Currently using MCSDK-HPC-3_00_01_04.
I have sourced setup_hpc_env.sh
I have set up TI SDK linux root file system in the EVM directory.
On executing ./install_hpc_packages_x86.sh /evmk2h_nfs/
the following errors show up.
Following is the error:
Installing ./debugss-mod_1.0.1_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './debugss-mod_1.0.1_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./dsptop_1.1.3_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './dsptop_1.1.3_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./gdbc6x_1.0.0_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './gdbc6x_1.0.0_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./gdbproxy-mod_1.0.1_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './gdbproxy-mod_1.0.1_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./gdbserver-c6x_1.0.0_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './gdbserver-c6x_1.0.0_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./kernel-module-cmemk_4.0.3.13_eng-r7b+gitrAUTOINC+952d22b15e01c724453e9679def64c2fc0279154_keystone_evm.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './kernel-module-cmemk_4.0.3.13_eng-r7b+gitrAUTOINC+952d22b15e01c724453e9679def64c2fc0279154_keystone_evm.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./keystone-hpc_3.0.1.4_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './keystone-hpc_3.0.1.4_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./libmpmtransport1_1.0.5-r0_cortexa15hf-vfp-neon-3.8.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './libmpmtransport1_1.0.5-r0_cortexa15hf-vfp-neon-3.8.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./libmpmtransport-dev_1.0.5-r0_cortexa15hf-vfp-neon-3.8.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './libmpmtransport-dev_1.0.5-r0_cortexa15hf-vfp-neon-3.8.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./libmpmtransport-staticdev_1.0.5-r0_cortexa15hf-vfp-neon-3.8.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './libmpmtransport-staticdev_1.0.5-r0_cortexa15hf-vfp-neon-3.8.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./libticmem1_4.0.3.13_eng-b+gitrAUTOINC+952d22b15e01c724453e9679def64c2fc0279154_cortexa15hf-vfp-neon-3.8.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './libticmem1_4.0.3.13_eng-b+gitrAUTOINC+952d22b15e01c724453e9679def64c2fc0279154_cortexa15hf-vfp-neon-3.8.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./libticmem-dev_4.0.3.13_eng-b+gitrAUTOINC+952d22b15e01c724453e9679def64c2fc0279154_cortexa15hf-vfp-neon-3.8.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './libticmem-dev_4.0.3.13_eng-b+gitrAUTOINC+952d22b15e01c724453e9679def64c2fc0279154_cortexa15hf-vfp-neon-3.8.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./libticmem-staticdev_4.0.3.13_eng-b+gitrAUTOINC+952d22b15e01c724453e9679def64c2fc0279154_cortexa15hf-vfp-neon-3.8.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './libticmem-staticdev_4.0.3.13_eng-b+gitrAUTOINC+952d22b15e01c724453e9679def64c2fc0279154_cortexa15hf-vfp-neon-3.8.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./temperature-mod_1.0.0_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './temperature-mod_1.0.0_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./ti-multiprocmgr_2.0.1-r1_cortexa15hf-vfp-neon-3.8.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './ti-multiprocmgr_2.0.1-r1_cortexa15hf-vfp-neon-3.8.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./ti-multiprocmgr-dev_2.0.1-r1_cortexa15hf-vfp-neon-3.8.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './ti-multiprocmgr-dev_2.0.1-r1_cortexa15hf-vfp-neon-3.8.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./ti-multiprocmgr-staticdev_2.0.1-r1_cortexa15hf-vfp-neon-3.8.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './ti-multiprocmgr-staticdev_2.0.1-r1_cortexa15hf-vfp-neon-3.8.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./ti-opencl_0.14.0_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './ti-opencl_0.14.0_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./ti-openmpacc_1.1.1_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './ti-openmpacc_1.1.1_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./ti-openmpi_1.0.0.14_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './ti-openmpi_1.0.0.14_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing ./ti-ulm_1.0.3_cortexa15hf-vfp-neon.ipk on to /evmk2h_nfs/
dpkg-deb: error: archive './ti-ulm_1.0.3_cortexa15hf-vfp-neon.ipk' has premature member 'data.tar.gz' before 'control.tar.gz', giving up
Installing CGTOOLS ti_cgt_c6000_8.0.0_armlinuxa8hf_busybox_installer.sh on to /evmk2h_nfs/
Installing C6000 Code Generation tools version 8.0.0 into //evmk2h_nfs
please wait, or press CTRL-C to abort
Extracting archive
Installing files
[####################] 100%
Installed successfully into //evmk2h_nfs
HPC Packages Installation on /evmk2h_nfs/ Complete
Please let me know what I can do so that I will be able to install the HPC IPKs.
Thanks.
