HI:
I have run through the videnc_copy example in $(CE_installpath)/examples/ti/sdo/ce/exampls/codecs/videnc_copy under the EZSDK enviroments ,and created files videnc_copy.a64P,videnc_copy.ae64P,videnc_copy.a674 and etc in /lib, and also the package file dir.
then,I tried to build the corresponding dsp_server under the path $(CE_installpath)/examples/ti/sdo/ce/exampls/all_codecs,which I've changed into the name videnc_copy, at the same time, ralated config files was also changed in order to make my videnc_copy server.
however,when I run the make command under this path,errors occured like following:
root@ubuntu:/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy# make
"/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/xdc" --jobs=1 \
XDCBUILDCFG=_config.bld \
XDCPATH="/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy/../../../../../..;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;/usr/local/ezsdk/component-sources/xdais_7_22_00_03/packages;/usr/local/ezsdk/component-sources/bios_6_33_05_46/packages;/usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages;/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages;/usr/local/ezsdk/component-sources/osal_1_22_01_09/packages;/usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages;/usr/local/ezsdk/component-sources/edma3lld_02_11_05_02/packages;/usr/local/ezsdk/component-sources/ipc_1_24_03_32/packages;/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/packages" \
XDCOPTIONS=v XDCARGS="DEVICE=\"TI816X\" PROGRAMS=\"APP_CLIENT DSP_SERVER\" GPPOS=\"LINUX_GCC\" ti.targets.C64P=\"/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4\" ti.targets.C674=\"/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4\" ti.targets.arm.elf.M3=\"\" ti.targets.elf.C64P=\"/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4\" ti.targets.elf.C64T=\"/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4\" ti.targets.elf.C66=\"/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4\" ti.targets.elf.C674=\"/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4\" gnu.targets.arm.GCArmv5T=\"/root/CodeSourcery/Sourcery_G++_Lite/;LONGNAME=bin/arm-none-linux-gnueabi-gcc;profiles.release.compileOpts.copts=-O2 -ffunction-sections\" google.targets.arm.Bionic=\";LONGNAME=;libcDir=;fsDir=\"" all -PD .
making all: Tue Apr 21 16:23:22 CST 2015 ...
======== .interfaces [/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy] ========
# making package.mak (because of package.bld) ...
/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/xs -Dxdc.path="/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy/../../../../../..;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;/usr/local/ezsdk/component-sources/xdais_7_22_00_03/packages;/usr/local/ezsdk/component-sources/bios_6_33_05_46/packages;/usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages;/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages;/usr/local/ezsdk/component-sources/osal_1_22_01_09/packages;/usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages;/usr/local/ezsdk/component-sources/edma3lld_02_11_05_02/packages;/usr/local/ezsdk/component-sources/ipc_1_24_03_32/packages;/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/packages;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;../../../../../.." -Dxdc.root=/usr/local/ezsdk/component-sources/xdctools_3_23_03_53 -Dxdc.hostOS=Linux -Dconfig.importPath=".;/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy/../../../../../..;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;/usr/local/ezsdk/component-sources/xdais_7_22_00_03/packages;/usr/local/ezsdk/component-sources/bios_6_33_05_46/packages;/usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages;/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages;/usr/local/ezsdk/component-sources/osal_1_22_01_09/packages;/usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages;/usr/local/ezsdk/component-sources/edma3lld_02_11_05_02/packages;/usr/local/ezsdk/component-sources/ipc_1_24_03_32/packages;/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/packages;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;../../../../../..;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/etc" -Dxdc.bld.targets="" -DTOOLS= -f /usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages/xdc/bld/bld.js /usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy/_config.bld package.bld package.mak DEVICE="TI816X" PROGRAMS="APP_CLIENT DSP_SERVER" GPPOS="LINUX_GCC" ti.targets.C64P="/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4" ti.targets.C674="/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4" ti.targets.arm.elf.M3="" ti.targets.elf.C64P="/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4" ti.targets.elf.C64T="/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4" ti.targets.elf.C66="/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4" ti.targets.elf.C674="/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4" gnu.targets.arm.GCArmv5T="/root/CodeSourcery/Sourcery_G++_Lite/;LONGNAME=bin/arm-none-linux-gnueabi-gcc;profiles.release.compileOpts.copts=-O2 -ffunction-sections" google.targets.arm.Bionic=";LONGNAME=;libcDir=;fsDir="
Building 'ti.targets.C64P' using '/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4' ...
Building 'ti.targets.C674' using '/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4' ...
Building 'ti.targets.elf.C64P' using '/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4' ...
Building 'ti.targets.elf.C64T' using '/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4' ...
Building 'ti.targets.elf.C66' using '/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4' ...
Building 'ti.targets.elf.C674' using '/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4' ...
Building 'gnu.targets.arm.GCArmv5T' using '/root/CodeSourcery/Sourcery_G++_Lite/' ...
Configuring target.LONGNAME = bin/arm-none-linux-gnueabi-gcc
Configuring target.profiles.release.compileOpts.copts = -O2 -ffunction-sections
exe name = 'bin/ti_platforms_sim6xxx/videnc_copy_TMS320CDM420'
exe name = 'bin/ti_platforms_evmDA830/videnc_copy'
exe name = 'bin/ti_platforms_simTCI6616/videnc_copy'
exe name = 'bin/ti_platforms_evmTI816X/videnc_copy_DSP'
# generating interfaces for package ti.sdo.ce.examples.servers.videnc_copy (because package/package.xdc.inc is older than package.xdc) ...
/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/xs -Dxdc.path="/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy/../../../../../..;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;/usr/local/ezsdk/component-sources/xdais_7_22_00_03/packages;/usr/local/ezsdk/component-sources/bios_6_33_05_46/packages;/usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages;/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages;/usr/local/ezsdk/component-sources/osal_1_22_01_09/packages;/usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages;/usr/local/ezsdk/component-sources/edma3lld_02_11_05_02/packages;/usr/local/ezsdk/component-sources/ipc_1_24_03_32/packages;/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/packages;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;../../../../../.." -Dxdc.root=/usr/local/ezsdk/component-sources/xdctools_3_23_03_53 -Dxdc.hostOS=Linux -Dconfig.importPath=".;/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy/../../../../../..;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;/usr/local/ezsdk/component-sources/xdais_7_22_00_03/packages;/usr/local/ezsdk/component-sources/bios_6_33_05_46/packages;/usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages;/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages;/usr/local/ezsdk/component-sources/osal_1_22_01_09/packages;/usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages;/usr/local/ezsdk/component-sources/edma3lld_02_11_05_02/packages;/usr/local/ezsdk/component-sources/ipc_1_24_03_32/packages;/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/packages;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;../../../../../..;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/etc" -Dxdc.bld.targets="" -DTOOLS= -f xdc/services/intern/cmd/build.xs -m package/package.xdc.dep -i package/package.xdc.inc package.xdc
.interfaces files complete: Tue Apr 21 16:23:27 CST 2015.
======== .libraries [/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy] ========
.libraries files complete: Tue Apr 21 16:23:27 CST 2015.
======== .dlls [/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy] ========
# configuring bin/ti_platforms_sim6xxx/videnc_copy_TMS320CDM420.x64P from package/cfg/bin/ti_platforms_sim6xxx/videnc_copy_TMS320CDM420_p64P.cfg ...
/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/xs -Dxdc.path="/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy/../../../../../..;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;/usr/local/ezsdk/component-sources/xdais_7_22_00_03/packages;/usr/local/ezsdk/component-sources/bios_6_33_05_46/packages;/usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages;/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages;/usr/local/ezsdk/component-sources/osal_1_22_01_09/packages;/usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages;/usr/local/ezsdk/component-sources/edma3lld_02_11_05_02/packages;/usr/local/ezsdk/component-sources/ipc_1_24_03_32/packages;/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/packages;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;../../../../../.." -Dxdc.root=/usr/local/ezsdk/component-sources/xdctools_3_23_03_53 -Dxdc.hostOS=Linux -Dconfig.importPath=".;/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy/../../../../../..;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;/usr/local/ezsdk/component-sources/xdais_7_22_00_03/packages;/usr/local/ezsdk/component-sources/bios_6_33_05_46/packages;/usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages;/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages;/usr/local/ezsdk/component-sources/osal_1_22_01_09/packages;/usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages;/usr/local/ezsdk/component-sources/edma3lld_02_11_05_02/packages;/usr/local/ezsdk/component-sources/ipc_1_24_03_32/packages;/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/packages;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/packages;../../../../../..;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53;/usr/local/ezsdk/component-sources/xdctools_3_23_03_53/etc" -Dxdc.bld.targets="" -DTOOLS= xdc.cfg bin/ti_platforms_sim6xxx/videnc_copy_TMS320CDM420.x64P package/cfg/bin/ti_platforms_sim6xxx/videnc_copy_TMS320CDM420_p64P.cfg package/cfg/bin/ti_platforms_sim6xxx/videnc_copy_TMS320CDM420_p64P
js: "./heaps.cfg", line 60: TypeError: Cannot read property "len" from undefined
"./all_syslink.cfg", line 42
"./package/cfg/bin/ti_platforms_sim6xxx/videnc_copy_TMS320CDM420_p64P.cfg", line 195
"./package/cfg/bin/ti_platforms_sim6xxx/videnc_copy_TMS320CDM420_p64P.cfg", line 274
"./package/cfg/bin/ti_platforms_sim6xxx/videnc_copy_TMS320CDM420_p64P.cfg", line 182
gmake[1]: *** [package/cfg/bin/ti_platforms_sim6xxx/videnc_copy_TMS320CDM420_p64P.xdl] Error 1
gmake: *** [/usr/local/ezsdk/component-sources/codec_engine_3_22_01_06/examples/ti/sdo/ce/examples/servers/videnc_copy,.dlls] Error 2
make: *** [all] Error 2
Why does these happened?
Please anyone help me ?
Thank you!
