Hi
We are test usb on am335x evmsk board .but it is not detected. I have using 3.14 kernel version.
Any thing missing ?
Tejas
Hi
Any thing missing ?
Tejas
Tejas,
Please provide a detailed explanation of your problem. We cannot help based on the information you have given.
Which USB connector are you using? I suppose it's the big Type-A connector. Check this wiki for USB configuration: http://processors.wiki.ti.com/index.php/UsbgeneralpageLinuxCore
Tejas,
Please run the script attached below on your board with the binaries you built. It might tell where the problem is.
#!/bin/sh
# Util to check USB subsystem on for Linux kernel 3.12+
# TODO: usage
VERSION=0.2.0
### functions ###
has_supported_kernel() {
local _ver
local _t
_ver=`uname -r`
DBG_PRINT "kernel $_ver"
_t=${_ver%%.*}
# 2.x.x, unsupported
[ $_t -ge 3 ] || return 1
# 4.x.x, supported
[ $_t -lt 4 ] || return 0
_ver=${_ver#*.}
_t=${_ver%%.*}
# < 3.12.x, unsupported
[ $_t -ge 12 ] || return 1
return 0
check_platform () {
local _hw
_hw=`grep '^Hardware' /proc/cpuinfo`
DBG_PRINT $_hw
[ "${_hw#*AM33XX}" = "$_hw" ] || {
PLATFORM="am335x"
USB0='usb@47400000/usb@47401000'
USB1='usb@47400000/usb@47401800'
return 0;
[ "${_hw#*AM43}" = "$_hw" ] || {
PLATFORM="am437x"
USB0='omap_dwc3@48380000/usb@48390000'
USB1='omap_dwc3@483c0000/usb@483d0000'
return 0
[ "${_hw#*DRA74X}" = "$_hw" ] || {
PLATFORM="am57x"
USB0='omap_dwc3_1@48880000/usb@48890000'
USB1='omap_dwc3_2@488c0000/usb@488d0000'
return 0
echo "Unsupported $_hw"
return 1
# check a kernel CONFIG option
# params $1 - the config option
# $2 = '-q', quiet output
# return 0 - undefined
# 1 - defined as 'm', kernel module
# 2 - defined as 'y', kernel builtin
check_kernel_config() {
local _cfg
[ -n "$1" ] || return 0
_cfg=`zcat /proc/config.gz | grep "^$1\>"`
case ${_cfg#*=} in
"y") return 2;;
"m") return 1;;
*) [ "$2" = "-q" ] ||
echo "Error: $1 is undefined in kernel config"
return 0;;
esac
# check a kernel module
# $1 - module name, relative path from drivers/, with .ko surfix
# return 0 - found
# 1 - error
check_module() {
local _modname
local _moddep
[ -n "$1" ] || return 1
_modname="/lib/modules/`uname -r`/kernel/drivers/${1}.ko"
_moddep="/lib/modules/`uname -r`/modules.dep"
DBG_PRINT 1
[ -f $_modname ] || {
echo "Error: $_modname not found."
echo " Please ensure 'make module_install' is done properly."
return 1
DBG_PRINT 2
[ -f $_moddep ] || $moddep_checked || {
echo "Error: $_moddep not found."
moddep_checked=true
DBG_PRINT 3
lsmod | grep `basename $1 | tr '-' '_'` > /dev/null || {
DBG_PRINT ">>>> ${1}.ko:"
if grep "${1}.ko:" $_moddep > /dev/null; then
DBG_PRINT 5
echo "Error: $_moddep seems to be valid,"
echo " but `basename $1`.ko is not loaded."
echo " Please provide /proc/config.gz and /lib/module/`uname -r`/*"
echo " for further investigation."
else
DBG_PRINT 6
echo "Error: `basename $1`: $_moddep is invalid."
echo " Please run command 'depmod' on the target to re-generate it,"
echo " then reboot the target. If the issue still exists, please"
echo " ensure 'make module_install' is done properly."
fi
DBG_PRINT 7
return 1
DBG_PRINT 8
return 0
check_musb_drivers() {
check_kernel_config CONFIG_USB_MUSB_HDRC
[ $? != 1 ] || check_module 'usb/musb/musb_hdrc'
check_kernel_config CONFIG_USB_MUSB_DUAL_ROLE -q
[ $? != 0 ] || echo "Warning: CONFIG_USB_MUSB_DUAL_ROLE undefined."
check_kernel_config CONFIG_USB_MUSB_DSPS
[ $? != 1 ] || {
check_module 'usb/musb/musb_dsps'
check_module 'usb/musb/musb_am335x'
check_kernel_config CONFIG_AM335X_PHY_USB
[ $? != 1 ] || {
check_module 'usb/phy/phy-am335x'
check_module 'usb/phy/phy-am335x-control'
check_kernel_config CONFIG_MUSB_PIO_ONLY -q
[ $? != 0 ] || {
if check_kernel_config CONFIG_TI_CPPI41 -q; then
echo "Error: MUSB CPPI DMA mode is enabled, but CPPI moudle is not enabled in DMA Engine."
echo " Please enable CONFIG_TI_CPPI41 under DMA Engine Support in kernel config."
fi
check_dwc3_drivers() {
check_kernel_config CONFIG_USB_DWC3
[ $? != 1 ] || check_module 'usb/dwc3/dwc3'
check_kernel_config CONFIG_USB_DWC3_DUAL_ROLE -q
[ $? != 0 ] || echo "Warning: CONFIG_USB_DWC3_DUAL_ROLE undefined."
check_kernel_config CONFIG_USB_DWC3_OMAP
[ $? != 1 ] || check_module 'usb/dwc3/dwc3-omap'
check_kernel_config CONFIG_USB_XHCI_HCD
[ $? != 1 ] || {
check_module 'usb/host/xhci-plat-hcd'
check_module 'usb/host/xhci-hcd'
check_kernel_config CONFIG_OMAP_CONTROL_PHY
[ $? != 1 ] || check_module 'phy/phy-omap-control'
if [ $PLATFORM = am437x ]; then
check_kernel_config CONFIG_OMAP_USB2
[ $? != 1 ] || check_module 'phy/phy-omap-usb2'
else
check_kernel_config CONFIG_TI_PIPE3
[ $? != 1 ] || check_module 'phy/phy-ti-pipe3'
fi
### debug ###
g_log_file=/tmp/chmusb.log
DBG_ENABLE() { g_dbg_enabled=true; }
DBG_DISABLE() { g_dbg_enabled=false; }
DBG_LOG_RESET() { ! $g_dbg_enabled || echo > $g_log_file; }
DBG_PRINT() { ! $g_dbg_enabled || echo "$(date +%H:%M:%S) [$(basename $0)]: $*"; }
DBG_LOG() { DBG_PRINT $* >> $g_log_file; }
DBG_LOG_MARK() { DBG_PRINT "----------------" >> $g_log_file; }
### main ####
moddep_checked=false
echo "chkusb.sh Version $VERSION"
[ "$V" = "1" ] && DBG_ENABLE && DBG_LOG_RESET || DBG_DISABLE
has_supported_kernel ||
{ echo "Unsupported kernel version: `uname -r`"; exit 1; }
check_platform || exit 2
DBG_PRINT device: $PLATFORM
which lsusb > /dev/null ||
{ echo "Error; lsusb command not found"; exit 3; }
if lsusb > /dev/null 2>&1; then
echo "USB is initialized"
else
echo "USB initialization failed"
# failed, continue checking
[ -f /proc/config.gz ] ||
{ echo "Error: /proc/config.gz not found"; exit 4; }
case $PLATFORM in
am335x) check_musb_drivers;;
am437x | am57x) check_dwc3_drivers;;
echo "Error: unsupported platform $PLATFORM"
exit 5;;
esac
fi
# check dr_mode & gadget drivers
[ -d /proc/device-tree ] || {
echo "Warning: /proc/device-tree/ not found"
if [ -d "/lib/modules/`uname -r`/" ]; then
echo "The list of USB gadget drivers installed:"
ls -1Rp "/lib/modules/`uname -r`/kernel/drivers/usb/gadget/"
fi
exit 0
for _usb in "${USB0}" "${USB1}"; do
_usb_dir="/proc/device-tree/ocp/${_usb}"
_status=`cat $_usb_dir/status 2> /dev/null`
_dr_mode=`cat $_usb_dir/dr_mode`
echo `basename $_usb`: $_dr_mode, $_status
[ "$_status" = "disabled" -o "$_dr_mode" = "host" ] || gadget_mode=true
done
DBG_PRINT $gadget_mode
$gadget_mode || exit 0
echo
check_kernel_config CONFIG_USB_LIBCOMPOSITE
case $? in
0) echo "Error: no any gadget driver enabled"
exit 6;;
1) is_gadget_builtin=false;;
2) echo "The gadget driver is built-in"
is_gadget_builtin=true;;
esac
check_kernel_config CONFIG_USB_ZERO -q ||
echo "Gadget Kernel Config: g_zero is enabled"
check_kernel_config CONFIG_USB_AUDIO -q ||
echo "Gadget Kernel Config: g_audio is enabled"
check_kernel_config CONFIG_USB_ETH -q ||
echo "Gadget Kernel Config: g_ether is enabled"
check_kernel_config CONFIG_USB_G_NCM -q ||
echo "Gadget Kernel Config: g_ncm is enabled"
check_kernel_config CONFIG_USB_MASS_STORAGE -q ||
echo "Gadget Kernel Config: g_mass_storage is enabled"
check_kernel_config CONFIG_USB_G_SERIAL -q ||
echo "Gadget Kernel Config: g_serial is enabled"
check_kernel_config CONFIG_USB_G_PRINTER -q ||
echo "Gadget Kernel Config: g_printer is enabled"
g_driver=`grep '^DRIVER=' /sys/class/udc/*/uevent 2>/dev/null`
echo "gadget driver loaded: ${g_driver:-(none)}"
echo
if ! $is_gadget_builtin; then
else
echo "Error: /lib/modules/`uname -r`/ not found"
exit 7
fi
fi
# vim: ft=sh:ts=4:sw=4:et
