Hyperlink & GiGE conflict
Other Parts Discussed in Thread: TMS320C6678
Am connecting two c66x EVM using a hyperlink cable -
EVM-1 DSP-core0 receives the ICMP  packet from the ethernet gige interface and transfer it to EVM-2 DSP core0 through hyperlink.
Problem that am facing is both GIGE and HYPERLINK is having conflict .
If the Hyperlink link is through between two EVM , am not getting any gige packets interrupt.
If i comment out the hyperlink part - Packets are received through the Gige port .
Is there any interrupt conflict or any idea to resolve this issue ??
My CFG file
 *  Copyright 2009 by Texas Instruments Incorporated.
 *  All rights reserved. Property of Texas Instruments Incorporated.
 *  Restricted rights to use, duplicate or disclose this code are
 *  granted through contract.
/* THIS FILE WAS GENERATED BY ti.sysbios.genx */
/* Load all required BIOS/XDC runtime packages */
var Memory                      =   xdc.useModule('xdc.runtime.Memory');
var BIOS                        =   xdc.useModule('ti.sysbios.BIOS');
var HeapMem                     =   xdc.useModule('ti.sysbios.heaps.HeapMem');
var HeapBuf                     =   xdc.useModule('ti.sysbios.heaps.HeapBuf');
var Log                         =   xdc.useModule('xdc.runtime.Log');
var Task                        =   xdc.useModule('ti.sysbios.knl.Task');
var Semaphore                   =   xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi			                =	xdc.useModule('ti.sysbios.family.c64p.Hwi');
var ECM     					= 	xdc.useModule('ti.sysbios.family.c64p.EventCombiner');
var Timestamp                   =   xdc.useModule('xdc.runtime.Timestamp');
var TimestampProvider           =   xdc.useModule('ti.sysbios.family.c64p.TimestampProvider');
var Clock						= 	xdc.useModule('ti.sysbios.knl.Clock');
//Timestamp.SupportProxy          =   xdc.useModule('xdc.runtime.TimestampStd');
/* Load the CSL package */
var Csl     					= 	xdc.useModule('ti.csl.Settings');
/* Load the CPPI package */
var Cppi                        =   xdc.loadPackage('ti.drv.cppi');
/* Load the QMSS package */
var Qmss                        =   xdc.loadPackage('ti.drv.qmss');
/* Load the PA package */
var Pa 							= 	xdc.loadPackage('ti.drv.pa');
/* Load the SRIO driver package */
var Srio                        =   xdc.loadPackage('ti.drv.srio');
var System                      =   xdc.useModule('xdc.runtime.System');
var hlink = xdc.useModule('ti.drv.hyplnk.Settings');
/* Use the CSL module and indicate that INTC library will be used. */
SysStd                          =   xdc.useModule('xdc.runtime.SysStd');
var Startup  					=   xdc.useModule('xdc.runtime.Startup');
System.SupportProxy             =   SysStd;
System.extendedFormats = "%f";
/* create other heap in L2sram for GiGi */
var heapMemParams1              =   new HeapMem.Params;
heapMemParams1.size             =   8192 * 30;
heapMemParams1.sectionName      =   "GigiHeap";
//GigEHeap          =   HeapMem.create(heapMemParams1);
Program.global.GigiHeap            =   HeapMem.create(heapMemParams1);
//Default.common$.instanceHeap = heap1;
Program.sectMap["GigiHeap"]   = "L2SRAM"
/* Create a default system heap using ti.bios.HeapMem. */
heapMemParams1.size             =   8016 * 500;
heapMemParams1.sectionName      =   "systemHeap";
Program.global.heap0            =   HeapMem.create(heapMemParams1);
/* This is the default memory heap. */
Memory.defaultHeapInstance      =   Program.global.heap0;
var heapMemParams2              =   new HeapMem.Params;
heapMemParams2.size             =   8192 * 100 ;
heapMemParams2.sectionName      =   "IPCBUFFER";
Program.global.IPCBUFFER        =   HeapMem.create(heapMemParams2);
Program.sectMap["IPCBUFFER"]   =   "MSMCSRAM";
Program.sectMap["payload"] = "MSMCSRAM";
Program.sectMap["Flag"] = "MSMCSRAM";
Program.sectMap["TxDATA"] = "MSMCSRAM";
Program.sectMap["DLCONFIG"] = "MSMCSRAM";
Program.sectMap["TXREQUEST"] = "L2SRAM";
//Program.sectMap["systemHeap"]   =   Program.platform.stackMemory;
/****** IPC - Shared Memory Settings ********/
/* IPC packages */
//Startup.firstFxns.$add('&initPlatform');
var Ipc                         =   xdc.useModule('ti.sdo.ipc.Ipc');
var cslSettings = xdc.useModule ('ti.csl.Settings');
cslSettings.useCSLIntcLib = true;
var cacheEnabled = true;
var cacheLineSize = 128;
var procName = null;
var procNameList = [];
var Settings                =   xdc.module('ti.sdo.ipc.family.Settings');
var Cache             		= xdc.useModule('ti.sysbios.family.c66.Cache');
var MessageQ                = xdc.module('ti.sdo.ipc.MessageQ');
var Notify                  = xdc.module('ti.sdo.ipc.Notify');
//var Ipc                     = xdc.useModule('ti.sdo.ipc.Ipc');
Notify.SetupProxy           = xdc.module(Settings.getNotifySetupDelegate());
MessageQ.SetupTransportProxy= xdc.module(Settings.getMessageQSetupDelegate());
/* Use shared memory IPC */
Notify.SetupProxy           = xdc.module('ti.sdo.ipc.family.c647x.NotifyCircSetup');
MessageQ.SetupTransportProxy = xdc.module('ti.sdo.ipc.transports.TransportShmNotifySetup');
var ListMP                      =   xdc.useModule('ti.sdo.ipc.ListMP');
//var GateMP                      =   xdc.useModule('ti.sdo.ipc.GateMP');
var SharedRegion                =   xdc.useModule('ti.sdo.ipc.SharedRegion');
var HeapMemMP                   =   xdc.useModule('ti.sdo.ipc.heaps.HeapMemMP');
Program.global.NOTIFYSETUP = Notify.SetupProxy.delegate$.$name;
Program.global.TRANSPORTSETUP = MessageQ.SetupTransportProxy.delegate$.$name;
procNameList = ["CORE0","CORE1"];
var MultiProc                   =   xdc.useModule('ti.sdo.utils.MultiProc');
MultiProc.setConfig(null, procNameList);
Program.global.DEVICENAME = Program.cpu.deviceName;
Program.global.PROCNAMES = procNameList.join(",");
Program.global.BUILDPROFILE = Program.build.profile;
SharedRegion.translate = false;
SharedRegion.setEntryMeta(0,
    { base: 0x0c000000,
      len: 0x00010000,
      ownerProcId: 0,
      isValid: true,
      cacheEnable: cacheEnabled,
      cacheLineSize: cacheLineSize,  /* Aligns allocated messages to a cache line */
      createHeap: true,
var memmap = Program.cpu.memoryMap;
//Startup = xdc.useModule('xdc.runtime.Startup');
//Startup.firstFxns.$add('&myStartupFxn');
/* Configure the shared memory heap for shared memory allocations required by the
 * CPPI and QMSS Libraries */
/* Create a shared memory heap */
/* Synchronize all processors (this will be done in Ipc_start) */
Ipc.procSync = Ipc.ProcSync_ALL;
/* Enable BIOS Task Scheduler */
BIOS.taskEnabled = true;
 * Enable Event Groups here and registering of ISR for specific GEM INTC is done
 * using EventCombiner_dispatchPlug() and Hwi_eventMap() APIs
ECM.eventGroupHwiNum[0] = 7;
ECM.eventGroupHwiNum[1] = 8;
ECM.eventGroupHwiNum[2] = 9;
ECM.eventGroupHwiNum[3] = 10;
 *  @(#) ti.sysbios.genx; 2, 0, 0, 0,275; 4-29-2009 15:45:06; /db/vtree/library/trees/avala/avala-k25x/src/
Program.sectMap[".init_array"] = "L2SRAM";
Program.sectMap[".csl_vect"] = "L2SRAM";
Program.stack = 1024*4 + 0x400;
 Program.sectMap[".cinit"] = "MSMCSRAM";
 Program.sectMap[".fardata"] = "L2SRAM";
BIOS.libType = BIOS.LibType_Debug;
BIOS.assertsEnabled = true;
BIOS.logsEnabled = true;
BIOS.rtsGateType = BIOS.GateMutex;
BIOS.clockEnabled = true;
BIOS.customCCOpts = "-mv6600 --abi=eabi -q -mi10 -mo -pdr -pden -pds=238 -pds=880 -pds1110  --program_level_compile -g";
Program.sectMap[".text"] = "MSMCSRAM";
Program.sectMap[".qmss"] = "L2SRAM";
Program.sectMap[".cppi"] = "L2SRAM";
Program.sectMap["const"] = "MSMCSRAM";
Program.sectMap[".Memo"] = "MSMCSRAM";
Program.sectMap[".test"] = "L2SRAM";
BIOS.heapSize = 8192;
/* Optimization stuff */
Diags = xdc.useModule("xdc.runtime.Diags");
var Defaults = xdc.useModule('xdc.runtime.Defaults');
Defaults.common$.logger = null;
HyperlinkIntialize.cpp
 * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * This file contains the prototypes for functions that interface with
 * Hyperlink and the Hyperlink LLD.  They are common among all tests/examples.
#include <string.h>
/* Use regular "printf" when not using BIOS */
//#include <xdc/runtime/System.h>
#define System_printf printf
#include <stdio.h>
#include <ti/drv/hyplnk/hyplnk.h>
#include <ti/csl/csl_bootcfgAux.h>
#include <ti/csl/csl_cacheAux.h>
#include <ti/csl/cslr_device.h>
#include <ti/csl/csl_pscAux.h>
#include <c6x.h>
#include "lib/Hyperlink/include/hyplnkLLDIFace.h"
/* Pick parameters that changed based on loopback (loopback is faster) */
#ifdef hyplnk_EXAMPLE_LOOPBACK
  #define hyplnk_EXAMPLE_ILOOP_BIT 1
  #define hyplnk_EXAMPLE_SYNC_WAIT_LIMIT          hyplnk_EXAMPLE_uS_TO_CYCLES(100000)
#else
  #define hyplnk_EXAMPLE_ILOOP_BIT 0
  #define hyplnk_EXAMPLE_SYNC_WAIT_LIMIT          hyplnk_EXAMPLE_uS_TO_CYCLES( 1000000)
#endif
#define hyplnk_EXAMPLE_WAIT_STABILITY_TIME    hyplnk_EXAMPLE_uS_TO_CYCLES( 5000000)
/* Convert REFCLK_USE_PLATCFG to a refclk */
#ifdef hyplnk_EXAMPLE_REFCLK_USE_PLATCFG
  #if defined(hyplnk_EXAMPLE_REFCLK_156p25) || \
      defined(hyplnk_EXAMPLE_REFCLK_250p00) || \
      defined(hyplnk_EXAMPLE_REFCLK_312p50)
    #error Cannot define a specific REFCLK together with USE_PLATCFG
  #endif
  #if   (hyplnk_EXAMPLE_HYPLNK_REF_KHZ == 312500)
    #define hyplnk_EXAMPLE_REFCLK_312p50
  #elif (hyplnk_EXAMPLE_HYPLNK_REF_KHZ == 250000)
    #define hyplnk_EXAMPLE_REFCLK_250p00
  #elif (hyplnk_EXAMPLE_HYPLNK_REF_KHZ == 156250)
    #define hyplnk_EXAMPLE_REFCLK_156p25
  #else
    #error Unknown value for hyplnk_EXAMPLE_HYPLNK_REF_KHZ
  #endif
#endif
/* Check REFCLK definition */
  #if defined(hyplnk_EXAMPLE_REFCLK_250p00) || \
    #error Exactly one REFCLK must be defined (#1)
  #endif
#elif defined(hyplnk_EXAMPLE_REFCLK_250p00)
    #error Exactly one REFCLK must be defined (#2)
  #endif
#elif defined(hyplnk_EXAMPLE_REFCLK_312p50)
    #error Exactly one REFCLK must be defined (#3)
  #endif
#else
  #error Exactly one REFCLK must be defined (#4)
#endif
/* Check SERRATE definition */
#if defined(hyplnk_EXAMPLE_SERRATE_01p250)
  #if defined(hyplnk_EXAMPLE_SERRATE_03p125) || \
      defined(hyplnk_EXAMPLE_SERRATE_06p250) || \
      defined(hyplnk_EXAMPLE_SERRATE_07p500) || \
      defined(hyplnk_EXAMPLE_SERRATE_10p000) || \
      defined(hyplnk_EXAMPLE_SERRATE_12p500)
    #error Exactly one SERRATE must be defined (#1)
  #endif
#elif defined(hyplnk_EXAMPLE_SERRATE_03p125)
  #if defined(hyplnk_EXAMPLE_SERRATE_01p250) || \
    #error Exactly one SERRATE must be defined (#2)
  #endif
#elif defined(hyplnk_EXAMPLE_SERRATE_06p250)
    #error Exactly one SERRATE must be defined (#3)
  #endif
#elif defined(hyplnk_EXAMPLE_SERRATE_07p500)
    #error Exactly one SERRATE must be defined (#4)
  #endif
#elif defined(hyplnk_EXAMPLE_SERRATE_10p000)
    #error Exactly one SERRATE must be defined (#5)
  #endif
#elif defined(hyplnk_EXAMPLE_SERRATE_12p500)
    #error Exactly one SERRATE must be defined (#6)
  #endif
#else
  #error Exactly one SERRATE must be defined (#7)
#endif
 * These parameters can be changed for SERDES diagnostics
#define hyplnk_EXAMPLE_VUSR_RX_RES      0
#define hyplnk_EXAMPLE_VUSR_RX_TESTPAT  0 /* disabled */
#define hyplnk_EXAMPLE_VUSR_RX_LOOPBACK 0 /* disabled */
#define hyplnk_EXAMPLE_VUSR_TX_RES      0
#define hyplnk_EXAMPLE_VUSR_TX_TESTPAT  0 /* disabled */
#define hyplnk_EXAMPLE_VUSR_TX_LOOPBACK 0 /* disabled */
#define hyplnk_EXAMPLE_VUSR_PLL_RES     0
#define hyplnk_EXAMPLE_VUSR_PLL_LOOPBW  0
 * These parameters should remain fixed.  They are defined by the physical
 * connection between the SERDES and the Hyperlink inside the device
#define hyplnk_EXAMPLE_VUSR_RX_BUSWIDTH 2 /* 20 bits */
#define hyplnk_EXAMPLE_VUSR_RX_ENRX     1 /* enabled */
#define hyplnk_EXAMPLE_VUSR_RX_INVPAIR  0 /* normal */
#define hyplnk_EXAMPLE_VUSR_RX_TERM     1 /* 0.7V */
#define hyplnk_EXAMPLE_VUSR_RX_ALIGN    1 /* comma alignment */
#define hyplnk_EXAMPLE_VUSR_TX_FIRUPT   1 /* tie high */
#define hyplnk_EXAMPLE_VUSR_TX_BUSWIDTH 2 /* 20 bits */
#define hyplnk_EXAMPLE_VUSR_TX_ENTX     1 /* enable */
#define hyplnk_EXAMPLE_VUSR_TX_MSYNC    0 /* filled in by code below */
#define hyplnk_EXAMPLE_VUSR_TX_INVPAIR  0 /* normal */
#define hyplnk_EXAMPLE_VUSR_PLL_ENPLL   0
#define hyplnk_EXAMPLE_VUSR_PLL_SLEEP   0
#define hyplnk_EXAMPLE_VUSR_PLL_CLKBYP  0
 * These parameters do not depend on wire rate or reference clock
#define hyplnk_EXAMPLE_VUSR_RX_ENOC     1 /* compensation enabled */
#define hyplnk_EXAMPLE_VUSR_RX_EQHLD    0 /* adapation allowed (0=on!) */
#define hyplnk_EXAMPLE_VUSR_RX_EQ       1 /* adaptive */
#define hyplnk_EXAMPLE_VUSR_RX_CDR      5 /* clock recovery */
#define hyplnk_EXAMPLE_VUSR_RX_LOS      4 /* enabled */
 * The remaining parameters vary by wire rate and reference clock
 *  #define hyplnk_EXAMPLE_VUSR_RX_RATE
 *  #define hyplnk_EXAMPLE_VUSR_TX_RATE
 *  #define hyplnk_EXAMPLE_VUSR_TX_TWPST1
 *  #define hyplnk_EXAMPLE_VUSR_TX_TWPRE
 *  #define hyplnk_EXAMPLE_VUSR_TX_SWIN
/* Set PLL & SERDES configuration */
  #define hyplnk_EXAMPLE_VUSR_TX_TWPST1   0
  #define hyplnk_EXAMPLE_VUSR_TX_TWPRE    0
  #define hyplnk_EXAMPLE_VUSR_TX_SWING    0xf
  /* 1/8th rate implies MPY/2 below, vrange is 0 since 1.25*2 > 2.17 */
  #define hyplnk_EXAMPLE_VUSR_PLL_VRANGE  0
  #define hyplnk_EXAMPLE_VUSR_RX_RATE     3 /* 1/8th rate */
  #define hyplnk_EXAMPLE_VUSR_TX_RATE     3 /* 1/8th */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY   64  /* MPY in 0.25 units = 16x */
                                              /* 16/2 * 156.25 = 1.25G */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY   40  /* MPY in 0.25 units = 10x */
                                              /* 10/2 * 250 = 1.25G */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY   32  /* MPY in 0.25 units, = 8x */
                                              /* 8/2 * 312.5 = 1.25G */
  #endif
  #define hyplnk_EXAMPLE_VUSR_TX_TWPST1   19
  #define hyplnk_EXAMPLE_VUSR_TX_TWPRE    1
    /* 1/2 rate implies MPY*2 below, vrange is 1 since 3.125*0.5 < 2.17 */
    #define hyplnk_EXAMPLE_VUSR_PLL_VRANGE 1
    #define hyplnk_EXAMPLE_VUSR_RX_RATE    1  /* 1/2th rate */
    #define hyplnk_EXAMPLE_VUSR_TX_RATE    1  /* 1/2th */
                                              /* 10*2 * 156.25 = 3.125G */
    /* 1/4 rate implies MPY*1 below, vrange is 0 since 3.125*1 > 2.17 */
    #define hyplnk_EXAMPLE_VUSR_RX_RATE    2 /* 1/4th rate */
    #define hyplnk_EXAMPLE_VUSR_TX_RATE    2 /* 1/4th */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY    50 /* MPY in 0.25 units = 12.5x */
                                              /* 12.5*1 * 250 = 3.125G */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY    20 /* MPY in 0.25 units = 5x */
                                              /* 5*2 * 312.5 = 3.125G */
  #endif
  #define hyplnk_EXAMPLE_VUSR_TX_TWPST1   19 /* -7.5% */
  #define hyplnk_EXAMPLE_VUSR_TX_TWPRE    0  /* 0% */
  #define hyplnk_EXAMPLE_VUSR_TX_SWING    0x6
    /* full rate implies MPY*4 below, vrange is 1 since 6.25*0.25 < 2.17 */
    #define hyplnk_EXAMPLE_VUSR_RX_RATE    0  /* full rate */
    #define hyplnk_EXAMPLE_VUSR_TX_RATE    0  /* full */
                                              /* 10*4 * 156.25 = 6.25G */
    /* 1/2 rate implies MPY*2 below, vrange is 0 since 6.25*0.5 > 2.17 */
                                              /* 12.5*2 * 250 = 6.25G */
                                              /* 5*4 * 312.5 = 6.25G */
  #endif
  /* full rate implies MPY*4 below, vrange is 1 since 8.125*0.25 < 2.17 */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY    48 /* MPY in 0.25 units = 12x */
                                              /* 12*4 * 156.25 = 7.5G */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY    30 /* MPY in 0.25 units = 7.5x */
                                              /* 7.5*4 * 250 = 7.5G */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY    24 /* MPY in 0.25 units = 6x */
                                              /* 6.5*4 * 312.5 = 7.5G */
  #endif
  #define hyplnk_EXAMPLE_VUSR_TX_TWPST1   20 /* -10% */
  #define hyplnk_EXAMPLE_VUSR_TX_TWPRE    1  /* -10.0% */
  #define hyplnk_EXAMPLE_VUSR_TX_SWING    0x8
  /* full rate implies MPY*4 below, vrange is 0 since 10.0*0.25 > 2.17 */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY    80 /* MPY in 0.25 units = 16x */
                                              /* 16*4 * 156.25 = 10.0G */
                                              /* 10*4 * 250 = 10.0G */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY    32 /* MPY in 0.25 units = 8x */
                                              /* 8*4 * 312.5 = 10.0G */
  #endif
  #define hyplnk_EXAMPLE_VUSR_TX_TWPRE    4  /* -10.0% */
  /* full rate implies MPY*4 below, vrange is 0 since 12.5*0.25 > 2.17 */
    #define hyplnk_EXAMPLE_VUSR_PLL_MPY    80 /* MPY in 0.25 units = 20x */
                                              /* 20*4 * 156.25 = 12.5G */
                                              /* 12.5*4 * 250 = 12.5G */
                                              /* 10*4 * 312.5 = 12.5G */
  #endif
#endif
#define  hyplnk_EXAMPLE_VUSR_PLL                  \
        (hyplnk_EXAMPLE_VUSR_PLL_RES     << 15) | \
        (hyplnk_EXAMPLE_VUSR_PLL_CLKBYP  << 13) | \
        (hyplnk_EXAMPLE_VUSR_PLL_LOOPBW  << 11) | \
        (hyplnk_EXAMPLE_VUSR_PLL_SLEEP   << 10) | \
        (hyplnk_EXAMPLE_VUSR_PLL_VRANGE  <<  9) | \
        (hyplnk_EXAMPLE_VUSR_PLL_MPY     <<  1) | \
        (hyplnk_EXAMPLE_VUSR_PLL_ENPLL   <<  0)
#define  hyplnk_EXAMPLE_VUSR_RX_CONFIG            \
        (hyplnk_EXAMPLE_VUSR_RX_RES      << 28) | \
        (hyplnk_EXAMPLE_VUSR_RX_TESTPAT  << 25) | \
        (hyplnk_EXAMPLE_VUSR_RX_LOOPBACK << 23) | \
        (hyplnk_EXAMPLE_VUSR_RX_ENOC     << 22) | \
        (hyplnk_EXAMPLE_VUSR_RX_EQHLD    << 21) | \
        (hyplnk_EXAMPLE_VUSR_RX_EQ       << 18) | \
        (hyplnk_EXAMPLE_VUSR_RX_CDR      << 15) | \
        (hyplnk_EXAMPLE_VUSR_RX_LOS      << 12) | \
        (hyplnk_EXAMPLE_VUSR_RX_ALIGN    << 10) | \
        (hyplnk_EXAMPLE_VUSR_RX_TERM     <<  7) | \
        (hyplnk_EXAMPLE_VUSR_RX_INVPAIR  <<  6) | \
        (hyplnk_EXAMPLE_VUSR_RX_RATE     <<  4) | \
        (hyplnk_EXAMPLE_VUSR_RX_BUSWIDTH <<  1) | \
        (hyplnk_EXAMPLE_VUSR_RX_ENRX     <<  0)
#define  hyplnk_EXAMPLE_VUSR_TX_CONFIG            \
        (hyplnk_EXAMPLE_VUSR_TX_RES      << 26) | \
        (hyplnk_EXAMPLE_VUSR_TX_TESTPAT  << 23) | \
        (hyplnk_EXAMPLE_VUSR_TX_LOOPBACK << 21) | \
        (hyplnk_EXAMPLE_VUSR_TX_MSYNC    << 20) | \
        (hyplnk_EXAMPLE_VUSR_TX_FIRUPT   << 19) | \
        (hyplnk_EXAMPLE_VUSR_TX_TWPST1   << 14) | \
        (hyplnk_EXAMPLE_VUSR_TX_TWPRE    << 11) | \
        (hyplnk_EXAMPLE_VUSR_TX_SWING    <<  7) | \
        (hyplnk_EXAMPLE_VUSR_TX_INVPAIR  <<  6) | \
        (hyplnk_EXAMPLE_VUSR_TX_RATE     <<  4) | \
        (hyplnk_EXAMPLE_VUSR_TX_BUSWIDTH <<  1) | \
        (hyplnk_EXAMPLE_VUSR_TX_ENTX     <<  0)
#ifdef hyplnk_EXAMPLE_ALLOW_4_LANES
  #define hyplnk_EXAMPLE_MAX_LANES 4
#else
  #define hyplnk_EXAMPLE_MAX_LANES 1
#endif
 * Wait # of CPU cycles (excluding function call and loop entry/exit overhead)
void hyplnkExampleDelay (uint32_t cycles)
  uint32_t now = TSCL;
  while ((TSCL - now) < cycles);
 * Break down and print the revision register.
void hyplnkExamplePrintRevReg (hyplnkRevReg_t *rev) {
#if (hyplnk_EXAMPLE_PRINT_REV_REG >= hyplnk_EXAMPLE_PRINT_RAW)
  System_printf ("Revision register contents:\n"
                 "  Raw    = 0x%08x\n"
#if (hyplnk_EXAMPLE_PRINT_REV_REG >= hyplnk_EXAMPLE_PRINT_DETAILS)
                 "  Scheme = %d\n"
                 "  BU     = %d\n"
                 "  Func   = 0x%04x\n"
                 "  RTL    = %d\n"
                 "  cust   = %d\n"
                 "  revMaj = %d\n"
                 "  revMin = %d\n"
#endif
               , rev->raw
               , rev->scheme,
                 rev->bu,
                 rev->func,
                 rev->rtl,
                 rev->cust,
                 rev->revMaj,
                 rev->revMin
#endif
#endif
 * Break down and print the status register.
void hyplnkExamplePrintStatusReg (hyplnkStatusReg_t *status) {
#if (hyplnk_EXAMPLE_PRINT_STATUS_REG >= hyplnk_EXAMPLE_PRINT_RAW)
  System_printf ("Status register contents:\n"
                 "  Raw        = 0x%08x\n"
#if (hyplnk_EXAMPLE_PRINT_STATUS_REG >= hyplnk_EXAMPLE_PRINT_DETAILS)
                 "  swidthin   = %d\n"
                 "  swidthout  = %d\n"
                 "  serialHalt = %d\n"
                 "  pllUnlock  = %d\n"
                 "  rPend      = %d\n"
                 "  iFlow      = %d\n"
                 "  oFlow      = %d\n"
                 "  rError     = %d\n"
                 "  lError     = %d\n"
                 "  nfEmpty3   = %d\n"
                 "  nfEmpty2   = %d\n"
                 "  nfEmpty1   = %d\n"
                 "  nfEmpty0   = %d\n"
                 "  sPend      = %d\n"
                 "  mPend      = %d\n"
                 "  link       = %d\n"
#endif
               , status->raw
               , status->swidthin,
                 status->swidthout,
                 status->serialHalt,
                 status->pllUnlock,
                 status->rPend,
                 status->iFlow,
                 status->oFlow,
                 status->rError,
                 status->lError,
                 status->nfEmpty3,
                 status->nfEmpty2,
                 status->nfEmpty1,
                 status->nfEmpty0,
                 status->sPend,
                 status->mPend,
                 status->link
#endif
#endif
 * Break down and print the link status register.
void hyplnkExamplePrintLinkStatusReg (hyplnkLinkStatusReg_t *status) {
#if (hyplnk_EXAMPLE_PRINT_LINK_STATUS_REG >= hyplnk_EXAMPLE_PRINT_RAW)
  System_printf ("Link status register contents:\n"
                 "  Raw       = 0x%08x\n"
#if (hyplnk_EXAMPLE_PRINT_LINK_STATUS_REG >= hyplnk_EXAMPLE_PRINT_DETAILS)
                 "  txPlsReq  = %d\n"
                 "  txPlsAck  = %d\n"
                 "  txPmReq   = %d\n"
                 "  txRSync   = %d\n"
                 "  txPlsOK   = %d\n"
                 "  txPhyEn   = %d\n"
                 "  txFlowSts = %d\n"
                 "  rxPlsReq  = %d\n"
                 "  rxPlsAck  = %d\n"
                 "  rxPmReq   = %d\n"
                 "  rxLSync   = %d\n"
                 "  rxPhyEn   = %d\n"
                 "  rxPhyPol  = %d\n"
#endif
               , status->raw
               , status->txPlsReq,
                 status->txPlsAck,
                 status->txPmReq,
                 status->txRSync,
                 status->txPlsOK,
                 status->txPhyEn,
                 status->txFlowSts,
                 status->rxPlsReq,
                 status->rxPlsAck,
                 status->rxPmReq,
                 status->rxLSync,
                 status->rxPhyEn,
                 status->rxPhyPol
#endif
#endif
 * Break down and print the control register.
void hyplnkExamplePrintControlReg (hyplnkControlReg_t *control) {
#if (hyplnk_EXAMPLE_PRINT_CONTROL_REG >= hyplnk_EXAMPLE_PRINT_RAW)
  System_printf ("Control register contents:\n"
                 "  Raw             = 0x%08x\n"
#if (hyplnk_EXAMPLE_PRINT_CONTROL_REG >= hyplnk_EXAMPLE_PRINT_DETAILS)
                 "  intLocal        = %d\n"
                 "  statusIntEnable = %d\n"
                 "  statusIntVec    = %d\n"
                 "  int2cfg         = %d\n"
                 "  serialStop      = %d\n"
                 "  iLoop           = %d\n"
                 "  reset           = %d\n"
#endif
               , control->raw
               , control->intLocal,
                 control->statusIntEnable,
                 control->statusIntVec,
                 control->int2cfg,
                 control->serialStop,
                 control->iLoop,
                 control->reset
#endif
#endif
 * Break down and print the ECC errors register.
void hyplnkExamplePrintECCErrorsReg (hyplnkECCErrorsReg_t *errors) {
#if (hyplnk_EXAMPLE_PRINT_ECC_ERRORS_REG >= hyplnk_EXAMPLE_PRINT_RAW)
                 "  Raw        = 0x%08x\n"
#if (hyplnk_EXAMPLE_PRINT_ECC_ERRORS_REG >= hyplnk_EXAMPLE_PRINT_DETAILS)
                 "  sglErrCor  = %d\n"
                 "  dblErrDet  = %d\n"
#endif
               , errors->raw
               , errors->sglErrCor,
                 errors->dblErrDet
#endif
#endif
void hyplnkExamplePrintOneSerdesStatus (uint32_t sts, int n)
#if (hyplnk_EXAMPLE_SERDES_STS_REGS >= hyplnk_EXAMPLE_PRINT_RAW)
  System_printf ("SERDES_STS%d:\n"
                 "  raw = 0x%08x\n"
#if (hyplnk_EXAMPLE_SERDES_STS_REGS >= hyplnk_EXAMPLE_PRINT_DETAILS)
               , "  Tx Tesfail = %d\n"
                 "  EQover     = %d\n"
                 "  EQunder    = %d\n"
                 "  OCIP       = %d\n"
                 "  Losdtct    = %d\n"
                 "  Sync       = %d\n"
                 "  Rx Tesfail = %d\n"
#endif
               , n,
                 sts
                 (sts >> 6) & 1,
                 (sts >> 5) & 1,
                 (sts >> 4) & 1,
                 (sts >> 3) & 1,
                 (sts >> 2) & 1,
                 (sts >> 1) & 1,
                 (sts >> 0) & 1
#endif
#endif
uint32_t hyplnkExamplePrintSerdesStatus (uint32_t lastStatus)
  uint32_t thisStatus = hBootCfg->STS_VUSR;
  if (thisStatus == lastStatus) {
    return lastStatus;
  System_printf ("SERDES_STS (32 bits) contents: 0x%08x; lock = %d\n", thisStatus, thisStatus & 1);
  hyplnkExamplePrintOneSerdesStatus((thisStatus >> 1) & 0x7F, 0);
  hyplnkExamplePrintOneSerdesStatus((thisStatus >> 8) & 0x7F, 1);
  hyplnkExamplePrintOneSerdesStatus((thisStatus >> 15) & 0x7F, 2);
  hyplnkExamplePrintOneSerdesStatus((thisStatus >> 22) & 0x7F, 3);
  return thisStatus;
 * Place peripheral into reset
hyplnkRet_e hyplnkExampleAssertReset (int val)
  hyplnkControlReg_t control;
  hyplnkRegisters_t  setRegs;
  Hyplnk_Handle      handle = NULL;
  hyplnkRet_e        retVal;
  memset (&setRegs, 0, sizeof(setRegs));
  setRegs.control        = &control;
  if ((retVal = Hyplnk_open(0, &handle)) != hyplnk_RET_OK) {
    System_printf ("Open failed\n");
    return retVal;
  if ((retVal = Hyplnk_readRegs (handle, hyplnk_LOCATION_LOCAL, &setRegs)) != hyplnk_RET_OK) {
    System_printf ("Read failed!\n");
    return retVal;
  control.reset = val;
  if ((retVal = Hyplnk_writeRegs (handle, hyplnk_LOCATION_LOCAL, &setRegs)) != hyplnk_RET_OK) {
    System_printf ("Write failed!\n");
    return retVal;
  if ((retVal = Hyplnk_close (&handle)) != hyplnk_RET_OK) {
    System_printf ("close failed!\n");
    return retVal;
  return hyplnk_RET_OK;
 * Sets the SERDES configuration registers
void hyplnkExampleSerdesCfg (uint32_t rx, uint32_t tx)
  CSL_BootCfgUnlockKicker();
  CSL_BootCfgSetVUSRRxConfig (0, rx);
  CSL_BootCfgSetVUSRRxConfig (1, rx);
  CSL_BootCfgSetVUSRRxConfig (2, rx);
  CSL_BootCfgSetVUSRRxConfig (3, rx);
  CSL_BootCfgSetVUSRTxConfig (0, tx);
  CSL_BootCfgSetVUSRTxConfig (1, tx);
  CSL_BootCfgSetVUSRTxConfig (2, tx);
  CSL_BootCfgSetVUSRTxConfig (3, tx);
  CSL_BootCfgLockKicker();
} /* hyplnkExampleSerdesCfg */
 * Performs some of the system setup (HyperLink parameters outside of the
 * HyperLink block).
 * The HyperLink power domain is enabled, and the SERDES configuration
 * registers are programmed per the clock configuration (input=312.5 mhz).
 * The system PLL is not touched (but could be).
hyplnkRet_e hyplnkExampleSysSetup (void)
  /* The system PLLs are set up via the gel file described in the comments
   * at the header of this file.
#if (defined(CSL_PSC_PD_HYPERBRIDGE) && defined(CSL_PSC_LPSC_HYPERBRIDGE))
	printf("!");
  /* Turn on the Hyperlink power domain */
  if (CSL_PSC_getPowerDomainState (CSL_PSC_PD_HYPERBRIDGE) != PSC_PDSTATE_ON) {
    /* Enable the domain */printf("1");
    CSL_PSC_enablePowerDomain (CSL_PSC_PD_HYPERBRIDGE);
    /* Enable MDCTL */printf("2");
    CSL_PSC_setModuleNextState (CSL_PSC_LPSC_HYPERBRIDGE, PSC_MODSTATE_ENABLE);
    /* Apply the domain */printf("3");
    CSL_PSC_startStateTransition (CSL_PSC_PD_HYPERBRIDGE);
    /* Wait for it to finish */printf("4");
    while (! CSL_PSC_isStateTransitionDone (CSL_PSC_PD_HYPERBRIDGE));
  } else {
    System_printf ("Power domain is already enabled.  You probably re-ran without device reset (which is OK)\n");
#endif
  hyplnkExampleAssertReset (1);
  /* Set up the HyperLink (vUSR) related portions of the boot config registers */
  CSL_BootCfgSetVUSRConfigPLL (hyplnk_EXAMPLE_VUSR_PLL);
  while (((*(volatile unsigned int *)0x2620160) & 1) == 0);
  hyplnkExampleSerdesCfg (hyplnk_EXAMPLE_VUSR_RX_CONFIG, hyplnk_EXAMPLE_VUSR_TX_CONFIG);
  printf("Constructed SERDES configs: PLL=0x%08x; RX=0x%08x; TX=0x%08x\n",
         hyplnk_EXAMPLE_VUSR_PLL,
#ifdef hyplnk_EXAMPLE_EQ_ANALYSIS
 * These functions performe equalization analysis on each lane.
 * This will analyze the precursor (TX_TWPRE) and postcursor (TX_TWPST1) as
 * seen by the receiver on this side of the connection.  For each lane and
 * each coefficient, it will print out whether the coefficient is too large
 * and/or too small.
 * The analysis can be run several times with the same configuration in
 * order to decide if the configuration is optimal.  When adjusting the
 * coefficients, remember that the transmitter (other device) is being
 * analyzed by this device.
 * The result will be 4 ordered pairs, one ordered pair per lane.
 * The first digit in the pair is whether the coefficient is too big;
 * the second digit is whether it is too small.  It is possible to get
 * both 0 or both 1s.
void hyplnkExampleEQLaneAnalysis (uint32_t lane, uint32_t status)
  if (lane) {
    System_printf(",");
  System_printf ("%d,%d", (status >> 5) & 1, (status >> 4) & 1);
} /* hyplnkExampleEQLaneAnalysis */
void hyplnkExampleEQAnalysisOneEq (int precursor)
  uint32_t eqVal;
  uint32_t thisStatus;
  eqVal = precursor ? 2 : 3;
  /* EQHLD is set to 0 and EQ is set to 1 */
  /* Set EQHLD to 1 and wait at least 48UI */
#undef hyplnk_EXAMPLE_VUSR_RX_EQHLD
#define hyplnk_EXAMPLE_VUSR_RX_EQHLD  1
  hyplnkExampleDelay (1000);
  /* Set EQHLD to 0 and EQ to eqVal (to select pre (2) or post (3) cursor) and wait 150K UI */
#define hyplnk_EXAMPLE_VUSR_RX_EQ     0
  /* EQ is set to 0, the eqVal is added in below */
  hyplnkExampleSerdesCfg (hyplnk_EXAMPLE_VUSR_RX_CONFIG | (eqVal << 18),
  hyplnkExampleDelay (1000000);
  /* Set EQHLD to 1 */
  /* Set EQ to 1 and EQHLD to 0 */
  if (precursor) {
    System_printf ("Precursors %d ", hyplnk_EXAMPLE_VUSR_TX_TWPRE);
  } else {
    System_printf ("Postcursors: %d ", hyplnk_EXAMPLE_VUSR_TX_TWPST1);
  System_printf ("Analysis: ");
  hyplnkExampleEQLaneAnalysis (0, (thisStatus >> 1) & 0x7f);
  hyplnkExampleEQLaneAnalysis (1, (thisStatus >> 8) & 0x7f);
  hyplnkExampleEQLaneAnalysis (2, (thisStatus >> 15) & 0x7f);
  hyplnkExampleEQLaneAnalysis (3, (thisStatus >> 22) & 0x7f);
  System_printf ("\n");
} /* hyplnkExampleEQAnalysisOneEq */
void hyplnkExampleEQAnalysis (void)
  hyplnkExampleEQAnalysisOneEq (1);
  hyplnkExampleEQAnalysisOneEq (0);
} /* hyplnkExampleEQAnalysis */
#endif /* hyplnk_EXAMPLE_EQ_ANALYSIS */
 * Forcibly reset the peripheral, and place it into loopback.  The
 * reset protocol is not performed, so pending transactions could leave
 * either device in a bad state.  Therefore it is assumed there are
 * no such transactions.
hyplnkRet_e hyplnkExamplePeriphSetup (void)
  hyplnkRevReg_t            rev;
  hyplnkStatusReg_t         status;
  hyplnkLinkStatusReg_t     linkStatus;
  hyplnkECCErrorsReg_t      ECCErrors;
  hyplnkLanePwrMgmtReg_t    lanePwrMgmt;
  hyplnkSERDESControl1Reg_t serdesControl1;
  hyplnkRegisters_t getRegs;
  uint64_t wait_start, time_waited;
#ifndef hyplnk_EXAMPLE_LOOPBACK
  int retryCount = 0;
#endif
  uint32_t lastSerdesSTS = 0;
  hyplnkRet_e retVal;
  /* To prove the APIs work -- expose uninitialized variables */
  memset (&rev,            0xff, sizeof(rev));
  memset (&control,        0xff, sizeof(control));
  memset (&status,         0xff, sizeof(status));
  memset (&linkStatus,     0xff, sizeof(linkStatus));
  memset (&ECCErrors,      0xff, sizeof(ECCErrors));
  memset (&lanePwrMgmt,    0xff, sizeof(lanePwrMgmt));
  memset (&serdesControl1, 0xff, sizeof(serdesControl1));
  /* Will always write these regs when writing */
  setRegs.status         = &status;
  setRegs.ECCErrors      = &ECCErrors;
  setRegs.lanePwrMgmt    = &lanePwrMgmt;
  setRegs.serdesControl1 = &serdesControl1;
  /* Will always read these regs when reading */
  memset (&getRegs, 0, sizeof(getRegs));
  getRegs.control        = &control;
  getRegs.rev            = &rev;
  getRegs.status         = &status;
  getRegs.linkStatus     = &linkStatus;
  getRegs.lanePwrMgmt    = &lanePwrMgmt;
  getRegs.ECCErrors      = &ECCErrors;
  getRegs.serdesControl1 = &serdesControl1;
    return retVal;
  /* Read rev and control */
  if ((retVal = Hyplnk_readRegs (handle, hyplnk_LOCATION_LOCAL, &getRegs)) != hyplnk_RET_OK) {
    System_printf ("Read revision register failed!\n");
    return retVal;
  System_printf ("============== begin registers before initialization ===========\n");
  hyplnkExamplePrintRevReg(&rev);
  hyplnkExamplePrintStatusReg(&status);
  hyplnkExamplePrintLinkStatusReg(&linkStatus);
  hyplnkExamplePrintControlReg(&control);
  hyplnkExamplePrintECCErrorsReg(&ECCErrors);
  System_printf ("============== end registers before initialization ===========\n");
  if ((rev.revMaj == 0) && (rev.revMin == 0)) {
    System_printf ("The revision register seems to be invalid.  This example doesn't run on the simulator\n");
    exit(1);
  /* Reset the peripheral */
  control.reset       = 1;
  status.lError       = 1; /* Clear any error */
  status.rError       = 1; /* Clear any error */
  ECCErrors.sglErrCor = 0;
  ECCErrors.dblErrDet = 0;
  /* Force single lane operation */
#ifdef hyplnk_EXAMPLE_ALLOW_1_LANE
  lanePwrMgmt.singleLane = 1;
#else
  lanePwrMgmt.singleLane = 0;
#endif
#ifdef hyplnk_EXAMPLE_ALLOW_0_LANES
  lanePwrMgmt.zeroLane   = 1;
#else
  lanePwrMgmt.zeroLane   = 0;
#endif
  lanePwrMgmt.quadLane   = 1;
#else
  lanePwrMgmt.quadLane   = 0;
#endif
#if !defined(hyplnk_EXAMPLE_ALLOW_4_LANES) && !defined(hyplnk_EXAMPLE_ALLOW_1_LANE)
#error Must allow 1, 4, or 1 and 4 lanes.
#endif
#ifdef hyplnk_EXAMPLE_ASYNC_CLOCKS
  serdesControl1.sleepCnt   = 0xff;
  serdesControl1.disableCnt = 0xff;
#endif
    System_printf ("Control register write failed!\n");
    return retVal;
  /* Don't need to clear any more status bits */
  setRegs.status         = NULL;
  setRegs.ECCErrors      = NULL;
  setRegs.lanePwrMgmt    = NULL;
  setRegs.serdesControl1 = NULL;
  /* Take out of reset loopback */
  control.reset           = 0;
  control.statusIntEnable = 1; /* enable interrupt on lerror or rerror */
  control.intLocal        = 1;
  control.statusIntVec    = hyplnk_EXAMPLE_ISRNUM_FATAL;
  control.iLoop           = hyplnk_EXAMPLE_ILOOP_BIT;
    return retVal;
  /* Don't care about rev reg any more */
  getRegs.rev            = NULL;
  getRegs.serdesControl1 = NULL;
  /* Wait for peripheral to come up */
  wait_start = hyplnkExampleReadTime();
  do {
      System_printf ("Read status failed!\n");
      return retVal;
    time_waited = (hyplnkExampleReadTime() - wait_start);
    if ((! time_waited) || (time_waited > hyplnk_EXAMPLE_SYNC_WAIT_LIMIT)) {
      System_printf ("Waited too long (FAIL)\n");
      exit(1);
#else
      System_printf ("Waiting for other side to come up (%8d)\n", retryCount);
      retryCount++;
      lastSerdesSTS = hyplnkExamplePrintSerdesStatus (lastSerdesSTS);
#endif
  } while ((!status.link) || (status.serialHalt) || (status.pllUnlock));
  hyplnkExampleCheckOneStat (hyplnk_LOCATION_LOCAL, "immediately after link up", 0);
  System_printf ("============== begin registers after initialization ===========\n");
  System_printf ("============== end registers after initialization ===========\n");
  System_printf ("Waiting 5 seconds to check link stability\n");
  hyplnkExampleCheckOneStat (hyplnk_LOCATION_LOCAL, "before stability wait", 0);
  while ((hyplnkExampleReadTime() - wait_start) < (uint64_t)hyplnk_EXAMPLE_WAIT_STABILITY_TIME);
  hyplnkExampleCheckOneStat (hyplnk_LOCATION_LOCAL, "before eq analysis", 0);
  hyplnkExampleEQAnalysis();
#endif
  hyplnkExampleCheckOneStat (hyplnk_LOCATION_LOCAL, "after stability wait", 0);
  System_printf ("Link seems stable\n");
  System_printf("About to try to read remote registers\n");
  printf("111\n");
  hyplnkExampleCheckOneStat (hyplnk_LOCATION_REMOTE, "after stability wait", 0);
  /* Get the remote registers */
  printf("222\n");
  if ((retVal = Hyplnk_readRegs (handle, hyplnk_LOCATION_REMOTE, &getRegs)) != hyplnk_RET_OK) {
    System_printf ("REMOTE Read status failed!\n");
    return retVal;
  System_printf ("============== begin REMOTE registers after initialization ===========\n");
  System_printf ("============== end REMOTE registers after initialization ===========\n");
    return retVal;
 * Program the memory map registers so the dataBuffer can be
 * seen through HyperLink
hyplnkRet_e hyplnkExampleAddrMap (void *dataBuffer, void **dataBufferViaHlink)
  hyplnkRet_e retVal;
  hyplnkTXAddrOvlyReg_t TXAddrOvly;
  hyplnkRXAddrSelReg_t  RXAddrSel;
  hyplnkRXPrivIDTbl_t   RXPrivIDs;
  hyplnkRXSegTbl_t      RXSegs;
  hyplnkRegisters_t     localRegs;
  hyplnkRegisters_t     remoteRegs;
  uint32_t globalAddr = (uint32_t)dataBuffer;
  uint32_t globalAddrBase, globalAddrOffset;
  int i;
  void *hlinkBase;
  memset (&TXAddrOvly, 0, sizeof(TXAddrOvly));
  memset (&RXAddrSel,  0, sizeof(RXAddrSel));
  memset (&RXPrivIDs,  0, sizeof(RXPrivIDs));
  memset (&RXSegs,     0, sizeof(RXSegs));
  memset (&localRegs,  0, sizeof(localRegs));
  memset (&remoteRegs, 0, sizeof(remoteRegs));
  localRegs.TXAddrOvly   = &TXAddrOvly;
  remoteRegs.RXAddrSel   = &RXAddrSel;
  remoteRegs.RXSegTbl    = &RXSegs;
  remoteRegs.RXPrivIDTbl = &RXPrivIDs;
    return retVal;
  /* This is "my side" */
  TXAddrOvly.txSecOvl    = 0;  /* Ignore the secure bit */
  TXAddrOvly.txPrivIDOvl = 12; /* Put privid in the MS 4 bits of address */
  TXAddrOvly.txIgnMask   = 11; /* Open whole 256MB window */
  /* This is the "other side" (but it is me, because of loopback) */
  RXAddrSel.rxSecHi     = 0; /* Don't care about secure */
  RXAddrSel.rxSecLo     = 0; /* Don't care about secure */
  RXAddrSel.rxSecSel    = 0; /* Don't care about secure */
  RXAddrSel.rxPrivIDSel = 12; /* Symmetric with TXAddrOvly.txPrivIDOvl */
  RXAddrSel.rxSegSel    = 6;  /* Make segments of 4MB each */
  /* Make PrivID transparent */
  for (i = 0; i < hyplnk_RX_PRIVID_TBL_ENTS; i++) {
    RXPrivIDs[i].rxPrivIDVal = i;
  /* Make one segment which can see dataBuffer */
  if ((globalAddr >= 0x800000) && (globalAddr < 0xa00000)) {
    /* Address is in L2 */
    globalAddr |= 0x10000000 | (DNUM << 24);
  } else {
    System_printf ("Don't know how to make global address for 0x%08x\n", globalAddr);
  /* Align to 4MB */
  globalAddrOffset = globalAddr &  0x3fffff;//The 22 LSBs of the corresponding global address of &dataBuffer
  System_printf("\nGlobal Address Offset = %x", globalAddrOffset);//- THIS MASK WILL CHANGE BASED ON SEGMENT SIZE
  globalAddrBase   = globalAddr & ~0x3fffff;//The remaining digits - THIS MASK WILL CHANGE BASED ON SEGMENT SIZE
  RXSegs[0].rxSegVal = (globalAddrBase >> 16); /* 4MB */ //LUTs - constant 16 bit shift....
  System_printf("\nRxSegVal = %x\n", RXSegs[0].rxSegVal);
  RXSegs[0].rxLenVal = 21; /* 4MB */
  if ((retVal = Hyplnk_getWindow (handle, &hlinkBase, NULL)) != hyplnk_RET_OK) {
    System_printf ("getWindow failed\n");
    return retVal;
  *dataBufferViaHlink = (void *)( (char *)hlinkBase + globalAddrOffset);
  System_printf("\nhlinkbase = %x\n", hlinkBase);
  System_printf("\nAddress in AddrMap function = %x\n", *dataBufferViaHlink);
//THIS IS WHERE WE LOAD THE CONFIGURATIONS INTO THE NECESSARY Tx AND Rx REGISTERS
  if ((retVal = Hyplnk_writeRegs (handle, hyplnk_LOCATION_LOCAL, &localRegs)) != hyplnk_RET_OK) {
    System_printf ("Local register write failed!\n");
    return retVal;
  if ((retVal = Hyplnk_writeRegs (handle, hyplnk_LOCATION_REMOTE, &remoteRegs)) != hyplnk_RET_OK) {
    System_printf ("Remote register write failed!\n");
    return retVal;
    return retVal;
 * Make sure there are no errors on the serial link on one side
void hyplnkExampleCheckOneStat (hyplnkLocation_e  location,
                                const char       *name,
                                int               noWarn)
  int                       pass = 1;
  hyplnkRegisters_t         regs;
  const char               *locStr;
  static uint32_t           lastRemoteCor = 0, lastLocalCor = 0;
  uint32_t                 *lastCor;
  memset(&regs, 0, sizeof(regs));
  regs.ECCErrors = &ECCErrors;
  regs.status    = &status;
  if (location == hyplnk_LOCATION_LOCAL) {
    locStr  = "Local";
    lastCor = &lastLocalCor;
  } else {
    locStr  = "Remote";
    lastCor = &lastRemoteCor;
  if (Hyplnk_open(0, &handle) != hyplnk_RET_OK) {
    exit(1);
  if (Hyplnk_readRegs (handle, location, &regs) != hyplnk_RET_OK) {
    System_printf ("%s read for %s failed!\n", locStr, name);
    exit(1);
  if (Hyplnk_close (&handle) != hyplnk_RET_OK) {
    exit(1);
  if (status.lError) {
    System_printf ("%s %s status.lError = %d\n",
                   locStr, name, status.lError);
    pass = 0;
  if (status.rError) {
    System_printf ("%s %s status.rError = %d\n",
                   locStr, name, status.rError);
    pass = 0;
  if (status.pllUnlock) {
    System_printf ("%s %s status.pllUnlock = %d\n",
                   locStr, name, status.pllUnlock);
    pass = 0;
  if (ECCErrors.sglErrCor != *lastCor) {
    if (! noWarn) {
      System_printf ("%s %s WARNING: ECCErrors.sglErrCor = %d\n",
                     locStr, name, ECCErrors.sglErrCor);
      *lastCor = ECCErrors.sglErrCor;
  if (ECCErrors.dblErrDet) {
    System_printf ("%s %s ECCErrors.dblErrDet = %d\n",
                   locStr, name, ECCErrors.dblErrDet);
    pass = 0;
  if (! pass) {
    exit(1);
} /* hyplnkExampleCheckOneStat */
/* Nothing past this point */
    For my understanding, both GIGE and HYPERLINK are try to accessing the same memory region on your application code.
    Have you using IPC for both GIGE and HYPERLINK? Have you validated the each peripheral transfer separately?
    Prove your DSP part number, we will try to reproduce your issue.
  • Hi Ganapathi ,
    I too was suspecting the shared region conflict !
    Is it possible to create two different shared region for each module separately ? If yes, where to set the shared region starting address info in the hyperlink module ???
    Yes am using IPC , as i said earlier both Gige and Hyperlink works independently.
    am using TMS320c6678 EVM .
    regards ,
    vinodh
    If you want to maintain the memory for both peripherals, you can create separate memory entry via platform editing in CCS and then use that new memory entry in *.cfg file.
    To open/edit platform file.
    Go to debug mode -> Tools -> RTSC Tools -> Platform -> Edit/View -> Now give the location path where you have project platform
    Now, create new memory entry with any conflict.
