Hi community member,
Please let me confirm the following question.
[Question]
Can customer use the following SPI Flash for C5535 bootlaoder?
Flash: N25Q032A13EF440F
Memory size: 32Mbit
I/O voltage: 2.7V to 3.6V
Best regards.
Kaka
[Question]
Memory size: 32Mbit
Best regards.
Kaka
Hi Kaka-san,
I did parsed the Micron SPI Flash datasheet and it looks ok to me including operating voltage.
But suggest you to reconfirm on the below operating conditions for SPI flash to work.
• The device must support at least a 500-kHz SPI clock.
• The device uses three bytes (24 bits) for internal addressing (up to 16MB). - Though the other Flash device supports upto 32MB
• The device must have the capability to auto-increment its internal address counter to allow sequential reads from the device. - This looks like its supported.
• Any and all write-protect features must be disabled if re-authoring is needed. - Recheck and confirm (if re-authoring)
Hope this helps.
Vasanth
Hi Kaka-san,
Below are my comments:
[Confirming]
>>Though the other Flash device supports upto 32MB What does it mean "the other flash"?
Vasanth: By "other flash" - I meant the Flash: N25Q032A13EF440F
And can C5535 support the 32MByte flash size in maximum? ** The bootloader is described " (up to 16MB).".
Vasanth: C5535 with 24-bit SPI can support up to 16MB, you could use bigger flash but not all memories can be accessed.
Hope this clarifies.
Vasanth
