Other Parts Discussed in Thread: TPS65910, PCF8575, TLC59108, TPS65911, TPA6130A2
When try to play a wav file, no audio is heard, on console continuously output i2c controller timed out message. Please find the details below.
root@c6a811x-evm:~# aplay -fS16_LE -r 48000 -c2 ./audio48K.wav
omap_i2c omap_i2c.1: controller timed out
root@c6a811x-evm:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: EVM [TI81XX EVM], device 0: AIC3X tlv320aic3x-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
root@c6a811x-evm:~#
root@c6a811x-evm:~# amixer
Simple mixer control 'PCM',0
Capabilities: pvolume penum
Playback channels: Front Left - Front Right
Limits: Playback 0 - 127
Mono:
Front Left: Playback 87 [69%] [-20.00dB]
Front Right: Playback 87 [69%] [-20.00dB]
Simple mixer control 'Line',0
Capabilities: pswitch penum
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control 'Line DAC',0
Limits: Playback 0 - 118
Mono:
Front Left: Playback 71 [60%] [-23.50dB]
Front Right: Playback 71 [60%] [-23.50dB]
Simple mixer control 'Line Line2 Bypass',0
Capabilities: volume penum
Capture channels: Front Left - Front Right
Limits: 0 - 118
Front Left: 71 [60%] [-23.50dB]
Front Right: 71 [60%] [-23.50dB]
Simple mixer control 'Line PGA Bypass',0
Limits: 0 - 118
Simple mixer control 'Mono',0
Capabilities: pswitch pswitch-joined penum
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Mono DAC',0
Mono:
Simple mixer control 'Mono Line2 Bypass',0
Limits: 0 - 118
Simple mixer control 'Mono Mixer DACL1',0
Mono: Playback [on]
Simple mixer control 'Mono Mixer DACR1',0
Mono: Playback [on]
Simple mixer control 'Mono Mixer Line2L Bypass',0
Mono: Playback [off]
Simple mixer control 'Mono Mixer Line2R Bypass',0
Simple mixer control 'Mono Mixer PGAL Bypass',0
Simple mixer control 'Mono Mixer PGAR Bypass',0
Simple mixer control 'Mono PGA Bypass',0
Limits: 0 - 118
Simple mixer control 'ADC HPF Cut-off',0
Capabilities: enum
Items: 'Disabled' '0.0045xFs' '0.0125xFs' '0.025xFs'
Item0: 'Disabled'
Item1: 'Disabled'
Simple mixer control 'AGC',0
Mono:
Front Left: Playback [off]
Front Right: Playback [off]
Simple mixer control 'HP',0
Mono:
Simple mixer control 'HP DAC',0
Mono:
Simple mixer control 'HP Line2 Bypass',0
Limits: 0 - 118
Simple mixer control 'HP PGA Bypass',0
Limits: 0 - 118
Simple mixer control 'HPCOM',0
Mono:
Simple mixer control 'HPCOM DAC',0
Mono:
Simple mixer control 'HPCOM Line2 Bypass',0
Limits: 0 - 118
Simple mixer control 'HPCOM PGA Bypass',0
Limits: 0 - 118
Simple mixer control 'Left DAC Mux',0
Capabilities: enum
Items: 'DAC_L1' 'DAC_L3' 'DAC_L2'
Item0: 'DAC_L1'
Simple mixer control 'Left HP Mixer DACL1',0
Mono: Playback [on]
Simple mixer control 'Left HP Mixer DACR1',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
Mono: Playback 118 [100%] [0.00dB] [off]
Simple mixer control 'Left HP Mixer Line2L Bypass',0
Simple mixer control 'Left HP Mixer Line2R Bypass',0
Capabilities: volume volume-joined pswitch pswitch-joined penum
Capture channels: Mono
Limits: 0 - 118
Mono: 118 [100%] [0.00dB] Playback [off]
Simple mixer control 'Left HP Mixer PGAL Bypass',0
Simple mixer control 'Left HP Mixer PGAR Bypass',0
Limits: 0 - 118
Simple mixer control 'Left HPCOM Mixer DACL1',0
Mono: Playback [on]
Simple mixer control 'Left HPCOM Mixer DACR1',0
Simple mixer control 'Left HPCOM Mixer Line2L Bypass',0
Simple mixer control 'Left HPCOM Mixer Line2R Bypass',0
Limits: 0 - 118
Simple mixer control 'Left HPCOM Mixer PGAL Bypass',0
Simple mixer control 'Left HPCOM Mixer PGAR Bypass',0
Limits: 0 - 118
Simple mixer control 'Left HPCOM Mux',0
Capabilities: enum
Items: 'differential of HPLOUT' 'constant VCM' 'single-ended'
Item0: 'differential of HPLOUT'
Simple mixer control 'Left Line Mixer DACL1',0
Mono: Playback [on]
Simple mixer control 'Left Line Mixer DACR1',0
Simple mixer control 'Left Line Mixer Line2L Bypass',0
Simple mixer control 'Left Line Mixer Line2R Bypass',0
Limits: 0 - 118
Simple mixer control 'Left Line Mixer PGAL Bypass',0
Simple mixer control 'Left Line Mixer PGAR Bypass',0
Limits: 0 - 118
Simple mixer control 'Left Line1L Mux',0
Capabilities: enum
Items: 'single-ended' 'differential'
Item0: 'single-ended'
Simple mixer control 'Left Line1R Mux',0
Capabilities: enum
Simple mixer control 'Left Line2L Mux',0
Capabilities: enum
Simple mixer control 'Left PGA Mixer Line1L',0
Mono: Playback [on]
Simple mixer control 'Left PGA Mixer Line1R',0
Simple mixer control 'Left PGA Mixer Line2L',0
Simple mixer control 'Left PGA Mixer Mic3L',0
Simple mixer control 'Left PGA Mixer Mic3R',0
Simple mixer control 'PGA',0
Capabilities: cvolume cswitch penum
Limits: Capture 0 - 119
Front Left: Capture 32 [27%] [16.00dB] [on]
Front Right: Capture 32 [27%] [16.00dB] [on]
Simple mixer control 'Right DAC Mux',0
Capabilities: enum
Items: 'DAC_R1' 'DAC_R3' 'DAC_R2'
Item0: 'DAC_R1'
Simple mixer control 'Right HP Mixer DACL1',0
Simple mixer control 'Right HP Mixer DACR1',0
Mono: Playback [on]
Simple mixer control 'Right HP Mixer Line2L Bypass',0
Limits: 0 - 118
Simple mixer control 'Right HP Mixer Line2R Bypass',0
Simple mixer control 'Right HP Mixer PGAL Bypass',0
Limits: 0 - 118
Simple mixer control 'Right HP Mixer PGAR Bypass',0
Simple mixer control 'Right HPCOM Mixer DACL1',0
Simple mixer control 'Right HPCOM Mixer DACR1',0
Mono: Playback [on]
Simple mixer control 'Right HPCOM Mixer Line2L Bypass',0
Limits: 0 - 118
Simple mixer control 'Right HPCOM Mixer Line2R Bypass',0
Simple mixer control 'Right HPCOM Mixer PGAL Bypass',0
Limits: 0 - 118
Simple mixer control 'Right HPCOM Mixer PGAR Bypass',0
Simple mixer control 'Right HPCOM Mux',0
Capabilities: enum
Items: 'differential of HPROUT' 'constant VCM' 'single-ended' 'differential of HPLCOM' 'external feedback'
Item0: 'differential of HPROUT'
Simple mixer control 'Right Line Mixer DACL1',0
Simple mixer control 'Right Line Mixer DACR1',0
Mono: Playback [on]
Simple mixer control 'Right Line Mixer Line2L Bypass',0
Limits: 0 - 118
Simple mixer control 'Right Line Mixer Line2R Bypass',0
Simple mixer control 'Right Line Mixer PGAL Bypass',0
Limits: 0 - 118
Simple mixer control 'Right Line Mixer PGAR Bypass',0
Simple mixer control 'Right Line1L Mux',0
Capabilities: enum
Simple mixer control 'Right Line1R Mux',0
Capabilities: enum
Simple mixer control 'Right Line2R Mux',0
Capabilities: enum
Simple mixer control 'Right PGA Mixer Line1L',0
Simple mixer control 'Right PGA Mixer Line1R',0
Mono: Playback [on]
Simple mixer control 'Right PGA Mixer Line2R',0
Simple mixer control 'Right PGA Mixer Mic3L',0
Simple mixer control 'Right PGA Mixer Mic3R',0
