RDK enc fps reduce
*** Capture Driver Advanced Statistics ***
[m3vpss ]
[m3vpss ] VIP Parser Reset Count : 0
[m3vpss ]
[m3vpss ] | Total Even Odd Total Even Odd Min / Max Min / Max Dropped Fid Repeat Frame Error Y/C
[m3vpss ] CH | Fields Fields Fields FPS FPS FPS Width Height Fields Count (Desc Error Y/C)
[m3vpss ] ------------------------------------------------------------------------------------------------------------
[m3vpss ] 000 | 2587 2587 0 60 60 0 1920 / 1920 1080 / 1080 81 0 0/0 (0/0)
[m3vpss ] 200 | 2587 2587 0 60 60 0 1920 / 1920 1080 / 1080 1136 0 0/0 (0/0)
[m3vpss ]
[m3vpss ] VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
[m3vpss ] VIP Capture Port 2 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
[m3vpss ]
[m3vpss ] *** Capture List Manager Advanced Statistics ***
[m3vpss ]
[m3vpss ] List Post Count : 10783
[m3vpss ] List Stall Count : 0
[m3vpss ] List Post Time (ms) : Max = 0, Min = 0, Avg = 0, Total = 0
[m3vpss ] INTC Timeout Count : (0, 0) (Min timeout value = 969, 990)
[m3vpss ] Descriptor miss found count : 0
[m3vpss ]
[m3vpss ]
[m3vpss ] VIP and VPDMA registers,
[m3vpss ] VIP0 : FIQ_STATUS : 0x4810551c = 0x00000000
[m3vpss ] VIP1 : FIQ_STATUS : 0x48105a1c = 0x00000000
[m3vpss ] VPDMA: LIST_BUSY : 0x4810d00c = 0x00760000
[m3vpss ]
[m3vpss ]
[m3vpss ] 58852: CAPTURE: Fields = 3957 (fps = 91, CPU Load = 0)
[m3vpss ] 58852: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 58852: SYSTEM : FREE SPACE : System Heap = 66512 B, Mbx = 10229 msgs)
[m3vpss ] 58852: SYSTEM : FREE SPACE : SR0 Heap = 8713728 B (8 MB)
[m3vpss ] 58853: SYSTEM : FREE SPACE : Frame Buffer = 1541504 B (1 MB)
[m3vpss ] 58853: SYSTEM : FREE SPACE : Bitstream Buffer = 184969088 B (176 MB)
[m3vpss ] 58856: SYSTEM : FREE SPACE : Tiler Buffer = 199 B (0 MB) - TILER OFF
[m3vpss ]
[m3vpss ] *** [DEI0 ] DEI Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time : 20 secs
[m3vpss ] Total Fields Processed : 5534
[m3vpss ] Total Fields FPS : 130 FPS
[m3vpss ]
[m3vpss ]
[m3vpss ] CH | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency
[m3vpss ] Num | FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS FPS Skip FPS Skip FPS Skip FPS Skip FPS Skip FPS Min / Max
[m3vpss ] -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 60 0 60 0 60 0 0 0 60 0 0 0 0 0 0 0 0 0 120 / 180
[m3vpss ] 1 | 34 0 34 0 34 0 0 0 34 0 0 0 0 0 0 0 0 0 65 / 173
[m3vpss ] 2 | 37 0 37 0 37 0 0 0 37 0 0 0 0 0 0 0 0 0 87 / 164
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Statistics ***
[m3vpss ]
[m3vpss ] Elasped Time: 20 secs
[m3vpss ]
[m3vpss ] Output Request FPS : 61 fps (1226 frames)
[m3vpss ] Output Actual FPS : 37 fps (754 frames)
[m3vpss ] Output Drop FPS : 23 fps (472 frames)
[m3vpss ] Output Reject FPS : 0 fps (0 frames)
[m3vpss ] Scaling Internal : 16 ms
[m3vpss ] Scaling Internal min : 1 ms
[m3vpss ] Scaling Internal max : 23 ms
[m3vpss ]
[m3vpss ] Win | Window Repeat Drop Recv Que FID Invlid Acc Event Invalid Que Reject Reject Latency OutBufCopy InBufCopy
[m3vpss ] Num | FPS FPS FPS FPS FPS FPS Count (Max/Min) CH Frames Frames Frames Min / Max FPS FPS
[m3vpss ] 0 | 37 0 22 60 37 0 356 ( 8/ 5) 0 0 0 55 / 135 0 0
[m3vpss ] 1 | 37 29 0 8 8 0 0 ( 0/255) 0 0 0 19 / 195 0 0
[m3vpss ] 2 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 0 0
[m3vpss ] 3 | 0 0 0 0 0 0 0 ( 0/255) 0 0 0 65535 / 0 0 0
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 60
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame |
[m3vpss ] 0 | 0 | 0, 0 | 1920 x 1080 | 2048 / 2048 | NON-TILED | 0, 0 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 1 | 1 | 0, 0 | 1920 x 1080 | 2048 / 2048 | NON-TILED | 960, 0 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 420SP | OFF |
[m3vpss ] 2 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 540 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 422I | ON |
[m3vpss ] 3 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 960, 540 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 422I | ON |
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Statistics ***
[m3vpss ]
[m3vpss ]
[m3vpss ] Output Request FPS : 50 fps (1019 frames)
[m3vpss ] Output Actual FPS : 50 fps (1019 frames)
[m3vpss ] Output Drop FPS : 0 fps (0 frames)
[m3vpss ] Scaling Internal : 20 ms
[m3vpss ] Scaling Internal min : 19 ms
[m3vpss ] Scaling Internal max : 24 ms
[m3vpss ]
[m3vpss ] 0 | 50 0 9 60 50 0 184 ( 5/ 5) 0 0 0 60 / 95 0 0
[m3vpss ] 1 | 50 16 0 34 34 0 0 ( 0/255) 0 0 0 10 / 112 0 0
[m3vpss ]
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 16 | 0, 0 | 1920 x 1080 | 3840 / 3840 | NON-TILED | 0, 270 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 422I | OFF |
[m3vpss ] 1 | 17 | 0, 0 | 1920 x 1080 | 3840 / 3840 | NON-TILED | 960, 270 | 960 x 540 | 3840 / 0 | NON-TILED | OFF | 0 | 422I | OFF |
[m3vpss ] 2 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 0 | 1920 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | ON |
[m3vpss ] 3 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 810 | 1920 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | ON |
[m3vpss ]
[m3vpss ]
[m3vpss ] 59033: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 73 / 144 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 47 / 116 ) !!!
[m3vpss ] 59033: DISPLAY DRV: HDDAC(BP0) : Q:[1583] Display:[2596], Repeat:[1014], DQ:[1581]
[m3vpss ] 59033: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1244, HDDAC(BP0) 1247, DVO2(BP1) 1247, SDDAC(SEC1) 2528
[m3vpss ] 59033: SYSTEM : FREE SPACE : System Heap = 66512 B, Mbx = 10233 msgs)
[m3vpss ] 59033: SYSTEM : FREE SPACE : SR0 Heap = 8713728 B (8 MB)
[m3vpss ] 59033: SYSTEM : FREE SPACE : Frame Buffer = 1541504 B (1 MB)
[m3vpss ] 59034: SYSTEM : FREE SPACE : Bitstream Buffer = 184969088 B (176 MB)
[m3vpss ] 59034: SYSTEM : FREE SPACE : Tiler Buffer = 199 B (0 MB) - TILER OFF
[m3vpss ] 59034: DISPLAY: DVO2(BP1) : 59 fps, Latency (Min / Max) = ( 73 / 92 ), Callback Interval (Min / Max) = ( 16 / 17 ) DropCount:0 DispLatency (Min / Max) = ( 47 / 66 ) !!!
[m3vpss ] 59034: DISPLAY DRV: DVO2(BP1) : Q:[2134] Display:[2594], Repeat:[462], DQ:[2131]
[m3vpss ]
[m3vpss ] *** IpcFramesOutRTOS Statistics ***
[m3vpss ]
[m3vpss ] Total Fields Processed : 1773
[m3vpss ] Total Fields FPS : 88 FPS
[m3vpss ]
[m3vpss ]
[m3vpss ] CH | In Recv In Process In Skip
[m3vpss ] 0 | 37 37 0
[m3vpss ] 1 | 50 50 0
[m3vpss ]
[c6xdsp ]
[c6xdsp ] *** SCD Statistics ***
[c6xdsp ]
[c6xdsp ] Elasped Time : 20 secs
[c6xdsp ] Total Fields Processed : 0
[c6xdsp ] Total Fields FPS : 0 FPS
[c6xdsp ]
[c6xdsp ]
[c6xdsp ] CH | In Recv In Process User Skip Process Skip In Process Time
[c6xdsp ] Num | FPS FPS FPS FPS per frame (msec)
[c6xdsp ] ----------------------------------------------------------------
[c6xdsp ]
[m3video] 65036: HDVICP-ID:0
[m3video] All percentage figures are based off totalElapsedTime
[m3video] totalAcquire2wait :0 %
[m3video] totalWait2Isr :23 %
[m3video] totalIsr2Done :0 %
[m3video] totalWait2Done :24 %
[m3video] totalDone2Release :0 %
[m3video] totalAcquire2Release :24 %
[m3video] totalAcq2acqDelay :75 %
[m3video] totalElapsedTime in msec : 49227
[m3video] numAccessCnt: 854
[m3video] IVA-FPS : 17
[m3video] Average time spent per frame in microsec: 13257
[m3video] 65037: HDVICP-ID:1
[m3video] totalWait2Isr :75 %
[m3video] totalWait2Done :75 %
[m3video] totalAcquire2Release :75 %
[m3video] totalAcq2acqDelay :24 %
[m3video] totalElapsedTime in msec : 49261
[m3video] numAccessCnt: 2847
[m3video] IVA-FPS : 58
[m3video] Average time spent per frame in microsec: 12976
[m3video] 65038: HDVICP-ID:2
[m3video] totalWait2Isr :68 %
[m3video] totalWait2Done :68 %
[m3video] totalAcquire2Release :68 %
[m3video] totalAcq2acqDelay :31 %
[m3video] totalElapsedTime in msec : 49128
[m3video] numAccessCnt: 2819
[m3video] IVA-FPS : 57
[m3video] Average time spent per frame in microsec: 11850
[m3video]
[m3video] *** ENCODE Statistics ***
[m3video]
[m3video] Elasped Time : 20 secs
[m3video]
[m3video]
[m3video] CH | In Recv In Skip In User Out Latency
[m3video] Num | FPS FPS Skip FPS FPS Min / Max
[m3video] --------------------------------------------
[m3video] 0 | 60 0 0 60 255 / 14664
[m3video] 1 | 34 0 26 8 255 / 14645
[m3video] 2 | 37 0 37 0 255 / 0
[m3video]
[m3video] Multi Channel Encode Average Submit Batch Size
[m3video] Max Submit Batch Size : 24
[m3video] IVAHD_0 Average Batch Size : 1
[m3video] IVAHD_0 Max achieved Batch Size : 1
[m3video] IVAHD_1 Average Batch Size : 1
[m3video] IVAHD_1 Max achieved Batch Size : 1
[m3video] IVAHD_2 Average Batch Size : 0
[m3video] IVAHD_2 Max achieved Batch Size : 0
[m3video]
[m3video] Multi Channel Encode Batch break Stats
[m3video] Total Number of Batches created: 174
[m3video] All numbers are based off total number of Batches created
[m3video] Batch breaks due to batch sizeexceeding limit: 100 %
[m3video] Batch breaks due to ReqObj Que being empty: 0 %
[m3video] Batch breaks due to changed resolution class: 0 %
[m3video] Batch breaks due to interlace and progressivecontent mix: 0 %
[m3video] Batch breaks due to channel repeat: 0 %
[m3video] Batch breaks due to different codec: 0 %
[m3video] Total Number of Batches created: 1205
[m3video] Total Number of Batches created: 0
[m3video] Batch breaks due to batch sizeexceeding limit: 0 %
[m3video]
[m3video] *** DECODE Statistics ***
[m3video]
[m3video]
[m3video]
[m3video] CH | In Recv In User Out
[m3video] Num | FPS Skip FPS FPS
[m3video] 0 | 60 0 60
[m3video] 1 | 8 0 8
[m3video] 2 | 0 0 0
[m3video] 3 | 0 0 0
[m3video] 4 | 0 0 0
[m3video] 5 | 0 0 0
[m3video] 6 | 0 0 0
[m3video] 7 | 0 0 0
[m3video] 8 | 0 0 0
[m3video] 9 | 0 0 0
[m3video] 10 | 0 0 0
[m3video] 11 | 0 0 0
[m3video] 12 | 0 0 0
[m3video] 13 | 0 0 0
[m3video] 14 | 0 0 0
[m3video] 15 | 0 0 0
[m3video]
[m3video] Multi Channel Decode Average Submit Batch Size
[m3video] IVAHD_1 Average Batch Size : 0
[m3video] IVAHD_1 Max achieved Batch Size : 0
[m3video] IVAHD_2 Average Batch Size : 1
[m3video] IVAHD_2 Max achieved Batch Size : 1
[m3video]
[m3video] Multi Channel Decode Batch break Stats
[m3video] Total Number of Batches created: 1206
[m3video]
[m3vpss ]
[m3vpss ] 68046: LOAD: CPU: 22.2% HWI: 4.9%, SWI:2.7%
[m3vpss ]
[m3vpss ] 68046: LOAD: TSK: IPC_OUT_M30 : 0.7%
[m3vpss ] 68046: LOAD: TSK: IPC_IN_M30 : 0.3%
[m3vpss ] 68047: LOAD: TSK: IPC_FRAMES_OUT0 : 1.3%
[m3vpss ] 68047: LOAD: TSK: CAPTURE : 0.5%
[m3vpss ] 68047: LOAD: TSK: DEI0 : 1.5%
[m3vpss ] 68047: LOAD: TSK: DISPLAY0 : 0.5%
[m3vpss ] 68047: LOAD: TSK: DISPLAY1 : 0.6%
[m3vpss ] 68047: LOAD: TSK: DUP0 : 0.3%
[m3vpss ] 68047: LOAD: TSK: DUP1 : 0.5%
[m3vpss ] 68047: LOAD: TSK: DUP2 : 0.2%
[m3vpss ] 68048: LOAD: TSK: SWMS0 : 2.1%
[m3vpss ] 68048: LOAD: TSK: SWMS1 : 2.4%
[m3vpss ] 68048: LOAD: TSK: MERGE0 : 0.3%
[m3vpss ] 68048: LOAD: TSK: MERGE1 : 0.2%
[m3vpss ] 68048: LOAD: TSK: MERGE2 : 0.2%
[m3vpss ] 68048: LOAD: TSK: MISC : 3.0%
[m3vpss ]
[m3video]
[m3video] 68549: LOAD: CPU: 12.4% HWI: 1.3%, SWI:2.1%
[m3video]
[m3video] 68549: LOAD: TSK: IPC_OUT_M30 : 0.7%
[m3video] 68549: LOAD: TSK: IPC_IN_M30 : 0.2%
[m3video] 68549: LOAD: TSK: IPC_BITS_IN0 : 0.3%
[m3video] 68549: LOAD: TSK: IPC_BITS_OUT0 : 0.7%
[m3video] 68549: LOAD: TSK: ENC0 : 1.4%
[m3video] 68549: LOAD: TSK: DEC0 : 1.9%
[m3video] 68549: LOAD: TSK: DEC_PROCESS_TSK_0 : 0.2%
[m3video] 68549: LOAD: TSK: DEC_PROCESS_TSK_2 : 1.3%
[m3video] 68550: LOAD: TSK: ENC_PROCESS_TSK_0 : 0.2%
[m3video] 68550: LOAD: TSK: ENC_PROCESS_TSK_1 : 1.5%
[m3video] 68550: LOAD: TSK: MISC : 0.6%
[m3video]
[c6xdsp ]
[c6xdsp ] 67328: LOAD: CPU: 0.6% HWI: 0.1%, SWI:0.0%
[c6xdsp ]
[c6xdsp ] 67328: LOAD: TSK: IPC_FRAMES_IN0 : 0.2%
[c6xdsp ] 67328: LOAD: TSK: ALG0 : 0.1%
[c6xdsp ] 67328: LOAD: TSK: MISC : 0.2%
[c6xdsp ]
above is my app log . i want to know why the enc out fps reduced from 34 to 8
tks
