Boot ELF image from NAND using IBL
As I understand it, the IBL on the TMDSEVM667x is not configured out of the box to be able to boot an ELF image from NAND, and in order to make it do so I must change the IBL Configuration Table.
From the IBL source code I can see what the structure of the IBL Configuration Table is, and what needs to be changed, but I haven't found documentation indicating where in I2C memory it is located and what the accepted procedure is for modifying it. So my question boils down to this:
How do I modify the IBL Configuration Table contents?
Thanks.
