got event*** unrecoverable error: XXX
Other Parts Discussed in Thread: TVP7002
I am trying to run the capture_encode application after n frames of capture I get following errors, any pointers on
what could be the issue.
tearing down the capture-encode example
 exiting thread
 exiting thread
 exiting thread
 exiting thread
 got eventState changed to: OMX_StateIdle
 DEI state idle
 display state idle
 display control state idle
 Encoder state idle
 got eventState changed to: OMX_StateLoaded
 display state loaded
 ctrl-dc state loaded
 encoder state loaded
 dei state loaded
 got event*** unrecoverable error: <unknown> (0x8000101c)
Press a key to proceed
got event*** unrecoverable error: <unknown> (0x80001017)
Thanks And Regards,
Mike
 exiting thread
 exiting thread
 exiting thread
 exiting thread
 DEI state idle
 display state idle
 Encoder state idle
 dei state loaded
    Could you attach the full trace log?
    What changes you have done in the demo also?
    BR
    Margarita
  • Hi Margarita,
    Since I am using the fpga for capturing I have following mods to the application, also I see that it records .264 but when I try and play the file with mplayer it is just raw pixels no proper video any pointers on that ?
    Thanks And Regards,
    Mike
    Index: ezsdk-5_05_02_00/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode/src/ilclient.c
    --- ezsdk-5_05_02_00.orig/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode/src/ilclient.c 2012-12-20 09:11:19.000000000 -0600
    +++ ezsdk-5_05_02_00/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode/src/ilclient.c 2013-06-14 14:32:54.983722649 -0600
    @@ -723,6 +723,7 @@
    pAppData->capILComp->handle = pAppData->pCapHandle;
    +#if USE_TVP
    /* This is control component, without ports. It is implemented as OMX
    component */
    eError =
    @@ -738,6 +739,7 @@
    IL_ClientErrorToStr (eError));
    goto EXIT;
    +#endif
    /* Configute the capture componet */
    /* calling OMX_Setparam in this function */
    @@ -908,13 +910,13 @@
    OMX_VFPC_OUTPUT_PORT_START_INDEX,
    pAppData->disILComp,
    OMX_VFDC_INPUT_PORT_START_INDEX);
    + printf("HERE 1\n");
    /* OMX_SendCommand expecting OMX_StateIdle, after this command component will
    wait for all buffers to be allocated as per omx buffers are created during
    loaded to Idle transition IF ports are enabled ) */
    +#if USE_TVP
    eError =
    OMX_SendCommand (pAppData->pTvpHandle, OMX_CommandStateSet,
    OMX_StateIdle, NULL);
    @@ -926,10 +928,12 @@
    semp_pend (pAppData->capILComp->done_sem);
    +#endif
    + printf("HERE 2\n");
    eError =
    OMX_SendCommand (pAppData->pCapHandle, OMX_CommandStateSet,
    + printf("HERE 3\n");
    if (eError != OMX_ErrorNone)
    printf ("Error in SendCommand()-OMX_StateIdle State set : %s \n",
    @@ -1221,7 +1225,7 @@
    printf (" capture state execute \n ");
    +#if USE_TVP
    eError =
    OMX_StateExecuting, NULL);
    @@ -1232,10 +1236,11 @@
    goto EXIT;
    printf (" capture control ( TVP ) state execute \n ");
    +#endif
    /* Create thread for writing bitstream and passing the buffers to encoder
    @@ -1347,6 +1352,7 @@
    printf (" capture state idle \n ");
    +#if USE_TVP
    /* change state to idle so that buffers processing would stop */
    eError =
    OMX_SendCommand(pAppData->pTvpHandle, OMX_CommandStateSet,
    @@ -1357,10 +1363,10 @@
    IL_ClientErrorToStr(eError));
    goto EXIT;
    semp_pend(pAppData->capILComp->done_sem);
    printf(" control tvp state idle \n ");
    +#endif
    /* change state to idle so that buffers processing can stop */
    eError =
    @@ -1584,6 +1590,7 @@
    printf (" capture state loaded \n ");
    +#if USE_TVP
    /* ctrl tvp component does not alloc/free any data buffers, It's interface
    is though as it is omx componenet */
    eError =
    @@ -1595,10 +1602,11 @@
    goto EXIT;
    printf(" ctrl-tvp state loaded \n ");
    +#endif
    @@ -1613,6 +1621,7 @@
    printf (" capture free handle \n");
    +#if USE_TVP
    eError = OMX_FreeHandle(pAppData->pTvpHandle);
    if ((eError != OMX_ErrorNone))
    @@ -1622,6 +1631,7 @@
    printf(" ctrl-tvp free handle \n");
    +#endif
    eError = OMX_FreeHandle (pAppData->pEncHandle);
    Index: ezsdk-5_05_02_00/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode/src/ilclient.h
    --- ezsdk-5_05_02_00.orig/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode/src/ilclient.h 2012-12-20 09:11:19.000000000 -0600
    +++ ezsdk-5_05_02_00/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode/src/ilclient.h 2013-06-14 13:49:37.983712681 -0600
    @@ -53,7 +53,7 @@
    extern "C"
    { /* be compiled by a C++ compiler */
    #endif
    +#define USE_TVP 0
    #define IL_CLIENT_MAX_NUM_IN_BUFS 16
    #define IL_CLIENT_MAX_NUM_OUT_BUFS 16
    @@ -188,8 +188,13 @@
    typedef struct IL_Client
    +#if USE_TVP
    OMX_HANDLETYPE pCapHandle, pDeiHandle, pDisHandle, pctrlHandle, pTvpHandle,
    pEncHandle;
    +#else
    + OMX_HANDLETYPE pCapHandle, pDeiHandle, pDisHandle, pctrlHandle,
    + pEncHandle;
    +#endif
    OMX_COMPONENTTYPE *pComponent;
    OMX_CALLBACKTYPE pCb;
    OMX_STATETYPE eState;
    Index: ezsdk-5_05_02_00/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode/src/ilclient_utils.c
    --- ezsdk-5_05_02_00.orig/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode/src/ilclient_utils.c 2012-12-20 09:11:19.000000000 -0600
    +++ ezsdk-5_05_02_00/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode/src/ilclient_utils.c 2013-06-14 13:39:16.643710296 -0600
    @@ -63,6 +63,7 @@
    #include <OMX_TI_Index.h>
    /*---------------------- function prototypes ---------------------------------*/
    /* None */
    +#define USE_TVP 0
    void usage (IL_ARGS *argsp)
    @@ -1017,15 +1018,15 @@
    (OMX_INDEXTYPE) OMX_TI_IndexConfigVFCCFrameSkip,
    (OMX_PTR) & sCapSkipFrames);
    +#if USE_TVP
    /* Set parameters for TVP controller */
    OMX_INIT_PARAM (&sHwPortId);
    /* capture on EIO card is component input at VIP1 port */
    sHwPortId.eHwPortId = OMX_VIDEO_CaptureHWPortVIP1_PORTA;
    eError = OMX_SetParameter (pAppData->pTvpHandle,
    (OMX_INDEXTYPE) OMX_TI_IndexParamVFCCHwPortID,
    (OMX_PTR) & sHwPortId);
    OMX_INIT_PARAM (&sHwPortParam);
    sHwPortParam.eCaptMode = OMX_VIDEO_CaptureModeSC_NON_MUX;
    sHwPortParam.eVifMode = OMX_VIDEO_CaptureVifMode_16BIT;
    @@ -1047,7 +1048,7 @@
    (OMX_INDEXTYPE)
    OMX_TI_IndexParamVFCCHwPortProperties,
    (OMX_PTR) & sHwPortParam);
    OMX_INIT_PARAM (&sVidDecParam);
    /* set the mode based on capture/display device */
    @@ -1076,6 +1077,7 @@
    (OMX_PTR) & sVidDecParam);
    ERROR ("failed to set Ctrl Vid dec info \n");
    +#endif
    return (eError);
    You are seeing this error got event*** unrecoverable error: <unknown> (0x8000101c) when you are tearing down the capture encode demo, correct?
    You also not using control component in the capture_encode demo, correct?
    Could you attach then encoded video h264 video and the full debug log?
    BR
    Margarita
  • Hi Margarita,
    Please find the attached logs.
    Thanks And Regards,
    Mike
    5775.log.txt
    output file: sample.h264
    bit_rate: 1000000
    frame_rate: 30
    num_frames: 10
    mode: 1080p
    display_id: 0
     Capture-Encode example
     OMX_Init completed
     UIAClient is ready to send a UIA configuration command
    UIAClient received UIA_CONFIGURE_ACK
    UIAClient is done sending requests
     openeing file
     capture compoenent is created
    Buffer Size computed: 3110400
    set input port params (width = 1920, height = 1080) applying skip mask
    enable capture output port
    got eventEnable/Disable Event
     dei compoenent is created
    set output port params (width = 1920, height = 1080)set output port params (width = 1920, height = 1080)set number of channelsset input resolutionset out
    enable dei output port 0
    enable dei output port 1
     encoder compoenent is created
    found handle 0xfbcc8 for component OMX.TI.VPSSM3.VFDC
     got display handle
    found handle 0xffcd0 for component OMX.TI.VPSSM3.CTRL.DC
    Buffer Size computed: 4147200
    set input port params (width = 1920, height = 1080)setting input and output memory type to defaultenable input port
     connect call for capture-Dei
      connect call for dei- encoder
      connect call for dei-display
      Capture outport buffers allocated
     Capture is in IDLE state
     Dei input port use buffer done
      DEI outport buffers allocated
     DEI is in IDLE state
     encoder input port use buffer done
      encoder outport buffers allocated
     Encoder state IDLE
     ctrl-dc state IDLE
      display buffers allocated
     waiting for IDLEgot eventState changed to: OMX_StateIdle
     display state IDLE
     got eventState changed to: OMX_StateExecuting
     display control state execute
     display state execute
     encoder state execute
     dei state execute
      file write thread created
      encode connect thread created
      dei connect thread created
      capture connect thread created
      display connect thread created
      executing the application now!!
     Frame counter: 1
     Frame counter: 2
     Frame counter: 3
     Frame counter: 4
     Frame counter: 5
     Frame counter: 6
     Frame counter: 7
     Frame counter: 8
     Frame counter: 9
     Frame counter: 10
     exiting thread
     exiting thread
     exiting thread
     exiting thread
     DEI state idle
     display state idle
     Encoder state idle
     dei state loaded
    ^C^Z
    sample.txt
  • Hi Margarita,
    1: Yes the application at the end by default does the tear down I suspect.
    2: Yes I am not using the control component.
    3: sample.txt needs to be renamed .264
    Thanks And Regards,
    Mike
    In the log it seems that the VFCC reports ErrorIncorrectStateTransition error when you are trying to tear down. I would recommend you to look into changes you have did. You could check the format that you are using as well.
    BR
    Margarita
  • Hi Margarita,
    In my case the fpga is giving same format as tvp7002 decoder to vip (embedded syncs with yuv 420).
    Thanks And Regards,
    Mike
    Not yuv420, I meant OMX_COLOR_FormatYCbYCr (YUV422 16 bit) with Embedded syncs, since the vip driver is getting the embedded syncs correct I suspect its getting proper frames (since app proceeds to capture data ?
    Thanks And Regards,
    Mike
    Could you check the stream before to fed the encoder component.
    BR
    Margarita
  • Hi Margarita,
    Yes I can see the camera feed onto the TV screen before feeding to the vip.
    Thanks And Regards,
    Mike
