request help install TI-Android-JB-4.2.2-DevKit-4.1.1
I can not install this version of Android Beagle bone black version C, with LCD 4d cape 43T.
I read on many sites that many people have this problem, the script fails mkmmc-android.sh installation, so I will not create any partition.
I use ubuntu and an external SD card reader.
I also tried to make the partitions with Gparted and manually copy the files, LCD but no signs of life.
At the moment I have not found answers on the forum.
someone can help me I read that many have this problem.
    Can you please post your question on the dedicated Android forum: e2e.ti.com/.../509 ?
    Yordan
  • Moving this thread to the Android forum.
  • thanks
    sorry. I am new to this forum
  • thanks for the reply.
    <<<I'm trying with 3 sd card (micro sd 8GB SanDisk Ultra, Transcend 8GB / 4GB)
    I have Ubuntu on a virtual machine installed on windows 8
    in order I executed the following commands: >>>
    paolo@ubuntu:/media/paolo/boot$ sudo fdisk -l
    Disk /dev/sda: 21.5 GB, 21474836480 bytes
    255 heads, 63 sectors / track, 2610 cylinders, total 41,943,040 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    ID disk: 0x000429cc
    device Boot Start End Blocks Id System
    /dev/sda1 * 2048 39845887 19921920 83 Linux
    /dev/sda2 39847934 41940991 1046529 5 Esteso
    /dev/sda5 39847936 41940991 1046528 82 Linux swap / Solaris
    device /dev/sdc: 7746 MB, 7746879488 byte
    214 heads, 40 sectors / track, 1767 cylinders, total 15,130,624 sectors
    ID disk: 0x0008c7e1
    Dispositivo Boot Start End Blocks Id System
    /dev/sdc1 2048 15130623 7564288 b W95 FAT32
    paolo@ubuntu:/media/paolo/boot$ cd /mnt/hgfs/ubuntu_share/beagleboneblack/
    paolo@ubuntu:/mnt/hgfs/ubuntu_share/beagleboneblack$ sudo ./mkmmc-android.sh /dev/sdc
    Assuming Default Locations for Prebuilt Images
    All data on / dev / sdc now will be destroyed! Continue? [y / n]
    y
    [Umount all existing partitions on the device]
    umount: /dev/sdc: unmounted
    umount: /dev/sdc1: unmounted
    [Partitioning /dev/sdc ...]
    The disk /dev/sdc does not contain a valid partition table
    DISK SIZE - bytes
    (standard_in) 1: syntax error
    CYLINDERS -
    expr: syntax error
    [Making filesystems ...]
    [Copying files ...]
    [Copying START_HERE folder to boot partition]
    mount: special device /dev/sdc2 not exist
    umount: /dev/sdc2: Not Found
    [Copying all clips to data partition]
    mount: special device /dev/sdc4 not exist
    umount: /dev/sdc4: Not Found
    [Done]
    paolo@ubuntu:/mnt/hgfs/ubuntu_share/beagleboneblack$ sudo fdisk -l
    Sector size (logical / physical): 512 bytes / 512 bytes
    I / O size (minimum / optimal): 512 bytes / 512 bytes
    ID disk: 0x000429cc
    Device Boot Start End Blocks Id System
    / dev / sda1 * 2048 39845887 19921920 83 Linux
    / dev / sda2 39,847,934 41,940,991 1,046,529 5 Extended
    / dev / sda5 39847936 41940991 1046528 82 Linux swap / Solaris
    Disk / dev / sdc: 7746 MB, 7746879488 bytes
    239 heads, 62 sectors / track, 1021 cylinders, total 15,130,624 sectors
    ID disk: 0x00000000
    The disk / dev / sdc does not contain a valid partition table
    <<<< while running the script above, ubuntu desktop, you see that changes its name to the device sd card,
    and writes it as a boot.
    but then I want to see if you wrote correctly partitions with: >>>
    Disk / dev / sda: 21.5 GB, 21474836480 bytes
    ID disk: 0x000429cc
    ID disk: 0x00000000
    paolo@ubuntu:/mnt/hgfs/ubuntu_share/beagleboneblack$ df -hT
    File system Tipo Dim. Usati Dispon. Uso% Montato su
    /dev/sda1 ext4 19G 6,1G 12G 35% /
    none tmpfs 4,0K 0 4,0K 0% /sys/fs/cgroup
    udev devtmpfs 2,4G 12K 2,4G 1% /dev
    tmpfs tmpfs 488M 1,4M 487M 1% /run
    none tmpfs 5,0M 0 5,0M 0% /run/lock
    none tmpfs 2,4G 152K 2,4G 1% /run/shm
    none tmpfs 100M 52K 100M 1% /run/user
    .host:/ vmhgfs 451G 422G 30G 94% /mnt/hgfs
    <<<I think, run the script creates the partition and then delete the partition.
    In fact I see with gparted partition unallocated File System unallocated>>>
    <<<Tthen I decided to hand the procedure
    with gparted I created one called boot partition with fat 32 and boot flag
    2 ext4 partition and 1 partition Fat 32.
    I copied the files to the sd card but BBB cape 43T and LCD does not come on.
    that the contents of the SD Card>>>
    paolo@ubuntu:/media/paolo/boot$ sudo fdisk -l /dev/sdb
    Disk /dev/sdb: 7948 MB, 7948206080 bytes
    245 heads, 62 sectors / track, 1021 cylinders, total 15,523,840 sectors
    ID disk: 0x00004947
    /dev/sdb1 * 2,048 4,225,023 2,111,488 c W95 FAT32 (LBA)
    /dev/sdb2 4225024 8404991 2089984 83 Linux
    /dev/sdb3 8404992 11665407 1630208 83 Linux
    /dev/sdb4 11,665,408 15,523,839 1,929,216 c W95 FAT32 (LBA)
    paul @ ubuntu: /media/paul / boot $ df -i
    File system Inode I used I free I used% Mounted on
    /dev/sda1 1,245,184 211,704 1,033,480 18% /
    none 623 910 11 623 899 1% / sys / fs / cgroup
    udev 621225 505 620 720 1% / dev
    tmpfs 623910 600 623 310 1% / run
    none 623 910 5 623 905 1% / run / lock
    none 623 910 6 623 904 1% / run / shm
    none 623 910 28 623 882 1% / run / user
    .host: / 0 0 0 - / mnt / hgfs
    /dev/sdb1 0 0 0 - / media / paul / boot
    /dev/sdb2 130,816 1,250 129,566 1% / media / paul / rootfs
    /dev/sdb4 0 0 0 - / media / paul / date
    /dev/sdb3 101 920 415 101 505 1% / media / paul / usrdata
    paul @ ubuntu: / media / paul / boot $ df -h
    File system Dim. Used UNAVAILABLE. Use% Mounted on
    /dev/sda1 6,1G 19G 12G 35% /
    none 4,0K 4,0K 0 0% / sys / fs / cgroup
    udev 2.4G 2.4G 12K 1% / dev
    tmpfs 1,4m 488m 487m 1% / run
    none 5.0M 5.0M 0 0% / run / lock
    none 152K 2.4G 2.4G 1% / run / shm
    none 100M 48K 100M 1% / run / user
    .host: / 451G 422G 30G 94% / mnt / hgfs
    /dev / sdb1 2,1G 2,1G 6.8m 1% / media / paul / boot
    /dev / sdb2 2.0g 186m 1,7g 11% / media / paul / rootfs
    /dev / sdb4 1,9G 124m 1.8g 7% / media / paul / date
    /dev / sdb3 1.5g 56M 1,4G 4% / media / paul / usrdata
  • Hi Paolo,
    seeing the output of the mkmmc-android.sh command, it seems the fdisk -l command is failing when trying to process the geometry of the SD Card. This can happen if you are using a fdisk version that doesn't not support GPT partition, but this seems weird since we are not trying to use GPT. It could also be normal (since we just erase the partition table on the previous line), but in that case, we need to understand why reading the device size fails.
    Could you provide the version of fdisk you are using:
    $ fdisk -v
    Also, can you please run the following command directly from a terminal (if your SD Card is detected on /dev/sdc):
    $ fdisk -l /dev/sdc
    Also, can you please copy the content of the following to check that /dev/sdc is indeed your sd card:
    $ sudo dmesg -c
    connect the USB SD reader to your PC
    $ sleep 20
    $ dmesg
    Some USB SD reader will declare several /dev/sd[c-f] block devices for every slot the have, but most of them will be inactive, and only one is really connected to the SD Card, usually, not the first one.
    With the result of above commands, I should be able to understand why fdisk is failing to partition your SD Card and help you fix it.
  • Thank you for your valuable response.
    I tried to answer yesterday but the server did not answer.
    I run the commands you told me following the result.
    I'm sorry for the long message but are not aware of how to attach a file.
    Script iniziato su gio 07 mag 2015 00:11:35 PDT
    ;paolo@ubuntu: ~/Documentipaolo@ubuntu:~/Documenti$ clear
    ;paolo@ubuntu: ~/Documentipaolo@ubuntu:~/Documenti$ fdisk -v
    fdisk (util-linux 2.20.1)
    ;paolo@ubuntu: ~/Documentipaolo@ubuntu:~/Documenti$ sudo fdisk -l /dev/sdc
    [sudo] password for paolo:
    /dev/sdc1 ? 1635000430 2179175648 272087609+ 72 Sconosciuto
    /dev/sdc2 ? 1918986614 1919645402 329394+ 72 Sconosciuto
    /dev/sdc4 28049408 28049850 221+ 0 Vuoto
    ]0;paolo@ubuntu: ~/Documentipaolo@ubuntu:~/Documenti$ sudo fdisk -l /dev/sdc
    Disco /dev/sdc: 7746 MB, 7746879488 byte
    239 testine, 62 settori/tracce, 1021 cilindri, totale 15130624 settori
    Unità = settori di 1 * 512 = 512 byte
    Identificativo disco: 0x0dff6f63
    Questa non sembra una tabella delle partizioni.
    Probabilmente è stato scelto il dispositivo sbagliato.
    ]0;paolo@ubuntu: ~/Documentipaolo@ubuntu:~/Documenti$ sudo fdisk -l /dev/sdc[Kb
    ]0;paolo@ubuntu: ~/Documentipaolo@ubuntu:~/Documenti$ sudo dmesg -c
    [ 1633.590103] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.590106] sd 32:0:1:0: [sdb]
    [ 1633.590109] Sense Key : Not Ready [current]
    [ 1633.590113] sd 32:0:1:0: [sdb]
    [ 1633.590116] Add. Sense: No additional sense information
    [ 1633.590119] sd 32:0:1:0: [sdb] CDB:
    [ 1633.590121] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1633.590626] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.590632] sd 32:0:1:0: [sdb]
    [ 1633.590669] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.590675] sd 32:0:1:0: [sdb]
    [ 1633.590677] Sense Key : Not Ready [current]
    [ 1633.590682] sd 32:0:1:0: [sdb]
    [ 1633.590685] Add. Sense: No additional sense information
    [ 1633.590688] sd 32:0:1:0: [sdb] CDB:
    [ 1633.590690] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.591496] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.591505] sd 32:0:1:0: [sdb]
    [ 1633.591510] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.591516] sd 32:0:1:0: [sdb]
    [ 1633.591520] Sense Key : Not Ready [current]
    [ 1633.591527] sd 32:0:1:0: [sdb]
    [ 1633.591531] Add. Sense: No additional sense information
    [ 1633.591537] sd 32:0:1:0: [sdb] CDB:
    [ 1633.591539] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.592037] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.592047] sd 32:0:1:0: [sdb]
    [ 1633.592050] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.592056] sd 32:0:1:0: [sdb]
    [ 1633.592060] Sense Key : Not Ready [current]
    [ 1633.592067] sd 32:0:1:0: [sdb]
    [ 1633.592071] Add. Sense: No additional sense information
    [ 1633.592077] sd 32:0:1:0: [sdb] CDB:
    [ 1633.592080] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1633.594427] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.594449] sd 32:0:1:0: [sdb]
    [ 1633.594459] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.594466] sd 32:0:1:0: [sdb]
    [ 1633.594472] Sense Key : Not Ready [current]
    [ 1633.594483] sd 32:0:1:0: [sdb]
    [ 1633.594490] Add. Sense: No additional sense information
    [ 1633.594497] sd 32:0:1:0: [sdb] CDB:
    [ 1633.594503] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1633.596892] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.596916] sd 32:0:1:0: [sdb]
    [ 1633.596923] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.596930] sd 32:0:1:0: [sdb]
    [ 1633.596937] Sense Key : Not Ready [current]
    [ 1633.596948] sd 32:0:1:0: [sdb]
    [ 1633.596954] Add. Sense: No additional sense information
    [ 1633.596960] sd 32:0:1:0: [sdb] CDB:
    [ 1633.596967] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1633.597930] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.597942] sd 32:0:1:0: [sdb]
    [ 1633.597946] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.597950] sd 32:0:1:0: [sdb]
    [ 1633.597952] Sense Key : Not Ready [current]
    [ 1633.597958] sd 32:0:1:0: [sdb]
    [ 1633.597961] Add. Sense: No additional sense information
    [ 1633.597965] sd 32:0:1:0: [sdb] CDB:
    [ 1633.597968] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1633.598928] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.598946] sd 32:0:1:0: [sdb]
    [ 1633.598951] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.598955] sd 32:0:1:0: [sdb]
    [ 1633.598958] Sense Key : Not Ready [current]
    [ 1633.598966] sd 32:0:1:0: [sdb]
    [ 1633.598970] Add. Sense: No additional sense information
    [ 1633.598975] sd 32:0:1:0: [sdb] CDB:
    [ 1633.598977] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1633.599661] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.599729] sd 32:0:1:0: [sdb]
    [ 1633.599736] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.599742] sd 32:0:1:0: [sdb]
    [ 1633.599746] Sense Key : Not Ready [current]
    [ 1633.599756] sd 32:0:1:0: [sdb]
    [ 1633.599761] Add. Sense: No additional sense information
    [ 1633.599767] sd 32:0:1:0: [sdb] CDB:
    [ 1633.599771] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1633.602006] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.602020] sd 32:0:1:0: [sdb]
    [ 1633.602026] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.602030] sd 32:0:1:0: [sdb]
    [ 1633.602033] Sense Key : Not Ready [current]
    [ 1633.602041] sd 32:0:1:0: [sdb]
    [ 1633.602045] Add. Sense: No additional sense information
    [ 1633.602050] sd 32:0:1:0: [sdb] CDB:
    [ 1633.602053] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1633.603231] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.603245] sd 32:0:1:0: [sdb]
    [ 1633.603251] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.603255] sd 32:0:1:0: [sdb]
    [ 1633.603258] Sense Key : Not Ready [current]
    [ 1633.603265] sd 32:0:1:0: [sdb]
    [ 1633.603269] Add. Sense: No additional sense information
    [ 1633.603273] sd 32:0:1:0: [sdb] CDB:
    [ 1633.603276] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1633.604139] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.604150] sd 32:0:1:0: [sdb]
    [ 1633.604155] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.604159] sd 32:0:1:0: [sdb]
    [ 1633.604162] Sense Key : Not Ready [current]
    [ 1633.604169] sd 32:0:1:0: [sdb]
    [ 1633.604172] Add. Sense: No additional sense information
    [ 1633.604176] sd 32:0:1:0: [sdb] CDB:
    [ 1633.604179] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.604967] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.604978] sd 32:0:1:0: [sdb]
    [ 1633.604982] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.604986] sd 32:0:1:0: [sdb]
    [ 1633.604990] Sense Key : Not Ready [current]
    [ 1633.604996] sd 32:0:1:0: [sdb]
    [ 1633.605000] Add. Sense: No additional sense information
    [ 1633.605004] sd 32:0:1:0: [sdb] CDB:
    [ 1633.605007] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.606452] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.606489] sd 32:0:1:0: [sdb]
    [ 1633.606494] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.606497] sd 32:0:1:0: [sdb]
    [ 1633.606500] Sense Key : Not Ready [current]
    [ 1633.606507] sd 32:0:1:0: [sdb]
    [ 1633.606510] Add. Sense: No additional sense information
    [ 1633.606514] sd 32:0:1:0: [sdb] CDB:
    [ 1633.606517] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.607602] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.607637] sd 32:0:1:0: [sdb]
    [ 1633.607642] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.607646] sd 32:0:1:0: [sdb]
    [ 1633.607648] Sense Key : Not Ready [current]
    [ 1633.607712] sd 32:0:1:0: [sdb]
    [ 1633.607716] Add. Sense: No additional sense information
    [ 1633.607721] sd 32:0:1:0: [sdb] CDB:
    [ 1633.607723] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.608479] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.608515] sd 32:0:1:0: [sdb]
    [ 1633.608519] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.608523] sd 32:0:1:0: [sdb]
    [ 1633.608526] Sense Key : Not Ready [current]
    [ 1633.608532] sd 32:0:1:0: [sdb]
    [ 1633.608535] Add. Sense: No additional sense information
    [ 1633.608539] sd 32:0:1:0: [sdb] CDB:
    [ 1633.608541] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.609270] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.609298] sd 32:0:1:0: [sdb]
    [ 1633.609302] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.609305] sd 32:0:1:0: [sdb]
    [ 1633.609308] Sense Key : Not Ready [current]
    [ 1633.609313] sd 32:0:1:0: [sdb]
    [ 1633.609316] Add. Sense: No additional sense information
    [ 1633.609319] sd 32:0:1:0: [sdb] CDB:
    [ 1633.609321] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.609957] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.609986] sd 32:0:1:0: [sdb]
    [ 1633.609990] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.609993] sd 32:0:1:0: [sdb]
    [ 1633.609995] Sense Key : Not Ready [current]
    [ 1633.610000] sd 32:0:1:0: [sdb]
    [ 1633.610002] Add. Sense: No additional sense information
    [ 1633.610006] sd 32:0:1:0: [sdb] CDB:
    [ 1633.610008] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1633.610736] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.610772] sd 32:0:1:0: [sdb]
    [ 1633.610777] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.610781] sd 32:0:1:0: [sdb]
    [ 1633.610784] Sense Key : Not Ready [current]
    [ 1633.610790] sd 32:0:1:0: [sdb]
    [ 1633.610793] Add. Sense: No additional sense information
    [ 1633.610798] sd 32:0:1:0: [sdb] CDB:
    [ 1633.610800] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1633.611544] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.611579] sd 32:0:1:0: [sdb]
    [ 1633.611584] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.611588] sd 32:0:1:0: [sdb]
    [ 1633.611591] Sense Key : Not Ready [current]
    [ 1633.611597] sd 32:0:1:0: [sdb]
    [ 1633.611600] Add. Sense: No additional sense information
    [ 1633.611604] sd 32:0:1:0: [sdb] CDB:
    [ 1633.611606] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1633.612415] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.612445] sd 32:0:1:0: [sdb]
    [ 1633.612450] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.612453] sd 32:0:1:0: [sdb]
    [ 1633.612456] Sense Key : Not Ready [current]
    [ 1633.612462] sd 32:0:1:0: [sdb]
    [ 1633.612466] Add. Sense: No additional sense information
    [ 1633.612470] sd 32:0:1:0: [sdb] CDB:
    [ 1633.612472] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1633.613489] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.613525] sd 32:0:1:0: [sdb]
    [ 1633.613530] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.613534] sd 32:0:1:0: [sdb]
    [ 1633.613537] Sense Key : Not Ready [current]
    [ 1633.613543] sd 32:0:1:0: [sdb]
    [ 1633.613546] Add. Sense: No additional sense information
    [ 1633.613550] sd 32:0:1:0: [sdb] CDB:
    [ 1633.613552] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1633.614262] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.614293] sd 32:0:1:0: [sdb]
    [ 1633.614297] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.614300] sd 32:0:1:0: [sdb]
    [ 1633.614303] Sense Key : Not Ready [current]
    [ 1633.614308] sd 32:0:1:0: [sdb]
    [ 1633.614311] Add. Sense: No additional sense information
    [ 1633.614314] sd 32:0:1:0: [sdb] CDB:
    [ 1633.614317] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1633.614949] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.614980] sd 32:0:1:0: [sdb]
    [ 1633.614984] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.614987] sd 32:0:1:0: [sdb]
    [ 1633.614990] Sense Key : Not Ready [current]
    [ 1633.614994] sd 32:0:1:0: [sdb]
    [ 1633.614997] Add. Sense: No additional sense information
    [ 1633.615001] sd 32:0:1:0: [sdb] CDB:
    [ 1633.615003] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1633.615782] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.615822] sd 32:0:1:0: [sdb]
    [ 1633.615827] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.615831] sd 32:0:1:0: [sdb]
    [ 1633.615833] Sense Key : Not Ready [current]
    [ 1633.615840] sd 32:0:1:0: [sdb]
    [ 1633.615843] Add. Sense: No additional sense information
    [ 1633.615848] sd 32:0:1:0: [sdb] CDB:
    [ 1633.615850] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1633.616726] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.616766] sd 32:0:1:0: [sdb]
    [ 1633.616771] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.616775] sd 32:0:1:0: [sdb]
    [ 1633.616778] Sense Key : Not Ready [current]
    [ 1633.616784] sd 32:0:1:0: [sdb]
    [ 1633.616788] Add. Sense: No additional sense information
    [ 1633.616792] sd 32:0:1:0: [sdb] CDB:
    [ 1633.616794] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1633.617571] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.617606] sd 32:0:1:0: [sdb]
    [ 1633.617611] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.617614] sd 32:0:1:0: [sdb]
    [ 1633.617617] Sense Key : Not Ready [current]
    [ 1633.617624] sd 32:0:1:0: [sdb]
    [ 1633.617627] Add. Sense: No additional sense information
    [ 1633.617631] sd 32:0:1:0: [sdb] CDB:
    [ 1633.617633] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1633.618419] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.618454] sd 32:0:1:0: [sdb]
    [ 1633.618458] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.618463] sd 32:0:1:0: [sdb]
    [ 1633.618465] Sense Key : Not Ready [current]
    [ 1633.618472] sd 32:0:1:0: [sdb]
    [ 1633.618475] Add. Sense: No additional sense information
    [ 1633.618479] sd 32:0:1:0: [sdb] CDB:
    [ 1633.618481] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1633.619279] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.619314] sd 32:0:1:0: [sdb]
    [ 1633.619318] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.619322] sd 32:0:1:0: [sdb]
    [ 1633.619325] Sense Key : Not Ready [current]
    [ 1633.619331] sd 32:0:1:0: [sdb]
    [ 1633.619334] Add. Sense: No additional sense information
    [ 1633.619338] sd 32:0:1:0: [sdb] CDB:
    [ 1633.619341] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1633.619776] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.619782] sd 32:0:1:0: [sdb]
    [ 1633.619786] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.619789] sd 32:0:1:0: [sdb]
    [ 1633.619792] Sense Key : Not Ready [current]
    [ 1633.619797] sd 32:0:1:0: [sdb]
    [ 1633.619800] Add. Sense: No additional sense information
    [ 1633.619803] sd 32:0:1:0: [sdb] CDB:
    [ 1633.619806] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1633.620420] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.620429] sd 32:0:1:0: [sdb]
    [ 1633.620433] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.620437] sd 32:0:1:0: [sdb]
    [ 1633.620440] Sense Key : Not Ready [current]
    [ 1633.620446] sd 32:0:1:0: [sdb]
    [ 1633.620450] Add. Sense: No additional sense information
    [ 1633.620454] sd 32:0:1:0: [sdb] CDB:
    [ 1633.620456] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1633.620893] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.620898] sd 32:0:1:0: [sdb]
    [ 1633.620902] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.620905] sd 32:0:1:0: [sdb]
    [ 1633.620908] Sense Key : Not Ready [current]
    [ 1633.620913] sd 32:0:1:0: [sdb]
    [ 1633.620915] Add. Sense: No additional sense information
    [ 1633.620919] sd 32:0:1:0: [sdb] CDB:
    [ 1633.620921] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1633.621776] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.621811] sd 32:0:1:0: [sdb]
    [ 1633.621815] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.621819] sd 32:0:1:0: [sdb]
    [ 1633.621822] Sense Key : Not Ready [current]
    [ 1633.621828] sd 32:0:1:0: [sdb]
    [ 1633.621831] Add. Sense: No additional sense information
    [ 1633.621835] sd 32:0:1:0: [sdb] CDB:
    [ 1633.621837] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1633.622272] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.622278] sd 32:0:1:0: [sdb]
    [ 1633.622282] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.622285] sd 32:0:1:0: [sdb]
    [ 1633.622287] Sense Key : Not Ready [current]
    [ 1633.622292] sd 32:0:1:0: [sdb]
    [ 1633.622295] Add. Sense: No additional sense information
    [ 1633.622299] sd 32:0:1:0: [sdb] CDB:
    [ 1633.622301] Read(10): 28 00 00 00 01 00 00 00 08 00
    [ 1633.622864] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.622873] sd 32:0:1:0: [sdb]
    [ 1633.622877] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.622881] sd 32:0:1:0: [sdb]
    [ 1633.622884] Sense Key : Not Ready [current]
    [ 1633.622890] sd 32:0:1:0: [sdb]
    [ 1633.622893] Add. Sense: No additional sense information
    [ 1633.622897] sd 32:0:1:0: [sdb] CDB:
    [ 1633.622900] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.623608] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.623617] sd 32:0:1:0: [sdb]
    [ 1633.623621] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.623625] sd 32:0:1:0: [sdb]
    [ 1633.623627] Sense Key : Not Ready [current]
    [ 1633.623633] sd 32:0:1:0: [sdb]
    [ 1633.623637] Add. Sense: No additional sense information
    [ 1633.623641] sd 32:0:1:0: [sdb] CDB:
    [ 1633.623643] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.624220] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.624230] sd 32:0:1:0: [sdb]
    [ 1633.624234] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.624237] sd 32:0:1:0: [sdb]
    [ 1633.624240] Sense Key : Not Ready [current]
    [ 1633.624246] sd 32:0:1:0: [sdb]
    [ 1633.624249] Add. Sense: No additional sense information
    [ 1633.624254] sd 32:0:1:0: [sdb] CDB:
    [ 1633.624256] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.624867] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.624876] sd 32:0:1:0: [sdb]
    [ 1633.624881] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.624885] sd 32:0:1:0: [sdb]
    [ 1633.624887] Sense Key : Not Ready [current]
    [ 1633.624894] sd 32:0:1:0: [sdb]
    [ 1633.624897] Add. Sense: No additional sense information
    [ 1633.624901] sd 32:0:1:0: [sdb] CDB:
    [ 1633.624903] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.625330] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.625335] sd 32:0:1:0: [sdb]
    [ 1633.625339] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.625342] sd 32:0:1:0: [sdb]
    [ 1633.625344] Sense Key : Not Ready [current]
    [ 1633.625349] sd 32:0:1:0: [sdb]
    [ 1633.625352] Add. Sense: No additional sense information
    [ 1633.625355] sd 32:0:1:0: [sdb] CDB:
    [ 1633.625357] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.626025] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.626032] sd 32:0:1:0: [sdb]
    [ 1633.626035] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.626038] sd 32:0:1:0: [sdb]
    [ 1633.626041] Sense Key : Not Ready [current]
    [ 1633.626046] sd 32:0:1:0: [sdb]
    [ 1633.626048] Add. Sense: No additional sense information
    [ 1633.626052] sd 32:0:1:0: [sdb] CDB:
    [ 1633.626054] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1633.626706] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.626758] sd 32:0:1:0: [sdb]
    [ 1633.626763] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.626766] sd 32:0:1:0: [sdb]
    [ 1633.626769] Sense Key : Not Ready [current]
    [ 1633.626776] sd 32:0:1:0: [sdb]
    [ 1633.626779] Add. Sense: No additional sense information
    [ 1633.626783] sd 32:0:1:0: [sdb] CDB:
    [ 1633.626786] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.627302] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.627311] sd 32:0:1:0: [sdb]
    [ 1633.627316] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.627320] sd 32:0:1:0: [sdb]
    [ 1633.627322] Sense Key : Not Ready [current]
    [ 1633.627329] sd 32:0:1:0: [sdb]
    [ 1633.627332] Add. Sense: No additional sense information
    [ 1633.627336] sd 32:0:1:0: [sdb] CDB:
    [ 1633.627338] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.627883] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.627893] sd 32:0:1:0: [sdb]
    [ 1633.627897] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.627901] sd 32:0:1:0: [sdb]
    [ 1633.627903] Sense Key : Not Ready [current]
    [ 1633.627910] sd 32:0:1:0: [sdb]
    [ 1633.627913] Add. Sense: No additional sense information
    [ 1633.627917] sd 32:0:1:0: [sdb] CDB:
    [ 1633.627919] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.628438] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.628447] sd 32:0:1:0: [sdb]
    [ 1633.628451] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.628455] sd 32:0:1:0: [sdb]
    [ 1633.628458] Sense Key : Not Ready [current]
    [ 1633.628464] sd 32:0:1:0: [sdb]
    [ 1633.628467] Add. Sense: No additional sense information
    [ 1633.628471] sd 32:0:1:0: [sdb] CDB:
    [ 1633.628473] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.628950] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.628955] sd 32:0:1:0: [sdb]
    [ 1633.628959] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.628962] sd 32:0:1:0: [sdb]
    [ 1633.628965] Sense Key : Not Ready [current]
    [ 1633.628970] sd 32:0:1:0: [sdb]
    [ 1633.628972] Add. Sense: No additional sense information
    [ 1633.628976] sd 32:0:1:0: [sdb] CDB:
    [ 1633.628978] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.629963] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.629998] sd 32:0:1:0: [sdb]
    [ 1633.630003] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.630007] sd 32:0:1:0: [sdb]
    [ 1633.630010] Sense Key : Not Ready [current]
    [ 1633.630016] sd 32:0:1:0: [sdb]
    [ 1633.630019] Add. Sense: No additional sense information
    [ 1633.630023] sd 32:0:1:0: [sdb] CDB:
    [ 1633.630026] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.630504] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.630510] sd 32:0:1:0: [sdb]
    [ 1633.630513] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.630517] sd 32:0:1:0: [sdb]
    [ 1633.630519] Sense Key : Not Ready [current]
    [ 1633.630524] sd 32:0:1:0: [sdb]
    [ 1633.630527] Add. Sense: No additional sense information
    [ 1633.630530] sd 32:0:1:0: [sdb] CDB:
    [ 1633.630532] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.631078] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.631087] sd 32:0:1:0: [sdb]
    [ 1633.631091] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.631095] sd 32:0:1:0: [sdb]
    [ 1633.631098] Sense Key : Not Ready [current]
    [ 1633.631105] sd 32:0:1:0: [sdb]
    [ 1633.631108] Add. Sense: No additional sense information
    [ 1633.631112] sd 32:0:1:0: [sdb] CDB:
    [ 1633.631114] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.631662] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.631671] sd 32:0:1:0: [sdb]
    [ 1633.631675] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.631679] sd 32:0:1:0: [sdb]
    [ 1633.631682] Sense Key : Not Ready [current]
    [ 1633.631689] sd 32:0:1:0: [sdb]
    [ 1633.631692] Add. Sense: No additional sense information
    [ 1633.631750] sd 32:0:1:0: [sdb] CDB:
    [ 1633.631754] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.632277] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.632286] sd 32:0:1:0: [sdb]
    [ 1633.632290] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.632294] sd 32:0:1:0: [sdb]
    [ 1633.632297] Sense Key : Not Ready [current]
    [ 1633.632303] sd 32:0:1:0: [sdb]
    [ 1633.632306] Add. Sense: No additional sense information
    [ 1633.632310] sd 32:0:1:0: [sdb] CDB:
    [ 1633.632313] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.632907] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.632916] sd 32:0:1:0: [sdb]
    [ 1633.632920] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.632924] sd 32:0:1:0: [sdb]
    [ 1633.632926] Sense Key : Not Ready [current]
    [ 1633.632933] sd 32:0:1:0: [sdb]
    [ 1633.632936] Add. Sense: No additional sense information
    [ 1633.632940] sd 32:0:1:0: [sdb] CDB:
    [ 1633.632943] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.633369] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.633374] sd 32:0:1:0: [sdb]
    [ 1633.633377] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.633380] sd 32:0:1:0: [sdb]
    [ 1633.633382] Sense Key : Not Ready [current]
    [ 1633.633387] sd 32:0:1:0: [sdb]
    [ 1633.633390] Add. Sense: No additional sense information
    [ 1633.633393] sd 32:0:1:0: [sdb] CDB:
    [ 1633.633395] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.634391] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.634427] sd 32:0:1:0: [sdb]
    [ 1633.634431] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.634435] sd 32:0:1:0: [sdb]
    [ 1633.634438] Sense Key : Not Ready [current]
    [ 1633.634444] sd 32:0:1:0: [sdb]
    [ 1633.634447] Add. Sense: No additional sense information
    [ 1633.634452] sd 32:0:1:0: [sdb] CDB:
    [ 1633.634454] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1633.634889] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.634895] sd 32:0:1:0: [sdb]
    [ 1633.634899] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.634902] sd 32:0:1:0: [sdb]
    [ 1633.634904] Sense Key : Not Ready [current]
    [ 1633.634909] sd 32:0:1:0: [sdb]
    [ 1633.634912] Add. Sense: No additional sense information
    [ 1633.634916] sd 32:0:1:0: [sdb] CDB:
    [ 1633.634918] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1633.635347] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.635353] sd 32:0:1:0: [sdb]
    [ 1633.635356] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.635359] sd 32:0:1:0: [sdb]
    [ 1633.635361] Sense Key : Not Ready [current]
    [ 1633.635366] sd 32:0:1:0: [sdb]
    [ 1633.635368] Add. Sense: No additional sense information
    [ 1633.635372] sd 32:0:1:0: [sdb] CDB:
    [ 1633.635374] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1633.635881] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.635890] sd 32:0:1:0: [sdb]
    [ 1633.635894] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.635898] sd 32:0:1:0: [sdb]
    [ 1633.635901] Sense Key : Not Ready [current]
    [ 1633.635907] sd 32:0:1:0: [sdb]
    [ 1633.635910] Add. Sense: No additional sense information
    [ 1633.635914] sd 32:0:1:0: [sdb] CDB:
    [ 1633.635917] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.636508] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.636517] sd 32:0:1:0: [sdb]
    [ 1633.636521] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.636525] sd 32:0:1:0: [sdb]
    [ 1633.636528] Sense Key : Not Ready [current]
    [ 1633.636535] sd 32:0:1:0: [sdb]
    [ 1633.636538] Add. Sense: No additional sense information
    [ 1633.636542] sd 32:0:1:0: [sdb] CDB:
    [ 1633.636544] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.637011] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.637016] sd 32:0:1:0: [sdb]
    [ 1633.637020] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.637023] sd 32:0:1:0: [sdb]
    [ 1633.637026] Sense Key : Not Ready [current]
    [ 1633.637031] sd 32:0:1:0: [sdb]
    [ 1633.637033] Add. Sense: No additional sense information
    [ 1633.637037] sd 32:0:1:0: [sdb] CDB:
    [ 1633.637039] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1633.637925] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.637932] sd 32:0:1:0: [sdb]
    [ 1633.637936] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.637939] sd 32:0:1:0: [sdb]
    [ 1633.637942] Sense Key : Not Ready [current]
    [ 1633.637946] sd 32:0:1:0: [sdb]
    [ 1633.637949] Add. Sense: No additional sense information
    [ 1633.637953] sd 32:0:1:0: [sdb] CDB:
    [ 1633.637955] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1633.638618] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.638628] sd 32:0:1:0: [sdb]
    [ 1633.638633] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.638636] sd 32:0:1:0: [sdb]
    [ 1633.638639] Sense Key : Not Ready [current]
    [ 1633.638645] sd 32:0:1:0: [sdb]
    [ 1633.638648] Add. Sense: No additional sense information
    [ 1633.638653] sd 32:0:1:0: [sdb] CDB:
    [ 1633.638655] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.639172] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.639182] sd 32:0:1:0: [sdb]
    [ 1633.639187] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.639192] sd 32:0:1:0: [sdb]
    [ 1633.639196] Sense Key : Not Ready [current]
    [ 1633.639204] sd 32:0:1:0: [sdb]
    [ 1633.639208] Add. Sense: No additional sense information
    [ 1633.639214] sd 32:0:1:0: [sdb] CDB:
    [ 1633.639217] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.639789] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.639799] sd 32:0:1:0: [sdb]
    [ 1633.639804] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.639808] sd 32:0:1:0: [sdb]
    [ 1633.639811] Sense Key : Not Ready [current]
    [ 1633.639817] sd 32:0:1:0: [sdb]
    [ 1633.639820] Add. Sense: No additional sense information
    [ 1633.639824] sd 32:0:1:0: [sdb] CDB:
    [ 1633.639827] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.640241] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.640247] sd 32:0:1:0: [sdb]
    [ 1633.640250] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.640254] sd 32:0:1:0: [sdb]
    [ 1633.640256] Sense Key : Not Ready [current]
    [ 1633.640261] sd 32:0:1:0: [sdb]
    [ 1633.640263] Add. Sense: No additional sense information
    [ 1633.640267] sd 32:0:1:0: [sdb] CDB:
    [ 1633.640269] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.640873] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.640882] sd 32:0:1:0: [sdb]
    [ 1633.640886] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.640890] sd 32:0:1:0: [sdb]
    [ 1633.640893] Sense Key : Not Ready [current]
    [ 1633.640899] sd 32:0:1:0: [sdb]
    [ 1633.640902] Add. Sense: No additional sense information
    [ 1633.640906] sd 32:0:1:0: [sdb] CDB:
    [ 1633.640908] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.641333] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.641338] sd 32:0:1:0: [sdb]
    [ 1633.641341] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.641345] sd 32:0:1:0: [sdb]
    [ 1633.641347] Sense Key : Not Ready [current]
    [ 1633.641352] sd 32:0:1:0: [sdb]
    [ 1633.641354] Add. Sense: No additional sense information
    [ 1633.641358] sd 32:0:1:0: [sdb] CDB:
    [ 1633.641360] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.642443] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.642479] sd 32:0:1:0: [sdb]
    [ 1633.642484] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.642488] sd 32:0:1:0: [sdb]
    [ 1633.642491] Sense Key : Not Ready [current]
    [ 1633.642497] sd 32:0:1:0: [sdb]
    [ 1633.642500] Add. Sense: No additional sense information
    [ 1633.642505] sd 32:0:1:0: [sdb] CDB:
    [ 1633.642507] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1633.642971] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.642977] sd 32:0:1:0: [sdb]
    [ 1633.642981] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.642984] sd 32:0:1:0: [sdb]
    [ 1633.642986] Sense Key : Not Ready [current]
    [ 1633.642991] sd 32:0:1:0: [sdb]
    [ 1633.642994] Add. Sense: No additional sense information
    [ 1633.642998] sd 32:0:1:0: [sdb] CDB:
    [ 1633.643000] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1633.643399] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.643406] sd 32:0:1:0: [sdb]
    [ 1633.643409] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.643412] sd 32:0:1:0: [sdb]
    [ 1633.643414] Sense Key : Not Ready [current]
    [ 1633.643418] sd 32:0:1:0: [sdb]
    [ 1633.643421] Add. Sense: No additional sense information
    [ 1633.643425] sd 32:0:1:0: [sdb] CDB:
    [ 1633.643427] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.643930] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.643940] sd 32:0:1:0: [sdb]
    [ 1633.643944] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.643948] sd 32:0:1:0: [sdb]
    [ 1633.643950] Sense Key : Not Ready [current]
    [ 1633.643957] sd 32:0:1:0: [sdb]
    [ 1633.643960] Add. Sense: No additional sense information
    [ 1633.643964] sd 32:0:1:0: [sdb] CDB:
    [ 1633.643966] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.644482] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.644492] sd 32:0:1:0: [sdb]
    [ 1633.644496] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.644499] sd 32:0:1:0: [sdb]
    [ 1633.644502] Sense Key : Not Ready [current]
    [ 1633.644508] sd 32:0:1:0: [sdb]
    [ 1633.644511] Add. Sense: No additional sense information
    [ 1633.644515] sd 32:0:1:0: [sdb] CDB:
    [ 1633.644518] Read(10): 28 00 00 00 10 00 00 00 08 00
    [ 1633.645049] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.645055] sd 32:0:1:0: [sdb]
    [ 1633.645059] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.645062] sd 32:0:1:0: [sdb]
    [ 1633.645064] Sense Key : Not Ready [current]
    [ 1633.645069] sd 32:0:1:0: [sdb]
    [ 1633.645072] Add. Sense: No additional sense information
    [ 1633.645076] sd 32:0:1:0: [sdb] CDB:
    [ 1633.645078] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.645601] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.645607] sd 32:0:1:0: [sdb]
    [ 1633.645611] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.645614] sd 32:0:1:0: [sdb]
    [ 1633.645616] Sense Key : Not Ready [current]
    [ 1633.645621] sd 32:0:1:0: [sdb]
    [ 1633.645623] Add. Sense: No additional sense information
    [ 1633.645627] sd 32:0:1:0: [sdb] CDB:
    [ 1633.645629] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.645993] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.645999] sd 32:0:1:0: [sdb]
    [ 1633.646002] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.646005] sd 32:0:1:0: [sdb]
    [ 1633.646007] Sense Key : Not Ready [current]
    [ 1633.646012] sd 32:0:1:0: [sdb]
    [ 1633.646015] Add. Sense: No additional sense information
    [ 1633.646018] sd 32:0:1:0: [sdb] CDB:
    [ 1633.646020] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.646504] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.646510] sd 32:0:1:0: [sdb]
    [ 1633.646513] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.646517] sd 32:0:1:0: [sdb]
    [ 1633.646519] Sense Key : Not Ready [current]
    [ 1633.646523] sd 32:0:1:0: [sdb]
    [ 1633.646526] Add. Sense: No additional sense information
    [ 1633.646529] sd 32:0:1:0: [sdb] CDB:
    [ 1633.646531] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.647012] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.647022] sd 32:0:1:0: [sdb]
    [ 1633.647027] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.647030] sd 32:0:1:0: [sdb]
    [ 1633.647033] Sense Key : Not Ready [current]
    [ 1633.647039] sd 32:0:1:0: [sdb]
    [ 1633.647043] Add. Sense: No additional sense information
    [ 1633.647047] sd 32:0:1:0: [sdb] CDB:
    [ 1633.647049] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.647483] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.647489] sd 32:0:1:0: [sdb]
    [ 1633.647492] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.647496] sd 32:0:1:0: [sdb]
    [ 1633.647498] Sense Key : Not Ready [current]
    [ 1633.647503] sd 32:0:1:0: [sdb]
    [ 1633.647506] Add. Sense: No additional sense information
    [ 1633.647509] sd 32:0:1:0: [sdb] CDB:
    [ 1633.647511] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1633.745803] sd 32:0:1:0: [sdb] Device not ready
    [ 1633.745815] sd 32:0:1:0: [sdb]
    [ 1633.745820] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1633.745824] sd 32:0:1:0: [sdb]
    [ 1633.745827] Sense Key : Not Ready [current]
    [ 1633.745834] sd 32:0:1:0: [sdb]
    [ 1633.745837] Add. Sense: No additional sense information
    [ 1633.745842] sd 32:0:1:0: [sdb] CDB:
    [ 1633.745844] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.607540] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.607551] sd 32:0:1:0: [sdb]
    [ 1636.607557] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.607561] sd 32:0:1:0: [sdb]
    [ 1636.607564] Sense Key : Not Ready [current]
    [ 1636.607570] sd 32:0:1:0: [sdb]
    [ 1636.607574] Add. Sense: No additional sense information
    [ 1636.607578] sd 32:0:1:0: [sdb] CDB:
    [ 1636.607581] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.608172] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.608182] sd 32:0:1:0: [sdb]
    [ 1636.608186] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.608190] sd 32:0:1:0: [sdb]
    [ 1636.608193] Sense Key : Not Ready [current]
    [ 1636.608199] sd 32:0:1:0: [sdb]
    [ 1636.608202] Add. Sense: No additional sense information
    [ 1636.608206] sd 32:0:1:0: [sdb] CDB:
    [ 1636.608208] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.608692] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.608698] sd 32:0:1:0: [sdb]
    [ 1636.608701] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.608705] sd 32:0:1:0: [sdb]
    [ 1636.608707] Sense Key : Not Ready [current]
    [ 1636.608761] sd 32:0:1:0: [sdb]
    [ 1636.608764] Add. Sense: No additional sense information
    [ 1636.608768] sd 32:0:1:0: [sdb] CDB:
    [ 1636.608770] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.609814] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.609824] sd 32:0:1:0: [sdb]
    [ 1636.609828] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.609832] sd 32:0:1:0: [sdb]
    [ 1636.609834] Sense Key : Not Ready [current]
    [ 1636.609841] sd 32:0:1:0: [sdb]
    [ 1636.609844] Add. Sense: No additional sense information
    [ 1636.609848] sd 32:0:1:0: [sdb] CDB:
    [ 1636.609850] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.610409] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.610418] sd 32:0:1:0: [sdb]
    [ 1636.610422] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.610426] sd 32:0:1:0: [sdb]
    [ 1636.610429] Sense Key : Not Ready [current]
    [ 1636.610436] sd 32:0:1:0: [sdb]
    [ 1636.610439] Add. Sense: No additional sense information
    [ 1636.610443] sd 32:0:1:0: [sdb] CDB:
    [ 1636.610445] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.611001] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.611010] sd 32:0:1:0: [sdb]
    [ 1636.611014] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.611018] sd 32:0:1:0: [sdb]
    [ 1636.611021] Sense Key : Not Ready [current]
    [ 1636.611027] sd 32:0:1:0: [sdb]
    [ 1636.611030] Add. Sense: No additional sense information
    [ 1636.611034] sd 32:0:1:0: [sdb] CDB:
    [ 1636.611037] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.611648] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.611657] sd 32:0:1:0: [sdb]
    [ 1636.611661] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.611665] sd 32:0:1:0: [sdb]
    [ 1636.611668] Sense Key : Not Ready [current]
    [ 1636.611674] sd 32:0:1:0: [sdb]
    [ 1636.611677] Add. Sense: No additional sense information
    [ 1636.611682] sd 32:0:1:0: [sdb] CDB:
    [ 1636.611684] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.612274] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.612283] sd 32:0:1:0: [sdb]
    [ 1636.612287] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.612290] sd 32:0:1:0: [sdb]
    [ 1636.612293] Sense Key : Not Ready [current]
    [ 1636.612299] sd 32:0:1:0: [sdb]
    [ 1636.612302] Add. Sense: No additional sense information
    [ 1636.612307] sd 32:0:1:0: [sdb] CDB:
    [ 1636.612309] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.612807] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.612812] sd 32:0:1:0: [sdb]
    [ 1636.612816] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.612819] sd 32:0:1:0: [sdb]
    [ 1636.612822] Sense Key : Not Ready [current]
    [ 1636.612827] sd 32:0:1:0: [sdb]
    [ 1636.612829] Add. Sense: No additional sense information
    [ 1636.612833] sd 32:0:1:0: [sdb] CDB:
    [ 1636.612835] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.613856] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.613866] sd 32:0:1:0: [sdb]
    [ 1636.613870] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.613874] sd 32:0:1:0: [sdb]
    [ 1636.613877] Sense Key : Not Ready [current]
    [ 1636.613883] sd 32:0:1:0: [sdb]
    [ 1636.613886] Add. Sense: No additional sense information
    [ 1636.613891] sd 32:0:1:0: [sdb] CDB:
    [ 1636.613893] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1636.614426] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.614435] sd 32:0:1:0: [sdb]
    [ 1636.614439] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.614443] sd 32:0:1:0: [sdb]
    [ 1636.614446] Sense Key : Not Ready [current]
    [ 1636.614452] sd 32:0:1:0: [sdb]
    [ 1636.614456] Add. Sense: No additional sense information
    [ 1636.614460] sd 32:0:1:0: [sdb] CDB:
    [ 1636.614462] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1636.615007] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.615017] sd 32:0:1:0: [sdb]
    [ 1636.615021] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.615025] sd 32:0:1:0: [sdb]
    [ 1636.615028] Sense Key : Not Ready [current]
    [ 1636.615034] sd 32:0:1:0: [sdb]
    [ 1636.615037] Add. Sense: No additional sense information
    [ 1636.615041] sd 32:0:1:0: [sdb] CDB:
    [ 1636.615044] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1636.615600] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.615610] sd 32:0:1:0: [sdb]
    [ 1636.615614] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.615618] sd 32:0:1:0: [sdb]
    [ 1636.615620] Sense Key : Not Ready [current]
    [ 1636.615627] sd 32:0:1:0: [sdb]
    [ 1636.615630] Add. Sense: No additional sense information
    [ 1636.615634] sd 32:0:1:0: [sdb] CDB:
    [ 1636.615636] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1636.616127] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.616133] sd 32:0:1:0: [sdb]
    [ 1636.616136] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.616140] sd 32:0:1:0: [sdb]
    [ 1636.616142] Sense Key : Not Ready [current]
    [ 1636.616147] sd 32:0:1:0: [sdb]
    [ 1636.616149] Add. Sense: No additional sense information
    [ 1636.616153] sd 32:0:1:0: [sdb] CDB:
    [ 1636.616155] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1636.616603] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.616608] sd 32:0:1:0: [sdb]
    [ 1636.616611] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.616614] sd 32:0:1:0: [sdb]
    [ 1636.616617] Sense Key : Not Ready [current]
    [ 1636.616621] sd 32:0:1:0: [sdb]
    [ 1636.616624] Add. Sense: No additional sense information
    [ 1636.616627] sd 32:0:1:0: [sdb] CDB:
    [ 1636.616629] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1636.617629] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.617664] sd 32:0:1:0: [sdb]
    [ 1636.617668] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.617672] sd 32:0:1:0: [sdb]
    [ 1636.617675] Sense Key : Not Ready [current]
    [ 1636.617681] sd 32:0:1:0: [sdb]
    [ 1636.617684] Add. Sense: No additional sense information
    [ 1636.617688] sd 32:0:1:0: [sdb] CDB:
    [ 1636.617690] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1636.618525] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.618560] sd 32:0:1:0: [sdb]
    [ 1636.618564] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.618568] sd 32:0:1:0: [sdb]
    [ 1636.618571] Sense Key : Not Ready [current]
    [ 1636.618577] sd 32:0:1:0: [sdb]
    [ 1636.618580] Add. Sense: No additional sense information
    [ 1636.618584] sd 32:0:1:0: [sdb] CDB:
    [ 1636.618587] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1636.619444] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.619474] sd 32:0:1:0: [sdb]
    [ 1636.619478] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.619482] sd 32:0:1:0: [sdb]
    [ 1636.619484] Sense Key : Not Ready [current]
    [ 1636.619490] sd 32:0:1:0: [sdb]
    [ 1636.619493] Add. Sense: No additional sense information
    [ 1636.619498] sd 32:0:1:0: [sdb] CDB:
    [ 1636.619500] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.620416] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.620452] sd 32:0:1:0: [sdb]
    [ 1636.620456] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.620460] sd 32:0:1:0: [sdb]
    [ 1636.620463] Sense Key : Not Ready [current]
    [ 1636.620469] sd 32:0:1:0: [sdb]
    [ 1636.620473] Add. Sense: No additional sense information
    [ 1636.620477] sd 32:0:1:0: [sdb] CDB:
    [ 1636.620479] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.621290] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.621325] sd 32:0:1:0: [sdb]
    [ 1636.621330] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.621333] sd 32:0:1:0: [sdb]
    [ 1636.621336] Sense Key : Not Ready [current]
    [ 1636.621342] sd 32:0:1:0: [sdb]
    [ 1636.621345] Add. Sense: No additional sense information
    [ 1636.621350] sd 32:0:1:0: [sdb] CDB:
    [ 1636.621352] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.622128] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.622163] sd 32:0:1:0: [sdb]
    [ 1636.622167] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.622171] sd 32:0:1:0: [sdb]
    [ 1636.622174] Sense Key : Not Ready [current]
    [ 1636.622180] sd 32:0:1:0: [sdb]
    [ 1636.622183] Add. Sense: No additional sense information
    [ 1636.622187] sd 32:0:1:0: [sdb] CDB:
    [ 1636.622190] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1636.622904] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.622939] sd 32:0:1:0: [sdb]
    [ 1636.622943] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.622947] sd 32:0:1:0: [sdb]
    [ 1636.622950] Sense Key : Not Ready [current]
    [ 1636.622956] sd 32:0:1:0: [sdb]
    [ 1636.622959] Add. Sense: No additional sense information
    [ 1636.622963] sd 32:0:1:0: [sdb] CDB:
    [ 1636.622966] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.623735] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.623826] sd 32:0:1:0: [sdb]
    [ 1636.623831] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.623835] sd 32:0:1:0: [sdb]
    [ 1636.623837] Sense Key : Not Ready [current]
    [ 1636.623844] sd 32:0:1:0: [sdb]
    [ 1636.623847] Add. Sense: No additional sense information
    [ 1636.623851] sd 32:0:1:0: [sdb] CDB:
    [ 1636.623853] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.624603] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.624638] sd 32:0:1:0: [sdb]
    [ 1636.624643] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.624646] sd 32:0:1:0: [sdb]
    [ 1636.624649] Sense Key : Not Ready [current]
    [ 1636.624655] sd 32:0:1:0: [sdb]
    [ 1636.624659] Add. Sense: No additional sense information
    [ 1636.624663] sd 32:0:1:0: [sdb] CDB:
    [ 1636.624665] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.625616] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.625651] sd 32:0:1:0: [sdb]
    [ 1636.625655] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.625659] sd 32:0:1:0: [sdb]
    [ 1636.625662] Sense Key : Not Ready [current]
    [ 1636.625668] sd 32:0:1:0: [sdb]
    [ 1636.625671] Add. Sense: No additional sense information
    [ 1636.625675] sd 32:0:1:0: [sdb] CDB:
    [ 1636.625678] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1636.626485] sd 32:0:1:0: [sdb] Device not ready
    [ 1636.626520] sd 32:0:1:0: [sdb]
    [ 1636.626525] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1636.626529] sd 32:0:1:0: [sdb]
    [ 1636.626531] Sense Key : Not Ready [current]
    [ 1636.626538] sd 32:0:1:0: [sdb]
    [ 1636.626541] Add. Sense: No additional sense information
    [ 1636.626545] sd 32:0:1:0: [sdb] CDB:
    [ 1636.626548] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.839080] blk_update_request: 148 callbacks suppressed
    [ 1648.839090] end_request: I/O error, dev fd0, sector 0
    [ 1648.849986] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.849997] sd 32:0:1:0: [sdb]
    [ 1648.850002] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.850007] sd 32:0:1:0: [sdb]
    [ 1648.850010] Sense Key : Not Ready [current]
    [ 1648.850016] sd 32:0:1:0: [sdb]
    [ 1648.850020] Add. Sense: No additional sense information
    [ 1648.850024] sd 32:0:1:0: [sdb] CDB:
    [ 1648.850027] Read(10): 28 00 00 e6 df 80 00 00 08 00
    [ 1648.850041] end_request: I/O error, dev sdb, sector 15130496
    [ 1648.850048] quiet_error: 147 callbacks suppressed
    [ 1648.850053] Buffer I/O error on device sdb, logical block 1891312
    [ 1648.850961] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.850968] sd 32:0:1:0: [sdb]
    [ 1648.850971] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.850975] sd 32:0:1:0: [sdb]
    [ 1648.850977] Sense Key : Not Ready [current]
    [ 1648.850983] sd 32:0:1:0: [sdb]
    [ 1648.850985] Add. Sense: No additional sense information
    [ 1648.850989] sd 32:0:1:0: [sdb] CDB:
    [ 1648.850992] Read(10): 28 00 00 e6 df f0 00 00 08 00
    [ 1648.851005] end_request: I/O error, dev sdb, sector 15130608
    [ 1648.851010] Buffer I/O error on device sdb, logical block 1891326
    [ 1648.851647] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.851654] sd 32:0:1:0: [sdb]
    [ 1648.851657] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.851661] sd 32:0:1:0: [sdb]
    [ 1648.851663] Sense Key : Not Ready [current]
    [ 1648.851668] sd 32:0:1:0: [sdb]
    [ 1648.851671] Add. Sense: No additional sense information
    [ 1648.851674] sd 32:0:1:0: [sdb] CDB:
    [ 1648.851677] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.851689] end_request: I/O error, dev sdb, sector 0
    [ 1648.851694] Buffer I/O error on device sdb, logical block 0
    [ 1648.852129] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.852135] sd 32:0:1:0: [sdb]
    [ 1648.852138] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.852141] sd 32:0:1:0: [sdb]
    [ 1648.852143] Sense Key : Not Ready [current]
    [ 1648.852148] sd 32:0:1:0: [sdb]
    [ 1648.852151] Add. Sense: No additional sense information
    [ 1648.852154] sd 32:0:1:0: [sdb] CDB:
    [ 1648.852157] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.852168] end_request: I/O error, dev sdb, sector 8
    [ 1648.852173] Buffer I/O error on device sdb, logical block 1
    [ 1648.852626] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.852632] sd 32:0:1:0: [sdb]
    [ 1648.852635] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.852639] sd 32:0:1:0: [sdb]
    [ 1648.852641] Sense Key : Not Ready [current]
    [ 1648.852646] sd 32:0:1:0: [sdb]
    [ 1648.852648] Add. Sense: No additional sense information
    [ 1648.852652] sd 32:0:1:0: [sdb] CDB:
    [ 1648.852654] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1648.852666] end_request: I/O error, dev sdb, sector 15130616
    [ 1648.852671] Buffer I/O error on device sdb, logical block 1891327
    [ 1648.853234] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.853240] sd 32:0:1:0: [sdb]
    [ 1648.853243] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.853246] sd 32:0:1:0: [sdb]
    [ 1648.853248] Sense Key : Not Ready [current]
    [ 1648.853253] sd 32:0:1:0: [sdb]
    [ 1648.853256] Add. Sense: No additional sense information
    [ 1648.853259] sd 32:0:1:0: [sdb] CDB:
    [ 1648.853262] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1648.853274] end_request: I/O error, dev sdb, sector 15130616
    [ 1648.853279] Buffer I/O error on device sdb, logical block 1891327
    [ 1648.853976] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.853982] sd 32:0:1:0: [sdb]
    [ 1648.853985] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.853988] sd 32:0:1:0: [sdb]
    [ 1648.853990] Sense Key : Not Ready [current]
    [ 1648.853995] sd 32:0:1:0: [sdb]
    [ 1648.853998] Add. Sense: No additional sense information
    [ 1648.854001] sd 32:0:1:0: [sdb] CDB:
    [ 1648.854003] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1648.854015] end_request: I/O error, dev sdb, sector 15130616
    [ 1648.854020] Buffer I/O error on device sdb, logical block 1891327
    [ 1648.855263] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.855270] sd 32:0:1:0: [sdb]
    [ 1648.855273] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.855276] sd 32:0:1:0: [sdb]
    [ 1648.855278] Sense Key : Not Ready [current]
    [ 1648.855283] sd 32:0:1:0: [sdb]
    [ 1648.855286] Add. Sense: No additional sense information
    [ 1648.855289] sd 32:0:1:0: [sdb] CDB:
    [ 1648.855291] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1648.855303] end_request: I/O error, dev sdb, sector 15130616
    [ 1648.855309] Buffer I/O error on device sdb, logical block 1891327
    [ 1648.855758] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.855764] sd 32:0:1:0: [sdb]
    [ 1648.855766] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.855770] sd 32:0:1:0: [sdb]
    [ 1648.855772] Sense Key : Not Ready [current]
    [ 1648.855776] sd 32:0:1:0: [sdb]
    [ 1648.855779] Add. Sense: No additional sense information
    [ 1648.855782] sd 32:0:1:0: [sdb] CDB:
    [ 1648.855785] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1648.855796] end_request: I/O error, dev sdb, sector 15130616
    [ 1648.855801] Buffer I/O error on device sdb, logical block 1891327
    [ 1648.856290] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.856295] sd 32:0:1:0: [sdb]
    [ 1648.856298] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.856302] sd 32:0:1:0: [sdb]
    [ 1648.856304] Sense Key : Not Ready [current]
    [ 1648.856308] sd 32:0:1:0: [sdb]
    [ 1648.856311] Add. Sense: No additional sense information
    [ 1648.856314] sd 32:0:1:0: [sdb] CDB:
    [ 1648.856316] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1648.856329] Buffer I/O error on device sdb, logical block 1891327
    [ 1648.856731] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.856737] sd 32:0:1:0: [sdb]
    [ 1648.856740] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.856744] sd 32:0:1:0: [sdb]
    [ 1648.856746] Sense Key : Not Ready [current]
    [ 1648.856750] sd 32:0:1:0: [sdb]
    [ 1648.856753] Add. Sense: No additional sense information
    [ 1648.856756] sd 32:0:1:0: [sdb] CDB:
    [ 1648.856758] Read(10): 28 00 00 e6 df c0 00 00 08 00
    [ 1648.857255] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.857262] sd 32:0:1:0: [sdb]
    [ 1648.857266] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.857269] sd 32:0:1:0: [sdb]
    [ 1648.857271] Sense Key : Not Ready [current]
    [ 1648.857276] sd 32:0:1:0: [sdb]
    [ 1648.857278] Add. Sense: No additional sense information
    [ 1648.857282] sd 32:0:1:0: [sdb] CDB:
    [ 1648.857284] Read(10): 28 00 00 e6 df f0 00 00 08 00
    [ 1648.857737] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.857743] sd 32:0:1:0: [sdb]
    [ 1648.857746] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.857749] sd 32:0:1:0: [sdb]
    [ 1648.857751] Sense Key : Not Ready [current]
    [ 1648.857755] sd 32:0:1:0: [sdb]
    [ 1648.857758] Add. Sense: No additional sense information
    [ 1648.857761] sd 32:0:1:0: [sdb] CDB:
    [ 1648.857763] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.858193] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.858199] sd 32:0:1:0: [sdb]
    [ 1648.858202] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.858206] sd 32:0:1:0: [sdb]
    [ 1648.858208] Sense Key : Not Ready [current]
    [ 1648.858212] sd 32:0:1:0: [sdb]
    [ 1648.858214] Add. Sense: No additional sense information
    [ 1648.858218] sd 32:0:1:0: [sdb] CDB:
    [ 1648.858221] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.859488] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.859494] sd 32:0:1:0: [sdb]
    [ 1648.859498] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.859501] sd 32:0:1:0: [sdb]
    [ 1648.859503] Sense Key : Not Ready [current]
    [ 1648.859508] sd 32:0:1:0: [sdb]
    [ 1648.859510] Add. Sense: No additional sense information
    [ 1648.859513] sd 32:0:1:0: [sdb] CDB:
    [ 1648.859515] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1648.860233] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.860240] sd 32:0:1:0: [sdb]
    [ 1648.860243] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.860246] sd 32:0:1:0: [sdb]
    [ 1648.860248] Sense Key : Not Ready [current]
    [ 1648.860253] sd 32:0:1:0: [sdb]
    [ 1648.860255] Add. Sense: No additional sense information
    [ 1648.860259] sd 32:0:1:0: [sdb] CDB:
    [ 1648.860261] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1648.860846] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.860855] sd 32:0:1:0: [sdb]
    [ 1648.860859] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.860864] sd 32:0:1:0: [sdb]
    [ 1648.860868] Sense Key : Not Ready [current]
    [ 1648.860875] sd 32:0:1:0: [sdb]
    [ 1648.860879] Add. Sense: No additional sense information
    [ 1648.860884] sd 32:0:1:0: [sdb] CDB:
    [ 1648.860888] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1648.861484] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.861493] sd 32:0:1:0: [sdb]
    [ 1648.861497] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.861503] sd 32:0:1:0: [sdb]
    [ 1648.861507] Sense Key : Not Ready [current]
    [ 1648.861513] sd 32:0:1:0: [sdb]
    [ 1648.861517] Add. Sense: No additional sense information
    [ 1648.861523] sd 32:0:1:0: [sdb] CDB:
    [ 1648.861526] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.862026] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.862035] sd 32:0:1:0: [sdb]
    [ 1648.862039] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.862044] sd 32:0:1:0: [sdb]
    [ 1648.862048] Sense Key : Not Ready [current]
    [ 1648.862055] sd 32:0:1:0: [sdb]
    [ 1648.862060] Add. Sense: No additional sense information
    [ 1648.862066] sd 32:0:1:0: [sdb] CDB:
    [ 1648.862069] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.863053] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.863062] sd 32:0:1:0: [sdb]
    [ 1648.863066] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.863072] sd 32:0:1:0: [sdb]
    [ 1648.863075] Sense Key : Not Ready [current]
    [ 1648.863082] sd 32:0:1:0: [sdb]
    [ 1648.863086] Add. Sense: No additional sense information
    [ 1648.863092] sd 32:0:1:0: [sdb] CDB:
    [ 1648.863095] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.868131] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.868144] sd 32:0:1:0: [sdb]
    [ 1648.868150] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.868155] sd 32:0:1:0: [sdb]
    [ 1648.868158] Sense Key : Not Ready [current]
    [ 1648.868166] sd 32:0:1:0: [sdb]
    [ 1648.868170] Add. Sense: No additional sense information
    [ 1648.868176] sd 32:0:1:0: [sdb] CDB:
    [ 1648.868179] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.869141] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.869151] sd 32:0:1:0: [sdb]
    [ 1648.869155] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.869161] sd 32:0:1:0: [sdb]
    [ 1648.869164] Sense Key : Not Ready [current]
    [ 1648.869171] sd 32:0:1:0: [sdb]
    [ 1648.869176] Add. Sense: No additional sense information
    [ 1648.869181] sd 32:0:1:0: [sdb] CDB:
    [ 1648.869185] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.869641] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.869649] sd 32:0:1:0: [sdb]
    [ 1648.869653] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.869658] sd 32:0:1:0: [sdb]
    [ 1648.869662] Sense Key : Not Ready [current]
    [ 1648.869669] sd 32:0:1:0: [sdb]
    [ 1648.869673] Add. Sense: No additional sense information
    [ 1648.869679] sd 32:0:1:0: [sdb] CDB:
    [ 1648.869683] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.870074] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.870082] sd 32:0:1:0: [sdb]
    [ 1648.870087] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.870092] sd 32:0:1:0: [sdb]
    [ 1648.870095] Sense Key : Not Ready [current]
    [ 1648.870102] sd 32:0:1:0: [sdb]
    [ 1648.870105] Add. Sense: No additional sense information
    [ 1648.870112] sd 32:0:1:0: [sdb] CDB:
    [ 1648.870115] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.870639] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.870647] sd 32:0:1:0: [sdb]
    [ 1648.870652] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.870657] sd 32:0:1:0: [sdb]
    [ 1648.870660] Sense Key : Not Ready [current]
    [ 1648.870666] sd 32:0:1:0: [sdb]
    [ 1648.870670] Add. Sense: No additional sense information
    [ 1648.870675] sd 32:0:1:0: [sdb] CDB:
    [ 1648.870678] Read(10): 28 00 00 00 08 00 00 00 08 00
    [ 1648.871442] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.871453] sd 32:0:1:0: [sdb]
    [ 1648.871457] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.871461] sd 32:0:1:0: [sdb]
    [ 1648.871464] Sense Key : Not Ready [current]
    [ 1648.871469] sd 32:0:1:0: [sdb]
    [ 1648.871472] Add. Sense: No additional sense information
    [ 1648.871476] sd 32:0:1:0: [sdb] CDB:
    [ 1648.871478] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.872029] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.872035] sd 32:0:1:0: [sdb]
    [ 1648.872037] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.872040] sd 32:0:1:0: [sdb]
    [ 1648.872043] Sense Key : Not Ready [current]
    [ 1648.872047] sd 32:0:1:0: [sdb]
    [ 1648.872050] Add. Sense: No additional sense information
    [ 1648.872053] sd 32:0:1:0: [sdb] CDB:
    [ 1648.872055] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.880108] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.880120] sd 32:0:1:0: [sdb]
    [ 1648.880125] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.880129] sd 32:0:1:0: [sdb]
    [ 1648.880132] Sense Key : Not Ready [current]
    [ 1648.880138] sd 32:0:1:0: [sdb]
    [ 1648.880141] Add. Sense: No additional sense information
    [ 1648.880146] sd 32:0:1:0: [sdb] CDB:
    [ 1648.880148] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.881574] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.881588] sd 32:0:1:0: [sdb]
    [ 1648.881594] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.881598] sd 32:0:1:0: [sdb]
    [ 1648.881601] Sense Key : Not Ready [current]
    [ 1648.881609] sd 32:0:1:0: [sdb]
    [ 1648.881613] Add. Sense: No additional sense information
    [ 1648.881618] sd 32:0:1:0: [sdb] CDB:
    [ 1648.881621] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.887629] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.887642] sd 32:0:1:0: [sdb]
    [ 1648.887648] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.887652] sd 32:0:1:0: [sdb]
    [ 1648.887655] Sense Key : Not Ready [current]
    [ 1648.887662] sd 32:0:1:0: [sdb]
    [ 1648.887665] Add. Sense: No additional sense information
    [ 1648.887669] sd 32:0:1:0: [sdb] CDB:
    [ 1648.887673] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.889447] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.889468] sd 32:0:1:0: [sdb]
    [ 1648.889475] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.889484] sd 32:0:1:0: [sdb]
    [ 1648.889488] Sense Key : Not Ready [current]
    [ 1648.889499] sd 32:0:1:0: [sdb]
    [ 1648.889505] Add. Sense: No additional sense information
    [ 1648.889513] sd 32:0:1:0: [sdb] CDB:
    [ 1648.889518] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.890638] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.890648] sd 32:0:1:0: [sdb]
    [ 1648.890654] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.890659] sd 32:0:1:0: [sdb]
    [ 1648.890663] Sense Key : Not Ready [current]
    [ 1648.890672] sd 32:0:1:0: [sdb]
    [ 1648.890676] Add. Sense: No additional sense information
    [ 1648.890683] sd 32:0:1:0: [sdb] CDB:
    [ 1648.890688] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.894030] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.894059] sd 32:0:1:0: [sdb]
    [ 1648.894067] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.894072] sd 32:0:1:0: [sdb]
    [ 1648.894076] Sense Key : Not Ready [current]
    [ 1648.894084] sd 32:0:1:0: [sdb]
    [ 1648.894089] Add. Sense: No additional sense information
    [ 1648.894094] sd 32:0:1:0: [sdb] CDB:
    [ 1648.894097] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.895215] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.895230] sd 32:0:1:0: [sdb]
    [ 1648.895238] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.895244] sd 32:0:1:0: [sdb]
    [ 1648.895248] Sense Key : Not Ready [current]
    [ 1648.895257] sd 32:0:1:0: [sdb]
    [ 1648.895262] Add. Sense: No additional sense information
    [ 1648.895267] sd 32:0:1:0: [sdb] CDB:
    [ 1648.895272] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.897871] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.897886] sd 32:0:1:0: [sdb]
    [ 1648.897891] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.897895] sd 32:0:1:0: [sdb]
    [ 1648.897899] Sense Key : Not Ready [current]
    [ 1648.897908] sd 32:0:1:0: [sdb]
    [ 1648.897912] Add. Sense: No additional sense information
    [ 1648.897916] sd 32:0:1:0: [sdb] CDB:
    [ 1648.897919] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.899192] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.899201] sd 32:0:1:0: [sdb]
    [ 1648.899206] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.899209] sd 32:0:1:0: [sdb]
    [ 1648.899212] Sense Key : Not Ready [current]
    [ 1648.899218] sd 32:0:1:0: [sdb]
    [ 1648.899221] Add. Sense: No additional sense information
    [ 1648.899225] sd 32:0:1:0: [sdb] CDB:
    [ 1648.899228] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.900189] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.900200] sd 32:0:1:0: [sdb]
    [ 1648.900205] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.900209] sd 32:0:1:0: [sdb]
    [ 1648.900212] Sense Key : Not Ready [current]
    [ 1648.900217] sd 32:0:1:0: [sdb]
    [ 1648.900220] Add. Sense: No additional sense information
    [ 1648.900224] sd 32:0:1:0: [sdb] CDB:
    [ 1648.900227] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.901171] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.901187] sd 32:0:1:0: [sdb]
    [ 1648.901192] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.901196] sd 32:0:1:0: [sdb]
    [ 1648.901199] Sense Key : Not Ready [current]
    [ 1648.901206] sd 32:0:1:0: [sdb]
    [ 1648.901210] Add. Sense: No additional sense information
    [ 1648.901214] sd 32:0:1:0: [sdb] CDB:
    [ 1648.901217] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.902147] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.902159] sd 32:0:1:0: [sdb]
    [ 1648.902164] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.902168] sd 32:0:1:0: [sdb]
    [ 1648.902171] Sense Key : Not Ready [current]
    [ 1648.902178] sd 32:0:1:0: [sdb]
    [ 1648.902181] Add. Sense: No additional sense information
    [ 1648.902186] sd 32:0:1:0: [sdb] CDB:
    [ 1648.902188] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.902764] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.902770] sd 32:0:1:0: [sdb]
    [ 1648.902773] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.902777] sd 32:0:1:0: [sdb]
    [ 1648.902779] Sense Key : Not Ready [current]
    [ 1648.902784] sd 32:0:1:0: [sdb]
    [ 1648.902787] Add. Sense: No additional sense information
    [ 1648.902791] sd 32:0:1:0: [sdb] CDB:
    [ 1648.902793] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.903921] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.903960] sd 32:0:1:0: [sdb]
    [ 1648.903965] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.903969] sd 32:0:1:0: [sdb]
    [ 1648.903972] Sense Key : Not Ready [current]
    [ 1648.903978] sd 32:0:1:0: [sdb]
    [ 1648.903981] Add. Sense: No additional sense information
    [ 1648.903986] sd 32:0:1:0: [sdb] CDB:
    [ 1648.904032] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.904930] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.904975] sd 32:0:1:0: [sdb]
    [ 1648.904980] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.904984] sd 32:0:1:0: [sdb]
    [ 1648.904987] Sense Key : Not Ready [current]
    [ 1648.904994] sd 32:0:1:0: [sdb]
    [ 1648.905051] Add. Sense: No additional sense information
    [ 1648.905066] sd 32:0:1:0: [sdb] CDB:
    [ 1648.905071] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.906181] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.906227] sd 32:0:1:0: [sdb]
    [ 1648.906232] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.906236] sd 32:0:1:0: [sdb]
    [ 1648.906239] Sense Key : Not Ready [current]
    [ 1648.906245] sd 32:0:1:0: [sdb]
    [ 1648.906249] Add. Sense: No additional sense information
    [ 1648.906254] sd 32:0:1:0: [sdb] CDB:
    [ 1648.906256] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.907148] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.907177] sd 32:0:1:0: [sdb]
    [ 1648.907181] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.907185] sd 32:0:1:0: [sdb]
    [ 1648.907187] Sense Key : Not Ready [current]
    [ 1648.907193] sd 32:0:1:0: [sdb]
    [ 1648.907195] Add. Sense: No additional sense information
    [ 1648.907199] sd 32:0:1:0: [sdb] CDB:
    [ 1648.907201] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1648.907906] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.907942] sd 32:0:1:0: [sdb]
    [ 1648.907946] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.907950] sd 32:0:1:0: [sdb]
    [ 1648.907952] Sense Key : Not Ready [current]
    [ 1648.907959] sd 32:0:1:0: [sdb]
    [ 1648.907962] Add. Sense: No additional sense information
    [ 1648.907966] sd 32:0:1:0: [sdb] CDB:
    [ 1648.907968] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1648.908790] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.908825] sd 32:0:1:0: [sdb]
    [ 1648.908830] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.908834] sd 32:0:1:0: [sdb]
    [ 1648.908836] Sense Key : Not Ready [current]
    [ 1648.908843] sd 32:0:1:0: [sdb]
    [ 1648.908846] Add. Sense: No additional sense information
    [ 1648.908850] sd 32:0:1:0: [sdb] CDB:
    [ 1648.908853] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1648.909653] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.909683] sd 32:0:1:0: [sdb]
    [ 1648.909687] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.909691] sd 32:0:1:0: [sdb]
    [ 1648.909694] Sense Key : Not Ready [current]
    [ 1648.909700] sd 32:0:1:0: [sdb]
    [ 1648.909703] Add. Sense: No additional sense information
    [ 1648.909708] sd 32:0:1:0: [sdb] CDB:
    [ 1648.909710] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1648.910641] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.910676] sd 32:0:1:0: [sdb]
    [ 1648.910681] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.910684] sd 32:0:1:0: [sdb]
    [ 1648.910687] Sense Key : Not Ready [current]
    [ 1648.910694] sd 32:0:1:0: [sdb]
    [ 1648.910697] Add. Sense: No additional sense information
    [ 1648.910701] sd 32:0:1:0: [sdb] CDB:
    [ 1648.910703] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1648.911376] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.911406] sd 32:0:1:0: [sdb]
    [ 1648.911409] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.911413] sd 32:0:1:0: [sdb]
    [ 1648.911415] Sense Key : Not Ready [current]
    [ 1648.911420] sd 32:0:1:0: [sdb]
    [ 1648.911423] Add. Sense: No additional sense information
    [ 1648.911427] sd 32:0:1:0: [sdb] CDB:
    [ 1648.911429] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1648.912320] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.912362] sd 32:0:1:0: [sdb]
    [ 1648.912367] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.912371] sd 32:0:1:0: [sdb]
    [ 1648.912374] Sense Key : Not Ready [current]
    [ 1648.912381] sd 32:0:1:0: [sdb]
    [ 1648.912384] Add. Sense: No additional sense information
    [ 1648.912388] sd 32:0:1:0: [sdb] CDB:
    [ 1648.912390] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1648.913093] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.913125] sd 32:0:1:0: [sdb]
    [ 1648.913129] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.913132] sd 32:0:1:0: [sdb]
    [ 1648.913135] Sense Key : Not Ready [current]
    [ 1648.913140] sd 32:0:1:0: [sdb]
    [ 1648.913143] Add. Sense: No additional sense information
    [ 1648.913147] sd 32:0:1:0: [sdb] CDB:
    [ 1648.913149] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1648.913820] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.913856] sd 32:0:1:0: [sdb]
    [ 1648.913861] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.913865] sd 32:0:1:0: [sdb]
    [ 1648.913868] Sense Key : Not Ready [current]
    [ 1648.913874] sd 32:0:1:0: [sdb]
    [ 1648.913877] Add. Sense: No additional sense information
    [ 1648.913881] sd 32:0:1:0: [sdb] CDB:
    [ 1648.913884] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1648.914756] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.914794] sd 32:0:1:0: [sdb]
    [ 1648.914798] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.914802] sd 32:0:1:0: [sdb]
    [ 1648.914805] Sense Key : Not Ready [current]
    [ 1648.914812] sd 32:0:1:0: [sdb]
    [ 1648.914815] Add. Sense: No additional sense information
    [ 1648.914819] sd 32:0:1:0: [sdb] CDB:
    [ 1648.914822] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1648.915712] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.915749] sd 32:0:1:0: [sdb]
    [ 1648.915754] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.915758] sd 32:0:1:0: [sdb]
    [ 1648.915761] Sense Key : Not Ready [current]
    [ 1648.915767] sd 32:0:1:0: [sdb]
    [ 1648.915771] Add. Sense: No additional sense information
    [ 1648.915775] sd 32:0:1:0: [sdb] CDB:
    [ 1648.915778] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1648.916333] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.916361] sd 32:0:1:0: [sdb]
    [ 1648.916364] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.916368] sd 32:0:1:0: [sdb]
    [ 1648.916370] Sense Key : Not Ready [current]
    [ 1648.916375] sd 32:0:1:0: [sdb]
    [ 1648.916377] Add. Sense: No additional sense information
    [ 1648.916381] sd 32:0:1:0: [sdb] CDB:
    [ 1648.916383] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1648.916806] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.916832] sd 32:0:1:0: [sdb]
    [ 1648.916835] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.916838] sd 32:0:1:0: [sdb]
    [ 1648.916840] Sense Key : Not Ready [current]
    [ 1648.916845] sd 32:0:1:0: [sdb]
    [ 1648.916847] Add. Sense: No additional sense information
    [ 1648.916851] sd 32:0:1:0: [sdb] CDB:
    [ 1648.916852] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.917264] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.917269] sd 32:0:1:0: [sdb]
    [ 1648.917272] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.917275] sd 32:0:1:0: [sdb]
    [ 1648.917278] Sense Key : Not Ready [current]
    [ 1648.917282] sd 32:0:1:0: [sdb]
    [ 1648.917285] Add. Sense: No additional sense information
    [ 1648.917288] sd 32:0:1:0: [sdb] CDB:
    [ 1648.917290] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.917799] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.917809] sd 32:0:1:0: [sdb]
    [ 1648.917813] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.917817] sd 32:0:1:0: [sdb]
    [ 1648.917819] Sense Key : Not Ready [current]
    [ 1648.917826] sd 32:0:1:0: [sdb]
    [ 1648.917829] Add. Sense: No additional sense information
    [ 1648.917833] sd 32:0:1:0: [sdb] CDB:
    [ 1648.917835] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.918398] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.918408] sd 32:0:1:0: [sdb]
    [ 1648.918412] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.918416] sd 32:0:1:0: [sdb]
    [ 1648.918419] Sense Key : Not Ready [current]
    [ 1648.918425] sd 32:0:1:0: [sdb]
    [ 1648.918428] Add. Sense: No additional sense information
    [ 1648.918432] sd 32:0:1:0: [sdb] CDB:
    [ 1648.918434] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.918870] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.918875] sd 32:0:1:0: [sdb]
    [ 1648.918878] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.918881] sd 32:0:1:0: [sdb]
    [ 1648.918884] Sense Key : Not Ready [current]
    [ 1648.918889] sd 32:0:1:0: [sdb]
    [ 1648.918891] Add. Sense: No additional sense information
    [ 1648.918895] sd 32:0:1:0: [sdb] CDB:
    [ 1648.918897] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1648.919801] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.919836] sd 32:0:1:0: [sdb]
    [ 1648.919841] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.919845] sd 32:0:1:0: [sdb]
    [ 1648.919847] Sense Key : Not Ready [current]
    [ 1648.919854] sd 32:0:1:0: [sdb]
    [ 1648.919857] Add. Sense: No additional sense information
    [ 1648.919861] sd 32:0:1:0: [sdb] CDB:
    [ 1648.919863] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1648.920273] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.920278] sd 32:0:1:0: [sdb]
    [ 1648.920282] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.920285] sd 32:0:1:0: [sdb]
    [ 1648.920287] Sense Key : Not Ready [current]
    [ 1648.920292] sd 32:0:1:0: [sdb]
    [ 1648.920295] Add. Sense: No additional sense information
    [ 1648.920298] sd 32:0:1:0: [sdb] CDB:
    [ 1648.920300] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1648.920814] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.920820] sd 32:0:1:0: [sdb]
    [ 1648.920823] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.920827] sd 32:0:1:0: [sdb]
    [ 1648.920829] Sense Key : Not Ready [current]
    [ 1648.920833] sd 32:0:1:0: [sdb]
    [ 1648.920836] Add. Sense: No additional sense information
    [ 1648.920840] sd 32:0:1:0: [sdb] CDB:
    [ 1648.920842] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1648.921271] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.921277] sd 32:0:1:0: [sdb]
    [ 1648.921280] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.921283] sd 32:0:1:0: [sdb]
    [ 1648.921285] Sense Key : Not Ready [current]
    [ 1648.921290] sd 32:0:1:0: [sdb]
    [ 1648.921292] Add. Sense: No additional sense information
    [ 1648.921296] sd 32:0:1:0: [sdb] CDB:
    [ 1648.921298] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1648.921778] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.921787] sd 32:0:1:0: [sdb]
    [ 1648.921791] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.921795] sd 32:0:1:0: [sdb]
    [ 1648.921798] Sense Key : Not Ready [current]
    [ 1648.921805] sd 32:0:1:0: [sdb]
    [ 1648.921808] Add. Sense: No additional sense information
    [ 1648.921812] sd 32:0:1:0: [sdb] CDB:
    [ 1648.921814] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1648.922389] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.922398] sd 32:0:1:0: [sdb]
    [ 1648.922402] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.922406] sd 32:0:1:0: [sdb]
    [ 1648.922409] Sense Key : Not Ready [current]
    [ 1648.922415] sd 32:0:1:0: [sdb]
    [ 1648.922418] Add. Sense: No additional sense information
    [ 1648.922423] sd 32:0:1:0: [sdb] CDB:
    [ 1648.922425] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.922859] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.922864] sd 32:0:1:0: [sdb]
    [ 1648.922867] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.922870] sd 32:0:1:0: [sdb]
    [ 1648.922873] Sense Key : Not Ready [current]
    [ 1648.922878] sd 32:0:1:0: [sdb]
    [ 1648.922880] Add. Sense: No additional sense information
    [ 1648.922884] sd 32:0:1:0: [sdb] CDB:
    [ 1648.922886] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.923843] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.923879] sd 32:0:1:0: [sdb]
    [ 1648.923884] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.923888] sd 32:0:1:0: [sdb]
    [ 1648.923890] Sense Key : Not Ready [current]
    [ 1648.923897] sd 32:0:1:0: [sdb]
    [ 1648.923900] Add. Sense: No additional sense information
    [ 1648.923904] sd 32:0:1:0: [sdb] CDB:
    [ 1648.923906] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.924328] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.924334] sd 32:0:1:0: [sdb]
    [ 1648.924338] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.924341] sd 32:0:1:0: [sdb]
    [ 1648.924343] Sense Key : Not Ready [current]
    [ 1648.924349] sd 32:0:1:0: [sdb]
    [ 1648.924351] Add. Sense: No additional sense information
    [ 1648.924355] sd 32:0:1:0: [sdb] CDB:
    [ 1648.924357] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.924961] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.924970] sd 32:0:1:0: [sdb]
    [ 1648.924974] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.924978] sd 32:0:1:0: [sdb]
    [ 1648.924981] Sense Key : Not Ready [current]
    [ 1648.924987] sd 32:0:1:0: [sdb]
    [ 1648.924990] Add. Sense: No additional sense information
    [ 1648.924995] sd 32:0:1:0: [sdb] CDB:
    [ 1648.924997] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.925554] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.925563] sd 32:0:1:0: [sdb]
    [ 1648.925567] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.925571] sd 32:0:1:0: [sdb]
    [ 1648.925573] Sense Key : Not Ready [current]
    [ 1648.925580] sd 32:0:1:0: [sdb]
    [ 1648.925583] Add. Sense: No additional sense information
    [ 1648.925587] sd 32:0:1:0: [sdb] CDB:
    [ 1648.925590] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.926142] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.926151] sd 32:0:1:0: [sdb]
    [ 1648.926155] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.926159] sd 32:0:1:0: [sdb]
    [ 1648.926162] Sense Key : Not Ready [current]
    [ 1648.926168] sd 32:0:1:0: [sdb]
    [ 1648.926171] Add. Sense: No additional sense information
    [ 1648.926175] sd 32:0:1:0: [sdb] CDB:
    [ 1648.926178] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1648.926762] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.926771] sd 32:0:1:0: [sdb]
    [ 1648.926775] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.926779] sd 32:0:1:0: [sdb]
    [ 1648.926782] Sense Key : Not Ready [current]
    [ 1648.926788] sd 32:0:1:0: [sdb]
    [ 1648.926792] Add. Sense: No additional sense information
    [ 1648.926796] sd 32:0:1:0: [sdb] CDB:
    [ 1648.926798] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1648.927234] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.927239] sd 32:0:1:0: [sdb]
    [ 1648.927242] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.927245] sd 32:0:1:0: [sdb]
    [ 1648.927248] Sense Key : Not Ready [current]
    [ 1648.927252] sd 32:0:1:0: [sdb]
    [ 1648.927255] Add. Sense: No additional sense information
    [ 1648.927258] sd 32:0:1:0: [sdb] CDB:
    [ 1648.927261] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1648.928226] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.928262] sd 32:0:1:0: [sdb]
    [ 1648.928266] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.928270] sd 32:0:1:0: [sdb]
    [ 1648.928273] Sense Key : Not Ready [current]
    [ 1648.928279] sd 32:0:1:0: [sdb]
    [ 1648.928282] Add. Sense: No additional sense information
    [ 1648.928286] sd 32:0:1:0: [sdb] CDB:
    [ 1648.928289] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1648.928734] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.928740] sd 32:0:1:0: [sdb]
    [ 1648.928743] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.928747] sd 32:0:1:0: [sdb]
    [ 1648.928749] Sense Key : Not Ready [current]
    [ 1648.928754] sd 32:0:1:0: [sdb]
    [ 1648.928757] Add. Sense: No additional sense information
    [ 1648.928761] sd 32:0:1:0: [sdb] CDB:
    [ 1648.928763] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1648.929299] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.929306] sd 32:0:1:0: [sdb]
    [ 1648.929309] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.929312] sd 32:0:1:0: [sdb]
    [ 1648.929315] Sense Key : Not Ready [current]
    [ 1648.929319] sd 32:0:1:0: [sdb]
    [ 1648.929322] Add. Sense: No additional sense information
    [ 1648.929325] sd 32:0:1:0: [sdb] CDB:
    [ 1648.929328] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1648.929807] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.929816] sd 32:0:1:0: [sdb]
    [ 1648.929820] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.929825] sd 32:0:1:0: [sdb]
    [ 1648.929827] Sense Key : Not Ready [current]
    [ 1648.929834] sd 32:0:1:0: [sdb]
    [ 1648.929837] Add. Sense: No additional sense information
    [ 1648.929841] sd 32:0:1:0: [sdb] CDB:
    [ 1648.929843] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1648.930398] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.930407] sd 32:0:1:0: [sdb]
    [ 1648.930411] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.930416] sd 32:0:1:0: [sdb]
    [ 1648.930418] Sense Key : Not Ready [current]
    [ 1648.930425] sd 32:0:1:0: [sdb]
    [ 1648.930428] Add. Sense: No additional sense information
    [ 1648.930432] sd 32:0:1:0: [sdb] CDB:
    [ 1648.930434] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1648.930868] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.930873] sd 32:0:1:0: [sdb]
    [ 1648.930876] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.930879] sd 32:0:1:0: [sdb]
    [ 1648.930882] Sense Key : Not Ready [current]
    [ 1648.930887] sd 32:0:1:0: [sdb]
    [ 1648.930889] Add. Sense: No additional sense information
    [ 1648.930893] sd 32:0:1:0: [sdb] CDB:
    [ 1648.930895] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1648.931551] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.931558] sd 32:0:1:0: [sdb]
    [ 1648.931561] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.931565] sd 32:0:1:0: [sdb]
    [ 1648.931567] Sense Key : Not Ready [current]
    [ 1648.931572] sd 32:0:1:0: [sdb]
    [ 1648.931575] Add. Sense: No additional sense information
    [ 1648.931578] sd 32:0:1:0: [sdb] CDB:
    [ 1648.931581] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1648.932007] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.932013] sd 32:0:1:0: [sdb]
    [ 1648.932016] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.932019] sd 32:0:1:0: [sdb]
    [ 1648.932021] Sense Key : Not Ready [current]
    [ 1648.932026] sd 32:0:1:0: [sdb]
    [ 1648.932028] Add. Sense: No additional sense information
    [ 1648.932032] sd 32:0:1:0: [sdb] CDB:
    [ 1648.932034] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1648.932550] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.932560] sd 32:0:1:0: [sdb]
    [ 1648.932564] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.932567] sd 32:0:1:0: [sdb]
    [ 1648.932570] Sense Key : Not Ready [current]
    [ 1648.932576] sd 32:0:1:0: [sdb]
    [ 1648.932579] Add. Sense: No additional sense information
    [ 1648.932584] sd 32:0:1:0: [sdb] CDB:
    [ 1648.932586] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1648.933150] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.933160] sd 32:0:1:0: [sdb]
    [ 1648.933164] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.933168] sd 32:0:1:0: [sdb]
    [ 1648.933170] Sense Key : Not Ready [current]
    [ 1648.933177] sd 32:0:1:0: [sdb]
    [ 1648.933180] Add. Sense: No additional sense information
    [ 1648.933184] sd 32:0:1:0: [sdb] CDB:
    [ 1648.933186] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1648.933696] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.933705] sd 32:0:1:0: [sdb]
    [ 1648.933709] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.933713] sd 32:0:1:0: [sdb]
    [ 1648.933716] Sense Key : Not Ready [current]
    [ 1648.933722] sd 32:0:1:0: [sdb]
    [ 1648.933726] Add. Sense: No additional sense information
    [ 1648.933730] sd 32:0:1:0: [sdb] CDB:
    [ 1648.933732] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1648.934220] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.934230] sd 32:0:1:0: [sdb]
    [ 1648.934234] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.934238] sd 32:0:1:0: [sdb]
    [ 1648.934241] Sense Key : Not Ready [current]
    [ 1648.934247] sd 32:0:1:0: [sdb]
    [ 1648.934250] Add. Sense: No additional sense information
    [ 1648.934255] sd 32:0:1:0: [sdb] CDB:
    [ 1648.934257] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1648.934724] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.934729] sd 32:0:1:0: [sdb]
    [ 1648.934732] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.934735] sd 32:0:1:0: [sdb]
    [ 1648.934738] Sense Key : Not Ready [current]
    [ 1648.934742] sd 32:0:1:0: [sdb]
    [ 1648.934745] Add. Sense: No additional sense information
    [ 1648.934749] sd 32:0:1:0: [sdb] CDB:
    [ 1648.934751] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1648.935815] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.935850] sd 32:0:1:0: [sdb]
    [ 1648.935855] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.935858] sd 32:0:1:0: [sdb]
    [ 1648.935861] Sense Key : Not Ready [current]
    [ 1648.935867] sd 32:0:1:0: [sdb]
    [ 1648.935871] Add. Sense: No additional sense information
    [ 1648.935875] sd 32:0:1:0: [sdb] CDB:
    [ 1648.935877] Read(10): 28 00 00 00 01 00 00 00 08 00
    [ 1648.936307] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.936312] sd 32:0:1:0: [sdb]
    [ 1648.936316] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.936319] sd 32:0:1:0: [sdb]
    [ 1648.936322] Sense Key : Not Ready [current]
    [ 1648.936327] sd 32:0:1:0: [sdb]
    [ 1648.936330] Add. Sense: No additional sense information
    [ 1648.936334] sd 32:0:1:0: [sdb] CDB:
    [ 1648.936336] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.936735] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.936741] sd 32:0:1:0: [sdb]
    [ 1648.936744] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.936748] sd 32:0:1:0: [sdb]
    [ 1648.936750] Sense Key : Not Ready [current]
    [ 1648.936754] sd 32:0:1:0: [sdb]
    [ 1648.936757] Add. Sense: No additional sense information
    [ 1648.936761] sd 32:0:1:0: [sdb] CDB:
    [ 1648.936763] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.937245] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.937254] sd 32:0:1:0: [sdb]
    [ 1648.937258] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.937263] sd 32:0:1:0: [sdb]
    [ 1648.937265] Sense Key : Not Ready [current]
    [ 1648.937272] sd 32:0:1:0: [sdb]
    [ 1648.937275] Add. Sense: No additional sense information
    [ 1648.937279] sd 32:0:1:0: [sdb] CDB:
    [ 1648.937281] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.937819] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.937828] sd 32:0:1:0: [sdb]
    [ 1648.937832] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.937836] sd 32:0:1:0: [sdb]
    [ 1648.937839] Sense Key : Not Ready [current]
    [ 1648.937845] sd 32:0:1:0: [sdb]
    [ 1648.937848] Add. Sense: No additional sense information
    [ 1648.937853] sd 32:0:1:0: [sdb] CDB:
    [ 1648.937855] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.938408] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.938417] sd 32:0:1:0: [sdb]
    [ 1648.938422] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.938426] sd 32:0:1:0: [sdb]
    [ 1648.938428] Sense Key : Not Ready [current]
    [ 1648.938435] sd 32:0:1:0: [sdb]
    [ 1648.938438] Add. Sense: No additional sense information
    [ 1648.938442] sd 32:0:1:0: [sdb] CDB:
    [ 1648.938445] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.938902] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.938907] sd 32:0:1:0: [sdb]
    [ 1648.938911] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.938914] sd 32:0:1:0: [sdb]
    [ 1648.938917] Sense Key : Not Ready [current]
    [ 1648.938921] sd 32:0:1:0: [sdb]
    [ 1648.938924] Add. Sense: No additional sense information
    [ 1648.938928] sd 32:0:1:0: [sdb] CDB:
    [ 1648.938930] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1648.939304] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.939309] sd 32:0:1:0: [sdb]
    [ 1648.939312] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.939316] sd 32:0:1:0: [sdb]
    [ 1648.939318] Sense Key : Not Ready [current]
    [ 1648.939323] sd 32:0:1:0: [sdb]
    [ 1648.939325] Add. Sense: No additional sense information
    [ 1648.939329] sd 32:0:1:0: [sdb] CDB:
    [ 1648.939331] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.939728] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.939734] sd 32:0:1:0: [sdb]
    [ 1648.939737] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.939740] sd 32:0:1:0: [sdb]
    [ 1648.939742] Sense Key : Not Ready [current]
    [ 1648.939746] sd 32:0:1:0: [sdb]
    [ 1648.939749] Add. Sense: No additional sense information
    [ 1648.939752] sd 32:0:1:0: [sdb] CDB:
    [ 1648.939754] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.940245] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.940251] sd 32:0:1:0: [sdb]
    [ 1648.940254] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.940257] sd 32:0:1:0: [sdb]
    [ 1648.940259] Sense Key : Not Ready [current]
    [ 1648.940264] sd 32:0:1:0: [sdb]
    [ 1648.940266] Add. Sense: No additional sense information
    [ 1648.940270] sd 32:0:1:0: [sdb] CDB:
    [ 1648.940272] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.940636] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.940645] sd 32:0:1:0: [sdb]
    [ 1648.940649] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.940654] sd 32:0:1:0: [sdb]
    [ 1648.940657] Sense Key : Not Ready [current]
    [ 1648.940665] sd 32:0:1:0: [sdb]
    [ 1648.940669] Add. Sense: No additional sense information
    [ 1648.940675] sd 32:0:1:0: [sdb] CDB:
    [ 1648.940679] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.941151] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.941161] sd 32:0:1:0: [sdb]
    [ 1648.941165] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.941172] sd 32:0:1:0: [sdb]
    [ 1648.941176] Sense Key : Not Ready [current]
    [ 1648.941183] sd 32:0:1:0: [sdb]
    [ 1648.941187] Add. Sense: No additional sense information
    [ 1648.941193] sd 32:0:1:0: [sdb] CDB:
    [ 1648.941197] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.941691] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.941700] sd 32:0:1:0: [sdb]
    [ 1648.941706] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.941712] sd 32:0:1:0: [sdb]
    [ 1648.941716] Sense Key : Not Ready [current]
    [ 1648.941725] sd 32:0:1:0: [sdb]
    [ 1648.941729] Add. Sense: No additional sense information
    [ 1648.941735] sd 32:0:1:0: [sdb] CDB:
    [ 1648.941738] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.942267] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.942277] sd 32:0:1:0: [sdb]
    [ 1648.942282] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.942288] sd 32:0:1:0: [sdb]
    [ 1648.942292] Sense Key : Not Ready [current]
    [ 1648.942300] sd 32:0:1:0: [sdb]
    [ 1648.942304] Add. Sense: No additional sense information
    [ 1648.942311] sd 32:0:1:0: [sdb] CDB:
    [ 1648.942315] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.942819] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.942826] sd 32:0:1:0: [sdb]
    [ 1648.942831] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.942836] sd 32:0:1:0: [sdb]
    [ 1648.942840] Sense Key : Not Ready [current]
    [ 1648.942847] sd 32:0:1:0: [sdb]
    [ 1648.942851] Add. Sense: No additional sense information
    [ 1648.942856] sd 32:0:1:0: [sdb] CDB:
    [ 1648.942860] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.943349] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.943358] sd 32:0:1:0: [sdb]
    [ 1648.943363] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.943369] sd 32:0:1:0: [sdb]
    [ 1648.943373] Sense Key : Not Ready [current]
    [ 1648.943381] sd 32:0:1:0: [sdb]
    [ 1648.943386] Add. Sense: No additional sense information
    [ 1648.943392] sd 32:0:1:0: [sdb] CDB:
    [ 1648.943396] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.943899] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.943908] sd 32:0:1:0: [sdb]
    [ 1648.943913] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.943918] sd 32:0:1:0: [sdb]
    [ 1648.943922] Sense Key : Not Ready [current]
    [ 1648.943930] sd 32:0:1:0: [sdb]
    [ 1648.943934] Add. Sense: No additional sense information
    [ 1648.943941] sd 32:0:1:0: [sdb] CDB:
    [ 1648.943944] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.944374] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.944383] sd 32:0:1:0: [sdb]
    [ 1648.944388] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.944394] sd 32:0:1:0: [sdb]
    [ 1648.944398] Sense Key : Not Ready [current]
    [ 1648.944405] sd 32:0:1:0: [sdb]
    [ 1648.944410] Add. Sense: No additional sense information
    [ 1648.944416] sd 32:0:1:0: [sdb] CDB:
    [ 1648.944419] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.944917] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.944927] sd 32:0:1:0: [sdb]
    [ 1648.944932] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.944938] sd 32:0:1:0: [sdb]
    [ 1648.944941] Sense Key : Not Ready [current]
    [ 1648.944948] sd 32:0:1:0: [sdb]
    [ 1648.944953] Add. Sense: No additional sense information
    [ 1648.944959] sd 32:0:1:0: [sdb] CDB:
    [ 1648.944963] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.945490] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.945500] sd 32:0:1:0: [sdb]
    [ 1648.945505] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.945511] sd 32:0:1:0: [sdb]
    [ 1648.945514] Sense Key : Not Ready [current]
    [ 1648.945522] sd 32:0:1:0: [sdb]
    [ 1648.945526] Add. Sense: No additional sense information
    [ 1648.945532] sd 32:0:1:0: [sdb] CDB:
    [ 1648.945536] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1648.946002] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.946009] sd 32:0:1:0: [sdb]
    [ 1648.946012] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.946015] sd 32:0:1:0: [sdb]
    [ 1648.946017] Sense Key : Not Ready [current]
    [ 1648.946022] sd 32:0:1:0: [sdb]
    [ 1648.946025] Add. Sense: No additional sense information
    [ 1648.946028] sd 32:0:1:0: [sdb] CDB:
    [ 1648.946030] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1648.946477] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.946483] sd 32:0:1:0: [sdb]
    [ 1648.946486] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.946489] sd 32:0:1:0: [sdb]
    [ 1648.946491] Sense Key : Not Ready [current]
    [ 1648.946496] sd 32:0:1:0: [sdb]
    [ 1648.946498] Add. Sense: No additional sense information
    [ 1648.946501] sd 32:0:1:0: [sdb] CDB:
    [ 1648.946503] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1648.946897] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.946902] sd 32:0:1:0: [sdb]
    [ 1648.946905] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.946908] sd 32:0:1:0: [sdb]
    [ 1648.946910] Sense Key : Not Ready [current]
    [ 1648.946915] sd 32:0:1:0: [sdb]
    [ 1648.946917] Add. Sense: No additional sense information
    [ 1648.946920] sd 32:0:1:0: [sdb] CDB:
    [ 1648.946922] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.947313] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.947319] sd 32:0:1:0: [sdb]
    [ 1648.947322] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.947325] sd 32:0:1:0: [sdb]
    [ 1648.947327] Sense Key : Not Ready [current]
    [ 1648.947331] sd 32:0:1:0: [sdb]
    [ 1648.947334] Add. Sense: No additional sense information
    [ 1648.947337] sd 32:0:1:0: [sdb] CDB:
    [ 1648.947339] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.947732] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.947738] sd 32:0:1:0: [sdb]
    [ 1648.947740] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.947744] sd 32:0:1:0: [sdb]
    [ 1648.947746] Sense Key : Not Ready [current]
    [ 1648.947750] sd 32:0:1:0: [sdb]
    [ 1648.947752] Add. Sense: No additional sense information
    [ 1648.947756] sd 32:0:1:0: [sdb] CDB:
    [ 1648.947758] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.948137] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.948143] sd 32:0:1:0: [sdb]
    [ 1648.948146] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.948149] sd 32:0:1:0: [sdb]
    [ 1648.948151] Sense Key : Not Ready [current]
    [ 1648.948155] sd 32:0:1:0: [sdb]
    [ 1648.948157] Add. Sense: No additional sense information
    [ 1648.948161] sd 32:0:1:0: [sdb] CDB:
    [ 1648.948163] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1648.948582] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.948588] sd 32:0:1:0: [sdb]
    [ 1648.948591] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.948594] sd 32:0:1:0: [sdb]
    [ 1648.948596] Sense Key : Not Ready [current]
    [ 1648.948600] sd 32:0:1:0: [sdb]
    [ 1648.948602] Add. Sense: No additional sense information
    [ 1648.948606] sd 32:0:1:0: [sdb] CDB:
    [ 1648.948608] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.949137] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.949148] sd 32:0:1:0: [sdb]
    [ 1648.949152] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.949156] sd 32:0:1:0: [sdb]
    [ 1648.949159] Sense Key : Not Ready [current]
    [ 1648.949165] sd 32:0:1:0: [sdb]
    [ 1648.949169] Add. Sense: No additional sense information
    [ 1648.949173] sd 32:0:1:0: [sdb] CDB:
    [ 1648.949175] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.949682] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.949691] sd 32:0:1:0: [sdb]
    [ 1648.949695] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.949699] sd 32:0:1:0: [sdb]
    [ 1648.949702] Sense Key : Not Ready [current]
    [ 1648.949708] sd 32:0:1:0: [sdb]
    [ 1648.949711] Add. Sense: No additional sense information
    [ 1648.949715] sd 32:0:1:0: [sdb] CDB:
    [ 1648.949717] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.950234] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.950244] sd 32:0:1:0: [sdb]
    [ 1648.950248] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.950252] sd 32:0:1:0: [sdb]
    [ 1648.950254] Sense Key : Not Ready [current]
    [ 1648.950261] sd 32:0:1:0: [sdb]
    [ 1648.950264] Add. Sense: No additional sense information
    [ 1648.950268] sd 32:0:1:0: [sdb] CDB:
    [ 1648.950270] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.950703] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.950708] sd 32:0:1:0: [sdb]
    [ 1648.950712] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.950715] sd 32:0:1:0: [sdb]
    [ 1648.950718] Sense Key : Not Ready [current]
    [ 1648.950722] sd 32:0:1:0: [sdb]
    [ 1648.950725] Add. Sense: No additional sense information
    [ 1648.950729] sd 32:0:1:0: [sdb] CDB:
    [ 1648.950731] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.951144] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.951149] sd 32:0:1:0: [sdb]
    [ 1648.951152] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.951155] sd 32:0:1:0: [sdb]
    [ 1648.951158] Sense Key : Not Ready [current]
    [ 1648.951162] sd 32:0:1:0: [sdb]
    [ 1648.951165] Add. Sense: No additional sense information
    [ 1648.951168] sd 32:0:1:0: [sdb] CDB:
    [ 1648.951170] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.951566] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.951572] sd 32:0:1:0: [sdb]
    [ 1648.951575] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.951578] sd 32:0:1:0: [sdb]
    [ 1648.951580] Sense Key : Not Ready [current]
    [ 1648.951584] sd 32:0:1:0: [sdb]
    [ 1648.951587] Add. Sense: No additional sense information
    [ 1648.951590] sd 32:0:1:0: [sdb] CDB:
    [ 1648.951592] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1648.951986] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.951992] sd 32:0:1:0: [sdb]
    [ 1648.951995] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.951998] sd 32:0:1:0: [sdb]
    [ 1648.952001] Sense Key : Not Ready [current]
    [ 1648.952005] sd 32:0:1:0: [sdb]
    [ 1648.952008] Add. Sense: No additional sense information
    [ 1648.952011] sd 32:0:1:0: [sdb] CDB:
    [ 1648.952013] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1648.952487] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.952493] sd 32:0:1:0: [sdb]
    [ 1648.952496] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.952499] sd 32:0:1:0: [sdb]
    [ 1648.952501] Sense Key : Not Ready [current]
    [ 1648.952506] sd 32:0:1:0: [sdb]
    [ 1648.952508] Add. Sense: No additional sense information
    [ 1648.952511] sd 32:0:1:0: [sdb] CDB:
    [ 1648.952513] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.953114] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.953125] sd 32:0:1:0: [sdb]
    [ 1648.953129] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.953133] sd 32:0:1:0: [sdb]
    [ 1648.953136] Sense Key : Not Ready [current]
    [ 1648.953142] sd 32:0:1:0: [sdb]
    [ 1648.953146] Add. Sense: No additional sense information
    [ 1648.953150] sd 32:0:1:0: [sdb] CDB:
    [ 1648.953152] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.953694] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.953703] sd 32:0:1:0: [sdb]
    [ 1648.953707] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.953711] sd 32:0:1:0: [sdb]
    [ 1648.953714] Sense Key : Not Ready [current]
    [ 1648.953720] sd 32:0:1:0: [sdb]
    [ 1648.953724] Add. Sense: No additional sense information
    [ 1648.953728] sd 32:0:1:0: [sdb] CDB:
    [ 1648.953730] Read(10): 28 00 00 00 10 00 00 00 08 00
    [ 1648.954231] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.954241] sd 32:0:1:0: [sdb]
    [ 1648.954245] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.954249] sd 32:0:1:0: [sdb]
    [ 1648.954251] Sense Key : Not Ready [current]
    [ 1648.954258] sd 32:0:1:0: [sdb]
    [ 1648.954261] Add. Sense: No additional sense information
    [ 1648.954265] sd 32:0:1:0: [sdb] CDB:
    [ 1648.954267] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.954701] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.954705] sd 32:0:1:0: [sdb]
    [ 1648.954709] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.954712] sd 32:0:1:0: [sdb]
    [ 1648.954715] Sense Key : Not Ready [current]
    [ 1648.954720] sd 32:0:1:0: [sdb]
    [ 1648.954723] Add. Sense: No additional sense information
    [ 1648.954726] sd 32:0:1:0: [sdb] CDB:
    [ 1648.954728] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.955150] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.955156] sd 32:0:1:0: [sdb]
    [ 1648.955159] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.955162] sd 32:0:1:0: [sdb]
    [ 1648.955164] Sense Key : Not Ready [current]
    [ 1648.955169] sd 32:0:1:0: [sdb]
    [ 1648.955172] Add. Sense: No additional sense information
    [ 1648.955175] sd 32:0:1:0: [sdb] CDB:
    [ 1648.955177] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.955598] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.955604] sd 32:0:1:0: [sdb]
    [ 1648.955607] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.955611] sd 32:0:1:0: [sdb]
    [ 1648.955613] Sense Key : Not Ready [current]
    [ 1648.955617] sd 32:0:1:0: [sdb]
    [ 1648.955620] Add. Sense: No additional sense information
    [ 1648.955623] sd 32:0:1:0: [sdb] CDB:
    [ 1648.955625] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.956137] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.956143] sd 32:0:1:0: [sdb]
    [ 1648.956146] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.956149] sd 32:0:1:0: [sdb]
    [ 1648.956151] Sense Key : Not Ready [current]
    [ 1648.956156] sd 32:0:1:0: [sdb]
    [ 1648.956158] Add. Sense: No additional sense information
    [ 1648.956161] sd 32:0:1:0: [sdb] CDB:
    [ 1648.956163] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1648.956563] sd 32:0:1:0: [sdb] Device not ready
    [ 1648.956569] sd 32:0:1:0: [sdb]
    [ 1648.956572] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1648.956575] sd 32:0:1:0: [sdb]
    [ 1648.956577] Sense Key : Not Ready [current]
    [ 1648.956581] sd 32:0:1:0: [sdb]
    [ 1648.956584] Add. Sense: No additional sense information
    [ 1648.956587] sd 32:0:1:0: [sdb] CDB:
    [ 1648.956589] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1649.041912] sd 32:0:1:0: [sdb] Device not ready
    [ 1649.041923] sd 32:0:1:0: [sdb]
    [ 1649.041928] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1649.041932] sd 32:0:1:0: [sdb]
    [ 1649.041935] Sense Key : Not Ready [current]
    [ 1649.041942] sd 32:0:1:0: [sdb]
    [ 1649.041946] Add. Sense: No additional sense information
    [ 1649.041950] sd 32:0:1:0: [sdb] CDB:
    [ 1649.041953] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.482799] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.482810] sd 32:0:1:0: [sdb]
    [ 1651.482816] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.482820] sd 32:0:1:0: [sdb]
    [ 1651.482823] Sense Key : Not Ready [current]
    [ 1651.482830] sd 32:0:1:0: [sdb]
    [ 1651.482834] Add. Sense: No additional sense information
    [ 1651.482838] sd 32:0:1:0: [sdb] CDB:
    [ 1651.482841] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.486041] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.486051] sd 32:0:1:0: [sdb]
    [ 1651.486055] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.486059] sd 32:0:1:0: [sdb]
    [ 1651.486062] Sense Key : Not Ready [current]
    [ 1651.486068] sd 32:0:1:0: [sdb]
    [ 1651.486072] Add. Sense: No additional sense information
    [ 1651.486076] sd 32:0:1:0: [sdb] CDB:
    [ 1651.486078] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.487186] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.487196] sd 32:0:1:0: [sdb]
    [ 1651.487200] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.487204] sd 32:0:1:0: [sdb]
    [ 1651.487207] Sense Key : Not Ready [current]
    [ 1651.487213] sd 32:0:1:0: [sdb]
    [ 1651.487216] Add. Sense: No additional sense information
    [ 1651.487220] sd 32:0:1:0: [sdb] CDB:
    [ 1651.487223] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.487787] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.487796] sd 32:0:1:0: [sdb]
    [ 1651.487800] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.487804] sd 32:0:1:0: [sdb]
    [ 1651.487806] Sense Key : Not Ready [current]
    [ 1651.487813] sd 32:0:1:0: [sdb]
    [ 1651.487816] Add. Sense: No additional sense information
    [ 1651.487820] sd 32:0:1:0: [sdb] CDB:
    [ 1651.487823] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.488298] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.488304] sd 32:0:1:0: [sdb]
    [ 1651.488307] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.488310] sd 32:0:1:0: [sdb]
    [ 1651.488313] Sense Key : Not Ready [current]
    [ 1651.488318] sd 32:0:1:0: [sdb]
    [ 1651.488321] Add. Sense: No additional sense information
    [ 1651.488324] sd 32:0:1:0: [sdb] CDB:
    [ 1651.488326] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.489330] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.489338] sd 32:0:1:0: [sdb]
    [ 1651.489342] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.489345] sd 32:0:1:0: [sdb]
    [ 1651.489348] Sense Key : Not Ready [current]
    [ 1651.489355] sd 32:0:1:0: [sdb]
    [ 1651.489358] Add. Sense: No additional sense information
    [ 1651.489362] sd 32:0:1:0: [sdb] CDB:
    [ 1651.489364] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.495397] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.495405] sd 32:0:1:0: [sdb]
    [ 1651.495409] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.495413] sd 32:0:1:0: [sdb]
    [ 1651.495416] Sense Key : Not Ready [current]
    [ 1651.495422] sd 32:0:1:0: [sdb]
    [ 1651.495425] Add. Sense: No additional sense information
    [ 1651.495430] sd 32:0:1:0: [sdb] CDB:
    [ 1651.495432] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.495820] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.495826] sd 32:0:1:0: [sdb]
    [ 1651.495830] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.495833] sd 32:0:1:0: [sdb]
    [ 1651.495835] Sense Key : Not Ready [current]
    [ 1651.495841] sd 32:0:1:0: [sdb]
    [ 1651.495843] Add. Sense: No additional sense information
    [ 1651.495847] sd 32:0:1:0: [sdb] CDB:
    [ 1651.495849] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.496233] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.496240] sd 32:0:1:0: [sdb]
    [ 1651.496243] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.496246] sd 32:0:1:0: [sdb]
    [ 1651.496248] Sense Key : Not Ready [current]
    [ 1651.496253] sd 32:0:1:0: [sdb]
    [ 1651.496256] Add. Sense: No additional sense information
    [ 1651.496259] sd 32:0:1:0: [sdb] CDB:
    [ 1651.496261] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.496640] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.496646] sd 32:0:1:0: [sdb]
    [ 1651.496649] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.496652] sd 32:0:1:0: [sdb]
    [ 1651.496655] Sense Key : Not Ready [current]
    [ 1651.496659] sd 32:0:1:0: [sdb]
    [ 1651.496662] Add. Sense: No additional sense information
    [ 1651.496666] sd 32:0:1:0: [sdb] CDB:
    [ 1651.496668] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1651.497012] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.497051] sd 32:0:1:0: [sdb]
    [ 1651.497054] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.497058] sd 32:0:1:0: [sdb]
    [ 1651.497060] Sense Key : Not Ready [current]
    [ 1651.497064] sd 32:0:1:0: [sdb]
    [ 1651.497067] Add. Sense: No additional sense information
    [ 1651.497071] sd 32:0:1:0: [sdb] CDB:
    [ 1651.497073] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1651.498070] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.498077] sd 32:0:1:0: [sdb]
    [ 1651.498081] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.498085] sd 32:0:1:0: [sdb]
    [ 1651.498087] Sense Key : Not Ready [current]
    [ 1651.498092] sd 32:0:1:0: [sdb]
    [ 1651.498094] Add. Sense: No additional sense information
    [ 1651.498098] sd 32:0:1:0: [sdb] CDB:
    [ 1651.498100] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1651.498645] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.498652] sd 32:0:1:0: [sdb]
    [ 1651.498655] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.498658] sd 32:0:1:0: [sdb]
    [ 1651.498660] Sense Key : Not Ready [current]
    [ 1651.498727] sd 32:0:1:0: [sdb]
    [ 1651.498762] Add. Sense: No additional sense information
    [ 1651.498827] sd 32:0:1:0: [sdb] CDB:
    [ 1651.498831] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1651.499333] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.499339] sd 32:0:1:0: [sdb]
    [ 1651.499341] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.499345] sd 32:0:1:0: [sdb]
    [ 1651.499347] Sense Key : Not Ready [current]
    [ 1651.499351] sd 32:0:1:0: [sdb]
    [ 1651.499354] Add. Sense: No additional sense information
    [ 1651.499358] sd 32:0:1:0: [sdb] CDB:
    [ 1651.499360] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1651.499776] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.499781] sd 32:0:1:0: [sdb]
    [ 1651.499784] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.499788] sd 32:0:1:0: [sdb]
    [ 1651.499790] Sense Key : Not Ready [current]
    [ 1651.499794] sd 32:0:1:0: [sdb]
    [ 1651.499796] Add. Sense: No additional sense information
    [ 1651.499800] sd 32:0:1:0: [sdb] CDB:
    [ 1651.499802] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1651.500219] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.500224] sd 32:0:1:0: [sdb]
    [ 1651.500227] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.500230] sd 32:0:1:0: [sdb]
    [ 1651.500232] Sense Key : Not Ready [current]
    [ 1651.500236] sd 32:0:1:0: [sdb]
    [ 1651.500239] Add. Sense: No additional sense information
    [ 1651.500242] sd 32:0:1:0: [sdb] CDB:
    [ 1651.500244] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1651.501362] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.501369] sd 32:0:1:0: [sdb]
    [ 1651.501372] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.501375] sd 32:0:1:0: [sdb]
    [ 1651.501377] Sense Key : Not Ready [current]
    [ 1651.501382] sd 32:0:1:0: [sdb]
    [ 1651.501385] Add. Sense: No additional sense information
    [ 1651.501388] sd 32:0:1:0: [sdb] CDB:
    [ 1651.501390] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1651.501833] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.501842] sd 32:0:1:0: [sdb]
    [ 1651.501847] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.501852] sd 32:0:1:0: [sdb]
    [ 1651.501855] Sense Key : Not Ready [current]
    [ 1651.501862] sd 32:0:1:0: [sdb]
    [ 1651.501867] Add. Sense: No additional sense information
    [ 1651.501873] sd 32:0:1:0: [sdb] CDB:
    [ 1651.501877] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.502420] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.502434] sd 32:0:1:0: [sdb]
    [ 1651.502441] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.502448] sd 32:0:1:0: [sdb]
    [ 1651.502452] Sense Key : Not Ready [current]
    [ 1651.502461] sd 32:0:1:0: [sdb]
    [ 1651.502467] Add. Sense: No additional sense information
    [ 1651.502474] sd 32:0:1:0: [sdb] CDB:
    [ 1651.502478] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.502986] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.502996] sd 32:0:1:0: [sdb]
    [ 1651.503000] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.503006] sd 32:0:1:0: [sdb]
    [ 1651.503009] Sense Key : Not Ready [current]
    [ 1651.503017] sd 32:0:1:0: [sdb]
    [ 1651.503071] Add. Sense: No additional sense information
    [ 1651.503080] sd 32:0:1:0: [sdb] CDB:
    [ 1651.503084] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.503561] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.503571] sd 32:0:1:0: [sdb]
    [ 1651.503577] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.503584] sd 32:0:1:0: [sdb]
    [ 1651.503588] Sense Key : Not Ready [current]
    [ 1651.503596] sd 32:0:1:0: [sdb]
    [ 1651.503602] Add. Sense: No additional sense information
    [ 1651.503608] sd 32:0:1:0: [sdb] CDB:
    [ 1651.503611] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1651.504160] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.504170] sd 32:0:1:0: [sdb]
    [ 1651.504175] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.504182] sd 32:0:1:0: [sdb]
    [ 1651.504186] Sense Key : Not Ready [current]
    [ 1651.504194] sd 32:0:1:0: [sdb]
    [ 1651.504199] Add. Sense: No additional sense information
    [ 1651.504205] sd 32:0:1:0: [sdb] CDB:
    [ 1651.504208] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.506229] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.506240] sd 32:0:1:0: [sdb]
    [ 1651.506247] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.506253] sd 32:0:1:0: [sdb]
    [ 1651.506258] Sense Key : Not Ready [current]
    [ 1651.506267] sd 32:0:1:0: [sdb]
    [ 1651.506271] Add. Sense: No additional sense information
    [ 1651.506279] sd 32:0:1:0: [sdb] CDB:
    [ 1651.506283] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.506880] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.506891] sd 32:0:1:0: [sdb]
    [ 1651.506896] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.506903] sd 32:0:1:0: [sdb]
    [ 1651.506907] Sense Key : Not Ready [current]
    [ 1651.506916] sd 32:0:1:0: [sdb]
    [ 1651.506920] Add. Sense: No additional sense information
    [ 1651.506927] sd 32:0:1:0: [sdb] CDB:
    [ 1651.506931] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.507464] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.507475] sd 32:0:1:0: [sdb]
    [ 1651.507480] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.507486] sd 32:0:1:0: [sdb]
    [ 1651.507490] Sense Key : Not Ready [current]
    [ 1651.507500] sd 32:0:1:0: [sdb]
    [ 1651.507505] Add. Sense: No additional sense information
    [ 1651.507511] sd 32:0:1:0: [sdb] CDB:
    [ 1651.507515] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1651.507985] sd 32:0:1:0: [sdb] Device not ready
    [ 1651.507994] sd 32:0:1:0: [sdb]
    [ 1651.507999] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1651.508005] sd 32:0:1:0: [sdb]
    [ 1651.508009] Sense Key : Not Ready [current]
    [ 1651.508017] sd 32:0:1:0: [sdb]
    [ 1651.508022] Add. Sense: No additional sense information
    [ 1651.508075] sd 32:0:1:0: [sdb] CDB:
    [ 1651.508082] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.518147] blk_update_request: 148 callbacks suppressed
    [ 1665.518158] end_request: I/O error, dev fd0, sector 0
    [ 1665.522505] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.522515] sd 32:0:1:0: [sdb]
    [ 1665.522520] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.522524] sd 32:0:1:0: [sdb]
    [ 1665.522527] Sense Key : Not Ready [current]
    [ 1665.522533] sd 32:0:1:0: [sdb]
    [ 1665.522537] Add. Sense: No additional sense information
    [ 1665.522541] sd 32:0:1:0: [sdb] CDB:
    [ 1665.522544] Read(10): 28 00 00 e6 df 80 00 00 08 00
    [ 1665.522559] end_request: I/O error, dev sdb, sector 15130496
    [ 1665.522566] quiet_error: 147 callbacks suppressed
    [ 1665.522570] Buffer I/O error on device sdb, logical block 1891312
    [ 1665.523016] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.523022] sd 32:0:1:0: [sdb]
    [ 1665.523026] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.523029] sd 32:0:1:0: [sdb]
    [ 1665.523031] Sense Key : Not Ready [current]
    [ 1665.523036] sd 32:0:1:0: [sdb]
    [ 1665.523039] Add. Sense: No additional sense information
    [ 1665.523043] sd 32:0:1:0: [sdb] CDB:
    [ 1665.523046] Read(10): 28 00 00 e6 df f0 00 00 08 00
    [ 1665.523058] end_request: I/O error, dev sdb, sector 15130608
    [ 1665.523064] Buffer I/O error on device sdb, logical block 1891326
    [ 1665.523474] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.523479] sd 32:0:1:0: [sdb]
    [ 1665.523483] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.523486] sd 32:0:1:0: [sdb]
    [ 1665.523489] Sense Key : Not Ready [current]
    [ 1665.523494] sd 32:0:1:0: [sdb]
    [ 1665.523496] Add. Sense: No additional sense information
    [ 1665.523500] sd 32:0:1:0: [sdb] CDB:
    [ 1665.523502] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.523514] end_request: I/O error, dev sdb, sector 0
    [ 1665.523519] Buffer I/O error on device sdb, logical block 0
    [ 1665.523967] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.523973] sd 32:0:1:0: [sdb]
    [ 1665.523976] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.523979] sd 32:0:1:0: [sdb]
    [ 1665.523982] Sense Key : Not Ready [current]
    [ 1665.523987] sd 32:0:1:0: [sdb]
    [ 1665.523989] Add. Sense: No additional sense information
    [ 1665.523993] sd 32:0:1:0: [sdb] CDB:
    [ 1665.523995] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.524006] end_request: I/O error, dev sdb, sector 8
    [ 1665.524012] Buffer I/O error on device sdb, logical block 1
    [ 1665.524424] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.524430] sd 32:0:1:0: [sdb]
    [ 1665.524433] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.524436] sd 32:0:1:0: [sdb]
    [ 1665.524439] Sense Key : Not Ready [current]
    [ 1665.524444] sd 32:0:1:0: [sdb]
    [ 1665.524446] Add. Sense: No additional sense information
    [ 1665.524450] sd 32:0:1:0: [sdb] CDB:
    [ 1665.524452] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1665.524464] end_request: I/O error, dev sdb, sector 15130616
    [ 1665.524469] Buffer I/O error on device sdb, logical block 1891327
    [ 1665.525004] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.525011] sd 32:0:1:0: [sdb]
    [ 1665.525013] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.525017] sd 32:0:1:0: [sdb]
    [ 1665.525019] Sense Key : Not Ready [current]
    [ 1665.525024] sd 32:0:1:0: [sdb]
    [ 1665.525026] Add. Sense: No additional sense information
    [ 1665.525030] sd 32:0:1:0: [sdb] CDB:
    [ 1665.525032] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1665.525044] end_request: I/O error, dev sdb, sector 15130616
    [ 1665.525049] Buffer I/O error on device sdb, logical block 1891327
    [ 1665.525471] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.525477] sd 32:0:1:0: [sdb]
    [ 1665.525480] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.525483] sd 32:0:1:0: [sdb]
    [ 1665.525485] Sense Key : Not Ready [current]
    [ 1665.525490] sd 32:0:1:0: [sdb]
    [ 1665.525492] Add. Sense: No additional sense information
    [ 1665.525496] sd 32:0:1:0: [sdb] CDB:
    [ 1665.525498] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1665.525509] end_request: I/O error, dev sdb, sector 15130616
    [ 1665.525515] Buffer I/O error on device sdb, logical block 1891327
    [ 1665.525912] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.525963] sd 32:0:1:0: [sdb]
    [ 1665.525966] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.525970] sd 32:0:1:0: [sdb]
    [ 1665.525972] Sense Key : Not Ready [current]
    [ 1665.525977] sd 32:0:1:0: [sdb]
    [ 1665.525979] Add. Sense: No additional sense information
    [ 1665.525983] sd 32:0:1:0: [sdb] CDB:
    [ 1665.525985] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1665.525996] end_request: I/O error, dev sdb, sector 15130616
    [ 1665.526002] Buffer I/O error on device sdb, logical block 1891327
    [ 1665.527223] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.527230] sd 32:0:1:0: [sdb]
    [ 1665.527234] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.527237] sd 32:0:1:0: [sdb]
    [ 1665.527240] Sense Key : Not Ready [current]
    [ 1665.527244] sd 32:0:1:0: [sdb]
    [ 1665.527247] Add. Sense: No additional sense information
    [ 1665.527250] sd 32:0:1:0: [sdb] CDB:
    [ 1665.527252] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1665.527264] end_request: I/O error, dev sdb, sector 15130616
    [ 1665.527269] Buffer I/O error on device sdb, logical block 1891327
    [ 1665.527724] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.527729] sd 32:0:1:0: [sdb]
    [ 1665.527732] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.527736] sd 32:0:1:0: [sdb]
    [ 1665.527738] Sense Key : Not Ready [current]
    [ 1665.527743] sd 32:0:1:0: [sdb]
    [ 1665.527745] Add. Sense: No additional sense information
    [ 1665.527748] sd 32:0:1:0: [sdb] CDB:
    [ 1665.527751] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1665.527764] Buffer I/O error on device sdb, logical block 1891327
    [ 1665.528177] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.528183] sd 32:0:1:0: [sdb]
    [ 1665.528186] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.528189] sd 32:0:1:0: [sdb]
    [ 1665.528191] Sense Key : Not Ready [current]
    [ 1665.528195] sd 32:0:1:0: [sdb]
    [ 1665.528198] Add. Sense: No additional sense information
    [ 1665.528202] sd 32:0:1:0: [sdb] CDB:
    [ 1665.528204] Read(10): 28 00 00 e6 df c0 00 00 08 00
    [ 1665.528645] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.528651] sd 32:0:1:0: [sdb]
    [ 1665.528654] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.528657] sd 32:0:1:0: [sdb]
    [ 1665.528659] Sense Key : Not Ready [current]
    [ 1665.528663] sd 32:0:1:0: [sdb]
    [ 1665.528666] Add. Sense: No additional sense information
    [ 1665.528669] sd 32:0:1:0: [sdb] CDB:
    [ 1665.528671] Read(10): 28 00 00 e6 df f0 00 00 08 00
    [ 1665.529116] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.529121] sd 32:0:1:0: [sdb]
    [ 1665.529124] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.529127] sd 32:0:1:0: [sdb]
    [ 1665.529129] Sense Key : Not Ready [current]
    [ 1665.529134] sd 32:0:1:0: [sdb]
    [ 1665.529137] Add. Sense: No additional sense information
    [ 1665.529140] sd 32:0:1:0: [sdb] CDB:
    [ 1665.529142] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.529563] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.529569] sd 32:0:1:0: [sdb]
    [ 1665.529572] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.529575] sd 32:0:1:0: [sdb]
    [ 1665.529577] Sense Key : Not Ready [current]
    [ 1665.529581] sd 32:0:1:0: [sdb]
    [ 1665.529584] Add. Sense: No additional sense information
    [ 1665.529587] sd 32:0:1:0: [sdb] CDB:
    [ 1665.529589] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.530011] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.530016] sd 32:0:1:0: [sdb]
    [ 1665.530019] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.530022] sd 32:0:1:0: [sdb]
    [ 1665.530025] Sense Key : Not Ready [current]
    [ 1665.530029] sd 32:0:1:0: [sdb]
    [ 1665.530032] Add. Sense: No additional sense information
    [ 1665.530035] sd 32:0:1:0: [sdb] CDB:
    [ 1665.530037] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1665.531155] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.531162] sd 32:0:1:0: [sdb]
    [ 1665.531165] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.531168] sd 32:0:1:0: [sdb]
    [ 1665.531170] Sense Key : Not Ready [current]
    [ 1665.531174] sd 32:0:1:0: [sdb]
    [ 1665.531177] Add. Sense: No additional sense information
    [ 1665.531180] sd 32:0:1:0: [sdb] CDB:
    [ 1665.531182] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1665.531630] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.531635] sd 32:0:1:0: [sdb]
    [ 1665.531638] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.531641] sd 32:0:1:0: [sdb]
    [ 1665.531644] Sense Key : Not Ready [current]
    [ 1665.531648] sd 32:0:1:0: [sdb]
    [ 1665.531651] Add. Sense: No additional sense information
    [ 1665.531654] sd 32:0:1:0: [sdb] CDB:
    [ 1665.531656] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1665.532174] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.532180] sd 32:0:1:0: [sdb]
    [ 1665.532183] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.532187] sd 32:0:1:0: [sdb]
    [ 1665.532189] Sense Key : Not Ready [current]
    [ 1665.532193] sd 32:0:1:0: [sdb]
    [ 1665.532195] Add. Sense: No additional sense information
    [ 1665.532199] sd 32:0:1:0: [sdb] CDB:
    [ 1665.532201] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.532723] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.532731] sd 32:0:1:0: [sdb]
    [ 1665.532736] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.532742] sd 32:0:1:0: [sdb]
    [ 1665.532745] Sense Key : Not Ready [current]
    [ 1665.532753] sd 32:0:1:0: [sdb]
    [ 1665.532757] Add. Sense: No additional sense information
    [ 1665.532762] sd 32:0:1:0: [sdb] CDB:
    [ 1665.532765] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.533242] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.533251] sd 32:0:1:0: [sdb]
    [ 1665.533255] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.533260] sd 32:0:1:0: [sdb]
    [ 1665.533263] Sense Key : Not Ready [current]
    [ 1665.533270] sd 32:0:1:0: [sdb]
    [ 1665.533275] Add. Sense: No additional sense information
    [ 1665.533281] sd 32:0:1:0: [sdb] CDB:
    [ 1665.533284] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.533865] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.533874] sd 32:0:1:0: [sdb]
    [ 1665.533878] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.533883] sd 32:0:1:0: [sdb]
    [ 1665.533886] Sense Key : Not Ready [current]
    [ 1665.533894] sd 32:0:1:0: [sdb]
    [ 1665.533898] Add. Sense: No additional sense information
    [ 1665.533904] sd 32:0:1:0: [sdb] CDB:
    [ 1665.533907] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.536010] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.536022] sd 32:0:1:0: [sdb]
    [ 1665.536028] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.536034] sd 32:0:1:0: [sdb]
    [ 1665.536038] Sense Key : Not Ready [current]
    [ 1665.536046] sd 32:0:1:0: [sdb]
    [ 1665.536050] Add. Sense: No additional sense information
    [ 1665.536056] sd 32:0:1:0: [sdb] CDB:
    [ 1665.536059] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.543043] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.543066] sd 32:0:1:0: [sdb]
    [ 1665.543074] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.543080] sd 32:0:1:0: [sdb]
    [ 1665.543084] Sense Key : Not Ready [current]
    [ 1665.543095] sd 32:0:1:0: [sdb]
    [ 1665.543099] Add. Sense: No additional sense information
    [ 1665.543104] sd 32:0:1:0: [sdb] CDB:
    [ 1665.543109] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.550039] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.550056] sd 32:0:1:0: [sdb]
    [ 1665.550063] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.550070] sd 32:0:1:0: [sdb]
    [ 1665.550075] Sense Key : Not Ready [current]
    [ 1665.550083] sd 32:0:1:0: [sdb]
    [ 1665.550090] Add. Sense: No additional sense information
    [ 1665.550094] sd 32:0:1:0: [sdb] CDB:
    [ 1665.550097] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.551103] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.551120] sd 32:0:1:0: [sdb]
    [ 1665.551127] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.551135] sd 32:0:1:0: [sdb]
    [ 1665.551140] Sense Key : Not Ready [current]
    [ 1665.551149] sd 32:0:1:0: [sdb]
    [ 1665.551154] Add. Sense: No additional sense information
    [ 1665.551161] sd 32:0:1:0: [sdb] CDB:
    [ 1665.551165] Read(10): 28 00 00 00 08 00 00 00 08 00
    [ 1665.551963] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.552036] sd 32:0:1:0: [sdb]
    [ 1665.552042] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.552046] sd 32:0:1:0: [sdb]
    [ 1665.552049] Sense Key : Not Ready [current]
    [ 1665.552055] sd 32:0:1:0: [sdb]
    [ 1665.552058] Add. Sense: No additional sense information
    [ 1665.552063] sd 32:0:1:0: [sdb] CDB:
    [ 1665.552066] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.552962] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.553026] sd 32:0:1:0: [sdb]
    [ 1665.553031] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.553035] sd 32:0:1:0: [sdb]
    [ 1665.553038] Sense Key : Not Ready [current]
    [ 1665.553043] sd 32:0:1:0: [sdb]
    [ 1665.553046] Add. Sense: No additional sense information
    [ 1665.553050] sd 32:0:1:0: [sdb] CDB:
    [ 1665.553053] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.554784] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.554791] sd 32:0:1:0: [sdb]
    [ 1665.554794] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.554798] sd 32:0:1:0: [sdb]
    [ 1665.554800] Sense Key : Not Ready [current]
    [ 1665.554805] sd 32:0:1:0: [sdb]
    [ 1665.554808] Add. Sense: No additional sense information
    [ 1665.554812] sd 32:0:1:0: [sdb] CDB:
    [ 1665.554814] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.555269] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.555275] sd 32:0:1:0: [sdb]
    [ 1665.555278] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.555281] sd 32:0:1:0: [sdb]
    [ 1665.555283] Sense Key : Not Ready [current]
    [ 1665.555288] sd 32:0:1:0: [sdb]
    [ 1665.555291] Add. Sense: No additional sense information
    [ 1665.555294] sd 32:0:1:0: [sdb] CDB:
    [ 1665.555296] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.557426] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.557436] sd 32:0:1:0: [sdb]
    [ 1665.557440] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.557443] sd 32:0:1:0: [sdb]
    [ 1665.557446] Sense Key : Not Ready [current]
    [ 1665.557451] sd 32:0:1:0: [sdb]
    [ 1665.557454] Add. Sense: No additional sense information
    [ 1665.557457] sd 32:0:1:0: [sdb] CDB:
    [ 1665.557460] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.557847] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.557852] sd 32:0:1:0: [sdb]
    [ 1665.557856] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.557859] sd 32:0:1:0: [sdb]
    [ 1665.557861] Sense Key : Not Ready [current]
    [ 1665.557866] sd 32:0:1:0: [sdb]
    [ 1665.557868] Add. Sense: No additional sense information
    [ 1665.557872] sd 32:0:1:0: [sdb] CDB:
    [ 1665.557874] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.560452] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.560460] sd 32:0:1:0: [sdb]
    [ 1665.560464] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.560467] sd 32:0:1:0: [sdb]
    [ 1665.560470] Sense Key : Not Ready [current]
    [ 1665.560475] sd 32:0:1:0: [sdb]
    [ 1665.560478] Add. Sense: No additional sense information
    [ 1665.560482] sd 32:0:1:0: [sdb] CDB:
    [ 1665.560484] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.561561] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.561568] sd 32:0:1:0: [sdb]
    [ 1665.561572] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.561575] sd 32:0:1:0: [sdb]
    [ 1665.561578] Sense Key : Not Ready [current]
    [ 1665.561582] sd 32:0:1:0: [sdb]
    [ 1665.561585] Add. Sense: No additional sense information
    [ 1665.561589] sd 32:0:1:0: [sdb] CDB:
    [ 1665.561591] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.562213] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.562223] sd 32:0:1:0: [sdb]
    [ 1665.562229] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.562234] sd 32:0:1:0: [sdb]
    [ 1665.562238] Sense Key : Not Ready [current]
    [ 1665.562244] sd 32:0:1:0: [sdb]
    [ 1665.562247] Add. Sense: No additional sense information
    [ 1665.562252] sd 32:0:1:0: [sdb] CDB:
    [ 1665.562257] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.565153] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.565196] sd 32:0:1:0: [sdb]
    [ 1665.565207] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.565214] sd 32:0:1:0: [sdb]
    [ 1665.565220] Sense Key : Not Ready [current]
    [ 1665.565236] sd 32:0:1:0: [sdb]
    [ 1665.565243] Add. Sense: No additional sense information
    [ 1665.565250] sd 32:0:1:0: [sdb] CDB:
    [ 1665.565254] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.566993] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.567002] sd 32:0:1:0: [sdb]
    [ 1665.567079] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.567089] sd 32:0:1:0: [sdb]
    [ 1665.567094] Sense Key : Not Ready [current]
    [ 1665.567102] sd 32:0:1:0: [sdb]
    [ 1665.567107] Add. Sense: No additional sense information
    [ 1665.567112] sd 32:0:1:0: [sdb] CDB:
    [ 1665.567115] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.567756] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.567763] sd 32:0:1:0: [sdb]
    [ 1665.567767] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.567771] sd 32:0:1:0: [sdb]
    [ 1665.567773] Sense Key : Not Ready [current]
    [ 1665.567779] sd 32:0:1:0: [sdb]
    [ 1665.567782] Add. Sense: No additional sense information
    [ 1665.567786] sd 32:0:1:0: [sdb] CDB:
    [ 1665.567788] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.568470] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.568481] sd 32:0:1:0: [sdb]
    [ 1665.568485] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.568489] sd 32:0:1:0: [sdb]
    [ 1665.568492] Sense Key : Not Ready [current]
    [ 1665.568499] sd 32:0:1:0: [sdb]
    [ 1665.568502] Add. Sense: No additional sense information
    [ 1665.568507] sd 32:0:1:0: [sdb] CDB:
    [ 1665.568509] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.569193] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.569200] sd 32:0:1:0: [sdb]
    [ 1665.569203] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.569207] sd 32:0:1:0: [sdb]
    [ 1665.569209] Sense Key : Not Ready [current]
    [ 1665.569215] sd 32:0:1:0: [sdb]
    [ 1665.569217] Add. Sense: No additional sense information
    [ 1665.569221] sd 32:0:1:0: [sdb] CDB:
    [ 1665.569223] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.570577] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.570587] sd 32:0:1:0: [sdb]
    [ 1665.570591] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.570595] sd 32:0:1:0: [sdb]
    [ 1665.570598] Sense Key : Not Ready [current]
    [ 1665.570604] sd 32:0:1:0: [sdb]
    [ 1665.570608] Add. Sense: No additional sense information
    [ 1665.570612] sd 32:0:1:0: [sdb] CDB:
    [ 1665.570614] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.571207] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.571214] sd 32:0:1:0: [sdb]
    [ 1665.571217] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.571220] sd 32:0:1:0: [sdb]
    [ 1665.571223] Sense Key : Not Ready [current]
    [ 1665.571228] sd 32:0:1:0: [sdb]
    [ 1665.571231] Add. Sense: No additional sense information
    [ 1665.571235] sd 32:0:1:0: [sdb] CDB:
    [ 1665.571237] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.572440] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.572451] sd 32:0:1:0: [sdb]
    [ 1665.572455] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.572459] sd 32:0:1:0: [sdb]
    [ 1665.572462] Sense Key : Not Ready [current]
    [ 1665.572468] sd 32:0:1:0: [sdb]
    [ 1665.572471] Add. Sense: No additional sense information
    [ 1665.572475] sd 32:0:1:0: [sdb] CDB:
    [ 1665.572479] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.573440] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.573451] sd 32:0:1:0: [sdb]
    [ 1665.573454] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.573458] sd 32:0:1:0: [sdb]
    [ 1665.573461] Sense Key : Not Ready [current]
    [ 1665.573466] sd 32:0:1:0: [sdb]
    [ 1665.573469] Add. Sense: No additional sense information
    [ 1665.573474] sd 32:0:1:0: [sdb] CDB:
    [ 1665.573476] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.575313] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.575354] sd 32:0:1:0: [sdb]
    [ 1665.575359] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.575363] sd 32:0:1:0: [sdb]
    [ 1665.575366] Sense Key : Not Ready [current]
    [ 1665.575371] sd 32:0:1:0: [sdb]
    [ 1665.575374] Add. Sense: No additional sense information
    [ 1665.575377] sd 32:0:1:0: [sdb] CDB:
    [ 1665.575380] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1665.576297] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.576335] sd 32:0:1:0: [sdb]
    [ 1665.576339] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.576343] sd 32:0:1:0: [sdb]
    [ 1665.576346] Sense Key : Not Ready [current]
    [ 1665.576352] sd 32:0:1:0: [sdb]
    [ 1665.576355] Add. Sense: No additional sense information
    [ 1665.576360] sd 32:0:1:0: [sdb] CDB:
    [ 1665.576362] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1665.577142] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.577178] sd 32:0:1:0: [sdb]
    [ 1665.577182] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.577186] sd 32:0:1:0: [sdb]
    [ 1665.577189] Sense Key : Not Ready [current]
    [ 1665.577195] sd 32:0:1:0: [sdb]
    [ 1665.577198] Add. Sense: No additional sense information
    [ 1665.577202] sd 32:0:1:0: [sdb] CDB:
    [ 1665.577204] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1665.577957] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.577992] sd 32:0:1:0: [sdb]
    [ 1665.577996] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.578000] sd 32:0:1:0: [sdb]
    [ 1665.578003] Sense Key : Not Ready [current]
    [ 1665.578009] sd 32:0:1:0: [sdb]
    [ 1665.578012] Add. Sense: No additional sense information
    [ 1665.578061] sd 32:0:1:0: [sdb] CDB:
    [ 1665.578063] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1665.578810] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.578845] sd 32:0:1:0: [sdb]
    [ 1665.578849] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.578853] sd 32:0:1:0: [sdb]
    [ 1665.578856] Sense Key : Not Ready [current]
    [ 1665.578862] sd 32:0:1:0: [sdb]
    [ 1665.578865] Add. Sense: No additional sense information
    [ 1665.578869] sd 32:0:1:0: [sdb] CDB:
    [ 1665.578872] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1665.579723] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.579758] sd 32:0:1:0: [sdb]
    [ 1665.579763] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.579767] sd 32:0:1:0: [sdb]
    [ 1665.579769] Sense Key : Not Ready [current]
    [ 1665.579776] sd 32:0:1:0: [sdb]
    [ 1665.579779] Add. Sense: No additional sense information
    [ 1665.579783] sd 32:0:1:0: [sdb] CDB:
    [ 1665.579785] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1665.580482] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.580513] sd 32:0:1:0: [sdb]
    [ 1665.580517] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.580520] sd 32:0:1:0: [sdb]
    [ 1665.580523] Sense Key : Not Ready [current]
    [ 1665.580528] sd 32:0:1:0: [sdb]
    [ 1665.580531] Add. Sense: No additional sense information
    [ 1665.580535] sd 32:0:1:0: [sdb] CDB:
    [ 1665.580537] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1665.581236] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.581243] sd 32:0:1:0: [sdb]
    [ 1665.581247] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.581251] sd 32:0:1:0: [sdb]
    [ 1665.581253] Sense Key : Not Ready [current]
    [ 1665.581258] sd 32:0:1:0: [sdb]
    [ 1665.581261] Add. Sense: No additional sense information
    [ 1665.581265] sd 32:0:1:0: [sdb] CDB:
    [ 1665.581268] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1665.581917] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.581927] sd 32:0:1:0: [sdb]
    [ 1665.581931] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.581935] sd 32:0:1:0: [sdb]
    [ 1665.581937] Sense Key : Not Ready [current]
    [ 1665.581944] sd 32:0:1:0: [sdb]
    [ 1665.581947] Add. Sense: No additional sense information
    [ 1665.581951] sd 32:0:1:0: [sdb] CDB:
    [ 1665.581953] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1665.582870] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.582909] sd 32:0:1:0: [sdb]
    [ 1665.582913] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.582917] sd 32:0:1:0: [sdb]
    [ 1665.582920] Sense Key : Not Ready [current]
    [ 1665.582926] sd 32:0:1:0: [sdb]
    [ 1665.582929] Add. Sense: No additional sense information
    [ 1665.582933] sd 32:0:1:0: [sdb] CDB:
    [ 1665.582936] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1665.583753] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.583790] sd 32:0:1:0: [sdb]
    [ 1665.583795] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.583799] sd 32:0:1:0: [sdb]
    [ 1665.583801] Sense Key : Not Ready [current]
    [ 1665.583808] sd 32:0:1:0: [sdb]
    [ 1665.583811] Add. Sense: No additional sense information
    [ 1665.583815] sd 32:0:1:0: [sdb] CDB:
    [ 1665.583817] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1665.584653] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.584688] sd 32:0:1:0: [sdb]
    [ 1665.584693] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.584697] sd 32:0:1:0: [sdb]
    [ 1665.584700] Sense Key : Not Ready [current]
    [ 1665.584706] sd 32:0:1:0: [sdb]
    [ 1665.584709] Add. Sense: No additional sense information
    [ 1665.584713] sd 32:0:1:0: [sdb] CDB:
    [ 1665.584715] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1665.585417] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.585447] sd 32:0:1:0: [sdb]
    [ 1665.585451] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.585454] sd 32:0:1:0: [sdb]
    [ 1665.585457] Sense Key : Not Ready [current]
    [ 1665.585462] sd 32:0:1:0: [sdb]
    [ 1665.585465] Add. Sense: No additional sense information
    [ 1665.585468] sd 32:0:1:0: [sdb] CDB:
    [ 1665.585470] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.586109] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.586137] sd 32:0:1:0: [sdb]
    [ 1665.586141] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.586144] sd 32:0:1:0: [sdb]
    [ 1665.586146] Sense Key : Not Ready [current]
    [ 1665.586151] sd 32:0:1:0: [sdb]
    [ 1665.586154] Add. Sense: No additional sense information
    [ 1665.586157] sd 32:0:1:0: [sdb] CDB:
    [ 1665.586159] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.586844] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.586880] sd 32:0:1:0: [sdb]
    [ 1665.586884] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.586888] sd 32:0:1:0: [sdb]
    [ 1665.586891] Sense Key : Not Ready [current]
    [ 1665.586898] sd 32:0:1:0: [sdb]
    [ 1665.586901] Add. Sense: No additional sense information
    [ 1665.586905] sd 32:0:1:0: [sdb] CDB:
    [ 1665.586907] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.587720] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.587755] sd 32:0:1:0: [sdb]
    [ 1665.587759] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.587763] sd 32:0:1:0: [sdb]
    [ 1665.587766] Sense Key : Not Ready [current]
    [ 1665.587772] sd 32:0:1:0: [sdb]
    [ 1665.587775] Add. Sense: No additional sense information
    [ 1665.587779] sd 32:0:1:0: [sdb] CDB:
    [ 1665.587782] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.588576] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.588611] sd 32:0:1:0: [sdb]
    [ 1665.588616] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.588620] sd 32:0:1:0: [sdb]
    [ 1665.588623] Sense Key : Not Ready [current]
    [ 1665.588629] sd 32:0:1:0: [sdb]
    [ 1665.588632] Add. Sense: No additional sense information
    [ 1665.588636] sd 32:0:1:0: [sdb] CDB:
    [ 1665.588638] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1665.589340] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.589370] sd 32:0:1:0: [sdb]
    [ 1665.589374] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.589378] sd 32:0:1:0: [sdb]
    [ 1665.589380] Sense Key : Not Ready [current]
    [ 1665.589385] sd 32:0:1:0: [sdb]
    [ 1665.589388] Add. Sense: No additional sense information
    [ 1665.589391] sd 32:0:1:0: [sdb] CDB:
    [ 1665.589393] Read(10): 28 00 00 00 00 18 00 00 08 00
    [ 1665.590113] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.590148] sd 32:0:1:0: [sdb]
    [ 1665.590153] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.590157] sd 32:0:1:0: [sdb]
    [ 1665.590160] Sense Key : Not Ready [current]
    [ 1665.590166] sd 32:0:1:0: [sdb]
    [ 1665.590169] Add. Sense: No additional sense information
    [ 1665.590174] sd 32:0:1:0: [sdb] CDB:
    [ 1665.590176] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1665.590944] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.590979] sd 32:0:1:0: [sdb]
    [ 1665.590984] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.590988] sd 32:0:1:0: [sdb]
    [ 1665.590991] Sense Key : Not Ready [current]
    [ 1665.590997] sd 32:0:1:0: [sdb]
    [ 1665.591000] Add. Sense: No additional sense information
    [ 1665.591004] sd 32:0:1:0: [sdb] CDB:
    [ 1665.591007] Read(10): 28 00 00 00 00 38 00 00 08 00
    [ 1665.591734] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.591741] sd 32:0:1:0: [sdb]
    [ 1665.591744] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.591747] sd 32:0:1:0: [sdb]
    [ 1665.591750] Sense Key : Not Ready [current]
    [ 1665.591755] sd 32:0:1:0: [sdb]
    [ 1665.591758] Add. Sense: No additional sense information
    [ 1665.591762] sd 32:0:1:0: [sdb] CDB:
    [ 1665.591764] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1665.592272] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.592281] sd 32:0:1:0: [sdb]
    [ 1665.592285] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.592289] sd 32:0:1:0: [sdb]
    [ 1665.592292] Sense Key : Not Ready [current]
    [ 1665.592298] sd 32:0:1:0: [sdb]
    [ 1665.592301] Add. Sense: No additional sense information
    [ 1665.592305] sd 32:0:1:0: [sdb] CDB:
    [ 1665.592308] Read(10): 28 00 00 00 00 78 00 00 08 00
    [ 1665.592822] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.592831] sd 32:0:1:0: [sdb]
    [ 1665.592835] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.592839] sd 32:0:1:0: [sdb]
    [ 1665.592842] Sense Key : Not Ready [current]
    [ 1665.592848] sd 32:0:1:0: [sdb]
    [ 1665.592851] Add. Sense: No additional sense information
    [ 1665.592856] sd 32:0:1:0: [sdb] CDB:
    [ 1665.592858] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.593314] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.593320] sd 32:0:1:0: [sdb]
    [ 1665.593324] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.593327] sd 32:0:1:0: [sdb]
    [ 1665.593330] Sense Key : Not Ready [current]
    [ 1665.593335] sd 32:0:1:0: [sdb]
    [ 1665.593337] Add. Sense: No additional sense information
    [ 1665.593341] sd 32:0:1:0: [sdb] CDB:
    [ 1665.593343] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.593866] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.593875] sd 32:0:1:0: [sdb]
    [ 1665.593879] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.593883] sd 32:0:1:0: [sdb]
    [ 1665.593886] Sense Key : Not Ready [current]
    [ 1665.593892] sd 32:0:1:0: [sdb]
    [ 1665.593895] Add. Sense: No additional sense information
    [ 1665.593899] sd 32:0:1:0: [sdb] CDB:
    [ 1665.593901] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.595159] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.595196] sd 32:0:1:0: [sdb]
    [ 1665.595200] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.595204] sd 32:0:1:0: [sdb]
    [ 1665.595207] Sense Key : Not Ready [current]
    [ 1665.595213] sd 32:0:1:0: [sdb]
    [ 1665.595216] Add. Sense: No additional sense information
    [ 1665.595220] sd 32:0:1:0: [sdb] CDB:
    [ 1665.595223] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.595959] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.595995] sd 32:0:1:0: [sdb]
    [ 1665.595999] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.596003] sd 32:0:1:0: [sdb]
    [ 1665.596006] Sense Key : Not Ready [current]
    [ 1665.596012] sd 32:0:1:0: [sdb]
    [ 1665.596015] Add. Sense: No additional sense information
    [ 1665.596019] sd 32:0:1:0: [sdb] CDB:
    [ 1665.596022] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.596935] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.596971] sd 32:0:1:0: [sdb]
    [ 1665.596975] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.596979] sd 32:0:1:0: [sdb]
    [ 1665.596982] Sense Key : Not Ready [current]
    [ 1665.596988] sd 32:0:1:0: [sdb]
    [ 1665.596991] Add. Sense: No additional sense information
    [ 1665.596995] sd 32:0:1:0: [sdb] CDB:
    [ 1665.596997] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.597825] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.597860] sd 32:0:1:0: [sdb]
    [ 1665.597865] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.597869] sd 32:0:1:0: [sdb]
    [ 1665.597871] Sense Key : Not Ready [current]
    [ 1665.597877] sd 32:0:1:0: [sdb]
    [ 1665.597881] Add. Sense: No additional sense information
    [ 1665.597885] sd 32:0:1:0: [sdb] CDB:
    [ 1665.597887] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1665.598666] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.598700] sd 32:0:1:0: [sdb]
    [ 1665.598705] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.598709] sd 32:0:1:0: [sdb]
    [ 1665.598712] Sense Key : Not Ready [current]
    [ 1665.598718] sd 32:0:1:0: [sdb]
    [ 1665.598721] Add. Sense: No additional sense information
    [ 1665.598725] sd 32:0:1:0: [sdb] CDB:
    [ 1665.598728] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1665.599204] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.599211] sd 32:0:1:0: [sdb]
    [ 1665.599214] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.599217] sd 32:0:1:0: [sdb]
    [ 1665.599220] Sense Key : Not Ready [current]
    [ 1665.599225] sd 32:0:1:0: [sdb]
    [ 1665.599228] Add. Sense: No additional sense information
    [ 1665.599231] sd 32:0:1:0: [sdb] CDB:
    [ 1665.599233] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1665.599773] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.599782] sd 32:0:1:0: [sdb]
    [ 1665.599786] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.599790] sd 32:0:1:0: [sdb]
    [ 1665.599793] Sense Key : Not Ready [current]
    [ 1665.599799] sd 32:0:1:0: [sdb]
    [ 1665.599802] Add. Sense: No additional sense information
    [ 1665.599806] sd 32:0:1:0: [sdb] CDB:
    [ 1665.599808] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1665.600349] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.600359] sd 32:0:1:0: [sdb]
    [ 1665.600363] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.600367] sd 32:0:1:0: [sdb]
    [ 1665.600369] Sense Key : Not Ready [current]
    [ 1665.600376] sd 32:0:1:0: [sdb]
    [ 1665.600379] Add. Sense: No additional sense information
    [ 1665.600383] sd 32:0:1:0: [sdb] CDB:
    [ 1665.600385] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1665.600898] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.600908] sd 32:0:1:0: [sdb]
    [ 1665.600912] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.600916] sd 32:0:1:0: [sdb]
    [ 1665.600919] Sense Key : Not Ready [current]
    [ 1665.600925] sd 32:0:1:0: [sdb]
    [ 1665.600928] Add. Sense: No additional sense information
    [ 1665.600933] sd 32:0:1:0: [sdb] CDB:
    [ 1665.600935] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1665.601479] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.601488] sd 32:0:1:0: [sdb]
    [ 1665.601492] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.601496] sd 32:0:1:0: [sdb]
    [ 1665.601499] Sense Key : Not Ready [current]
    [ 1665.601505] sd 32:0:1:0: [sdb]
    [ 1665.601508] Add. Sense: No additional sense information
    [ 1665.601512] sd 32:0:1:0: [sdb] CDB:
    [ 1665.601515] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1665.601948] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.601953] sd 32:0:1:0: [sdb]
    [ 1665.601956] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.601959] sd 32:0:1:0: [sdb]
    [ 1665.601962] Sense Key : Not Ready [current]
    [ 1665.601967] sd 32:0:1:0: [sdb]
    [ 1665.601969] Add. Sense: No additional sense information
    [ 1665.601973] sd 32:0:1:0: [sdb] CDB:
    [ 1665.601975] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1665.602998] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.603034] sd 32:0:1:0: [sdb]
    [ 1665.603093] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.603099] sd 32:0:1:0: [sdb]
    [ 1665.603101] Sense Key : Not Ready [current]
    [ 1665.603107] sd 32:0:1:0: [sdb]
    [ 1665.603111] Add. Sense: No additional sense information
    [ 1665.603115] sd 32:0:1:0: [sdb] CDB:
    [ 1665.603117] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1665.603578] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.603585] sd 32:0:1:0: [sdb]
    [ 1665.603588] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.603591] sd 32:0:1:0: [sdb]
    [ 1665.603594] Sense Key : Not Ready [current]
    [ 1665.603599] sd 32:0:1:0: [sdb]
    [ 1665.603602] Add. Sense: No additional sense information
    [ 1665.603606] sd 32:0:1:0: [sdb] CDB:
    [ 1665.603608] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1665.604155] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.604164] sd 32:0:1:0: [sdb]
    [ 1665.604168] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.604172] sd 32:0:1:0: [sdb]
    [ 1665.604175] Sense Key : Not Ready [current]
    [ 1665.604181] sd 32:0:1:0: [sdb]
    [ 1665.604184] Add. Sense: No additional sense information
    [ 1665.604188] sd 32:0:1:0: [sdb] CDB:
    [ 1665.604191] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1665.604730] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.604739] sd 32:0:1:0: [sdb]
    [ 1665.604743] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.604747] sd 32:0:1:0: [sdb]
    [ 1665.604749] Sense Key : Not Ready [current]
    [ 1665.604756] sd 32:0:1:0: [sdb]
    [ 1665.604759] Add. Sense: No additional sense information
    [ 1665.604763] sd 32:0:1:0: [sdb] CDB:
    [ 1665.604765] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1665.605378] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.605387] sd 32:0:1:0: [sdb]
    [ 1665.605391] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.605395] sd 32:0:1:0: [sdb]
    [ 1665.605398] Sense Key : Not Ready [current]
    [ 1665.605404] sd 32:0:1:0: [sdb]
    [ 1665.605407] Add. Sense: No additional sense information
    [ 1665.605412] sd 32:0:1:0: [sdb] CDB:
    [ 1665.605414] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1665.605974] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.605983] sd 32:0:1:0: [sdb]
    [ 1665.605987] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.605991] sd 32:0:1:0: [sdb]
    [ 1665.605994] Sense Key : Not Ready [current]
    [ 1665.606000] sd 32:0:1:0: [sdb]
    [ 1665.606003] Add. Sense: No additional sense information
    [ 1665.606007] sd 32:0:1:0: [sdb] CDB:
    [ 1665.606009] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1665.607145] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.607180] sd 32:0:1:0: [sdb]
    [ 1665.607185] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.607189] sd 32:0:1:0: [sdb]
    [ 1665.607192] Sense Key : Not Ready [current]
    [ 1665.607198] sd 32:0:1:0: [sdb]
    [ 1665.607201] Add. Sense: No additional sense information
    [ 1665.607205] sd 32:0:1:0: [sdb] CDB:
    [ 1665.607207] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1665.607646] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.607652] sd 32:0:1:0: [sdb]
    [ 1665.607655] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.607659] sd 32:0:1:0: [sdb]
    [ 1665.607661] Sense Key : Not Ready [current]
    [ 1665.607666] sd 32:0:1:0: [sdb]
    [ 1665.607669] Add. Sense: No additional sense information
    [ 1665.607673] sd 32:0:1:0: [sdb] CDB:
    [ 1665.607675] Read(10): 28 00 00 00 00 40 00 00 08 00
    [ 1665.608187] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.608196] sd 32:0:1:0: [sdb]
    [ 1665.608200] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.608204] sd 32:0:1:0: [sdb]
    [ 1665.608207] Sense Key : Not Ready [current]
    [ 1665.608213] sd 32:0:1:0: [sdb]
    [ 1665.608216] Add. Sense: No additional sense information
    [ 1665.608220] sd 32:0:1:0: [sdb] CDB:
    [ 1665.608222] Read(10): 28 00 00 00 01 00 00 00 08 00
    [ 1665.608759] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.608769] sd 32:0:1:0: [sdb]
    [ 1665.608773] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.608777] sd 32:0:1:0: [sdb]
    [ 1665.608780] Sense Key : Not Ready [current]
    [ 1665.608786] sd 32:0:1:0: [sdb]
    [ 1665.608789] Add. Sense: No additional sense information
    [ 1665.608794] sd 32:0:1:0: [sdb] CDB:
    [ 1665.608796] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.609280] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.609289] sd 32:0:1:0: [sdb]
    [ 1665.609293] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.609297] sd 32:0:1:0: [sdb]
    [ 1665.609300] Sense Key : Not Ready [current]
    [ 1665.609306] sd 32:0:1:0: [sdb]
    [ 1665.609310] Add. Sense: No additional sense information
    [ 1665.609314] sd 32:0:1:0: [sdb] CDB:
    [ 1665.609316] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.609892] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.609901] sd 32:0:1:0: [sdb]
    [ 1665.609905] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.609909] sd 32:0:1:0: [sdb]
    [ 1665.609911] Sense Key : Not Ready [current]
    [ 1665.609918] sd 32:0:1:0: [sdb]
    [ 1665.609921] Add. Sense: No additional sense information
    [ 1665.609925] sd 32:0:1:0: [sdb] CDB:
    [ 1665.609927] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.610344] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.610349] sd 32:0:1:0: [sdb]
    [ 1665.610353] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.610356] sd 32:0:1:0: [sdb]
    [ 1665.610358] Sense Key : Not Ready [current]
    [ 1665.610363] sd 32:0:1:0: [sdb]
    [ 1665.610366] Add. Sense: No additional sense information
    [ 1665.610369] sd 32:0:1:0: [sdb] CDB:
    [ 1665.610372] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.611366] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.611401] sd 32:0:1:0: [sdb]
    [ 1665.611406] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.611410] sd 32:0:1:0: [sdb]
    [ 1665.611412] Sense Key : Not Ready [current]
    [ 1665.611419] sd 32:0:1:0: [sdb]
    [ 1665.611422] Add. Sense: No additional sense information
    [ 1665.611426] sd 32:0:1:0: [sdb] CDB:
    [ 1665.611428] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.611873] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.611879] sd 32:0:1:0: [sdb]
    [ 1665.611882] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.611886] sd 32:0:1:0: [sdb]
    [ 1665.611888] Sense Key : Not Ready [current]
    [ 1665.611893] sd 32:0:1:0: [sdb]
    [ 1665.611895] Add. Sense: No additional sense information
    [ 1665.611899] sd 32:0:1:0: [sdb] CDB:
    [ 1665.611901] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1665.612422] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.612431] sd 32:0:1:0: [sdb]
    [ 1665.612435] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.612439] sd 32:0:1:0: [sdb]
    [ 1665.612441] Sense Key : Not Ready [current]
    [ 1665.612448] sd 32:0:1:0: [sdb]
    [ 1665.612451] Add. Sense: No additional sense information
    [ 1665.612455] sd 32:0:1:0: [sdb] CDB:
    [ 1665.612457] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.612971] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.612980] sd 32:0:1:0: [sdb]
    [ 1665.612984] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.612988] sd 32:0:1:0: [sdb]
    [ 1665.612991] Sense Key : Not Ready [current]
    [ 1665.612997] sd 32:0:1:0: [sdb]
    [ 1665.613001] Add. Sense: No additional sense information
    [ 1665.613005] sd 32:0:1:0: [sdb] CDB:
    [ 1665.613007] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.613541] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.613551] sd 32:0:1:0: [sdb]
    [ 1665.613555] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.613559] sd 32:0:1:0: [sdb]
    [ 1665.613562] Sense Key : Not Ready [current]
    [ 1665.613568] sd 32:0:1:0: [sdb]
    [ 1665.613572] Add. Sense: No additional sense information
    [ 1665.613576] sd 32:0:1:0: [sdb] CDB:
    [ 1665.613578] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.614012] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.614017] sd 32:0:1:0: [sdb]
    [ 1665.614020] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.614024] sd 32:0:1:0: [sdb]
    [ 1665.614026] Sense Key : Not Ready [current]
    [ 1665.614031] sd 32:0:1:0: [sdb]
    [ 1665.614034] Add. Sense: No additional sense information
    [ 1665.614037] sd 32:0:1:0: [sdb] CDB:
    [ 1665.614039] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.614894] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.614901] sd 32:0:1:0: [sdb]
    [ 1665.614904] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.614908] sd 32:0:1:0: [sdb]
    [ 1665.614910] Sense Key : Not Ready [current]
    [ 1665.614915] sd 32:0:1:0: [sdb]
    [ 1665.614918] Add. Sense: No additional sense information
    [ 1665.614921] sd 32:0:1:0: [sdb] CDB:
    [ 1665.614923] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.615416] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.615422] sd 32:0:1:0: [sdb]
    [ 1665.615425] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.615428] sd 32:0:1:0: [sdb]
    [ 1665.615430] Sense Key : Not Ready [current]
    [ 1665.615435] sd 32:0:1:0: [sdb]
    [ 1665.615437] Add. Sense: No additional sense information
    [ 1665.615441] sd 32:0:1:0: [sdb] CDB:
    [ 1665.615443] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.615917] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.615926] sd 32:0:1:0: [sdb]
    [ 1665.615931] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.615934] sd 32:0:1:0: [sdb]
    [ 1665.615937] Sense Key : Not Ready [current]
    [ 1665.615943] sd 32:0:1:0: [sdb]
    [ 1665.615947] Add. Sense: No additional sense information
    [ 1665.615951] sd 32:0:1:0: [sdb] CDB:
    [ 1665.615953] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.616496] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.616506] sd 32:0:1:0: [sdb]
    [ 1665.616510] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.616514] sd 32:0:1:0: [sdb]
    [ 1665.616516] Sense Key : Not Ready [current]
    [ 1665.616522] sd 32:0:1:0: [sdb]
    [ 1665.616526] Add. Sense: No additional sense information
    [ 1665.616530] sd 32:0:1:0: [sdb] CDB:
    [ 1665.616532] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.617043] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.617052] sd 32:0:1:0: [sdb]
    [ 1665.617056] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.617115] sd 32:0:1:0: [sdb]
    [ 1665.617120] Sense Key : Not Ready [current]
    [ 1665.617126] sd 32:0:1:0: [sdb]
    [ 1665.617130] Add. Sense: No additional sense information
    [ 1665.617134] sd 32:0:1:0: [sdb] CDB:
    [ 1665.617136] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.617682] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.617691] sd 32:0:1:0: [sdb]
    [ 1665.617695] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.617699] sd 32:0:1:0: [sdb]
    [ 1665.617702] Sense Key : Not Ready [current]
    [ 1665.617708] sd 32:0:1:0: [sdb]
    [ 1665.617711] Add. Sense: No additional sense information
    [ 1665.617715] sd 32:0:1:0: [sdb] CDB:
    [ 1665.617718] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.618163] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.618168] sd 32:0:1:0: [sdb]
    [ 1665.618172] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.618175] sd 32:0:1:0: [sdb]
    [ 1665.618177] Sense Key : Not Ready [current]
    [ 1665.618182] sd 32:0:1:0: [sdb]
    [ 1665.618185] Add. Sense: No additional sense information
    [ 1665.618188] sd 32:0:1:0: [sdb] CDB:
    [ 1665.618190] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.619300] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.619335] sd 32:0:1:0: [sdb]
    [ 1665.619340] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.619344] sd 32:0:1:0: [sdb]
    [ 1665.619346] Sense Key : Not Ready [current]
    [ 1665.619353] sd 32:0:1:0: [sdb]
    [ 1665.619356] Add. Sense: No additional sense information
    [ 1665.619360] sd 32:0:1:0: [sdb] CDB:
    [ 1665.619362] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.619869] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.619876] sd 32:0:1:0: [sdb]
    [ 1665.619879] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.619883] sd 32:0:1:0: [sdb]
    [ 1665.619885] Sense Key : Not Ready [current]
    [ 1665.619890] sd 32:0:1:0: [sdb]
    [ 1665.619893] Add. Sense: No additional sense information
    [ 1665.619897] sd 32:0:1:0: [sdb] CDB:
    [ 1665.619899] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1665.620726] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.620735] sd 32:0:1:0: [sdb]
    [ 1665.620739] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.620743] sd 32:0:1:0: [sdb]
    [ 1665.620746] Sense Key : Not Ready [current]
    [ 1665.620753] sd 32:0:1:0: [sdb]
    [ 1665.620756] Add. Sense: No additional sense information
    [ 1665.620760] sd 32:0:1:0: [sdb] CDB:
    [ 1665.620762] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1665.621266] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.621272] sd 32:0:1:0: [sdb]
    [ 1665.621275] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.621278] sd 32:0:1:0: [sdb]
    [ 1665.621281] Sense Key : Not Ready [current]
    [ 1665.621286] sd 32:0:1:0: [sdb]
    [ 1665.621289] Add. Sense: No additional sense information
    [ 1665.621292] sd 32:0:1:0: [sdb] CDB:
    [ 1665.621294] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1665.621685] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.621691] sd 32:0:1:0: [sdb]
    [ 1665.621694] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.621697] sd 32:0:1:0: [sdb]
    [ 1665.621699] Sense Key : Not Ready [current]
    [ 1665.621704] sd 32:0:1:0: [sdb]
    [ 1665.621706] Add. Sense: No additional sense information
    [ 1665.621710] sd 32:0:1:0: [sdb] CDB:
    [ 1665.621712] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.622052] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.622056] sd 32:0:1:0: [sdb]
    [ 1665.622059] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.622062] sd 32:0:1:0: [sdb]
    [ 1665.622065] Sense Key : Not Ready [current]
    [ 1665.622117] sd 32:0:1:0: [sdb]
    [ 1665.622121] Add. Sense: No additional sense information
    [ 1665.622125] sd 32:0:1:0: [sdb] CDB:
    [ 1665.622127] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.623139] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.623179] sd 32:0:1:0: [sdb]
    [ 1665.623184] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.623188] sd 32:0:1:0: [sdb]
    [ 1665.623191] Sense Key : Not Ready [current]
    [ 1665.623197] sd 32:0:1:0: [sdb]
    [ 1665.623200] Add. Sense: No additional sense information
    [ 1665.623205] sd 32:0:1:0: [sdb] CDB:
    [ 1665.623207] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.623670] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.623676] sd 32:0:1:0: [sdb]
    [ 1665.623679] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.623682] sd 32:0:1:0: [sdb]
    [ 1665.623685] Sense Key : Not Ready [current]
    [ 1665.623690] sd 32:0:1:0: [sdb]
    [ 1665.623693] Add. Sense: No additional sense information
    [ 1665.623696] sd 32:0:1:0: [sdb] CDB:
    [ 1665.623698] Read(10): 28 00 00 00 00 10 00 00 08 00
    [ 1665.624264] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.624273] sd 32:0:1:0: [sdb]
    [ 1665.624277] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.624281] sd 32:0:1:0: [sdb]
    [ 1665.624284] Sense Key : Not Ready [current]
    [ 1665.624291] sd 32:0:1:0: [sdb]
    [ 1665.624294] Add. Sense: No additional sense information
    [ 1665.624298] sd 32:0:1:0: [sdb] CDB:
    [ 1665.624301] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.624814] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.624823] sd 32:0:1:0: [sdb]
    [ 1665.624828] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.624831] sd 32:0:1:0: [sdb]
    [ 1665.624834] Sense Key : Not Ready [current]
    [ 1665.624840] sd 32:0:1:0: [sdb]
    [ 1665.624843] Add. Sense: No additional sense information
    [ 1665.624848] sd 32:0:1:0: [sdb] CDB:
    [ 1665.624850] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.625321] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.625327] sd 32:0:1:0: [sdb]
    [ 1665.625330] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.625334] sd 32:0:1:0: [sdb]
    [ 1665.625336] Sense Key : Not Ready [current]
    [ 1665.625341] sd 32:0:1:0: [sdb]
    [ 1665.625343] Add. Sense: No additional sense information
    [ 1665.625347] sd 32:0:1:0: [sdb] CDB:
    [ 1665.625349] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.628771] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.628777] sd 32:0:1:0: [sdb]
    [ 1665.628781] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.628784] sd 32:0:1:0: [sdb]
    [ 1665.628787] Sense Key : Not Ready [current]
    [ 1665.628792] sd 32:0:1:0: [sdb]
    [ 1665.628795] Add. Sense: No additional sense information
    [ 1665.628798] sd 32:0:1:0: [sdb] CDB:
    [ 1665.628801] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.629365] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.629371] sd 32:0:1:0: [sdb]
    [ 1665.629374] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.629378] sd 32:0:1:0: [sdb]
    [ 1665.629380] Sense Key : Not Ready [current]
    [ 1665.629384] sd 32:0:1:0: [sdb]
    [ 1665.629387] Add. Sense: No additional sense information
    [ 1665.629391] sd 32:0:1:0: [sdb] CDB:
    [ 1665.629393] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.630321] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.630328] sd 32:0:1:0: [sdb]
    [ 1665.630331] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.630334] sd 32:0:1:0: [sdb]
    [ 1665.630336] Sense Key : Not Ready [current]
    [ 1665.630341] sd 32:0:1:0: [sdb]
    [ 1665.630344] Add. Sense: No additional sense information
    [ 1665.630347] sd 32:0:1:0: [sdb] CDB:
    [ 1665.630349] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.630753] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.630759] sd 32:0:1:0: [sdb]
    [ 1665.630761] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.630765] sd 32:0:1:0: [sdb]
    [ 1665.630767] Sense Key : Not Ready [current]
    [ 1665.630771] sd 32:0:1:0: [sdb]
    [ 1665.630774] Add. Sense: No additional sense information
    [ 1665.630777] sd 32:0:1:0: [sdb] CDB:
    [ 1665.630779] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1665.631250] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.631259] sd 32:0:1:0: [sdb]
    [ 1665.631264] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.631268] sd 32:0:1:0: [sdb]
    [ 1665.631271] Sense Key : Not Ready [current]
    [ 1665.631277] sd 32:0:1:0: [sdb]
    [ 1665.631280] Add. Sense: No additional sense information
    [ 1665.631284] sd 32:0:1:0: [sdb] CDB:
    [ 1665.631287] Read(10): 28 00 00 00 00 80 00 00 08 00
    [ 1665.631806] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.631815] sd 32:0:1:0: [sdb]
    [ 1665.631819] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.631823] sd 32:0:1:0: [sdb]
    [ 1665.631826] Sense Key : Not Ready [current]
    [ 1665.631832] sd 32:0:1:0: [sdb]
    [ 1665.631835] Add. Sense: No additional sense information
    [ 1665.631839] sd 32:0:1:0: [sdb] CDB:
    [ 1665.631842] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.632362] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.632371] sd 32:0:1:0: [sdb]
    [ 1665.632375] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.632379] sd 32:0:1:0: [sdb]
    [ 1665.632382] Sense Key : Not Ready [current]
    [ 1665.632388] sd 32:0:1:0: [sdb]
    [ 1665.632392] Add. Sense: No additional sense information
    [ 1665.632396] sd 32:0:1:0: [sdb] CDB:
    [ 1665.632398] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.632938] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.632947] sd 32:0:1:0: [sdb]
    [ 1665.632951] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.632955] sd 32:0:1:0: [sdb]
    [ 1665.632958] Sense Key : Not Ready [current]
    [ 1665.632964] sd 32:0:1:0: [sdb]
    [ 1665.632967] Add. Sense: No additional sense information
    [ 1665.632972] sd 32:0:1:0: [sdb] CDB:
    [ 1665.632974] Read(10): 28 00 00 00 10 00 00 00 08 00
    [ 1665.633412] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.633418] sd 32:0:1:0: [sdb]
    [ 1665.633421] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.633424] sd 32:0:1:0: [sdb]
    [ 1665.633426] Sense Key : Not Ready [current]
    [ 1665.633431] sd 32:0:1:0: [sdb]
    [ 1665.633434] Add. Sense: No additional sense information
    [ 1665.633438] sd 32:0:1:0: [sdb] CDB:
    [ 1665.633440] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.633999] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.634008] sd 32:0:1:0: [sdb]
    [ 1665.634012] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.634016] sd 32:0:1:0: [sdb]
    [ 1665.634019] Sense Key : Not Ready [current]
    [ 1665.634025] sd 32:0:1:0: [sdb]
    [ 1665.634028] Add. Sense: No additional sense information
    [ 1665.634033] sd 32:0:1:0: [sdb] CDB:
    [ 1665.634035] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.634528] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.634533] sd 32:0:1:0: [sdb]
    [ 1665.634536] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.634540] sd 32:0:1:0: [sdb]
    [ 1665.634542] Sense Key : Not Ready [current]
    [ 1665.634547] sd 32:0:1:0: [sdb]
    [ 1665.634550] Add. Sense: No additional sense information
    [ 1665.634553] sd 32:0:1:0: [sdb] CDB:
    [ 1665.634555] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.635745] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.635780] sd 32:0:1:0: [sdb]
    [ 1665.635785] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.635789] sd 32:0:1:0: [sdb]
    [ 1665.635792] Sense Key : Not Ready [current]
    [ 1665.635798] sd 32:0:1:0: [sdb]
    [ 1665.635801] Add. Sense: No additional sense information
    [ 1665.635805] sd 32:0:1:0: [sdb] CDB:
    [ 1665.635808] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.636285] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.636292] sd 32:0:1:0: [sdb]
    [ 1665.636295] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.636299] sd 32:0:1:0: [sdb]
    [ 1665.636301] Sense Key : Not Ready [current]
    [ 1665.636307] sd 32:0:1:0: [sdb]
    [ 1665.636310] Add. Sense: No additional sense information
    [ 1665.636314] sd 32:0:1:0: [sdb] CDB:
    [ 1665.636316] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.637007] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.637013] sd 32:0:1:0: [sdb]
    [ 1665.637016] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.637019] sd 32:0:1:0: [sdb]
    [ 1665.637021] Sense Key : Not Ready [current]
    [ 1665.637026] sd 32:0:1:0: [sdb]
    [ 1665.637029] Add. Sense: No additional sense information
    [ 1665.637033] sd 32:0:1:0: [sdb] CDB:
    [ 1665.637035] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1665.725698] sd 32:0:1:0: [sdb] Device not ready
    [ 1665.725709] sd 32:0:1:0: [sdb]
    [ 1665.725714] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1665.725718] sd 32:0:1:0: [sdb]
    [ 1665.725721] Sense Key : Not Ready [current]
    [ 1665.725728] sd 32:0:1:0: [sdb]
    [ 1665.725731] Add. Sense: No additional sense information
    [ 1665.725736] sd 32:0:1:0: [sdb] CDB:
    [ 1665.725738] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.230579] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.230591] sd 32:0:1:0: [sdb]
    [ 1668.230597] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.230601] sd 32:0:1:0: [sdb]
    [ 1668.230604] Sense Key : Not Ready [current]
    [ 1668.230611] sd 32:0:1:0: [sdb]
    [ 1668.230614] Add. Sense: No additional sense information
    [ 1668.230619] sd 32:0:1:0: [sdb] CDB:
    [ 1668.230622] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.231234] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.231244] sd 32:0:1:0: [sdb]
    [ 1668.231247] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.231251] sd 32:0:1:0: [sdb]
    [ 1668.231254] Sense Key : Not Ready [current]
    [ 1668.231260] sd 32:0:1:0: [sdb]
    [ 1668.231264] Add. Sense: No additional sense information
    [ 1668.231268] sd 32:0:1:0: [sdb] CDB:
    [ 1668.231270] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.231711] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.231717] sd 32:0:1:0: [sdb]
    [ 1668.231720] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.231724] sd 32:0:1:0: [sdb]
    [ 1668.231726] Sense Key : Not Ready [current]
    [ 1668.231732] sd 32:0:1:0: [sdb]
    [ 1668.231734] Add. Sense: No additional sense information
    [ 1668.231738] sd 32:0:1:0: [sdb] CDB:
    [ 1668.231740] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.232155] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.232162] sd 32:0:1:0: [sdb]
    [ 1668.232165] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.232168] sd 32:0:1:0: [sdb]
    [ 1668.232171] Sense Key : Not Ready [current]
    [ 1668.232175] sd 32:0:1:0: [sdb]
    [ 1668.232178] Add. Sense: No additional sense information
    [ 1668.232182] sd 32:0:1:0: [sdb] CDB:
    [ 1668.232184] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.233877] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.233888] sd 32:0:1:0: [sdb]
    [ 1668.233894] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.233901] sd 32:0:1:0: [sdb]
    [ 1668.233905] Sense Key : Not Ready [current]
    [ 1668.233913] sd 32:0:1:0: [sdb]
    [ 1668.233918] Add. Sense: No additional sense information
    [ 1668.233924] sd 32:0:1:0: [sdb] CDB:
    [ 1668.233927] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.234979] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.234988] sd 32:0:1:0: [sdb]
    [ 1668.234992] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.234995] sd 32:0:1:0: [sdb]
    [ 1668.234998] Sense Key : Not Ready [current]
    [ 1668.235003] sd 32:0:1:0: [sdb]
    [ 1668.235006] Add. Sense: No additional sense information
    [ 1668.235010] sd 32:0:1:0: [sdb] CDB:
    [ 1668.235012] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.235467] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.235473] sd 32:0:1:0: [sdb]
    [ 1668.235477] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.235480] sd 32:0:1:0: [sdb]
    [ 1668.235482] Sense Key : Not Ready [current]
    [ 1668.235487] sd 32:0:1:0: [sdb]
    [ 1668.235490] Add. Sense: No additional sense information
    [ 1668.235494] sd 32:0:1:0: [sdb] CDB:
    [ 1668.235496] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.236016] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.236023] sd 32:0:1:0: [sdb]
    [ 1668.236026] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.236029] sd 32:0:1:0: [sdb]
    [ 1668.236031] Sense Key : Not Ready [current]
    [ 1668.236036] sd 32:0:1:0: [sdb]
    [ 1668.236038] Add. Sense: No additional sense information
    [ 1668.236042] sd 32:0:1:0: [sdb] CDB:
    [ 1668.236044] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.236653] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.236660] sd 32:0:1:0: [sdb]
    [ 1668.236663] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.236666] sd 32:0:1:0: [sdb]
    [ 1668.236668] Sense Key : Not Ready [current]
    [ 1668.236673] sd 32:0:1:0: [sdb]
    [ 1668.236676] Add. Sense: No additional sense information
    [ 1668.236679] sd 32:0:1:0: [sdb] CDB:
    [ 1668.236682] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.237623] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.237630] sd 32:0:1:0: [sdb]
    [ 1668.237633] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.237636] sd 32:0:1:0: [sdb]
    [ 1668.237639] Sense Key : Not Ready [current]
    [ 1668.237643] sd 32:0:1:0: [sdb]
    [ 1668.237646] Add. Sense: No additional sense information
    [ 1668.237649] sd 32:0:1:0: [sdb] CDB:
    [ 1668.237652] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1668.238131] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.238141] sd 32:0:1:0: [sdb]
    [ 1668.238145] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.238148] sd 32:0:1:0: [sdb]
    [ 1668.238151] Sense Key : Not Ready [current]
    [ 1668.238158] sd 32:0:1:0: [sdb]
    [ 1668.238161] Add. Sense: No additional sense information
    [ 1668.238165] sd 32:0:1:0: [sdb] CDB:
    [ 1668.238167] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1668.238627] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.238636] sd 32:0:1:0: [sdb]
    [ 1668.238641] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.238644] sd 32:0:1:0: [sdb]
    [ 1668.238647] Sense Key : Not Ready [current]
    [ 1668.238652] sd 32:0:1:0: [sdb]
    [ 1668.238655] Add. Sense: No additional sense information
    [ 1668.238658] sd 32:0:1:0: [sdb] CDB:
    [ 1668.238660] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1668.239102] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.239112] sd 32:0:1:0: [sdb]
    [ 1668.239117] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.239121] sd 32:0:1:0: [sdb]
    [ 1668.239124] Sense Key : Not Ready [current]
    [ 1668.239131] sd 32:0:1:0: [sdb]
    [ 1668.239134] Add. Sense: No additional sense information
    [ 1668.239139] sd 32:0:1:0: [sdb] CDB:
    [ 1668.239143] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1668.239588] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.239595] sd 32:0:1:0: [sdb]
    [ 1668.239598] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.239602] sd 32:0:1:0: [sdb]
    [ 1668.239605] Sense Key : Not Ready [current]
    [ 1668.239611] sd 32:0:1:0: [sdb]
    [ 1668.239613] Add. Sense: No additional sense information
    [ 1668.239618] sd 32:0:1:0: [sdb] CDB:
    [ 1668.239620] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1668.240003] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.240009] sd 32:0:1:0: [sdb]
    [ 1668.240012] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.240016] sd 32:0:1:0: [sdb]
    [ 1668.240018] Sense Key : Not Ready [current]
    [ 1668.240023] sd 32:0:1:0: [sdb]
    [ 1668.240026] Add. Sense: No additional sense information
    [ 1668.240030] sd 32:0:1:0: [sdb] CDB:
    [ 1668.240032] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1668.245283] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.245296] sd 32:0:1:0: [sdb]
    [ 1668.245303] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.245309] sd 32:0:1:0: [sdb]
    [ 1668.245313] Sense Key : Not Ready [current]
    [ 1668.245322] sd 32:0:1:0: [sdb]
    [ 1668.245327] Add. Sense: No additional sense information
    [ 1668.245333] sd 32:0:1:0: [sdb] CDB:
    [ 1668.245337] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1668.245803] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.245809] sd 32:0:1:0: [sdb]
    [ 1668.245813] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.245817] sd 32:0:1:0: [sdb]
    [ 1668.245819] Sense Key : Not Ready [current]
    [ 1668.245825] sd 32:0:1:0: [sdb]
    [ 1668.245828] Add. Sense: No additional sense information
    [ 1668.245832] sd 32:0:1:0: [sdb] CDB:
    [ 1668.245834] Read(10): 28 00 00 00 00 08 00 00 08 00
    [ 1668.246256] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.246265] sd 32:0:1:0: [sdb]
    [ 1668.246271] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.246277] sd 32:0:1:0: [sdb]
    [ 1668.246282] Sense Key : Not Ready [current]
    [ 1668.246290] sd 32:0:1:0: [sdb]
    [ 1668.246295] Add. Sense: No additional sense information
    [ 1668.246302] sd 32:0:1:0: [sdb] CDB:
    [ 1668.246306] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.246751] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.246758] sd 32:0:1:0: [sdb]
    [ 1668.246761] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.246765] sd 32:0:1:0: [sdb]
    [ 1668.246767] Sense Key : Not Ready [current]
    [ 1668.246772] sd 32:0:1:0: [sdb]
    [ 1668.246775] Add. Sense: No additional sense information
    [ 1668.246779] sd 32:0:1:0: [sdb] CDB:
    [ 1668.246781] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.247276] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.247285] sd 32:0:1:0: [sdb]
    [ 1668.247291] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.247297] sd 32:0:1:0: [sdb]
    [ 1668.247302] Sense Key : Not Ready [current]
    [ 1668.247310] sd 32:0:1:0: [sdb]
    [ 1668.247315] Add. Sense: No additional sense information
    [ 1668.247322] sd 32:0:1:0: [sdb] CDB:
    [ 1668.247326] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.247783] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.247793] sd 32:0:1:0: [sdb]
    [ 1668.247798] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.247804] sd 32:0:1:0: [sdb]
    [ 1668.247808] Sense Key : Not Ready [current]
    [ 1668.247816] sd 32:0:1:0: [sdb]
    [ 1668.247820] Add. Sense: No additional sense information
    [ 1668.247826] sd 32:0:1:0: [sdb] CDB:
    [ 1668.247830] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1668.248282] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.248289] sd 32:0:1:0: [sdb]
    [ 1668.248292] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.248296] sd 32:0:1:0: [sdb]
    [ 1668.248298] Sense Key : Not Ready [current]
    [ 1668.248303] sd 32:0:1:0: [sdb]
    [ 1668.248306] Add. Sense: No additional sense information
    [ 1668.248309] sd 32:0:1:0: [sdb] CDB:
    [ 1668.248312] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.248745] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.248753] sd 32:0:1:0: [sdb]
    [ 1668.248758] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.248764] sd 32:0:1:0: [sdb]
    [ 1668.248768] Sense Key : Not Ready [current]
    [ 1668.248776] sd 32:0:1:0: [sdb]
    [ 1668.248781] Add. Sense: No additional sense information
    [ 1668.248787] sd 32:0:1:0: [sdb] CDB:
    [ 1668.248791] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.250454] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.250465] sd 32:0:1:0: [sdb]
    [ 1668.250470] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.250476] sd 32:0:1:0: [sdb]
    [ 1668.250481] Sense Key : Not Ready [current]
    [ 1668.250489] sd 32:0:1:0: [sdb]
    [ 1668.250494] Add. Sense: No additional sense information
    [ 1668.250500] sd 32:0:1:0: [sdb] CDB:
    [ 1668.250504] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.250978] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.250985] sd 32:0:1:0: [sdb]
    [ 1668.250988] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.250991] sd 32:0:1:0: [sdb]
    [ 1668.250994] Sense Key : Not Ready [current]
    [ 1668.250999] sd 32:0:1:0: [sdb]
    [ 1668.251001] Add. Sense: No additional sense information
    [ 1668.251005] sd 32:0:1:0: [sdb] CDB:
    [ 1668.251007] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1668.251407] sd 32:0:1:0: [sdb] Device not ready
    [ 1668.251416] sd 32:0:1:0: [sdb]
    [ 1668.251421] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1668.251427] sd 32:0:1:0: [sdb]
    [ 1668.251431] Sense Key : Not Ready [current]
    [ 1668.251439] sd 32:0:1:0: [sdb]
    [ 1668.251443] Add. Sense: No additional sense information
    [ 1668.251450] sd 32:0:1:0: [sdb] CDB:
    [ 1668.251453] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1685.310156] usb 1-1: USB disconnect, device number 2
    [ 1697.869555] usb 1-1: new high-speed USB device number 6 using ehci-pci
    [ 1698.145783] usb 1-1: New USB device found, idVendor=04f2, idProduct=b34f
    [ 1698.145795] usb 1-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
    [ 1698.145801] usb 1-1: Product: HP Truevision HD
    [ 1698.145806] usb 1-1: Manufacturer: Chicony Electronics Co.,Ltd.
    [ 1698.145810] usb 1-1: SerialNumber: 0x0001
    [ 1698.169204] uvcvideo: Found UVC 1.00 device HP Truevision HD (04f2:b34f)
    [ 1698.187694] input: HP Truevision HD as /devices/pci0000:00/0000:00:11.0/0000:02:03.0/usb1/1-1/1-1:1.0/input/input6
    [ 1717.028602] usb 1-1: USB disconnect, device number 6
    [ 1731.182021] sd 32:0:1:0: [sdb] Device not ready
    [ 1731.182037] sd 32:0:1:0: [sdb]
    [ 1731.182045] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1731.182052] sd 32:0:1:0: [sdb]
    [ 1731.182057] Sense Key : Not Ready [current]
    [ 1731.182068] sd 32:0:1:0: [sdb]
    [ 1731.182074] Add. Sense: No additional sense information
    [ 1731.182082] sd 32:0:1:0: [sdb] CDB:
    [ 1731.182087] Read(10): 28 00 00 00 00 00 00 00 20 00
    [ 1731.182110] blk_update_request: 148 callbacks suppressed
    [ 1731.182117] end_request: I/O error, dev sdb, sector 0
    [ 1731.182177] quiet_error: 147 callbacks suppressed
    [ 1731.182186] Buffer I/O error on device sdb, logical block 0
    [ 1731.182198] Buffer I/O error on device sdb, logical block 1
    [ 1731.182205] Buffer I/O error on device sdb, logical block 2
    [ 1731.182212] Buffer I/O error on device sdb, logical block 3
    [ 1731.182409] sd 32:0:1:0: [sdb] Device not ready
    [ 1731.182418] sd 32:0:1:0: [sdb]
    [ 1731.182423] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1731.182430] sd 32:0:1:0: [sdb]
    [ 1731.182434] Sense Key : Not Ready [current]
    [ 1731.182443] sd 32:0:1:0: [sdb]
    [ 1731.182448] Add. Sense: No additional sense information
    [ 1731.182455] sd 32:0:1:0: [sdb] CDB:
    [ 1731.182459] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1731.182480] end_request: I/O error, dev sdb, sector 0
    [ 1731.182488] Buffer I/O error on device sdb, logical block 0
    [ 1731.182816] sd 32:0:1:0: [sdb] Device not ready
    [ 1731.182824] sd 32:0:1:0: [sdb]
    [ 1731.182830] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1731.182836] sd 32:0:1:0: [sdb]
    [ 1731.182840] Sense Key : Not Ready [current]
    [ 1731.182849] sd 32:0:1:0: [sdb]
    [ 1731.182854] Add. Sense: No additional sense information
    [ 1731.182860] sd 32:0:1:0: [sdb] CDB:
    [ 1731.182864] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1731.182885] end_request: I/O error, dev sdb, sector 15130616
    [ 1731.182893] Buffer I/O error on device sdb, logical block 1891327
    [ 1731.183073] sd 32:0:1:0: [sdb] Device not ready
    [ 1731.183081] sd 32:0:1:0: [sdb]
    [ 1731.183086] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1731.183092] sd 32:0:1:0: [sdb]
    [ 1731.183096] Sense Key : Not Ready [current]
    [ 1731.183104] sd 32:0:1:0: [sdb]
    [ 1731.183109] Add. Sense: No additional sense information
    [ 1731.183115] sd 32:0:1:0: [sdb] CDB:
    [ 1731.183119] Read(10): 28 00 00 e6 df f8 00 00 08 00
    [ 1731.183189] end_request: I/O error, dev sdb, sector 15130616
    [ 1731.183198] Buffer I/O error on device sdb, logical block 1891327
    [ 1731.184206] sd 32:0:1:0: [sdb] Device not ready
    [ 1731.184216] sd 32:0:1:0: [sdb]
    [ 1731.184221] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1731.184227] sd 32:0:1:0: [sdb]
    [ 1731.184231] Sense Key : Not Ready [current]
    [ 1731.184240] sd 32:0:1:0: [sdb]
    [ 1731.184244] Add. Sense: No additional sense information
    [ 1731.184250] sd 32:0:1:0: [sdb] CDB:
    [ 1731.184254] Read(10): 28 00 00 00 00 00 00 00 20 00
    [ 1731.184274] end_request: I/O error, dev sdb, sector 0
    [ 1731.184282] Buffer I/O error on device sdb, logical block 0
    [ 1731.184291] Buffer I/O error on device sdb, logical block 1
    [ 1731.184298] Buffer I/O error on device sdb, logical block 2
    [ 1731.184482] sd 32:0:1:0: [sdb] Device not ready
    [ 1731.184490] sd 32:0:1:0: [sdb]
    [ 1731.184495] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
    [ 1731.184501] sd 32:0:1:0: [sdb]
    [ 1731.184505] Sense Key : Not Ready [current]
    [ 1731.184513] sd 32:0:1:0: [sdb]
    [ 1731.184518] Add. Sense: No additional sense information
    [ 1731.184524] sd 32:0:1:0: [sdb] CDB:
    [ 1731.184528] Read(10): 28 00 00 00 00 00 00 00 08 00
    [ 1731.184547] end_request: I/O error, dev sdb, sector 0
    [ 1752.535173] usb 1-2: USB disconnect, device number 5
    ]0;paolo@ubuntu: ~/Documentipaolo@ubuntu:~/Documenti$ sleep 20
    ]0;paolo@ubuntu: ~/Documentipaolo@ubuntu:~/Documenti$ dmesg
    [ 1772.760716] usb 1-1: new high-speed USB device number 7 using ehci-pci
    [ 1772.994416] usb 1-1: New USB device found, idVendor=0bda, idProduct=0158
    [ 1772.994432] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 1772.994441] usb 1-1: Product: USB2.0-CRW
    [ 1772.994516] usb 1-1: Manufacturer: Generic
    [ 1772.994524] usb 1-1: SerialNumber: 20060413092100000
    [ 1773.009842] ums-realtek 1-1:1.0: USB Mass Storage device detected
    [ 1773.023466] scsi36 : usb-storage 1-1:1.0
    [ 1774.037453] scsi 36:0:0:0: Direct-Access Generic- Multi-Card 1.00 PQ: 0 ANSI: 0 CCS
    [ 1774.042146] sd 36:0:0:0: Attached scsi generic sg4 type 0
    [ 1774.602668] sd 36:0:0:0: [sdc] 15130624 512-byte logical blocks: (7.74 GB/7.21 GiB)
    [ 1774.611273] sd 36:0:0:0: [sdc] Write Protect is off
    [ 1774.611284] sd 36:0:0:0: [sdc] Mode Sense: 03 00 00 00
    [ 1774.619285] sd 36:0:0:0: [sdc] No Caching mode page found
    [ 1774.619297] sd 36:0:0:0: [sdc] Assuming drive cache: write through
    [ 1774.654244] sd 36:0:0:0: [sdc] No Caching mode page found
    [ 1774.654258] sd 36:0:0:0: [sdc] Assuming drive cache: write through
    [ 1774.660959] sdc:
    [ 1774.695722] sd 36:0:0:0: [sdc] No Caching mode page found
    [ 1774.695735] sd 36:0:0:0: [sdc] Assuming drive cache: write through
    [ 1774.695743] sd 36:0:0:0: [sdc] Attached SCSI removable disk
    [ 1775.266627] FAT-fs (sdc): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    ]0;paolo@ubuntu: ~/Documentipaolo@ubuntu:~/Documenti$ exit
    exit
    Script effettuato su gio 07 mag 2015 00:19:51 PDT
  • I have a question
    but why even by manually copying the files it does not work?
    I formatted the 4 partitions with gparted.
  • Paolo,
    The first partition has to be formatted in a very specific way:
    - bootable
    - correct partition type (0xc)
    - correct FAT filesystem
    If you did not do all that on gparted, it will not boot.
  • Paolo,
    from the output you provided, I can tell that /dev/sdc is indeed your device. Also fdisk manages to read the device size properly but I can see in your last log that your PC is configured to be using the IT locale. Unfortunately the script looks for certain keywords in the fdisk output and those are expected to be the english version.
    The easy solution would be to override the language with this command:
    $ sudo LANG=C ./mkmmc-android.sh /dev/sdc
    Let us know if it works better.
  • Thank you very much for your support.
    I made your suggestions and worked.
    Thank you.
    below you back the results.
    Unfortunately Lcd 4dcape 43T did not work, I do not see anything on the screen.
    I tried to press the S2, then insert power 5V 2A, let S2 pressed for 10 seconds
    by the following tests:
    1 - leaving both entered the jumpers on LCD
    2- removing both of the jumpers on LCd
    paolo@ubuntu:~/Documenti/ubuntu_sh/beagleboneblack$ sudo LANG=C ./mkmmc-android.sh /dev/sdb
    Assuming Default Locations for Prebuilt Images
    All data on /dev/sdb now will be destroyed! Continue? [y/n]
    y
    [Unmounting all existing partitions on the device ]
    umount: /dev/sdb: not mounted
    [Partitioning /dev/sdb...]
    Disk /dev/sdb doesn't contain a valid partition table
    DISK SIZE - 7746879488 bytes
    CYLINDERS - 941
    [Making filesystems...]
    [Copying files...]
    [Copying START_HERE folder to boot partition]
    [Copying all clips to data partition]
    [Done]
    paolo@ubuntu:~/Documenti/ubuntu_sh/beagleboneblack$ sudo fdisk -l
    Disk /dev/sda: 21.5 GB, 21474836480 bytes
    255 testine, 63 settori/tracce, 2610 cilindri, totale 41943040 settori
    Unità = settori di 1 * 512 = 512 byte
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Identificativo disco: 0x000429cc
    Dispositivo Boot Start End Blocks Id System
    /dev/sda1 * 2048 39845887 19921920 83 Linux
    /dev/sda2 39847934 41940991 1046529 5 Esteso
    /dev/sda5 39847936 41940991 1046528 82 Linux swap / Solaris
    Disco /dev/sdb: 7746 MB, 7746879488 byte
    255 testine, 63 settori/tracce, 941 cilindri, totale 15130624 settori
    Identificativo disco: 0x00000000
    /dev/sdb1 * 63 144584 72261 c W95 FAT32 (LBA)
    /dev/sdb2 144585 3919859 1887637+ 83 Linux
    /dev/sdb3 3919860 7695134 1887637+ 83 Linux
    /dev/sdb4 7695135 15117164 3711015 c W95 FAT32 (LBA)
    paolo@ubuntu:~/Documenti/ubuntu_sh/beagleboneblack$ sudo mount /dev/sdb1 /mnt
    paolo@ubuntu:~/Documenti/ubuntu_sh/beagleboneblack$ ls /mnt
    MLO START_HERE System Volume Information u-boot.img uEnv.txt uImage
    paolo@ubuntu:~/Documenti/ubuntu_sh/beagleboneblack$ sudo mount /dev/sdb2 /mnt
    acct fstab.am335xevm lost+found ueventd.am335xevm.rc
    cache init mnt ueventd.goldfish.rc
    config init.am335xevm.rc proc ueventd.rc
    d init.am335xevm.usb.rc sbin usbdrive
    data init.goldfish.rc sdcard vendor
    default.prop init.rc storage
    dev init.trace.rc sys
    etc init.usb.rc system
    app app-private data local misc ssh
    app-asec backup dontpanic lost+found property system
    app-lib dalvik-cache drm media resource-cache user
    Audio Images LOST.DIR Video
    paolo@ubuntu:~/Documenti/ubuntu_sh/beagleboneblack$ df -hT
    File system Tipo Dim. Usati Dispon. Uso% Montato su
    /dev/sda1 ext4 19G 7,8G 9,9G 45% /
    none tmpfs 4,0K 0 4,0K 0% /sys/fs/cgroup
    udev devtmpfs 3,7G 4,0K 3,7G 1% /dev
    tmpfs tmpfs 744M 1,6M 743M 1% /run
    none tmpfs 5,0M 0 5,0M 0% /run/lock
    none tmpfs 3,7G 152K 3,7G 1% /run/shm
    none tmpfs 100M 44K 100M 1% /run/user
    /dev/sdb1 vfat 70M 6,7M 63M 10% /mnt
    /dev/sdb2 ext4 1,8G 186M 1,5G 12% /mnt
    paolo@ubuntu:~/Documenti/ubuntu_sh/beagleboneblack$ sudo mount /dev/sdb3 /mnt
    /dev/sdb3 ext4 1,8G 31M 1,7G 2% /mnt
    paolo@ubuntu:~/Documenti/ubuntu_sh/beagleboneblack$ sudo mount /dev/sdb4 /mnt
    /dev/sdb4 vfat 3,6G 124M 3,5G 4% /mnt
  • Hi Paolo,
    Good to hear that your issue is resolved. We request you to open a new thread with your other question.
  • Thanks again for your precious help.
    I proceed with the opening of a new thread.
