J5 -Eco: Bit clock and frame sync generation from MCLK confirmation code
Other Parts Discussed in Thread: TVP5158
Please, verify below settings which i have applied for Master configuration and for transmitting bit clock and framesync to codec and Amplifier
Divider for :
MCA[4]_AHCLKX = 12.288MHz / (48kHz * 32 * 8) = 1-------->TDM8-32-bit-----------------Amplifier
MCA[0]_AHCLKX = 12.288MHz / (48kHz * 24 *4) = 2.67~3---------->I2S 24-bit --------------codec
MCA[2]_AHCLKX = 12.288MHz / (48kHz * 16 * 2) = 8---------->I2S 16-bit-----------------------codec
McAsp0 - 48khz,24 bit, 4 Channels(I2S mode)
sysclk=12288000;
ret = snd_soc_dai_set_sysclk(cpu_dai, 0, sysclk, SND_SOC_CLOCK_OUT);
if (ret < 0)
return ret;
ret = snd_soc_dai_set_clkdiv(cpu_dai, 0, 3);
if (ret < 0)
return ret;
McAsp2 - 48Khz,16 bit ,2 Channels (I2S mode)
if (ret < 0)
return ret;
ret = snd_soc_dai_set_clkdiv(cpu_dai, 0, 8);
if (ret < 0)
return ret;
McAsp4 - 48Khz,32 bit,4 channels (TDM mode)
if (ret < 0)
return ret;
ret = snd_soc_dai_set_clkdiv(cpu_dai, 0, 1);
if (ret < 0)
return ret
  • Manju,
    Can you have a try with the below modification:
    if (dir == SND_SOC_CLOCK_OUT) {
    //mcasp_set_bits(dev->base + DAVINCI_MCASP_AHCLKXCTL_REG, AHCLKXE);
    //mcasp_set_bits(dev->base + DAVINCI_MCASP_AHCLKRCTL_REG, AHCLKRE);
    //mcasp_set_bits(dev->base + DAVINCI_MCASP_PDIR_REG, AHCLKX);
    } else {
    After this modification, see if you have clock signals on McASP0/2/4 CLKX pins, and check about the values in McASP0/2/4 PDIR and AHCLKXCTL registers.
    BR
    Pavel
  • Dear Pavel,
    No clock on MCASP4.
    Below is the log:
    root@c6a811x-evm:/home/PCM# aplay -D "hw:0,0" -c 2 -r 48000 -f S16_LE 04Track.raw
    Playing raw dataMCASP Port Format setting begins
    '04Track.raw' :Before writing McASP4.PDIR = 0
    Signed 16 bit LBefore writing McASP0.PDIR = 0
    ittle Endian, RaBefore writing McASP2.PDIR = 0
    te 48000 Hz, SteBefore writing McASP4.AHCLKXCTL = 8000
    reo
    Before writing McASP0.AHCLKXCTL = 8000
    Before writing McASP2.AHCLKXCTL = 8000
    After writing McASP4.PDIR = 0
    After writing McASP0.PDIR = 14000000
    After writing McASP2.PDIR = 0
    After writing McASP4.AHCLKXCTL = 8000
    After writing McASP0.AHCLKXCTL = 8000
    After writing McASP2.AHCLKXCTL = 8000
    MCASP SND_SOC_DAIFMT_CBS_CFS
    MCASP SND_SOC_DAIFMT_NB_IF
    Setting MCASP as Clock out...!
    Setting complete MCASP as Clock out...!
    Entered MCLK divider
    aplay: pcm_write:1694: write error: Input/output error
    w
    Playing raw data '04Track.raw' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
    Before writing McASP0.PDIR = 14000000
    Before writing McASP0.AHCLKXCTL = 8007
    After writing McASP0.AHCLKXCTL = 8007
    root@c6a811x-evm:/home/PCM# aplay -D "hw:0,2" -c 2 -r 48000 -f S16_LE 04Track.ra
    w
    Signed 16 bit LBefore writing McASP0.PDIR = 14000000
    reo
    After writing McASP2.PDIR = 14000000
    root@c6a811x-evm:/home/PCM# aplay -D "hw:0,1" -c 2 -r 48000 -f S16_LE 04Track.ra
    w
    ittle Endian, RaBefore writing McASP2.PDIR = 14000001
    reo
    Before writing McASP2.AHCLKXCTL = 8007
    After writing McASP4.PDIR = 14000000
    After writing McASP2.PDIR = 14000001
    After writing McASP2.AHCLKXCTL = 8007
    MCASP SND_SOC_DAIFMT_IB_NF
  • manju gunnaiah said:
    No clock on MCASP4.
    Do you mean there is clock on McASP0/2 ACLKX pin, but no clock on McASP4 ACLKX pin?
    Provide me the values in McASP0/2/4 PDIR and AHCLKXCTL registers after the aplay command, using devmem2.
    BR
    Pavel
  • Dear Pavel,
    Yes there is clock on McASP0/2 ACLKX pin. But no clock on on McASP4_ACLKX pin,
    Below is the log for devmem2:
    root@c6a811x-evm:/home/PCM# aplay -D "hw:0,1" -c 2 -r 48000 -f S16_LE 04Track.raw----------MCASP4
    reo
    After writing McASP0.PDIR = 0
    root@c6a811x-evm:/home/PCM# devmem2 0x4a1a8014
    /dev/mem opened.
    Memory mapped at address 0x401e7000.
    Read at address  0x4A1A8014 (0x401e7014): 0x14000001
    root@c6a811x-evm:/home/PCM# devmem2 0x4a1a80b4
    /dev/mem opened.
    Memory mapped at address 0x402bc000.
    Read at address  0x4A1A80B4 (0x402bc0b4): 0x00188000
    root@c6a811x-evm:/home/PCM# aplay -D "hw:0,0" -c 2 -r 48000 -f S16_LE 04Track.raw-----------------MCASP0
     '04Track.raw' :Before writing McASP4.PDIR = 14000001
    te 48000 Hz, SteBefore writing McASP4.AHCLKXCTL = 188000
    reo
    After writing McASP4.PDIR = 14000001
    After writing McASP4.AHCLKXCTL = 188000
    root@c6a811x-evm:/home/PCM# devmem2 0x48038014
    /dev/mem opened.
    Memory mapped at address 0x402f7000.
    Read at address  0x48038014 (0x402f7014): 0x14000000
    root@c6a811x-evm:/home/PCM# devmem2 0x480380B4
    /dev/mem opened.
    Memory mapped at address 0x400a3000.
    Read at address  0x480380B4 (0x400a30b4): 0x00008007
    root@c6a811x-evm:/home/PCM# aplay -D "hw:0,2" -c 2 -r 48000 -f S16_LE 04Track.raw-------------------MCASP2
    reo
    root@c6a811x-evm:/home/PCM# devmem2 0x48050014
    /dev/mem opened.
    Memory mapped at address 0x402d1000.
    Read at address  0x48050014 (0x402d1014): 0x14000001
    root@c6a811x-evm:/home/PCM# devmem2 0x480500B4
    /dev/mem opened.
    Memory mapped at address 0x4027e000.
    Read at address  0x480500B4 (0x4027e0b4): 0x00008007
    Below is my clock settings for MCASP0/2/4 ports:
    clk_enable_init_clocks();
    //Selecting AUDIO_CLK_IN0 to MCASP0/2/4 AHCLKX pins Manju.G
    if (cpu_is_ti81xx()) {
    clkp0 = clk_get(NULL,"mcasp1_ahx_ck");
        if(!clkp0) printk("MCASP0 AHCLKX clk_get failed\n");
        else printk("MCASP0 AHCLKX clk_get successed.\n");
    clkp2 = clk_get(NULL,"mcasp3_ahx_ck");
        if(!clkp2) printk("MCASP2 AHCLKX clk_get failed\n");
        else printk("MCASP2 AHCLKX clk_get successed.\n");
    clkp4 = clk_get(NULL,"mcasp5_ahx_ck");
        if(!clkp4) printk("MCASP4 AHCLKX clk_get failed\n");
        else printk("MCASP4 AHCLKX clk_get successed.\n");
        new_parent = clk_get(NULL,"xref0_ck");
        if(!new_parent) printk("AUDIO_CLK_IN0 clk_get failed\n");
        else printk("AUDIO_CLK_IN0 clk_get successed.\n");
    clk_enable(new_parent);
      ret0=clk_set_parent(clkp0, new_parent);
    if(ret0==-EINVAL)
    printk("MCASP0 parent clock setting invalid.\n");
    else if(ret0==-EBUSY)
    printk("MCASP0 parent clock setting busy.\n");
    else
    printk("MCASP0 parent clock setting successed.\n");
    ret2=clk_set_parent(clkp2, new_parent);
    if(ret2==-EINVAL)
    printk("MCASP2 parent clock setting invalid.\n");
    else if(ret2==-EBUSY)
    printk("MCASP2 parent clock setting busy.\n");
    else
    printk("MCASP2 parent clock setting successed.\n");
    ret4=clk_set_parent(clkp4, new_parent);
    if(ret4==-EINVAL)
    printk("MCASP4 parent clock setting invalid.\n");
    else if(ret4==-EBUSY)
    printk("MCASP4 parent clock setting busy.\n");
    else
    printk("MCASP4 parent clock setting successed.\n");
    clk_enable(clkp0);
    clk_enable(clkp2);
    clk_enable(clkp4);
    clk_put(clkp0);
    clk_put(clkp2);
    clk_put(clkp4);
  • Can you have a try with the below modification:
    mcasp_clr_bits(dev->base + DAVINCI_MCASP_AHCLKXCTL_REG, AHCLKXE);
    } else {
    After this modification, check if you have clock signal on McASP0/2/4 ACLKX pin and provide me the values in McASP0/2/4 PDIR and AHCLKXCTL registers after the aplay command, using devmem2
    BR
    Pavel
  • Dear Pavel,
    Now i'm getting the MCASP4 clock along with the MCASP0 and MCASP2.
    But frame sync are  not proper as expected.Whether we need to adjust clock divider for frame sync also?
    As per clkdiv driver code we can divide Bit clock too:
    static int davinci_mcasp_set_clkdiv(struct snd_soc_dai *dai, int div_id, int div)
        struct davinci_audio_dev *dev = snd_soc_dai_get_drvdata(dai);
        switch (div_id) {
        case 0:        /* MCLK divider */
            mcasp_mod_bits(dev->base + DAVINCI_MCASP_AHCLKXCTL_REG,
                       AHCLKXDIV(div - 1), AHCLKXDIV_MASK);
            mcasp_mod_bits(dev->base + DAVINCI_MCASP_AHCLKRCTL_REG,
                       AHCLKRDIV(div - 1), AHCLKRDIV_MASK);
            printk("Entered MCLK divider\n");
            break;
        case 1:        /* BCLK divider */
            mcasp_mod_bits(dev->base + DAVINCI_MCASP_ACLKXCTL_REG,
                       ACLKXDIV(div - 1), ACLKXDIV_MASK);
            mcasp_mod_bits(dev->base + DAVINCI_MCASP_ACLKRCTL_REG,
                       ACLKRDIV(div - 1), ACLKRDIV_MASK);
            printk("Entered BCLK divider\n");
            break;
        case 2:        /* BCLK/LRCLK ratio */
            dev->bclk_lrclk_ratio = div;
            printk("Entered BCLK/LRCLK ratio\n");
            break;
        default:
            return -EINVAL;
        return 0;
    But there is issue on data, it is not transmitted on MCASP_AXR0 and MCASP_AXR1 pins. Below is the logs along with devmem2 values:
    root@c6a811x-evm:/home/PCM# aplay -D "hw:0,0" -c 2 -r 48000 -f S16_LE 04Track.raw-------------------------------MCASP0
    reo
    /dev/mem opened.
    Memory mapped at address 0x402aa000.
    Read at address  0x48038014 (0x402aa014): 0x14000000
    /dev/mem opened.
    Memory mapped at address 0x402b5000.
    Read at address  0x480380B4 (0x402b50b4): 0x00000007
    root@c6a811x-evm:/home/PCM# aplay -D "hw:0,2" -c 2 -r 48000 -f S16_LE 04Track.raw------------------------------MCASP2
    reo
    Before writing McASP0.AHCLKXCTL = 7
    After writing McASP0.AHCLKXCTL = 7
    underrun!!! (at least 0.146 ms long)
    underrun!!! (at least 0.604 ms long)
    underrun!!! (at least 0.036 ms long)
    underrun!!! (at least 0.243 ms long)
    underrun!!! (at least 0.409 ms long)
    underrun!!! (at least 0.570 ms long)
    underrun!!! (at least 0.325 ms long)
    underrun!!! (at least 0.284 ms long)
    underrun!!! (at least 0.124 ms long)
    underrun!!! (at least 0.112 ms long)
    /dev/mem opened.
    Memory mapped at address 0x40200000.
    Read at address  0x48050014 (0x40200014): 0x14000001
    /dev/mem opened.
    Memory mapped at address 0x4026f000.
    Read at address  0x480500B4 (0x4026f0b4): 0x00000007
    root@c6a811x-evm:/home/PCM# aplay -D "hw:0,1" -c 2 -r 48000 -f S16_LE 04Track.raw---------------------------------------MCASP4
    reo
    Before writing McASP2.AHCLKXCTL = 7
    After writing McASP2.AHCLKXCTL = 7
    underrun!!! (at least 0.168 ms long)
    underrun!!! (at least 0.040 ms long)
    underrun!!! (at least 0.536 ms long)
    root@c6a811x-evm:/home/PCM# devmem2 0x4A1A8014
    /dev/mem opened.
    Memory mapped at address 0x40243000.
    Read at address  0x4A1A8014 (0x40243014): 0x14000001
    root@c6a811x-evm:/home/PCM# devmem2 0x4A1A80B4
    /dev/mem opened.
    Memory mapped at address 0x40338000.
    Read at address  0x4A1A80B4 (0x403380b4): 0x00180000
    Do you mean you have no FS signal on AFSX pins (MCA[0]_AFSX/AH4, MCA[2]_AFSX/AF9 and MCA[4]_AFSX/AD3)? Or you have signals, but it is not
    with the frequency that you expect?
    BR
    Pavel
  • Dear Pavel,
    Yes i have signals on board but not expected one.Because have set divider value 8, to get 48KHz.
    As far now for testing i'm configuring all MCASP0, MCASP2 and MCASP4 to I2S mode with 2-channels and channels is set from board file also: .tdm_slots = 2,
    We are getting ACLKX as 12.288Mhz which is from AUD_CLKIN0(12.288Mhz) eventhough i have set divider value to 8.
    Divider = (12.288Mhz)/(16bitsX2channelsX48Khz)=8.
    Accordingly frames sync is also clocking without divider being set.
  • Manju,
    Can you provide me (after the latest modification of the code) the values of the below registers, after aplay command, using the devmem2 tool:
    McASP0.ACLKXCTL/0x480380B0
    McASP2.ACLKXCTL/0x480500B0
    McASP2.ACLKXCTL/0x4A1A80B0
    BR
    Pavel
  • Please note that ACLKXCTL[4:0] CLKXDIV is not set in the default linux kernel code. You might be interested in the below patch, it configures McASP as master and sets the divider also:
    diff --git a/sound/soc/davinci/davinci-evm.c b/sound/soc/davinci/davinci-evm.c
    index 4081a54..ca9ed9a 100644
    --- a/sound/soc/davinci/davinci-evm.c
    +++ b/sound/soc/davinci/davinci-evm.c
    @@ -38,7 +38,7 @@
    #include "davinci-mcasp.h"
    #define AUDIO_FORMAT (SND_SOC_DAIFMT_DSP_B | \
    - SND_SOC_DAIFMT_CBM_CFM | SND_SOC_DAIFMT_IB_NF)
    + SND_SOC_DAIFMT_CBS_CFS | SND_SOC_DAIFMT_IB_NF)
    static int evm_hw_params(struct snd_pcm_substream *substream,
    struct snd_pcm_hw_params *params)
    @@ -89,6 +89,11 @@ static int evm_hw_params(struct snd_pcm_substream *substream,
    if (ret < 0)
    return ret;
    + /* set the cpu system clock */
    + ret = snd_soc_dai_set_sysclk(cpu_dai, 0, 20000000, SND_SOC_CLOCK_OUT);
    + if (ret < 0)
    + return ret;
    return 0;
    diff --git a/sound/soc/davinci/davinci-mcasp.c b/sound/soc/davinci/davinci-mcasp.c
    index 7b17d6d..a0ad06b 100644
    --- a/sound/soc/davinci/davinci-mcasp.c
    +++ b/sound/soc/davinci/davinci-mcasp.c
    @@ -342,6 +342,45 @@ static inline void mcasp_set_ctl_reg(void __iomem *regs, u32 val)
    printk(KERN_ERR "GBLCTL write error\n");
    +static int davinci_config_clock(struct davinci_audio_dev *dev,
    + int rate, int slot_size)
    + void __iomem *base = dev->base;
    + u32 bclk, div;
    + printk("[%s] rate:%d slot_size:%d \n",__func__, rate, slot_size);
    + if (dev->sysclk_freq == 0 || dev->mclk_freq == 0) {
    + printk(KERN_NOTICE "Invalid clock value\n");
    + return 0;
    + div = (dev->sysclk_freq / dev->mclk_freq) - 1;
    + mcasp_mod_bits(base + DAVINCI_MCASP_AHCLKXCTL_REG, AHCLKXDIV(div), AHCLKXDIV(0xFFF));
    + mcasp_mod_bits(base + DAVINCI_MCASP_AHCLKRCTL_REG, AHCLKRDIV(div), AHCLKRDIV(0xFFF));
    + * bclk = rate * #tdm_slots * (slot_size)
    + * div = (sysclk / bclk) - 1
    + * for example
    + * rate = 48000 - rate sometime known as fs or sample rate
    + * tdm_slot = 2 - standard i2s format
    + * slot_size = 32 - standard i2s format for bits per slot
    + * mclk = 12288000 - from hardware spec.
    + * bclk = 48000 * 2 * 16 = 1536000
    + * div = (12288000 / 1536000) - 1 = 7
    + bclk = rate * dev->tdm_slots * slot_size;
    + div = ((dev->mclk_freq + (bclk - 1)) / bclk) - 1;
    + mcasp_mod_bits(base + DAVINCI_MCASP_ACLKXCTL_REG, ACLKXDIV(div), 0x1F);
    + mcasp_mod_bits(base + DAVINCI_MCASP_ACLKRCTL_REG, ACLKRDIV(div), 0x1F);
    + return 0;
    static void mcasp_start_rx(struct davinci_audio_dev *dev)
    mcasp_set_ctl_reg(dev->base + DAVINCI_MCASP_GBLCTLR_REG, RXHCLKRST);
    @@ -736,6 +775,8 @@ static int davinci_mcasp_hw_params(struct snd_pcm_substream *substream,
    int word_length;
    u8 fifo_level;
    + davinci_config_clock(dev, params_rate(params),params_format(params) * 8);
    davinci_hw_common_param(dev, substream->stream);
    if (substream->stream == SNDRV_PCM_STREAM_PLAYBACK)
    fifo_level = dev->txnumevt;
    @@ -826,11 +867,22 @@ static int davinci_mcasp_startup(struct snd_pcm_substream *substream,
    return 0;
    +static int davinci_mcasp_set_sysclk(struct snd_soc_dai *dai,
    + int clk_id, unsigned int freq, int dir)
    + struct davinci_audio_dev *dev = snd_soc_dai_get_drvdata(dai);
    + printk("DEBUG: [%s] freq:%d\n",__func__, freq);
    + dev->mclk_freq = freq;
    + dev->sysclk_freq = freq;
    + return 0;
    static struct snd_soc_dai_ops davinci_mcasp_dai_ops = {
    .startup = davinci_mcasp_startup,
    .trigger = davinci_mcasp_trigger,
    .hw_params = davinci_mcasp_hw_params,
    .set_fmt = davinci_mcasp_set_dai_fmt,
    + .set_sysclk = davinci_mcasp_set_sysclk,
    diff --git a/sound/soc/davinci/davinci-mcasp.h b/sound/soc/davinci/davinci-mcasp.h
    index 280c277..348e405 100644
    --- a/sound/soc/davinci/davinci-mcasp.h
    +++ b/sound/soc/davinci/davinci-mcasp.h
    @@ -68,6 +68,8 @@ struct davinci_audio_dev {
    * configure the McASP driver PIN_DIR
    int clk_input_pin;
    + u32 mclk_freq;
    + u32 sysclk_freq;
    #endif /* DAVINCI_MCASP_H */
    BR
    Pavel
  • I also found you have backport davinci_mcasp_set_clkdiv() function in your davinci-mcasp.c file. Can you check if your flow enters in the below case?
    switch (div_id) {
    break;
  • Dear Pavel,
    Clock division is happening and frame sync is also tuned.I did this by back-porting the mcasp driver functions from recent kernel to our J5eco kernel 2.6.37.
    Calling below functions from davinici_evm.c
    sysclk=12288000;
    if (ret < 0)
    return ret;
    ret = snd_soc_dai_set_clkdiv(cpu_dai, 1, 8);
    if (ret < 0)
    return ret;
    ret = snd_soc_dai_set_clkdiv(cpu_dai, 2, 32);
    if (ret < 0)
    return ret;
    Will be updating on TDM mode configuration and testing with Amplifier soon.
    Thank you very much for your valuable inputs on mcasp.
  • Manju,
    Let me know if you have more questions.
    BR
    Pavel
  • Dear Pavel,
    MCASP0: I2S mode with 24-bit data and 2 channels
    static u8 ti811x_iis_serializer_direction_mcasp0[] = {
        RX_MODE,    RX_MODE,    INACTIVE_MODE,    INACTIVE_MODE,
        INACTIVE_MODE,    INACTIVE_MODE,    INACTIVE_MODE,    INACTIVE_MODE,
       {      .tx_dma_offset  = 0x46000000,
            .rx_dma_offset  = 0x46000000,
            .op_mode        = DAVINCI_MCASP_IIS_MODE,
            .num_serializer = ARRAY_SIZE(ti811x_iis_serializer_direction_mcasp0),
            .tdm_slots      = 2,
            .serial_dir     = ti811x_iis_serializer_direction_mcasp0,
            .asp_chan_q     = EVENTQ_2,
            .version        = MCASP_VERSION_2,
            .txnumevt = 1,
             .rxnumevt = 1,
            .clk_input_pin = MCASP_AHCLKX_IN,
    MCASP4: TDM 8-slots 32-bit MSB first
    static u8 ti811x_iis_serializer_direction_mcasp4[] = {
        TX_MODE,    INACTIVE_MODE,    INACTIVE_MODE,    INACTIVE_MODE,
        .tx_dma_offset    = 0x4A1AB000,
        .rx_dma_offset    = 0x4A1AB000,
        .num_serializer = ARRAY_SIZE(ti811x_iis_serializer_direction_mcasp4),
        .tdm_slots    = 8,
        .serial_dir    = ti811x_iis_serializer_direction_mcasp4,
        .txnumevt    = 1,
        .rxnumevt    = 1,
    MCASP0 will have now two receivers:AXR0 and AXR1
    AXR0:24-bit 2channel audio i.e, Front-Left and Front-Right
    AXR1:24-bit 2channel audio i.e, Rear-Left and Rear-Right
    Both AXR0 and AXR1 data needs to be received and Transmitted over MCASP4 AXR0.
    How can i achieve this by using alsa readi and writei functions.Will our MCASP support two receivers to receive the data in parallel at the same time?
    Do you mean snd_pcm_readi and snd_pcm_writei functions?
    I think J5Eco McASP is able to receive data on two pins (AXR0 and AXR1) in parallel at the same time.
    BR
    Pavel
  • Dear Pavel,
    Yes it is snd_pcm_readi and snd_pcm_writei functions.
    This means that if i read from MCASP0, with snd_pcm_readi i will get data from both AXR0 and AXR1 at the same time ?
    If i get data from AXR0 and AXR1 at the same time with snd_pcm_readi function and then if i write to MCASP4 using snd_pcm_writei function will all data from MCASP0 AXR0 and AXR1 will written in 4 slots.
    For McASP4:  The AMP requires the following Format:
    Fs = 48 kHz
    Fsck = 256 *fs
    Ws = min.: 2/Fsck and max.: 255/Fsck
     TDM8 with 32 Bit/Channel (first 24 Bit Audio Data and trailing 8 Bit stuffed with zeros) with MSB first.
    To get the AMP data from the I2S Stream (McASP0) simply need to copy the channels to the McASP4
    MCASP0 -->McASP4
    Ch1 --->Ch1
    Ch2 --> Ch2
    Ch3---> Ch3
    Ch4 --> Ch4
  • Dear Pavel,
    Using aplay command if i increase channel from 2 to 4 it is throwing error:
    root@c6a811x-evm:/home/audiosamples# aplay -D "hw:0,1" -c 4 -r 48000 -f S32_LE 0
    4Track.raw
    Playing raw data '04Track.raw' : Signed 32 bit Little Endian, Rate 48000 Hz, Channels 4
    aplay: set_params:1071: Channels count non available
  • Manju,
    To capture/record data on two serializers (AXR0/1) you can use snd_pcm_readi or arecord.
    For using snd_pcm_readi, refer to the record application (pointers below), you should modify the application per your requirements (i.e. change number of channels from 2 to 4):
    processors.wiki.ti.com/.../TI811X_PSP_AUDIO_Driver_User_Guide
    ti-ezsdk_c6a811x-evm_5_05_01_10/example-applications/linux-driver-examples-psp04.07.00.02/audio/
    The captured output buffer will have the multi-channel PCM data.
    For using arecord, you should also pass arguments according to your specific requirements, see the below pointers:
    Note: For testing purpose use the ALSA arecrod utility to capture the data to a WAV file and verify the data using the audio analyzer tool.
    EVM# arecord –f cd -t wav -c <num of channels to capture> <Audio file.wav>
    The above command will capture the data from save it in the WAV file format.
    e2e.ti.com/.../1639485
    Refer also to the below pointers regarding usage of two RX serializers at the same time:
    processors.wiki.ti.com/.../FAQ_for_DaVinci_Linux
    e2e.ti.com/.../405924
    e2e.ti.com/.../402384
    e2e.ti.com/.../114863
    e2e.ti.com/.../561249
    BR
    Pavel
  • Manju,
    hw:0,1 is McASP4. On McASP4 you have only one serializer (AXR0 on TX_MODE). Do you mean you need to set multi channel playback on a single serializer (4 channels on AXR0)?
    BR
    Pavel
  • Dear Pavel,
    Yes On McASP4 i have only one serializer (AXR0 on TX_MODE).I need to set multi channel playback on a single serializer (4 channels on AXR0)
  • Manju,
    The current version of the J5Eco audio driver only support stereo mode of operations due the codec (AIC3106) limitations used in the J5Eco EVM. As a first step make sure your external codec supports multi-channel capture.
    In DM814x DVR RDK system (code and board), TVP5158 is used (instead of AIC3106), and TVP5158 support multi-channel audio.
    I would recommend you to check the DM8148 DVR RDK implementation of the TVP5158 codec for audio.
    arago-project.org/.../
    See files:
    linux-dvr-rdk-dm81xx/sound/soc/davinci/ti81xx-evm.c
    linux-dvr-rdk-dm81xx/sound/soc/davinci/ti81xx-uddvr.c
    linux-dvr-rdk-dm81xx/arch/arm/mach-omap2/devices.c
    linux-dvr-rdk-dm81xx/sound/soc/codecs/tvp5158-audio.c
    linux-dvr-rdk-dm81xx/sound/soc/davinci/Kconfig
    linux-dvr-rdk-dm81xx/sound/soc/codecs/Kconfig
    linux-dvr-rdk-dm81xx/sound/soc/codecs/Makefile
    linux-dvr-rdk-dm81xx/arch/arm/configs/ti814x_dvr_defconfig
    linux-dvr-rdk-dm81xx/arch/arm/configs/ti8148_evm_defconfig
    The difference is that DVR RDK code is made for capture/record (RX_MODE) on single serializer AXR0, while you need to adjust for playback (TX_MODE).
    BR
    Pavel
  • Dear Pavel,
    MCASP0/2/4 Bit clock and frame sync are seen only by giving "aplay command". How can we make it to be available when kernel boots.
  • Manju,
    Do you mean you need aplay executed during linux kernel boot up or executed automatically right after kernel boot up?
    If you need executed automatically right after kernel boot up, you can try doing this with script. Refer to the below wikis for more info regarding start up scripts:
    processors.wiki.ti.com/.../Sitara_Linux_SDK_Training - see Init Scripts
    processors.wiki.ti.com/.../Sitara_Linux_Training:_Init_Scripts
    BR
    Pavel
  • Dear Pavel,
    Yes , aplay should be executed during linux kernel boot up or executed automatically right after kernel boot up.
    Because external amplifier needs mcasp clocks to initialize.
    If i add aplay to run in as init script for MCASP0/2/4.Then if i wan't to open the device from userspace is it possible ? Because its already opened with aplay.
    If i use snd_pcm_writei and snd_pcm_readi function i will succeed?
    Aplay is mandatory to run the MCASP bit clock and framesync? There is no alternative setting for this?
    I do not understand your questions. Which device will be already open?
    succeed with what?
    Aplay or playback application can be used.
    BR
    Pavel
  • Manju,
    Both aplay and snd_pcm_writei are user space tool and function, which invokes the audio driver in kernel. I do not think you can implement these inside the linux kernel.
    BR
    Pavel
  • Dear Pavel,
    When i play the sound card device "hw:0,1"(MCASP4) using aplay command: aplay -D "hw:0,1" -c 8 -f S32_LE -r 48000 track1.wav
    After which if i try to access the same device i.e, "hw:0,1" its shows device busy.
    So, As per your suggestion if run the aplay command for "hw:0,1" aplay -D "hw:0,1" -c 8 -f S32_LE -r 48000 as startup script in linux kernel that device will holded by the aplay.Then if i try to do snd_pcm_writei and snd_pcm_readi then it will show device busy right?.
    It won't allow me to set any hardware parameters for the device "hw:0,1" from userspace.
    How can i go with this
  • Manju,
    You should wait for the track1.wav file to playback to the end. Only then you can use again hw:0,1
    aplay and snd_pcm_writei are invoking the same linux kernel audio driver code. So you can use snd_pcm_writei after aplay finished, not before that. Once aplay finished playing track1.wav, it releases the device (hw:0,1) and device hw:0,1 can be used for other aplay or snd_pcm_writei.
    BR
    Pavel
  • Dear Pavel,
    Once aplay finishes the track1.wav then clocks also stops from MCASP4 i.e "hw:0,1" then again my amplifer goes to standby mode.My amplifier needs continuous bitclock and framesync to be alive.
  • Dear Pavel,
    After track1.wav file playback goes to end parallely MCASP4 i.e "hw:0,1" bit clock and framesync also ends with aplay.My amplifier needs continuous bit clock and framesync to be alive otherwise amplifier goes to standby mode.
  • Manju,
    One possible solution can be to use playback application (instead of aplay tool), where snd_pcm_writei is used:
    You can check with the scope that bit clock and fs will come up after execution of this snd_pcm_writei function. And you can modify the application to run this snd_pcm_writei function as long as you need.
    BR
    Pavel
  • Other possible solution can be to use the aplay tool, when execute aplay you will invoke the below driver functions:
    davinci-mcasp.c
    davinci_mcasp_trigger() -> davinci_mcasp_start() -> mcasp_start_tx()
    You should verify the scope that bit clock and fs come up on the pins inside mcasp_start_tx(). Check with the scope after which line of code exactly the bit clock and fs are active. Then you should check that you are in the McASP4 case (dev->tdm_slots should be 8) and modify the mcasp_start_tx() function to execute as long as you need.
    BR
    Pavel
  • Dear Pavel,
    As per your suggestion i wrote sample application which will read from "hw:0,0"(MCASP0) and writes on to "hw:0,1"(MCASP4).
    When i open one device "hw:0,0"(MCASP0) for the first time it is successfully opened and opening of the second device fails.
    char *snd_device_in = "hw:0,0";-------->MCASP0
    char *snd_device_out = "hw:0,1";------->MCASP4
    if ((err = snd_pcm_open(&playback_handle, snd_device_out, SND_PCM_STREAM_PLAYBACK, SND_PCM_NONBLOCK)) < 0) {
    printf("Playback open error:%s : %s\n", snd_device_out, snd_strerror(err));
    exit(1);
    if ((err = snd_pcm_open(&capture_handle,snd_device_in, SND_PCM_STREAM_CAPTURE, SND_PCM_NONBLOCK)) < 0) {
    printf("Record open error: %s :%s\n", snd_device_in, snd_strerror(err));
    exit(1);
    root@c6a811x-evm:/home/audiosamples# ./mcasp_test
    Record open error: hw:0,0 :Invalid argument
    Then i tried to open "hw:0,0" first and then "hw:0,1" , in this case "hw:0,0" is successfully opened but "hw:0,1" fails to open.
    exit(1);
    exit(1);
    Playback open error: hw:0,1 :Invalid argument
    But if use aplay command :
    root@c6a811x-evm:/home/audiosamples# aplay -D "hw:0,0" -c 2 -r 48000 -f S32_LE 0
    4Track.raw
    and then run the
    it is running successfully.But no clocks for snd_pcm_writei function.
    Why second device fails to open always in my test application?
    Why after aplay command both devices are opened successfully in my test application?
    Why snd_pcm_writei function not triggering clocks ?
  • Manju,
    If you use plughw:0,x instead of hw:0,x, will be there any improvement?
    BR
    Pavel
  • Dear Pavel,
    If i use plughw:0,x also same there is no improvement.
  • Manju,
    J5Eco audio driver supports simultaneous playback and record (full-duplex mode), but does not allow opening the same stream (playback/capture) multiple times.
    Make sure you have different streams for playback and capture:
    snd_pcm_t *playback_handle;
    snd_pcm_stream_t stream_playback = SND_PCM_STREAM_PLAYBACK;
    snd_pcm_open (&playback_handle, device, stream_playback, 0);
    snd_pcm_t *capture_handle;
    snd_pcm_stream_t stream_capture = SND_PCM_STREAM_CAPTURE;
    snd_pcm_open (&capture_handle, device, stream_capture, 0);
    Check also if there will be any improvement if you use "default" for playback and "hw:0,0" for capture/record.
    BR
    Pavel
  • Dear Pave,
    I'm using different streams for playback and record from my initial code:
    char           *snd_device_in  = "hw:0,0";-------------->MCASP0
    char           *snd_device_out = "hw:0,1";--------------->MCASP4
           if ((err = snd_pcm_open(&playback_handle, snd_device_out, SND_PCM_STREAM_PLAYBACK, SND_PCM_ASYNC)) < 0) {
                   exit(1);
           if ((err = snd_pcm_open(&capture_handle,snd_device_in, SND_PCM_STREAM_CAPTURE, SND_PCM_ASYNC)) < 0) {
                   exit(1);
    But still no improvement.
    capture device doesn't open after playback device.
    If swap the positions then capture device will open but playback device doesn't.
    After using aplay for failed device opening.Then if i run application both device opens.
  • Check also if there will be any improvement if you use "default" for playback and "hw:0,0" for capture/record.
  • Dear Pavel,
    Using default also no improvement.
    //char *snd_device_out = "hw:0,1";
    char *snd_device_out = "default";
    if ((err = snd_pcm_open(&playback_handle, snd_device_out, SND_PCM_STREAM_PLAYBACK, 0)) < 0) {
    exit(1);
    if ((err = snd_pcm_open(&capture_handle,snd_device_in, SND_PCM_STREAM_PLAYBACK, 0)) < 0) {
    exit(1);
  • Manju,
    I check this on my side, and it works fine, I can open both playback and capture devices:
    root@dm814x-evm:~# aplay -l
    **** List of PLAYBACK Hardware Devices ****
    card 0: EVM [TI81XX EVM], device 0: AIC3X tlv320aic3x-hifi-0 []
     Subdevices: 1/1
     Subdevice #0: subdevice #0
    card 0: EVM [TI81XX EVM], device 1: hdmi HDMI-DAI-CODEC-1 []
     Subdevices: 1/1
    root@dm814x-evm:~# arecord -l
    **** List of CAPTURE Hardware Devices ****
     Subdevices: 1/1
    root@dm814x-evm:~# ./minimal_playback_capture
    capture snd_pcm_open err = 0
    playback snd_pcm_open err = 0
    snd_pcm_readi successful
    I compile with below Makefile:
    minimal_playback_capture:
    # Make sure that you use a tab below
        $(CSTOOL_PREFIX)gcc -I/home/users/pbotev/ti-ezsdk_dm814x-evm_5_05_02_00/linux-devkit/arm-none-linux-gnueabi/usr/include/ -L/home/users/pbotev/ti-ezsdk_dm814x-evm_5_05_02_00/linux-devkit/arm-none-linux-gnueabi/usr/lib/ -lasound -o minimal_playback_capture minimal_playback_capture.c
    The application is as below:
    #include <stdio.h>
    #include <stdlib.h>
    #include <alsa/asoundlib.h>
    #define BUFF_SIZE 4096
    int main (int argc, char *argv[])
      int err;
      short buf[BUFF_SIZE];
      int rate = 44100; /* Sample rate */
      int exact_rate; /* Sample rate returned by */
      /* This structure contains information about the hardware and can be used to specify the configuration to be used for */
      /* the PCM stream. */
      snd_pcm_hw_params_t *hw_params;
      /* Name of the PCM device, like hw:0,0 */
      /* The first number is the number of the soundcard, the second number is the number of the device. */
      static char *cdevice = "plughw:0,0"; /* capture device */ //McASP2
      static char *pdevice = "plughw:0,1"; /* playback device */ //HDMI
      /* Open PCM. The last parameter of this function is the mode. */
      if ((err = snd_pcm_open (&capture_handle, cdevice, SND_PCM_STREAM_CAPTURE, 0)) < 0) {
        fprintf (stderr, "cannot open audio device (%s)\n", snd_strerror (err));
        exit (1);
       printf("capture snd_pcm_open err = %d\n",err);
      if ((err = snd_pcm_open (&playback_handle, pdevice, SND_PCM_STREAM_PLAYBACK, 0)) < 0) {
        exit (1);
       printf("playback snd_pcm_open err = %d\n",err);
      memset(buf,0,BUFF_SIZE);
    Can you provide me the below things:
    1. Your Makefile. If you do not use Makefile, please provide me details about how exactly you create/build/make your executable
    2. The output of "aplay -l" and "arecord -l"
    3. Your C file
    BR
    Pavel
  • Dear Pavel,
    Below are the details:
    root@c6a811x-evm:~# aplay -l
      Subdevices: 1/1
    card 0: EVM [TI81XX EVM], device 1: AIC3X tlv320aic3x-hifi-1 []
      Subdevices: 1/1
    card 0: EVM [TI81XX EVM], device 2: AIC3X tlv320aic3x-hifi-2 []
      Subdevices: 1/1
    root@c6a811x-evm:~# arecord -l
      Subdevices: 1/1
      Subdevices: 1/1
      Subdevices: 1/1
    8585.mcasp_test.c
    4336.Makefile.txt
  • Manju,
    Below is the beginning of your application:
    int             restarting;
    int err=0;
    int err1=0;
    int             fragments = 2;
    int             pchannels = 4,cchannels=4 ,i=0;
    int             buffer_size = 512,size=0;
    int             bits = 32;
    int catch;
    int             frames, inframes, outframes, frame_size,exit_program=0;
    char *rdbuf;
    //char           *snd_device_out = "default";
    #if(0)
    #endif
    #if(0)
    char           *snd_device_in  = "hw:1,0";
    char           *snd_device_out = "hw:1,0";
    #endif
                   exit(1);
                   exit(1);
    Do your application give error on the below code from the extract?
                    exit(1);
    BR
    Pavel
  • Dear Pavel,
    Exactly at,
    exit(1);
  • Manju,
    You are using the same stream (SND_PCM_STREAM_PLAYBACK) for both playback and capture. As we already discusses (see the below e2e post), J5Eco audio driver does not allow opening the same stream (playback/capture) multiple times.
    Can you try the below modification:
    if ((err = snd_pcm_open(&capture_handle,snd_device_in, SND_PCM_STREAM_CAPTURE, 0)) < 0) {
    exit(1);
    BR
    Pavel
  • Dear Pavel,
    Sorry i have sent you file which is not correct.But I'm not using same stream you can see in my earlier post about it.I tested this with different streams.
    exit(1);
    exit(1);
    No improvement on this
  • Can you check this on the TI EVM? I suspect this might be HW malfunction of your custom board, as this works fine on the TI EVM.
    BR
    Pavel
  • Dear Pavel,
    On EVM with
    "hw:0,0"--->MCASP0 device opening successful
    "hw:0,1"--->MCASP4 device opening is not successful
    root@c6a811x-evm:/bin# ./mcasp-test
    Error value for input devie:0
    Error value for output device:-22
    cannot open output or playback audio device hw:0,1: Invalid argument
    On EVM with
    "plughw:0,0"--->MCASP0 device opening successful
    "plughw:0,1"--->MCASP4 device opening is not successful
    cannot open output or playback audio device plughw:0,1: Invalid argument
  • Manju,
    On EVM, what is the output of "aplay -l" and "arecord -l"?
    Can you modify your application like below and try on both custom board and TI EVM:
    static char           *snd_device_in  = "plughw:0,0";
    static char           *snd_device_out = "plughw:0,1";
    Please provide me the console output when you start your application.
    BR
    Pavel
  • Dear Pavel,
    I tried adding below changes:
    But still its the same issue.
    I'm attaching my alsa.conf file.
    0842.alsa.conf.txt
  • Manju,
    I don't need your alsa.conf file.
    What I need is:
    1. On EVM, what is the output of "aplay -l" and "arecord -l"?
    2. Provide me the console output when you start your application
    BR
    Pavel
