dm8148 capture 1080p@xx
I using the TI EVM with ezsdk release, the capture encode application does 1080p60, I want the different variants of 1080p to work as well
1080p 30 fps, 1080p 50 fps. What modifications to the application needs to be done to get it working for example 1080p30 ?
Thanks And Regards,
Mike
    It should be working for 1080p30 fps. Have you try is with option -f 30?
    Which EZSDK version you are using?
    BR
    Margarita
  • Hi Margarita,
    My source itself is 1080p30 and I tried with -f 30 option it doesn’t work.
    Thanks And Regards,
    Mike
    What you are observing ?
    BR
    Margarita
    I dont see any output on the TV screen, Please find the below log:
    $ capture_encode_a8host_debug.xv5T -o sample.h264 -m 1080p -f 30 -b 1000000 -n 1000 -d 0
    output file: sample.h264
    bit_rate: 1000000
    frame_rate: 30
    num_frames: 1000
    mode: 1080p
    display_id: 1
    Capture-Encode example
    OMX_Init completed
    UIAClient is ready to send a UIA configuration command
    UIAClient received UIA_CONFIGURE_ACK
    UIAClient is done sending requests
    openeing file
    capture compoenent is created
    control TVP compoenent is created
    Buffer Size computed: 3110400
    set input port params (width = 1920, height = 1080) applying skip mask
    enable capture output port
    got eventEnable/Disable Event
    dei compoenent is created
    set output port params (width = 1920, height = 1080)set output port params (width = 1920, height = 1080)set number of channelsset input resolutionset outp
    ut resolutionenable dei input port
    enable dei output port 0
    enable dei output port 1
    encoder compoenent is created
    found handle 0x1307e0 for component OMX.TI.VPSSM3.VFDC
    got display handle
    found handle 0x1347e8 for component OMX.TI.VPSSM3.CTRL.DC
    Buffer Size computed: 1728000
    set input port params (width = 1920, height = 1080)setting input and output memory type to defaultenable input port
    connect call for capture-Dei
    connect call for dei- encoder
    connect call for dei-display
    got eventState changed to: OMX_StateIdle
    Capture outport buffers allocated
    Capture is in IDLE state
    Dei input port use buffer done
    DEI outport buffers allocated
    DEI is in IDLE state
    encoder input port use buffer done
    encoder outport buffers allocated
    Encoder state IDLE
    ctrl-dc state IDLE
    display buffers allocated
    waiting for IDLEgot eventState changed to: OMX_StateIdle
    display state IDLE
    got eventState changed to: OMX_StateExecuting
    display control state execute
    display state execute
    encoder state execute
    dei state execute
    capture state execute
    ^C^C^C^C^Z
  • Hi Margarita,
    Just to confirm my camera source is 1080p30 component and I have tested it connecting to the TV screen.
    In this link processors.wiki.ti.com/.../OMX_EZSDK_Examples its says the source needs to
    1080p60 so what changes need to be done to get 1080p30 ?
    Thanks And Regards,
    Mike
    Provide me this log :
    ./loggerSMDump.out 0x9e400000 0x100000 all
    Also you could check in the example :
    if (pAppData->nFrameRate == 30)
    OMX_INIT_PARAM (&sCapSkipFrames);
    printf (" applying skip mask \n");
    sCapSkipFrames.frameSkipMask = 0x2AAAAAAA;
    eError = OMX_SetConfig (pAppData->pCapHandle,
    (OMX_INDEXTYPE) OMX_TI_IndexConfigVFCCFrameSkip,
    (OMX_PTR) & sCapSkipFrames);
    BR
    Margarita
  • Hi Margarita,
    Please find the below logs:
    $ capture_encode_a8host_debug.xv5T -o sample.h264 -m 1080p -f 60 -b 1000000 -d 0 -n 100
    bit_rate: 1000000
    frame_rate: 60
    num_frames: 100
    mode: 1080p
    display_id: 0
    OMX_Init completed
    openeing file
    set input port params (width = 1920, height = 1080)enable capture output port
    got display handle
    Buffer Size computed: 4147200
    Encoder state IDLE
    ctrl-dc state IDLE
    display state IDLE
    dei state execute
    ^C^Z
    N:VPSS P:2 #:00908 T:00000005dc0a2243 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:00909 T:00000005dc0aadc5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:00910 T:00000005dc0dad31 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:00911 T:00000005dc0e8a39 M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 2
    N:VPSS P:2 #:00912 T:00000005dc0f5317 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:00914 T:00000005dc11de54 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:00915 T:00000005dc136731 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS P:2 #:00916 T:00000005dc13df13 M:xdc.runtime.Main S:Entered: OMX_BASE_DIO_Init (0x9f2a3718, 0, OMX.DIO.NONTUNNEL, 0x9f2a30b4)
    N:VPSS P:2 #:00917 T:00000005dc14aedf M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS P:2 #:00918 T:00000005dc155777 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS P:2 #:00919 T:00000005dc183577 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:VPSS P:2 #:00920 T:00000005dc1a8f65 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:00913 T:00000005dc1113a3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:00922 T:00000005dc1dcd4f M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:00921 T:00000005dc1cf515 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00924 T:00000005dc20ca97 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:00925 T:00000005dc240055 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:00923 T:00000005dc22e8e1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00927 T:00000005dc271a1b M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:00926 T:00000005dc261a4b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00929 T:00000005dc2a447f M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:00928 T:00000005dc29727d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00930 T:00000005dc2cdc73 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00931 T:00000005dc2da3df M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00932 T:00000005dc2e24dd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00933 T:00000005dc2ea9c7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:00934 T:00000005dc2f21ff M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransition> @line<339> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:00935 T:00000005dc31174d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00937 T:00000005dc32f17d M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:00936 T:00000005dc319d65 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:00938 T:00000005dc357c53 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS P:2 #:00939 T:00000005dc361515 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS P:2 #:00940 T:00000005dc369fd7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00941 T:00000005dc37269f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00942 T:00000005dc37bbfb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00943 T:00000005dc3832f9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00944 T:00000005dc38ab77 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00945 T:00000005dc39321d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:00946 T:00000005dc39d2c7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransitionComplete> @line<535> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:00947 T:00000005dc3a713b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1398>
    N:VPSS P:2 #:00948 T:00000005dc3aed0d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1453> with error<0:ErrorNone>
    N:VPSS P:2 #:00949 T:00000005dc3b78eb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:00950 T:00000005dc3c01af M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:00951 T:00000005dc3eef87 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:00952 T:00000005dc3fe31f M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS P:2 #:00953 T:00000005dc409a65 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:00954 T:00000005dc4253cd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:00955 T:00000005dc42ea73 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00956 T:00000005dc437547 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00957 T:00000005dc43ff2d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00958 T:00000005dc4480fd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00959 T:00000005dc452a07 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00960 T:00000005dc45e93b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00961 T:00000005dc466f0d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00962 T:00000005dc46fbbb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:00963 T:00000005dc477717 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS P:2 #:00964 T:00000005dc4814e4 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00965 T:00000005dc488deb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:00966 T:00000005dc4926c1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS P:2 #:00967 T:00000005dc49b06f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS P:2 #:00968 T:00000005dc4a3a5f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00969 T:00000005dc4ac053 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00970 T:00000005dc4b4c3f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00971 T:00000005dc4bd3d9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00972 T:00000005dc4c5909 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00973 T:00000005dc4ce8c5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:00974 T:00000005dc4d6873 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS P:2 #:00975 T:00000005dc4dfa81 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:00976 T:00000005dc4e8793 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:00977 T:00000005dc5161af M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:00978 T:00000005dc525861 M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS P:2 #:00979 T:00000005dc5308b3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:00980 T:00000005dc54b3eb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:00981 T:00000005dc5547d5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00982 T:00000005dc55d461 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00983 T:00000005dc56623f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00984 T:00000005dc56e2fd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00985 T:00000005dc578f47 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00986 T:00000005dc58533f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00987 T:00000005dc58d0d3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00988 T:00000005dc595c17 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:00989 T:00000005dc59d1d7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS P:2 #:00990 T:00000005dc5cb3ab M:xdc.runtime.Main S:Mosaic configuration DONE!!
    N:Video P:1 #:00208 T:00000005dde87ff1 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:00991 T:00000005ddde4983 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00209 T:00000005dde96761 M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS P:2 #:00992 T:00000005dddef96b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:Video P:1 #:00210 T:00000005ddea2633 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:00993 T:00000005dddf9347 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:Video P:1 #:00211 T:00000005ddebc59f M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00994 T:00000005dde01c5b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:Video P:1 #:00212 T:00000005ddec82eb M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00995 T:00000005dde0a3fb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:Video P:1 #:00213 T:00000005dded0a9b M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00996 T:00000005dde12c37 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00214 T:00000005dded9a8b M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:00997 T:00000005dde1bef5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:Video P:1 #:00215 T:00000005ddee1ff7 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS P:2 #:00998 T:00000005dde2330b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:Video P:1 #:00216 T:00000005ddeef167 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3657::VENC->Idle to Executing Transition Begin
    N:VPSS P:2 #:00999 T:00000005dde2a979 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00217 T:00000005ddef7345 M:xdc.runtime.Main S:_OMX_TI_VIDENC_EnablePeriodicDataProcess::Line 5374::VENC->Enabled Notification based data processing
    N:VPSS P:2 #:01000 T:00000005dde33573 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:Video P:1 #:00218 T:00000005ddeff13b M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3671::VENC->Idle to Executing Transition End
    N:VPSS P:2 #:01001 T:00000005dde3b1ef M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:Video P:1 #:00219 T:00000005ddf063c3 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3936::VENC->Before OMX_EventCmdComplete Notify
    N:VPSS P:2 #:01002 T:00000005dde441b9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:Video P:1 #:00220 T:00000005ddf0ddd1 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:01003 T:00000005dde4e457 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:Video P:1 #:00221 T:00000005ddf18bb5 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:01004 T:00000005dde8285f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:Video P:1 #:00222 T:00000005ddf22abd M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS P:2 #:01005 T:00000005dde9d6d9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:Video P:1 #:00223 T:00000005ddf2b1d3 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3942::VENC->OMX_EventCmdComplete Notify Done
    N:VPSS P:2 #:01006 T:00000005ddea782d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:Video P:1 #:00224 T:00000005ddf34f41 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS P:2 #:01007 T:00000005ddeb4695 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:Video P:1 #:00225 T:00000005ddf3d833 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:01008 T:00000005ddebe8f1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:Video P:1 #:00226 T:00000005ddf4634f M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01009 T:00000005dded2c7f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00227 T:00000005ddf4f481 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:01010 T:00000005ddedc229 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00228 T:00000005ddf56d27 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:01011 T:00000005ddfb9f47 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SendCommand> @line<499>
    N:Video P:1 #:00229 T:00000005ddf5e5c1 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01012 T:00000005ddfc8d1b M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:Video P:1 #:00230 T:00000005ddf674d5 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:01013 T:00000005ddfd73c7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:Video P:1 #:00231 T:00000005ddf6efc5 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS P:2 #:01014 T:00000005ddfef34f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00232 T:00000005ddf79da9 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:01015 T:00000005ddffab77 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:Video P:1 #:00233 T:00000005ddf829e1 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:01016 T:00000005de0030c1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00234 T:00000005ddfb48e7 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01017 T:00000005de00c5ab M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:Video P:1 #:00235 T:00000005ddfcfe2d M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01018 T:00000005de01464d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:Video P:1 #:00236 T:00000005ddfdc7bd M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01019 T:00000005de049863 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00237 T:00000005ddff5c3f M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01020 T:00000005de053451 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:Video P:1 #:00238 T:00000005ddfff86b M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:01021 T:00000005de05d90b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:Video P:1 #:00239 T:00000005de008823 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:01022 T:00000005de06649f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:Video P:1 #:00240 T:00000005de0117a5 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:01023 T:00000005de06fd13 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:Video P:1 #:00241 T:00000005de01ad51 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01024 T:00000005de07868b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00242 T:00000005de0244f7 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01025 T:00000005de082269 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:01026 T:00000005de08a0af M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:01027 T:00000005de0920e7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01028 T:00000005de09d33d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:01029 T:00000005de0a5b44 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS P:2 #:01030 T:00000005de0aef3d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:01031 T:00000005de0b83c3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:01032 T:00000005de0e88fb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:01033 T:00000005de0f6725 M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS P:2 #:01034 T:00000005de103e87 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:01035 T:00000005de11fbcd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01036 T:00000005de138625 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01037 T:00000005de14149b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01038 T:00000005de154f6f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01039 T:00000005de15f82b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01040 T:00000005de17477b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01041 T:00000005de17d4eb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:01042 T:00000005de18604b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:01043 T:00000005de18eeeb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:01044 T:00000005de1982d3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01045 T:00000005de1a074f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01046 T:00000005de1ac157 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01047 T:00000005de1b5f21 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:01048 T:00000005de1bf13b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01049 T:00000005de1c7ceb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:01050 T:00000005de1cf69d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS P:2 #:01051 T:00000005de1d97c3 M:xdc.runtime.Main S:Starting Capture Driver
    N:VPSS P:2 #:01052 T:00000005de1df921 M:xdc.runtime.Main S:VFCC Capture_drvOverflowDetectAndReset::Line 3648::VIP Reset Happend, reset count:: 1 portId : 0
    N:VPSS P:2 #:01053 T:00000005de1e7c29 M:xdc.runtime.Main S:VFCC VIP Id:0
    N:VPSS P:2 #:01054 T:00000005de6c2047 M:xdc.runtime.Main S:RESET Count:: 1 , curTime:: 61345
    N:VPSS P:2 #:01055 T:00000005de6c9af5 M:xdc.runtime.Main S:Capture Driver Started!!
    N:VPSS P:2 #:01056 T:00000005de6d22cf M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01057 T:00000005de6d8249 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01058 T:00000005de6de0eb M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01059 T:00000005de6e3e5b M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01060 T:00000005de6e9d07 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01061 T:00000005de6efa6b M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01062 T:00000005de6f5949 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01063 T:00000005de6fafe1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:01064 T:00000005de702b11 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:01065 T:00000005de70c6c7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS P:2 #:01066 T:00000005de71c789 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS P:2 #:01067 T:00000005de725837 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:01068 T:00000005de72dba9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01069 T:00000005de736d07 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:01070 T:00000005de73e477 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:01071 T:00000005de745cf5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01072 T:00000005de74e64b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:01073 T:00000005de756441 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS P:2 #:01074 T:00000005de75f093 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:01075 T:00000005de767d19 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:01076 T:00000005de7a6fe7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:01077 T:00000005de7b5727 M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS P:2 #:01078 T:00000005de7c07d7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:01079 T:00000005de7f3729 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01080 T:00000005de80d193 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01081 T:00000005de815acd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:01082 T:00000005de81df47 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:01083 T:00000005de826771 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:01084 T:00000005de838e3f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01085 T:00000005de842565 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01086 T:00000005de84e4a3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01087 T:00000005de8584f7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:01088 T:00000005de860021 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01089 T:00000005de868781 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:01090 T:00000005de8703f1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS P:2 #:01091 T:00000005de879a1f M:xdc.runtime.Main S:Entered: _OMX_CTRLTvpDrvStart @ line 631
    N:VPSS P:2 #:01092 T:00000005de87fca5 M:xdc.runtime.Main S:Starting Video Decoder Capture Driver
    N:VPSS P:2 #:01093 T:00000005de88c2b5 M:xdc.runtime.Main S: CAPTUREAPP: Detect video in progress for inst 0 !!!
    N:VPSS P:2 #:01094 T:00000005ded35119 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :1 Total Capture Frame Count 0
    N:VPSS P:2 #:01095 T:00000005e0ecd4c7 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01096 T:00000005e3548a37 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    ....... The same goes on printing.
    #!/bin/sh
    configure_lcd()
    echo "Configuring fb0 to LCD"
    echo 1:dvo2 > /sys/devices/platform/vpss/graphics0/nodes
    echo 0 > /sys/devices/platform/vpss/display1/enabled
    echo 33500,800/164/89/10,480/10/23/10,1 > /sys/devices/platform/vpss/display1/timings
    echo triplediscrete,rgb888 > /sys/devices/platform/vpss/display1/output
    echo 1 > /sys/devices/platform/vpss/display1/enabled
    fbset -xres 800 -yres 480 -vxres 800 -vyres 480
    case "$1" in
    start)
    # configure the clocks
    echo "configure the clocks(prcm)";
    prcm_config_app s;
    sleep 1;
    # Insert the syslink module for IPC
    echo "Insert the syslink"
    insmod syslink.ko;
    sleep 2;
    firmware_loader 1 dm814x_hdvicp.xem3 start;
    sleep 1;
    echo "Loading HDVPSS Firmware";
    firmware_loader 2 dm814x_hdvpss.xem3 start;
    sleep 1;
    echo "Loading DSP Firmware";
    firmware_loader 0 dm81xx_c6xdsp.xe674 start;
    sleep 1;
    insmod vpss.ko sbufaddr=0xBFB00000 mode=hdmi:1080p-60 i2c_mode=1;
    echo "Loading VPSS module";
    sleep 1;
    insmod ti81xxfb.ko vram=0:24M,1:16M,2:6M;
    echo "Loading FB module";
    sleep 1;
    configure_lcd
    insmod ti81xxhdmi.ko;
    echo "Loading HDMI module"
    sleep 1;
    stop)
    firmware_loader 0 dm81xx_c6xdsp.xe674 stop
    firmware_loader 1 dm814x_hdvicp.xem3 stop
    rmmod ti81xxhdmi.ko
    rmmod ti81xxfb.ko
    rmmod vpss.ko
    firmware_loader 2 dm814x_hdvpss.xem3 stop
    rm /tmp/firmware.*
    rmmod syslink.ko
    echo "Usage: /etc/init.d/load-hd-firmware.sh {start|stop}"
    exit 1
    esac
    exit 0
    Thanks And Regards,
    Mike
    Sorry posted wrong dump earlier:
    ./capture_encode_a8host_debug.xv5T -o sample.h264 -m 1080p -f 30 -b 1000000 -d 0 -n 10
    bit_rate: 1000000
    frame_rate: 30
    num_frames: 10
    mode: 1080p
    display_id: 0
    OMX_Init completed
    openeing file
    found handle 0x1247e0 for component OMX.TI.VPSSM3.VFDC
    got display handle
    found handle 0x1287e8 for component OMX.TI.VPSSM3.CTRL.DC
    Encoder state IDLE
    ctrl-dc state IDLE
    display state IDLE
    dei state execute
    Hung....
    N:Video P:1 #:00121 T:00000004d5331fd3 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS P:2 #:00882 T:00000004d52fc28b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:Video P:1 #:00122 T:00000004d534a937 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS P:2 #:00883 T:00000004d5305c6b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00123 T:00000004d5352237 M:xdc.runtime.Main S:Entered: OMX_BASE_DIO_Init (0x9dff2620, 0, OMX.DIO.NONTUNNEL, 0x9dff1f94)
    N:VPSS P:2 #:00884 T:00000004d530f785 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00124 T:00000004d5361a91 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:Video P:1 #:00125 T:00000004d536a2c5 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Open> @line<252>
    N:Video P:1 #:00126 T:00000004d539778f M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:Video P:1 #:00120 T:00000004d531f0d5 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00128 T:00000004d53c0973 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00129 T:00000004d53f04f9 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00127 T:00000004d53b106b M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:Video P:1 #:00131 T:00000004d54246ef M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00130 T:00000004d5410e3f M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00133 T:00000004d54530bb M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00132 T:00000004d54465bb M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:Video P:1 #:00134 T:00000004d5483005 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00136 T:00000004d54b427b M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00135 T:00000004d54a353f M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<_OMX_BASE_HandleStateTransition> @line<339> msg<Loaded to Idle Transition>
    N:Video P:1 #:00137 T:00000004d54e5241 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00139 T:00000004d551786b M:xdc.runtime.Main S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00140 T:00000004d552f86b M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Init> @line<120>
    N:Video P:1 #:00141 T:00000004d5537857 M:xdc.runtime.Main S:Entered: OMX_BASE_DIO_Init (0x9dff2620, 1, OMX.DIO.NONTUNNEL, 0x9dff1f8c)
    N:Video P:1 #:00142 T:00000004d5546185 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:Video P:1 #:00143 T:00000004d554e6af M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Open> @line<252>
    N:Video P:1 #:00144 T:00000004d562bad1 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:Video P:1 #:00138 T:00000004d55076eb M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3525::VENC->Loaded to Idle Transition Begin
    N:Video P:1 #:00146 T:00000004d565613f M:xdc.runtime.Main S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00145 T:00000004d5643f59 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3529::VENC->Before VIDENC2_Create
    N:Video P:1 #:00148 T:00000004d568c0db M:xdc.runtime.Main S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00147 T:00000004d567cd0f M:xdc.runtime.Main S:Calling VIDENC2_create for ivahd_h264enc_0
    N:Video P:1 #:00149 T:00000004d56bcc7f M:xdc.runtime.Main S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00150 T:00000004d56f0e11 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00151 T:00000004d5725d65 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00152 T:00000004d5759c45 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00153 T:00000004d578e64f M:xdc.runtime.Main S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00154 T:00000004d5830657 M:xdc.runtime.Main S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS P:2 #:00885 T:00000004d5a40de9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_SendCommand> @line<499>
    N:Video P:1 #:00155 T:00000004d58387f5 M:xdc.runtime.Main S:accessDimension = 0, accessUnit = 1 sizeDim0 = 69376 sizeDim1 = 0 alignment = 32
    N:VPSS P:2 #:00886 T:00000004d5a4fc17 M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 2
    N:Video P:1 #:00156 T:00000004d5845afb M:xdc.runtime.Main S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS P:2 #:00887 T:00000004d5a5b8c1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:Video P:1 #:00157 T:00000004d584e15f M:xdc.runtime.Main S:accessDimension = 0, accessUnit = 1 sizeDim0 = 18240 sizeDim1 = 0 alignment = 32
    N:VPSS P:2 #:00888 T:00000004d5a721f1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00158 T:00000004d5859a0d M:xdc.runtime.Main S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS P:2 #:00889 T:00000004d5a7d701 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:Video P:1 #:00159 T:00000004d585fac5 M:xdc.runtime.Main S:accessDimension = 0, accessUnit = 1 sizeDim0 = 2960 sizeDim1 = 0 alignment = 32
    N:VPSS P:2 #:00890 T:00000004d5a87bf9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00160 T:00000004d586a915 M:xdc.runtime.Main S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS P:2 #:00891 T:00000004d5a90967 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:Video P:1 #:00161 T:00000004d5870851 M:xdc.runtime.Main S:accessDimension = 0, accessUnit = 1 sizeDim0 = 36 sizeDim1 = 0 alignment = 32
    N:VPSS P:2 #:00892 T:00000004d5a98f87 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<_OMX_BASE_HandleStateTransition> @line<339> msg<Loaded to Idle Transition>
    N:Video P:1 #:00162 T:00000004d587b5d1 M:xdc.runtime.Main S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS P:2 #:00893 T:00000004d5ab6045 M:xdc.runtime.Main S:Display Controller Path configured for 0!!
    N:Video P:1 #:00163 T:00000004d5881435 M:xdc.runtime.Main S:accessDimension = 1, accessUnit = 2 sizeDim0 = 2048 sizeDim1 = 1152 alignment = 32
    N:Video P:1 #:00164 T:00000004d588cb19 M:xdc.runtime.Main S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS P:2 #:00894 T:00000004d5abc559 M:xdc.runtime.Main S: Display Controller Driver Create - DONE !!!
    N:Video P:1 #:00165 T:00000004d5892c2d M:xdc.runtime.Main S:accessDimension = 1, accessUnit = 3 sizeDim0 = 2048 sizeDim1 = 576 alignment = 32
    N:VPSS P:2 #:00895 T:00000004d5ac2563 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00166 T:00000004d589eed7 M:xdc.runtime.Main S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS P:2 #:00896 T:00000004d5aca429 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:Video P:1 #:00167 T:00000004d58a528b M:xdc.runtime.Main S:accessDimension = 1, accessUnit = 2 sizeDim0 = 2048 sizeDim1 = 1152 alignment = 32
    N:VPSS P:2 #:00897 T:00000004d5ad4115 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:Video P:1 #:00168 T:00000004d58b2237 M:xdc.runtime.Main S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS P:2 #:00898 T:00000004d5adca88 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:Video P:1 #:00169 T:00000004d58b8443 M:xdc.runtime.Main S:accessDimension = 1, accessUnit = 3 sizeDim0 = 2048 sizeDim1 = 576 alignment = 32
    N:VPSS P:2 #:00899 T:00000004d5ae739b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:Video P:1 #:00170 T:00000004d58d270f M:xdc.runtime.Main S:VIDENC2_control(XDM_GETSTATUS) after VIDENC2_create returned errorcode = 0x0
    N:VPSS P:2 #:00900 T:00000004d5af0069 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00171 T:00000004d58f0f1f M:xdc.runtime.Main S:VIDENC2_control(XDM_GETSTATUS) returned errorcode = 0x0
    N:VPSS P:2 #:00901 T:00000004d5af9baf M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:Video P:1 #:00172 T:00000004d58f7e19 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3536::VENC->VIDENC2_Create Successful
    N:VPSS P:2 #:00902 T:00000004d5b014d9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:Video P:1 #:00173 T:00000004d58ff6f7 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3568::VENC->Before IvaServer_registerInstance
    N:VPSS P:2 #:00903 T:00000004d5b090a3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00174 T:00000004d590a91f M:xdc.runtime.Main S:IvaScheduler_registerInstance::Line 665::Width 1920::Height 1080::Resolution 4
    N:VPSS P:2 #:00904 T:00000004d5b11f65 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:Video P:1 #:00175 T:00000004d5917483 M:xdc.runtime.Main S:IvaScheduler_asssignStaticResource::Line 356::CodecId 0::Allocated IVAHD 0::Estimated IVAHD Load of Codec(MHz) 250::Total IVAHD load(MHz) 250
    N:VPSS P:2 #:00905 T:00000004d5b19f2b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<_OMX_BASE_HandleStateTransitionComplete> @line<535> msg<Loaded to Idle Transition>
    N:Video P:1 #:00176 T:00000004d5921879 M:xdc.runtime.Main S:IvaScheduler_registerInstance::Line 816::Scheduling Scheme 0
    N:VPSS P:2 #:00906 T:00000004d5b22e37 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1398>
    N:Video P:1 #:00177 T:00000004d5927e21 M:xdc.runtime.Main S:IvaScheduler_registerInstance::Line 818::Number of IVAHDs 1
    N:VPSS P:2 #:00907 T:00000004d5b2a8c9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1453> with error<0:ErrorNone>
    N:Video P:1 #:00178 T:00000004d592e727 M:xdc.runtime.Main S:IvaScheduler_registerInstance::Line 820::Number of registered channels 1
    N:VPSS P:2 #:00908 T:00000004d5b32e1f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:Video P:1 #:00179 T:00000004d59358f3 M:xdc.runtime.Main S:IvaScheduler_registerInstance::Line 825::IVAHD Queue 0::Number of channels 1
    N:VPSS P:2 #:00909 T:00000004d5b3b927 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:Video P:1 #:00180 T:00000004d593cc97 M:xdc.runtime.Main S:IvaScheduler_registerInstance::Line 827::IVAHD Queue 0::Number of frames 0
    N:VPSS P:2 #:00910 T:00000004d5b6da85 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SendCommand> @line<499>
    N:Video P:1 #:00181 T:00000004d5944281 M:xdc.runtime.Main S:IvaScheduler_registerInstance::Line 829::IVAHD Queue 0::Number of commands 0
    N:VPSS P:2 #:00911 T:00000004d5b7b8cd M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 2
    N:Video P:1 #:00182 T:00000004d594b551 M:xdc.runtime.Main S:IvaScheduler_registerInstance::Line 831::IVAHD Queue 0::Last Codec Id 0
    N:VPSS P:2 #:00912 T:00000004d5b8655d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:Video P:1 #:00183 T:00000004d5952869 M:xdc.runtime.Main S:IvaScheduler_registerInstance::Line 833::IVAHD Queue 0::Load(MHz) 250
    N:VPSS P:2 #:00914 T:00000004d5bafa4f M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00184 T:00000004d5959fe5 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3576::VENC->IvaServer_registerInstance Successful
    N:VPSS P:2 #:00915 T:00000004d5bc8709 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Init> @line<120>
    N:Video P:1 #:00185 T:00000004d59645b1 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3646::VENC->Loaded to Idle Transition End
    N:VPSS P:2 #:00916 T:00000004d5bd013b M:xdc.runtime.Main S:Entered: OMX_BASE_DIO_Init (0x9f2a3718, 0, OMX.DIO.NONTUNNEL, 0x9f2a30b4)
    N:Video P:1 #:00186 T:00000004d596bc3f M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3936::VENC->Before OMX_EventCmdComplete Notify
    N:VPSS P:2 #:00917 T:00000004d5bdd65d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:Video P:1 #:00187 T:00000004d5974aa3 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00918 T:00000004d5be55dd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Open> @line<252>
    N:Video P:1 #:00188 T:00000004d597c74d M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:00919 T:00000004d5c1512b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:Video P:1 #:00189 T:00000004d59866af M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS P:2 #:00920 T:00000004d5c3bc27 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00190 T:00000004d598eca7 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3942::VENC->OMX_EventCmdComplete Notify Done
    N:VPSS P:2 #:00913 T:00000004d5ba1189 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:Video P:1 #:00191 T:00000004d59986f3 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS P:2 #:00922 T:00000004d5c6f1f7 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00192 T:00000004d59a1163 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00921 T:00000004d5c5fc35 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:Video P:1 #:00193 T:00000004d59a9fd3 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00923 T:00000004d5c9f61f M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00194 T:00000004d59b3643 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00925 T:00000004d5cd2ecf M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00195 T:00000004d59bad1f M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00924 T:00000004d5cbff4b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:Video P:1 #:00196 T:00000004d59c26cd M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00927 T:00000004d5d02e81 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00197 T:00000004d59cb686 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:00926 T:00000004d5cf5e41 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00198 T:00000004d59d4bb3 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<_OMX_BASE_HandleStateTransitionComplete> @line<535> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:00928 T:00000004d5d35459 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00199 T:00000004d59de0d9 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1398>
    N:VPSS P:2 #:00930 T:00000004d5d682f9 M:xdc.runtime.Main S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00200 T:00000004d59e653d M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1453> with error<0:ErrorNone>
    N:VPSS P:2 #:00929 T:00000004d5d57131 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00201 T:00000004d59eec87 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:00931 T:00000004d5d8d955 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00202 T:00000004d59f7c07 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:00932 T:00000004d5d9a47b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:Video P:1 #:00203 T:00000004d5a3c835 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:00933 T:00000004d5da223b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00204 T:00000004d5a47f9b M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00934 T:00000004d5daabdb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:Video P:1 #:00205 T:00000004d5a51525 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00935 T:00000004d5db245f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransition> @line<339> msg<Loaded to Idle Transition>
    N:Video P:1 #:00206 T:00000004d5a5ab8f M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00936 T:00000004d5dd1edd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00207 T:00000004d5a64113 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00937 T:00000004d5dda565 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:00938 T:00000004d5de42a1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS P:2 #:00939 T:00000004d5deca65 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS P:2 #:00940 T:00000004d5df7489 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00941 T:00000004d5dffbef M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00942 T:00000004d5e09321 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00943 T:00000004d5e10b9d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00944 T:00000004d5e18465 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00945 T:00000004d5e20bfd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:00946 T:00000004d5e28bb3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransitionComplete> @line<535> msg<Loaded to Idle Transition>
    N:VPSS P:2 #:00947 T:00000004d5e321e5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1398>
    N:VPSS P:2 #:00948 T:00000004d5e39eb9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1453> with error<0:ErrorNone>
    N:VPSS P:2 #:00949 T:00000004d5e42be3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:00950 T:00000004d5e4b3b1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:00951 T:00000004d5e80ef7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:00952 T:00000004d5e8f1e3 M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS P:2 #:00953 T:00000004d5e9a137 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:00954 T:00000004d5eb6681 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:00955 T:00000004d5ec00e3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00956 T:00000004d5ec9035 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00957 T:00000004d5ed1ebf M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00958 T:00000004d5eda2e9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00959 T:00000004d5ee5393 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00960 T:00000004d5eeee19 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00961 T:00000004d5ef6801 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00962 T:00000004d5eff1db M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:00963 T:00000004d5f06d9d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS P:2 #:00964 T:00000004d5f10631 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:00965 T:00000004d5f19363 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:00966 T:00000004d5f22f25 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS P:2 #:00967 T:00000004d5f2bea9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS P:2 #:00968 T:00000004d5f34a43 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:00969 T:00000004d5f3cf87 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00970 T:00000004d5f45cf1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:00971 T:00000004d5f4d249 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:00972 T:00000004d5f54d67 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00973 T:00000004d5f5db33 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:00974 T:00000004d5f65b4d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS P:2 #:00975 T:00000004d5f6ed2d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:00976 T:00000004d5f792c5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:00977 T:00000004d5fa7d67 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:00978 T:00000004d5fb5901 M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS P:2 #:00979 T:00000004d5fc0665 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:00980 T:00000004d5fdd183 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:00981 T:00000004d5fe67a1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:00982 T:00000004d5fef815 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:00983 T:00000004d5ff87ed M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00984 T:00000004d6000bd9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:00985 T:00000004d600be7d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00986 T:00000004d6015adb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00987 T:00000004d601cf19 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00988 T:00000004d60258fd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:00989 T:00000004d602cf51 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS P:2 #:00990 T:00000004d605d467 M:xdc.runtime.Main S:Mosaic configuration DONE!!
    N:Video P:1 #:00208 T:00000004d735d81b M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:00991 T:00000004d72b73c9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00209 T:00000004d736e479 M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS P:2 #:00992 T:00000004d72c15e7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:Video P:1 #:00210 T:00000004d737a4e9 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:00993 T:00000004d72cc2e9 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:Video P:1 #:00211 T:00000004d73916ab M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:00994 T:00000004d72d4e07 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:Video P:1 #:00212 T:00000004d739d249 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:00995 T:00000004d72dd6cb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:Video P:1 #:00213 T:00000004d73a5893 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:00996 T:00000004d72e5eb3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00214 T:00000004d73aeb4b M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:00997 T:00000004d72f1ab1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:Video P:1 #:00215 T:00000004d73b77af M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS P:2 #:00998 T:00000004d72f9387 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:Video P:1 #:00216 T:00000004d73c7663 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3657::VENC->Idle to Executing Transition Begin
    N:VPSS P:2 #:00999 T:00000004d7301071 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00217 T:00000004d73cfe43 M:xdc.runtime.Main S:_OMX_TI_VIDENC_EnablePeriodicDataProcess::Line 5374::VENC->Enabled Notification based data processing
    N:VPSS P:2 #:01000 T:00000004d7309e65 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:Video P:1 #:00218 T:00000004d73d7bf5 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3671::VENC->Idle to Executing Transition End
    N:VPSS P:2 #:01001 T:00000004d7311a77 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:Video P:1 #:00219 T:00000004d73ded35 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3936::VENC->Before OMX_EventCmdComplete Notify
    N:VPSS P:2 #:01002 T:00000004d731ab3b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:Video P:1 #:00220 T:00000004d73e6745 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:01003 T:00000004d732366d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:Video P:1 #:00221 T:00000004d73ee069 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:01004 T:00000004d7358665 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:Video P:1 #:00222 T:00000004d73f7d8f M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS P:2 #:01005 T:00000004d7373afb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:Video P:1 #:00223 T:00000004d7400455 M:xdc.runtime.Main S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3942::VENC->OMX_EventCmdComplete Notify Done
    N:VPSS P:2 #:01006 T:00000004d737e0db M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:Video P:1 #:00224 T:00000004d7409dd6 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS P:2 #:01007 T:00000004d738826d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:Video P:1 #:00225 T:00000004d7412a53 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:01008 T:00000004d7391e3f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:Video P:1 #:00226 T:00000004d741b735 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01009 T:00000004d73a62d7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00227 T:00000004d74263fb M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:01010 T:00000004d73b28eb M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00228 T:00000004d742df93 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:01011 T:00000004d74cb315 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SendCommand> @line<499>
    N:Video P:1 #:00229 T:00000004d74357f3 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01012 T:00000004d74dbfb9 M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:Video P:1 #:00230 T:00000004d743e7a1 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:01013 T:00000004d74e81c5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:Video P:1 #:00231 T:00000004d74462b9 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS P:2 #:01014 T:00000004d74ff419 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00232 T:00000004d744f4d3 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:01015 T:00000004d750a501 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:Video P:1 #:00233 T:00000004d7457e75 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:01016 T:00000004d75128dd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00234 T:00000004d74a6b57 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01017 T:00000004d751c16b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:Video P:1 #:00235 T:00000004d74c113b M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01018 T:00000004d75247d5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:Video P:1 #:00236 T:00000004d74cab29 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01019 T:00000004d75551cd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00237 T:00000004d74e2459 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01020 T:00000004d755ec43 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:Video P:1 #:00238 T:00000004d74eee5f M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:01021 T:00000004d75690bd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:Video P:1 #:00239 T:00000004d74f98b5 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:01022 T:00000004d7571c73 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:Video P:1 #:00240 T:00000004d7503b11 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:01023 T:00000004d757b361 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:Video P:1 #:00241 T:00000004d750d995 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01024 T:00000004d7583ca7 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00242 T:00000004d7516c75 M:xdc.runtime.Main S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01025 T:00000004d758d9b3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:01026 T:00000004d759581f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:01027 T:00000004d759f5c3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01028 T:00000004d75a89e5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:01029 T:00000004d75b1465 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS P:2 #:01030 T:00000004d75ba94b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:01031 T:00000004d75c3d67 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:01032 T:00000004d75f4691 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:01033 T:00000004d7603ceb M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS P:2 #:01034 T:00000004d760f829 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:01035 T:00000004d762b95b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01036 T:00000004d7644867 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01037 T:00000004d764d775 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01038 T:00000004d7663337 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01039 T:00000004d766b93f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01040 T:00000004d768064f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01041 T:00000004d768948b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:01042 T:00000004d76920e5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:01043 T:00000004d769b00b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:01044 T:00000004d76a454d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01045 T:00000004d76ac9fd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01046 T:00000004d76b83e3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01047 T:00000004d76c36ed M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:01048 T:00000004d76cb089 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01049 T:00000004d76d3ddd M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:01050 T:00000004d76db895 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS P:2 #:01051 T:00000004d76e5929 M:xdc.runtime.Main S:Starting Capture Driver
    N:VPSS P:2 #:01052 T:00000004d76eb9f3 M:xdc.runtime.Main S:VFCC Capture_drvOverflowDetectAndReset::Line 3648::VIP Reset Happend, reset count:: 1 portId : 0
    N:VPSS P:2 #:01053 T:00000004d76f3d68 M:xdc.runtime.Main S:VFCC VIP Id:0
    N:VPSS P:2 #:01054 T:00000004d7bc4847 M:xdc.runtime.Main S:RESET Count:: 1 , curTime:: 48761
    N:VPSS P:2 #:01055 T:00000004d7bcc365 M:xdc.runtime.Main S:Capture Driver Started!!
    N:VPSS P:2 #:01056 T:00000004d7bd4d61 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01057 T:00000004d7bdad03 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01058 T:00000004d7be0be1 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01059 T:00000004d7be6945 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01060 T:00000004d7bec823 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01061 T:00000004d7bf2587 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01062 T:00000004d7bf8465 M:xdc.runtime.Main S:Priming the buffers to the Capture Driver
    N:VPSS P:2 #:01063 T:00000004d7bfdaff M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS P:2 #:01064 T:00000004d7c056db M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS P:2 #:01065 T:00000004d7c0f38d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS P:2 #:01066 T:00000004d7c1ee29 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS P:2 #:01067 T:00000004d7c28017 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS P:2 #:01068 T:00000004d7c304c3 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01069 T:00000004d7c3958f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS P:2 #:01070 T:00000004d7c40d3f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS P:2 #:01071 T:00000004d7c4862d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01072 T:00000004d7c5109d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS P:2 #:01073 T:00000004d7c58e3f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS P:2 #:01074 T:00000004d7c61aa1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS P:2 #:01075 T:00000004d7c6a799 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS P:2 #:01076 T:00000004d7caa975 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS P:2 #:01077 T:00000004d7cb93fd M:xdc.runtime.Main S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS P:2 #:01078 T:00000004d7cc46f0 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS P:2 #:01079 T:00000004d7cf7b6b M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS P:2 #:01080 T:00000004d7d118e5 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS P:2 #:01081 T:00000004d7d1a2ff M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS P:2 #:01082 T:00000004d7d226c1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS P:2 #:01083 T:00000004d7d2ae95 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS P:2 #:01084 T:00000004d7d3d659 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01085 T:00000004d7d4625d M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS P:2 #:01086 T:00000004d7d528ef M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS P:2 #:01087 T:00000004d7d5cfed M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS P:2 #:01088 T:00000004d7d64b93 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS P:2 #:01089 T:00000004d7d6d32f M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS P:2 #:01090 T:00000004d7d74fe1 M:xdc.runtime.Main S:Module<OMX.TI.VPSSM3.CTRL.TVP> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS P:2 #:01091 T:00000004d7d7e567 M:xdc.runtime.Main S:Entered: _OMX_CTRLTvpDrvStart @ line 631
    N:VPSS P:2 #:01092 T:00000004d7d8480d M:xdc.runtime.Main S:Starting Video Decoder Capture Driver
    N:VPSS P:2 #:01093 T:00000004d7d90e9f M:xdc.runtime.Main S: CAPTUREAPP: Detect video in progress for inst 0 !!!
    N:VPSS P:2 #:01094 T:00000004d8236fe5 M:xdc.runtime.Main S:VIP-0 PORT-A Dropped Frame Count :1 Total Capture Frame Count 0
    N:VPSS P:2 #:01095 T:00000004db43f4bd M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01096 T:00000004deb286d9 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01097 T:00000004e2216001 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01098 T:00000004e591038d M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01099 T:00000004e8ff0446 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1126@29Hz, 0)!!!
    N:VPSS P:2 #:01100 T:00000004ec6e0711 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01101 T:00000004efdcbed5 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01102 T:00000004f34bbce1 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01103 T:00000004f6bac799 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01104 T:00000004fa29e31f M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1126@29Hz, 0)!!!
    N:VPSS P:2 #:01105 T:00000004fd98a11b M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01106 T:0000000501074c83 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01107 T:00000005047668f3 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1071@31Hz, 0)!!!
    N:VPSS P:2 #:01108 T:0000000507e53ddf M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01109 T:000000050b5405c1 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1126@29Hz, 0)!!!
    N:VPSS P:2 #:01110 T:000000050ec2fd41 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01111 T:000000051231d9f1 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01112 T:0000000515a0a653 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x3375@10Hz, 0)!!!
    N:VPSS P:2 #:01113 T:00000005191010cf M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01114 T:000000051c7fbaa5 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1126@29Hz, 0)!!!
    N:VPSS P:2 #:01115 T:000000051feedb4b M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01116 T:00000005235c5d8b M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01117 T:0000000526cd1701 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x3429@9Hz, 0)!!!
    N:VPSS P:2 #:01118 T:000000052a3a4d0b M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01119 T:000000052da90edd M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    N:VPSS P:2 #:01120 T:0000000531181f39 M:xdc.runtime.Main S: CAPTUREAPP: Detected video at CH0 (4400x1125@30Hz, 0)!!!
    It seems that the video source has resolution 4400x1250@30fps. Could you check your video source. Also your video source should be connected to the component input J8,J9,J10 on the EVM.
    Could you try to use the default scrip in EZSDK for loading the firmwares.
    BR
    Margarita
