Recommended to update xcdtools?
Other Parts Discussed in Thread: CC2650
Hy,
I am in the middle of a development of a CC2650 based prototype.When starting my CCS today, I got a message about upgrading xdctools.
Do you generally recommend to use every available update? Is there a way to step back to the previous version when I notice negative side-effects? Is there a version history where I can see the changes to the current version?
And, now that cancelled the installation, how can I trigger the update again? When I use "Help -> Check for updates" CCS won't find any updates
Thanks and best regards
Harald
  • Hi Harald,
    What version of CCS are you using?
    Each version of XDCtools has release notes in the top directory. There's a "What's New" that lists new features and bug fixes.
    You can roll back to different versions of XDCtools. You can select different versions via Project Properities->General->RTSC->XDCtools version drop-down.
    If you go to Window->Preferences->Code Composer Studio->RTSC->Products in CCS, you can rescan:
    Todd
  • Hy Todd,
    thanks for the quick and perfect response!
    I Use CCS 6.1.0.00104
    Apparently the current versions of xcdtools were installed on my PC already, when this message showed up. Although I have not installed the updates when I was asked for they seem to be on my PC:
    I usually have two instances of CCS open, might that be an issue?
    Harald
    That should be fine given that both are not trying to use the same emulator.
