A related question is a question created from another question. When the related question is created, it will be automatically linked to the original question.
1. The DVFlasher that I am using only works on the first UBL block. Is there other utility that I can use to program the blocks 2 - 5?.
2. In Linux userspace, what utility did you use to check the CRC validity of UBL data on blocks 1-5?.
3. Lastly, what utility did you use in linux userspace to re-program the UBL block 1-5 just incase they messed up?. I do believe, using mtdwrite is not possible due to CRC incompatibility.
