error when i run the make on dm8168
Dear Sir,
export dvr_rdk_BASE="${HOME}/DVRRDK_04_01_00_02"
dvr_rdk_BASE variable available in Rules.make under /home/balaji/DVRRDK_04_01_00_02/dvr_rdk/
everything is correct. i don't know why it is showing error.
ti_vdis_hdmi_ctrl_priv.c:17:30: fatal error: linux/ti81xxhdmi.h: No such file or directory
can you tell me what i have to do to fix the below errors
compilation terminated.
make[3]: *** [depend] Error 1
make[3]: Leaving directory `/home/balaji/DVRRDK_04_01_00_02/dvr_rdk/mcfw/src_linux/mcfw_api'
make[2]: *** [mcfw_api] Error 2
make[2]: Leaving directory `/home/balaji/DVRRDK_04_01_00_02/dvr_rdk/mcfw/src_linux'
make[1]: *** [dvr_rdk] Error 2
make[1]: Leaving directory `/home/balaji/DVRRDK_04_01_00_02/dvr_rdk/mcfw/src_linux'
make: *** [dvr_rdk_linux] Error 2
Thanking you,
Balaji
  • Either this HDMI driver is not installed in the linux or linux path is wrong. could you please check these conditions?
    Brijesh
  • Dear Sir,
    I have placed DVRRDK_04_01_00_02 in /home/balaji/DVRRDK_04_01_00_02.
    export dvr_rdk_BASE = "${HOME}/DVRRDK_04_01_00_02"
    execute the make file on DVRRDK_04_01_00_02.
    included
    KERNELDIR        := $(TI_SW_ROOT)/linux_lsp/kernel/linux-dvr-rdk under this directory it has ti81xxhdmi.h
    I have attached the Rules.make file. check it whether all are correct or not? can you mail me where could be the problem?
    # Copyright Texas Instruments
    ifeq ($(dvr_rdk_PATH), )
    # Board type can be one of the following
    # 1. DM816X_UD_DVR
    # 2. DM816X_TI_EVM
    # 3. DM814X_TI_EVM
    # 4. DM810X_TI_EVM
    # 5. DM810X_UD_DVR
    # 6. DM810X_BCH_120_DVR
    ifeq ($(DVR_RDK_BOARD_TYPE ), )
      DVR_RDK_BOARD_TYPE := DM816X_UD_DVR
    endif
    # Default build environment, windows or linux
    ifeq ($(OS), )
      OS := Linux
    endif
    dvr_rdk_RELPATH = dvr_rdk
    ifeq ($(OS),Windows_NT)
      dvr_rdk_BASE     := $(CURDIR)/..
      TI_SW_ROOT       := D:/ti_software
    endif
    ifeq ($(OS),Linux)
      dvr_rdk_BASE     := $(shell pwd)/..
      TI_SW_ROOT       := $(dvr_rdk_BASE)/ti_tools
    endif
    dvr_rdk_PATH     := $(dvr_rdk_BASE)/$(dvr_rdk_RELPATH)
    # Code gen tools
    CODEGEN_PATH_A8  := $(TI_SW_ROOT)/cgt_a8/arago/linux-devkit
    CODEGEN_PATH_DSP := $(TI_SW_ROOT)/cgt_dsp/cgt6x_7_3_5/
    CODEGEN_PATH_M3  := $(TI_SW_ROOT)/cgt_m3/cgt470_4_9_5/
    CODEGEN_PREFIX   := $(CODEGEN_PATH_A8)/bin/arm-arago-linux-gnueabi-
    CSTOOL_PREFIX    := arm-arago-linux-gnueabi-
    CODEGEN_PREFIX   := $(TI_SW_ROOT)/cgt_a8/arm-2009q1/bin/arm-none-linux-gnueabi-
    CSTOOL_PREFIX    := arm-none-linux-gnueabi-
    endif
    # BIOS side tools
    xdc_PATH         := $(TI_SW_ROOT)/xdc/xdctools_3_23_03_53
    bios_PATH        := $(TI_SW_ROOT)/bios/bios_6_33_05_46
    ipc_PATH         := $(TI_SW_ROOT)/ipc/ipc_1_24_03_32
    fc_PATH          := $(TI_SW_ROOT)/framework_components/framework_components_3_22_02_08_patched
    edma3lld_PATH    := $(TI_SW_ROOT)/edma3lld/edma3_lld_02_11_06_01
    iss_PATH         := $(TI_SW_ROOT)/iss/iss_02_00_00_08
    hdvpss_PATH      := $(dvr_rdk_BASE)/ti_tools/hdvpss/dvr_rdk_hdvpss
    # Codecs
    xdais_PATH       := $(TI_SW_ROOT)/xdais/xdais_7_22_00_03
    hdvicplib_PATH   := $(TI_SW_ROOT)/ivahd_hdvicp/hdvicp20
    h264dec_DIR      := $(TI_SW_ROOT)/codecs/REL.500.V.H264AVC.D.HP.IVAHD.02.00.08.00
    h264enc_DIR      := $(TI_SW_ROOT)/codecs/REL.500.V.H264AVC.E.IVAHD.02.00.06.00
    h264dec_PATH     := $(h264dec_DIR)/500.V.H264AVC.D.HP.IVAHD.02.00/IVAHD_001
    h264enc_PATH     := $(h264enc_DIR)/500.V.H264AVC.E.IVAHD.02.00/IVAHD_001
    jpegdec_DIR      := $(TI_SW_ROOT)/codecs/REL.500.V.MJPEG.D.IVAHD.01.00.06.00
    jpegenc_DIR      := $(TI_SW_ROOT)/codecs/REL.500.V.MJPEG.E.IVAHD.01.00.04.00
    jpegdec_PATH     := $(jpegdec_DIR)/500.V.MJPEG.D.IVAHD.01.00/IVAHD_001
    jpegenc_PATH     := $(jpegenc_DIR)/500.V.MJPEG.E.IVAHD.01.00/IVAHD_001
    mpeg4dec_DIR     := $(TI_SW_ROOT)/codecs/REL.500.V.MPEG4.D.IVAHD.01.00.11.00
    mpeg4dec_PATH    := $(mpeg4dec_DIR)/500.V.MPEG4.D.ASP.IVAHD.01.00/IVAHD_001
    mpeg4enc_DIR     := $(TI_SW_ROOT)/codecs/REL.500.V.MPEG4.E.SP.IVAHD.01.00.01.00
    mpeg4enc_PATH    := $(mpeg4enc_DIR)/500.V.MPEG4.E.SP.IVAHD.01.00/IVAHD_001
    mpeg2dec_DIR     := $(TI_SW_ROOT)/codecs/REL.500.V.MPEG2.D.IVAHD.01.00.12.00
    mpeg2dec_PATH    := $(mpeg2dec_DIR)/500.V.MPEG2.D.IVAHD.01.00/IVAHD_001
    watermark_lib_PATH := $(TI_SW_ROOT)/codecs/REL_WATERMARK_DECRYPT_IVAHD_00_04.zip
    # Audio framework (RPE) and Codecs
    rpe_PATH         := $(TI_SW_ROOT)/rpe/remote-processor-execute
    aaclcdec_PATH    := $(TI_SW_ROOT)/codecs/c674x_aaclcdec_01_41_00_00_elf
    aaclcenc_PATH    := $(TI_SW_ROOT)/codecs/c674x_aaclcenc_01_00_01_00_elf_patched
    # Linux side tools
    syslink_PATH     := $(TI_SW_ROOT)/syslink/syslink_2_20_02_20
    linuxdevkit_PATH := $(CODEGEN_PATH_A8)/arm-arago-linux-gnueabi
    UBOOTDIR         := $(TI_SW_ROOT)/linux_lsp/uboot/u-boot-dvr-rdk
    LSP_COLLATERALS  := $(TI_SW_ROOT)/linux_lsp/collaterals
    # DVR Qt GUI Application tools
    ifeq ($(DVR_RDK_BOARD_TYPE),DM810X_UD_DVR)
    dvrapp_PATH      := $(dvr_rdk_PATH)/dvrapp/ti810x
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM816X_UD_DVR)
    dvrapp_PATH      := $(dvr_rdk_PATH)/dvrapp/ti816x
    endif
    # NVR Qt GUI Application tools
    nvrapp_PATH      := $(dvr_rdk_PATH)/dvrapp/ti810x_nvr
    endif
    nvrapp_PATH      := $(dvr_rdk_PATH)/dvrapp/ti816x_nvr
    endif
    memcpy_neon_PATH := $(dvr_rdk_PATH)/module/memcpy_neon
    live555_PATH     := $(dvr_rdk_PATH)/module/live555
    #qt_PATH          := /usr/local/Trolltech/QtEmbedded-4.8.1-arm
    qt_PATH          := /home/hwjun/proj/qt-everywhere-opensource-src-4.8.1
    # filesystem related paths
    mtdutils_PATH    := $(TI_SW_ROOT)/mtd_utils
    #TFTP_HOME     := $(dvr_rdk_BASE)/tftphome
    TFTP_HOME     := /tftpboot
    TARGET_FS     := $(dvr_rdk_BASE)/target/rfs
    TARGET_FS_DIR := $(dvr_rdk_PATH)/bin/ti816x
    TARGET_EXE_DIR := opt/dvr_rdk/ti816x
    ROOTDIR := $(dvr_rdk_PATH)
    ifeq ($(DVR_RDK_BOARD_TYPE),DM814X_TI_EVM)
    TARGET_FS_DIR := $(dvr_rdk_PATH)/bin/ti814x
    TARGET_FS     := $(dvr_rdk_BASE)/target/rfs_814x
    TARGET_EXE_DIR := opt/dvr_rdk/ti814x
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM814X_BCH_DVR)
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM816X_TI_EVM)
    TARGET_FS     := $(dvr_rdk_BASE)/target/rfs_816x
    endif
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM810X_TI_EVM)
    TARGET_FS_DIR := $(dvr_rdk_PATH)/bin/ti810x
    TARGET_FS     := $(dvr_rdk_BASE)/target/rfs_810x
    TARGET_EXE_DIR := opt/dvr_rdk/ti810x
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM810X_BCH_DVR)
    endif
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM810X_BCH_120_DVR)
    endif
    ifeq ($(DEMOTYPE), )
    #  DEMOTYPE := link_api_sd_demo
    endif
    endif
    # set to TRUE to enable standalone RTSP demo
    DEMO_RTSP_ENABLE := FALSE
    DVR_RDK_BOARD := DVR_RDK_BOARD_TYPE
    ifeq ($(DVR_RDK_BOARD_TYPE),DM816X_DVR)
      DVR_RDK_BOARD := ud816x_dvr
    endif
    ifeq ($(DVR_RDK_BOARD_TYPE),DM810X_DVR)
      DVR_RDK_BOARD := ud810x_dvr
    endif
    ifeq ($(CORE), )
      CORE := m3vpss
    endif
    # Default platform
    ifeq ($(PLATFORM), )
      PLATFORM := ti816x-evm
      PLATFORM := ti814x-evm
    endif
    endif
      PLATFORM := ti810x-evm
    endif
    endif
    endif
    endif
    endif
    # DDR_MEM and LINUX_MEM set.
    # TI816X: 1G,256M; 2G,512M;
    # TI814X: 512M,128M;
    # TI810X: 256M,64M; 512M,128M; 512,192M; 512,256M;
    ifeq ($(PLATFORM), ti816x-evm)
    ifeq ($(DDR_MEM), )
      DDR_MEM := DDR_MEM_1024M
    ifeq ($(LINUX_MEM),)
    LINUX_MEM := LINUX_MEM_256M
    #    LINUX_MEM := LINUX_MEM_128M
    endif
    else
    # DDR_MEM := DDR_MEM_2048M
    endif
    endif
    endif
      VS_CARD := WITH_VS_CARD
    #  VS_CARD := WITHOUT_VS_CARD
    endif
    ifeq ($(PLATFORM), ti814x-evm)
    ifeq ($(DDR_MEM), )
      DDR_MEM := DDR_MEM_512M
    endif
    endif
    endif
    ifeq ($(PLATFORM), ti810x-evm)
    ifeq ($(DDR_MEM), )
    #  DDR_MEM := DDR_MEM_256M
    endif
    #  LINUX_MEM := LINUX_MEM_64M
    #  LINUX_MEM := LINUX_MEM_192M
    #  LINUX_MEM := LINUX_MEM_256M
    endif
    endif
    #Set String Format when use LINUX_MEM and DDR_MEM as suffix of filenames.
    #Prefix of size
    DDR_SIZE_PREFIX :=
    LINUX_SIZE_PREFIX :=
    #Will be used as filename suffix.
    DDR_SUFFIX := $(subst DDR_MEM_,$(DDR_SIZE_PREFIX),$(DDR_MEM))
    # Default profile
    ifeq ($(PROFILE_m3video), )
      PROFILE_m3video := release
    #  PROFILE_m3video := debug
    endif
    ifeq ($(PROFILE_m3vpss), )
      PROFILE_m3vpss := release
    #  PROFILE_m3vpss := debug
    endif
    ifneq ($(PLATFORM), ti810x-evm)
    ifeq ($(PROFILE_c6xdsp), )
      PROFILE_c6xdsp := debug
    endif
    endif
    # Default klockwork build flag
    ifeq ($(KW_BUILD), )
      KW_BUILD := no
    endif
    USE_SYSLINK_NOTIFY=0
    XDCPATH = $(bios_PATH)/packages;$(xdc_PATH)/packages;$(ipc_PATH)/packages;$(hdvpss_PATH)/packages;$(fc_PATH)/packages;$(dvr_rdk_PATH);$(syslink_PATH)/packages;$(xdais_PATH)/packages;$(edma3lld_PATH)/packages;
    ifeq ($(DISABLE_AUDIO), )
      DISABLE_AUDIO := no
    endif
    #Power Optimization based profile use for 810x-evm
    810X_SAVE_POWER_MODE=no
    #Device Collaterals
    DEV_COLLATERALS  := $(TI_SW_ROOT)/device_collateral
    TREAT_WARNINGS_AS_ERROR=yes
    BUILD_BIOS6_FIRMWARE=yes
    ifeq ($(PLATFORM),ti816x-evm)
    SYSTEM_ETH_OFFLOAD_ENABLE=yes
    SYSTEM_ETH_OFFLOAD_CORE_DSP=yes
    endif
    ifeq ($(PLATFORM),ti810x-evm)
    SYSTEM_ETH_OFFLOAD_ENABLE=no
    endif
    DVR_RDK_ISS_LIB_PATH=$(dvr_rdk_PATH)/mcfw/src_bios6/alg/simcop/lib
    DVR_RDK_ISS_INC_PATH=$(dvr_rdk_PATH)/mcfw/src_bios6/alg/simcop/inc
    endif
    RPE_BUILD_VARS = ipc_PATH="${ipc_PATH}" \
    bios_PATH="${bios_PATH}" \
    xdc_PATH="${xdc_PATH}" \
    xdais_PATH="${xdais_PATH}" \
    syslink_PATH="${syslink_PATH}" \
    kernel_PATH="${KERNELDIR}" \
    CODEGEN_PATH_A8="${CODEGEN_PATH_A8}" \
    CGT_ARM_PREFIX="${CSTOOL_PREFIX}" \
    CODEGEN_PATH_DSP="${CODEGEN_PATH_DSP}" \
    CODEGEN_PATH_DSPELF="${CODEGEN_PATH_DSP}" \
    ROOTDIR="${rpe_PATH}" \
    aaclcdec_PATH="${aaclcdec_PATH}" \
    aaclcenc_PATH="${aaclcenc_PATH}"
    include $(ROOTDIR)/makerules/build_config.mk
    include $(ROOTDIR)/makerules/env.mk
    include $(ROOTDIR)/makerules/platform.mk
    include $(dvr_rdk_PATH)/component.mk
    LINUX_SUFFIX :=$(shell cat ${CONFIG_BLD_XDC_m3}|sed -n 's/.*LINUX_SIZE\s*=\s*\([0-9]*\)\s*\*\s*MB/\1M/p')
    LINUX_SUFFIX := $(subst ;,$(LINUX_SIZE_PREFIX),$(LINUX_SUFFIX))
    export OS
    export PLATFORM
    export CORE
    export PROFILE_m3vpss
    export PROFILE_m3video
    export PROFILE_c6xdsp
    export CODEGEN_PATH_M3
    export CODEGEN_PREFIX
    export CODEGEN_PATH_A8
    export CODEGEN_PATH_DSP
    export bios_PATH
    export xdc_PATH
    export hdvpss_PATH
    export dvr_rdk_PATH
    export ipc_PATH
    export fc_PATH
    export xdais_PATH
    export h264dec_DIR
    export h264enc_DIR
    export jpegdec_DIR
    export mpeg4dec_DIR
    export jpegenc_DIR
    export mpeg2dec_DIR
    export h264dec_PATH
    export h264enc_PATH
    export jpegdec_PATH
    export mpeg4dec_PATH
    export mpeg4enc_PATH
    export mpeg4enc_DIR
    export jpegenc_PATH
    export mpeg2dec_PATH
    export hdvicplib_PATH
    export linuxdevkit_PATH
    export edma3lld_PATH
    export ROOTDIR
    export XDCPATH
    export KW_BUILD
    export syslink_PATH
    export KERNELDIR
    export TARGET_FS_DIR
    export TARGET_EXE_DIR
    export UBOOTDIR
    export DVR_RDK_BOARD_TYPE
    export USE_SYSLINK_NOTIFY
    export DEST_ROOT
    export dvr_rdk_BASE
    export TFTP_HOME
    export LINUX_MEM
    export DDR_MEM
    export DISABLE_AUDIO
    export dvrapp_PATH
    export nvrapp_PATH
    export memcpy_neon_PATH
    export live555_PATH
    export qt_PATH
    export 810X_SAVE_POWER_MODE
    export TREAT_WARNINGS_AS_ERROR
    export VS_CARD
    export SC_SCRIPTS_BASE_DIR
    export iss_PATH
    export SYSTEM_VCOP_ENABLE
    export SYSTEM_VCOP_VIDEOM3
    export DVR_RDK_ISS_LIB_PATH
    export DVR_RDK_ISS_INC_PATH
    export DEMOTYPE
    export rpe_PATH
    export RPE_BUILD_VARS
    export aaclcdec_PATH
    export aaclcenc_PATH
    export mtdutils_PATH
    export DDR_SUFFIX
    export LINUX_SUFFIX
    export TI_SW_ROOT
    export DEMO_RTSP_ENABLE
    export LSP_COLLATERALS
    export DEV_COLLATERALS
    export SYSTEM_ETH_OFFLOAD_ENABLE
    export SYSTEM_ETH_OFFLOAD_CORE_DSP
    export watermark_lib_PATH
    Thanking you,
    Balaji
  • Dear Sir,
              I am new to Linux.  kindly support me until gets confident on ubuntu.
    Thanking you,
    Balaji
  • Fixed issue.
    how i fixed this issues by
    make -s sys_all
    then
    make -s all
    Now , there is no error.
    Balaji
