alsa audio open error
Dear Ti E2E Community,
I facing the below error, am using am335x & ti sdk 8
Something wrong when execute arecord & aplay :
arecord and aplay does not work for the first time & it works after throwing error after 5 times
Couple of times I get the below error:
root@lifeline:/# arecord -D VINL8 -f S16_LE | aplay -D VOUTR8
Recording WAVE 'stdin' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
Playing WAVE 'stdin' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
^CAborted by signal Interrupt...
ALSA lib /home/jenkins/amsdk-nightly-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8t2hf-vfp-neon-oe-linux-gnueabi/alsa-lib/1.0.27.2-r0/alsa-lib-1.0.27.2/src/pcm/pcm_dsnoop.c:618:(snd_pcm_dsnoop_open) unable to open slave
arecord: main:722: audio open error: Invalid argument
aplay: playback:2715: read error
ALSA lib /home/jenkins/amsdk-nightly-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa8t2hf-vfp-neon-oe-linux-gnueabi/alsa-lib/1.0.27.2-r0/alsa-lib-1.0.27.2/src/pcm/pcm_dshare.c:710:(snd_pcm_dshare_open) unable to open slave
aplay: main:722: audio open error: Invalid argument
But there is no answer...
Could someone give me some clues?
