Dear all,
I try to configure two EDMA controllers fro the C6657 platform . The one should handle the interrupts from MCBSP and the other should make QDMA transfers. But when the interrupt is called , either from the EDMA 0 or EDMA 1, the instance of the one edma is always used. It depends on the value of the ccXferCompInt[0][0].
Something should be wrong in the way that I have registered the interrupts in each of these EDMA instances.
Please find below the piece of the code that do the interrupts registration
unsigned int ccXferHostInt[2][2] = {
{0u, 20u},
{2u, 22u}
//CIC0_OUT(1+20*n)
//CIC0_OUT(3+20*n)
unsigned int edma3ErrHostInt[2][2] = {
{1u, 21u},
{3u, 23u}
unsigned int ccXferCompInt[NUM_EDMA3_INSTANCES][EDMA3_MAX_REGIONS] = {
24u, 25u, 26u, 27u,
28u, 29u, 30u, 31u,
24u, 25u, 26u, 27u,
28u, 29u, 30u, 31u,
* Variable which will be used internally for referring channel controller's
* error interrupt.
unsigned int ccErrorInt[NUM_EDMA3_INSTANCES] = {16u, 16u};
* Variable which will be used internally for referring transfer controllers'
* error interrupts.
unsigned int tcErrorInt[NUM_EDMA3_INSTANCES][EDMA3_MAX_TC] = {
18u, 19u, 20u, 21u,
0u, 0u, 0u, 0u,
18u, 19u, 20u, 21u,
0u, 0u, 0u, 0u
EDMA3_DRV_GblConfigParams sampleEdma3GblCfgParams[NUM_EDMA3_INSTANCES] =
/* EDMA3 INSTANCE# 0 */
/** Total number of DMA Channels supported by the EDMA3 Controller */
64u,
/** Total number of QDMA Channels supported by the EDMA3 Controller */
8u,
/** Total number of TCCs supported by the EDMA3 Controller */
64u,
/** Total number of PaRAM Sets supported by the EDMA3 Controller */
512u,
/** Total number of Event Queues in the EDMA3 Controller */
4u,
/** Total number of Transfer Controllers (TCs) in the EDMA3 Controller */
4u,
/** Number of Regions on this EDMA3 controller */
8u,
* \brief Channel mapping existence
* A value of 0 (No channel mapping) implies that there is fixed association
* for a channel number to a parameter entry number or, in other words,
* PaRAM entry n corresponds to channel n.
1u,
/** Existence of memory protection feature */
1u,
/** Global Register Region of CC Registers */
(void *)0x02740000u,
/** Transfer Controller (TC) Registers */
(void *)0x02790000u,
(void *)0x02798000u,
(void *)0x027A0000u,
(void *)0x027A8000u,
(void *)NULL,
(void *)NULL,
(void *)NULL,
(void *)NULL
/** Interrupt no. for Transfer Completion */
24u,
/** Interrupt no. for CC Error */
16u,
/** Interrupt no. for TCs Error */
18u,
19u,
20u,
21u,
0u,
0u,
0u,
0u,
* \brief EDMA3 TC priority setting
* User can program the priority of the Event Queues
* at a system-wide level. This means that the user can set the
* priority of an IO initiated by either of the TCs (Transfer Controllers)
* relative to IO initiated by the other bus masters on the
* device (ARM, DSP, USB, etc)
0u,
1u,
2u,
3u,
0u,
0u,
0u,
0u
* \brief To Configure the Threshold level of number of events
* that can be queued up in the Event queues. EDMA3CC error register
* (CCERR) will indicate whether or not at any instant of time the
* number of events queued up in any of the event queues exceeds
* or equals the threshold/watermark value that is set
* in the queue watermark threshold register (QWMTHRA).
16u,
16u,
16u,
16u,
0u,
0u,
0u,
0u
* \brief To Configure the Default Burst Size (DBS) of TCs.
* An optimally-sized command is defined by the transfer controller
* default burst size (DBS). Different TCs can have different
* DBS values. It is defined in Bytes.
64u,
64u,
64u,
64u,
0u,
0u,
0u,
0u
* \brief Mapping from each DMA channel to a Parameter RAM set,
* if it exists, otherwise of no use.
0u, 1u, 2u, 3u, 4u, 5u, 6u, 7u,
8u, 9u, 10u, 11u, 12u, 13u, 14u, 15u,
16u, 17u, 18u, 19u, 20u, 21u, 22u, 23u,
24u, 25u, 26u, 27u, 28u, 29u, 30u, 31u,
32u, 33u, 34u, 35u, 36u, 37u, 38u, 39u,
40u, 41u, 42u, 43u, 44u, 45u, 46u, 47u,
48u, 49u, 50u, 51u, 52u, 53u, 54u, 55u,
56u, 57u, 58u, 59u, 60u, 61u, 62u, 63u
* \brief Mapping from each DMA channel to a TCC. This specific
* TCC code will be returned when the transfer is completed
* on the mapped channel.
EDMA3_RM_CH_NO_TCC_MAP, EDMA3_RM_CH_NO_TCC_MAP, EDMA3_RM_CH_NO_TCC_MAP, EDMA3_RM_CH_NO_TCC_MAP,
* \brief Mapping of DMA channels to Hardware Events from
* various peripherals, which use EDMA for data transfer.
* All channels need not be mapped, some can be free also.
0xFFFFFFFFu,
0xFFFFFFFFu
64u,
8u,
64u,
512u,
4u,
4u,
8u,
1u,
1u,
(void *)NULL,
(void *)NULL,
(void *)NULL,
(void *)NULL
25u,
16u,
18u,
19u,
20u,
21u,
0u,
0u,
0u,
0u,
0u,
1u,
2u,
3u,
0u,
0u,
0u,
0u
16u,
16u,
16u,
16u,
0u,
0u,
0u,
0u
64u,
64u,
64u,
64u,
0u,
0u,
0u,
0u
0xFFFFFFFFu,
0xFFFFFFFFu
Could you please help to find a solution?
