timestamp in Non-AVsync application
Guru 20755 points
I would like to ask a general question regarding timestamp.
I have 2 scenarios :
1. TI's  H.264 encoding of video only (no audio) and muxing it to TS (mpeg-ts)
2. demuxing of mpeg-ts (was encoded by some other encoder - not TI's) and decoding video only (no audio) using TI's H.264 decoder
Our application does not require AVsync (there is no audio)
Do you think I need in the 1st scenario to generate PTS from codec output into stream ? and in the 2ns scenario do I need to retrieve PTS from TS and use it in TI's codec ?
Thank you,
Ran
  • Hello Ran,
    If you are using EZSDK:
    1.In EZSDK you could archive this by using gstreamer. You could use mpegtsmux element. Here is example pipeline for encoding and muxing in ts container:
    ...... ! omx_h264enc ! mpegtsmux  ! filesink location=test.tsmux
    2. You could try to use and omx encode demo(I have not try this). You could try to build the ffmpeg for arm. In ffmpeg package there is a example for muxing but in this exmaple it uses the ffmpeg codecs you could try to change it to use our h264 codec.
    Same as the previous answers but reversed. You could use gstreamer.
    gst-launch filesrc location=test.tsmux ! mpegtsdemux ! h264parse access-unit=true ! omx_h264dec ! omx_scaler ! omx_ctrl display-mode=OMX_DC_MODE_1080P_60  ! gstperf ! omx_videosink
    BR
    Margarita
  • Thank you,
    I'm familiar with most of this solutions,
    But I still wander what is required to do with timestamp in the mpeg-ts stream. Do we need to read PTS DST, from it when decoding and do we need to insert PTS,DTS to mpeg-ts when encoding ? (Non-audio stream).
    Ran
