dec ouputbuffers are locked-up inside the codec lib
hi all.when i do my stability test .i found the following error.so how can i fix it?
that following is my decoder parameters:
vdecCrePrm.targetFrameRate = 30;
vdecCrePrm.scanFormat = 1;
//displayDelay valid only for H264, stream specific value
vdecCrePrm.displayDelay = 0;
vdecCrePrm.numBufPerCh = 6;
vdecCrePrm.decodeFrameType = 0;
vdecCrePrm.processCallLevel= VDEC_FRAMELEVELPROCESSCALL;
vdecCrePrm.fieldMergeDecodeEnable = FALSE;
vdecCrePrm.tilerEnable = FALSE;//FALSE//TRUE
vdecCrePrm.chMaxReqBufSize = (vdecCrePrm.targetMaxWidth * vdecCrePrm.targetMaxHeight);
vdecCrePrm.totalBitStreamBufferSize = (vdecCrePrm.chMaxReqBufSize* ITCM_decodeGetBitBufLimit(res));
status = Vdec_createChn(&vdecCrePrm);
the error log is following :
 [m3vpss ]  31492051: SWMS0    : Loading Vertical Co-effs (1/1)x ...
 [m3vpss ]  31492051: SWMS0    : Loading Horizontal Co-effs (1/1)x ...
 [m3vpss ]  31492052: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]  *** [SWMS0] Mosaic Parameters ***
 [m3vpss ]
 [m3vpss ]  Output FPS: 60
 [m3vpss ]
 [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |
 [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |
 [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
 [m3vpss ]    0 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]    1 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  960,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]    2 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]    3 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  960,  540 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]
 [m3vpss ]  86427615: DISPLAY: HDDAC(BP0) : 10 fps, Latency (Min / Max) = ( 60 / 464 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 33 / 399 ) !!!
 [m3vpss ]  86427615: DISPLAY DRV: HDDAC(BP0) : Q:[4376925] Display:[5184001], Repeat:[807078], DQ:[4376921]
 [m3vpss ]  86427615: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 5140148, HDDAC(BP0) 5182888, DVO2(BP1) 5182888, SDDAC(SEC1) 5180034
 [m3vpss ]  86427615: SYSTEM  : FREE SPACE : System Heap      = 67520 B, Mbx = 10240 msgs)
 [m3vpss ]  86427615: SYSTEM  : FREE SPACE : SR0 Heap         = 8684544 B (8 MB)
 [m3vpss ]  86427616: SYSTEM  : FREE SPACE : Frame Buffer     = 22591872 B (21 MB)
 [m3vpss ]  86427616: SYSTEM  : FREE SPACE : Bitstream Buffer = 142195584 B (135 MB)
 [m3vpss ]  86427616: SYSTEM  : FREE SPACE : Tiler Buffer     = 224 B (0 MB)  - TILER OFF
 [m3video] DECLINK_H264:HEAPID:0	USED:2368
 [m3video] DECLINK_H264:HEAPID:3	USED:4505600
 [m3video]  96036862: DECODE: Creating CH0 of 720 x 576 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
 [m3vpss ]  96036865: SWMS    : ******* Configuring clock 15 secs...
 [m3video]  96036862: DECODE: CH0: Decoder Create CH done!!!
 [m3vpss ]  96036865: SWMS0    : Loading Vertical Co-effs (14/16)x ...
 [m3vpss ]  96036865: SWMS0    : Loading Horizontal Co-effs (1/1)x ...
 [m3vpss ]  96036865: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    0 |   0 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |    0,    0 |   960 x    540 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |    ON |
 [m3vpss ]
 [m3video] 96036882:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] ALGPROCESS FAILED:STATUS
 [m3video] outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0x1421
 [m3video] Sequence called number 1
 [m3video] Sequence called number 2
 [m3video] 96036883:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 3
 [m3video] 96036898:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 4
 [m3video] 96036962:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 5
 [m3video] 96036994:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 6
 [m3video] 96037042:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 7
 [m3video] 96037090:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 8
 [m3video] 96037106:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 9
 [m3video] 96037138:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 10
 [m3video] 96037186:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 11
 [m3video] 96037250:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 12
 [m3video] 96037266:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 13
 [m3video] 96037298:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 14
 [m3video] 96037330:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 15
 [m3video] 96037362:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 16
 [m3video] 96037426:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 17
 [m3video] 96037490:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 18
 [m3video] 96037506:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 19
 [m3video] 96037554:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 20
 [m3video] 96037586:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 21
 [m3video] 96037634:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 22
 [m3video] 96037682:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 23
 [m3video] 96037698:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 24
 [m3video] 96037762:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 25
 [m3video] 96037778:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 26
 [m3video] 96037826:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 27
 [m3vpss ]  96041734: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  96041734: SWMS0    : Loading Vertical Co-effs (1/1)x ...
 [m3vpss ]  96041734: SWMS0    : Loading Horizontal Co-effs (1/1)x ...
 [m3vpss ]  96041734: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    0 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,    0 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |   OFF |
 [m3vpss ]    1 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  640,    0 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]    2 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1280,    0 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]    3 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  360 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]    4 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  640,  360 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |   OFF |
 [m3vpss ]    5 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1280,  360 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |   OFF |
 [m3vpss ]    6 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  720 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |   OFF |
 [m3vpss ]    7 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  640,  720 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |   OFF |
 [m3vpss ]    8 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1280,  720 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |   OFF |
 [m3vpss ]
 [m3vpss ]  96041739: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  96041739: SWMS0    : Loading Vertical Co-effs (9/16)x ...
 [m3vpss ]  96041739: SWMS0    : Loading Horizontal Co-effs (14/16)x ...
 [m3vpss ]  96041739: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    0 |   0 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |    0,    0 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]
 [m3video] DECLINK: ERROR!!! During Channel Open, CH1 is alreday in open state (opened earlier): close first and try open the channel again
 [m3video]
 [m3vpss ]  96166852: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  96166852: SWMS0    : Loading Vertical Co-effs (9/16)x ...
 [m3vpss ]  96166853: SWMS0    : Loading Horizontal Co-effs (14/16)x ...
 [m3vpss ]  96166853: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    1 |   1 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   |  640,    0 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |    ON |
 [m3vpss ]    4 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  640,  360 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]    5 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1280,  360 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]    6 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  720 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]    7 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  640,  720 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]    8 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1280,  720 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  422I  |    ON |
 [m3vpss ]
 [m3video] DEC_LINK: CH1 decoder changing resolution
 [m3video]  96166866: DECODE: CH1: Decoder flush needed (540049665)!!!
 [m3video]  96166866: DECODE: CH1: Decoder Flushing !!!
 [m3video] 96166867:DECLINK::links_m3video/iva_dec/decLink_h264.c:[493]::INTERNAL ERROR:-1
 [m3video] outArgs->viddec3OutArgs.extendedError for channel 1 with Resolution chnage Error: 0x20208001
 [m3video] 96166930:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x4000
 [m3video] Sequence called number 44659
 [m3video] 96166944:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 44660
 [m3video] 96166946:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 44661
 [m3video] 96166977:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 44662
 [m3video] 96167026:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 44663
 [m3video]  96167026: DECODE: CH1: Decoder flush needed (16384)!!!
 [m3video]  96167026: DECODE: CH1: Decoder Flushing !!!
 [m3video] DEC Link: Forced flush due to all dec ouputbuffers are locked-up inside the codec lib
 [m3video] 96167041:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 44664
 [m3video]  96167042: DECODE: CH1: Decoder flush needed (16384)!!!
 [m3video]  96167042: DECODE: CH1: Decoder Flushing !!!
 [m3video] DECLINK: ERROR!!! During Channel Open, CH2 is alreday in open state (opened earlier): close first and try open the channel again
 [m3video]
 [m3vpss ]  96175217: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  96175217: SWMS0    : Loading Vertical Co-effs (9/16)x ...
 [m3vpss ]  96175217: SWMS0    : Loading Horizontal Co-effs (14/16)x ...
 [m3vpss ]  96175217: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   | 1280,    0 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |    ON |
 [m3vpss ]
 [m3video] DECLINK: ERROR!!! During Channel Open, CH3 is alreday in open state (opened earlier): close first and try open the channel again
 [m3video]
 [m3vpss ]  96184036: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  96184036: SWMS0    : Loading Vertical Co-effs (9/16)x ...
 [m3vpss ]  96184036: SWMS0    : Loading Horizontal Co-effs (14/16)x ...
 [m3vpss ]  96184036: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    2 |   2 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   | 1280,    0 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    3 |   3 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,  360 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |    ON |
 [m3vpss ]
 [m3video] 96191571:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] outArgs->viddec3OutArgs.extendedError for channel 2 Error: 0x1409
 [m3video] Sequence called number 132433
 [m3video] DECLINK: ERROR!!! During Channel Open, CH4 is alreday in open state (opened earlier): close first and try open the channel again
 [m3video]
 [m3vpss ]  96192653: SWMS    : ******* Configuring clock 15 secs...
 [m3vpss ]  96192653: SWMS0    : Loading Vertical Co-effs (9/16)x ...
 [m3vpss ]  96192653: SWMS0    : Loading Horizontal Co-effs (14/16)x ...
 [m3vpss ]  96192653: SWMS    : Co-effs Loading ... DONE !!!
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    3 |   3 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |    0,  360 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    4 |   4 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |  640,  360 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |    ON |
 [m3vpss ]
 [m3video] DECLINK: ERROR!!! During Channel Open, CH5 is alreday in open state (opened earlier): close first and try open the channel again
 [m3video]
 [m3video] DEC_LINK: CH5 decoder changing resolution
 [m3vpss ]  96231339: SWMS    : ******* Configuring clock 15 secs...
 [m3video]  96231346: DECODE: CH5: Decoder flush needed (540049665)!!!
 [m3vpss ]  96231339: SWMS0    : Loading Vertical Co-effs (9/16)x ...
 [m3video]  96231346: DECODE: CH5: Decoder Flushing !!!
 [m3vpss ]  96231339: SWMS0    : Loading Horizontal Co-effs (14/16)x ...
 [m3vpss ]  96231339: SWMS    : Co-effs Loading ... DONE !!!
 [m3video] 96231347:DECLINK::links_m3video/iva_dec/decLink_h264.c:[493]::INTERNAL ERROR:-1
 [m3video] outArgs->viddec3OutArgs.extendedError for channel 5 with Resolution chnage Error: 0x20208001
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]
 [m3vpss ]    4 |   4 |    0,    0 |  1920 x   1080 |  2048 /  2048 | NON-TILED   |  640,  360 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
 [m3vpss ]    5 |   5 |    0,    0 |   704 x    576 |   896 /   896 | NON-TILED   | 1280,  360 |   640 x    360 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |    ON |
 [m3vpss ]
 [m3video] 96231410:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] outArgs->viddec3OutArgs.extendedError for channel 5 Error: 0x4000
 [m3video] Sequence called number 133845
 [m3video] 96231533:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 133846
 [m3video] 96231543:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 133847
 [m3video] 96231554:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 133848
 [m3video] 96231559:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 133849
 [m3video]  96231559: DECODE: CH5: Decoder flush needed (16384)!!!
 [m3video]  96231559: DECODE: CH5: Decoder Flushing !!!
 [m3video]  96231560: DECODE: CH5: Decoder Flushing !!!
 [m3video] 96231598:DECLINK::links_m3video/iva_dec/decLink_h264.c:[379]::INTERNAL ERROR:-1
 [m3video] Sequence called number 133850
 [m3video]  96231598: DECODE: CH5: Decoder flush needed (16384)!!!
 [m3video]  96231598: DECODE: CH5: Decoder Flushing !!!
 [m3video]  96231619: Assertion @ Line: 894 in links_m3video/iva_dec/decLink_common.c: (freeFrameInfo->pVdecOrgFrame == NULL) && (freeFrameInfo->vdecRefCount > 0) : failed !!!
root@HDMTerm:~#
root@HDMTerm:~#
root@HDMTerm:~#
root@HDMTerm:~#  [m3vpss ]  172827627: DISPLAY: HDDAC(BP0) : 10 fps, Latency (Min / Max) = ( 67 / 188 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 42 / 149 ) !!!
 [m3vpss ]  172827627: DISPLAY DRV: HDDAC(BP0) : Q:[7574136] Display:[10368000], Repeat:[2793865], DQ:[7574134]
 [m3vpss ]  172827627: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 5183990, HDDAC(BP0) 5183998, DVO2(BP1) 5183998, SDDAC(SEC1) 5184000
 [m3vpss ]  172827627: SYSTEM  : FREE SPACE : System Heap      = 67520 B, Mbx = 10238 msgs)
 [m3vpss ]  172827627: SYSTEM  : FREE SPACE : SR0 Heap         = 8610816 B (8 MB)
 [m3vpss ]  172827627: SYSTEM  : FREE SPACE : Frame Buffer     = 12667264 B (12 MB)
 [m3vpss ]  172827627: SYSTEM  : FREE SPACE : Bitstream Buffer = 139707264 B (133 MB)
 [m3vpss ]  172827628: SYSTEM  : FREE SPACE : Tiler Buffer     = 224 B (0 MB)  - TILER OFF
