Adding USB Hub support
I had recently raised a question about USB Hub support in TI-RTOS. At present it does not support any external hubs, As I am new to USB, I was able to test theUSB hub support example provided with Tivaware. I then modified the USBMSCHFatFsTiva.c incorporating the changes that was in the tivaware code.  The TI-RTOS is rebuilt as per the instructions in TI-RTOS user guide. The USB pen drive is not getting enumerated and is getting timed out. I am attaching the original, as well as the modified file.
Are the changes done to the file enough to support USB hub?
Any other changes needed to support the USB Hub?
USBMSCHFatFsTiva.c is the original Ti-RTOS file
USBMSCHFatFsTiva-modified.c is the modified file to support USB Hub
Thanks in advance
Narendra
 * Copyright (c) 2015, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdint.h>
#include <stdbool.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/Assert.h>
#include <xdc/runtime/Diags.h>
#include <xdc/runtime/Log.h>
#include <xdc/runtime/System.h>
#include <ti/sysbios/family/arm/m3/Hwi.h>
#include <ti/drivers/usbmschfatfs/USBMSCHFatFsTiva.h>
/* driverlib header files */
#include <inc/hw_ints.h>
#include <inc/hw_types.h>
/* usblib Header files */
#include <usblib/usb-ids.h>
#include <usblib/usblib.h>
#include <usblib/usbmsc.h>
#include <usblib/host/usbhost.h>
#include <usblib/host/usbhmsc.h>
#include <usblib/host/usbhhub.h>
#if defined(TIVAWARE)
/* c99 types needed by TivaWare */
typedef uint32_t                    USBMSCEventType;
#else /* MWare */
#define g_sUSBHostMSCClassDriver    g_USBHostMSCClassDriver
#define eUSBModeHost                USB_MODE_HOST
#define ui32Event                   ulEvent
typedef unsigned long               USBMSCEventType;
#endif
#define DRIVE_NOT_MOUNTED           ~0
 * Array of USBMSCHFatFs_Handles to determine the association of the FatFs drive
 * number with a USBMSCHFatFs_Handle
 * _VOLUMES is defined in <ti/sysbios/fatfs/ffconf.h>
 * As only one USB MSC Host class can be defined only the 1st element is used.
extern USBMSCHFatFs_Config USBMSCHFatFs_config[];
/* Function prototypes */
static void USBMSCHFatFsTiva_cbMSCHandler(USBMSCType instance,
                                          USBMSCEventType event,
                                          void *eventMsgPtr);
static void USBMSCHFatFsTiva_hwiHandler(UArg arg0);
static void USBMSCHFatFsTiva_serviceUSBHost(UArg arg0, UArg arg1);
static void USBMSCHFatFsTiva_usbHCDEvents(void *cbData);
/* FatFs disk I/O functions */
DSTATUS  USBMSCHFatFsTiva_diskInitialize(BYTE drv);
DRESULT  USBMSCHFatFsTiva_diskIOctl(BYTE drv, BYTE ctrl, void *buf);
DRESULT  USBMSCHFatFsTiva_diskRead(BYTE drv, BYTE *buf,
                                   DWORD sector, BYTE count);
DSTATUS  USBMSCHFatFsTiva_diskStatus(BYTE drv);
DRESULT  USBMSCHFatFsTiva_diskWrite(BYTE drv, const BYTE *buf,
/* USBMSCHFatFs functions */
void USBMSCHFatFsTiva_init(USBMSCHFatFs_Handle handle);
USBMSCHFatFs_Handle USBMSCHFatFsTiva_open(USBMSCHFatFs_Handle handle,
                                          unsigned char drv,
                                          USBMSCHFatFs_Params *params);
void USBMSCHFatFsTiva_close(USBMSCHFatFs_Handle handle);
int  USBMSCHFatFsTiva_control(USBMSCHFatFs_Handle handle,
                              unsigned int cmd,
                              void *arg);
bool USBMSCHFatFsTiva_waitForConnect(USBMSCHFatFs_Handle handle,
                                     unsigned int timeout);
/* USBMSCHFatFs function table for USBMSCHFatFsTiva implementation */
const USBMSCHFatFs_FxnTable USBMSCHFatFsTiva_fxnTable = {
    USBMSCHFatFsTiva_init,
    USBMSCHFatFsTiva_open,
    USBMSCHFatFsTiva_close,
    USBMSCHFatFsTiva_control,
/* Default USBMSCHFatFs params */
extern const USBMSCHFatFs_Params USBMSCHFatFs_defaultParams;
/* MACRO to create a generic USB event host driver */
DECLARE_EVENT_DRIVER(USBMSCHFatFs_eventDriver, 0, 0,
                     USBMSCHFatFsTiva_usbHCDEvents);
/* A list of available Host Class Drivers */
static tUSBHostClassDriver const * const usbHCDDriverList[] = {
	&g_sUSBHubClassDriver,      /* Hub class driver */
    &g_sUSBHostMSCClassDriver,  /* MSC Host class driver */
    &USBMSCHFatFs_eventDriver   /* Generic event notification handler */
/* Variable containing the number of HCDs in usbHCDDriverList */
static const unsigned long numHostClassDrivers =
    sizeof(usbHCDDriverList) / sizeof(tUSBHostClassDriver *);
// This is the callback from the USB HUB  handler.
// pvCBData is ignored by this function.
// ui32Event is one of the valid events for a mouse device.
// ui32MsgParam is defined by the event that occurs.
// pvMsgData is a pointer to data that is defined by the event that occurs.
// This function will return 0.
void
HubCallback(tHubInstance *psHubInstance, uint32_t ui32Event,
            uint32_t ui32MsgParam, void *pvMsgData)
 *  ======== USBMSCHFatFsTiva_cbMSCHandler ========
 *  Callback handler for the USB stack.
 *  Callback handler call by the USB stack to notify us on what has
 *  happened in regards to the mouse. This is done in a context of the priority
 *  of the USBMSCHFatFsTiva_serviceUSBHost task.
 *  @param  instance    A driver instance of MSC.
 *  @param  event       Identifies the event that occurred in regards to this
 *                      device.
 *  @param  eventMsgPtr A data pointer associated with a particular event.
                                          void *eventMsgPtr)
    USBMSCHFatFsTiva_Object    *object = USBMSCHFatFs_config->object;
    /* Determine what event has happened */
    switch (event) {
        case MSC_EVENT_OPEN:
            object->state = USBMSCHFatFsTiva_CONNECTED;
            Log_print0(Diags_USER2, "USBMSCHFatFs: MSC DEVICE CONNECTED; "
                                    "Posting semUSBConnected");
            Semaphore_post(Semaphore_handle(&object->semUSBConnected));
            break;
        case MSC_EVENT_CLOSE:
            object->state = USBMSCHFatFsTiva_NO_DEVICE;
            Log_print0(Diags_USER2, "USBMSCHFatFs: MSC DEVICE DISCONNECTED");
            break;
        default:
            break;
 *  ======== USBMSCHFatFsTiva_diskInitialize ========
 *  This function checks the USB Drive to see if it's ready to be accessed.
 *  This function attempts to read the USBHMSCDriveReady() function up to 10
 *  times to get a good return code. For some reason the first attempt to read
 *  this function doesn't return a good response value. Generally, you should
 *  get a good response on the second attempt.
 *  A gateMutex lock is required to prevent concurrent access to the USB
 *  Library's state machine variables within MSCInstance.
 *  @param  drv Drive Number
 *  @return Returns the disk status to the FatFs module
    unsigned char               i;
    unsigned int                key;
    uint32_t                    driveReady;
    /* Determine if the USB Drive is ready up to 10 times */
    for (i = 0; i < 10; i++ ) {
        key = GateMutex_enter(GateMutex_handle(&(object->gateUSBLibAccess)));
        driveReady = USBHMSCDriveReady(object->MSCInstance);
        GateMutex_leave(GateMutex_handle(&(object->gateUSBLibAccess)), key);
        if (driveReady == 0) {
            Log_print1(Diags_USER1, "USBMSCHFatFs: disk initialization: "
                                    "ready after %d tries", i);
            return (0x00); /* Disk OK */
    Log_print0(Diags_USER1, "USBMSCHFatFs: disk initialization: not ready");
    return (STA_NOINIT);
 *  ======== USBMSCHFatFsTiva_diskIOctl ========
 *  This function performs misc. control functions documented by FatFs
 *  NOTE: Formatting the USB MSC f_mkfs() is NOT supported!
 *  @param  ctrl    FatFs control function to be executed
 *  @param  buf     Pointer to a buffer to which data is written
    if (object->state != USBMSCHFatFsTiva_CONNECTED) {
        Log_print0(Diags_USER1, "USBMSCHFatFs: disk IO control: not "
                                "initialized");
        return (RES_NOTRDY);
    switch (ctrl) {
        case CTRL_SYNC:
            Log_print0(Diags_USER1, "USBMSCHFatFs: disk IO control: OK");
            return (RES_OK);
        default:
            Log_print0(Diags_USER1, "USBMSCHFatFs: disk IO control: "
                                    "parameter error");
            return (RES_PARERR);
 *  ======== USBMSCHFatFsTiva_diskRead ========
 *  This function reads sector(s) from the disk drive
 *  @param  sector  Sector number to read from
 *  @param  count   Number of sectors to be read
    unsigned int                key;
    uint32_t                    driveRead;
    Log_print2(Diags_USER1, "USBMSCHFatFs: diskRead: Sector %d, Count %d",
                             sector, count);
        Log_print0(Diags_USER1, "USBMSCHFatFs: diskRead: not initialized");
    /* READ BLOCK */
    driveRead = USBHMSCBlockRead(object->MSCInstance, sector, buf, count);
    if (driveRead == 0) {
        Log_print0(Diags_USER2, "USBMSCHFatFs: diskRead: OK");
        return (RES_OK);
    else {
        Log_print0(Diags_USER2, "USBMSCHFatFs: diskRead: ERROR");
        return (RES_ERROR);
 *  ======== USBMSCHFatFsTiva_diskStatus ========
 *  Returns the current status of a drive
        Log_print0(Diags_USER1, "USBMSCHFatFs: diskStatus: not initialized");
#if _READONLY == 0
 *  ======== USBMSCHFatFsTiva_diskWrite ========
 *  This function writes sector(s) to the disk drive
 *  @param  buf     Pointer to a buffer from which data is read
 *  @param  sector  Sector number to write to
 *  @param  count   Number of sectors to be written
    unsigned int                key;
    uint32_t                    driveWrite;
    Log_print2(Diags_USER1, "USBMSCHFatFs: diskWrite: Sector %d, Count %d",
                             sector, count);
    if (!count) {
        Log_print0(Diags_USER1, "USBMSCHFatFs: diskWrite: ERROR");
        Log_print0(Diags_USER1, "USBMSCHFatFs: diskWrite: not initialized");
    driveWrite = USBHMSCBlockWrite(object->MSCInstance, sector, (uint8_t *)buf, count);
    if (driveWrite == 0) {
        Log_print0(Diags_USER2, "USBMSCHFatFs: diskWrite: OK");
        return (RES_OK);
    else {
        Log_print0(Diags_USER2, "USBMSCHFatFs: diskWrite: ERROR");
        return (RES_ERROR);
#endif /* _READONLY */
 *  ======== USBMSCHFatFsTiva_hwiHandler ========
 *  This function calls the USB library's interrupt handler.
     * This function call generates a VBUS error interrupts; therefore we call
     * the OTG equivalent instead based on working TivaWare examples
    //USB0HostIntHandler();
    USB0OTGModeIntHandler();
 *  ======== USBMSCHFatFsTiva_serviceUSBHost ========
 *  Task to periodically service the USB Stack
 *  USBHCDMain handles the USB Stack's statemachine. For example it handles the
 *  enumeration process when a device connects.
 *  Future USB library improvement goal is to remove this polling requirement..
    unsigned int                key;
    while (true) {
        USBHCDMain();
        /* Future enhancement to remove the Task_sleep */
        Task_sleep(10);
 *  ======== USBMSCHFatFsTiva_usbHCDEvents ========
 *  Generic USB Host Class Driver event callback.
 *  This callback is called to notify the application that an unknown
 *  device was connected.
    tEventInfo                 *pEventInfo = (tEventInfo *)cbData;
    switch (pEventInfo->ui32Event) {
        case USB_EVENT_UNKNOWN_CONNECTED:
            /* An unknown device was detected. */
            object->state = USBMSCHFatFsTiva_UNKNOWN;
            Log_print0(Diags_USER2, "USBMSCHFatFs: usbHCDEvent Callback: "
                                    "UNKNOWN DEVICE CONNECTED");
            break;
        case USB_EVENT_DISCONNECTED:
            /* Unknown device has been removed. */
                                    "UNKNOWN DEVICE DISCONNECTED");
            break;
        case USB_EVENT_POWER_FAULT:
            /* No power means no device is present. */
            object->state = USBMSCHFatFsTiva_POWER_FAULT;
                                    "POWER FAULT");
            break;
        default:
            break;
 *  ======== USBMSCHFatFsTiva_init ========
    USBMSCHFatFsTiva_Object    *object = handle->object;
    object->driveNumber = DRIVE_NOT_MOUNTED;
 *  ======== USBMSCHFatFsTiva_open ========
                                          unsigned char drv,
    unsigned int                    key;
    DRESULT                         dresult;
    FRESULT                         fresult;
    USBMSCHFatFsTiva_HWAttrs const *hwAttrs = handle->hwAttrs;
    union {
        Task_Params                 taskParams;
        Semaphore_Params            semParams;
        GateMutex_Params            gateParams;
        Hwi_Params                  hwiParams;
    } paramsUnion;
    /* Determine if the device was already opened */
    key = Hwi_disable();
    if (object->driveNumber != DRIVE_NOT_MOUNTED) {
        Hwi_restore(key);
        return (NULL);
    /* Mark as being used */
    object->driveNumber = drv;
    Hwi_restore(key);
    /* Store the USBMSCHFatFs parameters */
    if (params == NULL) {
        /* No params passed in, so use the defaults */
        params = (USBMSCHFatFs_Params *) &USBMSCHFatFs_defaultParams;
    /* Initialize the USB stack for host mode. */
    USBStackModeSet(0, eUSBModeForceHost, NULL);
    /* Register host class drivers */
    USBHCDRegisterDrivers(0, usbHCDDriverList, numHostClassDrivers);
    // Open a hub instance and provide it with the memory required to hold
    // configuration descriptors for each attached device.
    USBHHubOpen(HubCallback);
    /* Open an instance of the MSC host driver */
    object->MSCInstance = USBHMSCDriveOpen(0, USBMSCHFatFsTiva_cbMSCHandler);
    if (!(object->MSCInstance)) {
        Log_print0(Diags_USER1,"USBMSCHFatFs: Error initializing the MSC Host");
        USBMSCHFatFsTiva_close(handle);
        return (NULL);
    /* Create the Hwi object to service interrupts */
    Hwi_Params_init(&(paramsUnion.hwiParams));
    paramsUnion.hwiParams.priority = hwAttrs->intPriority;
    Hwi_construct(&(object->hwi), hwAttrs->intNum, USBMSCHFatFsTiva_hwiHandler,
                 &(paramsUnion.hwiParams), NULL);
    /* Initialize USB power configuration */
    USBHCDPowerConfigInit(0, USBHCD_VBUS_AUTO_HIGH | USBHCD_VBUS_FILTER);
    /* Enable the USB stack */
    USBHCDInit(0, object->memPoolHCD, HCDMEMORYPOOLSIZE);
    /* RTOS primitives */
    Semaphore_Params_init(&(paramsUnion.semParams));
    paramsUnion.semParams.mode = Semaphore_Mode_BINARY;
    Semaphore_construct(&(object->semUSBConnected), 0, &(paramsUnion.semParams));
    GateMutex_Params_init(&(paramsUnion.gateParams));
    paramsUnion.gateParams.instance->name = "USB Library Access";
    GateMutex_construct(&(object->gateUSBLibAccess), &(paramsUnion.gateParams));
    paramsUnion.gateParams.instance->name = "USB Wait";
    GateMutex_construct(&(object->gateUSBWait), &(paramsUnion.gateParams));
     * Note that serviceUSBHost() should not be run until the USB Stack has been
     * initialized!!
    Task_Params_init(&(paramsUnion.taskParams));
     * If serviceTaskStackPtr is null, then Task_construct performs a
     * Memory_alloc - requiring a Heap
    paramsUnion.taskParams.stack = params->serviceTaskStackPtr;
     * If service priority passed in is higher than what is configured by the
     * Task module, then use the highest priority available.
    if (Task_numPriorities - 1 < params->servicePriority) {
        paramsUnion.taskParams.priority = (Task_numPriorities - 1);
    else {
        paramsUnion.taskParams.priority = params->servicePriority;
    /* If no stack size is passed in, then use the default task stack size */
    if (params->serviceTaskStackSize) {
        paramsUnion.taskParams.stackSize = params->serviceTaskStackSize;
    else {
        paramsUnion.taskParams.stackSize = Task_defaultStackSize;
    Task_construct(&(object->taskHCDMain),USBMSCHFatFsTiva_serviceUSBHost,
                   &(paramsUnion.taskParams), NULL);
    /* Register the new disk_*() functions */
    dresult = disk_register(drv,
                            USBMSCHFatFsTiva_diskInitialize,
                            USBMSCHFatFsTiva_diskStatus,
                            USBMSCHFatFsTiva_diskRead,
                            USBMSCHFatFsTiva_diskWrite,
                            USBMSCHFatFsTiva_diskIOctl);
    /* Check for drive errors */
    if (dresult != RES_OK) {
        Log_error0("USBMSCHFatFs: disk functions not registered");
        return (NULL);
    /* Mount the FatFs (this function does not access the SDCard yet...) */
    fresult = f_mount(drv, &(object->filesystem));
    if (fresult != FR_OK) {
        Log_error1("USBMSCHFatFs: drive %d not mounted", drv);
        return (NULL);
    Log_print1(Diags_USER1, "USBMSCHFatFs: drive %d opened", drv);
    return (handle);
 *  ======== USBMSCHFatFsTiva_close ========
    unsigned int                key;
    DRESULT                     dresult;
    FRESULT                     fresult;
    /* Unmount the FatFs drive */
    fresult = f_mount(object->driveNumber, NULL);
        Log_print0(Diags_USER1, "USBMSCHFatFs: could not unmount FatFs volume");
    /* Close USB Drive */
    USBHMSCDriveClose(object->MSCInstance);
    /* Unregister the disk_*() functions */
    dresult = disk_unregister(object->driveNumber);
        Log_print0(Diags_USER1, "USBMSCHFatFs: error unregistering disk "
                                "functions");
    /* Delete the HCDMain service task*/
    Task_destruct(&(object->taskHCDMain));
    /* Delete the semaphore */
    Semaphore_destruct(&(object->semUSBConnected));
    /* Delete the gate */
    GateMutex_destruct(&(object->gateUSBLibAccess));
    GateMutex_destruct(&(object->gateUSBWait));
    /* Delete the hwi */
    Hwi_destruct(&(object->hwi));
    Log_print1(Diags_USER1, "USBMSCHFatFs: drive %d closed",
    Hwi_restore(key);
 *  ======== USBMSCHFatFsTiva_control ========
 *  @pre    Function assumes that the handle is not NULL
                             unsigned int cmd,
                             void *arg)
	/* No implementation yet */
	return (USBMSCHFatFs_CMD_RESERVED);
 *  ======== USBMSCHFatFsTiva_waitForConnect ========
    unsigned int                key;
    bool                        ret = true;
    /* Need exclusive access to prevent a race condition */
    key = GateMutex_enter(GateMutex_handle(&(object->gateUSBWait)));
    if (object->state == USBMSCHFatFsTiva_NO_DEVICE) {
        if (!Semaphore_pend(Semaphore_handle(&(object->semUSBConnected)),
                                             timeout)) {
            ret = false;
    GateMutex_leave(GateMutex_handle(&(object->gateUSBWait)), key);
    return (ret);
 * are met:
#include <stdint.h>
#else /* MWare */
#endif
                                          void *eventMsgPtr);
                                          unsigned char drv,
                              unsigned int cmd,
                              void *arg);
 *                      device.
                                          void *eventMsgPtr)
    switch (event) {
            break;
            break;
        default:
            break;
    unsigned char               i;
    unsigned int                key;
                                "initialized");
    switch (ctrl) {
        case CTRL_SYNC:
            return (RES_OK);
        default:
                                    "parameter error");
    unsigned int                key;
    uint32_t                    driveRead;
                             sector, count);
    /* READ BLOCK */
        return (RES_OK);
    else {
        return (RES_ERROR);
#if _READONLY == 0
    unsigned int                key;
                             sector, count);
    if (!count) {
        return (RES_OK);
    else {
        return (RES_ERROR);
    unsigned int                key;
    while (true) {
        USBHCDMain();
        Task_sleep(10);
            break;
            break;
                                    "POWER FAULT");
            break;
        default:
            break;
                                          unsigned char drv,
    unsigned int                    key;
    DRESULT                         dresult;
    FRESULT                         fresult;
    union {
    } paramsUnion;
        Hwi_restore(key);
        return (NULL);
    Hwi_restore(key);
    USBStackModeSet(0, eUSBModeHost, NULL);
        return (NULL);
     * initialized!!
    else {
    else {
        return (NULL);
        return (NULL);
    return (handle);
    unsigned int                key;
    DRESULT                     dresult;
    FRESULT                     fresult;
                                "functions");
    Hwi_restore(key);
                             unsigned int cmd,
                             void *arg)
    unsigned int                key;
    bool                        ret = true;
                                             timeout)) {
            ret = false;
    return (ret);
