Other Parts Discussed in Thread: SPRC133
Hi
I am new and wish to create a new project for my eZdsp USB kit using code composer 6.0
I want to use all the csl functions how should I setup a project from scratch.
Thank you.
Hi
Thank you.
If you need to create a new project using CSL approach, then suggest you to go through Chip Support Library API Reference Guide.
This is available in the following link http://www.ti.com/tool/sprc133
Also there are several CSL example in CSL 3.04 package for your ready reference. This again is available in the same link( as mentioned above) you need to download and install the package. Installation guide in the CSL package should further help you on this .
From CCS point of view you could refer the following wiki page “Projects and Build Handbook for CCS” - processors.wiki.ti.com/.../Projects_and_Build_Handbook_for_CCS.
Hope the above information helps.
Vasanth
Attached document has the instructions to install the DSP/BIOS.
Hope this helps.
Vasanth
