H264 decode problem
Does the h264 decoder need an IDR to start decoding or it can start decoding from any random point?
I need the h264 codec can decode from any random point,but when my palyer work on this way,the h264 codec vdec _process always return -1.
And I have use the decode demo made a test,that if the h264 video start from IDR frame,the decode demo work very well,but if I delete the first IDR frame,and then use the decode demo to have a test,it exit abnormally.Bellow is the demo's trace:
./decode -v video1.264 (delete the first IDR frame)
Decode demo started.
Error: Failed to decode video buffer
./decode -v video2.264 (etrire video)
Decode demo ARM Load: 57% DSP Load: 14% Display Type: D1 NTSC Video Codec: H.264 BP Video fps: 21 fps Video bit rate: 275 kbps Video resolution: 720x576 Sound codec: N/A Sound bit rate: 0 kbps Sampling freq: 0 Time: 00:00:01
Decode demo ARM Load: 3% DSP Load: 12% Display Type: D1 NTSC Video Codec: H.264 BP Video fps: 30 fps Video bit rate: 8 kbps Video resolution: 720x576 Sound codec: N/A Sound bit rate: 0 kbps Sampling freq: 0 Time: 00:00:02
My  environment:
DVSDK-version:dvsdk_2_00_00_22
h264 dec-version:1.00.018
platform:dm6467
 David
  • Hi David,
    I understand you are using H.264 decoder version 1.00.018 on DM6467.
    Can you provide more detailed log running with CE_DEBUG=2 or 3?
    With regards to IDR frame, the FAQ column below specifies that v1.10 of the decoder does support decoding of non-IDR frame. At first glance,  based on the release notes of v1.00 and v1.10, it looks like v1.00 should also support the non-IDR frame support.
    http://processors.wiki.ti.com/index.php/DaVinciHD_Codecs_FAQ#H264_Decoder_FAQs_.28Reference_Codec_Version_--_REL_200_V_H264AVC_D_HP_DM6467_1_10_012.29
    Btw, there are later codec versions v1.10 and v1.20 of H.264 decoder available on DM6467 downloadable from links below -
    http://software-dl.ti.com/dsps/dsps_public_sw/codecs/DM6467/index_FDS.html
    Prateek
  • Hi Parteek,
    Thanks for your reply,below is CE_DEBUG:
    CE_DEBUG=3 ./decode -v video1.264
    @0,650,047us: [+4 T:0x4001f950 S:0xbeb38a94] OG - Global_init> This program was built with the following packages:
    @0,650,656us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package gnu.targets.rts470MV (/home/colin/dvsdk_2_00_00_22_6467/xdctools_3_10_03/packages/gnu/targets/rts470MV/) [1,0,0,0,1225517438755]
    @0,650,888us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.mpeg2dec (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mpeg2dec/) [1,0,0,1263292262000]
    @0,651,048us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.h264dec (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/h264dec/) [1,0,0,0]
    @0,651,198us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.aachedec (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/aachedec/) [1,0,0,1263292261000]
    @0,651,343us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.dolbyac3dec (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/dolbyac3dec/) [1,0,0,0]
    @0,651,483us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.mpeg4dec (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mpeg4dec/) [1,0,0,1263292264000]
    @0,651,627us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.mp3dec (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mp3dec/) [1,0,0,0]
    @0,651,767us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.global (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    @0,651,911us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.xdais.dm (/home/colin/dvsdk_2_00_00_22_6467/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    @0,652,049us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.utils.trace (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    @0,652,196us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.utils.xdm (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    @0,652,341us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package dsplink.gpp (/home/colin/dvsdk_2_00_00_22_6467/dsplink-1_61_03-prebuilt/packages/dsplink/gpp/) [5,0,0,1239931267000]
    @0,652,480us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.linuxutils.cmem (/home/colin/dvsdk_2_00_00_22_6467/linuxutils_2_23_01/packages/ti/sdo/linuxutils/cmem/) [2,2,0,1240253001679]
    @0,652,625us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.xdais (/home/colin/dvsdk_2_00_00_22_6467/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    @0,652,763us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.node (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    @0,652,904us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.fc.global (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    @0,653,050us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.fc.dman3 (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    @0,653,197us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.fc.memutils (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    @0,653,343us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.fc.acpy3 (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    @0,653,523us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package gnu.targets (/home/colin/dvsdk_2_00_00_22_6467/xdctools_3_10_03/packages/gnu/targets/) [1,0,1,1225517427930]
    @0,653,664us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.catalog.c470 (/home/colin/dvsdk_2_00_00_22_6467/xdctools_3_10_03/packages/ti/catalog/c470/) [1,0,1,0,0]
    @0,653,809us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.catalog.c6000 (/home/colin/dvsdk_2_00_00_22_6467/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    @0,654,008us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.platforms.evmDM6467 (/home/colin/dvsdk_2_00_00_22_6467/xdctools_3_10_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    @0,989,117us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.osal (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    @0,989,296us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.osal.linux (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/osal/linux/) [2,0,1,1240276736840]
    @0,989,555us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.ipc (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    @0,989,714us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.ipc.dsplink (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/) [2,0,1,1240276714152]
    @0,989,864us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.alg (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    @0,990,010us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    @0,990,155us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.video2 (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    @0,990,296us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.mpeg2dec.ce (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mpeg2dec/ce/) [1,0,0,1263292262000]
    @0,990,442us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.h264dec.ce (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/h264dec/ce/) [1,0,0,0]
    @0,990,584us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.audio1 (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    @0,990,726us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.aachedec.ce (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/aachedec/ce/) [1,0,0,1263292261000]
    @0,990,868us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.dolbyac3dec.ce (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/dolbyac3dec/ce/) [1,0,0,0]
    @0,991,008us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.mpeg4dec.ce (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mpeg4dec/ce/) [1,0,0,1263292263000]
    @0,991,153us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.codecs.mp3dec.ce (/mnt/win/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mp3dec/ce/) [1,0,0,0]
    @0,991,293us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.speech (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/speech/) [1,0,2,1240276762193]
    @0,991,437us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.speech1 (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/speech1/) [1,0,1,1240276763928]
    @0,991,578us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.audio (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/audio/) [1,0,2,1240276296374]
    @0,991,721us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.video (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/video/) [1,0,3,1240276930771]
    @0,991,894us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.video1 (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/video1/) [1,0,2,1240276935900]
    @0,992,044us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.image (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/image/) [1,0,3,1240276700525]
    @0,992,190us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.image1 (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/image1/) [1,0,1,1240276698808]
    @1,327,568us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.dmai (/home/colin/dvsdk_2_00_00_22_6467/dmai_1_20_00_06/packages/ti/sdo/dmai/) [1,0,0,1271906371000]
    @1,327,745us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.simplewidget (/home/colin/dvsdk_2_00_00_22_6467/dvsdk_demos_2_00_00_07/packages/ti/sdo/simplewidget/) []
    @1,327,901us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.bioslog (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    @1,328,048us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package ti.sdo.ce.utils.trace (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/utils/trace/) [1,0,1,1240276915917]
    @1,328,198us: [+4 T:0x4001f950 S:0xbeb38a94] OG -     package decode_config (/home/colin/dvsdk_2_00_00_22_6467/dvsdk_demos_2_00_00_07/dm6467/decode/decode_config/) []
    @1,328,410us: [+0 T:0x4001f950 S:0xbeb38a9c] OG - Global_atexit> enter (fxn=0x32168)
    @1,328,583us: [+0 T:0x4001f950 S:0xbeb38a9c] OG - Global_atexit> enter (fxn=0x315b4)
    @1,328,841us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_alloc> Enter(0x18)
    @1,329,002us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_alloc> return (0x620f0)
    @1,329,508us: [+0 T:0x4001f950 S:0xbeb38a8c] OG - Global_atexit> enter (fxn=0x2f4e4)
    @1,329,763us: [+0 T:0x4001f950 S:0xbeb38a64] OM - Memory_alloc> Enter(0x18)
    @1,329,931us: [+0 T:0x4001f950 S:0xbeb38a64] OM - Memory_alloc> return (0x62140)
    @1,330,075us: [+0 T:0x4001f950 S:0xbeb38a84] OG - Global_atexit> enter (fxn=0x2e390)
    @1,330,336us: [+0 T:0x4001f950 S:0xbeb38a8c] OG - Global_atexit> enter (fxn=0x30c18)
    @1,330,595us: [+0 T:0x4001f950 S:0xbeb38a84] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @1,330,749us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_alloc> Enter(0x14)
    @1,330,893us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_alloc> return (0x621c0)
    @1,331,060us: [+0 T:0x4001f950 S:0xbeb38a84] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x621c0]
    @1,331,213us: [+0 T:0x4001f950 S:0xbeb38a84] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @1,331,344us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_alloc> Enter(0x14)
    @1,331,483us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_alloc> return (0x621d8)
    @1,331,617us: [+0 T:0x4001f950 S:0xbeb38a84] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x621d8]
    @1,331,750us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_alloc> Enter(0x18)
    @1,331,889us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_alloc> return (0x621f0)
    @1,332,023us: [+0 T:0x4001f950 S:0xbeb38a64] OT - Thread_create> Enter (fxn=0x2cb68, attrs=0x0)
    @1,332,163us: [+0 T:0x4001f950 S:0xbeb38a4c] OM - Memory_alloc> Enter(0x64)
    @1,332,303us: [+0 T:0x4001f950 S:0xbeb38a4c] OM - Memory_alloc> return (0x62210)
    @1,333,088us: [+0 T:0x4001f950 S:0xbeb38a64] OT - Thread_create> Exit (task=0x62210)
    @1,333,279us: [+0 T:0x4001f950 S:0xbeb38a9c] OG - Global_atexit> enter (fxn=0x2c558)
    @1,333,452us: [+0 T:0x4001f950 S:0xbeb38a9c] OG - Global_atexit> enter (fxn=0x2e8dc)
    @1,333,678us: [+0 T:0x4001f950 S:0xbeb38a84] ti.sdo.ce.alg - ALG_init> Enter
    @1,333,826us: [+0 T:0x4001f950 S:0xbeb38a74] OG - Global_atexit> enter (fxn=0x2c1a4)
    @1,333,973us: [+0 T:0x4001f950 S:0xbeb38aa4] ti.sdo.ce.alg - ALG_init> Exit
    @1,334,103us: [+0 T:0x4001f950 S:0xbeb38a9c] OG - Global_atexit> enter (fxn=0x2b5d0)
    @1,334,305us: [+0 T:0x4001f950 S:0xbeb38a74] OM - Memory_alloc> Enter(0x18)
    @1,334,466us: [+0 T:0x4001f950 S:0xbeb38a74] OM - Memory_alloc> return (0x623f0)
    @1,334,609us: [+0 T:0x4001f950 S:0xbeb38a9c] OG - Global_atexit> enter (fxn=0x31108)
    @1,334,840us: [+6 T:0x4001f950 S:0xbeb38a94] CE - Engine_init> CE debugging on (CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
    @1,335,012us: [+0 T:0x4001f950 S:0xbeb38a84] OG - Global_atexit> enter (fxn=0x28a64)
    @1,668,866us: [+0 T:0x4001f950 S:0xbeb38a64] OM - Memory_alloc> Enter(0x18)
    @1,669,050us: [+0 T:0x4001f950 S:0xbeb38a64] OM - Memory_alloc> return (0x62430)
    @1,669,202us: [+0 T:0x4001f950 S:0xbeb38a64] OM - Memory_alloc> Enter(0x18)
    @1,669,351us: [+0 T:0x4001f950 S:0xbeb38a64] OM - Memory_alloc> return (0x62450)
    @1,669,675us: [+0 T:0x4001f950 S:0xbeb38a64] OM - Memory_alloc> Enter(0x18)
    @1,669,838us: [+0 T:0x4001f950 S:0xbeb38a64] OM - Memory_alloc> return (0x62470)
    @1,670,080us: [+0 T:0x4001f950 S:0xbeb38a9c] CS - Server_init()
    @1,670,234us: [+0 T:0x4001f950 S:0xbeb38a9c] CS - Server_init> Global_useLinkArbiter = 0
    @1,670,378us: [+0 T:0x4001f950 S:0xbeb38a9c] OG - Global_atexit> enter (fxn=0x26d44)
    @1,670,625us: [+0 T:0x4001f950 S:0xbeb38aac] OG - Global_atexit> enter (fxn=0x13994)
    TraceUtil_start> note: CE_DEBUG env. var is set, so TraceUtil is not active (unset CE_DEBUG if you need TraceUtil)
    @1,673,984us: [+0 T:0x41bc8490 S:0x41bc7ca4] CE - Engine_open> Enter('decode', 0x0, 0x41bc7d14)
    @1,674,179us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_alloc> Enter(0x2c)
    @1,674,366us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_alloc> return (0x62ab0)
    @1,674,517us: [+0 T:0x41bc8490 S:0x41bc7ca4] CE - rserverOpen('decodeCombo.x64P'), count = 0
    @1,674,655us: [+0 T:0x41bc8490 S:0x41bc7c6c] OP - Processor_create> Enter(imageName='decodeCombo.x64P', linkCfg='(null)', attrs=0x41bc7cf8)
    @1,675,322us: [+1 T:0x40bc8490 S:0x40bc7d74] OP - daemon> thread created.
    @1,675,871us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_alloc> Enter(0x24)
    @1,676,058us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_alloc> return (0x62ae0)
    @1,676,208us: [+0 T:0x41bc8490 S:0x41bc7c4c] OP - doCmd> Enter (cmdId=1, proc=0x62ae0)
    @1,676,349us: [+0 T:0x41bc8490 S:0x41bc7c3c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x621c0]
    @1,676,571us: [+0 T:0x41bc8490 S:0x41bc7c4c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x621c0]
    @1,676,729us: [+0 T:0x41bc8490 S:0x41bc7c2c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x621d8] timeout[0xffffffff]
    @1,676,940us: [+0 T:0x40bc8490 S:0x40bc7d74] OP - getCmd_d> Enter (proc=0x40bc7de8)
    @1,677,105us: [+0 T:0x40bc8490 S:0x40bc7d54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x621c0] timeout[0xffffffff]
    @1,677,292us: [+0 T:0x40bc8490 S:0x40bc7d54] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x621c0] status[0]
    @1,677,438us: [+0 T:0x40bc8490 S:0x40bc7d74] OP - getCmd_d> Exit (result=1)
    @1,677,570us: [+0 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Enter(proc=0x62ae0)
    @1,677,703us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Initializing DSP PROC...
    @1,677,843us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'decodeCombo.x64P']
    @1,677,995us: [+0 T:0x40bc8490 S:0x40bc7d5c] OM - Memory_alloc> Enter(0xe0)
    @1,678,146us: [+0 T:0x40bc8490 S:0x40bc7d5c] OM - Memory_alloc> return (0x62b08)
    @1,678,290us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x87800000, sizeInBytes=0x700000, shared=1, syncd=0
    @1,678,466us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x87f00080, sizeInBytes=0xfff80, shared=1, syncd=0
    @1,678,638us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x87f00000, sizeInBytes=0x80, shared=1, syncd=0
    @1,678,807us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x86800000, sizeInBytes=0x1000000, shared=0, syncd=0
    @1,678,977us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> DODSPCTRL was=1; now=0
    @1,682,265us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Attaching to DSP PROC...
    @1,688,828us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Opening MSGQ pool...
    @1,689,783us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Loading decodeCombo.x64P on DSP (1 args)...
    @2,327,258us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Starting DSP PROC...
    @2,522,506us: [+2 T:0x413c8490 S:0x413c7c2c] ti.sdo.dmai - [Display] Video output set to size 720x480 pitch 720
    @2,522,932us: [+2 T:0x413c8490 S:0x413c7ab4] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers
    @2,523,563us: [+0 T:0x413c8490 S:0x413c7a84] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x42449000, size=4)
    @2,523,757us: [+1 T:0x413c8490 S:0x413c7a84] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x42449000, size=4)
    @2,523,909us: [+1 T:0x413c8490 S:0x413c7a84] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @2,524,065us: [+1 T:0x413c8490 S:0x413c7a84] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x42449000) = 0x83000000.
    @2,524,229us: [+1 T:0x413c8490 S:0x413c7a3c] OM - Memory__addContigBuf> Enter(virtAddr=0x42449000, size=4, physAddr=0x83000000)
    @2,524,380us: [+1 T:0x413c8490 S:0x413c7a3c] OM - Memory__addContigBuf> creating new contigBuf object
    @2,524,512us: [+0 T:0x413c8490 S:0x413c7a24] OM - Memory_alloc> Enter(0x10)
    @2,524,652us: [+0 T:0x413c8490 S:0x413c7a24] OM - Memory_alloc> return (0x62e20)
    @2,524,786us: [+1 T:0x413c8490 S:0x413c7a3c] OM - Memory__addContigBuf> returning: cb->phys=0x83000000, cb->size=4, cb->virt=0x42449000
    @2,524,931us: [+0 T:0x413c8490 S:0x413c7a84] OM - Memory_getBufferPhysicalAddress> return (0x83000000)
    @2,525,069us: [+2 T:0x413c8490 S:0x413c7abc] ti.sdo.dmai - [Buffer] Set user pointer 0x42449000 (physical 0x83000000)
    @2,853,450us: [+2 T:0x413c8490 S:0x413c7adc] ti.sdo.dmai - [Dmai] Driver buffer 0 mapped to 0x42449000 has physical address 0x83000000
    @2,854,047us: [+0 T:0x413c8490 S:0x413c7a84] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x4283e000, size=4)
    @2,854,243us: [+1 T:0x413c8490 S:0x413c7a84] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x4283e000, size=4)
    @2,854,395us: [+1 T:0x413c8490 S:0x413c7a84] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @2,854,552us: [+1 T:0x413c8490 S:0x413c7a84] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x4283e000) = 0x82c00000.
    @2,854,718us: [+1 T:0x413c8490 S:0x413c7a3c] OM - Memory__addContigBuf> Enter(virtAddr=0x4283e000, size=4, physAddr=0x82c00000)
    @2,854,872us: [+1 T:0x413c8490 S:0x413c7a3c] OM - Memory__addContigBuf> creating new contigBuf object
    @2,855,002us: [+0 T:0x413c8490 S:0x413c7a24] OM - Memory_alloc> Enter(0x10)
    @2,855,145us: [+0 T:0x413c8490 S:0x413c7a24] OM - Memory_alloc> return (0x62e38)
    @2,855,282us: [+1 T:0x413c8490 S:0x413c7a3c] OM - Memory__addContigBuf> returning: cb->phys=0x82c00000, cb->size=4, cb->virt=0x4283e000
    @2,855,428us: [+0 T:0x413c8490 S:0x413c7a84] OM - Memory_getBufferPhysicalAddress> return (0x82c00000)
    @2,855,566us: [+2 T:0x413c8490 S:0x413c7abc] ti.sdo.dmai - [Buffer] Set user pointer 0x4283e000 (physical 0x82c00000)
    @3,184,097us: [+2 T:0x413c8490 S:0x413c7adc] ti.sdo.dmai - [Dmai] Driver buffer 1 mapped to 0x4283e000 has physical address 0x82c00000
    @3,184,702us: [+0 T:0x413c8490 S:0x413c7a84] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x42c33000, size=4)
    @3,184,892us: [+1 T:0x413c8490 S:0x413c7a84] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x42c33000, size=4)
    @3,185,043us: [+1 T:0x413c8490 S:0x413c7a84] OM - Memory__getPhysicalAddress> returning physAddr=0x0
    @3,185,206us: [+1 T:0x413c8490 S:0x413c7a84] OM - Memory_getBufferPhysicalAddress> CMEM_getPhys(0x42c33000) = 0x82800000.
    @3,185,368us: [+1 T:0x413c8490 S:0x413c7a3c] OM - Memory__addContigBuf> Enter(virtAddr=0x42c33000, size=4, physAddr=0x82800000)
    @3,185,526us: [+1 T:0x413c8490 S:0x413c7a3c] OM - Memory__addContigBuf> creating new contigBuf object
    @3,185,659us: [+0 T:0x413c8490 S:0x413c7a24] OM - Memory_alloc> Enter(0x10)
    @3,185,799us: [+0 T:0x413c8490 S:0x413c7a24] OM - Memory_alloc> return (0x62e50)
    @3,185,937us: [+1 T:0x413c8490 S:0x413c7a3c] OM - Memory__addContigBuf> returning: cb->phys=0x82800000, cb->size=4, cb->virt=0x42c33000
    @3,186,083us: [+0 T:0x413c8490 S:0x413c7a84] OM - Memory_getBufferPhysicalAddress> return (0x82800000)
    @3,186,221us: [+2 T:0x413c8490 S:0x413c7abc] ti.sdo.dmai - [Buffer] Set user pointer 0x42c33000 (physical 0x82800000)
    @3,514,607us: [+2 T:0x413c8490 S:0x413c7adc] ti.sdo.dmai - [Dmai] Driver buffer 2 mapped to 0x42c33000 has physical address 0x82800000
    @3,515,295us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> Opening remote transport...
    @3,521,084us: [+2 T:0x40bc8490 S:0x40bc7d74] OP - Processor_create_d> return (1)
    @3,521,280us: [+0 T:0x40bc8490 S:0x40bc7d64] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x621d8]
    @3,521,480us: [+0 T:0x41bc8490 S:0x41bc7c2c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x621d8] status[0]
    @3,521,644us: [+0 T:0x41bc8490 S:0x41bc7c4c] OP - doCmd> Exit (result=1)
    @3,521,777us: [+0 T:0x41bc8490 S:0x41bc7c6c] OP - Processor_create> return (0x62ae0)
    @3,521,912us: [+0 T:0x41bc8490 S:0x41bc7ca4] CE - rserverOpen('decodeCombo.x64P'): 0x60f30 done.
    @3,522,052us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_alloc> Enter(0x24)
    @3,522,198us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_alloc> return (0x62e88)
    @3,522,358us: [+0 T:0x41bc8490 S:0x41bc7c7c] OC - Comm_create> Enter(queueName='decode_1037_0', queue=0x62ac0, attrs=0x0)
    @3,522,507us: [+0 T:0x41bc8490 S:0x41bc7c64] OM - Memory_alloc> Enter(0x4)
    @3,522,645us: [+0 T:0x41bc8490 S:0x41bc7c64] OM - Memory_alloc> return (0x62eb0)
    @3,523,082us: [+0 T:0x41bc8490 S:0x41bc7c7c] OC - Comm_create> return (0x62eb0)
    @3,523,296us: [+0 T:0x41bc8490 S:0x41bc7c84] OM - Memory_free> Enter(0x62e88, 0x24)
    @3,523,447us: [+0 T:0x41bc8490 S:0x41bc7c84] OM - Memory_free> return (0x1)
    @3,523,583us: [+0 T:0x41bc8490 S:0x41bc7c84] OC - Comm_alloc> Enter(poolId=0x0, msg=0x62acc, size=576)
    @3,523,764us: [+0 T:0x41bc8490 S:0x41bc7c84] OC - Comm_alloc> msg=0x423d8900, returning (0)
    @3,523,915us: [+0 T:0x41bc8490 S:0x41bc7c6c] OC - Comm_locate> Enter(queueName='rmsq', queue=0x62abc)
    @3,524,252us: [+0 T:0x40bc8490 S:0x40bc7d74] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x621d8]
    @3,524,443us: [+0 T:0x40bc8490 S:0x40bc7d74] OP - getCmd_d> Enter (proc=0x40bc7de8)
    @3,524,589us: [+0 T:0x40bc8490 S:0x40bc7d54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x621c0] timeout[0xffffffff]
    @3,527,374us: [+0 T:0x41bc8490 S:0x41bc7c6c] OC - Comm_locate> return (0)
    @3,527,559us: [+0 T:0x41bc8490 S:0x41bc7ca4] CE - checkServer(0x62ab0)
    @3,527,721us: [+0 T:0x41bc8490 S:0x41bc7c74] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @3,527,929us: [+0 T:0x41bc8490 S:0x41bc7c74] OC - Comm_put> return (0)
    @3,528,113us: [+0 T:0x41bc8490 S:0x41bc7c6c] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7d10, timeout=-1)
    @3,528,410us: [+0 T:0x41bc8490 S:0x41bc7c6c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @3,528,594us: [+0 T:0x41bc8490 S:0x41bc7ca4] CE - rmsInit> RMS initialized(0x62ab0); CE_DEBUG on, setting DSP trace mask to *+01234567,GT_prefix=12345,GT_time=3
    @3,528,759us: [+0 T:0x41bc8490 S:0x41bc7c7c] CE - Engine_setTrace> Enter(engine=0x62ab0, mask='*+01234567,GT_prefix=12345,GT_time=3')
    @3,528,967us: [+1 T:0x41bc8490 S:0x41bc7c7c] CE - Engine_setTrace> Requesting DSP set trace ...
    @3,529,102us: [+0 T:0x41bc8490 S:0x41bc7c4c] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @3,529,294us: [+0 T:0x41bc8490 S:0x41bc7c4c] OC - Comm_put> return (0)
    @3,529,542us: [+0 T:0x41bc8490 S:0x41bc7c44] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7cc4, timeout=-1)
    @3,531,447us: [+0 T:0x41bc8490 S:0x41bc7c44] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @3,531,666us: [+0 T:0x41bc8490 S:0x41bc7c7c] CE - Engine_setTrace> return(0)
    @3,531,838us: [+0 T:0x41bc8490 S:0x41bc7c0c] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @3,532,042us: [+0 T:0x41bc8490 S:0x41bc7c0c] OC - Comm_put> return (0)
    @3,532,244us: [+0 T:0x41bc8490 S:0x41bc7c04] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7ca4, timeout=-1)
    @3,532,544us: [+0 T:0x41bc8490 S:0x41bc7c04] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @2,337,362tk: [+0 T:0x8680006c S:0x86803fe4] OG - Global_setSpecialTrace> enter(mask='*+01234567,GT_prefix=12345,GT_time=3')
    [DSP] @2,337,453tk: [+4 T:0x8680006c S:0x86803fe4] OG - Global_setSpecialTrace> This program was built with the following packages:
    [DSP] @2,337,516tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.targets.rts6000 (/home/colin/dvsdk_2_00_00_22_6467/xdctools_3_10_03/packages/ti/targets/rts6000/) [1,0,0,0,1225517497925]
    [DSP] @2,337,601tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.mpeg2dec (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mpeg2dec/) [1,0,0,1256561562000]
    [DSP] @2,337,688tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.aachedec (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/aachedec/) [1,0,0,1256561562000]
    [DSP] @2,337,777tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.dolbyac3dec (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/dolbyac3dec/) [1,0,0,0]
    [DSP] @2,337,862tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.h264dec (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/h264dec/) [1,0,0,1256561562000]
    [DSP] @2,337,949tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.hdvicp (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/hdvicp/) [1,0,0,1256561562000]
    [DSP] @2,338,036tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.mpeg4dec (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mpeg4dec/) [1,0,0,1256561562000]
    [DSP] @2,338,124tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.mp3dec (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mp3dec/) [1,0,0,0]
    [DSP] @2,338,206tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.global (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/global/) [1,0,0,1240266696499]
    [DSP] @2,338,293tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.ires.hdvicp (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/ires/hdvicp/) [1,0,1,1240266763264]
    [DSP] @2,338,383tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.dman3 (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/dman3/) [1,0,4,1240266658662]
    [DSP] @2,338,469tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.edma3.rm (/home/colin/dvsdk_2_00_00_22_6467/edma3_lld_1_05_00/packages/ti/sdo/edma3/rm/) [1,3,3,0]
    [DSP] @2,338,547tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.ires.nullresource (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/ires/nullresource/) [1,0,0,1240266782634]
    [DSP] @2,338,641tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.global (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/global/) [1,0,0,1240276693464]
    [DSP] @2,338,724tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.xdais.dm (/home/colin/dvsdk_2_00_00_22_6467/xdais_6_23/packages/ti/xdais/dm/) [1,0,5,1236972452910]
    [DSP] @2,338,801tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.utils.trace (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/utils/trace/) [1,0,0,1240266922890]
    [DSP] @2,338,890tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.utils.xdm (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/utils/xdm/) [1,0,2,1240276919490]
    [DSP] @2,338,977tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.xdais (/home/colin/dvsdk_2_00_00_22_6467/xdais_6_23/packages/ti/xdais/) [1,2,1,1236972427008]
    [DSP] @2,339,051tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.node (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/node/) [1,0,0,1240276734858]
    [DSP] @2,339,133tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.ipc.dsplink.dsp (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2,0,1,1240276@3,873,397us: [+0 T:0x41bc8490 S:0x41bc7c0c] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @3,873,644us: [+0 T:0x41bc8490 S:0x41bc7c0c] OC - Comm_put> return (0)
    @3,873,832us: [+0 T:0x41bc8490 S:0x41bc7c04] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7ca4, timeout=-1)
    @4,210,857us: [+0 T:0x41bc8490 S:0x41bc7c04] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    720026]
    [DSP] @2,339,223tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package dsplink.dsp (/home/colin/dvsdk_2_00_00_22_6467/dsplink-1_61_03-prebuilt/packages/dsplink/dsp/) [1,4,0,1239931280000]
    [DSP] @2,339,305tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.rtdx (/home/colin/dvsdk_2_00_00_22_6467/bios_5_33_03/packages/ti/rtdx/) [2,0,0,4,1219531643983]
    [DSP] @2,339,380tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.psl (/home/colin/dvsdk_2_00_00_22_6467/bios_5_33_03/packages/ti/psl/) [5,0,0,0,0]
    [DSP] @2,339,461tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.bios (/home/colin/dvsdk_2_00_00_22_6467/bios_5_33_03/packages/ti/bios/) [5,2,5,6,1227035764854]
    [DSP] @2,339,536tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.dskt2 (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/dskt2/) [1,0,4,1240266678055]
    [DSP] @2,339,621tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.rman (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/rman/) [2,0,0,1240266813533]
    [DSP] @2,339,706tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.hdintc (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/hdintc/) [1,0,4,1240266707594]
    [DSP] @2,339,793tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.memutils (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/memutils/) [1,0,0,1240266801007]
    [DSP] @2,339,881tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.edma3 (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/edma3/) [2,0,0,1240266681138]
    [DSP] @2,339,966tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.ires.edma3chan (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/ires/edma3chan/) [1,0,0,1240266737833]
    [DSP] @2,340,059tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.fc.acpy3 (/home/colin/dvsdk_2_00_00_22_6467/framework_components_2_23_01/packages/ti/sdo/fc/acpy3/) [1,0,4,1240266659108]
    [DSP] @2,340,144tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.bios.utils (/home/colin/dvsdk_2_00_00_22_6467/biosutils_1_01_00/packages/ti/bios/utils/) [2,0,1,0,0]
    [DSP] @2,340,221tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.catalog.c6000 (/home/colin/dvsdk_2_00_00_22_6467/xdctools_3_10_03/packages/ti/catalog/c6000/) [1,0,0,0,0]
    [DSP] @2,340,299tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.platforms.evmDM6467 (/home/colin/dvsdk_2_00_00_22_6467/bios_5_33_03/packages/ti/platforms/evmDM6467/) [1,0,0,0,0]
    [DSP] @2,340,381tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.osal (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/osal/) [2,0,2,1240276730877]
    [DSP] @2,340,463tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.osal.bios (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/osal/bios/) [2,0,1,1240276734107]
    [DSP] @2,340,549tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.ipc (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/) [2,0,1,1240276698961]
    [DSP] @2,340,630tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.ipc.bios (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/ipc/bios/) [2,0,1,1240276705217]
    [DSP] @2,340,715tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.alg (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/alg/) [1,0,1,1240276276798]
    [DSP] @2,340,796tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/) [1,0,6,1240276276491]
    [DSP] @2,340,875tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.bioslog (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/bioslog/) [1,0,1,1240276303166]
    [DSP] @2,340,959tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.video2 (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/video2/) [1,0,2,1240276933444]
    [DSP] @2,341,042tk: [+4 T:0x8680006c S:0x86@4,550,095us: [+0 T:0x41bc8490 S:0x41bc7c0c] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @4,550,324us: [+0 T:0x41bc8490 S:0x41bc7c0c] OC - Comm_put> return (0)
    @4,550,511us: [+0 T:0x41bc8490 S:0x41bc7c04] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7ca4, timeout=-1)
    @4,550,816us: [+0 T:0x41bc8490 S:0x41bc7c04] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    803fe4] OG -     package ti.sdo.codecs.mpeg2dec.ce (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mpeg2dec/ce/) [1,0,0,1256561562000]
    [DSP] @2,341,132tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.ce.audio1 (/home/colin/dvsdk_2_00_00_22_6467/codec_engine_2_23_01/packages/ti/sdo/ce/audio1/) [1,0,1,1240276296900]
    [DSP] @2,341,217tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.aachedec.ce (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/aachedec/ce/) [1,0,0,1256561562000]
    [DSP] @2,341,308tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.dolbyac3dec.ce (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/dolbyac3dec/ce/) [1,0,0,0]
    [DSP] @2,341,396tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.h264dec.ce (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/h264dec/ce/) [1,0,0,1256561562000]
    [DSP] @2,341,485tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.mpeg4dec.ce (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mpeg4dec/ce/) [1,0,0,1256561562000]
    [DSP] @2,341,576tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package ti.sdo.codecs.mp3dec.ce (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/codecs/mp3dec/ce/) [1,0,0,0]
    [DSP] @2,341,660tk: [+4 T:0x8680006c S:0x86803fe4] OG -     package decodeCombo (/home/colin/workdir/player/PlayerDepend/player_codec_6467_colin/ti/sdo/servers/decode/decodeCombo/) []
    [DSP] @2,341,744tk: [+0 T:0x8680006c S:0x86803fe4] OG - Global_setSpecialTrace> return
    [DSP] @2,343,715tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 5
    [DSP] @2,343,772tk: [+0 T:0x8680006c S:0x8680402c] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @3,136,329tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 5
    [DSP] @3,136,386tk: [+0 T:0x8680006c S:0x8680402c] CR - remote time = 0x0, trace buffer size = 4032
    [DSP] @4,706,443tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 5
    [DSP] @4,706,501tk: [+0 T:0x8680006c S:0x8680402c] CR - remote time = 0x0, trace buffer size = 4032
    @4,554,139us: [+0 T:0x41bc8490 S:0x41bc7c3c] CE - Engine_fwriteTrace> returning count [10574]
    @4,554,287us: [+0 T:0x41bc8490 S:0x41bc7ca4] CE - Engine_open> return(404144)
    @4,554,569us: [+0 T:0x41bc8490 S:0x41bc7bf4] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_create> Enter (engine=0x62ab0, name='h264dec', params=0x41bc7d74)
    @4,554,770us: [+0 T:0x41bc8490 S:0x41bc7bc4] CV - VISA_create(0x62ab0, 'h264dec', 0x41bc7d74, 0x2484, 'ti.sdo.ce.video2.IVIDDEC2')
    @4,554,966us: [+0 T:0x41bc8490 S:0x41bc7ac4] CV - VISA_create2(0x62ab0, 'h264dec', 0x41bc7d74, 0x1c, 0x2484, 'ti.sdo.ce.video2.IVIDDEC2')
    @4,555,140us: [+0 T:0x41bc8490 S:0x41bc7aac] OM - Memory_alloc> Enter(0x30)
    @4,555,286us: [+0 T:0x41bc8490 S:0x41bc7aac] OM - Memory_alloc> return (0x63090)
    @4,555,423us: [+0 T:0x41bc8490 S:0x41bc7a4c] CE - Engine_createNode(0x62ab0, 'h264dec', 2484, 0x41bc7d74, 0x1c, 0x41bc7bbc)
    @4,890,606us: [+0 T:0x41bc8490 S:0x41bc7a4c] CE - Engine> allocNode Enter(engine=0x62ab0, impId='h264dec')
    @4,890,777us: [+0 T:0x41bc8490 S:0x41bc7a34] OM - Memory_alloc> Enter(0x20)
    @4,890,922us: [+0 T:0x41bc8490 S:0x41bc7a34] OM - Memory_alloc> return (0x62e88)
    @4,891,078us: [+0 T:0x41bc8490 S:0x41bc7a4c] CE - Engine> allocNode(). Calling Comm_create(gppfromnode_1037_1, 0x62e90, NULL)
    @4,891,226us: [+0 T:0x41bc8490 S:0x41bc7a24] OC - Comm_create> Enter(queueName='gppfromnode_1037_1', queue=0x62e90, attrs=0x0)
    @4,891,371us: [+0 T:0x41bc8490 S:0x41bc7a0c] OM - Memory_alloc> Enter(0x4)
    @4,891,510us: [+0 T:0x41bc8490 S:0x41bc7a0c] OM - Memory_alloc> return (0x630c8)
    @4,891,949us: [+0 T:0x41bc8490 S:0x41bc7a24] OC - Comm_create> return (0x630c8)
    @4,892,141us: [+0 T:0x41bc8490 S:0x41bc7a2c] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @4,892,352us: [+0 T:0x41bc8490 S:0x41bc7a2c] OC - Comm_put> return (0)
    @4,892,497us: [+0 T:0x41bc8490 S:0x41bc7a24] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7ad4, timeout=-1)
    @4,963,422us: [+0 T:0x41bc8490 S:0x41bc7a24] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @4,963,611us: [+0 T:0x41bc8490 S:0x41bc7a2c] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @4,963,817us: [+0 T:0x41bc8490 S:0x41bc7a2c] OC - Comm_put> return (0)
    @4,964,001us: [+0 T:0x41bc8490 S:0x41bc7a24] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7ad4, timeout=-1)
    @4,964,300us: [+0 T:0x41bc8490 S:0x41bc7a24] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @4,964,470us: [+4 T:0x41bc8490 S:0x41bc7a4c] CE - Engine_createNode> created node(stdIn=0x2, stdOut=0x10001, msgq=0x630c8, algName='h264dec', rmsNode=0x878d3ff8, algHandle=0x878d40e0)
    @4,964,657us: [+0 T:0x41bc8490 S:0x41bc79b4] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @4,964,854us: [+0 T:0x41bc8490 S:0x41bc79b4] OC - Comm_put> return (0)
    @4,965,032us: [+0 T:0x41bc8490 S:0x41bc79ac] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7a4c, timeout=-1)
    @4,965,330us: [+0 T:0x41bc8490 S:0x41bc79ac] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @5,500,052tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 0
    [DSP] @5,500,114tk: [+0 T:0x8680006c S:0x86803f1c] OM - Memory_alloc> Enter(size=0x18)
    [DSP] @5,500,168tk: [+0 T:0x8680006c S:0x86803f1c] OM - Memory_alloc> return (0x878d3ff8)
    [DSP] @5,500,221tk: [+0 T:0x8680006c S:0x86803f1c] OM - Memory_alloc> Enter(size=0xa)
    [DSP] @5,500,268tk: [+0 T:0x8680006c S:0x86803f1c] OM - Memory_alloc> return (0x878d4010)
    [DSP] @5,500,325tk: [+0 T:0x8680006c S:0x86803ee4] OM - Memory_alloc> Enter(size=0x20)
    [DSP] @5,500,371tk: [+0 T:0x8680006c S:0x86803ee4] OM - Memory_alloc> return (0x878d4020)
    [DSP] @5,500,423tk: [+0 T:0x8680006c S:0x86803eb4] OM - Memory_alloc> Enter(size=0x24)
    [DSP] @5,500,470tk: [+0 T:0x8680006c S:0x86803eb4] OM - Memory_alloc> return (0x878d4040)
    [DSP] @5,500,542tk: [+0 T:0x8680006c S:0x86803ecc] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_create> Enter (engine=0x0, name='h264dec', params=0x87f03940)
    [DSP] @5,500,622tk: [+0 T:0x8680006c S:0x86803e94] CV - VISA_create(0x0, 'h264dec', 0x87f03940, 0x2484, 'ti.sdo.ce.video2.IVIDDEC2')
    [DSP] @5,500,695tk: [+0 T:0x8680006c S:0x86803d84] CV - VISA_create2(0x0, 'h264dec', 0x87f03940, 0x1c, 0x2484, 'ti.sdo.ce.video2.IVIDDEC2')
    [DSP] @5,500,779tk: [+0 T:0x8680006c S:0x86803d1c] CE - Engine_open> Enter('local', 0x86803d6c, 0x87f03940)
    [DSP] @5,500,842tk: [+0 T:0x8680006c S:0x86803cfc] OM - Memory_alloc> Enter(size=0x2c)
    [DSP] @5,500,890tk: [+0 T:0x8680006c S:0x86803cfc] OM - Memory_alloc> return (0x878d40b0)
    [DSP] @5,500,948tk: [+0 T:0x8680006c S:0x86803d1c] CE - Engine_open> return(-2020786000)
    [DSP] @5,501,010tk: [+0 T:0x8680006c S:0x86803d64] OM - Memory_alloc> Enter(size=0x30)
    [DSP] @5,501,059tk: [+0 T:0x8680006c S:0x86803d64] OM - Memory_alloc> return (0x878d40e0)
    [DSP] @5,501,112tk: [+0 T:0x8680006c S:0x86803d3c] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0x8786a9e0, idma3Fxns=0x0, iresFxns=0x8786a9b8, params=0x87f03940, attrs=0x86803e80)
    [DSP] @5,501,208tk: [+0 T:0x8680006c S:0x86803d1c] OM - Memory_alloc> Enter(size=0x10)
    [DSP] @5,501,255tk: [+0 T:0x8680006c S:0x86803d1c] OM - Memory_alloc> return (0x878d4110)
    [DSP] @5,663,099tk: [+0 T:0x8680006c S:0x86803754] ti.sdo.ce.osal.Sem - Sem_create> count 1
    [DSP] @5,663,182tk: [+0 T:0x8680006c S:0x86803754] ti.sdo.ce.osal.Sem - Sem_create> sem: 0x87491abc
    [DSP] @5,663,305tk: [+0 T:0x8680006c S:0x86803754] ti.sdo.ce.osal.Sem - Sem_create> count 1
    [DSP] @5,663,357tk: [+0 T:0x8680006c S:0x86803754] ti.sdo.ce.osal.Sem - Sem_create> sem: 0x87491aec
    [DSP] @5,664,149tk: [+0 T:0x8680006c S:0x86803d3c] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x878d4110)
    [DSP] @5,664,224tk: [+5 T:0x8680006c S:0x86803d84] CV - VISA_create> local codec created (name='h264dec', handle=0x878d4110)
    [DSP] @5,664,292tk: [+0 T:0x8680006c S:0x86803ecc] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_create> return (0x878d40e0)
    [DSP] @5,664,361tk: [+4 T:0x8680006c S:0x86803e8c] OT - Thread_create > name: "h264dec#0", pri:  -1, stack size:  13096, stack seg: 0
    [DSP] @5,665,900tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 1
    [DSP] @5,668,285tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 5
    [DSP] @5,668,345tk: [+0 T:0x8680006c S:0x8680402c] CR - remote time = 0x0, trace buffer size = 4032
    @5,305,639us: [+0 T:0x41bc8490 S:0x41bc79e4] CE - Engine_fwriteTrace> returning count [3310]
    @5,305,797us: [+2 T:0x41bc8490 S:0x41bc7a4c] CE - Engine_createNode> Returning 0x62e88
    @5,305,939us: [+0 T:0x41bc8490 S:0x41bc7aac] OM - Memory_alloc> Enter(0x4)
    @5,306,083us: [+0 T:0x41bc8490 S:0x41bc7aac] OM - Memory_alloc> return (0x630d8)
    @5,306,224us: [+0 T:0x41bc8490 S:0x41bc7aa4] OC - Comm_alloc> Enter(poolId=0x0, msg=0x630d8, size=2484)
    @5,306,405us: [+0 T:0x41bc8490 S:0x41bc7aa4] OC - Comm_alloc> msg=0x423d9900, returning (0)
    @5,306,569us: [+5 T:0x41bc8490 S:0x41bc7ac4] CV - VISA_create> remote codec created (name='h264dec', localQueueID=0x10001, remoteQueueID=0x0002)
    @5,306,734us: [+0 T:0x41bc8490 S:0x41bc7bf4] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_create> return (0x63090)
    @5,306,877us: [+2 T:0x41bc8490 S:0x41bc7c1c] ti.sdo.dmai - [Vdec2] Video decoder instance created
    @5,307,006us: [+0 T:0x41bc8490 S:0x41bc7bac] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Enter (handle=0x63090, id=1, dynParams=0x41bc7d58 (size=0x1c), status=0x41bc7c74 (size=0xb8)
    @5,307,173us: [+5 T:0x41bc8490 S:0x41bc7b7c] CV - VISA_allocMsg> Allocating message for messageId=0x00020409
    @5,307,316us: [+0 T:0x41bc8490 S:0x41bc7b5c] CV - VISA_call(visa=0x63090, msg=0x423d9900): messageId=0x00020409, command=0x1
    @5,307,504us: [+0 T:0x41bc8490 S:0x41bc7b24] OC - Comm_put> Enter(queue=0x2, msg=0x423d9900)
    @5,307,704us: [+0 T:0x41bc8490 S:0x41bc7b24] OC - Comm_put> return (0)
    @5,307,846us: [+0 T:0x41bc8490 S:0x41bc7b1c] OC - Comm_get> Enter(queue=0x10001, msg=0x41bc7bc4, timeout=-1)
    @5,308,192us: [+0 T:0x41bc8490 S:0x41bc7b1c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @5,308,377us: [+0 T:0x41bc8490 S:0x41bc7aac] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @5,308,579us: [+0 T:0x41bc8490 S:0x41bc7aac] OC - Comm_put> return (0)
    @5,308,757us: [+0 T:0x41bc8490 S:0x41bc7aa4] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7b44, timeout=-1)
    @5,309,053us: [+0 T:0x41bc8490 S:0x41bc7aa4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @6,463,804tk: [+5 T:0x8749198c S:0x8749548c] CN - NODE> 0x878d4020(h264dec#0) call(algHandle=0x878d40e0, msg=0x87f04900); messageId=0x00020409
    [DSP] @6,463,895tk: [+0 T:0x8749198c S:0x87495314] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Enter (handle=0x878d40e0, id=1, dynParams=0x87f04934 (size=0x1c), status=0x87f04950 (size=0xb8)
    [DSP] @6,464,002tk: [+5 T:0x8749198c S:0x874952f4] CV - VISA_enter(visa=0x878d40e0): algHandle = 0x878d4110
    [DSP] @6,464,064tk: [+0 T:0x8749198c S:0x874952d4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x878d4110)
    [DSP] @6,464,178tk: [+0 T:0x8749198c S:0x874952d4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
    [DSP] @6,464,239tk: [+5 T:0x8749198c S:0x874952f4] CV - VISA_exit(visa=0x878d40e0): algHandle = 0x878d4110
    [DSP] @6,464,299tk: [+0 T:0x8749198c S:0x874952d4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x878d4110)
    [DSP] @6,464,364tk: [+0 T:0x8749198c S:0x874952d4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
    [DSP] @6,464,420tk: [+0 T:0x8749198c S:0x87495314] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Exit (handle=0x878d40e0, retVal=0x0)
    [DSP] @6,464,487tk: [+5 T:0x8749198c S:0x8749548c] CN - NODE> returned from call(algHandle=0x878d40e0, msg=0x87f04900); messageId=0x00020409
    [DSP] @6,465,835tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 5
    [DSP] @6,465,892tk: [+0 T:0x8680006c S:0x8680402c] CR - remote time = 0x0, trace buffer size = 4032
    @5,646,466us: [+0 T:0x41bc8490 S:0x41bc7adc] CE - Engine_fwriteTrace> returning count [1471]
    @5,646,630us: [+0 T:0x41bc8490 S:0x41bc7b5c] CV - VISA_call Completed: messageId=0x00020409, command=0x1, return(status=0)
    @5,646,785us: [+5 T:0x41bc8490 S:0x41bc7b64] CV - VISA_freeMsg(0x63090, 0x423d9900): Freeing message with messageId=0x00020409
    @5,646,933us: [+0 T:0x41bc8490 S:0x41bc7bac] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Exit (handle=0x63090, retVal=0x0)
    @5,647,074us: [+2 T:0x41bc8490 S:0x41bc7c1c] ti.sdo.dmai - [Vdec2] Made XDM_SETPARAMS control call
    @5,647,209us: [+0 T:0x41bc8490 S:0x41bc7adc] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Enter (handle=0x63090, id=5, dynParams=0x6301c (size=0x1c), status=0x41bc7b94 (size=0xb8)
    @5,647,374us: [+5 T:0x41bc8490 S:0x41bc7aac] CV - VISA_allocMsg> Allocating message for messageId=0x0002040a
    @5,647,515us: [+0 T:0x41bc8490 S:0x41bc7a8c] CV - VISA_call(visa=0x63090, msg=0x423d9900): messageId=0x0002040a, command=0x1
    @5,647,662us: [+0 T:0x41bc8490 S:0x41bc7a54] OC - Comm_put> Enter(queue=0x2, msg=0x423d9900)
    @5,647,857us: [+0 T:0x41bc8490 S:0x41bc7a54] OC - Comm_put> return (0)
    @5,648,003us: [+0 T:0x41bc8490 S:0x41bc7a4c] OC - Comm_get> Enter(queue=0x10001, msg=0x41bc7af4, timeout=-1)
    @5,648,329us: [+0 T:0x41bc8490 S:0x41bc7a4c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @5,648,516us: [+0 T:0x41bc8490 S:0x41bc79dc] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @5,648,745us: [+0 T:0x41bc8490 S:0x41bc79dc] OC - Comm_put> return (0)
    @5,648,927us: [+0 T:0x41bc8490 S:0x41bc79d4] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7a74, timeout=-1)
    @5,649,226us: [+0 T:0x41bc8490 S:0x41bc79d4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @7,253,061tk: [+5 T:0x8749198c S:0x8749548c] CN - NODE> 0x878d4020(h264dec#0) call(algHandle=0x878d40e0, msg=0x87f04900); messageId=0x0002040a
    [DSP] @7,253,147tk: [+0 T:0x8749198c S:0x87495314] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Enter (handle=0x878d40e0, id=5, dynParams=0x87f04934 (size=0x1c), status=0x87f04950 (size=0xb8)
    [DSP] @7,253,249tk: [+5 T:0x8749198c S:0x874952f4] CV - VISA_enter(visa=0x878d40e0): algHandle = 0x878d4110
    [DSP] @7,253,309tk: [+0 T:0x8749198c S:0x874952d4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x878d4110)
    [DSP] @7,253,372tk: [+0 T:0x8749198c S:0x874952d4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
    [DSP] @7,253,427tk: [+5 T:0x8749198c S:0x874952f4] CV - VISA_exit(visa=0x878d40e0): algHandle = 0x878d4110
    [DSP] @7,253,487tk: [+0 T:0x8749198c S:0x874952d4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x878d4110)
    [DSP] @7,253,549tk: [+0 T:0x8749198c S:0x874952d4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
    [DSP] @7,253,603tk: [+0 T:0x8749198c S:0x87495314] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Exit (handle=0x878d40e0, retVal=0x0)
    [DSP] @7,253,671tk: [+5 T:0x8749198c S:0x8749548c] CN - NODE> returned from call(algHandle=0x878d40e0, msg=0x87f04900); messageId=0x0002040a
    [DSP] @7,255,123tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 5
    [DSP] @7,255,180tk: [+0 T:0x8680006c S:0x8680402c] CR - remote time = 0x0, trace buffer size = 4032
    @5,651,629us: [+0 T:0x41bc8490 S:0x41bc7a0c] CE - Engine_fwriteTrace> returning count [1471]
    @5,651,783us: [+0 T:0x41bc8490 S:0x41bc7a8c] CV - VISA_call Completed: messageId=0x0002040a, command=0x1, return(status=0)
    @5,651,940us: [+5 T:0x41bc8490 S:0x41bc7a94] CV - VISA_freeMsg(0x63090, 0x423d9900): Freeing message with messageId=0x0002040a
    @5,987,264us: [+0 T:0x41bc8490 S:0x41bc7adc] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_control> Exit (handle=0x63090, retVal=0x0)
    @5,987,444us: [+2 T:0x41bc8490 S:0x41bc7b4c] ti.sdo.dmai - [Vdec2] Made XDM_GETBUFINFO control call
    @5,987,653us: [+2 T:0x41bc8490 S:0x41bc7cdc] ti.sdo.dmai - [BufTab] Allocating BufTab for 5 buffers
    @5,987,830us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_alloc> Enter(0x310200)
    @5,987,977us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> Enter(size=3211776, align=-1, cached=FALSE, heap=FALSE)
    @5,988,396us: [+4 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> CMEM_alloc(3211776) = 0x43028000.
    @5,988,591us: [+4 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> CMEM_getPhys(0x43028000) = 0x861de000.
    @5,988,746us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> Enter(virtAddr=0x43028000, size=3211776, physAddr=0x861de000)
    @5,988,901us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> creating new contigBuf object
    @5,989,032us: [+0 T:0x41bc8490 S:0x41bc7bf4] OM - Memory_alloc> Enter(0x10)
    @5,989,172us: [+0 T:0x41bc8490 S:0x41bc7bf4] OM - Memory_alloc> return (0x63188)
    @5,989,308us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> returning: cb->phys=0x861de000, cb->size=3211776, cb->virt=0x43028000
    @5,989,562us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> return (0x43028000)
    @5,989,705us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_alloc> return (0x43028000)
    @5,989,839us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43028000, size=4)
    @5,990,007us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43028000, size=4)
    @5,990,154us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> found in cb(Sc=0x43028000, Ec=0x43338200, Ss=0x43028000, Es=0x43028004, PSc=0x861de000)
    @5,990,312us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> returning physAddr=0x861de000
    @5,990,446us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_getBufferPhysicalAddress> return (0x861de000)
    @5,990,581us: [+2 T:0x41bc8490 S:0x41bc7cb4] ti.sdo.dmai - [Buffer] Alloc Buffer of size 3211776 at 0x43028000 (0x861de000 phys)
    @5,990,746us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_alloc> Enter(0x310200)
    @5,990,889us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> Enter(size=3211776, align=-1, cached=FALSE, heap=FALSE)
    @5,991,316us: [+4 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> CMEM_alloc(3211776) = 0x43339000.
    @5,991,516us: [+4 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> CMEM_getPhys(0x43339000) = 0x85ecd000.
    @5,991,668us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> Enter(virtAddr=0x43339000, size=3211776, physAddr=0x85ecd000)
    @5,991,817us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> creating new contigBuf object
    @5,991,948us: [+0 T:0x41bc8490 S:0x41bc7bf4] OM - Memory_alloc> Enter(0x10)
    @5,992,087us: [+0 T:0x41bc8490 S:0x41bc7bf4] OM - Memory_alloc> return (0x63210)
    @5,992,221us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> returning: cb->phys=0x85ecd000, cb->size=3211776, cb->virt=0x43339000
    @5,992,370us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> return (0x43339000)
    @5,992,502us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_alloc> return (0x43339000)
    @5,992,635us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43339000, size=4)
    @5,992,803us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43339000, size=4)
    @5,992,950us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> found in cb(Sc=0x43339000, Ec=0x43649200, Ss=0x43339000, Es=0x43339004, PSc=0x85ecd000)
    @5,993,106us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> returning physAddr=0x85ecd000
    @5,993,239us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_getBufferPhysicalAddress> return (0x85ecd000)
    @6,328,589us: [+2 T:0x41bc8490 S:0x41bc7cb4] ti.sdo.dmai - [Buffer] Alloc Buffer of size 3211776 at 0x43339000 (0x85ecd000 phys)
    @6,328,792us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_alloc> Enter(0x310200)
    @6,328,943us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> Enter(size=3211776, align=-1, cached=FALSE, heap=FALSE)
    @6,329,443us: [+4 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> CMEM_alloc(3211776) = 0x4364a000.
    @6,329,648us: [+4 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> CMEM_getPhys(0x4364a000) = 0x85bbc000.
    @6,329,804us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> Enter(virtAddr=0x4364a000, size=3211776, physAddr=0x85bbc000)
    @6,329,959us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> creating new contigBuf object
    @6,330,092us: [+0 T:0x41bc8490 S:0x41bc7bf4] OM - Memory_alloc> Enter(0x10)
    @6,330,236us: [+0 T:0x41bc8490 S:0x41bc7bf4] OM - Memory_alloc> return (0x63298)
    @6,330,368us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> returning: cb->phys=0x85bbc000, cb->size=3211776, cb->virt=0x4364a000
    @6,330,515us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> return (0x4364a000)
    @6,330,646us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_alloc> return (0x4364a000)
    @6,330,777us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x4364a000, size=4)
    @6,330,918us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x4364a000, size=4)
    @6,331,056us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> found in cb(Sc=0x4364a000, Ec=0x4395a200, Ss=0x4364a000, Es=0x4364a004, PSc=0x85bbc000)
    @6,331,213us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> returning physAddr=0x85bbc000
    @6,331,383us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_getBufferPhysicalAddress> return (0x85bbc000)
    @6,331,524us: [+2 T:0x41bc8490 S:0x41bc7cb4] ti.sdo.dmai - [Buffer] Alloc Buffer of size 3211776 at 0x4364a000 (0x85bbc000 phys)
    @6,331,686us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_alloc> Enter(0x310200)
    @6,331,829us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> Enter(size=3211776, align=-1, cached=FALSE, heap=FALSE)
    @6,332,259us: [+4 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> CMEM_alloc(3211776) = 0x4395b000.
    @6,332,456us: [+4 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> CMEM_getPhys(0x4395b000) = 0x858ab000.
    @6,332,607us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> Enter(virtAddr=0x4395b000, size=3211776, physAddr=0x858ab000)
    @6,332,761us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> creating new contigBuf object
    @6,332,891us: [+0 T:0x41bc8490 S:0x41bc7bf4] OM - Memory_alloc> Enter(0x10)
    @6,333,028us: [+0 T:0x41bc8490 S:0x41bc7bf4] OM - Memory_alloc> return (0x63320)
    @6,333,164us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> returning: cb->phys=0x858ab000, cb->size=3211776, cb->virt=0x4395b000
    @6,333,312us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> return (0x4395b000)
    @6,333,445us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_alloc> return (0x4395b000)
    @6,333,577us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x4395b000, size=4)
    @6,333,718us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x4395b000, size=4)
    @6,333,855us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> found in cb(Sc=0x4395b000, Ec=0x43c6b200, Ss=0x4395b000, Es=0x4395b004, PSc=0x858ab000)
    @6,334,008us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> returning physAddr=0x858ab000
    @6,334,178us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_getBufferPhysicalAddress> return (0x858ab000)
    @6,334,318us: [+2 T:0x41bc8490 S:0x41bc7cb4] ti.sdo.dmai - [Buffer] Alloc Buffer of size 3211776 at 0x4395b000 (0x858ab000 phys)
    @6,669,887us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_alloc> Enter(0x310200)
    @6,670,058us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> Enter(size=3211776, align=-1, cached=FALSE, heap=FALSE)
    @6,670,484us: [+4 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> CMEM_alloc(3211776) = 0x43c6c000.
    @6,670,682us: [+4 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> CMEM_getPhys(0x43c6c000) = 0x85289000.
    @6,670,834us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> Enter(virtAddr=0x43c6c000, size=3211776, physAddr=0x85289000)
    @6,670,990us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> creating new contigBuf object
    @6,671,121us: [+0 T:0x41bc8490 S:0x41bc7bf4] OM - Memory_alloc> Enter(0x10)
    @6,671,261us: [+0 T:0x41bc8490 S:0x41bc7bf4] OM - Memory_alloc> return (0x633a8)
    @6,671,396us: [+1 T:0x41bc8490 S:0x41bc7c0c] OM - Memory__addContigBuf> returning: cb->phys=0x85289000, cb->size=3211776, cb->virt=0x43c6c000
    @6,671,544us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_contigAlloc> return (0x43c6c000)
    @6,671,677us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_alloc> return (0x43c6c000)
    @6,671,808us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43c6c000, size=4)
    @6,671,949us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43c6c000, size=4)
    @6,672,086us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> found in cb(Sc=0x43c6c000, Ec=0x43f7c200, Ss=0x43c6c000, Es=0x43c6c004, PSc=0x85289000)
    @6,672,242us: [+1 T:0x41bc8490 S:0x41bc7c7c] OM - Memory__getPhysicalAddress> returning physAddr=0x85289000
    @6,672,376us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_getBufferPhysicalAddress> return (0x85289000)
    @6,672,511us: [+2 T:0x41bc8490 S:0x41bc7cb4] ti.sdo.dmai - [Buffer] Alloc Buffer of size 3211776 at 0x43c6c000 (0x85289000 phys)
    @6,672,714us: [+2 T:0x41bc8490 S:0x41bc7cbc] ti.sdo.dmai - [Loader] Creating Loader for video1.264 with buffer size 2697152, window size 1048576, alignment -1
    @6,673,698us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_alloc> Enter(0x2927c0)
    @6,673,884us: [+0 T:0x41bc8490 S:0x41bc7c34] OM - Memory_contigAlloc> Enter(size=2697152, align=-1, cached=FALSE, heap=FALSE)
    @6,674,328us: [+4 T:0x41bc8490 S:0x41bc7c34] OM - Memory_contigAlloc> CMEM_alloc(2697152) = 0x43f7d000.
    @6,674,527us: [+4 T:0x41bc8490 S:0x41bc7c34] OM - Memory_contigAlloc> CMEM_getPhys(0x43f7d000) = 0x864ef000.
    @6,674,682us: [+1 T:0x41bc8490 S:0x41bc7bec] OM - Memory__addContigBuf> Enter(virtAddr=0x43f7d000, size=2697152, physAddr=0x864ef000)
    @6,674,837us: [+1 T:0x41bc8490 S:0x41bc7bec] OM - Memory__addContigBuf> creating new contigBuf object
    @6,674,968us: [+0 T:0x41bc8490 S:0x41bc7bd4] OM - Memory_alloc> Enter(0x10)
    @6,675,109us: [+0 T:0x41bc8490 S:0x41bc7bd4] OM - Memory_alloc> return (0x635c8)
    @6,675,241us: [+1 T:0x41bc8490 S:0x41bc7bec] OM - Memory__addContigBuf> returning: cb->phys=0x864ef000, cb->size=2697152, cb->virt=0x43f7d000
    @6,675,416us: [+0 T:0x41bc8490 S:0x41bc7c34] OM - Memory_contigAlloc> return (0x43f7d000)
    @6,675,554us: [+0 T:0x41bc8490 S:0x41bc7c7c] OM - Memory_alloc> return (0x43f7d000)
    @6,675,688us: [+0 T:0x41bc8490 S:0x41bc7c5c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43f7d000, size=4)
    @6,675,829us: [+1 T:0x41bc8490 S:0x41bc7c5c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43f7d000, size=4)
    @6,675,970us: [+1 T:0x41bc8490 S:0x41bc7c5c] OM - Memory__getPhysicalAddress> found in cb(Sc=0x43f7d000, Ec=0x4420f7c0, Ss=0x43f7d000, Es=0x43f7d004, PSc=0x864ef000)
    @6,676,125us: [+1 T:0x41bc8490 S:0x41bc7c5c] OM - Memory__getPhysicalAddress> returning physAddr=0x864ef000
    @6,676,257us: [+0 T:0x41bc8490 S:0x41bc7c5c] OM - Memory_getBufferPhysicalAddress> return (0x864ef000)
    @6,676,389us: [+2 T:0x41bc8490 S:0x41bc7c94] ti.sdo.dmai - [Buffer] Alloc Buffer of size 2697152 at 0x43f7d000 (0x864ef000 phys)
    @7,011,172us: [+0 T:0x41bc8490 S:0x41bc7ca4] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @7,011,336us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_alloc> Enter(0x14)
    @7,011,486us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_alloc> return (0x63620)
    @7,011,623us: [+0 T:0x41bc8490 S:0x41bc7ca4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x63620]
    @7,011,758us: [+0 T:0x41bc8490 S:0x41bc7ca4] ti.sdo.ce.osal.Sem - Sem_create> count: 1
    @7,011,883us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_alloc> Enter(0x14)
    @7,012,023us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_alloc> return (0x63638)
    @7,012,159us: [+0 T:0x41bc8490 S:0x41bc7ca4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x63638]
    @7,012,292us: [+0 T:0x41bc8490 S:0x41bc7ca4] ti.sdo.ce.osal.Sem - Sem_create> count: 0
    @7,012,416us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_alloc> Enter(0x14)
    @7,012,554us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_alloc> return (0x63650)
    @7,012,692us: [+0 T:0x41bc8490 S:0x41bc7ca4] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x63650]
    @7,013,422us: [+0 T:0x4001f950 S:0xbeb38a14] CE - Engine_open> Enter('decode', 0x0, 0xbeb38a84)
    @7,013,624us: [+0 T:0x4001f950 S:0xbeb389fc] OM - Memory_alloc> Enter(0x2c)
    @7,013,785us: [+0 T:0x4001f950 S:0xbeb389fc] OM - Memory_alloc> return (0x636f8)
    @7,013,971us: [+0 T:0x4001f950 S:0xbeb38a14] CE - rserverOpen('decodeCombo.x64P'), count = 1
    @7,014,120us: [+0 T:0x4001f950 S:0xbeb38a14] CE - rserverOpen('decodeCombo.x64P'): 0x60f30 done.
    @7,014,272us: [+0 T:0x4001f950 S:0xbeb389fc] OM - Memory_alloc> Enter(0x24)
    @7,014,420us: [+0 T:0x4001f950 S:0xbeb389fc] OM - Memory_alloc> return (0x63728)
    @7,014,586us: [+0 T:0x4001f950 S:0xbeb389ec] OC - Comm_create> Enter(queueName='decode_1037_2', queue=0x63708, attrs=0x0)
    @7,014,742us: [+0 T:0x4001f950 S:0xbeb389d4] OM - Memory_alloc> Enter(0x4)
    @7,014,888us: [+0 T:0x4001f950 S:0xbeb389d4] OM - Memory_alloc> return (0x63750)
    @7,015,340us: [+0 T:0x4001f950 S:0xbeb389ec] OC - Comm_create> return (0x63750)
    @7,015,531us: [+0 T:0x4001f950 S:0xbeb389f4] OM - Memory_free> Enter(0x63728, 0x24)
    @7,015,691us: [+0 T:0x4001f950 S:0xbeb389f4] OM - Memory_free> return (0x1)
    @7,015,836us: [+0 T:0x4001f950 S:0xbeb389f4] OC - Comm_alloc> Enter(poolId=0x0, msg=0x63714, size=576)
    @7,016,024us: [+0 T:0x4001f950 S:0xbeb389f4] OC - Comm_alloc> msg=0x423da900, returning (0)
    @7,016,178us: [+0 T:0x4001f950 S:0xbeb389dc] OC - Comm_locate> Enter(queueName='rmsq', queue=0x63704)
    @7,016,709us: [+0 T:0x4001f950 S:0xbeb389dc] OC - Comm_locate> return (0)
    @7,016,901us: [+0 T:0x4001f950 S:0xbeb38a14] CE - checkServer(0x636f8)
    @7,017,074us: [+0 T:0x4001f950 S:0xbeb389e4] OC - Comm_put> Enter(queue=0x0, msg=0x423da900)
    @7,017,286us: [+0 T:0x4001f950 S:0xbeb389e4] OC - Comm_put> return (0)
    @7,017,481us: [+0 T:0x4001f950 S:0xbeb389dc] OC - Comm_get> Enter(queue=0x10002, msg=0xbeb38a80, timeout=-1)
    @7,017,789us: [+0 T:0x4001f950 S:0xbeb389dc] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @7,017,991us: [+0 T:0x4001f950 S:0xbeb3897c] OC - Comm_put> Enter(queue=0x0, msg=0x423da900)
    @7,018,202us: [+0 T:0x4001f950 S:0xbeb3897c] OC - Comm_put> return (0)
    @7,018,394us: [+0 T:0x4001f950 S:0xbeb38974] OC - Comm_get> Enter(queue=0x10002, msg=0xbeb38a14, timeout=-1)
    @7,018,701us: [+0 T:0x4001f950 S:0xbeb38974] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @10,430,560tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f05928, 4056): cmd = 6
    [DSP] @10,432,686tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f05928, 4056): cmd = 5
    [DSP] @10,432,745tk: [+0 T:0x8680006c S:0x8680402c] CR - remote time = 0x0, trace buffer size = 4032
    @7,019,441us: [+0 T:0x4001f950 S:0xbeb389ac] CE - Engine_fwriteTrace> returning count [297]
    @7,019,648us: [+0 T:0x4001f950 S:0xbeb38a14] CE - Engine_open> return(407288)
    @7,373,817us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43f7d000, size=4)
    @7,374,010us: [+1 T:0x41bc8490 S:0x41bc7c8c] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43f7d000, size=4)
    @7,374,165us: [+1 T:0x41bc8490 S:0x41bc7c8c] OM - Memory__getPhysicalAddress> found in cb(Sc=0x43f7d000, Ec=0x4420f7c0, Ss=0x43f7d000, Es=0x43f7d004, PSc=0x864ef000)
    @7,374,324us: [+1 T:0x41bc8490 S:0x41bc7c8c] OM - Memory__getPhysicalAddress> returning physAddr=0x864ef000
    @7,374,460us: [+0 T:0x41bc8490 S:0x41bc7c8c] OM - Memory_getBufferPhysicalAddress> return (0x864ef000)
    @7,374,596us: [+2 T:0x41bc8490 S:0x41bc7cc4] ti.sdo.dmai - [Buffer] Set user pointer 0x43f7d000 (physical 0x864ef000)
    @7,374,766us: [+0 T:0x41bc8490 S:0x41bc7cc4] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x63620]
    @7,374,925us: [+0 T:0x41bc8490 S:0x41bc7cd4] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x63620]
    @7,375,137us: [+0 T:0x41bc8490 S:0x41bc7354] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x63090, inBufs=0x41bc74a4, outBufs=0x41bc7498, inArgs=0x41bc7d08, outArgs=0x41bc7568)
    @7,375,420us: [+5 T:0x41bc8490 S:0x41bc72dc] CV - VISA_allocMsg> Allocating message for messageId=0x0002040b
    @7,375,609us: [+0 T:0x41bc8490 S:0x41bc72ac] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43f7d000, size=1048576)
    @7,375,770us: [+1 T:0x41bc8490 S:0x41bc72ac] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43f7d000, size=1048576)
    @7,375,919us: [+1 T:0x41bc8490 S:0x41bc72ac] OM - Memory__getPhysicalAddress> found in cb(Sc=0x43f7d000, Ec=0x4420f7c0, Ss=0x43f7d000, Es=0x4407d000, PSc=0x864ef000)
    @7,376,082us: [+1 T:0x41bc8490 S:0x41bc72ac] OM - Memory__getPhysicalAddress> returning physAddr=0x864ef000
    @7,376,226us: [+0 T:0x41bc8490 S:0x41bc72ac] OM - Memory_getBufferPhysicalAddress> return (0x864ef000)
    @7,376,374us: [+0 T:0x41bc8490 S:0x41bc72ac] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43028000, size=2141184)
    @7,376,524us: [+1 T:0x41bc8490 S:0x41bc72ac] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43028000, size=2141184)
    @7,376,672us: [+1 T:0x41bc8490 S:0x41bc72ac] OM - Memory__getPhysicalAddress> found in cb(Sc=0x43028000, Ec=0x43338200, Ss=0x43028000, Es=0x43232c00, PSc=0x861de000)
    @7,376,834us: [+1 T:0x41bc8490 S:0x41bc72ac] OM - Memory__getPhysicalAddress> returning physAddr=0x861de000
    @7,376,971us: [+0 T:0x41bc8490 S:0x41bc72ac] OM - Memory_getBufferPhysicalAddress> return (0x861de000)
    @7,377,116us: [+0 T:0x41bc8490 S:0x41bc72ac] OM - Memory_getBufferPhysicalAddress> Enter(virtAddr=0x43232c00, size=1070592)
    @7,377,262us: [+1 T:0x41bc8490 S:0x41bc72ac] OM - Memory__getPhysicalAddress> Enter(virtAddr=0x43232c00, size=1070592)
    @7,377,407us: [+1 T:0x41bc8490 S:0x41bc72ac] OM - Memory__getPhysicalAddress> found in cb(Sc=0x43028000, Ec=0x43338200, Ss=0x43232c00, Es=0x43338200, PSc=0x861de000)
    @7,377,597us: [+1 T:0x41bc8490 S:0x41bc72ac] OM - Memory__getPhysicalAddress> returning physAddr=0x863e8c00
    @7,377,743us: [+0 T:0x41bc8490 S:0x41bc72ac] OM - Memory_getBufferPhysicalAddress> return (0x863e8c00)
    @7,377,890us: [+0 T:0x41bc8490 S:0x41bc72f4] CV - VISA_call(visa=0x63090, msg=0x423d9900): messageId=0x0002040b, command=0x0
    @7,378,048us: [+0 T:0x41bc8490 S:0x41bc72bc] OC - Comm_put> Enter(queue=0x2, msg=0x423d9900)
    @7,378,251us: [+0 T:0x41bc8490 S:0x41bc72bc] OC - Comm_put> return (0)
    @7,378,401us: [+0 T:0x41bc8490 S:0x41bc72b4] OC - Comm_get> Enter(queue=0x10001, msg=0x41bc736c, timeout=-1)
    @7,378,630us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x63620] timeout[0xffffffff]
    @7,378,801us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x63620] status[0]
    @7,378,949us: [+0 T:0x44a8d490 S:0x44a8cd8c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x63620]
    @7,379,099us: [+0 T:0x44a8d490 S:0x44a8cd9c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x63620]
    @7,379,321us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x63638] timeout[0xffffffff]
    @7,379,585us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x63638] status[0]
    @7,713,349us: [+0 T:0x41bc8490 S:0x41bc72b4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @7,713,564us: [+0 T:0x41bc8490 S:0x41bc7244] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @7,713,782us: [+0 T:0x41bc8490 S:0x41bc7244] OC - Comm_put> return (0)
    @7,713,974us: [+0 T:0x41bc8490 S:0x41bc723c] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc72dc, timeout=-1)
    @7,718,436us: [+0 T:0x44a8d490 S:0x44a8cd8c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x63638]
    @7,718,633us: [+0 T:0x44a8d490 S:0x44a8cd9c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x63638]
    @7,718,786us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x63620] timeout[0xffffffff]
    @7,718,971us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x63620] status[0]
    @7,719,113us: [+0 T:0x44a8d490 S:0x44a8cd8c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x63620]
    @7,719,256us: [+0 T:0x44a8d490 S:0x44a8cd9c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x63620]
    @7,719,483us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x63638] timeout[0xffffffff]
    @7,719,665us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x63638] status[0]
    @7,719,813us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x63638]
    @7,719,962us: [+0 T:0x44a8d490 S:0x44a8cd8c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x63638]
    @7,720,101us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x63650] timeout[0xffffffff]
    @7,720,391us: [+0 T:0x41bc8490 S:0x41bc723c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @11,268,119tk: [+5 T:0x8749198c S:0x8749548c] CN - NODE> 0x878d4020(h264dec#0) call(algHandle=0x878d40e0, msg=0x87f04900); messageId=0x0002040b
    [DSP] @11,268,211tk: [+0 T:0x8749198c S:0x87495364] OM - Memory_cacheInv> Enter(addr=0x864ef000, sizeInBytes=1048576)
    [DSP] @11,269,410tk: [+0 T:0x8749198c S:0x87495364] OM - Memory_cacheInv> return
    [DSP] @11,269,457tk: [+0 T:0x8749198c S:0x87495324] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Enter (handle=0x878d40e0, inBufs=0x874953cc, outBufs=0x87495490, inArgs=0x87f04a78, outArgs=0x87f04a84)
    [DSP] @11,269,566tk: [+5 T:0x8749198c S:0x87495304] CV - VISA_enter(visa=0x878d40e0): algHandle = 0x878d4110
    [DSP] @11,269,627tk: [+0 T:0x8749198c S:0x874952e4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Enter(alg=0x878d4110)
    [DSP] @11,269,691tk: [+0 T:0x8749198c S:0x874952e4] ti.sdo.ce.alg.Algorithm - Algorithm_activate> Exit
    [DSP] @11,270,118tk: [+5 T:0x8749198c S:0x87495304] CV - VISA_exit(visa=0x878d40e0): algHandle = 0x878d4110
    [DSP] @11,270,190tk: [+0 T:0x8749198c S:0x874952e4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Enter(alg=0x878d4110)
    [DSP] @11,270,257tk: [+0 T:0x8749198c S:0x874952e4] ti.sdo.ce.alg.Algorithm - Algorithm_deactivate> Exit
    [DSP] @11,270,313tk: [+0 T:0x8749198c S:0x87495324] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x878d40e0, retVal=0xffffffff)
    [DSP] @11,270,406tk: [+5 T:0x8749198c S:0x8749548c] CN - NODE> returned from call(algHandle=0x878d40e0, msg=0x87f04900); messageId=0x0002040b
    [DSP] @12,046,665tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 5
    [DSP] @12,046,722tk: [+0 T:0x8680006c S:0x8680402c] CR - remote time = 0x0, trace buffer size = 4032
    @7,723,013us: [+0 T:0x41bc8490 S:0x41bc7274] CE - Engine_fwriteTrace> returning count [1697]
    @7,723,176us: [+0 T:0x41bc8490 S:0x41bc72f4] CV - VISA_call Completed: messageId=0x0002040b, command=0x0, return(status=-1)
    @7,723,361us: [+5 T:0x41bc8490 S:0x41bc72cc] CV - VISA_freeMsg(0x63090, 0x423d9900): Freeing message with messageId=0x0002040b
    @7,723,517us: [+0 T:0x41bc8490 S:0x41bc7354] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_process> Exit (handle=0x63090, retVal=0xffffffff)
    @7,723,669us: [+2 T:0x41bc8490 S:0x41bc73a4] ti.sdo.dmai - [Vdec2] VIDDEC2_process() ret -1 inId 0 inUse 1 consumed 3534
    @8,057,396us: [+7 T:0x41bc8490 S:0x41bc73a4] ti.sdo.dmai - [Vdec2] VIDDEC2_process() failed with error (-1 ext: 0x8860)
    Error: Failed to decode video buffer
    @8,057,944us: [+0 T:0x41bc8490 S:0x41bc7cd4] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x63620]
    @8,058,136us: [+0 T:0x41bc8490 S:0x41bc7ce4] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x63620]
    @8,058,281us: [+0 T:0x41bc8490 S:0x41bc7cd4] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x63638]
    @8,058,430us: [+0 T:0x41bc8490 S:0x41bc7ce4] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x63638]
    @8,058,569us: [+0 T:0x41bc8490 S:0x41bc7cd4] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x63650]
    @8,058,724us: [+0 T:0x41bc8490 S:0x41bc7ce4] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x63650]
    @8,058,913us: [+0 T:0x44a8d490 S:0x44a8cd7c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x63650] status[0]
    @8,322,976us: [+2 T:0x41bc8490 S:0x41bc7cb4] ti.sdo.dmai - [Buffer] Free Buffer of size 2697152 at 0x43f7d000 (0x864ef000 phys)
    @8,323,217us: [+0 T:0x41bc8490 S:0x41bc7c94] OM - Memory_free> Enter(0x43f7d000, 0x2927c0)
    @8,323,376us: [+0 T:0x41bc8490 S:0x41bc7c5c] OM - Memory_contigFree> Enter(addr=1140314112, size=2697152)
    @8,332,396us: [+1 T:0x41bc8490 S:0x41bc7c34] OM - Memory__removeContigBuf> Enter(virtAddr=0x43f7d000, size=2697152)
    @8,332,583us: [+1 T:0x41bc8490 S:0x41bc7c34] OM - Memory__removeContigBuf> removing cb->phys=0x864ef000, cb->size=0x2927c0, cb->virt=0x43f7d000
    @8,332,743us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_free> Enter(0x635c8, 0x10)
    @8,332,888us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_free> return (0x1)
    @8,333,022us: [+0 T:0x41bc8490 S:0x41bc7c5c] OM - Memory_contigFree> return (0x1)
    @8,333,150us: [+0 T:0x41bc8490 S:0x41bc7c94] OM - Memory_free> return (0x1)
    @8,333,284us: [+0 T:0x41bc8490 S:0x41bc7cc4] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x63620]
    @8,333,453us: [+0 T:0x41bc8490 S:0x41bc7ca4] OM - Memory_free> Enter(0x63620, 0x14)
    @8,333,609us: [+0 T:0x41bc8490 S:0x41bc7ca4] OM - Memory_free> return (0x1)
    @8,333,744us: [+0 T:0x41bc8490 S:0x41bc7cd4] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
    @8,333,870us: [+0 T:0x41bc8490 S:0x41bc7cc4] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x63638]
    @8,334,000us: [+0 T:0x41bc8490 S:0x41bc7ca4] OM - Memory_free> Enter(0x63638, 0x14)
    @8,334,139us: [+0 T:0x41bc8490 S:0x41bc7ca4] OM - Memory_free> return (0x1)
    @8,334,268us: [+0 T:0x41bc8490 S:0x41bc7cd4] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
    @8,334,420us: [+0 T:0x41bc8490 S:0x41bc7cc4] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x63650]
    @8,334,557us: [+0 T:0x41bc8490 S:0x41bc7ca4] OM - Memory_free> Enter(0x63650, 0x14)
    @8,334,696us: [+0 T:0x41bc8490 S:0x41bc7ca4] OM - Memory_free> return (0x1)
    @8,334,827us: [+0 T:0x41bc8490 S:0x41bc7cd4] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
    @8,334,954us: [+0 T:0x41bc8490 S:0x41bc7ce4] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_delete> Enter (handle=0x63090)
    @8,335,096us: [+0 T:0x41bc8490 S:0x41bc7cbc] CV - VISA_delete(0x63090)
    @8,335,227us: [+5 T:0x41bc8490 S:0x41bc7cbc] CV - VISA_delete> deleting codec (localQueue=0x10001, remoteQueue=0x2)
    @8,335,370us: [+0 T:0x41bc8490 S:0x41bc7c8c] OC - Comm_put> Enter(queue=0x2, msg=0x423d9900)
    @8,335,564us: [+0 T:0x41bc8490 S:0x41bc7c8c] OC - Comm_put> return (0)
    @8,335,744us: [+0 T:0x41bc8490 S:0x41bc7c94] OC - Comm_get> Enter(queue=0x10001, msg=0x630d8, timeout=-1)
    @8,336,115us: [+0 T:0x4001f950 S:0xbeb38a54] CE - Engine_close(0x636f8)
    @8,336,311us: [+0 T:0x4001f950 S:0xbeb389bc] OC - Comm_put> Enter(queue=0x0, msg=0x423da900)
    @8,336,524us: [+0 T:0x4001f950 S:0xbeb389bc] OC - Comm_put> return (0)
    @8,336,700us: [+0 T:0x4001f950 S:0xbeb389b4] OC - Comm_get> Enter(queue=0x10002, msg=0xbeb38a54, timeout=-1)
    @8,337,032us: [+0 T:0x41bc8490 S:0x41bc7c94] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @8,337,240us: [+0 T:0x41bc8490 S:0x41bc7c74] CE - Engine_deleteNode(0x62e88)
    @8,337,383us: [+0 T:0x41bc8490 S:0x41bc7c54] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @8,337,578us: [+0 T:0x41bc8490 S:0x41bc7c54] OC - Comm_put> return (0)
    @8,337,723us: [+0 T:0x41bc8490 S:0x41bc7c4c] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7ccc, timeout=-1)
    @8,337,936us: [+0 T:0x4001f950 S:0xbeb389b4] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @13,489,412tk: [+0 T:0x8749198c S:0x8749548c] CN - NODE_EXECFXN(0x878d4020): h264dec#0 exiting per request ...
    [DSP] @13,491,608tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f05928, 4056): cmd = 5
    [DSP] @13,491,663tk: [+0 T:0x8680006c S:0x8680402c] CR - remote time = 0x0, trace buffer size = 4032
    @8,338,624us: [+0 T:0x4001f950 S:0xbeb389ec] CE - Engine_fwriteTrace> returning count [316]
    @8,338,779us: [+0 T:0x4001f950 S:0xbeb38a44] OC - Comm_free> Enter (msg=0x423da900)
    @8,338,952us: [+0 T:0x4001f950 S:0xbeb38a44] OC - Comm_free> return (0)
    @8,339,093us: [+0 T:0x4001f950 S:0xbeb38a34] OC - Comm_delete> Enter (comm=0x63750)
    @8,339,615us: [+0 T:0x4001f950 S:0xbeb38a14] OM - Memory_free> Enter(0x63750, 0x4)
    @8,339,815us: [+0 T:0x4001f950 S:0xbeb38a14] OM - Memory_free> return (0x1)
    @8,339,993us: [+0 T:0x4001f950 S:0xbeb38a54] OC - Comm_delete> return
    @8,340,133us: [+0 T:0x4001f950 S:0xbeb38a44] OC - Comm_release> Enter(queue=0x0)
    @8,675,765us: [+0 T:0x41bc8490 S:0x41bc7c4c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    @8,675,957us: [+5 T:0x41bc8490 S:0x41bc7c74] CE - Engine_deleteNode(0x62e88): algName = h264dec, algHandle = 0x878d40e0, stack size = 13096, stack used = 1335(11%)
    @8,676,134us: [+0 T:0x41bc8490 S:0x41bc7c4c] OC - Comm_delete> Enter (comm=0x630c8)
    @8,676,542us: [+0 T:0x41bc8490 S:0x41bc7c2c] OM - Memory_free> Enter(0x630c8, 0x4)
    @8,676,736us: [+0 T:0x41bc8490 S:0x41bc7c2c] OM - Memory_free> return (0x1)
    @8,676,881us: [+0 T:0x41bc8490 S:0x41bc7c6c] OC - Comm_delete> return
    @8,677,011us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_free> Enter(0x62e88, 0x20)
    @8,677,153us: [+0 T:0x41bc8490 S:0x41bc7c54] OM - Memory_free> return (0x1)
    @8,677,286us: [+0 T:0x41bc8490 S:0x41bc7cac] OC - Comm_free> Enter (msg=0x423d9900)
    @8,677,452us: [+0 T:0x41bc8490 S:0x41bc7cac] OC - Comm_free> return (0)
    @8,677,589us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_free> Enter(0x630d8, 0x4)
    @8,677,732us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_free> return (0x1)
    @8,677,866us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_free> Enter(0x63090, 0x30)
    @8,678,003us: [+0 T:0x41bc8490 S:0x41bc7c9c] OM - Memory_free> return (0x1)
    @8,678,134us: [+0 T:0x41bc8490 S:0x41bc7cf4] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_delete> return
    @8,678,268us: [+0 T:0x41bc8490 S:0x41bc7ce4] CE - Engine_close(0x62ab0)
    @8,678,412us: [+0 T:0x41bc8490 S:0x41bc7c4c] OC - Comm_put> Enter(queue=0x0, msg=0x423d8900)
    @8,678,643us: [+0 T:0x41bc8490 S:0x41bc7c4c] OC - Comm_put> return (0)
    @8,678,826us: [+0 T:0x41bc8490 S:0x41bc7c44] OC - Comm_get> Enter(queue=0x10000, msg=0x41bc7ce4, timeout=-1)
    @8,679,041us: [+0 T:0x4001f950 S:0xbeb38a44] OC - Comm_release> return (0)
    @8,679,206us: [+0 T:0x4001f950 S:0xbeb38a54] CE - rserverClose(0x60f30), count = 2
    @8,679,348us: [+0 T:0x4001f950 S:0xbeb38a54] CE - rserverClose(0x60f30) done.
    @8,679,605us: [+0 T:0x4001f950 S:0xbeb38a54] OM - Memory_free> Enter(0x636f8, 0x2c)
    @8,679,763us: [+0 T:0x4001f950 S:0xbeb38a54] OM - Memory_free> return (0x1)
    @8,680,118us: [+0 T:0x41bc8490 S:0x41bc7c44] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
    [DSP] @13,494,053tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 2
    [DSP] @13,494,481tk: [+0 T:0x8680006c S:0x86803fe4] CN - NODE_delete(0x878d4020): h264dec#0
    [DSP] @13,494,549tk: [+0 T:0x8680006c S:0x86803fc4] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_delete> Enter (handle=0x878d40e0)
    [DSP] @13,494,611tk: [+0 T:0x8680006c S:0x86803f94] CV - VISA_delete(0x878d40e0)
    [DSP] @13,494,659tk: [+5 T:0x8680006c S:0x86803f94] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
    [DSP] @13,494,721tk: [+5 T:0x8680006c S:0x86803f94] CV - VISA_delete> deleting codec 0x878d4110
    [DSP] @13,494,773tk: [+0 T:0x8680006c S:0x86803f74] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0x878d4110)
    [DSP] @13,494,996tk: [+0 T:0x8680006c S:0x86803eb4] ti.sdo.ce.osal.Sem - Sem_delete> sem: 0x87491aec
    [DSP] @13,495,283tk: [+0 T:0x8680006c S:0x86803f44] OM - Memory_free> Enter(addr=0x878d4110, size=16)
    [DSP] @13,495,345tk: [+0 T:0x8680006c S:0x86803f44] OM - Memory_free> return (0x1)
    [DSP] @13,495,390tk: [+0 T:0x8680006c S:0x86803f74] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Exit
    [DSP] @13,495,441tk: [+0 T:0x8680006c S:0x86803f64] OM - Memory_free> Enter(addr=0x878d40e0, size=48)
    [DSP] @13,495,497tk: [+0 T:0x8680006c S:0x86803f64] OM - Memory_free> return (0x1)
    [DSP] @13,495,543tk: [+0 T:0x8680006c S:0x86803fc4] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_delete> return
    [DSP] @13,495,625tk: [+0 T:0x8680006c S:0x86803fac] OM - Memory_free> Enter(addr=0x878d4040, size=36)
    [DSP] @13,495,684tk: [+0 T:0x8680006c S:0x86803fac] OM - Memory_free> return (0x1)
    [DSP] @13,495,731tk: [+0 T:0x8680006c S:0x86803fb4] OM - Memory_free> Enter(addr=0x878d4020, size=32)
    [DSP] @13,495,786tk: [+0 T:0x8680006c S:0x86803fb4] OM - Memory_free> return (0x1)
    [DSP] @13,495,832tk: [+0 T:0x8680006c S:0x86803fd4] OM - Memory_free> Enter(addr=0x878d4010, size=10)
    [DSP] @13,495,889tk: [+0 T:0x8680006c S:0x86803fd4] OM - Memory_free> return (0x1)
    [DSP] @13,495,934tk: [+0 T:0x8680006c S:0x86803fd4] OM - Memory_free> Enter(addr=0x878d3ff8, size=24)
    [DSP] @13,495,990tk: [+0 T:0x8680006c S:0x86803fd4] OM - Memory_free> return (0x1)
    [DSP] @14,285,440tk: [+0 T:0x8680006c S:0x8680402c] CR - processRmsCmd(0x87f03928, 4056): cmd = 5
    [DSP] @14,285,500tk: [+0 T:0x8680006c S:0x8680402c] CR - remote time = 0x0, trace buffer size = 4032
    @9,017,948us: [+0 T:0x41bc8490 S:0x41bc7c7c] CE - Engine_fwriteTrace> returning count [2344]
    @9,018,112us: [+0 T:0x41bc8490 S:0x41bc7cd4] OC - Comm_free> Enter (msg=0x423d8900)
    @9,018,288us: [+0 T:0x41bc8490 S:0x41bc7cd4] OC - Comm_free> return (0)
    @9,018,429us: [+0 T:0x41bc8490 S:0x41bc7cc4] OC - Comm_delete> Enter (comm=0x62eb0)
    @9,018,835us: [+0 T:0x41bc8490 S:0x41bc7ca4] OM - Memory_free> Enter(0x62eb0, 0x4)
    @9,019,028us: [+0 T:0x41bc8490 S:0x41bc7ca4] OM - Memory_free> return (0x1)
    @9,019,174us: [+0 T:0x41bc8490 S:0x41bc7ce4] OC - Comm_delete> return
    @9,019,308us: [+0 T:0x41bc8490 S:0x41bc7cd4] OC - Comm_release> Enter(queue=0x0)
    @9,019,572us: [+0 T:0x41bc8490 S:0x41bc7cd4] OC - Comm_release> return (0)
    @9,019,749us: [+0 T:0x41bc8490 S:0x41bc7ce4] CE - rserverClose(0x60f30), count = 1
    @9,019,896us: [+0 T:0x41bc8490 S:0x41bc7ccc] OP - Processor_delete> Enter(proc=0x62ae0)
    @9,020,032us: [+0 T:0x41bc8490 S:0x41bc7cac] OP - doCmd> Enter (cmdId=2, proc=0x62ae0)
    @9,020,168us: [+0 T:0x41bc8490 S:0x41bc7c9c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x621c0]
    @9,020,331us: [+0 T:0x41bc8490 S:0x41bc7cac] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x621c0]
    @9,020,477us: [+0 T:0x41bc8490 S:0x41bc7c8c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x621d8] timeout[0xffffffff]
    @9,020,665us: [+0 T:0x40bc8490 S:0x40bc7d54] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x621c0] status[0]
    @9,020,828us: [+0 T:0x40bc8490 S:0x40bc7d74] OP - getCmd_d> Exit (result=2)
    @9,020,968us: [+0 T:0x40bc8490 S:0x40bc7d5c] OP - Processor_delete_d> Enter (proc=0x62ae0)
    @9,021,106us: [+2 T:0x40bc8490 S:0x40bc7d5c] OP - Processor_delete_d> Closing remote transport...
    @9,021,571us: [+2 T:0x40bc8490 S:0x40bc7d5c] OP - Processor_delete_d> Stopping DSP...
    @9,021,830us: [+2 T:0x40bc8490 S:0x40bc7d5c] OP - Processor_delete_d> Closing pool...
    @9,022,441us: [+2 T:0x40bc8490 S:0x40bc7d5c] OP - Processor_delete_d> Detaching from DSP...
    @9,027,619us: [+2 T:0x40bc8490 S:0x40bc7d5c] OP - Processor_delete_d> Destroying DSP... (object, that is)
    @9,028,686us: [+0 T:0x40bc8490 S:0x40bc7d3c] OM - Memory_free> Enter(0x62b08, 0x0)
    @9,028,883us: [+0 T:0x40bc8490 S:0x40bc7d3c] OM - Memory_free> return (0x1)
    @9,029,033us: [+0 T:0x40bc8490 S:0x40bc7d74] OP - Processor_delete_d> return
    @9,029,174us: [+0 T:0x40bc8490 S:0x40bc7d64] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x621d8]
    @9,029,441us: [+0 T:0x41bc8490 S:0x41bc7c8c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x621d8] status[0]
    @9,029,618us: [+0 T:0x41bc8490 S:0x41bc7cac] OP - doCmd> Exit (result=1)
    @9,029,759us: [+1 T:0x41bc8490 S:0x41bc7ccc] OP - Processor_delete(0x62ae0) freeing object ...
    @9,029,898us: [+0 T:0x41bc8490 S:0x41bc7cac] OM - Memory_free> Enter(0x62ae0, 0x24)
    @9,030,038us: [+0 T:0x41bc8490 S:0x41bc7cac] OM - Memory_free> return (0x1)
    @9,030,171us: [+0 T:0x41bc8490 S:0x41bc7ce4] OP - Processor_delete> return.
    @9,030,299us: [+0 T:0x41bc8490 S:0x41bc7ce4] CE - rserverClose(0x60f30) done.
    @9,030,429us: [+0 T:0x41bc8490 S:0x41bc7ce4] OM - Memory_free> Enter(0x62ab0, 0x2c)
    @9,030,566us: [+0 T:0x41bc8490 S:0x41bc7ce4] OM - Memory_free> return (0x1)
    @9,030,702us: [+2 T:0x41bc8490 S:0x41bc7c94] ti.sdo.dmai - [Buffer] Free Buffer of size 3211776 at 0x43028000 (0x861de000 phys)
    @9,363,919us: [+0 T:0x41bc8490 S:0x41bc7c74] OM - Memory_free> Enter(0x43028000, 0x310200)
    @9,364,099us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_contigFree> Enter(addr=1124237312, size=3211776)
    @9,373,127us: [+1 T:0x41bc8490 S:0x41bc7c14] OM - Memory__removeContigBuf> Enter(virtAddr=0x43028000, size=3211776)
    @9,373,315us: [+1 T:0x41bc8490 S:0x41bc7c14] OM - Memory__removeContigBuf> removing cb->phys=0x861de000, cb->size=0x310200, cb->virt=0x43028000
    @9,373,475us: [+0 T:0x41bc8490 S:0x41bc7c1c] OM - Memory_free> Enter(0x63188, 0x10)
    @9,373,619us: [+0 T:0x41bc8490 S:0x41bc7c1c] OM - Memory_free> return (0x1)
    @9,373,752us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_contigFree> return (0x1)
    @9,373,883us: [+0 T:0x41bc8490 S:0x41bc7c74] OM - Memory_free> return (0x1)
    @9,374,019us: [+2 T:0x41bc8490 S:0x41bc7c94] ti.sdo.dmai - [Buffer] Free Buffer of size 3211776 at 0x43339000 (0x85ecd000 phys)
    @9,374,166us: [+0 T:0x41bc8490 S:0x41bc7c74] OM - Memory_free> Enter(0x43339000, 0x310200)
    @9,374,305us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_contigFree> Enter(addr=1127452672, size=3211776)
    @9,383,308us: [+1 T:0x41bc8490 S:0x41bc7c14] OM - Memory__removeContigBuf> Enter(virtAddr=0x43339000, size=3211776)
    @9,383,520us: [+1 T:0x41bc8490 S:0x41bc7c14] OM - Memory__removeContigBuf> removing cb->phys=0x85ecd000, cb->size=0x310200, cb->virt=0x43339000
    @9,383,681us: [+0 T:0x41bc8490 S:0x41bc7c1c] OM - Memory_free> Enter(0x63210, 0x10)
    @9,383,825us: [+0 T:0x41bc8490 S:0x41bc7c1c] OM - Memory_free> return (0x1)
    @9,383,956us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_contigFree> return (0x1)
    @9,384,085us: [+0 T:0x41bc8490 S:0x41bc7c74] OM - Memory_free> return (0x1)
    @9,384,221us: [+2 T:0x41bc8490 S:0x41bc7c94] ti.sdo.dmai - [Buffer] Free Buffer of size 3211776 at 0x4364a000 (0x85bbc000 phys)
    @9,384,367us: [+0 T:0x41bc8490 S:0x41bc7c74] OM - Memory_free> Enter(0x4364a000, 0x310200)
    @9,384,503us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_contigFree> Enter(addr=1130668032, size=3211776)
    @9,393,517us: [+1 T:0x41bc8490 S:0x41bc7c14] OM - Memory__removeContigBuf> Enter(virtAddr=0x4364a000, size=3211776)
    @9,393,707us: [+1 T:0x41bc8490 S:0x41bc7c14] OM - Memory__removeContigBuf> removing cb->phys=0x85bbc000, cb->size=0x310200, cb->virt=0x4364a000
    @9,393,869us: [+0 T:0x41bc8490 S:0x41bc7c1c] OM - Memory_free> Enter(0x63298, 0x10)
    @9,394,012us: [+0 T:0x41bc8490 S:0x41bc7c1c] OM - Memory_free> return (0x1)
    @9,394,145us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_contigFree> return (0x1)
    @9,394,276us: [+0 T:0x41bc8490 S:0x41bc7c74] OM - Memory_free> return (0x1)
    @9,394,409us: [+2 T:0x41bc8490 S:0x41bc7c94] ti.sdo.dmai - [Buffer] Free Buffer of size 3211776 at 0x4395b000 (0x858ab000 phys)
    @9,394,555us: [+0 T:0x41bc8490 S:0x41bc7c74] OM - Memory_free> Enter(0x4395b000, 0x310200)
    @9,394,724us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_contigFree> Enter(addr=1133883392, size=3211776)
    @9,403,755us: [+1 T:0x41bc8490 S:0x41bc7c14] OM - Memory__removeContigBuf> Enter(virtAddr=0x4395b000, size=3211776)
    @9,403,941us: [+1 T:0x41bc8490 S:0x41bc7c14] OM - Memory__removeContigBuf> removing cb->phys=0x858ab000, cb->size=0x310200, cb->virt=0x4395b000
    @9,404,098us: [+0 T:0x41bc8490 S:0x41bc7c1c] OM - Memory_free> Enter(0x63320, 0x10)
    @9,404,246us: [+0 T:0x41bc8490 S:0x41bc7c1c] OM - Memory_free> return (0x1)
    @9,404,379us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_contigFree> return (0x1)
    @9,404,508us: [+0 T:0x41bc8490 S:0x41bc7c74] OM - Memory_free> return (0x1)
    @9,404,643us: [+2 T:0x41bc8490 S:0x41bc7c94] ti.sdo.dmai - [Buffer] Free Buffer of size 3211776 at 0x43c6c000 (0x85289000 phys)
    @9,404,791us: [+0 T:0x41bc8490 S:0x41bc7c74] OM - Memory_free> Enter(0x43c6c000, 0x310200)
    @9,404,925us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_contigFree> Enter(addr=1137098752, size=3211776)
    @9,413,932us: [+1 T:0x41bc8490 S:0x41bc7c14] OM - Memory__removeContigBuf> Enter(virtAddr=0x43c6c000, size=3211776)
    @9,414,118us: [+1 T:0x41bc8490 S:0x41bc7c14] OM - Memory__removeContigBuf> removing cb->phys=0x85289000, cb->size=0x310200, cb->virt=0x43c6c000
    @9,414,307us: [+0 T:0x41bc8490 S:0x41bc7c1c] OM - Memory_free> Enter(0x633a8, 0x10)
    @9,414,457us: [+0 T:0x41bc8490 S:0x41bc7c1c] OM - Memory_free> return (0x1)
    @9,414,591us: [+0 T:0x41bc8490 S:0x41bc7c3c] OM - Memory_contigFree> return (0x1)
    @9,414,720us: [+0 T:0x41bc8490 S:0x41bc7c74] OM - Memory_free> return (0x1)
    @9,750,175us: [+0 T:0x40bc8490 S:0x40bc7d74] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x621d8]
    @9,750,378us: [+0 T:0x40bc8490 S:0x40bc7d74] OP - getCmd_d> Enter (proc=0x40bc7de8)
    @9,750,530us: [+0 T:0x40bc8490 S:0x40bc7d54] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x621c0] timeout[0xffffffff]
    @9,751,018us: [+0 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> enter
    @9,751,197us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x13994()...
    @9,751,371us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x26d44()...
    @9,751,524us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x28a64()...
    @9,751,666us: [+0 T:0x4001f950 S:0xbeb38a7c] OM - Memory_free> Enter(0x62430, 0x18)
    @9,751,811us: [+0 T:0x4001f950 S:0xbeb38a7c] OM - Memory_free> return (0x1)
    @9,751,947us: [+0 T:0x4001f950 S:0xbeb38a7c] OM - Memory_free> Enter(0x62450, 0x18)
    @9,752,084us: [+0 T:0x4001f950 S:0xbeb38a7c] OM - Memory_free> return (0x1)
    @9,752,219us: [+0 T:0x4001f950 S:0xbeb38a7c] OM - Memory_free> Enter(0x62470, 0x18)
    @9,752,359us: [+0 T:0x4001f950 S:0xbeb38a7c] OM - Memory_free> return (0x1)
    @9,752,494us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x31108()...
    @9,752,633us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x2b5d0()...
    @9,752,806us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x2c1a4()...
    @9,752,950us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x2e8dc()...
    @9,753,087us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x2c558()...
    @9,753,226us: [+0 T:0x4001f950 S:0xbeb38a7c] OP - doCmd> Enter (cmdId=3, proc=0x0)
    @9,753,359us: [+0 T:0x4001f950 S:0xbeb38a6c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x621c0]
    @9,753,519us: [+0 T:0x4001f950 S:0xbeb38a7c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x621c0]
    @9,753,665us: [+0 T:0x4001f950 S:0xbeb38a5c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x621d8] timeout[0xffffffff]
    @9,753,851us: [+0 T:0x40bc8490 S:0x40bc7d54] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x621c0] status[0]
    @9,754,014us: [+0 T:0x40bc8490 S:0x40bc7d74] OP - getCmd_d> Exit (result=3)
    @9,754,156us: [+0 T:0x40bc8490 S:0x40bc7d64] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x621d8]
    @9,754,319us: [+0 T:0x40bc8490 S:0x40bc7d74] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x621d8]
    @9,754,680us: [+0 T:0x4001f950 S:0xbeb38a5c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x621d8] status[0]
    @9,754,866us: [+0 T:0x4001f950 S:0xbeb38a7c] OP - doCmd> Exit (result=1)
    @9,755,007us: [+0 T:0x4001f950 S:0xbeb38a84] OT - Thread_delete> Enter (task=0x62210)
    @9,755,198us: [+4 T:0x4001f950 S:0xbeb38a84] OT - Thread_delete> pthread_cancel (0x3)
    @9,755,360us: [+4 T:0x4001f950 S:0xbeb38a84] OT - Thread_delete> pthread_join (0x0)
    @9,755,504us: [+0 T:0x4001f950 S:0xbeb38a64] OM - Memory_free> Enter(0x62210, 0x64)
    @9,755,687us: [+0 T:0x4001f950 S:0xbeb38a64] OM - Memory_free> return (0x1)
    @9,755,825us: [+0 T:0x4001f950 S:0xbeb38a9c] OT - Thread_delete> Exit (task=0x62210)
    @9,755,960us: [+0 T:0x4001f950 S:0xbeb38a8c] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x621c0]
    @9,756,095us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_free> Enter(0x621c0, 0x14)
    @9,756,238us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_free> return (0x1)
    @9,756,369us: [+0 T:0x4001f950 S:0xbeb38a9c] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
    @9,756,496us: [+0 T:0x4001f950 S:0xbeb38a8c] ti.sdo.ce.osal.Sem - Entered Sem_delete> sem[0x621d8]
    @9,756,630us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_free> Enter(0x621d8, 0x14)
    @9,756,771us: [+0 T:0x4001f950 S:0xbeb38a6c] OM - Memory_free> return (0x1)
    @9,756,904us: [+0 T:0x4001f950 S:0xbeb38a9c] ti.sdo.ce.osal.Sem - Leaving Sem_delete>
    @9,757,035us: [+0 T:0x4001f950 S:0xbeb38a7c] OM - Memory_free> Enter(0x621f0, 0x18)
    @9,757,177us: [+0 T:0x4001f950 S:0xbeb38a7c] OM - Memory_free> return (0x1)
    @10,091,297us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x30c18()...
    @10,091,512us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x2e390()...
    @10,091,675us: [+0 T:0x4001f950 S:0xbeb38a8c] OM - Memory_free> Enter(0x62140, 0x18)
    @10,091,825us: [+0 T:0x4001f950 S:0xbeb38a8c] OM - Memory_free> return (0x1)
    @10,091,964us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x2f4e4()...
    @10,092,139us: [+0 T:0x4001f950 S:0xbeb38a7c] OM - Memory_free> Enter(0x620f0, 0x18)
    @10,092,295us: [+0 T:0x4001f950 S:0xbeb38a7c] OM - Memory_free> return (0x1)
    @10,092,438us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x315b4()...
    @10,092,579us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x32168()...
    @10,092,719us: [+2 T:0x4001f950 S:0xbeb38aac] OG - Global_exit> calling function *0x31514()...
  • It looks like the process is failing with extended error code of 0x8860. The low 8-bit LSB as per the codec user guide (page 4-21) implies it is H264D_ERR_IMPL_PPSUNAVAIL eror i.e valid PPS not available. Since this is fatal error, the decoding is terminated. Can you make sure there is valid PPS available for the stream?
  • Yes,I have delete the sps and pps from the header of the stream,if every frame need the correct pps and sps?
  • Every frame does not require a SPS/PPS. But we need a SPS/PPS at the beginning of the sequence to start decoding. Are you stripping out the SPS/PPS at the beginning of the stream?
    Kapil
  • Yes,I stripping out the sps/pps at the beginning of the stream.
    'But we need a SPS/PPS at the beginning of the sequence to start decoding'.You means at the beginning of every sequence in h264 stream we need a SPS/PPS,or the whole 264 stream only need one SPS/PPS?
  • Hi David,
    In H.264 codec every frame in a sequence refers to an PPS and every PPS refers to an SPS. In case the SPS or PPS is missing for a sequence, the frames cannot be decoded. The H.264 decoder will discard the frames with missing SPS and PPS and proceed till it finds valid SPS PPS headers.
    I guess in the bitstream you are using, there is only 1 SPS and PPS. If you remove just the IDR frame and keep the SPS and PPS headers, the decoder should have no problem decoding the frames. Or try a bitstream with multiple SPS and PPS at different intervals, it should work fine without an IDR frame.
    Shyam
