Other Parts Discussed in Thread: DAC7512, PCF8574, LM63, LM70, LM73, LM77, LM80, LM83, LM87, LM90, LM92, LM93, LM95241, ADS7828, ADS7871, AMC6821, TMP102, TMP401, TMP421, TPS65010, TLV320AIC23B, TVP5150, TVP7002, THS7303, THS7353
I am working on DM368 Board act as a host and connect with a device(WIFI USB Dongle) that is running as an AP.
The WIFI Dongle loses its connection to WIFI devices whenever the error message is shown.
error message:
musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
I think there is something wrong with musb.
I am using Linux kernel version 2.6.37
Following is my kernel configuration
# Automatically generated make config: don't edit
# Linux/arm 2.6.37 Kernel Configuration
# Wed Oct 21 15:27:45 2015
CONFIG_ARM=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_GENERIC_GPIO=y
# CONFIG_ARCH_USES_GETTIMEOFFSET is not set
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_GENERIC_HARDIRQS=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_HAVE_LATENCYTOP_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_RWSEM_GENERIC_SPINLOCK=y
CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ZONE_DMA=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y
CONFIG_VECTORS_BASE=0xffff0000
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_CONSTRUCTORS=y
CONFIG_HAVE_IRQ_WORK=y
# General setup
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_LOCK_KERNEL=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_CROSS_COMPILE=""
CONFIG_LOCALVERSION="_IPNC_DM365_4.0.0"
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_SWAP is not set
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# CONFIG_AUDIT is not set
# CONFIG_HAVE_GENERIC_HARDIRQS is not set
# CONFIG_SPARSE_IRQ is not set
# RCU Subsystem
CONFIG_TREE_PREEMPT_RCU=y
# CONFIG_TINY_RCU is not set
# CONFIG_TINY_PREEMPT_RCU is not set
CONFIG_PREEMPT_RCU=y
# CONFIG_RCU_TRACE is not set
CONFIG_RCU_FANOUT=32
# CONFIG_RCU_FANOUT_EXACT is not set
# CONFIG_TREE_RCU_TRACE is not set
# CONFIG_IKCONFIG is not set
CONFIG_LOG_BUF_SHIFT=14
# CONFIG_CGROUPS is not set
# CONFIG_NAMESPACES is not set
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
# CONFIG_RD_BZIP2 is not set
# CONFIG_RD_LZMA is not set
# CONFIG_RD_LZO is not set
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_EMBEDDED=y
CONFIG_UID16=y
CONFIG_SYSCTL_SYSCALL=y
# CONFIG_KALLSYMS is not set
CONFIG_KALLSYMS_ALL=y
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# Kernel Performance Events And Counters
# CONFIG_PERF_EVENTS is not set
# CONFIG_PERF_COUNTERS is not set
CONFIG_VM_EVENT_COUNTERS=y
# CONFIG_SLUB_DEBUG is not set
CONFIG_COMPAT_BRK=y
# CONFIG_SLAB is not set
CONFIG_SLUB=y
# CONFIG_SLOB is not set
# CONFIG_PROFILING is not set
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_CLK=y
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
# CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_BLOCK=y
CONFIG_LBDAF=y
# CONFIG_BLK_DEV_BSG is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
# CONFIG_IOSCHED_DEADLINE is not set
# CONFIG_IOSCHED_CFQ is not set
CONFIG_DEFAULT_NOOP=y
CONFIG_DEFAULT_IOSCHED="noop"
# CONFIG_INLINE_SPIN_TRYLOCK is not set
# CONFIG_INLINE_SPIN_TRYLOCK_BH is not set
# CONFIG_INLINE_SPIN_LOCK is not set
# CONFIG_INLINE_SPIN_LOCK_BH is not set
# CONFIG_INLINE_SPIN_LOCK_IRQ is not set
# CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set
# CONFIG_INLINE_SPIN_UNLOCK is not set
# CONFIG_INLINE_SPIN_UNLOCK_BH is not set
# CONFIG_INLINE_SPIN_UNLOCK_IRQ is not set
# CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set
# CONFIG_INLINE_READ_TRYLOCK is not set
# CONFIG_INLINE_READ_LOCK is not set
# CONFIG_INLINE_READ_LOCK_BH is not set
# CONFIG_INLINE_READ_LOCK_IRQ is not set
# CONFIG_INLINE_READ_LOCK_IRQSAVE is not set
# CONFIG_INLINE_READ_UNLOCK is not set
# CONFIG_INLINE_READ_UNLOCK_BH is not set
# CONFIG_INLINE_READ_UNLOCK_IRQ is not set
# CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set
# CONFIG_INLINE_WRITE_TRYLOCK is not set
# CONFIG_INLINE_WRITE_LOCK is not set
# CONFIG_INLINE_WRITE_LOCK_BH is not set
# CONFIG_INLINE_WRITE_LOCK_IRQ is not set
# CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set
# CONFIG_INLINE_WRITE_UNLOCK is not set
# CONFIG_INLINE_WRITE_UNLOCK_BH is not set
# CONFIG_INLINE_WRITE_UNLOCK_IRQ is not set
# CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set
# CONFIG_MUTEX_SPIN_ON_OWNER is not set
# CONFIG_FREEZER is not set
# System Type
CONFIG_MMU=y
# CONFIG_ARCH_AAEC2000 is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_VERSATILE is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_BCMRING is not set
# CONFIG_ARCH_CLPS711X is not set
# CONFIG_ARCH_CNS3XXX is not set
# CONFIG_ARCH_GEMINI is not set
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_STMP3XXX is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_H720X is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP23XX is not set
# CONFIG_ARCH_IXP2000 is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_KIRKWOOD is not set
# CONFIG_ARCH_LOKI is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_MV78XX0 is not set
# CONFIG_ARCH_ORION5X is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_NS9XXX is not set
# CONFIG_ARCH_W90X900 is not set
# CONFIG_ARCH_NUC93X is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_PNX4008 is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_MSM is not set
# CONFIG_ARCH_SHMOBILE is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C2410 is not set
# CONFIG_ARCH_S3C64XX is not set
# CONFIG_ARCH_S5P64X0 is not set
# CONFIG_ARCH_S5P6442 is not set
# CONFIG_ARCH_S5PC100 is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_S5PV310 is not set
# CONFIG_ARCH_SHARK is not set
# CONFIG_ARCH_TCC_926 is not set
# CONFIG_ARCH_LH7A40X is not set
# CONFIG_ARCH_U300 is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_NOMADIK is not set
CONFIG_ARCH_DAVINCI=y
# CONFIG_ARCH_OMAP is not set
# CONFIG_PLAT_SPEAR is not set
CONFIG_AINTC=y
CONFIG_ARCH_DAVINCI_DMx=y
# TI DaVinci Implementations
# DaVinci Core Type
# CONFIG_ARCH_DAVINCI_DM644x is not set
# CONFIG_ARCH_DAVINCI_DM355 is not set
# CONFIG_ARCH_DAVINCI_DM646x is not set
# CONFIG_ARCH_DAVINCI_DA830 is not set
# CONFIG_ARCH_DAVINCI_DA850 is not set
CONFIG_ARCH_DAVINCI_DM365=y
# CONFIG_ARCH_DAVINCI_TNETV107X is not set
# DaVinci Board Type
# CONFIG_MACH_DAVINCI_DM365_EVM is not set
# CONFIG_MACH_DAVINCI_DM365_IPNC is not set
CONFIG_MACH_DAVINCI_DM368_IPNC=y
# CONFIG_GPIO_PCA953X is not set
# CONFIG_KEYBOARD_GPIO_POLLED is not set
CONFIG_DAVINCI_MUX=y
# CONFIG_DAVINCI_MUX_DEBUG is not set
# CONFIG_DAVINCI_MUX_WARNINGS is not set
CONFIG_DAVINCI_RESET_CLOCKS=y
CONFIG_DAVINCI_MCBSP=y
CONFIG_DAVINCI_MCBSP0=y
CONFIG_DAVINCI_MCBSP1=y
# Processor Type
CONFIG_CPU_ARM926T=y
CONFIG_CPU_32v5=y
CONFIG_CPU_ABRT_EV5TJ=y
CONFIG_CPU_PABRT_LEGACY=y
CONFIG_CPU_CACHE_VIVT=y
CONFIG_CPU_COPY_V4WB=y
CONFIG_CPU_TLB_V4WBI=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
CONFIG_ARM_THUMB=y
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_WRITETHROUGH is not set
# CONFIG_CPU_CACHE_ROUND_ROBIN is not set
CONFIG_ARM_L1_CACHE_SHIFT=5
CONFIG_COMMON_CLKDEV=y
# Bus support
# CONFIG_PCI_SYSCALL is not set
# CONFIG_ARCH_SUPPORTS_MSI is not set
# CONFIG_PCCARD is not set
# Kernel Features
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_HZ=100
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
# CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
# CONFIG_HIGHMEM is not set
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_HAVE_MEMBLOCK=y
CONFIG_PAGEFLAGS_EXTENDED=y
CONFIG_SPLIT_PTLOCK_CPUS=999999
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=1
CONFIG_BOUNCE=y
CONFIG_VIRT_TO_BUS=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_NEED_PER_CPU_KM=y
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_LEDS=y
# CONFIG_LEDS_CPU is not set
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
# CONFIG_SECCOMP is not set
# CONFIG_CC_STACKPROTECTOR is not set
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
# Boot options
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
CONFIG_CMDLINE=""
# CONFIG_XIP_KERNEL is not set
# CONFIG_KEXEC is not set
# CONFIG_AUTO_ZRELADDR is not set
# CPU Power Management
# CONFIG_CPU_IDLE is not set
# Floating point emulation
# At least one emulation must be selected
# CONFIG_VFP is not set
# Userspace binary formats
CONFIG_BINFMT_ELF=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
CONFIG_HAVE_AOUT=y
# CONFIG_BINFMT_AOUT is not set
# CONFIG_BINFMT_MISC is not set
# Power management options
# CONFIG_PM is not set
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_XFRM=y
# CONFIG_XFRM_USER is not set
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
# CONFIG_NET_KEY is not set
CONFIG_INET=y
# CONFIG_IP_MULTICAST is not set
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
# CONFIG_IP_PNP_RARP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
# CONFIG_INET_TUNNEL is not set
CONFIG_INET_XFRM_MODE_TRANSPORT=y
CONFIG_INET_XFRM_MODE_TUNNEL=y
CONFIG_INET_XFRM_MODE_BEET=y
# CONFIG_INET_LRO is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
# CONFIG_IPV6 is not set
# CONFIG_NETWORK_SECMARK is not set
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
# CONFIG_NETFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_IRDA is not set
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_SPY=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=y
CONFIG_NL80211_TESTMODE=y
CONFIG_CFG80211_DEVELOPER_WARNINGS=y
# CONFIG_CFG80211_REG_DEBUG is not set
# CONFIG_CFG80211_DEFAULT_PS is not set
CONFIG_CFG80211_DEBUGFS=y
# CONFIG_CFG80211_INTERNAL_REGDB is not set
CONFIG_CFG80211_WEXT=y
CONFIG_WIRELESS_EXT_SYSFS=y
CONFIG_LIB80211=y
CONFIG_LIB80211_CRYPT_WEP=y
CONFIG_LIB80211_CRYPT_CCMP=y
CONFIG_LIB80211_CRYPT_TKIP=y
CONFIG_LIB80211_DEBUG=y
CONFIG_MAC80211=y
# CONFIG_MAC80211_HAS_RC is not set
# CONFIG_MAC80211_RC_PID is not set
# CONFIG_MAC80211_RC_MINSTREL is not set
CONFIG_MAC80211_RC_DEFAULT=""
# Some wireless drivers require a rate control algorithm
# CONFIG_MAC80211_MESH is not set
CONFIG_MAC80211_DEBUGFS=y
CONFIG_MAC80211_DEBUG_MENU=y
# CONFIG_MAC80211_NOINLINE is not set
CONFIG_MAC80211_VERBOSE_DEBUG=y
# CONFIG_MAC80211_HT_DEBUG is not set
CONFIG_MAC80211_TKIP_DEBUG=y
# CONFIG_MAC80211_IBSS_DEBUG is not set
# CONFIG_MAC80211_VERBOSE_PS_DEBUG is not set
CONFIG_MAC80211_DEBUG_COUNTERS=y
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
# CONFIG_DEVTMPFS is not set
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_CONNECTOR is not set
CONFIG_MTD=y
# CONFIG_MTD_DEBUG is not set
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_CONCAT is not set
CONFIG_MTD_PARTITIONS=y
# CONFIG_MTD_REDBOOT_PARTS is not set
CONFIG_MTD_CMDLINE_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_AR7_PARTS is not set
# User Modules And Translation Layers
CONFIG_MTD_CHAR=y
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
# CONFIG_MTD_DATAFLASH is not set
# CONFIG_MTD_M25P80 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOC2000 is not set
# CONFIG_MTD_DOC2001 is not set
# CONFIG_MTD_DOC2001PLUS is not set
CONFIG_MTD_NAND_ECC=y
# CONFIG_MTD_NAND_ECC_SMC is not set
CONFIG_MTD_NAND=y
# CONFIG_MTD_NAND_VERIFY_WRITE is not set
# CONFIG_MTD_SM_COMMON is not set
# CONFIG_MTD_NAND_MUSEUM_IDS is not set
# CONFIG_MTD_NAND_GPIO is not set
CONFIG_MTD_NAND_IDS=y
# CONFIG_MTD_NAND_DISKONCHIP is not set
# CONFIG_MTD_NAND_NANDSIM is not set
CONFIG_MTD_NAND_PLATFORM=y
# CONFIG_MTD_ALAUDA is not set
CONFIG_MTD_NAND_DAVINCI=y
# CONFIG_MTD_ONENAND is not set
# LPDDR flash memory drivers
# CONFIG_MTD_LPDDR is not set
CONFIG_MTD_UBI=y
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_RESERVE=1
# CONFIG_MTD_UBI_GLUEBI is not set
# UBI debugging options
# CONFIG_MTD_UBI_DEBUG is not set
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=y
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
# DRBD disabled because PROC_FS, INET or CONNECTOR not selected
CONFIG_BLK_DEV_NBD=y
# CONFIG_BLK_DEV_UB is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=1
CONFIG_BLK_DEV_RAM_SIZE=32768
# CONFIG_BLK_DEV_XIP is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_MG_DISK is not set
# CONFIG_BLK_DEV_RBD is not set
CONFIG_MISC_DEVICES=y
# CONFIG_AD525X_DPOT is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1780 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_TI_DAC7512 is not set
# CONFIG_BMP085 is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_IWMC3200TOP is not set
# Texas Instruments shared transport line discipline
CONFIG_HAVE_IDE=y
# CONFIG_IDE is not set
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_TGT is not set
# CONFIG_SCSI_NETLINK is not set
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
# CONFIG_BLK_DEV_SR is not set
CONFIG_CHR_DEV_SG=y
# CONFIG_CHR_DEV_SCH is not set
# CONFIG_SCSI_MULTI_LUN is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
CONFIG_SCSI_WAIT_SCAN=m
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
CONFIG_SCSI_ISCSI_ATTRS=m
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
CONFIG_SCSI_LOWLEVEL=y
CONFIG_ISCSI_TCP=m
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_LIBFC is not set
# CONFIG_LIBFCOE is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_DH is not set
# CONFIG_SCSI_OSD_INITIATOR is not set
# CONFIG_ATA is not set
# CONFIG_MD is not set
CONFIG_NETDEVICES=y
# CONFIG_DUMMY is not set
# CONFIG_BONDING is not set
# CONFIG_MACVLAN is not set
# CONFIG_EQUALIZER is not set
CONFIG_TUN=y
# CONFIG_VETH is not set
# CONFIG_MII is not set
CONFIG_PHYLIB=y
# MII PHY device drivers
# CONFIG_MARVELL_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_QSEMI_PHY is not set
CONFIG_LXT_PHY=y
# CONFIG_CICADA_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_BCM63XX_PHY is not set
# CONFIG_ICPLUS_PHY is not set
CONFIG_REALTEK_PHY=y
# CONFIG_NATIONAL_PHY is not set
# CONFIG_STE10XP is not set
CONFIG_LSI_ET1011C_PHY=y
# CONFIG_MICREL_PHY is not set
# CONFIG_FIXED_PHY is not set
# CONFIG_MDIO_BITBANG is not set
CONFIG_NET_ETHERNET=y
# CONFIG_AX88796 is not set
# CONFIG_SMC91X is not set
CONFIG_TI_DAVINCI_EMAC=y
CONFIG_TI_DAVINCI_MDIO=y
CONFIG_TI_DAVINCI_CPDMA=y
# CONFIG_DM9000 is not set
# CONFIG_ENC28J60 is not set
# CONFIG_ETHOC is not set
# CONFIG_SMC911X is not set
# CONFIG_SMSC911X is not set
# CONFIG_DNET is not set
# CONFIG_IBM_NEW_EMAC_ZMII is not set
# CONFIG_IBM_NEW_EMAC_RGMII is not set
# CONFIG_IBM_NEW_EMAC_TAH is not set
# CONFIG_IBM_NEW_EMAC_EMAC4 is not set
# CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
# CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
# CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
# CONFIG_B44 is not set
# CONFIG_KS8851 is not set
# CONFIG_KS8851_MLL is not set
# CONFIG_NETDEV_1000 is not set
# CONFIG_NETDEV_10000 is not set
CONFIG_WLAN=y
# CONFIG_LIBERTAS_THINFIRM is not set
# CONFIG_AT76C50X_USB is not set
# CONFIG_USB_ZD1201 is not set
# CONFIG_USB_NET_RNDIS_WLAN is not set
# CONFIG_RTL8187 is not set
# CONFIG_MAC80211_HWSIM is not set
# CONFIG_ATH_COMMON is not set
# CONFIG_B43 is not set
# CONFIG_B43LEGACY is not set
CONFIG_HOSTAP=y
CONFIG_HOSTAP_FIRMWARE=y
CONFIG_HOSTAP_FIRMWARE_NVRAM=y
# CONFIG_IWM is not set
# CONFIG_LIBERTAS is not set
# CONFIG_P54_COMMON is not set
# CONFIG_RT2X00 is not set
# CONFIG_WL1251 is not set
# CONFIG_WL12XX is not set
# CONFIG_ZD1211RW is not set
CONFIG_RTL8192CU=m
# Enable WiMAX (Networking options) to see the WiMAX drivers
# USB Network Adapters
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_USBNET is not set
# CONFIG_USB_IPHETH is not set
# CONFIG_WAN is not set
# CAIF transport drivers
CONFIG_PPP=m
# CONFIG_PPP_MULTILINK is not set
# CONFIG_PPP_FILTER is not set
# CONFIG_PPP_ASYNC is not set
# CONFIG_PPP_SYNC_TTY is not set
CONFIG_PPP_DEFLATE=m
# CONFIG_PPP_BSDCOMP is not set
# CONFIG_PPP_MPPE is not set
# CONFIG_PPPOE is not set
# CONFIG_SLIP is not set
CONFIG_SLHC=m
CONFIG_NETCONSOLE=m
# CONFIG_NETCONSOLE_DYNAMIC is not set
CONFIG_NETPOLL=y
CONFIG_NETPOLL_TRAP=y
CONFIG_NET_POLL_CONTROLLER=y
# CONFIG_ISDN is not set
# CONFIG_PHONE is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_FF_MEMLESS=y
# CONFIG_INPUT_POLLDEV is not set
# CONFIG_INPUT_SPARSEKMAP is not set
# Userland interfaces
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
CONFIG_INPUT_EVBUG=y
# Input Device Drivers
# CONFIG_INPUT_KEYBOARD is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_ATI_REMOTE is not set
# CONFIG_INPUT_ATI_REMOTE2 is not set
# CONFIG_INPUT_KEYSPAN_REMOTE is not set
# CONFIG_INPUT_POWERMATE is not set
# CONFIG_INPUT_YEALINK is not set
# CONFIG_INPUT_CM109 is not set
# CONFIG_INPUT_UINPUT is not set
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_INPUT_ADXL34X is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
# CONFIG_VT_CONSOLE is not set
CONFIG_HW_CONSOLE=y
# CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_DEVKMEM=y
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# Serial drivers
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_NR_UARTS=2
CONFIG_SERIAL_8250_RUNTIME_UARTS=2
# CONFIG_SERIAL_8250_EXTENDED is not set
# Non-8250 serial port support
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX3107 is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_TIMBERDALE is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
CONFIG_UNIX98_PTYS=y
CONFIG_DEVPTS_MULTIPLE_INSTANCES=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
CONFIG_TTY_PRINTK=y
# CONFIG_IPMI_HANDLER is not set
# CONFIG_HW_RANDOM is not set
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_DAVINCI_ADC is not set
# CONFIG_RAMOOPS is not set
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
# CONFIG_I2C_MUX is not set
CONFIG_I2C_HELPER_AUTO=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
CONFIG_I2C_DAVINCI=y
# CONFIG_I2C_DESIGNWARE is not set
# CONFIG_I2C_GPIO is not set
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
# SPI Master Controller Drivers
CONFIG_SPI_BITBANG=y
CONFIG_SPI_DAVINCI=y
# CONFIG_SPI_GPIO is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_DESIGNWARE is not set
# SPI Protocol Masters
# CONFIG_SPI_SPIDEV is not set
# CONFIG_SPI_TLE62X0 is not set
# PPS support
# CONFIG_PPS is not set
CONFIG_ARCH_REQUIRE_GPIOLIB=y
CONFIG_GPIOLIB=y
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO expanders:
# CONFIG_GPIO_BASIC_MMIO is not set
# CONFIG_GPIO_IT8761E is not set
# CONFIG_GPIO_VX855 is not set
# I2C GPIO expanders:
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
CONFIG_GPIO_PCF857X=y
# CONFIG_GPIO_SX150X is not set
# CONFIG_GPIO_ADP5588 is not set
# PCI GPIO expanders:
# SPI GPIO expanders:
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MCP23S08 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_74X164 is not set
# AC97 GPIO expanders:
# MODULbus GPIO expanders:
# CONFIG_GENERIC_PWM is not set
# CONFIG_W1 is not set
CONFIG_POWER_SUPPLY=y
CONFIG_POWER_SUPPLY_DEBUG=y
# CONFIG_PDA_POWER is not set
# CONFIG_TEST_POWER is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_BQ20Z75 is not set
# CONFIG_BATTERY_BQ27x00 is not set
CONFIG_BATTERY_MAX17040=y
# CONFIG_CHARGER_ISP1704 is not set
CONFIG_HWMON=y
# CONFIG_HWMON_VID is not set
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADCXX is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_GPIO_FAN is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_JC42 is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM70 is not set
# CONFIG_SENSORS_LM73 is not set
# CONFIG_SENSORS_LM75 is not set
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_MAX1111 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_SENSORS_SHT15 is not set
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_ADS7871 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_THMC50 is not set
# CONFIG_SENSORS_TMP102 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_THERMAL is not set
CONFIG_WATCHDOG=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
CONFIG_DAVINCI_WATCHDOG=y
# CONFIG_MAX63XX_WATCHDOG is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
CONFIG_MFD_SUPPORT=y
CONFIG_MFD_CORE=y
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_ASIC3 is not set
CONFIG_MFD_DAVINCI_VOICECODEC=y
# CONFIG_HTC_EGPIO is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_MFD_STMPE is not set
# CONFIG_MFD_TC35892 is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_MC13XXX is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_REGULATOR is not set
CONFIG_MEDIA_SUPPORT=y
# Multimedia core support
CONFIG_MEDIA_CONTROLLER=y
CONFIG_VIDEO_DEV=y
CONFIG_VIDEO_V4L2_COMMON=y
# CONFIG_VIDEO_ALLOW_V4L1 is not set
# CONFIG_VIDEO_V4L1_COMPAT is not set
CONFIG_VIDEO_V4L2_SUBDEV_API=y
# CONFIG_DVB_CORE is not set
CONFIG_VIDEO_MEDIA=y
# Multimedia drivers
# CONFIG_IR_CORE is not set
# CONFIG_MEDIA_ATTACH is not set
CONFIG_MEDIA_TUNER=y
# CONFIG_MEDIA_TUNER_CUSTOMISE is not set
CONFIG_MEDIA_TUNER_SIMPLE=y
CONFIG_MEDIA_TUNER_TDA8290=y
CONFIG_MEDIA_TUNER_TDA827X=y
CONFIG_MEDIA_TUNER_TDA18271=y
CONFIG_MEDIA_TUNER_TDA9887=y
CONFIG_MEDIA_TUNER_TEA5761=y
CONFIG_MEDIA_TUNER_TEA5767=y
CONFIG_MEDIA_TUNER_MT20XX=y
CONFIG_MEDIA_TUNER_XC2028=y
CONFIG_MEDIA_TUNER_XC5000=y
CONFIG_MEDIA_TUNER_MC44S803=y
CONFIG_VIDEO_V4L2=y
CONFIG_VIDEOBUF_GEN=y
CONFIG_VIDEOBUF_DMA_CONTIG=y
CONFIG_VIDEO_CAPTURE_DRIVERS=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
# CONFIG_VIDEO_HELPER_CHIPS_AUTO is not set
# Encoders/decoders and other helper chips
# Audio decoders
# CONFIG_VIDEO_TVAUDIO is not set
# CONFIG_VIDEO_TDA7432 is not set
# CONFIG_VIDEO_TDA9840 is not set
# CONFIG_VIDEO_TDA9875 is not set
# CONFIG_VIDEO_TEA6415C is not set
# CONFIG_VIDEO_TEA6420 is not set
# CONFIG_VIDEO_MSP3400 is not set
# CONFIG_VIDEO_CS5345 is not set
# CONFIG_VIDEO_CS53L32A is not set
# CONFIG_VIDEO_M52790 is not set
# CONFIG_VIDEO_TLV320AIC23B is not set
# CONFIG_VIDEO_WM8775 is not set
# CONFIG_VIDEO_WM8739 is not set
# CONFIG_VIDEO_VP27SMPX is not set
# RDS decoders
# CONFIG_VIDEO_SAA6588 is not set
# Video decoders
# CONFIG_VIDEO_ADV7180 is not set
# CONFIG_VIDEO_BT819 is not set
# CONFIG_VIDEO_BT856 is not set
# CONFIG_VIDEO_BT866 is not set
# CONFIG_VIDEO_KS0127 is not set
# CONFIG_VIDEO_OV7670 is not set
# CONFIG_VIDEO_MT9V011 is not set
# CONFIG_VIDEO_TCM825X is not set
# CONFIG_VIDEO_SAA7110 is not set
# CONFIG_VIDEO_SAA711X is not set
# CONFIG_VIDEO_SAA717X is not set
# CONFIG_VIDEO_SAA7191 is not set
# CONFIG_VIDEO_TVP514X is not set
# CONFIG_VIDEO_TVP5150 is not set
# CONFIG_VIDEO_TVP7002 is not set
# CONFIG_VIDEO_VPX3220 is not set
# Video and audio decoders
# CONFIG_VIDEO_CX25840 is not set
# MPEG video encoders
# CONFIG_VIDEO_CX2341X is not set
# Video encoders
# CONFIG_VIDEO_SAA7127 is not set
# CONFIG_VIDEO_SAA7185 is not set
# CONFIG_VIDEO_ADV7170 is not set
# CONFIG_VIDEO_ADV7175 is not set
# CONFIG_VIDEO_THS7303 is not set
# CONFIG_VIDEO_THS7353 is not set
# CONFIG_VIDEO_ADV7343 is not set
# CONFIG_VIDEO_AK881X is not set
# Video improvement chips
# CONFIG_VIDEO_UPD64031A is not set
# CONFIG_VIDEO_UPD64083 is not set
# CONFIG_VIDEO_DM365_3A_HW is not set
# CONFIG_VIDEO_DM365_AF is not set
# CONFIG_VIDEO_DM365_AEW is not set
# CONFIG_DM365_IPIPE is not set
CONFIG_VIDEO_VPSS_SYSTEM=y
# CONFIG_VIDEO_VPFE_CAPTURE is not set
CONFIG_VIDEO_DM644X_VPBE=y
CONFIG_VIDEO_VPBE_DISPLAY=y
# CONFIG_VIDEO_CPIA2 is not set
# CONFIG_VIDEO_SR030PC30 is not set
# CONFIG_SOC_CAMERA is not set
# CONFIG_SOC_CAMERA_MT9T031 is not set
# CONFIG_SOC_CAMERA_MT9P031 is not set
# CONFIG_SOC_CAMERA_PO1150K is not set
CONFIG_SOC_CAMERA_MT9D111=y
# CONFIG_V4L_USB_DRIVERS is not set
# CONFIG_V4L_MEM2MEM_DRIVERS is not set
# CONFIG_RADIO_ADAPTERS is not set
# CONFIG_DAB is not set
# Graphics support
# CONFIG_DRM is not set
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
# CONFIG_FB is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Display device support
# CONFIG_DISPLAY_SUPPORT is not set
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_SOUND=y
# CONFIG_SOUND_OSS_CORE is not set
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_JACK=y
# CONFIG_SND_SEQUENCER is not set
# CONFIG_SND_MIXER_OSS is not set
# CONFIG_SND_PCM_OSS is not set
# CONFIG_SND_HRTIMER is not set
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# CONFIG_SND_RAWMIDI_SEQ is not set
# CONFIG_SND_OPL3_LIB_SEQ is not set
# CONFIG_SND_OPL4_LIB_SEQ is not set
# CONFIG_SND_SBAWE_SEQ is not set
# CONFIG_SND_EMU10K1_SEQ is not set
CONFIG_SND_DRIVERS=y
# CONFIG_SND_DUMMY is not set
# CONFIG_SND_ALOOP is not set
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_MPU401 is not set
CONFIG_SND_ARM=y
CONFIG_SND_SPI=y
# CONFIG_SND_USB is not set
CONFIG_SND_SOC=y
CONFIG_SND_DAVINCI_SOC=y
CONFIG_SND_DAVINCI_SOC_I2S=y
CONFIG_SND_DAVINCI_SOC_VCIF=y
CONFIG_SND_DAVINCI_SOC_EVM=y
# CONFIG_SND_DM365_AIC3X_CODEC is not set
CONFIG_SND_DM365_VOICE_CODEC=y
CONFIG_SND_SOC_I2C_AND_SPI=y
# CONFIG_SND_SOC_ALL_CODECS is not set
CONFIG_SND_SOC_CQ0093VC=y
CONFIG_SND_SOC_TLV320AIC3X=y
# CONFIG_SOUND_PRIME is not set
# CONFIG_HID_SUPPORT is not set
CONFIG_USB_SUPPORT=y
CONFIG_USB_ARCH_HAS_HCD=y
# CONFIG_USB_ARCH_HAS_OHCI is not set
# CONFIG_USB_ARCH_HAS_EHCI is not set
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
# Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
CONFIG_USB_DEVICE_CLASS=y
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_MON is not set
# CONFIG_USB_WUSB is not set
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1760_HCD is not set
# CONFIG_USB_ISP1362_HCD is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HWA_HCD is not set
CONFIG_USB_MUSB_HDRC=m
CONFIG_USB_MUSB_SOC=y
# DaVinci 35x and 644x USB support
# CONFIG_USB_MUSB_AM35X is not set
CONFIG_USB_MUSB_HOST=y
CONFIG_USB_MUSB_HDRC_HCD=y
# CONFIG_MUSB_PIO_ONLY is not set
# CONFIG_USB_INVENTRA_DMA is not set
CONFIG_USB_TI_CPPI_DMA=y
# CONFIG_USB_MUSB_DEBUG is not set
# USB Device Class drivers
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
# CONFIG_USB_WDM is not set
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
# CONFIG_USB_STORAGE is not set
# CONFIG_USB_UAS is not set
# CONFIG_USB_LIBUSUAL is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# USB port drivers
# CONFIG_USB_SERIAL is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
# CONFIG_USB_GADGET is not set
# OTG and related infrastructure
CONFIG_USB_OTG_UTILS=y
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ULPI is not set
CONFIG_NOP_USB_XCEIV=y
CONFIG_MMC=y
# CONFIG_MMC_DEBUG is not set
# CONFIG_MMC_UNSAFE_RESUME is not set
# MMC/SD/SDIO Card Drivers
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
# CONFIG_MMC_BLOCK_BOUNCE is not set
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
CONFIG_MMC_SDHCI=y
# CONFIG_MMC_SDHCI_PLTFM is not set
CONFIG_MMC_DAVINCI=y
# CONFIG_MMC_SPI is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MEMSTICK is not set
# CONFIG_NEW_LEDS is not set
# CONFIG_ACCESSIBILITY is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=m
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_BQ32K is not set
CONFIG_RTC_DRV_S35390A=m
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_DS3234 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# on-CPU RTC drivers
# CONFIG_RTC_DRV_DAVINCI is not set
# CONFIG_DMADEVICES is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# CONFIG_STAGING is not set
# File systems
CONFIG_EXT2_FS=y
CONFIG_EXT2_FS_XATTR=y
CONFIG_EXT2_FS_POSIX_ACL=y
CONFIG_EXT2_FS_SECURITY=y
CONFIG_EXT2_FS_XIP=y
CONFIG_EXT3_FS=y
CONFIG_EXT3_DEFAULTS_TO_ORDERED=y
CONFIG_EXT3_FS_XATTR=y
CONFIG_EXT3_FS_POSIX_ACL=y
CONFIG_EXT3_FS_SECURITY=y
# CONFIG_EXT4_FS is not set
CONFIG_FS_XIP=y
CONFIG_JBD=y
# CONFIG_JBD_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
CONFIG_FS_POSIX_ACL=y
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
CONFIG_FILE_LOCKING=y
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
# CONFIG_QUOTA is not set
# CONFIG_QUOTACTL is not set
# CONFIG_AUTOFS4_FS is not set
# CONFIG_FUSE_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_HUGETLB_PAGE is not set
# CONFIG_CONFIGFS_FS is not set
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_JFFS2_FS=y
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
# CONFIG_JFFS2_SUMMARY is not set
# CONFIG_JFFS2_FS_XATTR is not set
# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
# CONFIG_JFFS2_LZO is not set
CONFIG_JFFS2_RTIME=y
# CONFIG_JFFS2_RUBIN is not set
CONFIG_UBIFS_FS=y
CONFIG_UBIFS_FS_XATTR=y
CONFIG_UBIFS_FS_ADVANCED_COMPR=y
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
CONFIG_UBIFS_FS_DEBUG=y
CONFIG_UBIFS_FS_DEBUG_MSG_LVL=0
# CONFIG_UBIFS_FS_DEBUG_CHKS is not set
# CONFIG_LOGFS is not set
CONFIG_CRAMFS=y
CONFIG_SQUASHFS=y
# CONFIG_SQUASHFS_XATTR is not set
# CONFIG_SQUASHFS_LZO is not set
# CONFIG_SQUASHFS_EMBEDDED is not set
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# CONFIG_NETWORK_FILESYSTEMS is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
# CONFIG_EFI_PARTITION is not set
# CONFIG_SYSV68_PARTITION is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
CONFIG_NLS_UTF8=y
# CONFIG_DLM is not set
# Kernel hacking
CONFIG_PRINTK_TIME=y
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_MAGIC_SYSRQ is not set
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_UNUSED_SYMBOLS is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_KERNEL is not set
# CONFIG_HARDLOCKUP_DETECTOR is not set
# CONFIG_SLUB_STATS is not set
CONFIG_BKL=y
# CONFIG_SPARSE_RCU_POINTER is not set
CONFIG_DEBUG_BUGVERBOSE=y
# CONFIG_DEBUG_MEMORY_INIT is not set
CONFIG_FRAME_POINTER=y
# CONFIG_RCU_CPU_STALL_DETECTOR is not set
# CONFIG_LKDTM is not set
# CONFIG_SYSCTL_SYSCALL_CHECK is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
# CONFIG_FUNCTION_TRACER is not set
# CONFIG_IRQSOFF_TRACER is not set
# CONFIG_PREEMPT_TRACER is not set
# CONFIG_SCHED_TRACER is not set
# CONFIG_ENABLE_DEFAULT_TRACERS is not set
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
# CONFIG_PROFILE_ALL_BRANCHES is not set
# CONFIG_STACK_TRACER is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
# CONFIG_DYNAMIC_DEBUG is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_STRICT_DEVMEM is not set
# CONFIG_ARM_UNWIND is not set
CONFIG_DEBUG_USER=y
# CONFIG_OC_ETM is not set
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_PCOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
# CONFIG_CRYPTO_GF128MUL is not set
# CONFIG_CRYPTO_NULL is not set
CONFIG_CRYPTO_WORKQUEUE=y
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_SEQIV is not set
# Block modes
CONFIG_CRYPTO_CBC=y
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=y
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# Hash modes
# CONFIG_CRYPTO_HMAC is not set
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=m
# CONFIG_CRYPTO_GHASH is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_MICHAEL_MIC=y
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=m
# CONFIG_CRYPTO_SHA256 is not set
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=y
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
CONFIG_CRYPTO_DEFLATE=y
# CONFIG_CRYPTO_ZLIB is not set
CONFIG_CRYPTO_LZO=y
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
# CONFIG_CRYPTO_HW is not set
# CONFIG_BINARY_PRINTF is not set
# Library routines
CONFIG_BITREVERSE=y
CONFIG_GENERIC_FIND_LAST_BIT=y
CONFIG_CRC_CCITT=m
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC7 is not set
CONFIG_LIBCRC32C=m
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_DECOMPRESS_GZIP=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
CONFIG_NLATTR=y
CONFIG_GENERIC_ATOMIC64=y
And This is kernel log when occurring stopping wifi operation.
vice 0:0e, driver unknown
<6>[ 2.799906] davinci_mdio davinci_mdio.0: phy[15]: device 0:0f, driver unknown
<6>[ 2.807143] davinci_mdio davinci_mdio.0: phy[16]: device 0:10, driver unknown
<6>[ 2.814381] davinci_mdio davinci_mdio.0: phy[17]: device 0:11, driver unknown
<6>[ 2.821617] davinci_mdio davinci_mdio.0: phy[18]: device 0:12, driver unknown
<6>[ 2.828808] davinci_mdio davinci_mdio.0: phy[19]: device 0:13, driver unknown
<6>[ 2.836042] davinci_mdio davinci_mdio.0: phy[20]: device 0:14, driver unknown
<6>[ 2.843283] davinci_mdio davinci_mdio.0: phy[21]: device 0:15, driver unknown
<6>[ 2.850522] davinci_mdio davinci_mdio.0: phy[22]: device 0:16, driver unknown
<6>[ 2.857713] davinci_mdio davinci_mdio.0: phy[23]: device 0:17, driver unknown
<6>[ 2.864945] davinci_mdio davinci_mdio.0: phy[24]: device 0:18, driver unknown
<6>[ 2.872183] davinci_mdio davinci_mdio.0: phy[25]: device 0:19, driver unknown
<6>[ 2.879374] davinci_mdio davinci_mdio.0: phy[26]: device 0:1a, driver unknown
<6>[ 2.886608] davinci_mdio davinci_mdio.0: phy[27]: device 0:1b, driver unknown
<6>[ 2.893846] davinci_mdio davinci_mdio.0: phy[28]: device 0:1c, driver unknown
<6>[ 2.901085] davinci_mdio davinci_mdio.0: phy[29]: device 0:1d, driver unknown
<6>[ 2.908275] davinci_mdio davinci_mdio.0: phy[30]: device 0:1e, driver unknown
<6>[ 2.915509] davinci_mdio davinci_mdio.0: phy[31]: device 0:1f, driver unknown
<6>[ 2.923304] tun: Universal TUN/TAP device driver, 1.6
<6>[ 2.928401] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<6>[ 2.935914] i2c /dev entries driver
<4>[ 2.940187]
<4>[ 2.940199] line:438:@i2c_add_driver in include/linux/i2c.h
<4>[ 2.949651] i2c-core: driver [dev_driver] registered
<6>[ 2.956035] Linux media interface: v0.10
<6>[ 2.960801] Linux video capture interface: v2.00
<4>[ 2.966103]
<4>[ 2.966115] line:1016:@mt9d111_mod_init in drivers/media/video/mt9d111.c
<4>[ 2.976302]
<4>[ 2.976314] line:1017:@mt9d111_mod_init in drivers/media/video/mt9d111.c
<4>[ 2.986487]
<4>[ 2.986499] line:1018:@mt9d111_mod_init in drivers/media/video/mt9d111.c
<4>[ 2.996625]
<4>[ 2.996637] line:438:@i2c_add_driver in include/linux/i2c.h
<4>[ 3.006135] i2c-core: driver [mt9d111] registered
<5>[ 3.011826] vpbe-osd vpbe-osd: OSD sub device probe success
<5>[ 3.018245] vpbe-venc vpbe-venc: VENC sub device probe success
<7>[ 3.024712] vpbe_display_init
<7>[ 3.024868] vpbe_display_probe
<6>[ 3.024984] vpbe-v4l2 vpbe-v4l2: vpbe v4l2 device registered
<7>[ 3.031014] vpbe-venc: venc_set_ntsc
<7>[ 3.031054] vpbe-venc: venc_enabledigitaloutput
<5>[ 3.031122] Setting default output to Composite
<5>[ 3.035697] Setting default mode to ntsc
<7>[ 3.039651] vpbe-venc: venc_set_ntsc
<7>[ 3.039676] vpbe-venc: venc_enabledigitaloutput
<6>[ 3.039719] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
<6>[ 3.046550] vpbe-v4l2 vpbe-v4l2: layer=c2991800,layer->video_dev=c29918e8
<6>[ 3.054628] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
<6>[ 3.061580] vpbe-v4l2 vpbe-v4l2: layer=c2a13e00,layer->video_dev=c2a13ee8
<7>[ 3.069612] Successfully completed the probing of vpbe v4l2 device
<7>[ 3.070367] vpbe_display_init:VPBE V4L2 Display Driver V1.0 loaded
<4>[ 3.070421]
<4>[ 3.070430] line:438:@i2c_add_driver in include/linux/i2c.h
<7>[ 3.079701] power_supply battery: uevent
<7>[ 3.079740] power_supply battery: POWER_SUPPLY_NAME=battery
<7>[ 3.079806] power_supply battery: prop STATUS=Unknown
<7>[ 3.079848] power_supply battery: prop ONLINE=0
<7>[ 3.079881] power_supply battery: prop VOLTAGE_NOW=0
<7>[ 3.079915] power_supply battery: prop CAPACITY=0
<7>[ 3.080634] power_supply battery: power_supply_changed
<7>[ 3.081038] power_supply battery: power_supply_changed_work
<7>[ 3.081124] power_supply battery: uevent
<7>[ 3.081153] power_supply battery: POWER_SUPPLY_NAME=battery
<7>[ 3.081211] power_supply battery: prop STATUS=Unknown
<7>[ 3.081251] power_supply battery: prop ONLINE=0
<7>[ 3.081285] power_supply battery: prop VOLTAGE_NOW=0
<7>[ 3.081318] power_supply battery: prop CAPACITY=0
<6>[ 3.082209] max17040 1-0036: MAX17040 Fuel-Gauge Ver 00
<4>[ 3.088050] i2c-core: driver [max17040] registered
<6>[ 3.093193] watchdog watchdog: heartbeat 60 sec
<6>[ 3.099978] sdhci: Secure Digital Host Controller Interface driver
<6>[ 3.106473] sdhci: Copyright(c) Pierre Ossman
<6>[ 3.111971] davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
<4>[ 3.122876]
<4>[ 3.122889] line:438:@i2c_add_driver in include/linux/i2c.h
<4>[ 3.132728] i2c-core: driver [tlv320aic3x-codec] registered
<3>[ 3.139160] Error: Driver 'davinci-mcbsp' is already registered, aborting...
<6>[ 3.148939] asoc: cq93vc-hifi <-> davinci-vcif mapping ok
<6>[ 3.159133] ALSA device list:
<6>[ 3.163331] #0: DaVinci DM365 EVM
<6>[ 3.169932] TCP cubic registered
<6>[ 3.173577] NET: Registered protocol family 17
<6>[ 3.178199] lib80211: common routines for IEEE802.11 drivers
<7>[ 3.184101] lib80211_crypt: registered algorithm 'NULL'
<7>[ 3.184142] lib80211_crypt: registered algorithm 'WEP'
<7>[ 3.184168] lib80211_crypt: registered algorithm 'CCMP'
<7>[ 3.184191] lib80211_crypt: registered algorithm 'TKIP'
<6>[ 3.194094] net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=0)
<4>[ 3.220828] IP-Config: Complete:
<4>[ 3.223924] device=eth0, addr=192.168.0.71, mask=255.255.255.0, gw=192.168.0.1,
<4>[ 3.231761] host=192.168.0.71, domain=, nis-domain=(none),
<4>[ 3.237721] bootserver=192.168.0.60, rootserver=192.168.0.60, rootpath=
<7>[ 3.261959] UBIFS DBG (pid 1153): ubifs_bg_thread: background thread "ubifs_bgt0_0" started, PID 1153
<5>[ 3.303573] UBIFS: recovery needed
<5>[ 3.379821] UBIFS: recovery completed
<5>[ 3.383703] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
<5>[ 3.389766] UBIFS: file system size: 38473728 bytes (37572 KiB, 36 MiB, 303 LEBs)
<5>[ 3.397546] UBIFS: journal size: 5332992 bytes (5208 KiB, 5 MiB, 42 LEBs)
<5>[ 3.404955] UBIFS: media format: w4/r0 (latest is w4/r0)
<5>[ 3.410874] UBIFS: default compressor: lzo
<5>[ 3.415001] UBIFS: reserved for root: 0 bytes (0 KiB)
<7>[ 3.420222] UBIFS DBG (pid 1): mount_ubifs: compiled on: Sep 20 2015 at 20:04:53
<7>[ 3.420263] UBIFS DBG (pid 1): mount_ubifs: min. I/O unit size: 2048 bytes
<7>[ 3.420297] UBIFS DBG (pid 1): mount_ubifs: LEB size: 126976 bytes (124 KiB)
<7>[ 3.420329] UBIFS DBG (pid 1): mount_ubifs: data journal heads: 1
<7>[ 3.420364] UBIFS DBG (pid 1): mount_ubifs: UUID: 0F78019D-2129-4114-8AC8-15BA6F318145
<7>[ 3.420401] UBIFS DBG (pid 1): mount_ubifs: big_lpt 0
<7>[ 3.420432] UBIFS DBG (pid 1): mount_ubifs: log LEBs: 4 (3 - 6)
<7>[ 3.420464] UBIFS DBG (pid 1): mount_ubifs: LPT area LEBs: 2 (7 - 8)
<7>[ 3.420497] UBIFS DBG (pid 1): mount_ubifs: orphan area LEBs: 1 (9 - 9)
<7>[ 3.420530] UBIFS DBG (pid 1): mount_ubifs: main area LEBs: 303 (10 - 312)
<7>[ 3.420560] UBIFS DBG (pid 1): mount_ubifs: index LEBs: 7
<7>[ 3.420592] UBIFS DBG (pid 1): mount_ubifs: total index bytes: 757376 (739 KiB, 0 MiB)
<7>[ 3.420624] UBIFS DBG (pid 1): mount_ubifs: key hash type: 0
<7>[ 3.420653] UBIFS DBG (pid 1): mount_ubifs: tree fanout: 8
<7>[ 3.420681] UBIFS DBG (pid 1): mount_ubifs: reserved GC LEB: 287
<7>[ 3.420708] UBIFS DBG (pid 1): mount_ubifs: first main LEB: 10
<7>[ 3.420735] UBIFS DBG (pid 1): mount_ubifs: max. znode size 240
<7>[ 3.420762] UBIFS DBG (pid 1): mount_ubifs: max. index node size 192
<7>[ 3.420794] UBIFS DBG (pid 1): mount_ubifs: node sizes: data 48, inode 160, dentry 56
<7>[ 3.420830] UBIFS DBG (pid 1): mount_ubifs: node sizes: trun 56, sb 4096, master 512
<7>[ 3.420867] UBIFS DBG (pid 1): mount_ubifs: node sizes: ref 64, cmt. start 32, orph 32
<7>[ 3.420905] UBIFS DBG (pid 1): mount_ubifs: max. node sizes: data 4144, inode 4256 dentry 312
<7>[ 3.420939] UBIFS DBG (pid 1): mount_ubifs: dead watermark: 2048
<7>[ 3.420968] UBIFS DBG (pid 1): mount_ubifs: dark watermark: 6144
<7>[ 3.420997] UBIFS DBG (pid 1): mount_ubifs: LEB overhead: 2656
<7>[ 3.421030] UBIFS DBG (pid 1): mount_ubifs: max. dark space: 1861632 (1818 KiB, 1 MiB)
<7>[ 3.421067] UBIFS DBG (pid 1): mount_ubifs: maximum bud bytes: 4825088 (4712 KiB, 4 MiB)
<7>[ 3.421104] UBIFS DBG (pid 1): mount_ubifs: BG commit bud bytes: 3920384 (3828 KiB, 3 MiB)
<7>[ 3.421140] UBIFS DBG (pid 1): mount_ubifs: current bud bytes 165888 (162 KiB, 0 MiB)
<7>[ 3.421172] UBIFS DBG (pid 1): mount_ubifs: max. seq. number: 37102
<7>[ 3.421200] UBIFS DBG (pid 1): mount_ubifs: commit number: 16
<4>[ 3.423596] VFS: Mounted root (ubifs filesystem) on device 0:12.
<3>[ 3.429649] VFS: mounted rootfs
<6>[ 3.433035] Freeing init memory: 140K
<4>[ 7.179645]
<4>[ 7.179659] line:438:@i2c_add_driver in include/linux/i2c.h
<4>[ 7.188917]
<4>[ 7.188930] func:s35390a_probe in drivers/rtc/rtc-s35390a.c(235)
<3>[ 7.203545] i2c i2c-1: Failed to register i2c client dummy at 0x36 (-16)
<3>[ 7.210507] rtc-s35390a 1-0030: Address 36 unavailable
<4>[ 7.218694] rtc-s35390a: probe of 1-0030 failed with error -16
<4>[ 7.225382] i2c-core: driver [rtc-s35390a] registered
<6>[ 7.463517] musb_hdrc: version 6.0, cppi-dma, host, debug=5
<4>[ 7.469290]
<4>[ 7.469303] line:2239:@musb_probe in drivers/usb/musb/musb_core.c
<4>[ 7.478969]
<4>[ 7.478982] line:2244:@musb_probe in drivers/usb/musb/musb_core.c
<4>[ 7.488518]
<4>[ 7.488529] line:2251:@musb_probe in drivers/usb/musb/musb_core.c
<4>[ 7.498063]
<4>[ 7.498074] line:2256:@musb_probe in drivers/usb/musb/musb_core.c
<4>[ 7.507579]
<4>[ 7.507589] line:1963:@musb_init_controller in drivers/usb/musb/musb_core.c
<4>[ 7.517964]
<4>[ 7.517975] line:1973:@musb_init_controller in drivers/usb/musb/musb_core.c
<4>[ 7.528342]
<4>[ 7.528353] line:2002:@musb_init_controller in drivers/usb/musb/musb_core.c
<4>[ 7.538749]
<4>[ 7.538760] line:2031:@musb_init_controller in drivers/usb/musb/musb_core.c
<4>[ 7.549134]
<4>[ 7.549145] line:2045:@musb_init_controller in drivers/usb/musb/musb_core.c
<4>[ 7.560244]
<4>[ 7.560258] line:393:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.570353]
<4>[ 7.570365] line:397:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.580327]
<4>[ 7.580337] line:400:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.590305]
<4>[ 7.590317] line:402:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.600261]
<4>[ 7.600272] line:409:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.610210]
<4>[ 7.610220] line:412:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.620149]
<4>[ 7.620160] line:417:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.630084]
<4>[ 7.630095] line:430:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.639981]
<4>[ 7.639989] line:444:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.649909]
<4>[ 7.649920] line:449:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.659861]
<4>[ 7.659872] line:68:@phy_on in drivers/usb/musb/davinci.c
<4>[ 7.680107]
<4>[ 7.680119] line:454:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.690012]
<4>[ 7.690021] line:460:@musb_platform_init in drivers/usb/musb/davinci.c
<4>[ 7.699965]
<4>[ 7.699976] line:2057:@musb_init_controller in drivers/usb/musb/musb_core.c
<4>[ 7.710354]
<4>[ 7.710364] line:2064:@musb_init_controller in drivers/usb/musb/musb_core.c
<7>[ 7.722656] musb_hdrc: ConfigData=0x06 (UTMI-8, dyn FIFOs, SoftConn)
<7>[ 7.722702] musb_hdrc: MHDRC RTL version 1.500
<7>[ 7.722728] musb_hdrc: setup fifo_mode 2
<7>[ 7.722763] musb_hdrc: 7/9 max ep, 2624/4096 memory
<6>[ 7.722846] musb_hdrc musb_hdrc: MUSB HDRC host driver
<6>[ 7.728211] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
<6>[ 7.735779] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 7.742759] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 7.750038] usb usb1: Product: MUSB HDRC host driver
<6>[ 7.755103] usb usb1: Manufacturer: Linux 2.6.37_IPNC_DM365_4.0.0 musb-hcd
<6>[ 7.762130] usb usb1: SerialNumber: musb_hdrc
<6>[ 7.768849] hub 1-0:1.0: USB hub found
<6>[ 7.773844] hub 1-0:1.0: 1 port detected
<6>[ 7.781016] musb_hdrc musb_hdrc: USB Host mode controller at fec64000 using DMA, IRQ 12
<4>[ 7.789280]
<4>[ 7.789292] line:2261:@musb_probe in drivers/usb/musb/musb_core.c
<4>[ 7.835510] musb_hdrc: disagrees about version of symbol module_layout
<6>[ 8.107909] usbcore: registered new interface driver rtl8192cu
<6>[ 8.230162] usb 1-1: new high speed USB device using musb_hdrc and address 2
<6>[ 8.371701] usb 1-1: New USB device found, idVendor=0bda, idProduct=8176
<6>[ 8.378469] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ 8.385735] usb 1-1: Product: 802.11n WLAN Adapter
<6>[ 8.390624] usb 1-1: Manufacturer: Realtek
<6>[ 8.394756] usb 1-1: SerialNumber: 00e04c000001
<4>[ 11.303581]
<4>[ 11.303595] line:1963:@cmem_init in /work_vol/Blackbox_with_Infobank/Blackbox_with_Infobank_using_DM365/trunk/DM36x_ipnc_4.0/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
<4>[ 11.326878]
<4>[ 11.326891] line:1964:@cmem_init in /work_vol/Blackbox_with_Infobank/Blackbox_with_Infobank_using_DM365/trunk/DM36x_ipnc_4.0/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
<4>[ 11.349972]
<4>[ 11.349983] line:1965:@cmem_init in /work_vol/Blackbox_with_Infobank/Blackbox_with_Infobank_using_DM365/trunk/DM36x_ipnc_4.0/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
<4>[ 11.373059]
<4>[ 11.373070] line:1966:@cmem_init in /work_vol/Blackbox_with_Infobank/Blackbox_with_Infobank_using_DM365/trunk/DM36x_ipnc_4.0/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
<6>[ 11.396104] CMEMK module: built on Oct 4 2012 at 02:16:38
<6>[ 11.401682] Reference Linux version 2.6.37
<6>[ 11.405985] File /work_vol/Blackbox_with_Infobank/Blackbox_with_Infobank_using_DM365/trunk/DM36x_ipnc_4.0/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
<4>[ 11.424253]
<4>[ 11.424263] cmem_major=245 :line:1993:@cmem_init in /work_vol/Blackbox_with_Infobank/Blackbox_with_Infobank_using_DM365/trunk/DM36x_ipnc_4.0/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
<6>[ 11.453421] allocated heap buffer 0xc7000000 of size 0x5000000
<4>[ 11.459311] CMEM Range Overlaps Kernel Physical - allowing overlap
<4>[ 11.465749] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
<6>[ 11.473357] cmemk initialized
<4>[ 18.655978]
<4>[ 18.655992] line:438:@i2c_add_driver in include/linux/i2c.h
<4>[ 18.668383] i2c-core: driver [I2C_IF] registered
<3>[ 113.039446] musb_ep_program 845: broken !rx_reinit, ep2 csr 0020
<3>[ 151.136854] musb_ep_program 845: broken !rx_reinit, ep2 csr 0020
<3>[ 30.782495] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
<3>[ 125.056601] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
<3>[ 11.074041] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
<3>[ 147.025712] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
<3>[ 20.863217] musb_ep_program 845: broken !rx_reinit, ep2 csr 0020
<3>[ 154.133990] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
<3>[ 133.302541] musb_ep_program 845: broken !rx_reinit, ep2 csr 0020
<3>[ 16.466298] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
<3>[ 45.849087] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
<3>[ 165.383227] musb_ep_program 845: broken !rx_reinit, ep2 csr 0020
<3>[ 103.060314] musb_ep_program 845: broken !rx_reinit, ep2 csr 0020
<3>[ 175.842676] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
<3>[ 16.236657] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
<3>[ 84.892895] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
<3>[ 142.964328] musb_ep_program 845: broken !rx_reinit, ep2 csr 0020
<3>[ 80.679656] musb_ep_program 845: broken !rx_reinit, ep2 csr 0220
I still don't figure out how to solve this problem and I can't find any clues.
Can anybody help me?
