How to change I2C frequency from 400KHz to 100KHz?
Is the below right? Should I modify others?
Before:
#define PSP_I2C_MAX_BUS_FREQ (400000u) /* 400 KHz */
Current:
#define PSP_I2C_MAX_BUS_FREQ (100000u) /* 100 KHz */
Before:
Current:
Can you provide more information like which device you are refering to.
Assuming that you are refering to C5515 device & to set I2C serial clock frequency to 100Khz you need to do appropriate configuration using the below mentioned formula.
SCL low period = (SYSCLK period) * (IPSC + 1) * (ICCL + d)
SCL high period = (SYSCLK period) * (IPSC + 1) * (ICCH + d)
Based on your system clock frequency you need to configure IPSC , ICCL, ICCH values appropriately to acheive 100KHz serial frequency.This is also explained in respective I2C userguide.
Hope the above information helps.
Vasanth
