DM3730 Android 4.1.2 UBIFS file system NAND booting problem
Other Parts Discussed in Thread: DM3730
I'm facing a large problem with my custom board using DM3730 processors and Micron NAND Flash MT29C4G96MAZBACJG.
I've ported android 4.1.2 into my board and it's ok for first time booting.
When i plug out the power supply and plug in again for times, my board has a proble with UBIFS file system and it cannot boot into Android anymore.
[ 35.600769] UBIFS error (pid 1333): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[ 35.610504] UBIFS error (pid 1333): ubifs_check_node: bad node at LEB 934:108088
[ 35.618286] UBIFS error (pid 1333): ubifs_read_node: expected node type 1
[ 35.625427] UBIFS error (pid 1333): do_readpage: cannot read page 601 of inode 1108, error -117
[ 35.939941] UBIFS error (pid 1333): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[ 35.949615] UBIFS error (pid 1333): ubifs_check_node: bad node at LEB 934:108088
[ 35.957397] UBIFS error (pid 1333): ubifs_read_node: expected node type 1
[ 35.964538] UBIFS error (pid 1333): do_readpage: cannot read page 601 of inode 1108, error -117
[ 36.588500] UBIFS error (pid 1333): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[ 36.598236] UBIFS error (pid 1333): ubifs_check_node: bad node at LEB 934:108088
[ 36.606018] UBIFS error (pid 1333): ubifs_read_node: expected node type 1
[ 36.613128] UBIFS error (pid 1333): do_readpage: cannot read page 601 of inode 1108, error -117
[ 36.626770] request_suspend_state: wakeup (0->0) at 36835479739 (2000-01-01 00:00:31.732086183 UTC)
Anyone has this problem? Any solutions for this?
You can read the attached file for more details about booting log.
U-Boot 2010.06-dirty (May 07 2015 - 10:05:08)
OMAP34xx/35xx-GP ES2.1, CPU-OPP2 L3-165MHz
OMAP3 Panther board + LPDDR/NAND
I2C:   ready
DRAM:  512 MiB
NAND:  HW ECC [Kernel/FS layout] selected
512 MiB
In:    serial
Out:   serial
Err:   serial
Panther Rev A
Die ID #7b6000029ff80000015913d80201c007
Hit any key to stop autoboot:  0
Booting from nand ...
NAND read: device 0 offset 0x280000, size 0x35d000
 3526656 bytes read: OK
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-2.6.37
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3526140 Bytes = 3.4 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Linux version 2.6.37 (gcc version 4.4.3 (GCC) ) #140 Mon May 25 17:18:42 ICT 2015
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: OMAP3 Panther Board
[    0.000000] Reserving 8388608 bytes SDRAM for VRAM
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] OMAP3630 ES1.2 (l2cache iva sgx neon isp 192mhz_clk )
[    0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 128000
[    0.000000] Kernel command line: init=/init console=ttyO2,115200n8 noinitrd ip=off androidboot.console=ttyO2 rootwait M
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 504MB = 504MB total
[    0.000000] Memory: 503576k/503576k available, 20712k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
[    0.000000]     vmalloc : 0xe0800000 - 0xf8000000   ( 376 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .init : 0xc0008000 - 0xc0043000   ( 236 kB)
[    0.000000]       .text : 0xc0043000 - 0xc06aa000   (6556 kB)
[    0.000000]       .data : 0xc06aa000 - 0xc0702f20   ( 356 kB)
[    0.000000] NR_IRQS:409
[    0.000000] Clocking rate (Crystal/Core/MPU): 26.0/400/600 MHz
[    0.000000] Reprogramming SDRC clock to 400000000 Hz
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[    0.000000] Total of 96 interrupts on 1 active controller
[    0.000000] GPMC revision 5.0
[    0.000000] Trying to install interrupt handler for IRQ402
[    0.000000] Trying to install interrupt handler for IRQ403
[    0.000000] Trying to install interrupt handler for IRQ404
[    0.000000] Trying to install interrupt handler for IRQ405
[    0.000000] Trying to install interrupt handler for IRQ406
[    0.000000] Trying to install interrupt handler for IRQ407
[    0.000000] Trying to install interrupt handler for IRQ408
[    0.000000] Trying to install type control for IRQ409
[    0.000000] Trying to set irq flags for IRQ409
[    0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[    0.000000] Console: colour dummy device 80x30
[    0.000000] Calibrating delay loop... 597.64 BogoMIPS (lpj=2334720)
[    0.000000] pid_max: default: 32768 minimum: 301
[    0.000000] Security Framework initialized
[    0.000000] Mount-cache hash table entries: 512
[    0.000000] CPU: Testing write buffer coherency: ok
[    0.000000] regulator: core version 0.5
[    0.000000] regulator: dummy:
[    0.000000] NET: Registered protocol family 16
[    0.000000] OMAP GPIO hardware version 2.5
[    0.000000] omap_mux_init: Add partition: #1: core, flags: 0
[    0.000000] Found NAND on CS0
[    0.000000] Registering NAND on CS0
[    0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.000000] OMAP DMA hardware revision 5.0
[    0.030242] bio: create slab <bio-0> at 0
[    0.031555] regulator: vwl1271: 1800 mV
[    0.033172] SCSI subsystem initialized
[    0.035888] usbcore: registered new interface driver usbfs
[    0.036102] usbcore: registered new interface driver hub
[    0.036346] usbcore: registered new device driver usb
[    0.037628] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
[    0.050933] twl4030: PIH (irq 7) chaining IRQs 368..375
[    0.050964] twl4030: power (irq 373) chaining IRQs 376..383
[    0.051574] twl4030: gpio (irq 368) chaining IRQs 384..401
[    0.055541] regulator: VUSB1V5: 1500 mV normal standby
[    0.056182] regulator: VUSB1V8: 1800 mV normal standby
[    0.056854] regulator: VUSB3V1: 3100 mV normal standby
[    0.060180] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[    0.061737] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
[    0.062438] regulator: VDAC: 1800 mV normal standby
[    0.063110] regulator: VDVI: 1800 mV normal standby
[    0.063842] regulator: VAUX3: 2800 mV normal standby
[    0.064575] regulator: VAUX4: 1800 mV normal standby
[    0.064819] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[    0.076812] omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
[    0.078704] Advanced Linux Sound Architecture Driver Version 1.0.23.
[    0.079559] Bluetooth: Core ver 2.15
[    0.079772] NET: Registered protocol family 31
[    0.079803] Bluetooth: HCI device and connection manager initialized
[    0.079803] Bluetooth: HCI socket layer initialized
[    0.080291] Switching to clocksource 32k_counter
[    0.106994] musb-hdrc: version 6.0, otg (peripheral+host), debug=0
[    0.107147] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[    0.107482] musb-hdrc musb-hdrc.0: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[    0.108062] NET: Registered protocol family 2
[    0.108245] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.108673] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.109039] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[    0.109252] TCP: Hash tables configured (established 16384 bind 16384)
[    0.109252] TCP reno registered
[    0.109283] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.109313] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.109497] NET: Registered protocol family 1
[    0.109863] RPC: Registered udp transport module.
[    0.109893] RPC: Registered tcp transport module.
[    0.109893] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.110107] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.111663] omap-iommu omap-iommu.0: isp registered
[    0.274078] ashmem: initialized
[    0.274566] VFS: Disk quotas dquot_6.5.2
[    0.274658] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.275665] JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.276397] msgmni has been set to 983
[    0.278045] io scheduler noop registered
[    0.278076] io scheduler deadline registered
[    0.278198] io scheduler cfq registered (default)
[    0.338470] OMAP DSS rev 2.0
[    0.338562] OMAP DISPC rev 3.0
[    0.338592] OMAP VENC rev 2
[    0.338928] OMAP DSI rev 1.0
[    0.667694] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.669738] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[    0.670135] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[    0.670532] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[    1.348632] console [ttyO2] enabled
[    1.352691] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
[    1.372192] brd: module loaded
[    1.381103] loop: module loaded
[    1.384735] (stk) :sysfs entries created
[    1.388916] (stk) : debugfs entries created
[    1.393493] 3-0018 supply Vdd not found, using dummy regulator
[    1.399810] 3-0018 supply Vdd_IO not found, using dummy regulator
[    1.426666] lis3lv02d: unknown sensor type 0x87
[    1.431457] lis3lv02d_i2c: probe of 3-0018 failed with error -22
[    1.440429] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.447204] omap2-nand driver initializing
[    1.451904] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron )
[    1.458892] Creating 5 MTD partitions on "omap2-nand.0":
[    1.464477] 0x000000000000-0x000000080000 : "X-Loader"
[    1.471954] 0x000000080000-0x0000001c0000 : "U-Boot"
[    1.479370] 0x0000001c0000-0x000000280000 : "U-Boot Env"
[    1.486816] 0x000000280000-0x000000780000 : "Kernel"
[    1.495697] 0x000000780000-0x000020000000 : "File System"
[    1.712493] OneNAND driver initializing
[    1.717376] UBI: attaching mtd4 to ubi0
[    1.721435] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    1.728027] UBI: logical eraseblock size:    126976 bytes
[    1.733703] UBI: smallest flash I/O unit:    2048
[    1.738647] UBI: sub-page size:              512
[    1.743469] UBI: VID header offset:          2048 (aligned 2048)
[    1.749786] UBI: data offset:                4096
[    3.248077] UBI: max. sequence number:       281
[    3.265502] UBI: attached mtd4 to ubi0
[    3.269500] UBI: MTD device name:            "File System"
[    3.275238] UBI: MTD device size:            504 MiB
[    3.280487] UBI: number of good PEBs:        4036
[    3.285430] UBI: number of bad PEBs:         0
[    3.290069] UBI: number of corrupted PEBs:   0
[    3.294738] UBI: max. allowed volumes:       128
[    3.299591] UBI: wear-leveling threshold:    4096
[    3.304504] UBI: number of internal volumes: 1
[    3.309173] UBI: number of user volumes:     1
[    3.313842] UBI: available PEBs:             0
[    3.318511] UBI: total number of reserved PEBs: 4036
[    3.323730] UBI: number of PEBs reserved for bad PEB handling: 40
[    3.330108] UBI: max/mean erase counter: 2/0
[    3.334594] UBI: image sequence number:  2050109733
[    3.339813] UBI: background thread "ubi_bgt0d" started, PID 587
[    3.347137] PPP generic driver version 2.4.2
[    3.352142] PPP Deflate Compression module registered
[    3.357482] PPP BSD Compression module registered
[    3.363067] usbcore: registered new interface driver asix
[    3.368927] usbcore: registered new interface driver cdc_ether
[    3.375274] usbcore: registered new interface driver smsc95xx
[    3.381500] usbcore: registered new interface driver net1080
[    3.387664] usbcore: registered new interface driver cdc_subset
[    3.394073] usbcore: registered new interface driver zaurus
[    3.400482] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.407440] ehci-omap.0 supply hsusb1 not found, using dummy regulator
[    4.416381] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[    4.422912] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[    4.430816] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[    4.447723] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[    4.453826] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.460968] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.468566] usb usb1: Product: OMAP-EHCI Host Controller
[    4.474151] usb usb1: Manufacturer: Linux 2.6.37 ehci_hcd
[    4.479827] usb usb1: SerialNumber: ehci-omap.0
[    4.485534] hub 1-0:1.0: USB hub found
[    4.489532] hub 1-0:1.0: 3 ports detected
[    4.518493] usbcore: registered new interface driver cdc_acm
[    4.524444] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.533416] Initializing USB Mass Storage driver...
[    4.538818] usbcore: registered new interface driver usb-storage
[    4.545135] USB Mass Storage support registered.
[    4.550445] usbcore: registered new interface driver usbserial
[    4.556549] usbserial: USB Serial Driver core
[    4.561309] USB Serial support registered for GSM modem (1-port)
[    4.567932] usbcore: registered new interface driver option
[    4.573791] option: v0.7.2:USB Driver for GSM modems
[    4.579010] android init
[    4.581756] android_probe pdata: c06ba7c8
[    4.586151] android_bind
[    4.589569] android_usb gadget: android_usb ready
[    4.594512] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    4.600555] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[    4.608459] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.615600] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.623168] usb usb2: Product: MUSB HDRC host driver
[    4.628387] usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
[    4.634063] usb usb2: SerialNumber: musb-hdrc.0
[    4.639709] hub 2-0:1.0: USB hub found
[    4.643707] hub 2-0:1.0: 1 port detected
[    4.648315] f_adb init
[    4.650817] android_register_function adb
[    4.655029] f_mass_storage init
[    4.658386] fsg_probe pdev: c06ba490, pdata: c06ba820
[    4.663909] android_register_function usb_mass_storage
[    4.669311] adb_bind_config
[    4.673278] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    4.680541] android_usb gadget: Number of LUNs=1
[    4.685394]  lun0: LUN: removable file: (no medium)
[    4.691406] mice: PS/2 mouse device common for all mice
[    4.697601] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.706970] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[    4.720123] using rtc device, twl_rtc, for alarms
[    4.724975] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[    4.731811] twl_rtc twl_rtc: Power up reset detected.
[    4.737487] twl_rtc twl_rtc: Enabling TWL-RTC.
[    4.742614] i2c /dev entries driver
[    4.747924] Linux media interface: v0.10
[    4.752227] Linux video capture interface: v2.00
[    4.757629] omap3isp supply VDD_CSIPHY1 not found, using dummy regulator
[    4.764709] omap3isp supply VDD_CSIPHY2 not found, using dummy regulator
[    4.771942] omap3isp omap3isp: Revision 15.0 found
[    4.777008] omap-iommu omap-iommu.0: isp: version 1.1
[    4.788391] Hi253: hi253_probe!
[    4.791748] Hi253: register successful as a media entity
[    4.797698] Hi253: hi253_s_config
[    4.801208] Hi253: hi253_dev_init
[    4.857543] Hi253: hi253_detect
[    4.860992] hi253_write_reg: write reg error:reg=3, val=0
[    4.866668] Hi253: hi253_read_reg
[    4.870300] hi253_read_reg:write reg error:reg=4
[    4.875122] hi253 2-0020: chip id mismatch read 0xffff, expecting 0x92
[    4.883819] isp_register_subdev_group: Unable to register subdev hi253
[    4.891204] usbcore: registered new interface driver uvcvideo
[    4.897247] USB Video Class driver (v1.0.0)
[    4.902435] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[    4.909179] twl4030_wdt twl4030_wdt: Failed to register misc device
[    4.915771] twl4030_wdt: probe of twl4030_wdt failed with error -16
[    4.922943] device-mapper: uevent: version 1.0.3
[    4.928436] device-mapper: ioctl: 4.18.0-ioctl (2010-06-29) initialised: dm-devel@redhat.com
[    4.937408] Bluetooth: HCI UART driver ver 2.2
[    4.942077] Bluetooth: HCI H4 protocol initialized
[    4.947113] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[    4.954498] cpuidle: using governor ladder
[    4.958831] android_usb gadget: high speed config #1: android
[    4.964935] cpuidle: using governor menu
[    4.970703] mmci-omap-hs.0 supply vmmc_aux not found, using dummy regulator
[    4.979003] usb 1-2: new high speed USB device using ehci-omap and address 2
[    4.986968] mmci-omap-hs.1 supply vmmc_aux not found, using dummy regulator
[    4.995788] usbcore: registered new interface driver usbhid
[    5.001647] usbhid: USB HID core driver
[    5.006988] logger: created 64K log 'log_main'
[    5.012115] logger: created 256K log 'log_events'
[    5.017608] logger: created 64K log 'log_radio'
[    5.022827] logger: created 64K log 'log_system'
[    5.029388] usbcore: registered new interface driver snd-usb-audio
[    5.037048] Panther SoC init
[    5.117370] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[    5.125000] ALSA device list:
[    5.128173]   #0: panther
[    5.130920] oprofile: hardware counters not available
[    5.136230] oprofile: using timer interrupt.
[    5.140930] TCP cubic registered
[    5.144348] Initializing XFRM netlink socket
[    5.149169] NET: Registered protocol family 10
[    5.154449] lo: Disabled Privacy Extensions
[    5.159118] Mobile IPv6
[    5.161682] IPv6 over IPv4 tunneling driver
[    5.167114] sit0: Disabled Privacy Extensions
[    5.172393] ip6tnl0: Disabled Privacy Extensions
[    5.177398] NET: Registered protocol family 17
[    5.182128] NET: Registered protocol family 15
[    5.186920] Bluetooth: L2CAP ver 2.15
[    5.190765] Bluetooth: L2CAP socket layer initialized
[    5.196075] Bluetooth: SCO (Voice Link) ver 0.6
[    5.200836] Bluetooth: SCO socket layer initialized
[    5.206085] Bluetooth: RFCOMM TTY layer initialized
[    5.211242] Bluetooth: RFCOMM socket layer initialized
[    5.216644] Bluetooth: RFCOMM ver 1.11
[    5.220581] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    5.226165] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.232788] Registering the dns_resolver key type
[    5.237823] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    5.247283] ThumbEE CPU extension supported.
[    5.255401] usb 1-2: New USB device found, idVendor=0424, idProduct=9514
[    5.262481] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.272857] Power Management for TI OMAP3.
[    5.277709] hub 1-2:1.0: USB hub found
[    5.281982] hub 1-2:1.0: 5 ports detected
[    5.288848] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[    5.297149] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[    5.305664] SmartReflex Class3 initialized
[    5.314056] clock: disabling unused clocks to save power
[    5.320312] platform mpu.0: omap_voltage_scale: Already at the requestedrate 600000000
[    5.379119] regulator_init_complete: incomplete constraints, leaving VDAC on
[    5.388244] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[    5.396911] omap_vout omap_vout: Buffer Size = 3686400
[    5.415985] omap_vout omap_vout: : registered and initialized video device 15
[    5.423522] omap_vout omap_vout: Buffer Size = 3686400
[    5.500701] omap_vout omap_vout: : registered and initialized video device 16
[    5.508941] Waiting 2sec before mounting root device...
[    5.546356] mmc1: card claims to support voltages below the defined range. These will be ignored.
[    5.581665] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[    5.588653] usb 1-2.1: new high speed USB device using ehci-omap and address 3
[    5.596374] mmc1: new SDIO card at address 0001
[    5.714019] usb 1-2.1: New USB device found, idVendor=0424, idProduct=ec00
[    5.721282] usb 1-2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.732604] smsc95xx v1.0.4
[    5.812530] smsc95xx 1-2.1:1.0: usb0: register 'smsc95xx' at usb-ehci-omap.0-2.1, smsc95xx USB 2.0 Ethernet, ca:cf:0d:2
[    5.908874] usb 1-2.2: new full speed USB device using ehci-omap and address 4
[    6.002655] usb 1-2.2: device descriptor read/64, error -32
[    6.197998] usb 1-2.2: device descriptor read/64, error -32
[    6.393371] usb 1-2.2: new full speed USB device using ehci-omap and address 5
[    6.487030] usb 1-2.2: device descriptor read/64, error -32
[    6.682373] usb 1-2.2: device descriptor read/64, error -32
[    6.877655] usb 1-2.2: new full speed USB device using ehci-omap and address 6
[    7.307128] usb 1-2.2: device not accepting address 6, error -32
[    7.393371] usb 1-2.2: new full speed USB device using ehci-omap and address 7
[    7.539978] UBIFS: recovery needed
[    7.617156] UBIFS: recovery completed
[    7.621063] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[    7.627380] UBIFS: file system size:   505364480 bytes (493520 KiB, 481 MiB, 3980 LEBs)
[    7.635772] UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[    7.643463] UBIFS: media format:       w4/r0 (latest is w4/r0)
[    7.649566] UBIFS: default compressor: lzo
[    7.653869] UBIFS: reserved for root:  0 bytes (0 KiB)
[    7.659820] VFS: Mounted root (ubifs filesystem) on device 0:13.
[    7.666168] Freeing init memory: 236K
[    7.691192] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[    7.822723] usb 1-2.2: device not accepting address 7, error -32
[    7.830352] hub 1-2:1.0: unable to enumerate USB device on port 2
[    7.873382] init: cannot open '/initlogo.rle'
[    7.922241] Compat-wireless backport release: r5.00.18-build_208-1-g35cf594
[    7.929595] Backport based on wl12xx_soldel_maintenance.git R4_SP3_SolDel
[    8.038391] cfg80211: Calling CRDA to update world regulatory domain
[    8.272430] cfg80211: World regulatory domain updated:
[    8.278045] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[    8.286834] cfg80211:     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    8.295135] cfg80211:     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[    8.303466] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[    8.311767] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    8.320098] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    8.335754] UBIFS error (pid 1): ubifs_check_node: bad CRC: calculated 0x62007a58, read 0x419c058
[    8.345123] UBIFS error (pid 1): ubifs_check_node: bad node at LEB 203:119544
[    8.352600] UBIFS error (pid 1): ubifs_read_node: expected node type 1
[    8.359466] UBIFS error (pid 1): do_readpage: cannot read page 32 of inode 235, error -117
[    8.422424] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[    8.752166] enabling adb
root@android:/ # [    8.916931] adb_open
[    9.099975] adb_release
[    9.106109] adb_open
[    9.225372] android_usb gadget: high speed config #1: android
[   10.236175] init: untracked pid 1131 exited
[   11.426361] UBIFS error (pid 1226): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   11.436065] UBIFS error (pid 1226): ubifs_check_node: bad node at LEB 934:108088
[   11.443847] UBIFS error (pid 1226): ubifs_read_node: expected node type 1
[   11.450958] UBIFS error (pid 1226): do_readpage: cannot read page 601 of inode 1108, error -117
[   11.461090] UBIFS error (pid 1226): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   11.470947] UBIFS error (pid 1226): ubifs_check_node: bad node at LEB 934:108088
[   11.478729] UBIFS error (pid 1226): ubifs_read_node: expected node type 1
[   11.485870] UBIFS error (pid 1226): do_readpage: cannot read page 601 of inode 1108, error -117
[   11.797485] UBIFS error (pid 1226): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   11.807189] UBIFS error (pid 1226): ubifs_check_node: bad node at LEB 934:108088
[   11.814971] UBIFS error (pid 1226): ubifs_read_node: expected node type 1
[   11.822082] UBIFS error (pid 1226): do_readpage: cannot read page 601 of inode 1108, error -117
[   12.411315] UBIFS error (pid 1226): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   12.421051] UBIFS error (pid 1226): ubifs_check_node: bad node at LEB 934:108088
[   12.428833] UBIFS error (pid 1226): ubifs_read_node: expected node type 1
[   12.435974] UBIFS error (pid 1226): do_readpage: cannot read page 601 of inode 1108, error -117
[   12.448577] request_suspend_state: wakeup (3->0) at 12657318118 (2000-01-01 00:00:07.553894045 UTC)
[   12.462707] init: untracked pid 1127 exited
[   12.479095] init: untracked pid 1133 exited
[   15.111907] UBIFS error (pid 1261): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   15.121765] UBIFS error (pid 1261): ubifs_check_node: bad node at LEB 934:108088
[   15.129547] UBIFS error (pid 1261): ubifs_read_node: expected node type 1
[   15.136688] UBIFS error (pid 1261): do_readpage: cannot read page 601 of inode 1108, error -117
[   15.451141] UBIFS error (pid 1261): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   15.460845] UBIFS error (pid 1261): ubifs_check_node: bad node at LEB 934:108088
[   15.468627] UBIFS error (pid 1261): ubifs_read_node: expected node type 1
[   15.475769] UBIFS error (pid 1261): do_readpage: cannot read page 601 of inode 1108, error -117
[   16.083068] UBIFS error (pid 1261): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   16.092834] UBIFS error (pid 1261): ubifs_check_node: bad node at LEB 934:108088
[   16.100585] UBIFS error (pid 1261): ubifs_read_node: expected node type 1
[   16.107727] UBIFS error (pid 1261): do_readpage: cannot read page 601 of inode 1108, error -117
[   16.120880] request_suspend_state: wakeup (0->0) at 16329620364 (2000-01-01 00:00:11.226196291 UTC)
[   16.134948] init: untracked pid 1237 exited
[   16.151123] init: untracked pid 1238 exited
[   20.476165] UBIFS error (pid 1279): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   20.485931] UBIFS error (pid 1279): ubifs_check_node: bad node at LEB 934:108088
[   20.493713] UBIFS error (pid 1279): ubifs_read_node: expected node type 1
[   20.500854] UBIFS error (pid 1279): do_readpage: cannot read page 601 of inode 1108, error -117
[   20.815307] UBIFS error (pid 1279): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   20.825012] UBIFS error (pid 1279): ubifs_check_node: bad node at LEB 934:108088
[   20.832763] UBIFS error (pid 1279): ubifs_read_node: expected node type 1
[   20.840087] UBIFS error (pid 1279): do_readpage: cannot read page 601 of inode 1108, error -117
[   21.450805] UBIFS error (pid 1279): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   21.460571] UBIFS error (pid 1279): ubifs_check_node: bad node at LEB 934:108088
[   21.468353] UBIFS error (pid 1279): ubifs_read_node: expected node type 1
[   21.475494] UBIFS error (pid 1279): do_readpage: cannot read page 601 of inode 1108, error -117
[   21.488311] request_suspend_state: wakeup (0->0) at 21697021488 (2000-01-01 00:00:16.593627932 UTC)
[   21.505401] init: untracked pid 1265 exited
[   21.525970] init: untracked pid 1266 exited
[   25.845672] UBIFS error (pid 1297): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   25.855438] UBIFS error (pid 1297): ubifs_check_node: bad node at LEB 934:108088
[   25.863189] UBIFS error (pid 1297): ubifs_read_node: expected node type 1
[   25.870330] UBIFS error (pid 1297): do_readpage: cannot read page 601 of inode 1108, error -117
[   26.184692] UBIFS error (pid 1297): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   26.194427] UBIFS error (pid 1297): ubifs_check_node: bad node at LEB 934:108088
[   26.202178] UBIFS error (pid 1297): ubifs_read_node: expected node type 1
[   26.209320] UBIFS error (pid 1297): do_readpage: cannot read page 601 of inode 1108, error -117
[   26.828277] UBIFS error (pid 1297): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   26.838012] UBIFS error (pid 1297): ubifs_check_node: bad node at LEB 934:108088
[   26.845947] UBIFS error (pid 1297): ubifs_read_node: expected node type 1
[   26.853118] UBIFS error (pid 1297): do_readpage: cannot read page 601 of inode 1108, error -117
[   26.865570] request_suspend_state: wakeup (0->0) at 27074310304 (2000-01-01 00:00:21.970886231 UTC)
[   26.879638] init: untracked pid 1283 exited
[   26.884063] init: untracked pid 1284 exited
[   30.226867] UBIFS error (pid 1315): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   30.236602] UBIFS error (pid 1315): ubifs_check_node: bad node at LEB 934:108088
[   30.244354] UBIFS error (pid 1315): ubifs_read_node: expected node type 1
[   30.251525] UBIFS error (pid 1315): do_readpage: cannot read page 601 of inode 1108, error -117
[   30.565948] UBIFS error (pid 1315): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   30.575683] UBIFS error (pid 1315): ubifs_check_node: bad node at LEB 934:108088
[   30.583435] UBIFS error (pid 1315): ubifs_read_node: expected node type 1
[   30.590759] UBIFS error (pid 1315): do_readpage: cannot read page 601 of inode 1108, error -117
[   31.216522] UBIFS error (pid 1315): ubifs_check_node: bad CRC: calculated 0xd54fb650, read 0x76323551
[   31.226226] UBIFS error (pid 1315): ubifs_check_node: bad node at LEB 934:108088
[   31.234008] UBIFS error (pid 1315): ubifs_read_node: expected node type 1
[   31.241149] UBIFS error (pid 1315): do_readpage: cannot read page 601 of inode 1108, error -117
[   31.254119] request_suspend_state: wakeup (0->0) at 31462829592 (2000-01-01 00:00:26.359436036 UTC)
[   31.268768] init: untracked pid 1301 exited
[   31.283813] init: untracked pid 1302 exited
[   36.646179] init: untracked pid 1319 exited
[   36.664276] init: untracked pid 1320 exited
