I'm working on OMAP4430 custom board with linux kernel 3.15(with device tree support) bring up. I'm having a problem with handsfree (Ext Spk) on TWL6040 audio codec, where Earphone, headset, haedset -mic, main-mic, and vibrator are working fine. When enabling handsfree with "amixer" control commands and play an audio file by means of "aplay" tool, I could hear only "pop" sound from handsfree. Could you please help me to resolve this issue?
Below are boot logs and commands used,
U-Boot 2015.01-rc1-gaa586d4 (Jun 18 2015 - 21:11:46)
CPU : OMAP4430 ES2.3
Board: OMAP4430 SDP
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Battery Voltage: 3691 mV
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading uImage
5317080 bytes read in 260 ms (19.5 MiB/s)
reading omap4-sdp.dtb
59572 bytes read in 7 ms (8.1 MiB/s)
Booting from mmc0 ...
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-3.15.0-00023-g788068e
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 5317016 Bytes = 5.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
Loading Device Tree to 8ffee000, end 8ffff8b3 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.15.0-00023-g788068e (mvijaybabu@ubuntu) (gcc version 4.6.3 (Sourcery CodeBench Lite 2012.03-57) ) #1 SMP Sun Jun 21 18:13:57 IST 2015
[ 0.000000] CPU: ARMv7 Processor [411fc093] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI OMAP4 SDP board
[ 0.000000] cma: CMA: reserved 16 MiB at ae800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4430 ES2.3
[ 0.000000] PERCPU: Embedded 9 pages/cpu @edf95000 s14080 r8192 d14592 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260368
[ 0.000000] Kernel command line: console=ttyO2,115200n8 vram=16M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait omapfb.mode=lcd:800x480MR-16@60 no_console_suspend
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1005796K/1047552K available (6854K kernel code, 596K rwdata, 2528K rodata, 381K init, 5531K bss, 41756K reserved, 269312K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0931cd0 (9384 kB)
[ 0.000000] .init : 0xc0932000 - 0xc0991700 ( 382 kB)
[ 0.000000] .data : 0xc0992000 - 0xc0a27180 ( 597 kB)
[ 0.000000] .bss : 0xc0a27180 - 0xc0f8e128 (5532 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node div_ts_ck
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node bandgap_ts_fclk
[ 0.000000] OMAP clockevent source: timer1 at 32768 Hz
[ 0.000030] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65536000000000ns
[ 0.000061] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000244] smp_twd: clock not found -2
[ 0.002838] Console: colour dummy device 80x30
[ 0.002929] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[ 0.002960] ... MAX_LOCKDEP_SUBCLASSES: 8
[ 0.002960] ... MAX_LOCK_DEPTH: 48
[ 0.002960] ... MAX_LOCKDEP_KEYS: 8191
[ 0.002990] ... CLASSHASH_SIZE: 4096
[ 0.002990] ... MAX_LOCKDEP_ENTRIES: 16384
[ 0.002990] ... MAX_LOCKDEP_CHAINS: 32768
[ 0.003021] ... CHAINHASH_SIZE: 16384
[ 0.003021] memory used by lock dependency info: 3695 kB
[ 0.003021] per task-struct memory footprint: 1152 bytes
[ 0.003112] Calibrating local timer... 297.34MHz.
[ 0.058135] Calibrating delay loop... 1185.38 BogoMIPS (lpj=5926912)
[ 0.137512] pid_max: default: 32768 minimum: 301
[ 0.138244] Security Framework initialized
[ 0.138549] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.138610] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.142578] CPU: Testing write buffer coherency: ok
[ 0.144622] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.144714] Setting up static identity map for 0x80684dd0 - 0x80684e40
[ 0.144897] L310 cache controller enabled
[ 0.144927] l2x0: 16 ways, CACHE_ID 0x410000c4, AUX_CTRL 0x7e470000, Cache size: 1024 kB
[ 0.154602] CPU1: Booted secondary processor
[ 0.186981] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.187713] Brought up 2 CPUs
[ 0.187744] SMP: Total of 2 processors activated.
[ 0.187774] CPU: All CPU(s) started in SVC mode.
[ 0.191131] devtmpfs: initialized
[ 0.201995] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.207946] omap_hwmod: l3_main_3 using broken dt data from ocp
[ 0.213134] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.415008] pinctrl core: initialized pinctrl subsystem
[ 0.418182] regulator-dummy: no parameters
[ 0.480010] NET: Registered protocol family 16
[ 0.485198] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.575347] OMAP GPIO hardware version 0.1
[ 0.586120] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 0.610076] platform 4b501000.aes: Cannot lookup hwmod 'aes'
[ 0.610595] platform 480a5000.des: Cannot lookup hwmod 'des'
[ 0.616394] error setting wl12xx data: -38
[ 0.619445] No ATAGs?
[ 0.619567] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.619567] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.622802] OMAP DMA hardware revision 0.0
[ 0.624664] ARM PMU: not yet supported on OMAP4430 due to missing CTI driver
[ 0.651824] edma-dma-engine edma-dma-engine.0: Can't allocate PaRAM dummy slot
[ 0.651916] edma-dma-engine: probe of edma-dma-engine.0 failed with error -5
[ 0.693359] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[ 0.695312] VDD_ETH: 3300 mV
[ 0.696258] VBAT: 3750 mV
[ 0.696807] reg-fixed-voltage wl12xx_vmmc.12: could not find pctldev for node /ocp/pinmux@4a100040/pinmux_wl12xx_en_pins, deferring probe
[ 0.696838] platform wl12xx_vmmc.12: Driver reg-fixed-voltage requests probe deferral
[ 0.700653] SCSI subsystem initialized
[ 0.701538] usbcore: registered new interface driver usbfs
[ 0.701751] usbcore: registered new interface driver hub
[ 0.702087] usbcore: registered new device driver usb
[ 0.702880] hsusb1_phy.13 supply vcc not found, using dummy regulator
[ 0.706054] omap_i2c 48070000.i2c: could not find pctldev for node /ocp/pinmux@4a100040/pinmux_i2c1_pins, deferring probe
[ 0.706085] platform 48070000.i2c: Driver omap_i2c requests probe deferral
[ 0.706176] omap_i2c 48072000.i2c: could not find pctldev for node /ocp/pinmux@4a100040/pinmux_i2c2_pins, deferring probe
[ 0.706207] platform 48072000.i2c: Driver omap_i2c requests probe deferral
[ 0.706298] omap_i2c 48060000.i2c: could not find pctldev for node /ocp/pinmux@4a100040/pinmux_i2c3_pins, deferring probe
[ 0.706329] platform 48060000.i2c: Driver omap_i2c requests probe deferral
[ 0.706420] omap_i2c 48350000.i2c: could not find pctldev for node /ocp/pinmux@4a100040/pinmux_i2c4_pins, deferring probe
[ 0.706451] platform 48350000.i2c: Driver omap_i2c requests probe deferral
[ 0.707977] Advanced Linux Sound Architecture Driver Initialized.
[ 0.712097] Switched to clocksource 32k_counter
[ 0.871582] NET: Registered protocol family 2
[ 0.873962] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.874298] TCP bind hash table entries: 8192 (order: 6, 294912 bytes)
[ 0.877563] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.877868] TCP: reno registered
[ 0.877929] UDP hash table entries: 512 (order: 3, 40960 bytes)
[ 0.878356] UDP-Lite hash table entries: 512 (order: 3, 40960 bytes)
[ 0.879913] NET: Registered protocol family 1
[ 0.881530] RPC: Registered named UNIX socket transport module.
[ 0.881561] RPC: Registered udp transport module.
[ 0.881561] RPC: Registered tcp transport module.
[ 0.881591] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.892822] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 1.104217] bounce pool size: 64 pages
[ 1.105377] VFS: Disk quotas dquot_6.5.2
[ 1.105529] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.108123] NFS: Registering the id_resolver key type
[ 1.108551] Key type id_resolver registered
[ 1.108581] Key type id_legacy registered
[ 1.108703] ntfs: driver 2.1.30 [Flags: R/W].
[ 1.108917] jffs2: version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 1.109588] msgmni has been set to 1470
[ 1.114379] io scheduler noop registered
[ 1.114410] io scheduler deadline registered
[ 1.114501] io scheduler cfq registered (default)
[ 1.121185] pinctrl-single 4a100040.pinmux: 203 pins at pa fc100040 size 406
[ 1.121765] pinctrl-single 4a31e040.pinmux: 28 pins at pa fc31e040 size 56
[ 1.125030] backlight.10 supply power not found, using dummy regulator
[ 1.125488] pwm-backlight backlight.10: unable to request PWM, trying legacy API
[ 1.125488] pwm-backlight backlight.10: unable to request legacy PWM
[ 1.125915] platform backlight.10: Driver pwm-backlight requests probe deferral
[ 1.127532] OMAP DSS rev 4.0
[ 1.133270] panel-dsi-hh display.16: Probe Successful: LCD Panel HH
[ 1.136077] panel-dsi-hh display.16: Connect Display..
[ 1.136199] panel-dsi-hh display.16: Failed to connect to video source
[ 1.136230] omapfb omapfb: failed to connect default display
[ 1.136230] omapfb omapfb: failed to init overlay connections
[ 1.136230] panel-dsi-hh display.16: Disconnect Disconnect..
[ 1.139923] omapfb omapfb: failed to setup omapfb
[ 1.139984] platform omapfb: Driver omapfb requests probe deferral
[ 1.141357] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.147949] omap_uart 4806a000.serial: no wakeirq for uart0
[ 1.148986] 4806a000.serial: ttyO0 at MMIO 0x4806a000 (irq = 104, base_baud = 3000000) is a OMAP UART0
[ 1.151184] omap_uart 4806c000.serial: no wakeirq for uart0
[ 1.151702] 4806c000.serial: ttyO1 at MMIO 0x4806c000 (irq = 105, base_baud = 3000000) is a OMAP UART1
[ 1.153259] omap_uart 48020000.serial: no wakeirq for uart0
[ 1.153900] 48020000.serial: ttyO2 at MMIO 0x48020000 (irq = 106, base_baud = 3000000) is a OMAP UART2
[ 2.084350] console [ttyO2] enabled
[ 2.089874] omap_uart 4806e000.serial: no wakeirq for uart0
[ 2.097167] 4806e000.serial: ttyO3 at MMIO 0x4806e000 (irq = 102, base_baud = 3000000) is a OMAP UART3
[ 2.132141] brd: module loaded
[ 2.150024] loop: module loaded
[ 2.156677] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 2.168243] PPP generic driver version 2.4.2
[ 2.173645] PPP BSD Compression module registered
[ 2.178588] PPP Deflate Compression module registered
[ 2.183990] PPP MPPE Compression module registered
[ 2.189025] NET: Registered protocol family 24
[ 2.193969] usbcore: registered new interface driver cdc_ether
[ 2.200347] usbcore: registered new interface driver cdc_ncm
[ 2.207183] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.214141] ehci-platform: EHCI generic platform driver
[ 2.220214] ehci-omap: OMAP-EHCI Host Controller driver
[ 2.246459] ehci-omap 4a064c00.ehci: EHCI Host Controller
[ 2.254547] ehci-omap 4a064c00.ehci: new USB bus registered, assigned bus number 1
[ 2.263580] ehci-omap 4a064c00.ehci: irq 109, io mem 0x4a064c00
[ 2.281951] ehci-omap 4a064c00.ehci: USB 2.0 started, EHCI 1.00
[ 2.290039] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.297210] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.304840] usb usb1: Product: EHCI Host Controller
[ 2.309967] usb usb1: Manufacturer: Linux 3.15.0-00023-g788068e ehci_hcd
[ 2.317047] usb usb1: SerialNumber: 4a064c00.ehci
[ 2.326263] hub 1-0:1.0: USB hub found
[ 2.330535] hub 1-0:1.0: 3 ports detected
[ 2.338714] usbcore: registered new interface driver cdc_acm
[ 2.344696] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.353393] usbcore: registered new interface driver usb-storage
[ 2.360076] usbcore: registered new interface driver usbserial
[ 2.366363] usbcore: registered new interface driver usbserial_generic
[ 2.373870] usbserial: USB Serial support registered for generic
[ 2.380340] usbcore: registered new interface driver option
[ 2.386383] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.394165] usbcore: registered new interface driver usbtest
[ 2.401611] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 2.408447] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
[ 2.417327] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.424499] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.432525] usb usb2: Product: MUSB HDRC host driver
[ 2.437744] usb usb2: Manufacturer: Linux 3.15.0-00023-g788068e musb-hcd
[ 2.444824] usb usb2: SerialNumber: musb-hdrc.0.auto
[ 2.452728] hub 2-0:1.0: USB hub found
[ 2.456939] hub 2-0:1.0: 1 port detected
[ 2.495758] mousedev: PS/2 mouse device common for all mice
[ 2.504730] i2c /dev entries driver
[ 2.508483] Driver for 1-wire Dallas network protocol.
[ 2.523132] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 2.533325] omap_hsmmc 4809c000.mmc: unable to get vmmc regulator -517
[ 2.540466] platform 4809c000.mmc: Driver omap_hsmmc requests probe deferral
[ 2.548553] omap_hsmmc 480b4000.mmc: unable to get vmmc regulator -517
[ 2.555603] platform 480b4000.mmc: Driver omap_hsmmc requests probe deferral
[ 2.563812] omap_hsmmc 480d5000.mmc: unable to get vmmc regulator -517
[ 2.570892] platform 480d5000.mmc: Driver omap_hsmmc requests probe deferral
[ 2.579345] usbcore: registered new interface driver usbhid
[ 2.585235] usbhid: USB HID core driver
[ 2.597778] omap-abe-twl6040 sound.11: ASoC: CODEC twl6040-codec not registered
[ 2.605682] omap-abe-twl6040 sound.11: snd_soc_register_card() failed: -517
[ 2.613891] platform sound.11: Driver omap-abe-twl6040 requests probe deferral
[ 2.622436] oprofile: no performance counters
[ 2.627777] oprofile: using timer interrupt.
[ 2.632904] TCP: cubic registered
[ 2.636413] Initializing XFRM netlink socket
[ 2.641021] NET: Registered protocol family 17
[ 2.645782] NET: Registered protocol family 15
[ 2.650848] Key type dns_resolver registered
[ 2.656768] Power Management for TI OMAP4+ devices.
[ 2.662017] Power Management for TI OMAP4.
[ 2.666320] OMAP4 PM: u-boot >= v2012.07 is required for full PM support
[ 2.673553] ThumbEE CPU extension supported.
[ 2.678131] Registering SWP/SWPB emulation handler
[ 2.687011] VBAT: disabling
[ 2.687011] VDD_ETH: disabling
[ 2.782073] vwl1271: 1800 mV
[ 2.792327] Skipping twl internal clock init and using bootloader value (unknown osc rate)
[ 2.806365] twl 0-0048: PIH (irq 39) nested IRQs
[ 2.814819] twl_rtc rtc.17: Enabling TWL-RTC
[ 2.824737] twl_rtc rtc.17: rtc core: registered rtc.17 as rtc0
[ 2.834350] VAUX1_6030: 1000 <--> 3000 mV at 2800 mV
[ 2.841979] VAUX2_6030: 1200 <--> 2800 mV at 1800 mV
[ 2.849456] VAUX3_6030: 1000 <--> 3000 mV at 1200 mV
[ 2.856994] VMMC: 1200 <--> 3000 mV at 3000 mV
[ 2.863891] VPP: 1800 <--> 2500 mV at 1900 mV
[ 2.870758] VUSIM: 1200 <--> 2900 mV at 1800 mV
[ 2.877563] VDAC: 1800 mV
[ 2.881927] VANA: 2100 mV
[ 2.886840] VCXIO: 1800 mV
[ 2.891326] VUSB: 3300 mV
[ 2.896179] V1V8: 1800 mV
[ 2.901062] V2V1: 2100 mV
[ 2.911041] twl6030_usb usb-comparator.31: Initialized TWL6030 USB module
[ 2.927062] twl6030_bci bci.35: twl6030_bci_battery_probe: Platform data not available, so populate from DT
[ 3.502624] twl6030_bci bci.35: Battery Voltage at Bootup is 3742 mV
[ 3.545959] twl6030_pwrbutton pwrbutton.36: twl6030_pwrbutton_probe: Platform data not available, so populate from DT
[ 3.557373] twl6030_pwrbutton_probe: Enter
[ 3.562683] input: twl6030_pwrbutton as /devices/44000000.ocp/48070000.i2c/i2c-0/0-0048/pwrbutton.36/input/input0
[ 3.590545] omap_i2c 48070000.i2c: bus 0 rev0.10 at 400 kHz
[ 3.601776] noa3301 1-0037: ALS Integration Time = 4
[ 3.607055] noa3301 1-0037: ALS Interval = 10
[ 3.611816] input: noa3301 as /devices/virtual/input/input1
[ 3.672607] noa3301 1-0037: noa3301_probe: NOA3301 probed successfully.
[ 3.672607] omap_i2c 48072000.i2c: bus 1 rev0.10 at 400 kHz
[ 3.690185] omap_i2c 48060000.i2c: bus 2 rev0.10 at 400 kHz
[ 3.792724] HX8526: Device ID = 85-26-01
[ 3.797515] HX8526: Version ID = 00
[ 3.944458] input: hx8526-touchscreen as /devices/44000000.ocp/48350000.i2c/i2c-3/3-004a/input/input2
[ 3.955810] omap_i2c 48350000.i2c: bus 3 rev0.10 at 100 kHz
[ 3.962738] backlight.10 supply power not found, using dummy regulator
[ 3.975494] panel-dsi-hh display.16: Connect Display..
[ 3.985015] omapfb omapfb: cannot parse default modes
[ 4.008941] Console: switching to colour frame buffer device 60x50
[ 4.023498] panel-dsi-hh display.16: Enable Display
[ 4.028961] panel-dsi-hh display.16: START : Power On Display ..
[ 4.481872] panel-dsi-hh display.16: Panel HH : Powered On
[ 4.488189] omapfb omapfb: using display 'lcd0' mode 480x800
[ 4.498992] omap_hsmmc 4809c000.mmc: pins are not configured from the driver
[ 4.554290] omap_hsmmc 480b4000.mmc: pins are not configured from the driver
[ 4.692962] omap-abe-twl6040 sound.11: twl6040-legacy <-> 40132000.mcpdm mapping ok
[ 4.702148] omap-abe-twl6040 sound.11: dmic-hifi <-> 4012e000.dmic mapping ok
[ 4.727783] input: SDP4430 Headset Jack as /devices/sound.11/sound/card0/input3
[ 4.736236] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 4.748565] mmc0: new high speed SDHC card at address e624
[ 4.749847] input: gpio_keys.7 as /devices/gpio_keys.7/input/input4
[ 4.760986] twl_rtc rtc.17: setting system clock to 2015-05-12 14:27:05 UTC (1431440825)
[ 4.764587] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[ 4.818145] ALSA device list:
[ 4.818695] #0: SDP4430
[ 4.833129] mmcblk0: p1 p2
[ 4.851654] kjournald starting. Commit interval 5 seconds
[ 4.859893] EXT3-fs (mmcblk0p2): using internal journal
[ 4.865600] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 4.872955] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 4.886016] devtmpfs: mounted
[ 4.886779] Freeing unused kernel memory: 380K (c0932000 - c0991000)
[ 4.932128] mmc1: new high speed MMC card at address 0001
[ 4.939758] mmcblk1: mmc1:0001 SEM04G 3.68 GiB
[ 4.945678] mmcblk1boot0: mmc1:0001 SEM04G partition 1 1.00 MiB
[ 4.952423] mmcblk1boot1: mmc1:0001 SEM04G partition 2 1.00 MiB
[ 4.964538] mmcblk1: p1 p2 p3
[ 4.976593] mmcblk1boot1: unknown partition table
[ 4.986968] mmcblk1boot0: unknown partition table
[ 4.997680] omap_hsmmc 480d5000.mmc: card claims to support voltages below defined range
[ 5.021240] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 5.030029] mmc2: new SDIO card at address 0001
INIT: version 2.88 booting
Starting udev
[ 5.712249] udevd[969]: starting version 182
[ 7.192291] random: nonblocking pool is initialized
[ 8.080383] wl1271_sdio mmc2:0001:2: legacy platform data not found, trying device tree
bootlogd: cannot allocate pseudo tty: No such file or directory
[ 8.588287] cfg80211: Calling CRDA to update world regulatory domain
INIT: Entering runlevel: 5
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
[ 9.787139] wlcore: loaded
Starting system message bus: dbus.
Starting syslogd/klogd: done
[ 10.137329] Number of LUNs=8
[ 10.143280] Mass Storage Function, version: 2009/09/11
[ 10.145477] LUN: removable file: (no medium)
[ 10.153411] Number of LUNs=1
[ 10.157684] LUN: removable file: /dev/mmcblk1p3
[ 10.162597] Number of LUNs=1
[ 10.167907] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 10.175933] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 10.175933] g_mass_storage gadget: g_mass_storage ready
Poky (Yocto Project Reference Distro) 1.7.2 hh /dev/ttyO2
login:root
root@hh:~# amixer controls
numid=3,iface=MIXER,name='Aux FM Volume'
numid=1,iface=MIXER,name='Capture Preamplifier Volume'
numid=2,iface=MIXER,name='Capture Volume'
numid=10,iface=MIXER,name='AUXL Playback Switch'
numid=9,iface=MIXER,name='AUXR Playback Switch'
numid=19,iface=MIXER,name='Analog Left Capture Route'
numid=18,iface=MIXER,name='Analog Right Capture Route'
numid=11,iface=MIXER,name='Earphone Playback Switch'
numid=6,iface=MIXER,name='Earphone Playback Volume'
numid=17,iface=MIXER,name='Handsfree Left Playback'
numid=5,iface=MIXER,name='Handsfree Playback Volume'
numid=16,iface=MIXER,name='Handsfree Right Playback'
numid=15,iface=MIXER,name='Headset Left Playback'
numid=4,iface=MIXER,name='Headset Playback Volume'
numid=7,iface=MIXER,name='Headset Power Mode'
numid=14,iface=MIXER,name='Headset Right Playback'
numid=8,iface=MIXER,name='PLL Selection'
numid=13,iface=MIXER,name='Vibra Left Playback'
numid=12,iface=MIXER,name='Vibra Right Playback'
root@hh:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: SDP4430 [SDP4430], device 0: TWL6040 twl6040-legacy-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
root@hh:~# arecord -l
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 0: SDP4430 [SDP4430], device 1: DMIC Capture dmic-hifi-1 []
Subdevices: 1/1
root@hh:~# amixer cset numid=8 1
; type=ENUMERATED,access=rw------,values=1,items=2
; Item #0 'Low-Power'
; Item #1 'High-Performance'
: values=1
root@hh:~# amixer cset numid=17 1
; type=ENUMERATED,access=rw------,values=1,items=3
; Item #0 'Off'
; Item #1 'HF DAC'
; Item #2 'Line-In amp'
: values=1
root@hh:~# amixer cset numid=16 1
; Item #0 'Off'
; Item #1 'HF DAC'
: values=1
root@hh:~# amixer cset numid=5 29
; type=INTEGER,access=rw---R--,values=2,min=0,max=29,step=0
: values=29,29
| dBscale-min=-52.00dB,step=2.00dB,mute=0
root@hh:~# aplay -v /opt/sound/test_play.wav
Playing WAVE '/opt/sound/test_play.wav' : Signed 24 bit Little Endian in 3bytes, Rate 11025 Hz, Mono
Plug PCM: Rate conversion PCM (96000, sformat=S32_LE)
Converter: linear-interpolation
Protocol version: 10002
Its setup is:
stream : PLAYBACK
access : RW_INTERLEAVED
format : S24_3LE
subformat : STD
channels : 1
rate : 11025
exact rate : 11025 (11025/1)
msbits : 24
buffer_size : 3763
period_size : 940
period_time : 85333
tstamp_mode : NONE
period_step : 1
avail_min : 940
period_event : 0
start_threshold : 3763
stop_threshold : 3763
silence_threshold: 0
silence_size : 0
boundary : 123305984
Slave: Hardware PCM card 0 'SDP4430' device 0 subdevice 0
Its setup is:
stream : PLAYBACK
access : MMAP_INTERLEAVED
format : S32_LE
subformat : STD
channels : 1
rate : 96000
exact rate : 96000 (96000/1)
msbits : 24
buffer_size : 32768
period_size : 8192
period_time : 85333
tstamp_mode : NONE
period_step : 1
avail_min : 8192
period_event : 0
start_threshold : 32768
stop_threshold : 32768
silence_size : 0
boundary : 1073741824
appl_ptr : 0
hw_ptr : 0
root@hh:~# cat /sys/kernel/debug/gpio
GPIOs 0-31, gpio:
gpio-2 (max8903-FLT ) in hi IRQ
gpio-3 (max8903-DOK ) in hi IRQ
gpio-13 (dsi en1 ) out hi
gpio-14 (dsi en2 ) out hi
gpio-16 (volumeup ) in hi IRQ
gpio-17 (next ) in hi IRQ
gpio-19 (? ) out lo
gpio-20 (main_mic_en ) out hi
gpio-25 (volumedown ) in hi IRQ
gpio-26 (play_pause ) in hi IRQ
GPIOs 32-63, gpio:
gpio-34 (vwl1271 ) out lo
gpio-35 (hsusb1_phy.13 ) out hi
gpio-48 (VDD_ETH ) out lo
gpio-49 (? ) out lo
gpio-62 (audio_vddhf_en ) out hi
GPIOs 64-95, gpio:
GPIOs 96-127, gpio:
gpio-104 (dsi reset ) out hi
gpio-127 (audpwron ) out hi
GPIOs 128-159, gpio:
GPIOs 160-191, gpio:
gpio-160 (? ) out lo
gpio-162 (? ) out lo
gpio-173 (? ) out hi
GPIOs 253-255, platform/twl6040-gpo, twl6040, can sleep:
root@hh:~#
I could hear only pop sounds during start and end of playing audio file. Am I missing anything? Could you please help me to fix it.
Thanks and Regards,
Vijaybabu.M
