#This configuration for 3.14 kernel
pcm.card0 {
type hw
card 0
ctl.card0 {
type hw
card 0
###Dshare
pcm.VOUTL8 {
type dshare
ipc_key 6678293
ipc_key_add_uid yes
slave {
pcm "hw:0,0"
rate 8000
buffer_size 4097
period_size 1000
period_time 125000
bindings {
0 0
pcm.VOUTR8 {
type dshare
ipc_key 6678293
ipc_key_add_uid yes
slave {
pcm "hw:0,0"
rate 8000
buffer_size 4097
period_size 1000
period_time 125000
bindings {
0 1
### Dsnoop splited channels
pcm.VINL8 {
type dsnoop
ipc_key 32
slave {
pcm "hw:0,0"
rate 8000
buffer_size 4097
period_size 1000
period_time 125000
channels 2
bindings.0 0
pcm.VINR8 {
type dsnoop
ipc_key 32
slave {
pcm "hw:0,0"
rate 8000
buffer_size 4097
period_size 1000
period_time 125000
channels 2
bindings.0 1
###Dshare 16k
pcm.VOUTL16 {
type dshare
ipc_key 6678293
ipc_key_add_uid yes
slave {
pcm "hw:0,0"
rate 16000
buffer_size 4097
period_size 1000
period_time 125000
bindings {
0 0
pcm.VOUTR16 {
type dshare
ipc_key 6678293
ipc_key_add_uid yes
slave {
pcm "hw:0,0"
rate 16000
buffer_size 4097
period_size 1000
period_time 125000
bindings {
0 1
pcm.VINL16 {
type dsnoop
ipc_key 32
slave {
pcm "hw:0,0"
rate 16000
buffer_size 4097
period_size 1000
period_time 125000
channels 2
bindings.0 0
pcm.VINR16 {
type dsnoop
ipc_key 32
slave {
pcm "hw:0,0"
rate 16000
buffer_size 4097
period_size 1000
period_time 125000
channels 2
bindings.0 1
###Dshare 32k
pcm.VOUTL32 {
type dshare
ipc_key 6678293
ipc_key_add_uid yes
slave {
pcm "hw:0,0"
rate 32000
buffer_size 4097
period_size 1000
period_time 125000
bindings {
0 0
pcm.VOUTR32 {
type dshare
ipc_key 6678293
ipc_key_add_uid yes
slave {
pcm "hw:0,0"
rate 32000
buffer_size 4097
period_size 1000
period_time 125000
bindings {
0 1
pcm.VINL32 {
type dsnoop
ipc_key 32
slave {
pcm "hw:0,0"
rate 32000
buffer_size 4097
period_size 1000
period_time 125000
channels 2
bindings.0 0
pcm.VINR32 {
type dsnoop
ipc_key 32
slave {
pcm "hw:0,0"
rate 32000
buffer_size 4097
period_size 1000
period_time 125000
channels 2
bindings.0 1
###Dshare 44k
pcm.VOUTL44 {
type dshare
ipc_key 6678293
ipc_key_add_uid yes
slave {
pcm "hw:0,0"
rate 44100
buffer_size 4097
period_size 1000
period_time 125000
bindings {
0 0
pcm.VOUTR44 {
type dshare
ipc_key 6678293
ipc_key_add_uid yes
slave {
pcm "hw:0,0"
rate 44100
buffer_size 4097
period_size 1000
period_time 125000
bindings {
0 1
pcm.VINL44 {
type dsnoop
ipc_key 32
slave {
pcm "hw:0,0"
rate 44100
buffer_size 4097
period_size 1000
period_time 125000
channels 2
bindings.0 0
pcm.VINR44 {
type dsnoop
ipc_key 32
slave {
pcm "hw:0,0"
rate 44100
buffer_size 4097
period_size 1000
period_time 125000
channels 2
bindings.0 1
###Dshare 48k
pcm.VOUTL48 {
type dshare
ipc_key 6678293
ipc_key_add_uid yes
slave {
pcm "hw:0,0"
rate 48000
buffer_size 4097
period_size 1000
period_time 125000
bindings {
0 0
pcm.VOUTR48 {
type dshare
ipc_key 6678293
ipc_key_add_uid yes
slave {
pcm "hw:0,0"
rate 48000
buffer_size 4097
period_size 1000
period_time 125000
bindings {
0 1
pcm.VINL48 {
type dsnoop
ipc_key 32
slave {
pcm "hw:0,0"
rate 48000
buffer_size 4097
period_size 1000
period_time 125000
channels 2
bindings.0 0
pcm.VINR48 {
type dsnoop
ipc_key 32
slave {
pcm "hw:0,0"
rate 48000
buffer_size 4097
period_size 1000
period_time 125000
channels 2
bindings.0 1
pcm.!default VOUTR8
pcm.!default VOUTL8
pcm.!default VOUTR16
pcm.!default VOUTL16
pcm.!default VOUTR32
pcm.!default VOUTL32
pcm.!default VOUTR44
pcm.!default VOUTL44
pcm.!default VOUTR48
pcm.!default VOUTL48
I am using the above ALSA application to connect GSM two way call, I see that there seems to be a delay of 3 seconds, when GSM call is made, that ie., it takes 3 seconds to hear on the speaker of our custom board when ever we talk from GSM & the delay is same when ever we talk from board MIC to speaker of GSM
But I tried to do loopback using the below command instead of using the above attached ALSA application, but still the delay issue persists
arecord -D VINL8 -f S16_LE | aplay -D VOUTR8
Could anybody please let me know how this delay issue can be resolved, Could anybody please provide any inputs or guidance w.r.t this issue
Any help would be greatly appreciated
Kindly do the needful as early as possible
Many Thanks in advance
#include <stdio.h>
#include <stdlib.h>
#include <alsa/asoundlib.h>
#define BUF_BYTES 128
int main (int argc, char *argv[]) {
int err, rc ;
unsigned char buf_right[BUF_BYTES];
unsigned char buf_left[BUF_BYTES];
//char *buf;
int size;
snd_pcm_t *playback_handle_right;
snd_pcm_t *capture_handle_right;
snd_pcm_t *playback_handle_left;
snd_pcm_t *capture_handle_left;
#if 0
char* device = "default";
if (argc > 1) device = argv[1];
#endif
char* crdevice ;
char* prdevice ;
char* cldevice ;
char* pldevice ;
unsigned int rate ;
unsigned int nchannels = 1;
snd_pcm_format_t format = SND_PCM_FORMAT_S16_LE;
unsigned int buf_frames_right = BUF_BYTES / nchannels / 2;
unsigned int buf_frames_left = BUF_BYTES / nchannels / 2;
// system("amixer set 'Power Control' 'off'");
if(argc != 2 )
printf("\nUsage is : application sampling_rate \n\n\t Ex: ./gsm_application_target 8000 \n\n\t Supported sampling rates are: \n\t 1) 8000 \n\t 2) 16000 \n\t 3) 32000 \n\t 4) 44100 \n\t 5) 48000 \n\n NOTE: Any number other than given sampling rate takes default as 48000\n\n");
exit(1);
rate = (int)atoi(argv[1]);
if(rate == 8000)
crdevice = "VINR8";
prdevice = "VOUTR8";
cldevice = "VINL8";
pldevice = "VOUTL8";
}else if(rate == 16000)
crdevice = "VINR16";
prdevice = "VOUTR16";
cldevice = "VINL16";
pldevice = "VOUTL16";
}else if(rate == 32000)
crdevice = "VINR32";
prdevice = "VOUTR32";
cldevice = "VINL32";
pldevice = "VOUTL32";
}else if(rate == 44100)
crdevice = "VINR44";
prdevice = "VOUTR44";
cldevice = "VINL44";
pldevice = "VOUTL44";
}else
crdevice = "VINR48";
prdevice = "VOUTR48";
cldevice = "VINL48";
pldevice = "VOUTL48";
rate = 48000;
///// RIGHT CHANNEL
newStart:
if ((err = snd_pcm_open (&playback_handle_right, prdevice, SND_PCM_STREAM_PLAYBACK, 0)) < 0) {
fprintf (stderr, "cannot open playback right audio device %s (%s)\n", prdevice, snd_strerror (err)); exit (1);
else
printf("Opened Playback right audio device successfully %s \n", prdevice);
if ((err = snd_pcm_set_params(playback_handle_right, format, SND_PCM_ACCESS_RW_INTERLEAVED, nchannels, rate, 1, 500000)) < 0) { /* 0.5sec */
fprintf(stderr, "Playback right open error: %s\n", snd_strerror(err)); exit(1);
if ((err = snd_pcm_open (&capture_handle_right, crdevice, SND_PCM_STREAM_CAPTURE, 0)) < 0) {
fprintf (stderr, "cannot open capture right audio device %s (%s)\n", crdevice, snd_strerror (err)); exit (1);
else
printf("Opened Capture right audio device successfully %s \n", crdevice);
if ((err = snd_pcm_set_params(capture_handle_right, format, SND_PCM_ACCESS_RW_INTERLEAVED, nchannels, rate, 1, 500000)) < 0) { /* 0.5sec */
fprintf(stderr, "capture right open error: %s\n", snd_strerror(err)); exit(1);
////LEFT CHANNEL
if ((err = snd_pcm_open (&playback_handle_left, pldevice, SND_PCM_STREAM_PLAYBACK, 0)) < 0) {
fprintf (stderr, "cannot open playback left audio device %s (%s)\n", pldevice, snd_strerror (err)); exit (1);
else
printf("Opened Playback left audio device successfully %s \n", pldevice);
if ((err = snd_pcm_set_params(playback_handle_left, format, SND_PCM_ACCESS_RW_INTERLEAVED, nchannels, rate, 1, 500000)) < 0) { /* 0.5sec */
fprintf(stderr, "Playback left open error: %s\n", snd_strerror(err)); exit(1);
if ((err = snd_pcm_open (&capture_handle_left, cldevice, SND_PCM_STREAM_CAPTURE, 0)) < 0) {
fprintf (stderr, "cannot open capture left audio device %s (%s)\n", cldevice, snd_strerror (err)); exit (1);
else
printf("Opened Capture left audio device successfully %s \n", crdevice);
if ((err = snd_pcm_set_params(capture_handle_left, format, SND_PCM_ACCESS_RW_INTERLEAVED, nchannels, rate, 1, 500000)) < 0) { /* 0.5sec */
fprintf(stderr, "capture left open error: %s\n", snd_strerror(err)); exit(1);
while(1) {
///// RIGHT CHANNEL
/***** Read the Frames from the Capture Device ******/
err = snd_pcm_readi(capture_handle_right, buf_right, buf_frames_right);
if(err == -EPIPE)
printf("capture right func: overrun!");
rc = snd_pcm_prepare(capture_handle_right);
if(rc < 0)
printf("Fail to recover from problem, Need to reopen the device\n");
// goto reStart;
}else if(err < 0)
fprintf (stderr, "read from audio interface right failed (%s)\n", snd_strerror (err));
rc = snd_pcm_recover(capture_handle_right,err,0);
if(rc < 0)
// goto reStart;
}else if(err != (int)buf_frames_right)
fprintf(stderr, "short read, read %d frames\n", err);
/**** Write the capture frame to playback ******/
err = snd_pcm_writei (playback_handle_right, buf_right, buf_frames_right);
if(err == -EPIPE)
printf("Playback right func: overrun!");
rc = snd_pcm_prepare(playback_handle_right);
if(rc < 0)
// goto reStart;
}else if(err < 0)
fprintf (stderr, "write to audio interface right failed (%s)\n", snd_strerror (err));
rc = snd_pcm_recover(playback_handle_right, err, 0);
if(rc < 0)
//goto reStart;
fprintf(stderr, "short write, write %d frames\n", err);
////LEFT CHANNEL
err = snd_pcm_readi(capture_handle_left, buf_left, buf_frames_left);
if(err == -EPIPE)
rc = snd_pcm_prepare(capture_handle_left);
if(rc < 0)
// goto reStart;
}else if(err < 0)
rc = snd_pcm_recover(capture_handle_left,err,0);
if(rc < 0)
// goto reStart;
}else if(err != (int)buf_frames_left)
err = snd_pcm_writei (playback_handle_left, buf_left, buf_frames_left);
if(err == -EPIPE)
rc = snd_pcm_prepare(playback_handle_left);
if(rc < 0)
// goto reStart;
}else if(err < 0)
rc = snd_pcm_recover(playback_handle_left, err, 0);
if(rc < 0)
// goto reStart;
reStart: fprintf (stderr, "close handles\n");
snd_pcm_close (playback_handle_right);
snd_pcm_close (capture_handle_right);
snd_pcm_close (playback_handle_left);
snd_pcm_close (capture_handle_left);
sleep(2);
//goto newStart;
return 0;
