received from DSP
    [  114.548173] Read DMA from DSP ...
    [  114.552143] rDataVirt[576]=0x00
    [  114.552143] rDataVirt[577]=0x00
    [  114.552143] rDataVirt[578]=0x00
    [  114.552143] rDataVirt[579]=0x00
    [  114.552143] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  115.415304] DMA write throughput is: 658.21 MB/s
    [  115.415306] DMA read throughput is: 658.43 MB/s
    [  115.422600] Write DMA to DSP ...
    [  115.428683] Generating interrupt to DSP ...
    [  115.553638] Interrupt 10 received from DSP
    [  115.553640] Read DMA from DSP ...
    [  115.556000] rDataVirt[576]=0x00
    [  115.556000] rDataVirt[577]=0x00
    [  115.556000] rDataVirt[578]=0x00
    [  115.556000] rDataVirt[579]=0x00
    [  115.556000] rDataVirt[4192]=0x01
    [  115.556000] rDataVirt[4193]=0x00
    [  115.556000] rDataVirt[4194]=0x00
    [  115.556000] rDataVirt[4195]=0x00
    [  115.556000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  116.437511] DMA write throughput is: 658.11 MB/s
    [  116.437514] DMA read throughput is: 658.43 MB/s
    [  116.444810] Write DMA to DSP ...
    [  116.450887] Generating interrupt to DSP ...
    [  116.575848] Interrupt 10 received from DSP
    [  116.575851] Read DMA from DSP ...
    [  116.579821] rDataVirt[576]=0x00
    [  116.579821] rDataVirt[577]=0x00
    [  116.579821] rDataVirt[578]=0x00
    [  116.579821] rDataVirt[579]=0x00
    [  116.579821] rDataVirt[4192]=0x01
    [  116.579821] rDataVirt[4193]=0x00
    [  116.579821] rDataVirt[4194]=0x00
    [  116.579821] rDataVirt[4195]=0x00
    [  116.579821] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  117.442981] DMA write throughput is: 658.32 MB/s
    [  117.442984] DMA read throughput is: 658.43 MB/s
    [  117.450279] Write DMA to DSP ...
    [  117.456356] Generating interrupt to DSP ...
    [  117.581310] Interrupt 10 received from DSP
    [  117.581312] Read DMA from DSP ...
    [  117.584000] rDataVirt[576]=0x00
    [  117.584000] rDataVirt[577]=0x00
    [  117.584000] rDataVirt[578]=0x00
    [  117.584000] rDataVirt[579]=0x00
    [  117.584000] rDataVirt[4192]=0x01
    [  117.584000] rDataVirt[4193]=0x00
    [  117.584000] rDataVirt[4194]=0x00
    [  117.584000] rDataVirt[4195]=0x00
    [  117.584000] rDataVirt[4208]=0x01
    [  117.584000] rDataVirt[4209]=0x00
    [  117.584000] rDataVirt[4210]=0x00
    [  117.584000] rDataVirt[4211]=0x00
    [  117.584000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  118.465184] DMA write throughput is: 658.87 MB/s
    [  118.465186] DMA read throughput is: 658.54 MB/s
    [  118.472520] Write DMA to DSP ...
    [  118.478591] Generating interrupt to DSP ...
    [  118.603543] Interrupt 10 received from DSP
    [  118.603544] Read DMA from DSP ...
    [  118.604000] rDataVirt[576]=0x00
    [  118.604000] rDataVirt[577]=0x00
    [  118.604000] rDataVirt[578]=0x00
    [  118.604000] rDataVirt[579]=0x00
    [  118.604000] rDataVirt[4192]=0x01
    [  118.604000] rDataVirt[4193]=0x00
    [  118.604000] rDataVirt[4194]=0x00
    [  118.604000] rDataVirt[4195]=0x00
    [  118.604000] rDataVirt[4208]=0x01
    [  118.604000] rDataVirt[4209]=0x00
    [  118.604000] rDataVirt[4210]=0x00
    [  118.604000] rDataVirt[4211]=0x00
    [  118.604000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  119.487406] DMA write throughput is: 658.97 MB/s
    [  119.487408] DMA read throughput is: 658.43 MB/s
    [  119.494706] Write DMA to DSP ...
    [  119.500789] Generating interrupt to DSP ...
    [  119.625750] Interrupt 10 received from DSP
    [  119.625753] Read DMA from DSP ...
    [  119.629721] rDataVirt[576]=0x00
    [  119.629721] rDataVirt[577]=0x00
    [  119.629721] rDataVirt[578]=0x00
    [  119.629721] rDataVirt[579]=0x00
    [  119.629721] rDataVirt[4192]=0x01
    [  119.629721] rDataVirt[4193]=0x00
    [  119.629721] rDataVirt[4194]=0x00
    [  119.629721] rDataVirt[4195]=0x00
    [  119.629721] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  120.492895] DMA write throughput is: 658.21 MB/s
    [  120.492897] DMA read throughput is: 658.43 MB/s
    [  120.492899] Freeing consistent memory ...
    [  127.375607] Start rmmod procedure !!!!!!!!
    [  127.375612] Start local reset assert for core (module id): 15 ...
    [  127.375617] Start local reset assert for core (module id): 16 ...
    [  127.375622] Start local reset assert for core (module id): 17 ...
    [  127.375628] Start local reset assert for core (module id): 18 ...
    [  127.375632] Start local reset assert for core (module id): 19 ...
    [  127.375637] Start local reset assert for core (module id): 20 ...
    [  127.375642] Start local reset assert for core (module id): 21 ...
    [  127.375647] Start local reset assert for core (module id): 22 ...
    [  127.382641] Boot entry address is 0x  878000
    [  127.382662] Total 3 sections, 0x748 bytes of data were written
    [  127.383655] Boot entry address is 0x  878000
    [  127.383676] Total 3 sections, 0x748 bytes of data were written
    [  127.384674] Boot entry address is 0x  878000
    [  127.384694] Total 3 sections, 0x748 bytes of data were written
    [  127.385687] Boot entry address is 0x  878000
    [  127.385708] Total 3 sections, 0x748 bytes of data were written
    [  127.386701] Boot entry address is 0x  878000
    [  127.386721] Total 3 sections, 0x748 bytes of data were written
    [  127.387715] Boot entry address is 0x  878000
    [  127.387735] Total 3 sections, 0x748 bytes of data were written
    [  127.388733] Boot entry address is 0x  878000
    [  127.388753] Total 3 sections, 0x748 bytes of data were written
    [  127.389747] Boot entry address is 0x  878000
    [  127.389767] Total 3 sections, 0x748 bytes of data were written
    [  127.407663] MD stat for pid 2 mid 9 state: 3 timeout
    [  127.410658] Start local reset de-assert for core (module id): 15 ...
    [  127.410663] Start local reset de-assert for core (module id): 16 ...
    [  127.410668] Start local reset de-assert for core (module id): 17 ...
    [  127.410673] Start local reset de-assert for core (module id): 18 ...
    [  127.410678] Start local reset de-assert for core (module id): 19 ...
    [  127.410683] Start local reset de-assert for core (module id): 20 ...
    [  127.410688] Start local reset de-assert for core (module id): 21 ...
    [  127.410693] Start local reset de-assert for core (module id): 22 ...
    [  137.757132] Finding the device....
    [  137.757154] Found TI device
    [  137.757156] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  137.757158] Reading the BAR areas....
    [  137.759450] Enabling the device....
    [  137.759458] pci 0000:01:00.0: setting latency timer to 64
    [  137.759466] Access PCIE application register ....
    [  137.759468] Registering the irq 16 ...
    [  137.759477] Allocating consistent memory  start...
    [  137.761387] Allocating consistent memory end...
    [  137.768701] Finish DMA_TRANSFER_SIZE
    [  137.768706] Boot entry address is 0x  82e2c0
    [  137.769308] Total 5 sections, 0xf30c bytes of data were written
    [  137.769309] Finish pushData
    [  137.769311] Finish writeDSPMemory
    [  137.833416] Waiting #1 of MAGIC_ADDR=0 is OK
    [  137.833418] j = 59033
    [  139.824802] Write DMA to DSP ...
    [  139.831045] Generating interrupt to DSP ...
    [  139.962355] Interrupt 16 received from DSP
    [  139.962357] Read DMA from DSP ...
    [  139.964001] rDataVirt[576]=0x00
    [  139.964001] rDataVirt[577]=0x00
    [  139.964001] rDataVirt[578]=0x00
    [  139.964001] rDataVirt[579]=0x00
    [  139.964001] rDataVirt[4192]=0x01
    [  139.964001] rDataVirt[4193]=0x00
    [  139.964001] rDataVirt[4194]=0x00
    [  139.964001] rDataVirt[4195]=0x00
    [  139.964001] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  140.839405] DMA write throughput is: 640.92 MB/s
    [  140.839407] DMA read throughput is: 640.20 MB/s
    [  140.846679] Write DMA to DSP ...
    [  140.852927] Generating interrupt to DSP ...
    [  140.984236] Interrupt 16 received from DSP
    [  140.984237] Read DMA from DSP ...
    [  140.988000] rDataVirt[576]=0x00
    [  140.988000] rDataVirt[577]=0x00
    [  140.988000] rDataVirt[578]=0x00
    [  140.988000] rDataVirt[579]=0x00
    [  140.988000] rDataVirt[4192]=0x01
    [  140.988000] rDataVirt[4193]=0x00
    [  140.988000] rDataVirt[4194]=0x00
    [  140.988000] rDataVirt[4195]=0x00
    [  140.988000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  141.861279] DMA write throughput is: 640.71 MB/s
    [  141.861281] DMA read throughput is: 640.20 MB/s
    [  141.868590] Write DMA to DSP ...
    [  141.874828] Generating interrupt to DSP ...
    [  142.006135] Interrupt 16 received from DSP
    [  142.006137] Read DMA from DSP ...
    [  142.008001] rDataVirt[576]=0x00
    [  142.008001] rDataVirt[577]=0x00
    [  142.008001] rDataVirt[578]=0x00
    [  142.008001] rDataVirt[579]=0x00
    [  142.008001] rDataVirt[4192]=0x01
    [  142.008001] rDataVirt[4193]=0x00
    [  142.008001] rDataVirt[4194]=0x00
    [  142.008001] rDataVirt[4195]=0x00
    [  142.008001] rDataVirt[4208]=0x01
    [  142.008001] rDataVirt[4209]=0x00
    [  142.008001] rDataVirt[4210]=0x00
    [  142.008001] rDataVirt[4211]=0x00
    [  142.008001] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  142.883201] DMA write throughput is: 641.23 MB/s
    [  142.883203] DMA read throughput is: 640.20 MB/s
    [  142.888071] Write DMA to DSP ...
    [  142.894314] Generating interrupt to DSP ...
    [  143.025624] Interrupt 16 received from DSP
    [  143.025627] Read DMA from DSP ...
    [  143.029617] rDataVirt[576]=0x00
    [  143.029617] rDataVirt[577]=0x00
    [  143.029617] rDataVirt[578]=0x00
    [  143.029617] rDataVirt[579]=0x00
    [  143.029617] rDataVirt[4192]=0x01
    [  143.029617] rDataVirt[4193]=0x00
    [  143.029617] rDataVirt[4194]=0x00
    [  143.029617] rDataVirt[4195]=0x00
    [  143.029617] rDataVirt[4208]=0x01
    [  143.029617] rDataVirt[4209]=0x00
    [  143.029617] rDataVirt[4210]=0x00
    [  143.029617] rDataVirt[4211]=0x00
    [  143.029617] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  143.886373] DMA write throughput is: 640.82 MB/s
    [  143.886376] DMA read throughput is: 640.20 MB/s
    [  143.893667] Write DMA to DSP ...
    [  143.899911] Generating interrupt to DSP ...
    [  144.031228] Interrupt 16 received from DSP
    [  144.031230] Read DMA from DSP ...
    [  144.035222] rDataVirt[576]=0x00
    [  144.035222] rDataVirt[577]=0x00
    [  144.035222] rDataVirt[578]=0x00
    [  144.035222] rDataVirt[579]=0x00
    [  144.040002] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  144.891971] DMA write throughput is: 640.61 MB/s
    [  144.891974] DMA read throughput is: 640.10 MB/s
    [  144.899247] Write DMA to DSP ...
    [  144.905489] Generating interrupt to DSP ...
    [  145.036797] Interrupt 16 received from DSP
    [  145.036800] Read DMA from DSP ...
    [  145.040790] rDataVirt[576]=0x00
    [  145.040790] rDataVirt[577]=0x00
    [  145.040790] rDataVirt[578]=0x00
    [  145.040790] rDataVirt[579]=0x00
    [  145.040790] rDataVirt[4192]=0x01
    [  145.040790] rDataVirt[4193]=0x00
    [  145.040790] rDataVirt[4194]=0x00
    [  145.040790] rDataVirt[4195]=0x00
    [  145.040790] rDataVirt[4208]=0x01
    [  145.040790] rDataVirt[4209]=0x00
    [  145.040790] rDataVirt[4210]=0x00
    [  145.040790] rDataVirt[4211]=0x00
    [  145.040790] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  145.897550] DMA write throughput is: 641.43 MB/s
    [  145.897552] DMA read throughput is: 640.10 MB/s
    [  145.904849] Write DMA to DSP ...
    [  145.911092] Generating interrupt to DSP ...
    [  146.042407] Interrupt 16 received from DSP
    [  146.042410] Read DMA from DSP ...
    [  146.046402] rDataVirt[576]=0x00
    [  146.046402] rDataVirt[577]=0x00
    [  146.046402] rDataVirt[578]=0x00
    [  146.046402] rDataVirt[579]=0x00
    [  146.046402] rDataVirt[4192]=0x01
    [  146.046402] rDataVirt[4193]=0x00
    [  146.046402] rDataVirt[4194]=0x00
    [  146.046402] rDataVirt[4195]=0x00
    [  146.046402] rDataVirt[4208]=0x01
    [  146.046402] rDataVirt[4209]=0x00
    [  146.046402] rDataVirt[4210]=0x00
    [  146.046402] rDataVirt[4211]=0x00
    [  146.046402] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  146.903158] DMA write throughput is: 640.82 MB/s
    [  146.903160] DMA read throughput is: 640.10 MB/s
    [  146.910434] Write DMA to DSP ...
    [  146.916682] Generating interrupt to DSP ...
    [  147.047991] Interrupt 16 received from DSP
    [  147.047992] Read DMA from DSP ...
    [  147.048000] rDataVirt[576]=0x00
    [  147.048000] rDataVirt[577]=0x00
    [  147.048000] rDataVirt[578]=0x00
    [  147.048000] rDataVirt[579]=0x00
    [  147.048000] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  147.925034] DMA write throughput is: 640.71 MB/s
    [  147.925036] DMA read throughput is: 640.20 MB/s
    [  147.932396] Write DMA to DSP ...
    [  147.938637] Generating interrupt to DSP ...
    [  148.069952] Interrupt 16 received from DSP
    [  148.069954] Read DMA from DSP ...
    [  148.072002] DMA test passed!
    [  148.930698] DMA write throughput is: 641.02 MB/s
    [  148.930700] DMA read throughput is: 639.79 MB/s
    [  148.937983] Write DMA to DSP ...
    [  148.944228] Generating interrupt to DSP ...
    [  149.075532] Interrupt 16 received from DSP
    [  149.075533] Read DMA from DSP ...
    [  149.076001] DMA test passed!
    [  149.949083] DMA write throughput is: 640.92 MB/s
    [  149.949085] DMA read throughput is: 641.53 MB/s
    [  149.949087] Freeing consistent memory ...
    [  153.286250] Start rmmod procedure !!!!!!!!
    [  153.286255] Start local reset assert for core (module id): 15 ...
    [  153.286260] Start local reset assert for core (module id): 16 ...
    [  153.286266] Start local reset assert for core (module id): 17 ...
    [  153.286271] Start local reset assert for core (module id): 18 ...
    [  153.286276] Start local reset assert for core (module id): 19 ...
    [  153.286281] Start local reset assert for core (module id): 20 ...
    [  153.286286] Start local reset assert for core (module id): 21 ...
    [  153.286291] Start local reset assert for core (module id): 22 ...
    [  153.295269] Boot entry address is 0x  878000
    [  153.295290] Total 3 sections, 0x748 bytes of data were written
    [  153.296288] Boot entry address is 0x  878000
    [  153.296306] Total 3 sections, 0x748 bytes of data were written
    [  153.297299] Boot entry address is 0x  878000
    [  153.297317] Total 3 sections, 0x748 bytes of data were written
    [  153.298310] Boot entry address is 0x  878000
    [  153.298328] Total 3 sections, 0x748 bytes of data were written
    [  153.299320] Boot entry address is 0x  878000
    [  153.299339] Total 3 sections, 0x748 bytes of data were written
    [  153.300336] Boot entry address is 0x  878000
    [  153.300354] Total 3 sections, 0x748 bytes of data were written
    [  153.301347] Boot entry address is 0x  878000
    [  153.301365] Total 3 sections, 0x748 bytes of data were written
    [  153.302358] Boot entry address is 0x  878000
    [  153.302376] Total 3 sections, 0x748 bytes of data were written
    [  153.320276] MD stat for pid 2 mid 9 state: 3 timeout
    [  153.323265] Start local reset de-assert for core (module id): 15 ...
    [  153.323270] Start local reset de-assert for core (module id): 16 ...
    [  153.323274] Start local reset de-assert for core (module id): 17 ...
    [  153.323279] Start local reset de-assert for core (module id): 18 ...
    [  153.323283] Start local reset de-assert for core (module id): 19 ...
    [  153.323288] Start local reset de-assert for core (module id): 20 ...
    [  153.323292] Start local reset de-assert for core (module id): 21 ...
    [  153.323297] Start local reset de-assert for core (module id): 22 ...
    [  155.111185] Finding the device....
    [  155.111207] Found TI device
    [  155.111209] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  155.111211] Reading the BAR areas....
    [  155.113519] Enabling the device....
    [  155.113528] pci 0000:01:00.0: setting latency timer to 64
    [  155.113536] Access PCIE application register ....
    [  155.113538] Registering the irq 16 ...
    [  155.113547] Allocating consistent memory  start...
    [  155.115402] Allocating consistent memory end...
    [  155.122719] Finish DMA_TRANSFER_SIZE
    [  155.122723] Boot entry address is 0x  82e2c0
    [  155.123321] Total 5 sections, 0xf30c bytes of data were written
    [  155.123322] Finish pushData
    [  155.123324] Finish writeDSPMemory
    [  155.187625] Waiting #1 of MAGIC_ADDR=0 is OK
    [  155.187626] j = 60919
    [  157.176631] Write DMA to DSP ...
    [  157.182709] Generating interrupt to DSP ...
    [  157.313984] Interrupt 16 received from DSP
    [  157.313986] Read DMA from DSP ...
    [  157.317978] rDataVirt[576]=0x00
    [  157.317978] rDataVirt[577]=0x00
    [  157.317978] rDataVirt[578]=0x00
    [  157.317978] rDataVirt[579]=0x00
    [  157.317978] rDataVirt[4192]=0x01
    [  157.317978] rDataVirt[4193]=0x00
    [  157.317978] rDataVirt[4194]=0x00
    [  157.317978] rDataVirt[4195]=0x00
    [  157.317978] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  158.174768] DMA write throughput is: 658.32 MB/s
    [  158.174771] DMA read throughput is: 658.43 MB/s
    [  158.182065] Write DMA to DSP ...
    [  158.188140] Generating interrupt to DSP ...
    [  158.319415] Interrupt 16 received from DSP
    [  158.319417] Read DMA from DSP ...
    [  158.320000] rDataVirt[576]=0x00
    [  158.320000] rDataVirt[577]=0x00
    [  158.320000] rDataVirt[578]=0x00
    [  158.320000] rDataVirt[579]=0x00
    [  158.320000] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  159.196274] DMA write throughput is: 658.97 MB/s
    [  159.196277] DMA read throughput is: 658.54 MB/s
    [  159.203573] Write DMA to DSP ...
    [  159.209656] Generating interrupt to DSP ...
    [  159.340942] Interrupt 16 received from DSP
    [  159.340943] Read DMA from DSP ...
    [  159.344000] rDataVirt[576]=0x00
    [  159.344000] rDataVirt[577]=0x00
    [  159.344000] rDataVirt[578]=0x00
    [  159.344000] rDataVirt[579]=0x00
    [  159.344000] rDataVirt[4192]=0x01
    [  159.344000] rDataVirt[4193]=0x00
    [  159.344000] rDataVirt[4194]=0x00
    [  159.344000] rDataVirt[4195]=0x00
    [  159.344000] rDataVirt[4208]=0x01
    [  159.344000] rDataVirt[4209]=0x00
    [  159.344000] rDataVirt[4210]=0x00
    [  159.344000] rDataVirt[4211]=0x00
    [  159.344000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  160.217811] DMA write throughput is: 658.11 MB/s
    [  160.217814] DMA read throughput is: 658.43 MB/s
    [  160.225121] Write DMA to DSP ...
    [  160.231198] Generating interrupt to DSP ...
    [  160.362484] Interrupt 16 received from DSP
    [  160.362487] Read DMA from DSP ...
    [  160.366477] rDataVirt[576]=0x00
    [  160.366477] rDataVirt[577]=0x00
    [  160.366477] rDataVirt[578]=0x00
    [  160.366477] rDataVirt[579]=0x00
    [  160.366477] rDataVirt[4192]=0x01
    [  160.366477] rDataVirt[4193]=0x00
    [  160.366477] rDataVirt[4194]=0x00
    [  160.366477] rDataVirt[4195]=0x00
    [  160.366477] rDataVirt[4208]=0x01
    [  160.366477] rDataVirt[4209]=0x00
    [  160.366477] rDataVirt[4210]=0x00
    [  160.366477] rDataVirt[4211]=0x00
    [  160.366477] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  161.223257] DMA write throughput is: 658.21 MB/s
    [  161.223260] DMA read throughput is: 658.43 MB/s
    [  161.230565] Write DMA to DSP ...
    [  161.236649] Generating interrupt to DSP ...
    [  161.367931] Interrupt 16 received from DSP
    [  161.367933] Read DMA from DSP ...
    [  161.368000] rDataVirt[576]=0x00
    [  161.368000] rDataVirt[577]=0x00
    [  161.368000] rDataVirt[578]=0x00
    [  161.368000] rDataVirt[579]=0x00
    [  161.368000] rDataVirt[4192]=0x01
    [  161.368000] rDataVirt[4193]=0x00
    [  161.368000] rDataVirt[4194]=0x00
    [  161.368000] rDataVirt[4195]=0x00
    [  161.368000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  162.244840] DMA write throughput is: 658.11 MB/s
    [  162.244841] DMA read throughput is: 658.43 MB/s
    [  162.249704] Write DMA to DSP ...
    [  162.255774] Generating interrupt to DSP ...
    [  162.387054] Interrupt 16 received from DSP
    [  162.387055] Read DMA from DSP ...
    [  162.388001] rDataVirt[576]=0x00
    [  162.388001] rDataVirt[577]=0x00
    [  162.388001] rDataVirt[578]=0x00
    [  162.388001] rDataVirt[579]=0x00
    [  162.388001] rDataVirt[4192]=0x01
    [  162.388001] rDataVirt[4193]=0x00
    [  162.388001] rDataVirt[4194]=0x00
    [  162.388001] rDataVirt[4195]=0x00
    [  162.388001] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  163.260388] DMA write throughput is: 659.08 MB/s
    [  163.260390] DMA read throughput is: 658.00 MB/s
    [  163.265252] Write DMA to DSP ...
    [  163.271321] Generating interrupt to DSP ...
    [  163.402612] Interrupt 16 received from DSP
    [  163.402614] Read DMA from DSP ...
    [  163.406604] DMA test passed!
    [  164.263481] DMA write throughput is: 658.97 MB/s
    [  164.263484] DMA read throughput is: 659.30 MB/s
    [  164.268962] Write DMA to DSP ...
    [  164.275033] Generating interrupt to DSP ...
    [  164.406321] Interrupt 16 received from DSP
    [  164.406323] Read DMA from DSP ...
    [  164.408001] rDataVirt[576]=0x00
    [  164.408001] rDataVirt[577]=0x00
    [  164.408001] rDataVirt[578]=0x00
    [  164.408001] rDataVirt[579]=0x00
    [  164.408001] rDataVirt[4192]=0x01
    [  164.408001] rDataVirt[4193]=0x00
    [  164.408001] rDataVirt[4194]=0x00
    [  164.408001] rDataVirt[4195]=0x00
    [  164.408001] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  165.279793] DMA write throughput is: 659.08 MB/s
    [  165.279795] DMA read throughput is: 658.97 MB/s
    [  165.284936] Write DMA to DSP ...
    [  165.291013] Generating interrupt to DSP ...
    [  165.422298] Interrupt 16 received from DSP
    [  165.422299] Read DMA from DSP ...
    [  165.424000] rDataVirt[576]=0x00
    [  165.424000] rDataVirt[577]=0x00
    [  165.424000] rDataVirt[578]=0x00
    [  165.424000] rDataVirt[579]=0x00
    [  165.424000] rDataVirt[4192]=0x01
    [  165.424000] rDataVirt[4193]=0x00
    [  165.424000] rDataVirt[4194]=0x00
    [  165.424000] rDataVirt[4195]=0x00
    [  165.424000] rDataVirt[4208]=0x01
    [  165.424000] rDataVirt[4209]=0x00
    [  165.424000] rDataVirt[4210]=0x00
    [  165.424000] rDataVirt[4211]=0x00
    [  165.424000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  166.295715] DMA write throughput is: 658.54 MB/s
    [  166.295718] DMA read throughput is: 658.32 MB/s
    [  166.303049] Write DMA to DSP ...
    [  166.309124] Generating interrupt to DSP ...
    [  166.440415] Interrupt 16 received from DSP
    [  166.440418] Read DMA from DSP ...
    [  166.444407] rDataVirt[576]=0x00
    [  166.444407] rDataVirt[577]=0x00
    [  166.444407] rDataVirt[578]=0x00
    [  166.444407] rDataVirt[579]=0x00
    [  166.444407] rDataVirt[4192]=0x01
    [  166.444407] rDataVirt[4193]=0x00
    [  166.444407] rDataVirt[4194]=0x00
    [  166.444407] rDataVirt[4195]=0x00
    [  166.444407] rDataVirt[4208]=0x01
    [  166.444407] rDataVirt[4209]=0x00
    [  166.444407] rDataVirt[4210]=0x00
    [  166.444407] rDataVirt[4211]=0x00
    [  166.444407] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  167.301183] DMA write throughput is: 658.97 MB/s
    [  167.301185] DMA read throughput is: 658.43 MB/s
    [  167.301187] Freeing consistent memory ...
    [  169.415348] Start rmmod procedure !!!!!!!!
    [  169.415353] Start local reset assert for core (module id): 15 ...
    [  169.415358] Start local reset assert for core (module id): 16 ...
    [  169.415363] Start local reset assert for core (module id): 17 ...
    [  169.415368] Start local reset assert for core (module id): 18 ...
    [  169.415373] Start local reset assert for core (module id): 19 ...
    [  169.415378] Start local reset assert for core (module id): 20 ...
    [  169.415383] Start local reset assert for core (module id): 21 ...
    [  169.415388] Start local reset assert for core (module id): 22 ...
    [  169.424370] Boot entry address is 0x  878000
    [  169.424390] Total 3 sections, 0x748 bytes of data were written
    [  169.425384] Boot entry address is 0x  878000
    [  169.425404] Total 3 sections, 0x748 bytes of data were written
    [  169.426398] Boot entry address is 0x  878000
    [  169.426418] Total 3 sections, 0x748 bytes of data were written
    [  169.427412] Boot entry address is 0x  878000
    [  169.427432] Total 3 sections, 0x748 bytes of data were written
    [  169.428430] Boot entry address is 0x  878000
    [  169.428450] Total 3 sections, 0x748 bytes of data were written
    [  169.429444] Boot entry address is 0x  878000
    [  169.429464] Total 3 sections, 0x748 bytes of data were written
    [  169.430458] Boot entry address is 0x  878000
    [  169.430478] Total 3 sections, 0x748 bytes of data were written
    [  169.431471] Boot entry address is 0x  878000
    [  169.431492] Total 3 sections, 0x748 bytes of data were written
    [  169.449392] MD stat for pid 2 mid 9 state: 3 timeout
    [  169.452386] Start local reset de-assert for core (module id): 15 ...
    [  169.452392] Start local reset de-assert for core (module id): 16 ...
    [  169.452397] Start local reset de-assert for core (module id): 17 ...
    [  169.452402] Start local reset de-assert for core (module id): 18 ...
    [  169.452407] Start local reset de-assert for core (module id): 19 ...
    [  169.452412] Start local reset de-assert for core (module id): 20 ...
    [  169.452416] Start local reset de-assert for core (module id): 21 ...
    [  169.452421] Start local reset de-assert for core (module id): 22 ...
    [  170.729522] Finding the device....
    [  170.729544] Found TI device
    [  170.729546] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  170.729548] Reading the BAR areas....
    [  170.732053] Enabling the device....
    [  170.732062] pci 0000:01:00.0: setting latency timer to 64
    [  170.732071] Access PCIE application register ....
    [  170.732073] Registering the irq 16 ...
    [  170.732867] Allocating consistent memory  start...
    [  170.734506] Allocating consistent memory end...
    [  170.739440] Finish DMA_TRANSFER_SIZE
    [  170.739444] Boot entry address is 0x  82e2c0
    [  170.739983] Total 5 sections, 0xf30c bytes of data were written
    [  170.739984] Finish pushData
    [  170.739985] Finish writeDSPMemory
    [  170.804157] Waiting #1 of MAGIC_ADDR=0 is OK
    [  170.804159] j = 62296
    [  172.793155] Write DMA to DSP ...
    [  172.799225] Generating interrupt to DSP ...
    [  172.930683] Interrupt 16 received from DSP
    [  172.930684] Read DMA from DSP ...
    [  172.932001] rDataVirt[576]=0x00
    [  172.932001] rDataVirt[577]=0x00
    [  172.932001] rDataVirt[578]=0x00
    [  172.932001] rDataVirt[579]=0x00
    [  172.932001] rDataVirt[4192]=0x01
    [  172.932001] rDataVirt[4193]=0x00
    [  172.932001] rDataVirt[4194]=0x00
    [  172.932001] rDataVirt[4195]=0x00
    [  172.932001] rDataVirt[4208]=0x01
    [  172.932001] rDataVirt[4209]=0x00
    [  172.932001] rDataVirt[4210]=0x00
    [  172.932001] rDataVirt[4211]=0x00
    [  172.932001] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  173.804069] DMA write throughput is: 659.08 MB/s
    [  173.804071] DMA read throughput is: 658.32 MB/s
    [  173.808968] Write DMA to DSP ...
    [  173.815040] Generating interrupt to DSP ...
    [  173.946500] Interrupt 16 received from DSP
    [  173.946501] Read DMA from DSP ...
    [  173.948000] rDataVirt[576]=0x00
    [  173.948000] rDataVirt[577]=0x00
    [  173.948000] rDataVirt[578]=0x00
    [  173.948000] rDataVirt[579]=0x00
    [  173.948000] rDataVirt[4192]=0x01
    [  173.948000] rDataVirt[4193]=0x00
    [  173.948000] rDataVirt[4194]=0x00
    [  173.948000] rDataVirt[4195]=0x00
    [  173.948000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  174.807130] DMA write throughput is: 658.76 MB/s
    [  174.807132] DMA read throughput is: 658.21 MB/s
    [  174.812058] Write DMA to DSP ...
    [  174.818135] Generating interrupt to DSP ...
    [  174.949592] Interrupt 16 received from DSP
    [  174.949594] Read DMA from DSP ...
    [  174.952001] DMA test passed!
    [  175.810225] DMA write throughput is: 658.32 MB/s
    [  175.810227] DMA read throughput is: 658.32 MB/s
    [  175.815061] Write DMA to DSP ...
    [  175.821140] Generating interrupt to DSP ...
    [  175.952598] Interrupt 16 received from DSP
    [  175.952600] Read DMA from DSP ...
    [  175.956002] rDataVirt[576]=0x00
    [  175.956002] rDataVirt[577]=0x00
    [  175.956002] rDataVirt[578]=0x00
    [  175.956002] rDataVirt[579]=0x00
    [  175.956002] rDataVirt[4192]=0x01
    [  175.956002] rDataVirt[4193]=0x00
    [  175.956002] rDataVirt[4194]=0x00
    [  175.956002] rDataVirt[4195]=0x00
    [  175.956002] rDataVirt[4208]=0x01
    [  175.956002] rDataVirt[4209]=0x00
    [  175.956002] rDataVirt[4210]=0x00
    [  175.956002] rDataVirt[4211]=0x00
    [  175.956002] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  176.813232] DMA write throughput is: 658.54 MB/s
    [  176.813234] DMA read throughput is: 658.43 MB/s
    [  176.818080] Write DMA to DSP ...
    [  176.824161] Generating interrupt to DSP ...
    [  176.955613] Interrupt 16 received from DSP
    [  176.955615] Read DMA from DSP ...
    [  176.956001] rDataVirt[576]=0x00
    [  176.956001] rDataVirt[577]=0x00
    [  176.956001] rDataVirt[578]=0x00
    [  176.956001] rDataVirt[579]=0x00
    [  176.956001] rDataVirt[4192]=0x01
    [  176.956001] rDataVirt[4193]=0x00
    [  176.956001] rDataVirt[4194]=0x00
    [  176.956001] rDataVirt[4195]=0x00
    [  176.956001] rDataVirt[4208]=0x01
    [  176.956001] rDataVirt[4209]=0x00
    [  176.956001] rDataVirt[4210]=0x00
    [  176.956001] rDataVirt[4211]=0x00
    [  176.956001] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  177.829040] DMA write throughput is: 658.21 MB/s
    [  177.829042] DMA read throughput is: 658.43 MB/s
    [  177.833889] Write DMA to DSP ...
    [  177.839966] Generating interrupt to DSP ...
    [  177.971424] Interrupt 16 received from DSP
    [  177.971427] Read DMA from DSP ...
    [  177.972003] DMA test passed!
    [  178.832060] DMA write throughput is: 658.21 MB/s
    [  178.832062] DMA read throughput is: 658.32 MB/s
    [  178.836942] Write DMA to DSP ...
    [  178.843012] Generating interrupt to DSP ...
    [  178.974469] Interrupt 16 received from DSP
    [  178.974470] Read DMA from DSP ...
    [  178.976001] rDataVirt[576]=0x00
    [  178.976001] rDataVirt[577]=0x00
    [  178.976001] rDataVirt[578]=0x00
    [  178.976001] rDataVirt[579]=0x00
    [  178.976001] rDataVirt[4192]=0x01
    [  178.976001] rDataVirt[4193]=0x00
    [  178.976001] rDataVirt[4194]=0x00
    [  178.976001] rDataVirt[4195]=0x00
    [  178.976001] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  179.847844] DMA write throughput is: 658.97 MB/s
    [  179.847845] DMA read throughput is: 658.43 MB/s
    [  179.852771] Write DMA to DSP ...
    [  179.858844] Generating interrupt to DSP ...
    [  179.990304] Interrupt 16 received from DSP
    [  179.990306] Read DMA from DSP ...
    [  179.994297] DMA test passed!
    [  180.850936] DMA write throughput is: 658.76 MB/s
    [  180.850938] DMA read throughput is: 658.32 MB/s
    [  180.855770] Write DMA to DSP ...
    [  180.861852] Generating interrupt to DSP ...
    [  180.993308] Interrupt 16 received from DSP
    [  180.993310] Read DMA from DSP ...
    [  180.996001] rDataVirt[576]=0x00
    [  180.996001] rDataVirt[577]=0x00
    [  180.996001] rDataVirt[578]=0x00
    [  180.996001] rDataVirt[579]=0x00
    [  180.996001] rDataVirt[4192]=0x01
    [  180.996001] rDataVirt[4193]=0x00
    [  180.996001] rDataVirt[4194]=0x00
    [  180.996001] rDataVirt[4195]=0x00
    [  180.996001] rDataVirt[4208]=0x01
    [  180.996001] rDataVirt[4209]=0x00
    [  180.996001] rDataVirt[4210]=0x00
    [  180.996001] rDataVirt[4211]=0x00
    [  180.996001] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  181.866677] DMA write throughput is: 658.21 MB/s
    [  181.866679] DMA read throughput is: 659.63 MB/s
    [  181.871514] Write DMA to DSP ...
    [  181.877592] Generating interrupt to DSP ...
    [  182.009048] Interrupt 16 received from DSP
    [  182.009050] Read DMA from DSP ...
    [  182.012001] rDataVirt[576]=0x00
    [  182.012001] rDataVirt[577]=0x00
    [  182.012001] rDataVirt[578]=0x00
    [  182.012001] rDataVirt[579]=0x00
    [  182.012001] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  182.882437] DMA write throughput is: 658.43 MB/s
    [  182.882439] DMA read throughput is: 658.43 MB/s
    [  182.882440] Freeing consistent memory ...
    [  184.474108] Start rmmod procedure !!!!!!!!
    [  184.474113] Start local reset assert for core (module id): 15 ...
    [  184.474118] Start local reset assert for core (module id): 16 ...
    [  184.474123] Start local reset assert for core (module id): 17 ...
    [  184.474128] Start local reset assert for core (module id): 18 ...
    [  184.474133] Start local reset assert for core (module id): 19 ...
    [  184.474138] Start local reset assert for core (module id): 20 ...
    [  184.474143] Start local reset assert for core (module id): 21 ...
    [  184.474148] Start local reset assert for core (module id): 22 ...
    [  184.483126] Boot entry address is 0x  878000
    [  184.483147] Total 3 sections, 0x748 bytes of data were written
    [  184.484145] Boot entry address is 0x  878000
    [  184.484165] Total 3 sections, 0x748 bytes of data were written
    [  184.485159] Boot entry address is 0x  878000
    [  184.485179] Total 3 sections, 0x748 bytes of data were written
    [  184.486173] Boot entry address is 0x  878000
    [  184.486193] Total 3 sections, 0x748 bytes of data were written
    [  184.487186] Boot entry address is 0x  878000
    [  184.487207] Total 3 sections, 0x748 bytes of data were written
    [  184.488205] Boot entry address is 0x  878000
    [  184.488225] Total 3 sections, 0x748 bytes of data were written
    [  184.489218] Boot entry address is 0x  878000
    [  184.489239] Total 3 sections, 0x748 bytes of data were written
    [  184.490232] Boot entry address is 0x  878000
    [  184.490253] Total 3 sections, 0x748 bytes of data were written
    [  184.508153] MD stat for pid 2 mid 9 state: 3 timeout
    [  184.511143] Start local reset de-assert for core (module id): 15 ...
    [  184.511148] Start local reset de-assert for core (module id): 16 ...
    [  184.511153] Start local reset de-assert for core (module id): 17 ...
    [  184.511158] Start local reset de-assert for core (module id): 18 ...
    [  184.511163] Start local reset de-assert for core (module id): 19 ...
    [  184.511168] Start local reset de-assert for core (module id): 20 ...
    [  184.511173] Start local reset de-assert for core (module id): 21 ...
    [  184.511178] Start local reset de-assert for core (module id): 22 ...
    [  185.540720] Finding the device....
    [  185.540743] Found TI device
    [  185.540745] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  185.540747] Reading the BAR areas....
    [  185.543236] Enabling the device....
    [  185.543245] pci 0000:01:00.0: setting latency timer to 64
    [  185.543252] Access PCIE application register ....
    [  185.543255] Registering the irq 16 ...
    [  185.543264] Allocating consistent memory  start...
    [  185.545305] Allocating consistent memory end...
    [  185.552606] Finish DMA_TRANSFER_SIZE
    [  185.552610] Boot entry address is 0x  82e2c0
    [  185.553208] Total 5 sections, 0xf30c bytes of data were written
    [  185.553210] Finish pushData
    [  185.553212] Finish writeDSPMemory
    [  185.617217] Waiting #1 of MAGIC_ADDR=0 is OK
    [  185.617220] j = 61488
    [  187.608594] Write DMA to DSP ...
    [  187.614672] Generating interrupt to DSP ...
    [  187.745982] Interrupt 16 received from DSP
    [  187.745984] Read DMA from DSP ...
    [  187.748000] rDataVirt[576]=0x00
    [  187.748000] rDataVirt[577]=0x00
    [  187.748000] rDataVirt[578]=0x00
    [  187.748000] rDataVirt[579]=0x00
    [  187.748000] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  188.622850] DMA write throughput is: 658.21 MB/s
    [  188.622852] DMA read throughput is: 658.43 MB/s
    [  188.630112] Write DMA to DSP ...
    [  188.636188] Generating interrupt to DSP ...
    [  188.767502] Interrupt 16 received from DSP
    [  188.767504] Read DMA from DSP ...
    [  188.771493] rDataVirt[576]=0x00
    [  188.771493] rDataVirt[577]=0x00
    [  188.771493] rDataVirt[578]=0x00
    [  188.771493] rDataVirt[579]=0x00
    [  188.771493] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  189.628247] DMA write throughput is: 658.87 MB/s
    [  189.628249] DMA read throughput is: 658.54 MB/s
    [  189.635506] Write DMA to DSP ...
    [  189.641581] Generating interrupt to DSP ...
    [  189.772887] Interrupt 16 received from DSP
    [  189.772889] Read DMA from DSP ...
    [  189.776000] rDataVirt[576]=0x00
    [  189.776000] rDataVirt[577]=0x00
    [  189.776000] rDataVirt[578]=0x00
    [  189.776000] rDataVirt[579]=0x00
    [  189.776000] rDataVirt[4192]=0x01
    [  189.776000] rDataVirt[4193]=0x00
    [  189.776000] rDataVirt[4194]=0x00
    [  189.776000] rDataVirt[4195]=0x00
    [  189.776000] rDataVirt[4208]=0x01
    [  189.776000] rDataVirt[4209]=0x00
    [  189.776000] rDataVirt[4210]=0x00
    [  189.776000] rDataVirt[4211]=0x00
    [  189.776000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  190.649768] DMA write throughput is: 658.87 MB/s
    [  190.649770] DMA read throughput is: 658.43 MB/s
    [  190.657035] Write DMA to DSP ...
    [  190.663113] Generating interrupt to DSP ...
    [  190.794423] Interrupt 16 received from DSP
    [  190.794426] Read DMA from DSP ...
    [  190.798416] DMA test passed!
    [  191.655174] DMA write throughput is: 658.21 MB/s
    [  191.655176] DMA read throughput is: 658.43 MB/s
    [  191.662437] Write DMA to DSP ...
    [  191.668513] Generating interrupt to DSP ...
    [  191.799817] Interrupt 16 received from DSP
    [  191.799818] Read DMA from DSP ...
    [  191.800000] DMA test passed!
    [  192.676677] DMA write throughput is: 658.87 MB/s
    [  192.676680] DMA read throughput is: 658.21 MB/s
    [  192.683931] Write DMA to DSP ...
    [  192.690010] Generating interrupt to DSP ...
    [  192.821320] Interrupt 16 received from DSP
    [  192.821322] Read DMA from DSP ...
    [  192.824001] rDataVirt[576]=0x00
    [  192.824001] rDataVirt[577]=0x00
    [  192.824001] rDataVirt[578]=0x00
    [  192.824001] rDataVirt[579]=0x00
    [  192.824001] rDataVirt[4192]=0x01
    [  192.824001] rDataVirt[4193]=0x00
    [  192.824001] rDataVirt[4194]=0x00
    [  192.824001] rDataVirt[4195]=0x00
    [  192.824001] rDataVirt[4208]=0x01
    [  192.824001] rDataVirt[4209]=0x00
    [  192.824001] rDataVirt[4210]=0x00
    [  192.824001] rDataVirt[4211]=0x00
    [  192.824001] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  193.698198] DMA write throughput is: 658.54 MB/s
    [  193.698201] DMA read throughput is: 658.54 MB/s
    [  193.705457] Write DMA to DSP ...
    [  193.711526] Generating interrupt to DSP ...
    [  193.842840] Interrupt 16 received from DSP
    [  193.842843] Read DMA from DSP ...
    [  193.846832] rDataVirt[576]=0x00
    [  193.846832] rDataVirt[577]=0x00
    [  193.846832] rDataVirt[578]=0x00
    [  193.846832] rDataVirt[579]=0x00
    [  193.846832] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  194.703586] DMA write throughput is: 659.08 MB/s
    [  194.703589] DMA read throughput is: 658.43 MB/s
    [  194.710847] Write DMA to DSP ...
    [  194.716922] Generating interrupt to DSP ...
    [  194.848232] Interrupt 16 received from DSP
    [  194.848234] Read DMA from DSP ...
    [  194.852000] rDataVirt[576]=0x00
    [  194.852000] rDataVirt[577]=0x00
    [  194.852000] rDataVirt[578]=0x00
    [  194.852000] rDataVirt[579]=0x00
    [  194.852000] rDataVirt[4192]=0x01
    [  194.852000] rDataVirt[4193]=0x00
    [  194.852000] rDataVirt[4194]=0x00
    [  194.852000] rDataVirt[4195]=0x00
    [  194.852000] rDataVirt[4208]=0x01
    [  194.852000] rDataVirt[4209]=0x00
    [  194.852000] rDataVirt[4210]=0x00
    [  194.852000] rDataVirt[4211]=0x00
    [  194.852000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  195.725106] DMA write throughput is: 658.97 MB/s
    [  195.725108] DMA read throughput is: 659.41 MB/s
    [  195.732417] Write DMA to DSP ...
    [  195.738489] Generating interrupt to DSP ...
    [  195.869793] Interrupt 16 received from DSP
    [  195.869795] Read DMA from DSP ...
    [  195.872000] rDataVirt[576]=0x00
    [  195.872000] rDataVirt[577]=0x00
    [  195.872000] rDataVirt[578]=0x00
    [  195.872000] rDataVirt[579]=0x00
    [  195.872000] rDataVirt[4192]=0x01
    [  195.872000] rDataVirt[4193]=0x00
    [  195.872000] rDataVirt[4194]=0x00
    [  195.872000] rDataVirt[4195]=0x00
    [  195.872000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  196.746663] DMA write throughput is: 658.76 MB/s
    [  196.746665] DMA read throughput is: 658.43 MB/s
    [  196.753933] Write DMA to DSP ...
    [  196.760016] Generating interrupt to DSP ...
    [  196.891322] Interrupt 16 received from DSP
    [  196.891324] Read DMA from DSP ...
    [  196.892000] rDataVirt[576]=0x00
    [  196.892000] rDataVirt[577]=0x00
    [  196.892000] rDataVirt[578]=0x00
    [  196.892000] rDataVirt[579]=0x00
    [  196.892000] rDataVirt[4192]=0x01
    [  196.892000] rDataVirt[4193]=0x00
    [  196.892000] rDataVirt[4194]=0x00
    [  196.892000] rDataVirt[4195]=0x00
    [  196.892000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  197.768198] DMA write throughput is: 658.21 MB/s
    [  197.768200] DMA read throughput is: 658.54 MB/s
    [  197.768201] Freeing consistent memory ...
    [  199.616509] Start rmmod procedure !!!!!!!!
    [  199.616514] Start local reset assert for core (module id): 15 ...
    [  199.616519] Start local reset assert for core (module id): 16 ...
    [  199.616524] Start local reset assert for core (module id): 17 ...
    [  199.616529] Start local reset assert for core (module id): 18 ...
    [  199.616534] Start local reset assert for core (module id): 19 ...
    [  199.616539] Start local reset assert for core (module id): 20 ...
    [  199.616544] Start local reset assert for core (module id): 21 ...
    [  199.616549] Start local reset assert for core (module id): 22 ...
    [  199.625528] Boot entry address is 0x  878000
    [  199.625549] Total 3 sections, 0x748 bytes of data were written
    [  199.626543] Boot entry address is 0x  878000
    [  199.626563] Total 3 sections, 0x748 bytes of data were written
    [  199.627557] Boot entry address is 0x  878000
    [  199.627577] Total 3 sections, 0x748 bytes of data were written
    [  199.628575] Boot entry address is 0x  878000
    [  199.628595] Total 3 sections, 0x748 bytes of data were written
    [  199.629589] Boot entry address is 0x  878000
    [  199.629609] Total 3 sections, 0x748 bytes of data were written
    [  199.630603] Boot entry address is 0x  878000
    [  199.630623] Total 3 sections, 0x748 bytes of data were written
    [  199.631616] Boot entry address is 0x  878000
    [  199.631637] Total 3 sections, 0x748 bytes of data were written
    [  199.632635] Boot entry address is 0x  878000
    [  199.632655] Total 3 sections, 0x748 bytes of data were written
    [  199.650551] MD stat for pid 2 mid 9 state: 3 timeout
    [  199.653546] Start local reset de-assert for core (module id): 15 ...
    [  199.653551] Start local reset de-assert for core (module id): 16 ...
    [  199.653556] Start local reset de-assert for core (module id): 17 ...
    [  199.653561] Start local reset de-assert for core (module id): 18 ...
    [  199.653566] Start local reset de-assert for core (module id): 19 ...
    [  199.653571] Start local reset de-assert for core (module id): 20 ...
    [  199.653576] Start local reset de-assert for core (module id): 21 ...
    [  199.653581] Start local reset de-assert for core (module id): 22 ...
    [  200.965257] Finding the device....
    [  200.965281] Found TI device
    [  200.965283] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  200.965285] Reading the BAR areas....
    [  200.967796] Enabling the device....
    [  200.967805] pci 0000:01:00.0: setting latency timer to 64
    [  200.967812] Access PCIE application register ....
    [  200.967815] Registering the irq 16 ...
    [  200.967824] Allocating consistent memory  start...
    [  200.970036] Allocating consistent memory end...
    [  200.977897] Finish DMA_TRANSFER_SIZE
    [  200.977901] Boot entry address is 0x  82e2c0
    [  200.978519] Total 5 sections, 0xf30c bytes of data were written
    [  200.978521] Finish pushData
    [  200.978523] Finish writeDSPMemory
    [  201.042707] Waiting #1 of MAGIC_ADDR=0 is OK
    [  201.042709] j = 60715
    [  203.031636] Write DMA to DSP ...
    [  203.037724] Generating interrupt to DSP ...
    [  203.167898] Interrupt 16 received from DSP
    [  203.167899] Read DMA from DSP ...
    [  203.168000] rDataVirt[576]=0x00
    [  203.168000] rDataVirt[577]=0x00
    [  203.168000] rDataVirt[578]=0x00
    [  203.168000] rDataVirt[579]=0x00
    [  203.168000] rDataVirt[4192]=0x01
    [  203.168000] rDataVirt[4193]=0x00
    [  203.168000] rDataVirt[4194]=0x00
    [  203.168000] rDataVirt[4195]=0x00
    [  203.168000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  204.045767] DMA write throughput is: 657.78 MB/s
    [  204.045769] DMA read throughput is: 658.54 MB/s
    [  204.053040] Write DMA to DSP ...
    [  204.059119] Generating interrupt to DSP ...
    [  204.189303] Interrupt 16 received from DSP
    [  204.189306] Read DMA from DSP ...
    [  204.193295] rDataVirt[576]=0x00
    [  204.193295] rDataVirt[577]=0x00
    [  204.193295] rDataVirt[578]=0x00
    [  204.193295] rDataVirt[579]=0x00
    [  204.193295] rDataVirt[4192]=0x01
    [  204.193295] rDataVirt[4193]=0x00
    [  204.193295] rDataVirt[4194]=0x00
    [  204.193295] rDataVirt[4195]=0x00
    [  204.193295] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  205.051180] DMA write throughput is: 658.11 MB/s
    [  205.051182] DMA read throughput is: 658.43 MB/s
    [  205.058449] Write DMA to DSP ...
    [  205.064527] Generating interrupt to DSP ...
    [  205.194712] Interrupt 16 received from DSP
    [  205.194714] Read DMA from DSP ...
    [  205.196000] rDataVirt[576]=0x00
    [  205.196000] rDataVirt[577]=0x00
    [  205.196000] rDataVirt[578]=0x00
    [  205.196000] rDataVirt[579]=0x00
    [  205.196000] rDataVirt[4192]=0x01
    [  205.196000] rDataVirt[4193]=0x00
    [  205.196000] rDataVirt[4194]=0x00
    [  205.196000] rDataVirt[4195]=0x00
    [  205.196000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  206.072576] DMA write throughput is: 658.65 MB/s
    [  206.072578] DMA read throughput is: 658.54 MB/s
    [  206.079866] Write DMA to DSP ...
    [  206.085948] Generating interrupt to DSP ...
    [  206.216132] Interrupt 16 received from DSP
    [  206.216134] Read DMA from DSP ...
    [  206.220000] rDataVirt[576]=0x00
    [  206.220000] rDataVirt[577]=0x00
    [  206.220000] rDataVirt[578]=0x00
    [  206.220000] rDataVirt[579]=0x00
    [  206.220000] rDataVirt[4192]=0x01
    [  206.220000] rDataVirt[4193]=0x00
    [  206.220000] rDataVirt[4194]=0x00
    [  206.220000] rDataVirt[4195]=0x00
    [  206.220000] rDataVirt[4208]=0x01
    [  206.220000] rDataVirt[4209]=0x00
    [  206.220000] rDataVirt[4210]=0x00
    [  206.220000] rDataVirt[4211]=0x00
    [  206.220000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  207.093998] DMA write throughput is: 658.32 MB/s
    [  207.094001] DMA read throughput is: 658.43 MB/s
    [  207.101274] Write DMA to DSP ...
    [  207.107346] Generating interrupt to DSP ...
    [  207.237541] Interrupt 16 received from DSP
    [  207.237544] Read DMA from DSP ...
    [  207.241533] DMA test passed!
    [  208.099406] DMA write throughput is: 658.76 MB/s
    [  208.099409] DMA read throughput is: 659.52 MB/s
    [  208.106681] Write DMA to DSP ...
    [  208.112764] Generating interrupt to DSP ...
    [  208.242941] Interrupt 16 received from DSP
    [  208.242942] Read DMA from DSP ...
    [  208.244000] rDataVirt[576]=0x00
    [  208.244000] rDataVirt[577]=0x00
    [  208.244000] rDataVirt[578]=0x00
    [  208.244000] rDataVirt[579]=0x00
    [  208.244000] rDataVirt[4192]=0x01
    [  208.244000] rDataVirt[4193]=0x00
    [  208.244000] rDataVirt[4194]=0x00
    [  208.244000] rDataVirt[4195]=0x00
    [  208.244000] rDataVirt[4208]=0x01
    [  208.244000] rDataVirt[4209]=0x00
    [  208.244000] rDataVirt[4210]=0x00
    [  208.244000] rDataVirt[4211]=0x00
    [  208.244000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  209.120811] DMA write throughput is: 658.21 MB/s
    [  209.120813] DMA read throughput is: 658.54 MB/s
    [  209.128097] Write DMA to DSP ...
    [  209.134174] Generating interrupt to DSP ...
    [  209.264359] Interrupt 16 received from DSP
    [  209.264360] Read DMA from DSP ...
    [  209.268000] rDataVirt[576]=0x00
    [  209.268000] rDataVirt[577]=0x00
    [  209.268000] rDataVirt[578]=0x00
    [  209.268000] rDataVirt[579]=0x00
    [  209.268000] rDataVirt[4192]=0x01
    [  209.268000] rDataVirt[4193]=0x00
    [  209.268000] rDataVirt[4194]=0x00
    [  209.268000] rDataVirt[4195]=0x00
    [  209.268000] rDataVirt[4208]=0x01
    [  209.268000] rDataVirt[4209]=0x00
    [  209.268000] rDataVirt[4210]=0x00
    [  209.268000] rDataVirt[4211]=0x00
    [  209.268000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  210.142229] DMA write throughput is: 658.21 MB/s
    [  210.142232] DMA read throughput is: 658.54 MB/s
    [  210.149497] Write DMA to DSP ...
    [  210.155576] Generating interrupt to DSP ...
    [  210.285760] Interrupt 16 received from DSP
    [  210.285762] Read DMA from DSP ...
    [  210.289752] rDataVirt[576]=0x00
    [  210.289752] rDataVirt[577]=0x00
    [  210.289752] rDataVirt[578]=0x00
    [  210.289752] rDataVirt[579]=0x00
    [  210.289752] rDataVirt[4192]=0x01
    [  210.289752] rDataVirt[4193]=0x00
    [  210.289752] rDataVirt[4194]=0x00
    [  210.289752] rDataVirt[4195]=0x00
    [  210.289752] rDataVirt[4208]=0x01
    [  210.289752] rDataVirt[4209]=0x00
    [  210.289752] rDataVirt[4210]=0x00
    [  210.289752] rDataVirt[4211]=0x00
    [  210.289752] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  211.147635] DMA write throughput is: 658.21 MB/s
    [  211.147638] DMA read throughput is: 658.43 MB/s
    [  211.155005] Write DMA to DSP ...
    [  211.161091] Generating interrupt to DSP ...
    [  211.291262] Interrupt 16 received from DSP
    [  211.291264] Read DMA from DSP ...
    [  211.292000] rDataVirt[576]=0x00
    [  211.292000] rDataVirt[577]=0x00
    [  211.292000] rDataVirt[578]=0x00
    [  211.292000] rDataVirt[579]=0x00
    [  211.292000] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  212.169126] DMA write throughput is: 657.89 MB/s
    [  212.169128] DMA read throughput is: 658.43 MB/s
    [  212.176390] Write DMA to DSP ...
    [  212.182468] Generating interrupt to DSP ...
    [  212.312655] Interrupt 16 received from DSP
    [  212.312657] Read DMA from DSP ...
    [  212.316647] rDataVirt[576]=0x00
    [  212.316647] rDataVirt[577]=0x00
    [  212.316647] rDataVirt[578]=0x00
    [  212.316647] rDataVirt[579]=0x00
    [  212.316647] rDataVirt[4192]=0x01
    [  212.316647] rDataVirt[4193]=0x00
    [  212.316647] rDataVirt[4194]=0x00
    [  212.316647] rDataVirt[4195]=0x00
    [  212.316647] rDataVirt[4208]=0x01
    [  212.316647] rDataVirt[4209]=0x00
    [  212.316647] rDataVirt[4210]=0x00
    [  212.316647] rDataVirt[4211]=0x00
    [  212.316647] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  213.174528] DMA write throughput is: 658.21 MB/s
    [  213.174530] DMA read throughput is: 658.43 MB/s
    [  213.174532] Freeing consistent memory ...
    [  214.994862] Start rmmod procedure !!!!!!!!
    [  214.994866] Start local reset assert for core (module id): 15 ...
    [  214.994871] Start local reset assert for core (module id): 16 ...
    [  214.994875] Start local reset assert for core (module id): 17 ...
    [  214.994879] Start local reset assert for core (module id): 18 ...
    [  214.994884] Start local reset assert for core (module id): 19 ...
    [  214.994888] Start local reset assert for core (module id): 20 ...
    [  214.994892] Start local reset assert for core (module id): 21 ...
    [  214.994897] Start local reset assert for core (module id): 22 ...
    [  215.003872] Boot entry address is 0x  878000
    [  215.003890] Total 3 sections, 0x748 bytes of data were written
    [  215.004888] Boot entry address is 0x  878000
    [  215.004906] Total 3 sections, 0x748 bytes of data were written
    [  215.005899] Boot entry address is 0x  878000
    [  215.005917] Total 3 sections, 0x748 bytes of data were written
    [  215.006909] Boot entry address is 0x  878000
    [  215.006927] Total 3 sections, 0x748 bytes of data were written
    [  215.007920] Boot entry address is 0x  878000
    [  215.007938] Total 3 sections, 0x748 bytes of data were written
    [  215.008935] Boot entry address is 0x  878000
    [  215.008954] Total 3 sections, 0x748 bytes of data were written
    [  215.009946] Boot entry address is 0x  878000
    [  215.009964] Total 3 sections, 0x748 bytes of data were written
    [  215.010957] Boot entry address is 0x  878000
    [  215.010975] Total 3 sections, 0x748 bytes of data were written
    [  215.028874] MD stat for pid 2 mid 9 state: 3 timeout
    [  215.031863] Start local reset de-assert for core (module id): 15 ...
    [  215.031868] Start local reset de-assert for core (module id): 16 ...
    [  215.031872] Start local reset de-assert for core (module id): 17 ...
    [  215.031876] Start local reset de-assert for core (module id): 18 ...
    [  215.031880] Start local reset de-assert for core (module id): 19 ...
    [  215.031885] Start local reset de-assert for core (module id): 20 ...
    [  215.031889] Start local reset de-assert for core (module id): 21 ...
    [  215.031893] Start local reset de-assert for core (module id): 22 ...
    [  215.854183] Finding the device....
    [  215.854205] Found TI device
    [  215.854207] TI device: vendor=0x104c, dev=0xb005, irq=0x00000010
    [  215.854209] Reading the BAR areas....
    [  215.856522] Enabling the device....
    [  215.856531] pci 0000:01:00.0: setting latency timer to 64
    [  215.856538] Access PCIE application register ....
    [  215.856541] Registering the irq 16 ...
    [  215.856549] Allocating consistent memory  start...
    [  215.858229] Allocating consistent memory end...
    [  215.865588] Finish DMA_TRANSFER_SIZE
    [  215.865592] Boot entry address is 0x  82e2c0
    [  215.866189] Total 5 sections, 0xf30c bytes of data were written
    [  215.866191] Finish pushData
    [  215.866193] Finish writeDSPMemory
    [  215.930479] Waiting #1 of MAGIC_ADDR=0 is OK
    [  215.930481] j = 60944
    [  217.921910] Write DMA to DSP ...
    [  217.927981] Generating interrupt to DSP ...
    [  218.059295] Interrupt 16 received from DSP
    [  218.059297] Read DMA from DSP ...
    [  218.060000] rDataVirt[576]=0x00
    [  218.060000] rDataVirt[577]=0x00
    [  218.060000] rDataVirt[578]=0x00
    [  218.060000] rDataVirt[579]=0x00
    [  218.060000] rDataVirt[4192]=0x01
    [  218.060000] rDataVirt[4193]=0x00
    [  218.060000] rDataVirt[4194]=0x00
    [  218.060000] rDataVirt[4195]=0x00
    [  218.060000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  218.936213] DMA write throughput is: 658.97 MB/s
    [  218.936215] DMA read throughput is: 658.43 MB/s
    [  218.943470] Write DMA to DSP ...
    [  218.949547] Generating interrupt to DSP ...
    [  219.080866] Interrupt 16 received from DSP
    [  219.080869] Read DMA from DSP ...
    [  219.084858] DMA test passed!
    [  219.941644] DMA write throughput is: 658.87 MB/s
    [  219.941647] DMA read throughput is: 658.43 MB/s
    [  219.949240] Write DMA to DSP ...
    [  219.955308] Generating interrupt to DSP ...
    [  220.086622] Interrupt 16 received from DSP
    [  220.086624] Read DMA from DSP ...
    [  220.088001] DMA test passed!
    [  220.963508] DMA write throughput is: 659.19 MB/s
    [  220.963511] DMA read throughput is: 658.43 MB/s
    [  220.968981] Write DMA to DSP ...
    [  220.975053] Generating interrupt to DSP ...
    [  221.106370] Interrupt 16 received from DSP
    [  221.106373] Read DMA from DSP ...
    [  221.110362] rDataVirt[576]=0x00
    [  221.110362] rDataVirt[577]=0x00
    [  221.110362] rDataVirt[578]=0x00
    [  221.110362] rDataVirt[579]=0x00
    [  221.110362] rDataVirt[4192]=0x01
    [  221.110362] rDataVirt[4193]=0x00
    [  221.110362] rDataVirt[4194]=0x00
    [  221.110362] rDataVirt[4195]=0x00
    [  221.110362] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  221.967153] DMA write throughput is: 658.87 MB/s
    [  221.967155] DMA read throughput is: 658.54 MB/s
    [  221.972468] Write DMA to DSP ...
    [  221.978547] Generating interrupt to DSP ...
    [  222.109867] Interrupt 16 received from DSP
    [  222.109868] Read DMA from DSP ...
    [  222.112000] rDataVirt[576]=0x00
    [  222.112000] rDataVirt[577]=0x00
    [  222.112000] rDataVirt[578]=0x00
    [  222.112000] rDataVirt[579]=0x00
    [  222.112000] rDataVirt[4192]=0x01
    [  222.112000] rDataVirt[4193]=0x00
    [  222.112000] rDataVirt[4194]=0x00
    [  222.112000] rDataVirt[4195]=0x00
    [  222.112000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  222.986999] DMA write throughput is: 658.11 MB/s
    [  222.987001] DMA read throughput is: 658.54 MB/s
    [  222.992610] Write DMA to DSP ...
    [  222.998679] Generating interrupt to DSP ...
    [  223.130004] Interrupt 16 received from DSP
    [  223.130006] Read DMA from DSP ...
    [  223.133998] DMA test passed!
    [  223.990774] DMA write throughput is: 659.19 MB/s
    [  223.990776] DMA read throughput is: 658.43 MB/s
    [  223.997450] Write DMA to DSP ...
    [  224.003524] Generating interrupt to DSP ...
    [  224.134841] Interrupt 16 received from DSP
    [  224.134843] Read DMA from DSP ...
    [  224.136000] rDataVirt[576]=0x00
    [  224.136000] rDataVirt[577]=0x00
    [  224.136000] rDataVirt[578]=0x00
    [  224.136000] rDataVirt[579]=0x00
    [  224.136000] rDataVirt[4192]=0x01
    [  224.136000] rDataVirt[4193]=0x00
    [  224.136000] rDataVirt[4194]=0x00
    [  224.136000] rDataVirt[4195]=0x00
    [  224.136000] DMA test failed with 8 locations !!!!!!!!!!!!!!!!!!!!
    [  225.011737] DMA write throughput is: 658.76 MB/s
    [  225.011740] DMA read throughput is: 658.43 MB/s
    [  225.019032] Write DMA to DSP ...
    [  225.025113] Generating interrupt to DSP ...
    [  225.156429] Interrupt 16 received from DSP
    [  225.156431] Read DMA from DSP ...
    [  225.160000] rDataVirt[576]=0x00
    [  225.160000] rDataVirt[577]=0x00
    [  225.160000] rDataVirt[578]=0x00
    [  225.160000] rDataVirt[579]=0x00
    [  225.160000] rDataVirt[4192]=0x01
    [  225.160000] rDataVirt[4193]=0x00
    [  225.160000] rDataVirt[4194]=0x00
    [  225.160000] rDataVirt[4195]=0x00
    [  225.160000] rDataVirt[4208]=0x01
    [  225.160000] rDataVirt[4209]=0x00
    [  225.160000] rDataVirt[4210]=0x00
    [  225.160000] rDataVirt[4211]=0x00
    [  225.160000] DMA test failed with 12 locations !!!!!!!!!!!!!!!!!!!!
    [  226.033334] DMA write throughput is: 658.32 MB/s
    [  226.033336] DMA read throughput is: 658.54 MB/s
    [  226.040634] Write DMA to DSP ...
    [  226.046713] Generating interrupt to DSP ...
    [  226.178038] Interrupt 16 received from DSP
    [  226.178040] Read DMA from DSP ...
    [  226.182030] DMA test passed!
    [  227.038809] DMA write throughput is: 658.21 MB/s
    [  227.038812] DMA read throughput is: 658.32 MB/s
    [  227.046101] Write DMA to DSP ...
    [  227.052176] Generating interrupt to DSP ...
    [  227.183496] Interrupt 16 received from DSP
    [  227.183499] Read DMA from DSP ...
    [  227.187487] rDataVirt[576]=0x00
    [  227.187487] rDataVirt[577]=0x00
    [  227.187487] rDataVirt[578]=0x00
    [  227.187487] rDataVirt[579]=0x00
    [  227.187487] DMA test failed with 4 locations !!!!!!!!!!!!!!!!!!!!
    [  228.044274] DMA write throughput is: 658.97 MB/s
    [  228.044277] DMA read throughput is: 659.63 MB/s
    [  228.044279] Freeing consistent memory ...
    I have done the test on below configuration:
    OS: Ubuntu 12.04 Linux 3.2.0-75
    PCIe adapter card : (PCB REV: 17-00107-03 and PCA REV: 18-00107-03)
    EVM revision: Rev 1.0
     I think it seemes as problen in the DSP. Isn't it?
    Thank you,
    Viktor.
