ROI implementation
I am working on ipnc rdk version 3.8 on my custom board. I already talk about ROI with you.
Please check below link:
http://e2e.ti.com/support/embedded/multimedia_software_codecs/f/356/p/401476/1421744#1421744
e2e.ti.com/.../431112
I want to do ROI like same as below as My Requirement :
The entire image will be captured, as a static cached image, at a configurable rate such as every 60 seconds. The constantly changing ROI based on the FPS will be overlaid on the static cached image. The static area of the image will result in reducing the bandwidth consumption as the compression algorithm should be able to encode it more efficiently.
Can you please let me know, exactly same working ROI in IPNC RDK version 3.8 ? or Any changes ?
If changes then can you please provide patch for same..??
Sandip
