Other Parts Discussed in Thread: OMAP-L138, OMAPL138
Dave
How are you calculating 100 uW ?
FYI, I think the crystal on the LogicPD OMAPL138 SOM for the 24 MHz is the following
http://www.citizencrystal.com/images/pdf/m-cs10.pdf
This specifies a DL value of 50 uW, and this is working fine without any known issues.
Also
1) In general the best way to confirm a crystal would be to actually test this out on the board (swapping out the crystal etc).
2) Most crystal application notes mention measuring the Irms value across the crystal to ensure that its power dissipation does not exceed the maximum specified Drive Level value
What crystal are you considering for your design and what is the drive level specified in the crystal datasheet?
Mukul
