Keystone II arm generic timer
We are porting an hypervisor on a Keystone II board (XTCIEVMK2X) and arm generic timer registers are not possible to modify (virtual or physical).
We can read the counter and it is counting and we executed the boot monitor before executing our code.
Could you explain what needs to be done to make those registers writeable ? same low level init code is working on an omap5 where no clock or anything else needs to be done to use arm generic timers.
Thanks for your help
  • Welcome to the TI E2E forum. I hope you will find many good answers here and in the TI.com documents and in the TI Wiki Pages (for processor issues). Be sure to search those for helpful information and to browse for the questions others may have asked on similar topics (e2e.ti.com). Please read all the links below my signature.
    We will get back to you on the above query shortly. Thank you for your patience.
  • Hi, Bertrand,
    In Keystone-2, some Cortex-A15 configurations need to be performed in Supervisor mode in the secure state which is what boot monitor is doing. Boot Monitor is part of the boot process which switches to the secure supervisor mode, configures A15, and then out of secure supervisor mode. This is through SMC instruction. Please refer to ARM Cortex-A15 TRM for details.
    I am not familiar with how OMAP5 works. It's different design. I'll see if I can get its info.
    Rex
  • Hi Rex,
    We found out that the timer registers are actually possible to modify and the "read" function we were using was actually the bug.
    Thanks anyway for your help
    Bertrand
  • Bertrand,
    Thank you for the update.
