MAD tools error for C6678 DSP
Hello all,
im trying to generate ROMFS .bin file from MAD utility and used deployment_template_C6678.json file with 3 .out files.  Its giving me error like ERROR: addFile() File1 name already exists.
my deployment_template_C6678.json file is looks like after some modification,
"deviceName" : "C6678",
"partitions" : [
"name" : "load-partition",
"vaddr" : "0x9e000000",
"size" : "0x1000000",
"loadPartition" : true
"applications" : [
"name" : "app1",
"fileName" : "C:\\ti\\mcsdk_2_01_02_05\\tools\\boot_loader\\mad-utils\\mad-loader\\examples\\app_1\\build\\Hello1.out",
"libPath" : "C:\\ti\\mcsdk_2_01_02_05\\tools\\boot_loader\\mad-utils\\mad-loader\\examples\\shlibs\\build",
"allowedCores" : [0,1,2]
"name" : "app1",
"fileName" : "C:\\ti\\mcsdk_2_01_02_05\\tools\\boot_loader\\mad-utils\\mad-loader\\examples\\app_1\\build\\Hello3.out",
"name" : "app2",
"fileName" : "C:\\ti\\mcsdk_2_01_02_05\\tools\\boot_loader\\mad-utils\\mad-loader\\examples\\app_2\\build\\Hello2.out",
"appDeployment" : [
"app1",
"app1",
"app2",
and the error what i got is,
$ python maptool.py ./config-files/maptoolCfg_C6678.json bypass-prelink
MAP tool executing in prelink bypass mode
c:\ti\mcsdk_2_01_02_05\tools\boot_loader\mad-utils\map-tool>"C:\ti\ccsv5\tools\c
ompiler\c6000_7.4.1\bin\strip6x" -o=./tmp/strippedImages\app1.strip ./images/app
Images\app1
Images\app1
error: unable to rename C:/Users/HPLAPT~1/AppData/Local/Temp\050762 to
./tmp/strippedImages\app1.strip: File exists
ompiler\c6000_7.4.1\bin\strip6x" -o=./tmp/strippedImages\app2.strip ./images/app
Images\app2
ompiler\c6000_7.4.1\bin\ofd6x" -x -o c:\users\hplapt~1\appdata\local\temp\tmpxau
dj3.xml "./tmp/strippedImages\app1.strip"
ompiler\c6000_7.4.1\bin\ofd6x" -x -o c:\users\hplapt~1\appdata\local\temp\tmp46c
kec.xml "./tmp/strippedImages\app1.strip"
ompiler\c6000_7.4.1\bin\ofd6x" -x -o c:\users\hplapt~1\appdata\local\temp\tmp5rz
ksg.xml "./tmp/strippedImages\app2.strip"
ompiler\c6000_7.4.1\bin\ofd6x" -x -o c:\users\hplapt~1\appdata\local\temp\tmppyt
yi7.xml "./tmp/fs\mal_app"
ompiler\c6000_7.4.1\bin\ofd6x" -x -o c:\users\hplapt~1\appdata\local\temp\tmp1qc
t5j.xml "./tmp/fs\nml"
 can anyone tell me where i did mistake ??
regards,
Gourav
  • Hi Gourav,
    I think, the "applications" section can cause the issue. The "app1" is linked with file name "Hello1.out" now you are trying to link same name for another application named "Hello3.out".
    "name" : "app1",
    Please try following,
    "applications" : [
    "name" : "app1",
    "name" : "app2",
    "appDeployment" : [
    "app1",
    "app1",
    "app2",
    (or)
    "applications" : [
    "name" : "app1",
    "name" : "app2",
    "name" : "app3",
    "fileName" : "C:\\ti\\mcsdk_2_01_02_05\\tools\\boot_loader\\mad-utils\\mad-loader\\examples\\app_3\\build\\Hello3.out",
    "appDeployment" : [
    "app1",
    "app2",
    "app3",
    Thank you.
  • Hi Raja,
    grt . 2nd option is working including all three .out files. (in first option you have not included 3rd .out file)
    thanks for your quick response !!!
    regards,
    Gourav
