no element named 'secureNetfp'
Hi Team,
I am new to this platform . When i started complie PHY , i got following error (runtime error: ti.runtime.netfp.Settings: no element named 'secureNetfp')
MCDSK : 3.1.0.3
PHY : LWP1410P5
Syslib : syslib_3_00_04_00
Configuring packages...
C:/ti/xdctools_3_25_06_96/xs --xdcpath=";C:/ti/bios_6_37_03_30/packages;C:/ti/ipc_3_22_02_11/packages;;C:/ti/sc_lte_sdk_04_01_lwp1405_premium/sc_lte_phy_04_01_lwp1410p5_premium/sc_lte_src\mo\platform\tcp3d_2_1_0_1;C:/ti/pdk_keystone2_3_01_00_03/packages;C:/ti/ndk_2_22_02_16/packages;C:/ti/edma3_lld_02_11_13_17/packages;C:/ti/salld_keystone2_02_00_02_00/packages;C:/ti/xdais_7_21_01_07/packages;C:/ti/uia_1_03_02_10/packages;/packages;C:/ti/sc_lte_sdk_04_01_lwp1405_premium/ltelib_3_01_00_07_light/LTE/packages;C:/ti/dsplib_c66x_3_2_0_1/packages;C:/ti/ctoolslib_1_1_0_0/packages;C:/ti/sc_lte_sdk_04_01_lwp1405_premium/syslib_3_00_04_00/syslib/packages;C:/TI/sc_lte_sdk_04_01_lwp1405_premium/sc_lte_phy_04_01_lwp1410p5_premium/sc_lte_src/mo/phy/lib/mo;C:/TI/sc_lte_sdk_04_01_lwp1405_premium/sc_lte_phy_04_01_lwp1410p5_premium/sc_lte_src/mo/phy/scripts/platform" xdc.tools.configuro -DPHY_MULTI_CORE_BUILD_ENABLE=1 -DPHY_MULTI_CORE_LOAD_ENABLE=1 -DCfg_HW_PLATFORM=5  -DARCH_TYPE=6614 -t ti.targets.elf.C66 -DSECURE_NETFP=0 -p
 ti.platforms.evm6614:LTE -b ../../../scripts/platform/tci6614_config.bld -DCfg_TRACE_MODE=4 -DCfg_UIA_MODE=3 -DBIOS_OUT_DIR=C:/TI/sc_lte_sdk_04_01_lwp1405_premium/sc_lte_phy_04_01_lwp1410p5_premium/sc_lte_src/mo/phy/build/integration/PHY/bios_build -r release -c C:/ti/ccsv5/tools/compiler/c6000_7.4.4   -o ./configPkg ../../../code/toplevel/phy/phy_master.cfg
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring phy_master.xe66 from package/cfg/phy_master_pe66.cfg ...
js: "C:/TI/sc_lte_sdk_04_01_lwp1405_premium/sc_lte_phy_04_01_lwp1410p5_premium/sc_lte_src/mo/phy/code/toplevel/phy/phy_master.cfg", line 102: XDC runtime error: ti.runtime.netfp.Settings: no element named 'secureNetfp'
    "./package/cfg/phy_master_pe66.cfg", line 334
gmake.exe: *** [package/cfg/phy_master_pe66.xdl] Error 1
Warning: directory "C:/packages" on package path does not exist
js: "C:/TI/xdctools_3_25_06_96/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake[1]: Leaving directory `C:/TI/sc_lte_sdk_04_01_lwp1405_premium/sc_lte_phy_04_01_lwp1410p5_premium/sc_lte_src/mo/phy/build/integration/PHY'
gmake: *** [all_build] Error 2
Can you please help to resolve this issue.
Also if possible can you share sc_lte_sdk_04_01_lwp1410_premium.exe
Thanks in Advance.
