TI-RTOS on DM8148 EVM Board
I am looking for Steps for running TI-RTOS and sample codes of TI-RTOS on TI's DM8148 EVM..  Please guide me to proper link for the same..
Another topic of discussion is feasibility of running Google test framework on TI-RTOS ? How TI-RTOS is providing APIs for I/O operations ?If you can guide me for getting started with TI-RTOS that would be great help..
Thanks in Advance..
  • Currently the drivers in TI-RTOS have not been ported to the DM8148. However, you can use SYS/BIOS (the RTOS kernel that comes with TI-RTOS) natively on the DM8148. Assuming you are using CCS,  download and install the latest SYS/BIOS and XDC tools products here:
       software-dl.ti.com/.../sysbios
    Launch CCS and then restart it after it finds these new products.
    Create a new CCS project and select the options shown below:
    Then click on 'Next'
    Then select the ti.platforms.evmDM8148 platform as shown in the image below (your SYS/BIOS and XDC Tools versions will be those you downloaded above):
    Then press 'Finish'.
    You now have a basic SYS/BIOS project that should run on your evmDM8148 board.
    This should get you started.
    I hope this helps.
    Alan
  • Thanks Alan for your detailed response..
    It indeed solves my doubts ..
    Another quick question .. So as you mentioned after selecting TI RTOS options while creating CCS Project , How To run this RTOS Project on DM8148? ( Using Load option only or any other method ? )..
  • I assume you've already created a "Target Configuration" for your EVM DM8148 board.
    If so, launch the target configuration, connect to the ARM core, "Load" and run the application.
    Alan
