J5 -Eco: Bit clock and frame sync generation from MCLK confirmation code
Other Parts Discussed in Thread: TVP5158
Please, verify below settings which i have applied for Master configuration and for transmitting bit clock and framesync to codec and Amplifier
Divider for :
MCA[4]_AHCLKX = 12.288MHz / (48kHz * 32 * 8) = 1-------->TDM8-32-bit-----------------Amplifier
MCA[0]_AHCLKX = 12.288MHz / (48kHz * 24 *4) = 2.67~3---------->I2S 24-bit --------------codec
MCA[2]_AHCLKX = 12.288MHz / (48kHz * 16 * 2) = 8---------->I2S 16-bit-----------------------codec
McAsp0 - 48khz,24 bit, 4 Channels(I2S mode)
sysclk=12288000;
ret = snd_soc_dai_set_sysclk(cpu_dai, 0, sysclk, SND_SOC_CLOCK_OUT);
if (ret < 0)
return ret;
ret = snd_soc_dai_set_clkdiv(cpu_dai, 0, 3);
if (ret < 0)
return ret;
McAsp2 - 48Khz,16 bit ,2 Channels (I2S mode)
if (ret < 0)
return ret;
ret = snd_soc_dai_set_clkdiv(cpu_dai, 0, 8);
if (ret < 0)
return ret;
McAsp4 - 48Khz,32 bit,4 channels (TDM mode)
if (ret < 0)
return ret;
ret = snd_soc_dai_set_clkdiv(cpu_dai, 0, 1);
if (ret < 0)
return ret
  • Manju,
    Can you also run the below executable on EVM and on your custom board. Let me know the console output.
    evm:~# ./mcasp_test
    2084.mcasp_test
    BR
    Pavel
  • Dear Pavel,
    On custom board,
    root@c6a811x-evm:/bin# ./mcasp_test
    Record open error: hw:0,0 :Invalid argument
    root@c6a811x-evm:~# aplay -l
    **** List of PLAYBACK Hardware Devices ****
    card 0: EVM [TI81XX EVM], device 0: AIC3X tlv320aic3x-hifi-0 []
    Subdevices: 1/1
    Subdevice #0: subdevice #0
    card 0: EVM [TI81XX EVM], device 1: AIC3X tlv320aic3x-hifi-1 []
    Subdevices: 1/1
    card 0: EVM [TI81XX EVM], device 2: AIC3X tlv320aic3x-hifi-2 []
    Subdevices: 1/1
    root@c6a811x-evm:~# arecord -l
    **** List of CAPTURE Hardware Devices ****
    Subdevices: 1/1
    Subdevices: 1/1
    Subdevices: 1/1
    On EVM,
    root@c6a811x-evm:/bin# aplay -l
    Subdevices: 0/1
    card 0: EVM [TI81XX EVM], device 1: hdmi HDMI-DAI-CODEC-1 []
    Subdevices: 0/1
    Audio MCLK set rate failed 6144000
    asoc: interface hdmi-dai hw params failed
    Input buffer overrun
  • manju gunnaiah said:
    On EVM,
    Subdevices: 0/1
    Subdevices: 0/1
    It seems to be able to open both playback and capture device on the EVM. Can you enable McASP0 (mapped on hw:0,0) and McASP4 (mapped on hw:0,1) on the EVM (same as in custom board) and try the application then.
    BR
    Pavel
  • Dear Pavel,
    On EVM enabled MCASP0 and MCASP4,
    Subdevices: 1/1
    Subdevices: 1/1
    card 0: EVM [TI81XX EVM], device 2: hdmi HDMI-DAI-CODEC-2 []
    Subdevices: 1/1
    Subdevices: 1/1
    Subdevices: 1/1
    root@c6a811x-evm:~# ./mcasp_test
    -sh: ./mcasp_test: Permission denied
    root@c6a811x-evm:~# chmod 777 mcasp_test
    davinci_pcm: Failed to get dma channels
    asoc: can't open platform davinci-pcm-audio
    Playback open error:hw:0,1 : Device or resource busy
    root@c6a811x-evm:~#
    Subdevices: 1/1
    Subdevices: 1/1
    Subdevices: 1/1
    Do you map McASP0 to hw:0,0, McASP4 to hw:0,1 and HDMI to hw:0,2? What about the default McASP2? Do you remove/disable McASP2 from the kernel?
    BR
    Pavel
  • Dear Pavel,
    Yes i disabled mcasp2 in kernel.
    Mapped McASP0 to hw:0,0, McASP4 to hw:0,1 and HDMI to hw:0,2
  • Dear Pavel,
    My Mcasp0 which is clock master  which is receiving data on two receiver lines AXR0 and AXR1 from codec.
    Both aplay and arecord are throwing  error,
    root@c6a811x-evm:~# arecord -D "hw:0,0" -f cd -t wav -c 2 track.wav
    Recording WAVE 'MCASP Port Format setting begins
    track.wav' : SigMCASP SND_SOC_DAIFMT_I2S
    ned 16 bit LittlBefore writing McASP4.PDIR = 0
    e Endian, Rate 4Before writing McASP0.PDIR = 0
    Before writing McASP2.PDIR = 0
    Before writing McASP4.AHCLKXCTL = 8000
    Before writing McASP0.AHCLKXCTL = 8000
    Before writing McASP2.AHCLKXCTL = 8000
    After writing McASP4.PDIR = 0
    After writing McASP0.PDIR = 14000000
    After writing McASP2.PDIR = 0
    After writing McASP4.AHCLKXCTL = 8000
    After writing McASP0.AHCLKXCTL = 8000
    After writing McASP2.AHCLKXCTL = 8000
    MCASP SND_SOC_DAIFMT_CBS_CFS
    MCASP SND_SOC_DAIFMT_NB_IF
    Sync set to Rising Edge...
     Setting MCASP as Clock out...!
    Setting complete MCASP as Clock out...!
    MCASP4 Global Transmit control register value = 0
    MCASP0 Global Transmit control register value = 0
    MCASP2 Global Transmit control register value = 0
    Entered BCLK divider
    Later MCASP4 Global Transmit control register value = 0
    Later MCASP0 Global Transmit control register value = 300
    Later MCASP2 Global Transmit control register value = 0
    MCASP2 AFSX control register value = 0
    MCASP0 AFSX control register value = 300
    Entered BCLK/LRCLK ratio
    PCM format for 16-bit set
    Enters the channel configuration
    Enters the channel size for 16-word
    mcasp start for Capture
    Settings made on global control register for Receive clock
    MCASP stop reception triggered
    arecord: pcm_read:1785: read error: Input/output error
    root@c6a811x-evm:~# aplay -D "hw:0,0" -c 8 -r 48000 -f S32_LE 04Track.raw
    Playing raw dataMCASP Port Format setting begins
    '04Track.raw' :MCASP SND_SOC_DAIFMT_I2S
    Signed 32 bit LBefore writing McASP4.PDIR = 14000001
    ittle Endian, RaBefore writing McASP0.PDIR = 14000000
    te 48000 Hz, ChaBefore writing McASP2.PDIR = 0
    nnels 8
    Before writing McASP4.AHCLKXCTL = 0
    Before writing McASP0.AHCLKXCTL = 0
    After writing McASP4.PDIR = 14000001
    After writing McASP4.AHCLKXCTL = 0
    After writing McASP0.AHCLKXCTL = 0
    MCASP4 Global Transmit control register value = 1300
    MCASP0 Global Transmit control register value = 313
    Later MCASP4 Global Transmit control register value = 1300
    Later MCASP0 Global Transmit control register value = 313
    MCASP0 AFSX control register value = 313
    playback started near FSXDUR
    PCM format for 32-bit set
    Enters the channel size for 32-word
    mcasp start for playback
    Settings made on global control register for Transmit clock
    MCASP stop transmission triggered
    aplay: pcm_write:1694: write error: Input/output error
    static u8 ti811x_iis_serializer_direction_mcasp0[] = {
        RX_MODE,    RX_MODE,    INACTIVE_MODE,    INACTIVE_MODE,
        INACTIVE_MODE,    INACTIVE_MODE,    INACTIVE_MODE,    INACTIVE_MODE,
         .tx_dma_offset  = 0x46000000,
             .rx_dma_offset  = 0x46000000,
             .op_mode        = DAVINCI_MCASP_IIS_MODE,
             .num_serializer = ARRAY_SIZE(ti811x_iis_serializer_direction_mcasp0),
             .tdm_slots      = 2,
             .serial_dir     = ti811x_iis_serializer_direction_mcasp0,
             .asp_chan_q     = EVENTQ_2,
             .version        = MCASP_VERSION_2,
             .txnumevt    = 16,
         .rxnumevt    = 16,
         .clk_input_pin    = MCASP_AHCLKX_IN,
    aplay on MCASP2 and MCASP4 are working fine and they use single serializer AXR0 in TX_MODE.I can see on oscilloscope on data lines.
  • Manju,
    Let switch back to your custom board for a while.
    On custom board,
    Subdevices: 1/1
    It seems to me McASP0 is mapped on hw:0,0. Do you have TVL320AIC3x codec connected to McASP0? If no, that might be the reason for the problem.
    BR
    Pavel
  • Dear Pavel,
    On Custom board,
    My Mcasp0 which is clock master which is receiving data on two receiver lines AXR0 and AXR1 from codec.MCASP0 is connected to codec but not TVL320AIC3x codec. Another codec DiRANA3 -SAF7751EL over i2s lines.
    nnels 8
    .tdm_slots = 2,
    .txnumevt = 16,
    .rxnumevt = 16,
  • Manju,
    Then you should change AIC3x to DiRANA for McASP0.
    over i2s lines.
    Do you mean I2C?
    BR
    Pavel
  • Dear Pavel,
    DiRANA3 doesn't require driver to initialize from J5-Eco .It has firmware in it which gets initialized over I2C when powered on.
    DiRANA3 receives bit clock and frame sync from MCASP0 and sends data to MCASP0 AXR0 and AXR1 lines.
    I have given dummy reference to TVL320AIC3x codec driver inorder to register as alsa sound card.
    MCASP 2 is also connected to DIRANA3 and MCASP2 is sending bit clock,frame sync to Dirana3.MCASP2 transmits data to DiRANA3 over AXR0.Which is successful i verified on oscilloscope.
    Both MCASP0 and MCASP2 are in I2S mode and same configuration.Only change is MCASP0 is with two serializer for receiving and MCASP2 has one serilaizer for transmitting.
    But MCASP0 is neither transmitting nor receiving.I tried by setting both TX_MODE and RX_MODE.
  • Manju,
    Are McASP0 and McASP2 configured for the same dummy codec? If yes, can you try to set different dummy codecs for McASP0 and McASP2?
    Do you see data with the scope on McASP0 AXR0/1 data pins?
    BR
    Pavel
  • Dear Pavel,
    Yes, McASP0 and McASP2 configured for the same dummy codec.
    Yes, i saw data with the scope on McASP0 AXR0/1 data pins
    I have also configured MCASP4 also to the same dummy codec.MCASP4 is transmitting data to Amplifier.I'm able to see on oscilloscope and amplifier is playing.
    Why not MCASP0?
    RSTAT register value i printed using devmem2 for MCASP0-0x48038080---->0x00000104
    RCKFAIL=1 and RERR =1 as per above value.
    TSTAT register value i printed using devmem2 for MCASP0-0x480380c0---->0x00000154
  • Manju,
    So McASP0/2/4 are configured for the same dummy codec, and McAP2/4 can transmit/output data to Amplifier successful? McASP2/4 are using only AXR0 in TX_MODE?
    Can you try configure the McASP0 to transmit/output data on AXR0 (TX_MODE) only?
    Please provide me the console output of the "aplay -l" and aplay command for all McASP0/2/4.
    BR
    Pavel
  • Dear Pavel,
    Yes,McASP0/2/4 are configured for the same dummy codec, and McAP2/4 can transmit/output data to Amplifier successful.
    Yes i configured the McASP0 to transmit/output data on AXR0 (TX_MODE) only. Below is the logs:
      Subdevices: 1/1
      Subdevices: 1/1
      Subdevices: 1/1
    root@c6a811x-evm:~# aplay -D "hw:0,0" -c 8 -r 48000 -f S32_LE 04Track.raw------------------------MCASP0
    Playing raw data '04Track.raw' : Signed 32 bit LiMCASP Port Format setting begins
    ttle Endian, RatMCASP SND_SOC_DAIFMT_I2S
    e 48000 Hz, ChanBefore writing McASP4.PDIR = 0
    nels 8
    MCASP0 Global Receive control register value = 0
    MCASP0 Global Receive control register value = 300
    No.of serializers for MCASP ports used:16
    root@c6a811x-evm:~# aplay -D "hw:0,1" -c 8 -r 48000 -f S32_LE 04Track.raw-----------------------------------MCASP4
    '04Track.raw' :MCASP SND_SOC_DAIFMT_DSP_B
    Signed 32 bit LBefore writing McASP4.PDIR = 0
    ittle Endian, RaBefore writing McASP0.PDIR = 14000001
    nnels 8
    After writing McASP4.PDIR = 14000000
    After writing McASP0.PDIR = 14000001
    MCASP SND_SOC_DAIFMT_IB_NF
    MCASP0 Global Transmit control register value = 1300
    MCASP0 Global Receive control register value = 1300
    Later MCASP4 Global Transmit control register value = 300
    Later MCASP0 Global Transmit control register value = 1300
    MCASP0 AFSX control register value = 1300
    Transmitter Framesync duty cycle shifts to 1-word for TDM mode
    root@c6a811x-evm:~# aplay -D "hw:0,2" -c 8 -r 48000 -f S32_LE 04Track.raw--------------------------MCASP2
    nnels 8
    After writing McASP2.PDIR = 14000000
    Later MCASP2 Global Transmit control register value = 300
    MCASP2 AFSX control register value = 300
  • Manju,
    Do you have valid signals on McASP0 clocks and AXR0 (TX_MODE) pin?
    Check I2C settings and pinmux for the codec attached to McASP0. Make sure you have correct communication between J5Eco/I2C and external codec attached to McASP0.
    Check external codec (attached to McASP0) settings.
    Check McASP0 pinmux and registers settings and compare with McASP2/4.
    Check with aplay -D "plughw:0,0" -c 8 -r 48000 -f S32_LE 04Track.raw -v
  • Dear Pavel,
    Yes, i have valid signals on McASP0 clocks. But no data on AXR0 (TX_MODE) pin for MCASP0.
    Codec settings is proper.As i can see data on data pins of codec on oscilloscope.
    Pinmux for mcasp:
    omap_mux_init_signal("mcasp0_aclkx_ti811x", 0 );
    omap_mux_init_signal("mcasp0_fsx_ti811x", 0 );
    omap_mux_init_signal("mcasp0_axr0_ti811x",0 );
    omap_mux_init_signal("mcasp0_axr1_ti811x",0);
    omap_mux_init_signal("mcasp2_aclkx_ti811x", 0 );
    omap_mux_init_signal("mcasp2_fsx_ti811x",0 );
    omap_mux_init_signal("mcasp2_axr0_ti811x",0 );
    omap_mux_init_signal("mcasp2_axr1_ti811x", 0 );
    omap_mux_init_signal("mcasp4_aclkx_ti811x", 0 );
    omap_mux_init_signal("mcasp4_fsx_ti811x", 0 | TI814X_SLEW_SLOW);
    omap_mux_init_signal("mcasp4_axr0_ti811x", 0 | TI814X_SLEW_SLOW);
    Below, aplay -D "plughw:0,0" -c 8 -r 48000 -f S32_LE 04Track.raw -v log:
    root@c6a811x-evm:~# aplay -D "plughw:0,0" -c 8 -r 48000 -f S32_LE 04Track.raw -v
    Playing raw data '04Track.raw' : Signed 32 bit LMCASP Port Format setting begins
    ittle Endian, RaMCASP SND_SOC_DAIFMT_I2S
    te 48000 Hz, ChaBefore writing McASP4.PDIR = 0
    nnels 8
    Plug PCM: Hardware PCM card 0 'TI81XX EVM' device 0 subdevice 0
    Its setup is:
    stream : PLAYBACK
    access mcasp start for playback
    : RW_INTERLEAVED
    format : S32_LE
    subformat : STD
    channels : 8
    rate : 48000
    exact rate : 48000 (48000/1)
    msbits : 32
    buffer_size : 4096
    period_size : 256
    period_time : 5333
    tstamp_mode : NONE
    period_step : 1
    avail_min : 256
    period_event : 0
    start_threshold : 4096
    stop_threshold : 4096
    silence_threshold: 0
    silence_size : 0
    boundary : 1073741824
    appl_ptr : 0
    hw_ptr : 0
    aplay: pcm_writeMCASP stop transmission triggered
  • Manju,
    But don't you connect AXR0 data pin to codec data pin? If not, to which codec pin you connect AXR0 data pin? I am confused because you see data on codec data pin, but do not see data on McASP0 data pin, but this should be the same pin!
    Pinmux for mcasp:
    Can you provide me McASP0/2/4 pinmux values after aplay command, get these with devmem2.
    BR
    Pavel
  • Dear Pavel,
    MCASP0 AXR0 and AXR1 both are connected to codec chip DiRANA3.Codec Dirana3 is getting clocks from MCAP0 which is Master.
    MCASP0_AXR0<----------------------------->i2s0_out_dirana3
    MCASP0_AXR1<----------------------------->i2s1_out_dirana3
    Data from dirana3 i2s out pins i verified on oscilloscope it showing data and the same is available to MCASP0 AXR0 and AXR1 pins also.
    But MCASP0 is not able to read the data on AXR0 and AXR1 pins.
    Pinmux for MCASP0, MCASP2 and MCASP4.
    MCASP0
    root@c6a811x-evm:~# devmem2 0x48140840
    /dev/mem opened.
    Memory mapped at address 0x4022f000.
    Read at address  0x48140840 (0x4022f840): 0x00000001
    root@c6a811x-evm:~# devmem2 0x48140844
    /dev/mem opened.
    Memory mapped at address 0x40356000.
    Read at address  0x48140844 (0x40356844): 0x00000001
    root@c6a811x-evm:~# devmem2 0x48140850
    /dev/mem opened.
    Memory mapped at address 0x402a5000.
    Read at address  0x48140850 (0x402a5850): 0x00000001
    root@c6a811x-evm:~# devmem2 0x48140854
    /dev/mem opened.
    Memory mapped at address 0x40261000.
    Read at address  0x48140854 (0x40261854): 0x00000001
    MCASP2
    root@c6a811x-evm:~# devmem2 0x48140898
    /dev/mem opened.
    Memory mapped at address 0x402fd000.
    Read at address  0x48140898 (0x402fd898): 0x00000001
    root@c6a811x-evm:~# devmem2 0x4814089C
    /dev/mem opened.
    Memory mapped at address 0x40270000.
    Read at address  0x4814089C (0x4027089c): 0x00000001
    root@c6a811x-evm:~# devmem2 0x481408A0
    /dev/mem opened.
    Memory mapped at address 0x402e6000.
    Read at address  0x481408A0 (0x402e68a0): 0x00000001
    MCASP4
    root@c6a811x-evm:~# devmem2 0x481408C8
    /dev/mem opened.
    Memory mapped at address 0x4011f000.
    Read at address  0x481408C8 (0x4011f8c8): 0x00000001
    root@c6a811x-evm:~# devmem2 0x481408CC
    /dev/mem opened.
    Read at address  0x481408CC (0x402fd8cc): 0x00080001
    root@c6a811x-evm:~# devmem2 0x481408D0
    /dev/mem opened.
    Memory mapped at address 0x4025a000.
    Read at address  0x481408D0 (0x4025a8d0): 0x00080001
  • Manju,
    Still not clear to me. One post you state you need to receive, other post you state you need to transmit, then start over again and again in a loop.
    What I though is you try now to output/trasmit from McASP0 AXR0 to outside the device (to Dirana3). But from the your last post, it seems you need to receive on McASP0 AXR0.
    Do you need to output/transmit audio data from McASP0 AXR0 to Dirana3? Or you need to input/receive audio data from Dirana3 to McASP0 AXR0?
    BR
    Pavel
  • Dear Pavel,
    In our case MCASP0 needs to receive data from Dirana3.MCASP0 provides clocks to DiRANA3 since it is master.
    I told you transmit/receive scenario earlier posts inorder to clear you that on MCASP0 neither Data transmit nor Data receive is not happening.MCASP0 is able to produce bitclock and frame sync as a Master.
    I need input/receive audio data from Dirana3 to McASP0 AXR0 and AXR1.
  • Manju,
    Let me clarify. You need to receive/input audio data from Dirana3 to McASP0 AXR0/1 pins. And you see data signals with scope on the connections/pins between Dirana3 and McASP0 AXR0/1?
    MCA[0]_AXR[0]/AH3 <-------------------- Dirana3
    MCA[0]_AXR[1]/AE6 <---------------------Dirana3
    The data signals goes to McASP0 AXR0/1 pins and then is lost (no data inside the McASP0 module)?
    And you have for this use case the below pinmux?
    MCA[0]_AXR[0]/PINCNTL21/0x48140850/AH3 = 0x00000001
    MCA[0]_AXR[1]/PINCNTL22/0x48140854/AE6 = 0x00000001
    BR
    Pavel
  • Dear Pavel,
    Yes, I need to receive/input audio data from Dirana3 to McASP0 AXR0/1 pins. And I see data signals with scope on the connections/pins between Dirana3 and McASP0 AXR0/1
    Yes, data signals goes to McASP0 AXR0/1 pins and then is lost (no data inside the McASP0 module).
    Yes, for my usecase i have below pinmux:
  • Manju,
    These are settings for output pins. To make AXR0/1 inputs, make the below changes (I also fix bit 19 for FSX and AXR0/1):
    omap_mux_init_signal("mcasp0_aclkx_ti811x", 0);
    omap_mux_init_signal("mcasp0_fsx_ti811x", 0 | TI814X_SLEW_SLOW );
    omap_mux_init_signal("mcasp0_axr0_ti811x",0 | TI814X_SLEW_SLOW | TI814X_INPUT_EN );
    omap_mux_init_signal("mcasp0_axr1_ti811x",0 | TI814X_SLEW_SLOW | TI814X_INPUT_EN);
    After these changes, check again McASP0 pins with scope, check if you have data received inside McASP0 module, and check McASP0 pinmux registers with devmem2.
    BR
    Pavel
  • Dear Pavel,
    After above modification also mcasp0 is not able to receive data.
    arecord -D "hw:0,0" -c 8 -r 48000 -f S32_LE -d 120 t1.raw
    Recording WAVE 'tlv320aic23_write cannot write 002 to register R7
    t1.raw' : SignedMCASP Port Format setting begins
    32 bit Little EMCASP SND_SOC_DAIFMT_I2S
    ndian, Rate 4800Before writing McASP4.PDIR = 0
    0 Hz, Channels 8Before writing McASP0.PDIR = 0
    tlv320aic23_write cannot write 07c to register R8
    tlv320aic23_write cannot write 00e to register R7
    tlv320aic23_write cannot write 001 to register R9
    tlv320aic23_write cannot write 045 to register R6
    tlv320aic23_write cannot write 041 to register R6
    tlv320aic23_write cannot write 004 to register R5
    tlv320aic23_write cannot write 000 to register R9
    tlv320aic23_write cannot write 047 to register R6
    Pin mux for MCASP0:
    /dev/mem opened.
    Memory mapped at address 0x4027c000.
    Read at address  0x48140840 (0x4027c840): 0x00000001
    /dev/mem opened.
    Memory mapped at address 0x402d6000.
    Read at address  0x48140844 (0x402d6844): 0x00080001
    /dev/mem opened.
    Read at address  0x48140850 (0x4022f850): 0x000C0001
    /dev/mem opened.
    Memory mapped at address 0x40200000.
    Read at address  0x48140854 (0x40200854): 0x000C0001
    AFSXCTL
    root@c6a811x-evm:~# devmem2 0x480380AC
    /dev/mem opened.
    Memory mapped at address 0x40223000.
    Read at address  0x480380AC (0x402230ac): 0x00000112
    ACLKXCTL
    root@c6a811x-evm:~# devmem2 0x480380B0
    /dev/mem opened.
    Memory mapped at address 0x402b7000.
    Read at address  0x480380B0 (0x402b70b0): 0x000000A3
    AHCLKXCTL
    root@c6a811x-evm:~# devmem2 0x480380B4
    /dev/mem opened.
    Memory mapped at address 0x402cb000.
    Read at address  0x480380B4 (0x402cb0b4): 0x00000000
  • Manju,
    Can you try with:
    arecord -D "plughw:0,0" -c 8 -r 48000 -f S32_LE -d 120 t1.raw -v
    Are you using tlv320aic23 codec for McASP0? This might be the issue here.
    McASP2 (default settings) use /sound/soc/codecs/tlv320aic3x.c
    .codec_dai_name = "tlv320aic3x-hifi",
    .codec_name = "tlv320aic3x-codec.1-0018",
    HDMI (default settings) use /sound/soc/codecs/ti81xx_hdmi.c
    .codec_dai_name = "HDMI-DAI-CODEC",     /* DAI name */
    .codec_name = "hdmi-dummy-codec",
    While your McASP0 seems to use /sound/soc/codecs/tvl320aic23.c. Can you check why?
    You might need Darina3 codec driver or at least use dummy codec driver. See the below pointers for more info:
    1. processors.wiki.ti.com/index.php/TI811X_PSP_AUDIO_Driver_User_Guide#FAQ - Add the support in ALSA SoC Driver
    2. processors.wiki.ti.com/index.php/TI811X_PSP_AUDIO_Driver_User_Guide#FAQ > Audio.zip -> Audio.ppt -> Using a different Codec
    3.
    Your McASP0 pinmux settings looks correct now. Please provide me the values of all the McASP0 registers (base address 0x48038000) after arecord, take them with devmem2.
    BR
    Pavel
  • Dear Pavel,
    Earlier MCASP0, MCASP2 and MCASP4 use tlv320aic3x codec driver.
    To resolve alsa multiple device opening issue.I gave MCASP0 to refer codec driver for tlv320aic23.
    MCASP0 and MCASP4 still use tlv320aic3x codec driver.
    Darina3 codec driver is not required as it has firmware already in it.It is initilaized from userspace application using I2C.
    So no Codec driver is required.
    Instead of dummy driver i have given reference to tlv320aic23(MCASP0) and tlv320aic3x(MCASP2,MCASP4) codec driver.
    Below is the pinmux after arecord:
    /dev/mem opened.
    Memory mapped at address 0x40319000.
    Read at address  0x48140840 (0x40319840): 0x00000001
    /dev/mem opened.
    Memory mapped at address 0x40221000.
    Read at address  0x48140844 (0x40221844): 0x00080001
    /dev/mem opened.
    Memory mapped at address 0x402b8000.
    Read at address  0x48140850 (0x402b8850): 0x000C0001
    /dev/mem opened.
    Memory mapped at address 0x40215000.
    Read at address  0x48140854 (0x40215854): 0x000C0001
    Does this resolve the multiple device opening issue?
    If you give McASP0 the hdmi codec, will be there any improvement?
    If you give McASP0 the tvl320aic3x codec, will be there any improvement?
    I think you should also try with dummy codec driver for McASP0 (I provide hints for dummy codec driver in my previous post).
    Your McASP0 pinmux settings looks correct. Please provide me the values of all the McASP0 registers (base address 0x48038000) after arecord, take them with devmem2.
    BR
    Pavel
  • Dear Pavel,
    Please find the attached MCASP0 base registers.2548.MCASP_REGISTER_DUMPS.pdf
  • Dear Pavel,
    Please find the attached McASP0 registers (base address 0x48038000) after arecord,
    8206.MCASP_REGISTER_DUMPS.pdf
  • Manju,
    How exactly you define that there is no data in McASP0 module? Do you check RBUF0/1 registers? I do not see these registers in your register dump pdf.
    BR
    Pavel
  • Dear Pavel,
    arecord is failing.
    arecord will be successful if data is there in Receive buffer and i would have got file with audio data.
    Below is the receive buffer dump:
    root@c6a811x-evm:~# devmem2 0x48038280
    /dev/mem opened.
    Memory mapped at address 0x40305000.
    Read at address 0x48038280 (0x40305280): 0x00000000
    root@c6a811x-evm:~# devmem2 0x48038281
    /dev/mem opened.
    Memory mapped at address 0x40236000.
    Read at address 0x48038281 (0x40236280): 0x00000000
  • Dear Misael,
    As per your suggestion i modified below mux lines:
    omap_mux_init_signal("mcasp0_axr0_ti811x",1 | TI814X_SLEW_SLOW | TI814X_INPUT_EN );
    omap_mux_init_signal("mcasp0_axr1_ti811x",1 | TI814X_SLEW_SLOW | TI814X_INPUT_EN);
    But still read is failing when i run arecord :arecord -D "hw:0,0" -c 8 -r 48000 -f S32_LE -d 120 t1.raw
    I have attached the register dump while running arecord command for MCASP0.
    1307.MCASP0_RX_REGISTER_DUMPS.xlsx
  • Dear Pavel,
    To test the driver i configured MCASP2 as receiver with same format as MCASP0.
    But MCASP2 is receiving and arecord command is successful it recorded for 120 secs in desired audio format.
    MCASP0 failed with error when i use arecord command.
  • Dear Pavel,
    I'm able to Transmit and receive from AXR0 and only Transmit over AXR1.
    I got these result by below settings:
    In devices.c
    , mux for pins:
        omap_mux_init_signal("mcasp0_fsx_ti811x",   0 | TI814X_SLEW_SLOW | TI814X_PULL_DIS );
        omap_mux_init_signal("mcasp0_axr0_ti811x",  0 | TI814X_SLEW_SLOW | TI814X_INPUT_EN | TI814X_PULL_DIS );
        omap_mux_init_signal("mcasp0_axr1_ti811x",  0 | TI814X_SLEW_SLOW | TI814X_INPUT_EN | TI814X_PULL_DIS);
    In board file,
        TX_MODE(AXR0),    RX_MODE(AXR1),    INACTIVE_MODE,    INACTIVE_MODE,
    Serializer direction  if i set to TX_MODE for AXR0 which is able to transmit and receive over the same pin.
    Then, if i set AXR0 pin as  INACTIVE_MODE and Make AXR1 as TX_MODE its is able to only transmit, but receiving failed.
    If i set both AXR0 and AXR1 serializer direction to RX_MODE neither transmit nor receive is happening.
    Why is this changing for MCASP0.Even though MCASP2 is also configured in the same I2S mode.
    Can you also provide me the latest version of your davinci-evm.c file?
    BR
    Pavel
  • Manju,
    Can you also try to set bit clock MCA[0]_ACLKX to input, will be there any improvement?
    omap_mux_init_signal("mcasp0_aclkx_ti811x", 0 | TI814X_INPUT_EN) ;
    Can you also try to set FS MCA[0]_AFSX to input, will be there any improvement?
    omap_mux_init_signal("mcasp0_fsx_ti811x", 0 | TI814X_SLEW_SLOW | TI814X_INPUT_EN );
    BR
    Pavel
  • Dear Pavel,
    In devices.c
    , mux for pins:
    In board file,
    Please find the attached davinci_evm.c file1307.davinci-evm.c
  • Dear Pavel,
    Device opening issue was since mcasp0 and mcasp4 using the same codec driver the control port will be only one I2C port.So, when alsa tries to open same control port: mcasp0 opens successfully and when mcasp4 tries to open same control port, it shows resource busy.
    So i gave mcasp0 codec driver reference to tlv320aic23 and new I2C port i gave reference.It solved.
  • Manju,
    On TI EVM, MCA2_AXR0 (TX_MODE) pin has external pull down resistor, and has 0x000E0001 as a pin mux value. MCA2_AXR1 (RX_MODE) pin has no external pull down resistor, and has 0x000E0001 as a pin mux value.
    What about your custom board? Do you have external pull resistors for the McASP0 AXR0/1 pins? There are also serial resistors on the AXR0/1 pins in TI EVM, do you have the same for custom board?
    BR
    Pavel
    Compare the HW design, pinmux and registers settings between McASP0 and McASP2 and align.
    BR
    Pavel
  • Dear Pavel,
    But Pavel we are using both MCA0_AXR0(RX_MODE) and MCA0_AXR1 (RX_MODE), it is not able to receive. There is pull down resistor required for receiving as per J5-eco EVM schematic.Our custom board also has serial resistors for MCA0_AXR0 and MCA0_AXR1 lines.
    MCA0_AXR0 started working when i configured in TX_MODE .Both transmit and receiving is happening in the same mode.
    Pin MCA0_AXR1 works only if i disable the MCA0_AXR0( INACTIVE_MODE), make it TX_MODE.
  • Manju,
    There is no external pull down resistor attached on the MCASP2 AXR1 (RX_MODE) pin on the J5Eco EVM. Can you double check this?
    Also I have test the below configurations:
    TX_MODE (AXR0), RX_MODE (AXR1) - this is the default configuration, it works fine.
    INACTIVE_MODE (AXR0), RX_MODE (AXR1) - works fine, I have t1.raw (3.1MB) file as result
    RX_MODE (AXR0), RX_MODE (AXR1) - does not work, gives "arecord: pcm_read:1785: read error: Input/output error", t1.raw is only 44 bytes
    I test with the below command:
    evm:~# arecord -D "hw:0,0" -c 2 -r 48000 -f S32_LE -d 8 t1.raw -v
    Recording WAVE 't1.raw' : Signed 32 bit Little Endian, Rate 48000 Hz, Stereo
    Its setup is:
     stream       : CAPTURE
     access       : RW_INTERLEAVED
     format       : S32_LE
     subformat    : STD
     channels     : 2
     rate         : 48000
     msbits       : 32
     buffer_size  : 16384
     period_size  : 1024
     period_time  : 21333
     tstamp_mode  : NONE
     period_step  : 1
     avail_min    : 1024
     period_event : 0
     start_threshold  : 1
     stop_threshold   : 16384
     silence_size : 0
     appl_ptr     : 0
     hw_ptr       : 0
    Can you test this mode: INACTIVE_MODE (AXR0), RX_MODE (AXR1) - this works fine on TI EVM.
    BR
    Pavel
  • Dear Pavel,
    In our custom board MCASP0_AXR0 and MCASP0_AXR1 both are receive pins.Both should work in RX_MODE.
    Hardware side both as serial resistors.
    Software pin mux is :
    and serializer direction is :
    If i configure MCASP0_AXRO as TX_MODE pin it can transmit and receive on the same pin.But in RX_MODE its is not able to receive.
    Why is it so?
  • Dear Pavel,
    Yes, MCASP0_AXR1 is working in RX_MODE, if i Make MCASP0_AXR0 in INACTIVE_MODE.
    But I'm receiving data on both AXR0 and AXR1 lines.I need to receive at a time on both.But, only one is active at a time.How to resolve this?
  • Manju,
    Let me clarify. You are able to receive audio data through AXR0 (RBUF0) and AXR1 (RBUF1), but not able to receive at the same time? Can you provide a console log when you try to get audio data at the same time?
    BR
    Pavel
  • Dear Pavel,
    I'm not able to receive audio data through AXR0 (RBUF0) and AXR1 (RBUF1) at a time.
    Only AXR0 (RBUF0) will be receiver and AXR1 (RBUF1) will not be enabled with serializer direction as tested above.
    At a time both AXR0 (RBUF0) and AXR1 (RBUF1) should be enabled as receivers and serializer direction to be RX_MODE.But this not happening in my case.
    Only one is active at a time.How can i make both AXR0 (RBUF0) and AXR1 (RBUF1) to be active receivers in RX_MODE.
  • Can you provide a console log when you try to get audio data at the same time?
  • case 1:
    static u8 x_iis_serializer_direction[] = {
    RX_MODE, INACTIVE_MODE, INACTIVE_MODE, INACTIVE_MODE,
    case 2:
    INACTIVE_MODE, RX_MODE, INACTIVE_MODE, INACTIVE_MODE,
    case 3:
    From what I understand, your board works for case 1 and case 2, but not for case 3?
    BR
    Pavel
  • Dear Pavel,
    Yes right,
    Only case1 and case2 works on my board.Not case3.
