Parallel RGB signals out from DM365
I'm trying to drive a parallel RGB LCD usign DM365 but  I'M NOT ABLE TO OBTAIN ANY SIGNAL OUT FROM DM365.
I'm using khilman_master_2.6.34-rc1 kernel branch.
I've patched davincifb.c in order to manage output=lcd:format=rgb using this function:
________________________________________________
static void davincifb_lcd_rgb_config(int on)
        if (on) {
                /* Reset video encoder module */
                dispc_reg_out(VENC_VMOD, 0x0);
                /* set hsync pulse width */
                dispc_reg_out(VENC_HSPLS, dm->osd0->info.var.hsync_len);
                /* set vsync pulse width */
                dispc_reg_out(VENC_VSPLS, dm->osd0->info.var.vsync_len);
                /* set horizontal interval  */
                dispc_reg_out(VENC_HINT, dm->osd0->info.var.left_margin + dm->osd0->info.var.right_margin + dm->osd0->info.var.width);
                /* set horizontal data valid start position  */
                dispc_reg_out(VENC_HSTART, dm->osd0->info.var.left_margin);
                /* set Horizontal data valid range  */
                dispc_reg_out(VENC_HVALID, dm->osd0->info.var.width);
                /* set Vertical interval  */
                dispc_reg_out(VENC_VINT, dm->osd0->info.var.upper_margin + dm->osd0->info.var.lower_margin + dm->osd0->info.var.height);
                /* set Vertical data valid start position */
                dispc_reg_out(VENC_VSTART, dm->osd0->info.var.upper_margin);
                dispc_reg_out(VENC_VVALID, dm->osd0->info.var.height);
                dispc_reg_out(VENC_DCLKCTL, 0x801);
                dispc_reg_out(VENC_DCLKPTN0, 0x03);
                dispc_reg_out(VENC_DCLKPTN1, 0x0);
                dispc_reg_out(VENC_DCLKPTN2, 0x0);
                dispc_reg_out(VENC_DCLKPTN3, 0x0);
                dispc_reg_out(VENC_DCLKPTN0A, 0x3);
                dispc_reg_out(VENC_DCLKPTN1A, 0x0);
                dispc_reg_out(VENC_DCLKPTN2A, 0x0);
                dispc_reg_out(VENC_DCLKPTN3A, 0x0);
                dispc_reg_out(VENC_OSDCLK1, 3);
                /* Enable VCLK */
                dispc_reg_out(VENC_VIDCTL, 0x2000);
                dispc_reg_out(VENC_VMOD,(VENC_VMOD_VDMD_RGB666<<VENC_VMOD_VDMD_SHIFT) |VENC_VMOD_ITLCL | VENC_VMOD_HDMD | VENC_VMOD_VIE | VENC_VMOD_VENC);
#endif
        } else {
                dispc_reg_out(VENC_VMOD, 0);
This is my registers situation:
PINMUX:
a(1C40000):  0x00E00000 0x00285555 0x000018C0 0x375AFFFF
a(1C40010):  0x00007FFF
PLL configurations:
a(1C40800):  0x0001080E 0x00000000 0x00000000 0x00000000
a(1C40810):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C40820):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C40830):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C40840):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C40850):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C40860):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C40870):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C40880):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C40890):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C408A0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C408B0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C408C0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C408D0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C408E0):  0x00000000 0x00000004 0x00000000 0x00000000
a(1C408F0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C40900):  0x00000051 0x00000010 0x00410000 0x00000000
a(1C40910):  0x00000051 0x00008007 0x00008000 0x00008001
a(1C40920):  0x00008001 0x00000000 0x00008000 0x00008000
a(1C40930):  0x00000000 0x00000000 0x00000001 0x00000006
a(1C40940):  0x0000001C 0x00000000 0x00000001 0x00000009
a(1C40950):  0x000001FF 0x00000000 0x00000000 0x00000000
a(1C40960):  0x00008003 0x00008001 0x00008011 0x00008000
a(1C40970):  0x00008003 0x00008001 0x00000000 0x00000000
a(1C40980):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C40990):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C409A0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C409B0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C409C0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C409D0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C409E0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C409F0):  0x00000000 0x00000000 0x00000000 0x00000000
VENC registers
a(1C71E00):  0x00002903 0x00002000 0x00000000 0x00000000
a(1C71E10):  0x00000002 0x00000002 0x0000010E 0x00000012
a(1C71E20):  0x000000F0 0x0000015C 0x00000014 0x00000140
a(1C71E30):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71E40):  0x0000FF00 0x00000000 0x00000000 0x00000000
a(1C71E50):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71E60):  0x00000000 0x00000801 0x00000003 0x00000000
a(1C71E70):  0x00000000 0x00000000 0x00000003 0x00000000
a(1C71E80):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71E90):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71EA0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71EB0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71EC0):  0x00000000 0x00007000 0x00000000 0x0000017A
a(1C71ED0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71EE0):  0x00000100 0x00000000 0x00000000 0x00000000
a(1C71EF0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71F00):  0x00000400 0x0000057C 0x00000159 0x000002CB
a(1C71F10):  0x000006EE 0x00000400 0x0000057C 0x00000159
a(1C71F20):  0x000002CB 0x000006EE 0x00000000 0x00000001
a(1C71F30):  0x00000003 0x00000000 0x00000000 0x00000000
a(1C71F40):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71F50):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71F60):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71F70):  0x0000D642 0x00000000 0x00000000 0x00000000
a(1C71F80):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71F90):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71FA0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71FB0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71FC0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71FD0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71FE0):  0x00000000 0x00000000 0x00000087 0x0000FFE7
a(1C71FF0):  0x00000008 0x00000000 0x00000000 0x00000000
OSD Registers
a(1C71C00):  0x00000200 0x00000302 0x00002003 0x00008002
a(1C71C10):  0x00000000 0x00000000 0x0000002D 0x0000002D
a(1C71C20):  0x0000002D 0x0000000C 0x00000000 0x00000000
a(1C71C30):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71C40):  0x00000080 0x00000012 0x00000000 0x00000000
a(1C71C50):  0x000002D0 0x000000A0 0x00000000 0x00000000
a(1C71C60):  0x000002D0 0x000000A0 0x00000000 0x00000000
a(1C71C70):  0x000000F0 0x000000A0 0x00000000 0x00000000
a(1C71C80):  0x000002D0 0x000000A0 0x00000000 0x00000000
a(1C71C90):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71CA0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71CB0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71CC0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71CD0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C71CE0):  0x00000000 0x00000000 0x00001000 0x00000000
a(1C71CF0):  0x00000000 0x00000000 0x00000000 0x00000000
VPBE Clock Control Register
a(1C70200):  0x00000019
VPSS_CLKCTL
a(1c40044):  0x00000018
ISP System Configuration Registers
a(1C70000):  0x4C180800 0x0000007F 0x00000002 0x00300200
a(1C70010):  0x0B1F0100 0x1F0A0F1F 0x00000015 0x00000000
a(1C70020):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C70030):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C70040):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C70050):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C70060):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C70070):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C70080):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C70090):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C700A0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C700B0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C700C0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C700D0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C700E0):  0x00000000 0x00000000 0x00000000 0x00000000
a(1C700F0):  0x00000000 0x00000000 0x00000000 0x00000000
Can you give me any help? What can I test, what else can be wrong?
Thx
