Other Parts Discussed in Thread: TFP410, TPS65910, TMP275, TMDXEVM3358
Hello Sir,
I am using Sdk v01.00.00.03 image. i am facing board reboot repeatedly.
Welcome to minicom 2.5
OPTIONS: I18n
Compiled on May 2 2011, 00:39:27.
Port /dev/ttyUSB0
Press CTRL-A Z for help on special keys
CCCCCCCC
U-Boot SPL 2014.07-gfb6ab76 (Jul 06 2015 - 16:00:22)
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
U-Boot 2014.07-gfb6ab76 (Jul 06 2015 - 16:00:22)
I2C: ready
DRAM: 512 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
** Unable to read file uEnv.txt **
4337552 bytes read in 323 ms (12.8 MiB/s)
39295 bytes read in 74 ms (518.6 KiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x422f90 ]
Loading Device Tree to 8fff3000, end 8ffff97e ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.14.43-g875c69b (gtbldadm@ubuntu-12) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2015
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM335x EVM
[ 0.000000] cma: CMA: reserved 24 MiB at 9e000000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES1.0 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 485172K/523264K available (5843K kernel code, 303K rwdata, 2144K rodata, 260K init, 232K bss, 38092K reserved, 0K highme)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07d50c4 (7989 kB)
[ 0.000000] .init : 0xc07d6000 - 0xc0817144 ( 261 kB)
[ 0.000000] .data : 0xc0818000 - 0xc0863da0 ( 304 kB)
[ 0.000000] .bss : 0xc0863da0 - 0xc089ddb8 ( 233 kB)
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns
[ 0.000038] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000327] Console: colour dummy device 80x30
[ 0.000356] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000363] This ensures that you still see kernel messages. Please
[ 0.000368] update your kernel commandline.
[ 0.000393] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[ 0.119332] pid_max: default: 32768 minimum: 301
[ 0.119445] Security Framework initialized
[ 0.119509] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.119522] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.128316] CPU: Testing write buffer coherency: ok
[ 0.128735] Setting up static identity map for 0x805baa20 - 0x805baa78
[ 0.129874] devtmpfs: initialized
[ 0.131764] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.139998] omap_hwmod: tptc0 using broken dt data from edma
[ 0.140092] omap_hwmod: tptc1 using broken dt data from edma
[ 0.140173] omap_hwmod: tptc2 using broken dt data from edma
[ 0.144518] omap_hwmod: debugss: _wait_target_disable failed
[ 0.200717] pinctrl core: initialized pinctrl subsystem
[ 0.201850] regulator-dummy: no parameters
[ 0.204401] NET: Registered protocol family 16
[ 0.206639] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.209544] cpuidle: using governor ladder
[ 0.209562] cpuidle: using governor menu
[ 0.216532] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb] registered
[ 0.218136] platform 49000000.edma: alias fck already exists
[ 0.218160] platform 49000000.edma: alias fck already exists
[ 0.218176] platform 49000000.edma: alias fck already exists
[ 0.219460] OMAP GPIO hardware version 0.1
[ 0.232202] omap-gpmc 50000000.gpmc: could not find pctldev for node /pinmux@44e10800/nandflash_pins_default, deferring probe
[ 0.232241] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral
[ 0.236932] No ATAGs?
[ 0.236953] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.266044] bio: create slab <bio-0> at 0
[ 0.283740] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.284900] vbat: 5000 mV
[ 0.285331] lis3_reg: no parameters
[ 0.285885] wlan-en-regulator: 1800 mV
[ 0.289537] vgaarb: loaded
[ 0.290127] i2c-core: driver [palmas] using legacy suspend method
[ 0.290138] i2c-core: driver [palmas] using legacy resume method
[ 0.290933] SCSI subsystem initialized
[ 0.292574] usbcore: registered new interface driver usbfs
[ 0.292786] usbcore: registered new interface driver hub
[ 0.293007] usbcore: registered new device driver usb
[ 0.294085] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c0_pins, deferring probe
[ 0.294117] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
[ 0.294148] omap_i2c 4802a000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c1_pins, deferring probe
[ 0.294165] platform 4802a000.i2c: Driver omap_i2c requests probe deferral
[ 0.294607] pps_core: LinuxPPS API ver. 1 registered
[ 0.294619] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.294759] PTP clock support registered
[ 0.296901] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.297937] Advanced Linux Sound Architecture Driver Initialized.
[ 0.299776] Switched to clocksource timer1
[ 0.321300] NET: Registered protocol family 2
[ 0.322284] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.322342] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.322394] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.322477] TCP: reno registered
[ 0.322491] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.322514] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.322706] NET: Registered protocol family 1
[ 0.323112] RPC: Registered named UNIX socket transport module.
[ 0.323124] RPC: Registered udp transport module.
[ 0.323131] RPC: Registered tcp transport module.
[ 0.323138] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.324354] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.327405] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.514541] VFS: Disk quotas dquot_6.5.2
[ 0.514618] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.515199] NFS: Registering the id_resolver key type
[ 0.515287] Key type id_resolver registered
[ 0.515296] Key type id_legacy registered
[ 0.515340] jffs2: version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 0.515529] msgmni has been set to 995
[ 0.517124] NET: Registered protocol family 38
[ 0.517167] io scheduler noop registered
[ 0.517176] io scheduler deadline registered
[ 0.517202] io scheduler cfq registered (default)
[ 0.519211] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.523653] backlight supply power not found, using dummy regulator
[ 0.527807] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.533769] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a 8250
[ 1.205453] console [ttyS0] enabled
[ 1.210242] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 89, base_baud = 3000000) is a 8250
[ 1.221128] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 1.228227] [drm] Initialized drm 1.1.0 20060810
[ 1.244777] brd: module loaded
[ 1.254134] loop: module loaded
[ 1.257681] (stk) :sysfs entries created
[ 1.261807] (stk) : debugfs entries created
[ 1.266148] (hci_tty): inside hci_tty_init
[ 1.270993] (hci_tty): allocated 250, 0
[ 1.280021] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.291051] usbcore: registered new interface driver asix
[ 1.296716] usbcore: registered new interface driver ax88179_178a
[ 1.303035] usbcore: registered new interface driver cdc_ether
[ 1.309111] usbcore: registered new interface driver smsc95xx
[ 1.315053] usbcore: registered new interface driver net1080
[ 1.320932] usbcore: registered new interface driver cdc_subset
[ 1.327081] usbcore: registered new interface driver zaurus
[ 1.332915] usbcore: registered new interface driver cdc_ncm
[ 1.339191] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.345785] ehci-pci: EHCI PCI platform driver
[ 1.350484] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.356273] usbcore: registered new interface driver cdc_wdm
[ 1.362217] usbcore: registered new interface driver usb-storage
[ 1.369444] mousedev: PS/2 mouse device common for all mice
[ 1.376507] TI-am335x-tsc TI-am335x-tsc: ti,charge-delay not specified
[ 1.383622] input: ti-tsc as /devices/ocp/44e0d000.tscadc/TI-am335x-tsc/input/input0
[ 1.393047] i2c-core: driver [rtc-ds1307] using legacy suspend method
[ 1.399523] i2c-core: driver [rtc-ds1307] using legacy resume method
[ 1.406810] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.414930] i2c /dev entries driver
[ 1.418620] Driver for 1-wire Dallas network protocol.
[ 1.426503] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.435704] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517
[ 1.442581] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral
[ 1.570840] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.580386] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.586605] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
[ 1.595976] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.603632] usbcore: registered new interface driver usbhid
[ 1.609244] usbhid: USB HID core driver
[ 1.613495] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral
[ 1.624570] oprofile: using arm/armv7
[ 1.628686] TCP: cubic registered
[ 1.632076] Initializing XFRM netlink socket
[ 1.636394] NET: Registered protocol family 17
[ 1.640941] NET: Registered protocol family 15
[ 1.645555] Key type dns_resolver registered
[ 1.650727] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 1.659475] cpu cpu0: cpu0 clock notifier not ready, retry
[ 1.665088] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral
[ 1.673353] PM: bootloader does not support rtc-only!
[ 1.678446] ThumbEE CPU extension supported.
[ 1.682980] Registering SWP/SWPB emulation handler
[ 1.689764] lis3_reg: disabling
[ 1.693117] vbat: disabling
[ 1.695942] regulator-dummy: disabling
[ 1.700811] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 1.706537] Error: Driver 'tfp410' is already registered, aborting...
[ 1.714058] panel panel: pins are not configured
[ 1.721029] mmc0: new SDIO card at address 0001
[ 1.727444] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.734140] [drm] No driver support for vblank timestamp query.
[ 1.796706] Console: switching to colour frame buffer device 100x30
[ 1.809732] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 1.815345] tilcdc 4830e000.lcdc: registered panic notifier
[ 1.820975] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 1.827675] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.832900] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.840415] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 1.846810] nand: Micron MT29F2G08ABAEAWP
[ 1.850871] nand: 256MiB, SLC, page size: 2048, OOB size: 64
[ 1.856565] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.862115] 10 ofpart partitions found on MTD device omap2-nand.0
[ 1.868237] Creating 10 MTD partitions on "omap2-nand.0":
[ 1.873696] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.880927] 0x000000020000-0x000000040000 : "NAND.SPL.backup1"
[ 1.888558] 0x000000040000-0x000000060000 : "NAND.SPL.backup2"
[ 1.896113] 0x000000060000-0x000000080000 : "NAND.SPL.backup3"
[ 1.903633] 0x000000080000-0x0000000c0000 : "NAND.u-boot-spl-os"
[ 1.911450] 0x0000000c0000-0x0000001c0000 : "NAND.u-boot"
[ 1.919262] 0x0000001c0000-0x0000001e0000 : "NAND.u-boot-env"
[ 1.926748] 0x0000001e0000-0x000000200000 : "NAND.u-boot-env.backup1"
[ 1.934971] 0x000000200000-0x000000a00000 : "NAND.kernel"
[ 1.948624] 0x000000a00000-0x000010000000 : "NAND.file-system"
[ 2.160587] tps65910 0-002d: No interrupt support, no core IRQ
[ 2.171091] vrtc: 1800 mV
[ 2.174120] vrtc: supplied by vbat
[ 2.179352] vio: at 1800 mV
[ 2.182377] vio: supplied by vbat
[ 2.187624] vdd_mpu: 912 <--> 1375 mV at 1137 mV
[ 2.192453] vdd_mpu: supplied by vbat
[ 2.197999] vdd_core: 912 <--> 1150 mV at 1137 mV
[ 2.202917] vdd_core: supplied by vbat
[ 2.208214] vdd3: 5000 mV
[ 2.212382] vdig1: at 1800 mV
[ 2.215540] vdig1: supplied by vbat
[ 2.220485] vdig2: at 1800 mV
[ 2.223636] vdig2: supplied by vbat
[ 2.228602] vpll: at 1800 mV
[ 2.231683] vpll: supplied by vbat
[ 2.236527] vdac: at 1800 mV
[ 2.239578] vdac: supplied by vbat
[ 2.244480] vaux1: at 1800 mV
[ 2.247628] vaux1: supplied by vbat
[ 2.252601] vaux2: at 3300 mV
[ 2.255748] vaux2: supplied by vbat
[ 2.260694] vaux33: at 3300 mV
[ 2.263940] vaux33: supplied by vbat
[ 2.268981] vmmc: 1800 <--> 3300 mV at 3300 mV
[ 2.273631] vmmc: supplied by vbat
[ 2.277973] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 2.286944] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 2.330512] remoteproc0: wkup_m3 is available
[ 2.334993] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 2.344045] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 2.354710] remoteproc0: Direct firmware load failed with error -2
[ 2.361083] remoteproc0: Falling back to user helper
[ 2.366675] cpu cpu0: of_pm_voltdm_notifier_register: Fail calculating voltage latency[1100000<->1260000]:-22
[ 2.429496] mmc1: new high speed SDHC card at address 0007
[ 2.435786] mmcblk0: mmc1:0007 SD16G 14.4 GiB (ro)
[ 2.440672] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 2.446795] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 2.454839] libphy: 4a101000.mdio: probed
[ 2.458938] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Atheros 8031 ethernet
[ 2.468354] mmcblk0: p1 p2
[ 2.473114] cpsw 4a100000.ethernet: Detected MACID = d4:94:a1:53:65:5a
[ 2.483357] input: volume_keys@0 as /devices/volume_keys@0/input/input1
[ 2.491000] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 2.503107] ALSA device list:
[ 2.506110] No soundcards found.
[ 2.526041] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.534332] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.545899] devtmpfs: mounted
[ 2.549364] Freeing unused kernel memory: 260K (c07d6000 - c0817000)
INIT: version 2.88 booting
Starting udev
[ 3.394926] udevd[920]: starting version 182
[ 3.693843] input: matrix_keypad@0 as /devices/matrix_keypad@0/input/input2
[ 3.724697] Bluetooth: Core ver 2.18
[ 3.728422] NET: Registered protocol family 31
[ 3.732993] Bluetooth: HCI device and connection manager initialized
[ 3.817339] remoteproc0: powering up wkup_m3
[ 3.840860] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 154412
[ 3.848675] PM: CM3 Firmware Version = 0x190
[ 3.974788] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 3.997084] Bluetooth: HCI socket layer initialized
[ 4.010729] remoteproc0: remote processor wkup_m3 is now up
[ 4.048626] Bluetooth: L2CAP socket layer initialized
[ 4.066916] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 4.090043] Bluetooth: SCO socket layer initialized
[ 4.184566] Loading modules backported from Linux version R8.5-2-gad69b45
[ 4.191501] Backport generated by backports.git R8.4-0-g0d46f43
[ 4.212038] (stc): chnl_id list empty :4
[ 4.216004] (stk) : st_kim_start(stk) :ldisc_install = 1
[ 4.416254] tsl2550 1-0039: standard operating mode
[ 4.490198] tsl2550 1-0039: support ver. 1.2 enabled
[ 4.577270] lm75 1-0048: hwmon0: sensor 'tmp275'
[ 4.630473] lis3lv02d: 16 bits lis331dlh sensor found
[ 4.750319] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input3
[ 5.319921] (stk) :ldisc installation timeout
[ 5.324161] (stk) :ldisc_install = 0[ 5.620260] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 6.319901] (stk) : timed out waiting for ldisc to be un-installed
[ 6.432831] (stk) :ldisc_install = 1(stk) :ldisc installation timeout
[ 7.432802] (stk) :ldisc_install = 0[ 8.380869] random: nonblocking pool is initialized
[ 8.430199] (stk) : timed out waiting for ldisc to be un-installed
[ 8.543150] (stk) :ldisc_install = 1[ 8.562553] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 8.599932] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 8.650562] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.657428] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.664723] usb usb1: Product: MUSB HDRC host driver
[ 8.669712] usb usb1: Manufacturer: Linux 3.14.43-g875c69b musb-hcd
[ 8.676024] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 8.757694] cfg80211: Calling CRDA to update world regulatory domain
[ 8.834454] hub 1-0:1.0: USB hub found
[ 8.838386] hub 1-0:1.0: 1 port detected
[ 8.867845] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[ 8.880539] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 2
[ 8.889312] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.896227] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.903509] usb usb2: Product: MUSB HDRC host driver
[ 8.908497] usb usb2: Manufacturer: Linux 3.14.43-g875c69b musb-hcd
[ 8.914811] usb usb2: SerialNumber: musb-hdrc.2.auto
[ 8.926423] hub 2-0:1.0: USB hub found
[ 8.930347] hub 2-0:1.0: 1 port detected
CCCCCCC
