McASP+AIC3204 on DM8148
Hi all,
I did the signal measurement to check the setup time and hold time on serializer data pins (AXRn) of DM8148.
But the serializer data pins could not meet minimum setup time and hold time of AIC3204.
Which McASP registers can be modified to balance the setup time and hold time?
Thanks in advance.
B.R.
OC
  • Hi OC,
    The McASP pins timing is described in the DM814x datasheet, section 8.14.3 McASP (McASP[5:0]) Electrical Data/Timing
    I do not think you can go beyond these values (go out of spec) through modifying the McASP registers settings.
    Pavel
