hello, everyone.
Now i'm working with dm365 EVM(revD) with dvsdk2_10, MV kernel 2.6.18.
I want to upgrade newly released mpeg4 codec dm365_mpeg4enc2.10.00.00 in my dvsdk2.10.
just i exchanged the folder dm365_codecs_01_00_06/packages/ti/sdo/codecs/mpeg4enc in dvsdk.
During the compile, error doesn't show up. but when i excute the encode demo.. fail to creade video encoder.
The input soruce is 720p.
root@jay:/opt/mpeg4## ./encode_2t -y 3 -v test.mpeg4
Encode demo started.
i2c_adapter i2c-0: TVP2002 - clocks per line detected = 137
davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:108
davinci_previewer davinci_previewer.2: ipipe_set_preview_config
vpfe ccdc capture vpfe ccdc capture.1: IMP chained
vpfe ccdc capture vpfe ccdc capture.1: Resizer present
Error: Failed to create video encoder: mpeg4enc
vpfe ccdc capture vpfe ccdc capture.1: hpitch = 1280, vpitch = 720, bpp = 1
Starting ccdc_config_ycbcr...<7>
starting ccdc_reset...<7>
End of ccdc_reset...<7>
Starting ccdc_setwin...<7>ipipe_set_resizer, resizer - A enabled
DavinciDisplay DavinciDisplay.1: Before finishing with S_FMT:
layer.pix_fmt.bytesperline = 1280,
layer.pix_fmt.width = 1280,
layer.pix_fmt.height = 720,
layer.pix_fmt.sizeimage =1382400
DavinciDisplay DavinciDisplay.1: pixfmt->width = 1280,
layer->layer_info.config.line_length= 1280
original encode file works fine with this environment.
I attached CEdebug log. but i can'n get a point to fix.
@0,564,603us: [+4 T:0x4001f970] OG - Global_init> This program was built with the following packages:
@0,565,194us: [+4 T:0x4001f970] OG - package gnu.targets.rts470MV (/opt/dvsdk_2_10/xdctools_3_15_01_59/packages/gnu/targets/rts470MV/) [1, 0, 0, 0]
@0,565,397us: [+4 T:0x4001f970] OG - package ti.sdo.linuxutils.vicp (/opt/dvsdk_2_10/dvsdk_2_10_01_18/linuxutils_2_24_02/packages/ti/sdo/linuxutils/vicp/) [1, 0, 0]
@0,565,506us: [+4 T:0x4001f970] OG - package ti.sdo.linuxutils.edma (/opt/dvsdk_2_10/dvsdk_2_10_01_18/linuxutils_2_24_02/packages/ti/sdo/linuxutils/edma/) [1, 0, 0]
@0,565,602us: [+4 T:0x4001f970] OG - package ti.sdo.linuxutils.cmem (/opt/dvsdk_2_10/dvsdk_2_10_01_18/linuxutils_2_24_02/packages/ti/sdo/linuxutils/cmem/) [2, 2, 0]
@0,565,693us: [+4 T:0x4001f970] OG - package ti.xdais.dm.examples.g711 (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/examples/ti/xdais/dm/examples/g711/) [1, 0, 0]
@0,565,783us: [+4 T:0x4001f970] OG - package ti.sdo.fc.ires (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/ires/) [1, 0, 0]
@0,565,873us: [+4 T:0x4001f970] OG - package ti.sdo.fc.global (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/global/) [1, 0, 0]
@0,565,961us: [+4 T:0x4001f970] OG - package ti.sdo.fc.memutils (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/memutils/) [1, 0, 0]
@0,566,113us: [+4 T:0x4001f970] OG - package ti.xdais (/opt/dvsdk_2_10/dvsdk_2_10_01_18/xdais_6_24/packages/ti/xdais/) [1, 2.0, 1]
@0,566,209us: [+4 T:0x4001f970] OG - package ti.sdo.fc.ires.addrspace (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/ires/addrspace/) [1, 0, 0]
@0,566,303us: [+4 T:0x4001f970] OG - package ti.sdo.utils.trace (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/utils/trace/) [1, 0, 0]
@0,566,391us: [+4 T:0x4001f970] OG - package ti.sdo.fc.utils (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/utils/) [1, 0, 2]
@0,566,480us: [+4 T:0x4001f970] OG - package ti.sdo.fc.ires.hdvicp (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/ires/hdvicp/) [1, 0, 1]
@0,566,569us: [+4 T:0x4001f970] OG - package ti.sdo.fc.ires.vicp (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/ires/vicp/) [1, 0, 1]
@0,566,659us: [+4 T:0x4001f970] OG - package ti.sdo.fc.vicpsync (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/vicpsync/) [1, 0, 0]
@0,566,746us: [+4 T:0x4001f970] OG - package ti.sdo.fc.hdvicpsync (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/hdvicpsync/) [1, 0, 0]
@0,566,834us: [+4 T:0x4001f970] OG - package ti.sdo.codecs.mpeg4enc (/opt/dvsdk_2_10/dvsdk_2_10_01_18/dm365_codecs_01_00_06/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0]
@0,566,920us: [+4 T:0x4001f970] OG - package ti.sdo.codecs.h264enc (/opt/dvsdk_2_10/dvsdk_2_10_01_18/dm365_codecs_01_00_06/packages/ti/sdo/codecs/h264enc/) [1, 0, 0]
@0,567,010us: [+4 T:0x4001f970] OG - package ti.sdo.fc.ires.nullresource (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/ires/nullresource/) [1, 0, 0]
@0,567,195us: [+4 T:0x4001f970] OG - package ti.sdo.fc.rman (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/rman/) [2, 0, 0]
@0,567,296us: [+4 T:0x4001f970] OG - package ti.sdo.fc.edma3 (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/edma3/) [3, 0, 0]
@0,567,387us: [+4 T:0x4001f970] OG - package ti.sdo.fc.ires.edma3chan (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/ires/edma3chan/) [1, 0, 0]
@0,567,477us: [+4 T:0x4001f970] OG - package ti.sdo.ce.global (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/global/) [1, 0, 0]
@0,567,565us: [+4 T:0x4001f970] OG - package ti.xdais.dm (/opt/dvsdk_2_10/dvsdk_2_10_01_18/xdais_6_24/packages/ti/xdais/dm/) [1, 0, 5]
@0,567,673us: [+4 T:0x4001f970] OG - package ti.sdo.ce.utils.xdm (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]
@0,567,777us: [+4 T:0x4001f970] OG - package ti.sdo.ce.node (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/node/) [1, 0, 0]
@0,567,872us: [+4 T:0x4001f970] OG - package ti.sdo.fc.dman3 (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/dman3/) [1, 0, 4]
@0,567,962us: [+4 T:0x4001f970] OG - package ti.sdo.fc.acpy3 (/opt/dvsdk_2_10/dvsdk_2_10_01_18/framework_components_2_24/packages/ti/sdo/fc/acpy3/) [1, 0, 4]
@0,568,054us: [+4 T:0x4001f970] OG - package gnu.targets (/opt/dvsdk_2_10/xdctools_3_15_01_59/packages/gnu/targets/) [1, 0, 1]
@0,568,146us: [+4 T:0x4001f970] OG - package ti.catalog.arm (/opt/dvsdk_2_10/xdctools_3_15_01_59/packages/ti/catalog/arm/) [1, 0, 1, 0]
@0,568,233us: [+4 T:0x4001f970] OG - package ti.catalog (/opt/dvsdk_2_10/xdctools_3_15_01_59/packages/ti/catalog/) [1, 0, 0]
@0,568,317us: [+4 T:0x4001f970] OG - package ti.platforms.evmDM365 (/opt/dvsdk_2_10/xdctools_3_15_01_59/packages/ti/platforms/evmDM365/) [1, 0, 0]
@0,568,403us: [+4 T:0x4001f970] OG - package ti.sdo.ce.osal (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/osal/) [2, 0, 2]
@0,568,493us: [+4 T:0x4001f970] OG - package ti.sdo.ce.osal.linux (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/osal/linux/) [2, 0, 1]
@0,568,581us: [+4 T:0x4001f970] OG - package ti.sdo.ce.ipc (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/ipc/) [2, 0, 1]
@0,568,667us: [+4 T:0x4001f970] OG - package ti.sdo.ce.ipc.linux (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/ipc/linux/) [2, 0, 1]
@0,568,755us: [+4 T:0x4001f970] OG - package ti.sdo.ce.alg (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/alg/) [1, 0, 1]
@0,568,844us: [+4 T:0x4001f970] OG - package ti.sdo.ce (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/) [1, 0, 6]
@0,568,933us: [+4 T:0x4001f970] OG - package ti.sdo.ce.speech (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/speech/) [1, 0, 2]
@0,569,023us: [+4 T:0x4001f970] OG - package ti.sdo.ce.speech1 (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/speech1/) [1, 0, 1]
@0,569,112us: [+4 T:0x4001f970] OG - package ti.sdo.ce.audio (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/audio/) [1, 0, 2]
@0,569,274us: [+4 T:0x4001f970] OG - package ti.sdo.ce.audio1 (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/audio1/) [1, 0, 1]
@0,569,551us: [+4 T:0x4001f970] OG - package ti.sdo.ce.video (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/video/) [1, 0, 3]
@0,569,671us: [+4 T:0x4001f970] OG - package ti.sdo.ce.video1 (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/video1/) [1, 0, 2]
@0,569,769us: [+4 T:0x4001f970] OG - package ti.sdo.ce.video2 (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/video2/) [1, 0, 2]
@0,569,860us: [+4 T:0x4001f970] OG - package ti.sdo.ce.image (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/image/) [1, 0, 3]
@0,569,949us: [+4 T:0x4001f970] OG - package ti.sdo.ce.image1 (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/packages/ti/sdo/ce/image1/) [1, 0, 1]
@0,570,042us: [+4 T:0x4001f970] OG - package ti.sdo.dmai (/opt/dvsdk_2_10/dvsdk_2_10_01_18/dmai_1_21_00_10/packages/ti/sdo/dmai/) [1, 0, 0]
@0,570,133us: [+4 T:0x4001f970] OG - package ti.sdo.simplewidget (/opt/dvsdk_2_10/dvsdk_2_10_01_18/dvsdk_demos_2_10_00_17/packages/ti/sdo/simplewidget/) []
@0,570,220us: [+4 T:0x4001f970] OG - package ti.sdo.codecs.mpeg4enc.ce (/opt/dvsdk_2_10/dvsdk_2_10_01_18/dm365_codecs_01_00_06/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0]
@0,570,322us: [+4 T:0x4001f970] OG - package ti.sdo.codecs.h264enc.ce (/opt/dvsdk_2_10/dvsdk_2_10_01_18/dm365_codecs_01_00_06/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0]
@0,570,420us: [+4 T:0x4001f970] OG - package ti.sdo.ce.examples.codecs.g711 (/opt/dvsdk_2_10/dvsdk_2_10_01_18/codec_engine_2_24/examples/ti/sdo/ce/examples/codecs/g711/) [1, 0, 0]
@0,570,515us: [+4 T:0x4001f970] OG - package encode_config (/opt/dvsdk_2_10/dvsdk_2_10_01_18/dvsdk_demos_2_10_00_17/dm365/encode/encode_config/) []
@0,571,524us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - LockMP_create> key: 0x524d414e count: 848176 attrs: 0xcfd18
@0,572,106us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_create> lock[0xd1200]
@0,572,271us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1200]
@0,572,569us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1200]
@0,572,714us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1200]
@0,572,838us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1200]
@0,573,077us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1200]
@0,573,225us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1200]
@0,573,343us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - LockMP_create> key: 0x4956444a count: 7136 attrs: 0xcf130
@0,573,565us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_create> lock[0xd1228]
@0,573,692us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1228]
@0,573,813us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1228]
@0,574,394us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1228]
@0,574,594us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1228]
@0,574,934us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1200]
@0,575,115us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1200]
@0,575,307us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1200]
@0,575,455us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1200]
@0,575,635us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - LockMP_create> key: 0x50434958 count: 848176 attrs: 0xd0f04
@0,575,878us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_create> lock[0xd1250]
@0,576,008us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1250]
@0,576,136us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1250]
@0,576,551us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1250]
@0,576,747us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1250]
@0,576,893us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1250]
@0,577,031us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1250]
@0,577,474us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1250]
@0,577,673us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1250]
@0,577,882us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1200]
@0,578,027us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1200]
@0,578,149us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1200]
@0,578,276us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1200]
@0,578,401us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1200]
@0,578,523us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1200]
@0,578,701us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1200]
@0,578,849us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1200]
@0,578,989us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1200]
@0,579,117us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1200]
@0,579,268us: [+0 T:0x4001f970] ti.sdo.ce.alg - ALG_init> Enter
@0,579,752us: [+0 T:0x4001f970] ti.sdo.ce.alg - ALG_init> Exit
@0,580,060us: [+6 T:0x4001f970] CE - Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@0,580,311us: [+0 T:0x4001f970] CS - Server_init()
@0,580,424us: [+0 T:0x4001f970] CS - Server_init> Global_useLinkArbiter = 0
@1,000,589us: [+2 T:0x4001f970] ti.sdo.dmai - [BufTab] Allocating BufTab for 1 buffers
@1,001,228us: [+2 T:0x4001f970] ti.sdo.dmai - [Buffer] Set user pointer 0x403ca000 (physical 0x84000000)
@1,002,481us: [+2 T:0x4001f970] ti.sdo.dmai - [Display] Display buffer 0 mapped to 0x403ca000 has physical address 0x84000000
@1,156,980us: [+2 T:0x40bf6490] ti.sdo.dmai - [Capture] COMPONENT input selected
@1,495,399us: [+2 T:0x40bf6490] ti.sdo.dmai - [Capture] Capture input set to COMPONENT
@1,495,687us: [+2 T:0x40bf6490] ti.sdo.dmai - [BufTab] Allocating BufTab for 9 buffers
@1,496,119us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_alloc(1382400) = 0x40bf7000.
@1,496,313us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_getPhys(0x40bf7000) = 0x8648c000.
@1,496,469us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x40bf7000 (0x8648c000 phys)
@1,496,869us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_alloc(1382400) = 0x40d71000.
@1,497,060us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_getPhys(0x40d71000) = 0x86312000.
@1,497,226us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x40d71000 (0x86312000 phys)
@1,497,628us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_alloc(1382400) = 0x40eeb000.
@1,497,824us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_getPhys(0x40eeb000) = 0x86198000.
@1,497,981us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x40eeb000 (0x86198000 phys)
@1,498,350us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_alloc(1382400) = 0x41065000.
@1,498,542us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_getPhys(0x41065000) = 0x8601e000.
@1,498,698us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x41065000 (0x8601e000 phys)
@1,499,100us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_alloc(1382400) = 0x411df000.
@1,499,292us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_getPhys(0x411df000) = 0x85ea4000.
@1,499,609us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x411df000 (0x85ea4000 phys)
@1,500,033us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_alloc(1382400) = 0x41359000.
@1,500,281us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_getPhys(0x41359000) = 0x85d2a000.
@1,500,447us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x41359000 (0x85d2a000 phys)
@1,500,854us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_alloc(1382400) = 0x414d3000.
@1,501,047us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_getPhys(0x414d3000) = 0x85bb0000.
@1,501,210us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x414d3000 (0x85bb0000 phys)
@1,501,585us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_alloc(1382400) = 0x4164d000.
@1,501,776us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_getPhys(0x4164d000) = 0x85a36000.
@1,501,932us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x4164d000 (0x85a36000 phys)
@1,502,342us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_alloc(1382400) = 0x417c7000.
@1,502,540us: [+4 T:0x40bf6490] OM - Memory_contigAlloc> CMEM_getPhys(0x417c7000) = 0x858bc000.
@1,502,699us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1382400 at 0x417c7000 (0x858bc000 phys)
@1,503,294us: [+2 T:0x40bf6490] ti.sdo.dmai - [Resize] Successfully set mode to continuous in resizer
@1,508,681us: [+2 T:0x40bf6490] ti.sdo.dmai - [Resize] Resizer initialized
@1,509,004us: [+2 T:0x40bf6490] ti.sdo.dmai - [Resize] Operating mode changed successfully to continuous in previewer@1,520,853us: [+2 T:0x40bf6490] ti.sdo.dmai - [Resize] Previewer initialized
@1,532,288us: [+0 T:0x42140490] CE - Engine_open> Enter('encode', 0x0, 0x4213fd24)
@1,532,514us: [+0 T:0x42140490] CE - Engine_open> return(1085808)
@1,532,659us: [+2 T:0x42140490] ti.sdo.dmai - [Venc1] Creating encoder mpeg4enc for max 1280x720 bitrate 0 ratectrl 4
@1,532,826us: [+0 T:0x42140490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> Enter (engine=0x109170, name='mpeg4enc', params=0x4213fdc8)
@1,532,975us: [+0 T:0x42140490] CV - VISA_create(0x109170, 'mpeg4enc', 0x4213fdc8, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
@1,533,101us: [+0 T:0x42140490] CV - VISA_create2(0x109170, 'mpeg4enc', 0x4213fdc8, 0x30, 0x2496, 'ti.sdo.ce.video1.IVIDENC1')
@1,533,318us: [+0 T:0x42140490] ti.sdo.ce.alg.Algorithm - Algorithm_create> Enter(fxns=0xd0354, idma3Fxns=0x0, iresFxns=0xd032c, params=0x4213fdc8, attrs=0x4213fbd4)
@1,533,513us: [+0 T:0x42140490] ti.sdo.ce.alg - ALG_create> Enter (scratchId=1, fxns=0xd0354, parentAlg=0x0, params=0x4213fdc8)
@1,533,705us: [+2 T:0x42140490] ti.sdo.ce.alg - ALG_create> algNumAlloc 7 memory recs
@1,533,881us: [+2 T:0x42140490] ti.sdo.ce.alg - ALG_create> algAlloc returned numRecs=7
@1,533,994us: [+4 T:0x42140490] ti.sdo.ce.alg - ALG_create> Memory requested memTab[0]: size=0x36b0, align=0x100, space=0x11, attrs=0x1
@1,534,106us: [+4 T:0x42140490] ti.sdo.ce.alg - ALG_create> Memory requested memTab[1]: size=0x200, align=0x100, space=0x11, attrs=0x1
@1,534,210us: [+4 T:0x42140490] ti.sdo.ce.alg - ALG_create> Memory requested memTab[2]: size=0x309c00, align=0x100, space=0x11, attrs=0x1
@1,534,316us: [+4 T:0x42140490] ti.sdo.ce.alg - ALG_create> Memory requested memTab[3]: size=0x1e00, align=0x100, space=0x11, attrs=0x1
@1,534,420us: [+4 T:0x42140490] ti.sdo.ce.alg - ALG_create> Memory requested memTab[4]: size=0x4, align=0x100, space=0x11, attrs=0x1
@1,534,524us: [+4 T:0x42140490] ti.sdo.ce.alg - ALG_create> Memory requested memTab[5]: size=0x14000, align=0x100, space=0x11, attrs=0x1
@1,534,628us: [+4 T:0x42140490] ti.sdo.ce.alg - ALG_create> Memory requested memTab[6]: size=0x7080, align=0x100, space=0x11, attrs=0x1
@1,534,919us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_alloc(14000) = 0x42141000.
@1,535,086us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_getPhys(0x42141000) = 0x87fef000.
@1,535,510us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_alloc(512) = 0x42145000.
@1,535,690us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_getPhys(0x42145000) = 0x87ffe000.
@1,536,212us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_alloc(3185664) = 0x42146000.
@1,536,408us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_getPhys(0x42146000) = 0x87a04000.
@1,561,976us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_alloc(7680) = 0x42450000.
@1,562,189us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_getPhys(0x42450000) = 0x87ff8000.
@1,562,570us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_alloc(4) = 0x42452000.
@1,562,745us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_getPhys(0x42452000) = 0x87fff000.
@1,563,058us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_alloc(81920) = 0x42453000.
@1,563,253us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_getPhys(0x42453000) = 0x87d22000.
@1,564,226us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_alloc(28800) = 0x42467000.
@1,564,420us: [+4 T:0x42140490] OM - Memory_contigAlloc> CMEM_getPhys(0x42467000) = 0x87d4a000.
@1,567,069us: [+7 T:0x42140490] ti.sdo.ce.alg - ALG_create> algInit call failed -16394
@1,576,943us: [+0 T:0x42140490] ti.sdo.ce.alg - ALG_create> Exit (algHandle=NULL)
@1,577,115us: [+7 T:0x42140490] ti.sdo.ce.alg.Algorithm - Algorithm_create> Algorithm creation FAILED; make sure that 1) alg params are correct/appropriate, 2) there is enough internal and external algorithm memory available -- check DSKT2 settings for heap assignments and scratch allocation
@1,577,244us: [+0 T:0x42140490] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Enter(alg=0x109348)
@1,577,369us: [+0 T:0x42140490] ti.sdo.ce.alg.Algorithm - Algorithm_delete> Exit
@1,577,469us: [+0 T:0x42140490] ti.sdo.ce.alg.Algorithm - Algorithm_create> return (0x0)
@1,577,571us: [+2 T:0x42140490] CV - VISA_create2> FAILED to create local codec.
@1,577,664us: [+0 T:0x42140490] CV - VISA_delete(0x109310)
@1,577,757us: [+5 T:0x42140490] CV - VISA_delete> deleting codec (localQueue=0xffff, remoteQueue=0xffff)
@1,577,870us: [+0 T:0x42140490] ti.sdo.ce.video1.VIDENC1 - VIDENC1_create> return (0x0)
@1,577,981us: [+7 T:0x42140490] ti.sdo.dmai - [Venc1] Failed to open video encode algorithm: mpeg4enc (0x0)
@1,844,937us: [+2 T:0x40bf6490] ti.sdo.dmai - [Capture] COMPONENT input selected
@2,774,201us: [+0 T:0x4001f970] CE - Engine_open> Enter('encode', 0x0, 0xbe889a8c)
@2,774,426us: [+0 T:0x4001f970] CE - Engine_open> return(1348336)
@2,777,995us: [+2 T:0x42940490] ti.sdo.dmai - [BufTab] Allocating BufTab for 9 buffers
@2,778,358us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_alloc(0) = 0x42941000.
@2,778,787us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_getPhys(0x42941000) = 0x87fff000.
@2,778,981us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x42941000 (0x87fff000 phys)
@2,779,305us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_alloc(0) = 0x42942000.
@2,779,610us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_getPhys(0x42942000) = 0x87ffe000.
@2,779,805us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x42942000 (0x87ffe000 phys)
@2,780,320us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_alloc(0) = 0x42943000.
@2,780,515us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_getPhys(0x42943000) = 0x87ffd000.
@2,780,739us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x42943000 (0x87ffd000 phys)
@2,781,043us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_alloc(0) = 0x42944000.
@2,781,221us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_getPhys(0x42944000) = 0x87ffc000.
@2,781,408us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x42944000 (0x87ffc000 phys)
@2,781,916us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_alloc(0) = 0x42945000.
@2,782,102us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_getPhys(0x42945000) = 0x87ffb000.
@2,782,314us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x42945000 (0x87ffb000 phys)
@2,782,620us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_alloc(0) = 0x42946000.
@2,782,799us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_getPhys(0x42946000) = 0x87ffa000.
@2,782,983us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x42946000 (0x87ffa000 phys)
@2,783,487us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_alloc(0) = 0x42947000.
@2,783,678us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_getPhys(0x42947000) = 0x87d57000.
@2,783,874us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x42947000 (0x87d57000 phys)
@2,784,213us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_alloc(0) = 0x42948000.
@2,784,395us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_getPhys(0x42948000) = 0x87d56000.
@2,784,593us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x42948000 (0x87d56000 phys)
@2,785,136us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_alloc(0) = 0x42949000.
@2,785,329us: [+4 T:0x42940490] OM - Memory_contigAlloc> CMEM_getPhys(0x42949000) = 0x87d55000.
@2,785,551us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x42949000 (0x87d55000 phys)
@2,791,847us: [+2 T:0x40bf6490] ti.sdo.dmai - [Capture] Capture input set to COMPONENT
@2,792,037us: [+2 T:0x40bf6490] ti.sdo.dmai - [Capture] Capture dimention is set to 720x1280
@2,807,324us: [+2 T:0x40bf6490] ti.sdo.dmai - [Capture] Video input connected size 1280x720 pitch 1280
@2,807,537us: [+2 T:0x40bf6490] ti.sdo.dmai - [Capture] Setting capture frame rate to half.
@3,070,734us: [+2 T:0x40bf6490] ti.sdo.dmai - [Display] Video output set to size 1280x720 pitch 2560
@3,132,929us: [+0 T:0x42140490] CE - Engine_close(0x109170)
@3,134,124us: [+0 T:0x4001f970] CE - Engine_close(0x1492f0)
@3,136,283us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x42941000 (0x87fff000 phys)
@3,136,659us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x42942000 (0x87ffe000 phys)
@3,136,957us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x42943000 (0x87ffd000 phys)
@3,137,238us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x42944000 (0x87ffc000 phys)
@3,137,511us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x42945000 (0x87ffb000 phys)
@3,137,791us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x42946000 (0x87ffa000 phys)
@3,138,060us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x42947000 (0x87d57000 phys)
@3,138,348us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x42948000 (0x87d56000 phys)
@3,138,621us: [+2 T:0x42940490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x42949000 (0x87d55000 phys)
@3,957,772us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 1382400 at 0x40bf7000 (0x8648c000 phys)
@3,960,822us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 1382400 at 0x40d71000 (0x86312000 phys)
@3,963,572us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 1382400 at 0x40eeb000 (0x86198000 phys)
@3,966,278us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 1382400 at 0x41065000 (0x8601e000 phys)
@3,968,961us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 1382400 at 0x411df000 (0x85ea4000 phys)
@3,971,768us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 1382400 at 0x41359000 (0x85d2a000 phys)
@3,974,455us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 1382400 at 0x414d3000 (0x85bb0000 phys)
@3,977,131us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 1382400 at 0x4164d000 (0x85a36000 phys)
@3,979,988us: [+2 T:0x40bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 1382400 at 0x417c7000 (0x858bc000 phys)
@4,167,732us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1200]
@4,167,984us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1200]
@4,168,117us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1228]
@4,168,250us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1228]
@4,168,746us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1228]
@4,168,943us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1228]
@4,169,069us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_delete> lock[0xd1228]
@4,169,262us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_delete>
@4,169,595us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1250]
@4,169,770us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1250]
@4,170,117us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1250]
@4,170,296us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1250]
@4,170,418us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_acquire> lock[0xd1250]
@4,170,545us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_acquire> lock[0xd1250]
@4,170,884us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1250]
@4,171,068us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1250]
@4,171,195us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_delete> lock[0xd1250]
@4,171,385us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_delete>
@4,171,514us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_release>lock[0xd1200]
@4,171,647us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_release>lock[0xd1200]
@4,171,755us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Entered LockMP_delete> lock[0xd1200]
@4,171,938us: [+0 T:0x4001f970] ti.sdo.ce.osal.LockMP - Leaving LockMP_delete>
thanks and Best regards.
melon.
