Other Parts Discussed in Thread: FFTLIB
I keep getting unresolved symbol errors when I try to use the libcblas.a libraries.
**** Build of configuration Debug for project 6678Test ****
/home/ankit/ti/ccsv5/utils/bin/gmake -k all
Building target: 6678Test.out
Invoking: C6000 Linker
"/home/ankit/ti/ti-cgt-c6000_8.0.0/bin/cl6x" -mv6600 --abi=eabi -g --display_error_number --diag_warning=225 --diag_wrap=off --openmp -z -m"6678Test.map" -i"/home/ankit/ti/ti-cgt-c6000_8.0.0/lib" -i"/home/ankit/ti/ti-cgt-c6000_8.0.0/include" --reread_libs --warn_sections --display_error_number --diag_wrap=off --xml_link_info="6678Test_linkInfo.xml" --rom_model -o "6678Test.out" "./main.obj" "../C6678.cmd" -l"libc.a" -l/home/ankit/ti/blas_c66x_3_11_0_3/packages/ti/blas/lib/libcblas.a -l/home/ankit/ti/fftlib_k2hx_2_0_1_3/packages/ti/fftlib/lib/fftlib.lib -l/home/ankit/ti/dsplib_c66x_3_4_0_0/packages/ti/dsplib/lib/dsplib.lib
<Linking>
warning #10247-D: creating output section ".tdata" without a SECTIONS specification
warning #10247-D: creating output section ".TI.tls_init" without a SECTIONS specification
warning #10247-D: creating output section ".text" without a SECTIONS specification
warning #10247-D: creating output section ".const" without a SECTIONS specification
warning #10247-D: creating output section ".stack" without a SECTIONS specification
warning #10247-D: creating output section ".fardata" without a SECTIONS specification
warning #10247-D: creating output section ".sysmem" without a SECTIONS specification
warning #10247-D: creating output section ".cio" without a SECTIONS specification
warning #10247-D: creating output section ".far:.common" without a SECTIONS specification
warning #10247-D: creating output section ".cinit" without a SECTIONS specification
warning #10210-D: creating ".stack" section with default size of 0x400; use the -stack option to change the default size
warning #10210-D: creating ".sysmem" section with default size of 0x400; use the -heap option to change the default size
undefined first referenced
symbol in file
ATL_cgemm /home/ankit/ti/blas_c66x_3_11_0_3/packages/ti/blas/lib/libcblas.a<cblas_cgemm.o>
ATL_csyreflect /home/ankit/ti/blas_c66x_3_11_0_3/packages/ti/blas/lib/libcblas.a<cblas_cgemm.o>
ATL_csyrk /home/ankit/ti/blas_c66x_3_11_0_3/packages/ti/blas/lib/libcblas.a<cblas_cgemm.o>
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "6678Test.out" not built
>> Compilation failure
gmake: *** [6678Test.out] Error 1
gmake: Target `all' not remade because of errors.
My setup: CCSv5.5 on Ubuntu 12.04, board is the K2H EVM set to DSP no-boot. Other code compiles fine. I've successfully used DSPLIB and I've used my own code without issue. I can't imagine where it's going wrong. Below is my code. Thank you in advance for any and all help.
#include <c6x.h>
#include <stdio.h>
#include <stdlib.h>
#include "ti/blas/inc/cblas.h"
int m = 24;
int n = 20;
#pragma DATA_ALIGN(x1, 8);
#pragma DATA_ALIGN(x2, 8);
#pragma DATA_ALIGN(y , 8);
float x1[24*2];
float x2[20*24*2];
float y[20*2];
int main()
printf("Starting main\n");
int i;
for(i = 0; i < 48; i++)
x1[i] = (rand()%10000)/100.0;
for(i = 0; i < 20*24*2; i++)
x2[i] = (rand()%10000)/100.0;
long t1, t2;
int lda = 24;
int ldb = 20;
int ldc = 20;
float alpha[2] = {1.0, 1.0};
float beta[2] = {0.0, 0.0};
t1 = _itoll(TSCH,TSCL);
cblas_cgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans, 1, 20, 24, alpha, x1, lda, x2, ldb, beta, y, ldc);
t2 = _itoll(TSCH,TSCL);
printf("Prelim result: %d\n", t2-t1);
return(0);
